[PATCH] arm64: zynqmp: Corrected pcap_prog register address
Currently the pcap_prog struct variable is pointing to 0x3004 which is incorrect according to [1]. The variable should point to 0x3000.
[1] https://www.xilinx.com/htmldocs/registers/ug1087/ug1087-zynq-ultrascale-regi...
Signed-off-by: Lukas Funke lukas.funke@weidmueller.com ---
arch/arm/mach-zynqmp/include/mach/hardware.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/mach-zynqmp/include/mach/hardware.h b/arch/arm/mach-zynqmp/include/mach/hardware.h index 634bf169c6..8cb6494e52 100644 --- a/arch/arm/mach-zynqmp/include/mach/hardware.h +++ b/arch/arm/mach-zynqmp/include/mach/hardware.h @@ -166,7 +166,7 @@ struct csu_regs { u32 jtag_dap_cfg; u32 idcode; u32 version; - u32 reserved2[3055]; + u32 reserved2[3054]; u32 pcap_prog; };
- u32 reserved2[3054]; u32 pcap_prog; };
Good catch. Applied. M
Michal Simek
