[PATCH 1/6] scripts: remove some configs in config_whitelist.txt
Remove some config finishing by _ badly added by scripts/build-whitelist.sh when joker is used in comments.
for example: doc/uImage.FIT/command_syntax_extensions.txt: ... #ifdef CONFIG_OF_* | ...
cmd/nvedit.c:# error Define one of CONFIG_ENV_IS_IN_{EEPROM| \ FLASH|MMC|FAT|EXT4|\
Remove also configs only used in comments: - CONFIG_BOOGER in include/linux/kconfig.h - CONFIG_COMMANDS - CONFIG_INIT_IGNORE_ERROR - CONFIG_REG_* - CONFIG_HOTPLUG : drivers/watchdog/omap_wdt.c:18
Signed-off-by: Patrick Delaunay patrick.delaunay@foss.st.com ---
arch/arm/include/asm/arch-omap5/dra7xx_iodelay.h | 8 ++++---- include/configs/M5235EVB.h | 2 +- include/configs/dra7xx_evm.h | 1 - scripts/config_whitelist.txt | 14 -------------- 4 files changed, 5 insertions(+), 20 deletions(-)
diff --git a/arch/arm/include/asm/arch-omap5/dra7xx_iodelay.h b/arch/arm/include/asm/arch-omap5/dra7xx_iodelay.h index ea2f113f98..df392a2714 100644 --- a/arch/arm/include/asm/arch-omap5/dra7xx_iodelay.h +++ b/arch/arm/include/asm/arch-omap5/dra7xx_iodelay.h @@ -11,7 +11,7 @@
#include <asm/arch/sys_proto.h>
-/* CONFIG_REG_0 */ +/* CFG REG_0 */ #define CFG_REG_0_OFFSET 0xC #define CFG_REG_ROM_READ_SHIFT 1 #define CFG_REG_ROM_READ_MASK (1 << 1) @@ -22,18 +22,18 @@ #define CFG_REG_ROM_READ_START (1 << 1) #define CFG_REG_ROM_READ_END (0 << 1)
-/* CONFIG_REG_2 */ +/* CFG REG_2 */ #define CFG_REG_2_OFFSET 0x14 #define CFG_REG_REFCLK_PERIOD_SHIFT 0 #define CFG_REG_REFCLK_PERIOD_MASK (0xFFFF << 0) #define CFG_REG_REFCLK_PERIOD 0x2EF
-/* CONFIG_REG_8 */ +/* CFG REG_8 */ #define CFG_REG_8_OFFSET 0x2C #define CFG_IODELAY_UNLOCK_KEY 0x0000AAAA #define CFG_IODELAY_LOCK_KEY 0x0000AAAB
-/* CONFIG_REG_3/4 */ +/* CFG REG_3/4 */ #define CFG_REG_3_OFFSET 0x18 #define CFG_REG_4_OFFSET 0x1C #define CFG_REG_DLY_CNT_SHIFT 16 diff --git a/include/configs/M5235EVB.h b/include/configs/M5235EVB.h index f983281cc1..b37c915538 100644 --- a/include/configs/M5235EVB.h +++ b/include/configs/M5235EVB.h @@ -54,7 +54,7 @@ #define CONFIG_SYS_I2C_PINMUX_CLR ~(GPIO_PAR_FECI2C_SCL_MASK | GPIO_PAR_FECI2C_SDA_MASK) #define CONFIG_SYS_I2C_PINMUX_SET (GPIO_PAR_FECI2C_SCL_I2CSCL | GPIO_PAR_FECI2C_SDA_I2CSDA)
