[PATCH] sunxi: Add support for using UART4 as console on A64
A64 has UART4 but it was in conflict with R_UART of older SoCs (e.g. A23).
This commit adds necessary definitions and checks to use UART4 port on A64.
Signed-off-by: Nazım Gediz Aydındoğmuş gediz.aydindogmus@genemek.com ---
arch/arm/include/asm/arch-sunxi/gpio.h | 1 + arch/arm/mach-sunxi/board.c | 4 ++++ arch/arm/mach-sunxi/clock_sun6i.c | 3 ++- include/configs/sunxi-common.h | 6 ++++++ 4 files changed, 13 insertions(+), 1 deletion(-)
diff --git a/arch/arm/include/asm/arch-sunxi/gpio.h b/arch/arm/include/asm/arch-sunxi/gpio.h index a646ea6a3c..1407aff25f 100644 --- a/arch/arm/include/asm/arch-sunxi/gpio.h +++ b/arch/arm/include/asm/arch-sunxi/gpio.h @@ -176,6 +176,7 @@ enum sunxi_gpio_number { #define SUNXI_GPD_LCD0 2 #define SUNXI_GPD_LVDS0 3 #define SUNXI_GPD_PWM 2 +#define SUN50I_GPD_UART4 3
#define SUN5I_GPE_SDC2 3 #define SUN8I_GPE_TWI2 3 diff --git a/arch/arm/mach-sunxi/board.c b/arch/arm/mach-sunxi/board.c index f40fccd8f8..7d95b7dd29 100644 --- a/arch/arm/mach-sunxi/board.c +++ b/arch/arm/mach-sunxi/board.c @@ -140,6 +140,10 @@ static int gpio_init(void) sunxi_gpio_set_cfgpin(SUNXI_GPL(2), SUN8I_GPL_R_UART); sunxi_gpio_set_cfgpin(SUNXI_GPL(3), SUN8I_GPL_R_UART); sunxi_gpio_set_pull(SUNXI_GPL(3), SUNXI_GPIO_PULL_UP); +#elif CONFIG_CONS_INDEX == 5 && defined(CONFIG_MACH_SUN50I) + sunxi_gpio_set_cfgpin(SUNXI_GPD(2), SUN50I_GPD_UART4); + sunxi_gpio_set_cfgpin(SUNXI_GPD(3), SUN50I_GPD_UART4); + sunxi_gpio_set_pull(SUNXI_GPD(3), SUNXI_GPIO_PULL_UP); #else #error Unsupported console port number. Please fix pin mux settings in board.c #endif diff --git a/arch/arm/mach-sunxi/clock_sun6i.c b/arch/arm/mach-sunxi/clock_sun6i.c index 8e84062bd7..4bb2d66b1e 100644 --- a/arch/arm/mach-sunxi/clock_sun6i.c +++ b/arch/arm/mach-sunxi/clock_sun6i.c @@ -83,7 +83,8 @@ void clock_init_sec(void)
void clock_init_uart(void) { -#if CONFIG_CONS_INDEX < 5 +#if CONFIG_CONS_INDEX < 5 || \ + defined(CONFIG_MACH_SUN50I) && CONFIG_CONS_INDEX < 6 struct sunxi_ccm_reg *const ccm = (struct sunxi_ccm_reg *)SUNXI_CCM_BASE;
diff --git a/include/configs/sunxi-common.h b/include/configs/sunxi-common.h index 5b0bec0561..f7a97b3dec 100644 --- a/include/configs/sunxi-common.h +++ b/include/configs/sunxi-common.h @@ -45,8 +45,12 @@ # define CONFIG_SYS_NS16550_COM2 SUNXI_UART1_BASE # define CONFIG_SYS_NS16550_COM3 SUNXI_UART2_BASE # define CONFIG_SYS_NS16550_COM4 SUNXI_UART3_BASE +#if defined(CONFIG_MACH_SUN50I) +# define CONFIG_SYS_NS16550_COM5 SUNXI_UART4_BASE +#else # define CONFIG_SYS_NS16550_COM5 SUNXI_R_UART_BASE #endif +#endif
/* CPU */ #define COUNTER_FREQUENCY 24000000 @@ -248,6 +252,8 @@ extern int soft_i2c_gpio_scl; #define OF_STDOUT_PATH "/soc@01c00000/serial@01c28800:115200" #elif CONFIG_CONS_INDEX == 5 && defined(CONFIG_MACH_SUN8I) #define OF_STDOUT_PATH "/soc@01c00000/serial@01f02800:115200" +#elif CONFIG_CONS_INDEX == 5 && defined(CONFIG_MACH_SUN50I) +#define OF_STDOUT_PATH "/soc@01c00000/serial@01c29000:115200" #else #error Unsupported console port nr. Please fix stdout-path in sunxi-common.h. #endif
- sunxi_gpio_set_cfgpin(SUNXI_GPD(2), SUN50I_GPD_UART4);
- sunxi_gpio_set_cfgpin(SUNXI_GPD(3), SUN50I_GPD_UART4);
- sunxi_gpio_set_pull(SUNXI_GPD(3), SUNXI_GPIO_PULL_UP);
struct sunxi_ccm_reg *const ccm = (struct sunxi_ccm_reg *)SUNXI_CCM_BASE;defined(CONFIG_MACH_SUN50I) && CONFIG_CONS_INDEX < 6
The soc node doesn't have a unit-address on the A64 Maxime
Hi.
If I've understood it well, you're pointing out for the following part, right?
To be honest, this part was remnant of days long trial and error attempts at trying to make UART4 work. Sorry for not scrutinizing it carefully. It was not because do not taking it serious but due to not fully grasping the said changes.
If there's not any other thing to remove/add/fix, should I reformat and submit a completely new patch or is it okay to send the updated one as a follow-up post in this thread?
Thanks for the review, by the way.
On Mon, Jun 29, 2020 at 07:12:04PM +0000, Nazım Gediz AYDINDOĞMUŞ wrote:
Hi.
Yep
Yeah, send a new version.
Maxime
Maxime Ripard
