[U-Boot] [PATCH 1/3] net: sh-eth: Remove definition of RX_DESC_SIZE and TX_DESC_SIZE
RX_DESC_SIZE and TX_DESC_SIZE mean the size of the data descriptor for sh-eth. We can acquire this in sizeof. It is not necessary to define these in define.
Signed-off-by: Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com --- drivers/net/sh_eth.c | 20 ++++++++++++-------- drivers/net/sh_eth.h | 4 ---- 2 files changed, 12 insertions(+), 12 deletions(-)
diff --git a/drivers/net/sh_eth.c b/drivers/net/sh_eth.c index bd1b70f..c5bc97c 100644 --- a/drivers/net/sh_eth.c +++ b/drivers/net/sh_eth.c @@ -186,19 +186,21 @@ static int sh_eth_tx_desc_init(struct sh_eth_dev *eth) struct tx_desc_s *cur_tx_desc;
/* - * Allocate tx descriptors. They must be TX_DESC_SIZE bytes aligned + * Allocate rx descriptors. They must be aligned to size of struct + * tx_desc_s. */ port_info->tx_desc_malloc = malloc(NUM_TX_DESC * sizeof(struct tx_desc_s) + - TX_DESC_SIZE - 1); + sizeof(struct tx_desc_s) - 1); if (!port_info->tx_desc_malloc) { printf(SHETHER_NAME ": malloc failed\n"); ret = -ENOMEM; goto err; }
- tmp_addr = (u32) (((int)port_info->tx_desc_malloc + TX_DESC_SIZE - 1) & - ~(TX_DESC_SIZE - 1)); + tmp_addr = (u32) (((int)port_info->tx_desc_malloc + + sizeof(struct tx_desc_s) - 1) & + ~(sizeof(struct tx_desc_s) - 1)); flush_cache_wback(tmp_addr, NUM_TX_DESC * sizeof(struct tx_desc_s)); /* Make sure we use a P2 address (non-cacheable) */ port_info->tx_desc_base = (struct tx_desc_s *)ADDR_TO_P2(tmp_addr); @@ -238,19 +240,21 @@ static int sh_eth_rx_desc_init(struct sh_eth_dev *eth) u8 *rx_buf;
/* - * Allocate rx descriptors. They must be RX_DESC_SIZE bytes aligned + * Allocate rx descriptors. They must be aligned to size of struct + * rx_desc_s. */ port_info->rx_desc_malloc = malloc(NUM_RX_DESC * sizeof(struct rx_desc_s) + - RX_DESC_SIZE - 1); + sizeof(struct rx_desc_s) - 1); if (!port_info->rx_desc_malloc) { printf(SHETHER_NAME ": malloc failed\n"); ret = -ENOMEM; goto err; }
- tmp_addr = (u32) (((int)port_info->rx_desc_malloc + RX_DESC_SIZE - 1) & - ~(RX_DESC_SIZE - 1)); + tmp_addr = (u32) (((int)port_info->rx_desc_malloc + + sizeof(struct rx_desc_s) - 1) & + ~(sizeof(struct rx_desc_s) - 1)); flush_cache_wback(tmp_addr, NUM_RX_DESC * sizeof(struct rx_desc_s)); /* Make sure we use a P2 address (non-cacheable) */ port_info->rx_desc_base = (struct rx_desc_s *)ADDR_TO_P2(tmp_addr); diff --git a/drivers/net/sh_eth.h b/drivers/net/sh_eth.h index dc93028..8e26c2a 100644 --- a/drivers/net/sh_eth.h +++ b/drivers/net/sh_eth.h @@ -51,8 +51,6 @@ /* The size of the tx descriptor is determined by how much padding is used. 4, 20, or 52 bytes of padding can be used */ #define TX_DESC_PADDING (CONFIG_SH_ETHER_ALIGNE_SIZE - 12) -/* same as CONFIG_SH_ETHER_ALIGNE_SIZE */ -#define TX_DESC_SIZE (12 + TX_DESC_PADDING)
/* Tx descriptor. We always use 3 bytes of padding */ struct tx_desc_s { @@ -68,8 +66,6 @@ struct tx_desc_s { /* The size of the rx descriptor is determined by how much padding is used. 4, 20, or 52 bytes of padding can be used */ #define RX_DESC_PADDING (CONFIG_SH_ETHER_ALIGNE_SIZE - 12) -/* same as CONFIG_SH_ETHER_ALIGNE_SIZE */ -#define RX_DESC_SIZE (12 + RX_DESC_PADDING) /* aligned cache line size */ #define RX_BUF_ALIGNE_SIZE (CONFIG_SH_ETHER_ALIGNE_SIZE > 32 ? 64 : 32)
Signed-off-by: Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com --- drivers/net/sh_eth.c | 83 ++++++++++++++++++++++++---------------------------- drivers/net/sh_eth.h | 6 ++-- 2 files changed, 41 insertions(+), 48 deletions(-)
