[U-Boot] Pull request: nand flash
The following changes since commit 59869ca72df8bc4e4ffa9dd17cb6673bbe010272: Wolfgang Denk (1): Merge branch 'master' of git://git.denx.de/u-boot-video
git://git.denx.de/u-boot-nand-flash.git master
David Brownell (3): davinci_nand: cleanup I (minor) davinci_nand: cleanup II (CONFIG_SYS_DAVINCI_BROKEN_ECC) davinci_nand chipselect/init cleanup
Guennadi Liakhovetski (2): env_nand: remove unused variable. nand_spl: read environment early, when booting from NAND using nand_spl
HeungJun Kim (1): env_onenand: change env_address type from unsigned long to loff_t
Jean-Christophe PLAGNIOL-VILLARD (1): mtd: nand: use loff_t for offset
Mike Frysinger (1): mtd: nand: new base driver for memory mapped nand devices
Mingkai Hu (1): fsl_elbc_nand: redirect the pointer of bbt pattern to RAM
Sandeep Paulraj (2): ARM DaVinci: Changing ALE Mask Value NAND DaVinci: Update to ALE/CLE Mask values
Scott Wood (1): nand_spl: Fix cmd_ctrl usage in nand_boot.c.
Wolfgang Denk (1): nand/onenand: Fix missing argument checking for "markbad" command
kevin.morfitt@fearnside-systems.co.uk (1): Bug-fix in drivers mtd nand Makefile
README | 6 + board/bf537-stamp/Makefile | 1 - board/bf537-stamp/nand.c | 100 ----------- board/davinci/sonata/sonata.c | 28 +++ common/cmd_nand.c | 31 +++- common/cmd_onenand.c | 35 +++-- common/env_nand.c | 51 +++--- common/env_onenand.c | 2 +- doc/README.nand | 9 - drivers/mtd/nand/Makefile | 3 +- drivers/mtd/nand/davinci_nand.c | 288 ++++-------------------------- drivers/mtd/nand/fsl_elbc_nand.c | 4 + drivers/mtd/nand/nand_plat.c | 53 ++++++ drivers/mtd/nand/nand_util.c | 20 +- include/asm-arm/arch-davinci/nand_defs.h | 130 +------------- include/configs/bf537-stamp.h | 44 ++--- include/configs/bfin_adi_common.h | 3 + include/configs/smdk6400.h | 3 + include/nand.h | 14 +- nand_spl/nand_boot.c | 28 +++- 20 files changed, 272 insertions(+), 581 deletions(-) delete mode 100644 board/bf537-stamp/nand.c create mode 100644 drivers/mtd/nand/nand_plat.c
Grr, there was a mismerge in this patch. Will send another pull request once it's fixed.
-Scott
Scott Wood
