[PATCH v2] arm: mach-k3: arm64-mmu: do not map ATF and OPTEE regions in A53 MMU
ATF and OPTEE regions may be firewalled from non-secure entities. If we still map them for non-secure A53, speculative access may happen, which will not cause any faults and related error response will be ignored, but it's better to not to map those regions for non-secure A53 as there will be no actual access at all.
Create separate table as ATF region is at different locations for am64 and am62/am62a.
Signed-off-by: Kamlesh Gurudasani kamlesh@ti.com --- Changes in v2: - Make the commit message more clearer --- arch/arm/mach-k3/arm64-mmu.c | 64 +++++++++++++++++++++++++++++++++--- 1 file changed, 59 insertions(+), 5 deletions(-)
diff --git a/arch/arm/mach-k3/arm64-mmu.c b/arch/arm/mach-k3/arm64-mmu.c index 88687c2d09..f8087d2421 100644 --- a/arch/arm/mach-k3/arm64-mmu.c +++ b/arch/arm/mach-k3/arm64-mmu.c @@ -222,14 +222,13 @@ struct mm_region *mem_map = j721s2_mem_map;
#endif /* CONFIG_SOC_K3_J721S2 */
-#if defined(CONFIG_SOC_K3_AM642) || defined(CONFIG_SOC_K3_AM625) || \ - defined(CONFIG_SOC_K3_AM62A7) +#if defined(CONFIG_SOC_K3_AM625) || defined(CONFIG_SOC_K3_AM62A7)
/* NR_DRAM_BANKS + 32bit IO + 64bit IO + terminator */ -#define NR_MMU_REGIONS (CONFIG_NR_DRAM_BANKS + 3) +#define NR_MMU_REGIONS (CONFIG_NR_DRAM_BANKS + 4)
/* ToDo: Add 64bit IO */ -struct mm_region am64_mem_map[NR_MMU_REGIONS] = { +struct mm_region am62_mem_map[NR_MMU_REGIONS] = { { .virt = 0x0UL, .phys = 0x0UL, @@ -240,9 +239,64 @@ struct mm_region am64_mem_map[NR_MMU_REGIONS] = { }, { .virt = 0x80000000UL, .phys = 0x80000000UL, + .size = 0x1E780000UL, + .attrs = PTE_BLOCK_MEMTYPE(MT_NORMAL) | + PTE_BLOCK_INNER_SHARE + }, { + .virt = 0xA0000000UL, + .phys = 0xA0000000UL, + .size = 0x60000000UL, + .attrs = PTE_BLOCK_MEMTYPE(MT_NORMAL) | + PTE_BLOCK_INNER_SHARE + + }, { + .virt = 0x880000000UL, + .phys = 0x880000000UL, .size = 0x80000000UL, .attrs = PTE_BLOCK_MEMTYPE(MT_NORMAL) | PTE_BLOCK_INNER_SHARE + }, { + .virt = 0x500000000UL, + .phys = 0x500000000UL, + .size = 0x400000000UL, + .attrs = PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | + PTE_BLOCK_NON_SHARE | + PTE_BLOCK_PXN | PTE_BLOCK_UXN + }, { + /* List terminator */ + 0, + } +}; + +struct mm_region *mem_map = am62_mem_map; +#endif /* CONFIG_SOC_K3_AM625 || CONFIG_SOC_K3_AM62A7 */ + +#ifdef CONFIG_SOC_K3_AM642 + +/* NR_DRAM_BANKS + 32bit IO + 64bit IO + terminator */ +#define NR_MMU_REGIONS (CONFIG_NR_DRAM_BANKS + 4) + +/* ToDo: Add 64bit IO */ +struct mm_region am64_mem_map[NR_MMU_REGIONS] = { + { + .virt = 0x0UL, + .phys = 0x0UL, + .size = 0x80000000UL, + .attrs = PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | + PTE_BLOCK_NON_SHARE | + PTE_BLOCK_PXN | PTE_BLOCK_UXN + }, { + .virt = 0x80000000UL, + .phys = 0x80000000UL, + .size = 0x1E800000UL, + .attrs = PTE_BLOCK_MEMTYPE(MT_NORMAL) | + PTE_BLOCK_INNER_SHARE + }, { + .virt = 0xA0000000UL, + .phys = 0xA0000000UL, + .size = 0x60000000UL, + .attrs = PTE_BLOCK_MEMTYPE(MT_NORMAL) | + PTE_BLOCK_INNER_SHARE }, { .virt = 0x880000000UL, .phys = 0x880000000UL, @@ -263,4 +317,4 @@ struct mm_region am64_mem_map[NR_MMU_REGIONS] = { };
struct mm_region *mem_map = am64_mem_map; -#endif /* CONFIG_SOC_K3_AM642 || CONFIG_SOC_K3_AM625 || CONFIG_SOC_K3_AM62A7 */ +#endif /* CONFIG_SOC_K3_AM642 */
kamlesh@ti.com