-/* this must be included AFTER the definition of CONFIG_COMMANDS (if any) */ +/* this must be included AFTER the definition of CONFIG COMMANDS (if any) */ #define CONFIG_BOOTFILE "u-boot.bin" #ifdef CONFIG_MCFFEC # define CONFIG_IPADDR 192.162.1.2 diff --git a/include/configs/dra7xx_evm.h b/include/configs/dra7xx_evm.h index 361ee9663d..16766943ab 100644 --- a/include/configs/dra7xx_evm.h +++ b/include/configs/dra7xx_evm.h @@ -113,7 +113,6 @@ #define CONFIG_SYS_MAX_FLASH_SECT 512 #define CONFIG_SYS_FLASH_CFI_WIDTH FLASH_CFI_16BIT #define CONFIG_SYS_FLASH_SIZE (64 * 1024 * 1024) /* 64 MB */ -/* #define CONFIG_INIT_IGNORE_ERROR */ #define CONFIG_SYS_MAX_FLASH_BANKS 1 #define CONFIG_SYS_FLASH_BASE (0x08000000) #define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 61ae682dcd..ca043b2f26 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -75,10 +75,8 @@ CONFIG_BOARD_IS_OPENRD_ULTIMATE CONFIG_BOARD_NAME CONFIG_BOARD_POSTCLK_INIT CONFIG_BOARD_SIZE_LIMIT -CONFIG_BOOGER CONFIG_BOOTFILE CONFIG_BOOTMODE -CONFIG_BOOTP_ CONFIG_BOOTP_BOOTFILESIZE CONFIG_BOOTP_DHCP_REQUEST_DELAY CONFIG_BOOTP_ID_CACHE_SIZE @@ -147,7 +145,6 @@ CONFIG_CM_T3X CONFIG_CM_T43 CONFIG_CM_TCRAM CONFIG_COLDFIRE -CONFIG_COMMANDS CONFIG_COMMON_BOOT CONFIG_COMPAT CONFIG_CONS_EXTC_PINSEL @@ -227,7 +224,6 @@ CONFIG_DNET_AUTONEG_TIMEOUT CONFIG_DP_DDR_CTRL CONFIG_DP_DDR_DIMM_SLOTS_PER_CTLR CONFIG_DP_DDR_NUM_CTRLS -CONFIG_DRAM_TIMINGS_ CONFIG_DRIVER_DM9000 CONFIG_DSP_CLUSTER_START CONFIG_DWCDDR21MCTL @@ -267,7 +263,6 @@ CONFIG_ENV_CALLBACK_LIST_STATIC CONFIG_ENV_FLAGS_LIST_DEFAULT CONFIG_ENV_FLAGS_LIST_STATIC CONFIG_ENV_IS_EMBEDDED -CONFIG_ENV_IS_IN_ CONFIG_ENV_MAX_ENTRIES CONFIG_ENV_MIN_ENTRIES CONFIG_ENV_OFFSET_OOB @@ -460,7 +455,6 @@ CONFIG_HIKEY_GPIO CONFIG_HITACHI_SX14 CONFIG_HOSTNAME CONFIG_HOST_MAX_DEVICES -CONFIG_HOTPLUG CONFIG_HPS_ALTERAGRP_DBGATCLK CONFIG_HPS_ALTERAGRP_MAINCLK CONFIG_HPS_ALTERAGRP_MPUCLK @@ -634,7 +628,6 @@ CONFIG_IMX6_PWM_PER_CLK CONFIG_IMX_HDMI CONFIG_IMX_VIDEO_SKIP CONFIG_INETSPACE_V2 -CONFIG_INIT_IGNORE_ERROR CONFIG_INI_ALLOW_MULTILINE CONFIG_INI_CASE_INSENSITIVE CONFIG_INI_MAX_LINE @@ -943,7 +936,6 @@ CONFIG_NUM_DSP_CPUS CONFIG_NUM_PAMU CONFIG_ODROID_REV_AIN CONFIG_OFF_PADCONF -CONFIG_OF_ CONFIG_OMAP_EHCI_PHY1_RESET_GPIO CONFIG_OMAP_EHCI_PHY2_RESET_GPIO CONFIG_OMAP_EHCI_PHY3_RESET_GPIO @@ -1073,10 +1065,6 @@ CONFIG_RD_LVL CONFIG_REALMODE_DEBUG CONFIG_RED_LED CONFIG_REG -CONFIG_REG_0 -CONFIG_REG_2 -CONFIG_REG_3 -CONFIG_REG_8 CONFIG_REMAKE_ELF CONFIG_REQ CONFIG_RESERVED_01_BASE @@ -1233,7 +1221,6 @@ CONFIG_SPI_FLASH_SIZE CONFIG_SPI_HALF_DUPLEX CONFIG_SPI_IDLE_VAL CONFIG_SPI_N25Q256A_RESET -CONFIG_SPL_ CONFIG_SPL_ATMEL_SIZE CONFIG_SPL_BOARD_LOAD_IMAGE CONFIG_SPL_BOOTROM_SAVE @@ -2339,7 +2326,6 @@ CONFIG_SYS_MMC_U_BOOT_DST CONFIG_SYS_MMC_U_BOOT_OFFS CONFIG_SYS_MMC_U_BOOT_SIZE CONFIG_SYS_MMC_U_BOOT_START -CONFIG_SYS_MONITOR_ CONFIG_SYS_MONITOR_BASE CONFIG_SYS_MONITOR_LEN CONFIG_SYS_MONITOR_SEC
This define was left over from a previous revision, and was never used.
