[PATCH] xilinx: Remove duplicate PMIO_NODE_ID_BASE macro
PMIO_NODE_ID_BASE is defined twice that's why remove one instance.
Fixes: 248fe9f302df ("spi: cadence_qspi: Enable apb linear mode for apb read & write operations") Signed-off-by: Michal Simek michal.simek@amd.com ---
include/zynqmp_firmware.h | 2 -- 1 file changed, 2 deletions(-)
diff --git a/include/zynqmp_firmware.h b/include/zynqmp_firmware.h index 6c4fd9a6c5f2..86c14d560e12 100644 --- a/include/zynqmp_firmware.h +++ b/include/zynqmp_firmware.h @@ -435,8 +435,6 @@ enum pm_gem_config_type { #define PMUFW_V1_0 ((1 << ZYNQMP_PM_VERSION_MAJOR_SHIFT) | 0) #define PMIO_NODE_ID_BASE 0x1410801B
-#define PMIO_NODE_ID_BASE 0x1410801B - /* * Return payload size * Not every firmware call expects the same amount of return bytes, however the
- Return payload size
- Not every firmware call expects the same amount of return bytes, however the
applied. M
Michal Simek