diff --git a/drivers/net/sh_eth.c b/drivers/net/sh_eth.c index c5bc97c..d1d3b68 100644 --- a/drivers/net/sh_eth.c +++ b/drivers/net/sh_eth.c @@ -181,7 +181,7 @@ static int sh_eth_reset(struct sh_eth_dev *eth) static int sh_eth_tx_desc_init(struct sh_eth_dev *eth) { int port = eth->port, i, ret = 0; - u32 tmp_addr; + u32 alloc_desc_size = NUM_TX_DESC * sizeof(struct tx_desc_s); struct sh_eth_info *port_info = ð->port_info[port]; struct tx_desc_s *cur_tx_desc;
@@ -189,21 +189,19 @@ static int sh_eth_tx_desc_init(struct sh_eth_dev *eth) * Allocate rx descriptors. They must be aligned to size of struct * tx_desc_s. */ - port_info->tx_desc_malloc = malloc(NUM_TX_DESC * - sizeof(struct tx_desc_s) + - sizeof(struct tx_desc_s) - 1); - if (!port_info->tx_desc_malloc) { - printf(SHETHER_NAME ": malloc failed\n"); + port_info->tx_desc_alloc = + memalign(sizeof(struct tx_desc_s), alloc_desc_size); + if (!port_info->tx_desc_alloc) { + printf(SHETHER_NAME ": memalign failed\n"); ret = -ENOMEM; goto err; }
- tmp_addr = (u32) (((int)port_info->tx_desc_malloc + - sizeof(struct tx_desc_s) - 1) & - ~(sizeof(struct tx_desc_s) - 1)); - flush_cache_wback(tmp_addr, NUM_TX_DESC * sizeof(struct tx_desc_s)); + flush_cache_wback((u32)port_info->tx_desc_alloc, alloc_desc_size); + /* Make sure we use a P2 address (non-cacheable) */ - port_info->tx_desc_base = (struct tx_desc_s *)ADDR_TO_P2(tmp_addr); + port_info->tx_desc_base = + (struct tx_desc_s *)ADDR_TO_P2((u32)port_info->tx_desc_alloc); port_info->tx_desc_cur = port_info->tx_desc_base;
/* Initialize all descriptors */ @@ -234,49 +232,44 @@ err: static int sh_eth_rx_desc_init(struct sh_eth_dev *eth) { int port = eth->port, i , ret = 0; + u32 alloc_desc_size = NUM_RX_DESC * sizeof(struct rx_desc_s); struct sh_eth_info *port_info = ð->port_info[port]; struct rx_desc_s *cur_rx_desc; - u32 tmp_addr; u8 *rx_buf;
/* * Allocate rx descriptors. They must be aligned to size of struct * rx_desc_s. */ - port_info->rx_desc_malloc = malloc(NUM_RX_DESC * - sizeof(struct rx_desc_s) + - sizeof(struct rx_desc_s) - 1); - if (!port_info->rx_desc_malloc) { - printf(SHETHER_NAME ": malloc failed\n"); + port_info->rx_desc_alloc = + memalign(sizeof(struct rx_desc_s), alloc_desc_size); + if (!port_info->rx_desc_alloc) { + printf(SHETHER_NAME ": memalign failed\n"); ret = -ENOMEM; goto err; }
- tmp_addr = (u32) (((int)port_info->rx_desc_malloc + - sizeof(struct rx_desc_s) - 1) & - ~(sizeof(struct rx_desc_s) - 1)); - flush_cache_wback(tmp_addr, NUM_RX_DESC * sizeof(struct rx_desc_s)); + flush_cache_wback(port_info->rx_desc_alloc, alloc_desc_size); + /* Make sure we use a P2 address (non-cacheable) */ - port_info->rx_desc_base = (struct rx_desc_s *)ADDR_TO_P2(tmp_addr); + port_info->rx_desc_base = + (struct rx_desc_s *)ADDR_TO_P2((u32)port_info->rx_desc_alloc);
port_info->rx_desc_cur = port_info->rx_desc_base;
/* - * Allocate rx data buffers. They must be 32 bytes aligned and in - * P2 area + * Allocate rx data buffers. They must be RX_BUF_ALIGNE_SIZE bytes + * aligned and in P2 area. */ - port_info->rx_buf_malloc = malloc( - NUM_RX_DESC * MAX_BUF_SIZE + RX_BUF_ALIGNE_SIZE - 1); - if (!port_info->rx_buf_malloc) { - printf(SHETHER_NAME ": malloc failed\n"); + port_info->rx_buf_alloc = + memalign(RX_BUF_ALIGNE_SIZE, NUM_RX_DESC * MAX_BUF_SIZE); + if (!port_info->rx_buf_alloc) { + printf(SHETHER_NAME ": alloc failed\n"); ret = -ENOMEM; - goto err_buf_malloc; + goto err_buf_alloc; }