include/configs/am335x_sl50.h | 7 ------- scripts/config_whitelist.txt | 1 - 2 files changed, 8 deletions(-)
diff --git a/include/configs/am335x_sl50.h b/include/configs/am335x_sl50.h index dff946801c..7fbf421149 100644 --- a/include/configs/am335x_sl50.h +++ b/include/configs/am335x_sl50.h @@ -62,13 +62,6 @@ /* Bootcount using the RTC block */ #define CONFIG_SYS_BOOTCOUNT_BE
-#if defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_USB_ETHER) -/* Remove other SPL modes. */ -/* disable host part of MUSB in SPL */ -#undef CONFIG_MUSB_HOST -/* disable EFI partitions and partition UUID support */ -#endif - /* Network. */
#endif /* ! __CONFIG_AM335X_SL50_H */ diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index ca043b2f26..b125568a26 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -857,7 +857,6 @@ CONFIG_MTD_UBI_DEBUG_PARANOID CONFIG_MTD_UBI_GLUEBI CONFIG_MTD_UBI_MODULE CONFIG_MULTI_CS -CONFIG_MUSB_HOST CONFIG_MVGBE_PORTS CONFIG_MVMFP_V2 CONFIG_MVS
On Mon, 4 Oct 2021 at 04:00, Patrick Delaunay patrick.delaunay@foss.st.com wrote:
Signed-off-by: Patrick Delaunay patrick.delaunay@foss.st.com Reviewed-by: Simon Glass sjg@chromium.org
Remove the latest reference of CONFIG_NO_RELOCATION in code
include/configs/thunderx_88xx.h | 1 - scripts/config_whitelist.txt | 1 - 2 files changed, 2 deletions(-)
diff --git a/include/configs/thunderx_88xx.h b/include/configs/thunderx_88xx.h index 1ce0347300..600689843b 100644 --- a/include/configs/thunderx_88xx.h +++ b/include/configs/thunderx_88xx.h @@ -58,7 +58,6 @@ /* Monitor Command Prompt */ #define CONFIG_SYS_CBSIZE 512 /* Console I/O Buffer Size */ #define CONFIG_SYS_MAXARGS 64 /* max command args */ -#define CONFIG_NO_RELOCATION 1 #define PLL_REF_CLK 50000000 /* 50 MHz */ #define NS_PER_REF_CLK_TICK (1000000000/PLL_REF_CLK)
diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index b125568a26..6479b49291 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -927,7 +927,6 @@ CONFIG_NON_SECURE CONFIG_NORBOOT CONFIG_NORFLASH_PS32BIT CONFIG_NO_ETH -CONFIG_NO_RELOCATION CONFIG_NO_WAIT CONFIG_NS16550_MIN_FUNCTIONS CONFIG_NS8382X
Remove the latest reference of CONFIG_SYS_FLASH_AMD_CHECK_DQ7 in code
include/configs/P2041RDB.h | 1 - include/configs/corenet_ds.h | 1 - scripts/config_whitelist.txt | 1 - 3 files changed, 3 deletions(-)
diff --git a/include/configs/P2041RDB.h b/include/configs/P2041RDB.h index 1e75066eb1..d17cdaadee 100644 --- a/include/configs/P2041RDB.h +++ b/include/configs/P2041RDB.h @@ -205,7 +205,6 @@ unsigned long get_board_sys_clk(unsigned long dummy); #endif /* CONFIG_NAND_FSL_ELBC */
#define CONFIG_SYS_FLASH_EMPTY_INFO -#define CONFIG_SYS_FLASH_AMD_CHECK_DQ7 #define CONFIG_SYS_FLASH_BANKS_LIST {CONFIG_SYS_FLASH_BASE_PHYS + 0x8000000}
#define CONFIG_HWCONFIG diff --git a/include/configs/corenet_ds.h b/include/configs/corenet_ds.h index 79fca968dc..b79991f8c9 100644 --- a/include/configs/corenet_ds.h +++ b/include/configs/corenet_ds.h @@ -206,7 +206,6 @@ #endif /* CONFIG_NAND_FSL_ELBC */
#define CONFIG_SYS_FLASH_EMPTY_INFO -#define CONFIG_SYS_FLASH_AMD_CHECK_DQ7 #define CONFIG_SYS_FLASH_BANKS_LIST {CONFIG_SYS_FLASH_BASE_PHYS + 0x8000000, CONFIG_SYS_FLASH_BASE_PHYS}
