[U-Boot] [PATCH 1/1] efi_loader: bootefi hello should use loadaddr
Command 'bootefi hello' currently uses CONFIG_SYS_LOAD_ADDR as loading address.
qemu machines have by default 128 MiB RAM. CONFIG_SYS_LOAD_ADDR for x86 is 0x20000000 (512 MiB). This causes 'bootefi hello' to fail.
We should use the environment variable loadaddr if available. It defaults to 0x1000000 (16 MiB) on qemu_x86.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- cmd/bootefi.c | 6 +++++- 1 file changed, 5 insertions(+), 1 deletion(-)
diff --git a/cmd/bootefi.c b/cmd/bootefi.c index 47771f87cc..a3768158a2 100644 --- a/cmd/bootefi.c +++ b/cmd/bootefi.c @@ -300,7 +300,11 @@ static int do_bootefi(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) if (!strcmp(argv[1], "hello")) { ulong size = __efi_hello_world_end - __efi_hello_world_begin;
- addr = CONFIG_SYS_LOAD_ADDR; + saddr = env_get("loadaddr"); + if (saddr) + addr = simple_strtoul(saddr, NULL, 16); + else + addr = CONFIG_SYS_LOAD_ADDR; memcpy((char *)addr, __efi_hello_world_begin, size); } else #endif
if (saddr)
else
I'm not terribly happy about that logic. Ideally I would want to have it load to *one* explicit address, not multiple ones.
Maybe we could just always memalign() a region?
Alternatively if we can not use memalign, I would rather drop the CONFIG_SYS_LOAD_ADDR branch and *only* rely on loadaddr.
Alex
if (saddr)
else
Alex
A user might have deleted loadaddr from the environment. If we do not fallback to CONFIG_SYS_LOAD_ADDR we would have to create an error message saying that we cannot do without loadaddr.
Shall I adjust the patch in this way?
Best regards
Heinrich
if (saddr)
else
Alex
No, let's do it the same way as booti / bootz. Just use the global load_addr variable.
Alex
Alexander Graf