- tmp_addr = (u32)(((int)port_info->rx_buf_malloc - + (RX_BUF_ALIGNE_SIZE - 1)) & - ~(RX_BUF_ALIGNE_SIZE - 1)); - port_info->rx_buf_base = (u8 *)ADDR_TO_P2(tmp_addr); + port_info->rx_buf_base = (u8 *)ADDR_TO_P2((u32)port_info->rx_buf_alloc);
/* Initialize all descriptors */ for (cur_rx_desc = port_info->rx_desc_base, @@ -301,9 +294,9 @@ static int sh_eth_rx_desc_init(struct sh_eth_dev *eth)
return ret;
-err_buf_malloc: - free(port_info->rx_desc_malloc); - port_info->rx_desc_malloc = NULL; +err_buf_alloc: + free(port_info->rx_desc_alloc); + port_info->rx_desc_alloc = NULL;
err: return ret; @@ -314,9 +307,9 @@ static void sh_eth_tx_desc_free(struct sh_eth_dev *eth) int port = eth->port; struct sh_eth_info *port_info = ð->port_info[port];
- if (port_info->tx_desc_malloc) { - free(port_info->tx_desc_malloc); - port_info->tx_desc_malloc = NULL; + if (port_info->tx_desc_alloc) { + free(port_info->tx_desc_alloc); + port_info->tx_desc_alloc = NULL; } }
@@ -325,14 +318,14 @@ static void sh_eth_rx_desc_free(struct sh_eth_dev *eth) int port = eth->port; struct sh_eth_info *port_info = ð->port_info[port];
- if (port_info->rx_desc_malloc) { - free(port_info->rx_desc_malloc); - port_info->rx_desc_malloc = NULL; + if (port_info->rx_desc_alloc) { + free(port_info->rx_desc_alloc); + port_info->rx_desc_alloc = NULL; }
- if (port_info->rx_buf_malloc) { - free(port_info->rx_buf_malloc); - port_info->rx_buf_malloc = NULL; + if (port_info->rx_buf_alloc) { + free(port_info->rx_buf_alloc); + port_info->rx_buf_alloc = NULL; } }
diff --git a/drivers/net/sh_eth.h b/drivers/net/sh_eth.h index 8e26c2a..5cb520c 100644 --- a/drivers/net/sh_eth.h +++ b/drivers/net/sh_eth.h @@ -78,13 +78,13 @@ struct rx_desc_s { };
struct sh_eth_info { - struct tx_desc_s *tx_desc_malloc; + struct tx_desc_s *tx_desc_alloc; struct tx_desc_s *tx_desc_base; struct tx_desc_s *tx_desc_cur; - struct rx_desc_s *rx_desc_malloc; + struct rx_desc_s *rx_desc_alloc; struct rx_desc_s *rx_desc_base; struct rx_desc_s *rx_desc_cur; - u8 *rx_buf_malloc; + u8 *rx_buf_alloc; u8 *rx_buf_base; u8 mac_addr[6]; u8 phy_addr;
A bit field of DMA descriptor is on memory area of DMA. If we set data to bit of DMA descriptor, we must be writeback data of DMA descriptor.
Signed-off-by: Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com --- drivers/net/sh_eth.c | 10 ++++++++-- 1 file changed, 8 insertions(+), 2 deletions(-)
diff --git a/drivers/net/sh_eth.c b/drivers/net/sh_eth.c index d1d3b68..4bf493e 100644 --- a/drivers/net/sh_eth.c +++ b/drivers/net/sh_eth.c @@ -2,9 +2,9 @@ * sh_eth.c - Driver for Renesas ethernet controler. * * Copyright (C) 2008, 2011 Renesas Solutions Corp. - * Copyright (c) 2008, 2011 Nobuhiro Iwamatsu + * Copyright (c) 2008, 2011, 2014 2014 Nobuhiro Iwamatsu * Copyright (c) 2007 Carlos Munoz carlos@kenati.com - * Copyright (C) 2013 Renesas Electronics Corporation + * Copyright (C) 2013, 2014 Renesas Electronics Corporation * * SPDX-License-Identifier: GPL-2.0+ */ @@ -83,6 +83,8 @@ int sh_eth_send(struct eth_device *dev, void *packet, int len) else port_info->tx_desc_cur->td0 = TD_TACT | TD_TFP;
+ flush_cache_wback(port_info->tx_desc_cur, sizeof(struct tx_desc_s)); + /* Restart the transmitter if disabled */ if (!(sh_eth_read(eth, EDTRR) & EDTRR_TRNS)) sh_eth_write(eth, EDTRR_TRNS, EDTRR); @@ -133,6 +135,10 @@ int sh_eth_recv(struct eth_device *dev) port_info->rx_desc_cur->rd0 = RD_RACT | RD_RDLE; else port_info->rx_desc_cur->rd0 = RD_RACT; + + flush_cache_wback(port_info->rx_desc_cur, + sizeof(struct rx_desc_s)); + /* Point to the next descriptor */ port_info->rx_desc_cur++; if (port_info->rx_desc_cur >=
Nobuhiro Iwamatsu