#define CONFIG_HWCONFIG diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 6479b49291..fe618ff39a 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -1713,7 +1713,6 @@ CONFIG_SYS_FLASH1_BASE_PHYS CONFIG_SYS_FLASH1_BASE_PHYS_EARLY CONFIG_SYS_FLASHBOOT CONFIG_SYS_FLASH_ADDR_BASE -CONFIG_SYS_FLASH_AMD_CHECK_DQ7 CONFIG_SYS_FLASH_AUTOPROTECT_LIST CONFIG_SYS_FLASH_BANKS_LIST CONFIG_SYS_FLASH_BANKS_SIZES
Remove the latest reference of CONFIG_CONS_NONE in code
include/configs/MPC8560ADS.h | 1 - scripts/config_whitelist.txt | 1 - 2 files changed, 2 deletions(-)
diff --git a/include/configs/MPC8560ADS.h b/include/configs/MPC8560ADS.h index 3a9ea03292..dcd538fdf1 100644 --- a/include/configs/MPC8560ADS.h +++ b/include/configs/MPC8560ADS.h @@ -191,7 +191,6 @@
/* Serial Port */ #define CONFIG_CONS_ON_SCC /* define if console on SCC */ -#undef CONFIG_CONS_NONE /* define if console on something else */
#define CONFIG_SYS_BAUDRATE_TABLE \ {300, 600, 1200, 2400, 4800, 9600, 19200, 38400,115200} diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index fe618ff39a..b3ebd20c57 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -149,7 +149,6 @@ CONFIG_COMMON_BOOT CONFIG_COMPAT CONFIG_CONS_EXTC_PINSEL CONFIG_CONS_EXTC_RATE -CONFIG_CONS_NONE CONFIG_CONS_ON_SCC CONFIG_CONS_SCIF0 CONFIG_CONS_SCIF1
Redefine the macro CONFIG_IS_ENABLED is not allowed, so this entry can be removed in whitelist file.
scripts/config_whitelist.txt | 1 - 1 file changed, 1 deletion(-)
diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index b3ebd20c57..41a0952c97 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -649,7 +649,6 @@ CONFIG_IRAM_SIZE CONFIG_IRAM_STACK CONFIG_IRAM_TOP CONFIG_IRDA_BASE -CONFIG_IS_ENABLED CONFIG_JFFS2_DEV CONFIG_JFFS2_LZO CONFIG_JFFS2_NAND
Hi Patrick,
diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index b3ebd20c57..41a0952c97 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -649,7 +649,6 @@ CONFIG_IRAM_SIZE CONFIG_IRAM_STACK CONFIG_IRAM_TOP CONFIG_IRDA_BASE -CONFIG_IS_ENABLED CONFIG_JFFS2_DEV CONFIG_JFFS2_LZO CONFIG_JFFS2_NAND -- 2.25.1
For this to work you need to actually remove it from the source tree (which we can't), otherwise you get:
Error: You must add new CONFIG options using Kconfig The following new ad-hoc CONFIG options were detected: CONFIG_IS_ENABLED
I don't think this is worth it though, so I suggest dropping this patch.
Hi Simon
On 10/14/21 5:09 PM, Simon Glass wrote:
Hi Patrick,
Yes ! sorry
CONFIG_IS_ENABLED is present in u-boot.cfg,
as CONFIG_VAL
even if it is strange for these macro defined in "linux/kconfig.h"
but agree to drop this tentative.
Do you think I can remove the CONFIG_IS_ENABLED and CONFIG_VAL
in u-boot.cfg when the file is generated ?
Patrick
Hi Patrick,
On Fri, 22 Oct 2021 at 11:13, Patrick DELAUNAY patrick.delaunay@foss.st.com wrote:
Hi Simon
Hi Patrick,
Yes ! sorry
as CONFIG_VAL
If you like.
- CONFIG_COMMANDS
- CONFIG_REG_*
Reviewed-by: Simon Glass sjg@chromium.org Tested on: sandbox Tested-by: Simon Glass sjg@chromium.org
- CONFIG_COMMANDS
- CONFIG_REG_*
Signed-off-by: Patrick Delaunay patrick.delaunay@foss.st.com Reviewed-by: Simon Glass sjg@chromium.org Tested-by: Simon Glass sjg@chromium.org
Patrick DELAUNAY
Patrick Delaunay
