[U-Boot] [PATCH] Add inverted clock polarity support for Atmel LCD driver
This is my third try for Olimex SAM9-L9260/61 board support patches.
Here follows the first patch. ---
Boards utilizing the Atmel LCD driver can now specify that the LCD clock must be inverted by defining the macro CONFIG_LCD_INVERTED_CLOCK. --- README | 5 +++++ drivers/video/atmel_lcdfb.c | 3 +++ 2 files changed, 8 insertions(+), 0 deletions(-)
diff --git a/README b/README index de700bd..d7c0afe 100644 --- a/README +++ b/README @@ -1063,6 +1063,11 @@ The following options need to be configured: Normally display is black on white background; define CONFIG_SYS_WHITE_ON_BLACK to get it inverted.
+ CONFIG_LCD_INVERTED_CLOCK + Define this if your LCD needs inverted clock polarity. Note + that this feature will work only if the selected LCD driver + and hardware controller support it. + - Splash Screen Support: CONFIG_SPLASH_SCREEN
If this option is set, the environment is checked for diff --git a/drivers/video/atmel_lcdfb.c b/drivers/video/atmel_lcdfb.c index db86763..d3e988e 100644 --- a/drivers/video/atmel_lcdfb.c +++ b/drivers/video/atmel_lcdfb.c @@ -112,6 +112,9 @@ void lcd_ctrl_init(void *lcdbase)
value |= panel_info.vl_sync; value |= (panel_info.vl_bpix << 5); +#if defined(CONFIG_LCD_INVERTED_CLOCK) + value |= ATMEL_LCDC_INVCLK_INVERTED; +#endif lcdc_writel(panel_info.mmio, ATMEL_LCDC_LCDCON2, value);
/* Vertical timing */
The SAM9-L9261 board support is based on code for AT91SAM9261EK. Networking is missing and will be added after the DM9000 support for AT91 boards is fixed to comply with U-Boot guide-lines. --- MAINTAINERS | 3 + MAKEALL | 1 + Makefile | 17 +++ board/olimex/sam9_l9261/Makefile | 56 ++++++++ board/olimex/sam9_l9261/config.mk | 1 + board/olimex/sam9_l9261/led.c | 43 +++++++ board/olimex/sam9_l9261/partition.c | 40 ++++++ board/olimex/sam9_l9261/sam9_l9261.c | 214 +++++++++++++++++++++++++++++++ include/configs/sam9_l9261.h | 230 ++++++++++++++++++++++++++++++++++ tools/Makefile | 3 + tools/logos/olimex.bmp | Bin 0 -> 27510 bytes 11 files changed, 608 insertions(+), 0 deletions(-) create mode 100644 board/olimex/sam9_l9261/Makefile create mode 100644 board/olimex/sam9_l9261/config.mk create mode 100644 board/olimex/sam9_l9261/led.c create mode 100644 board/olimex/sam9_l9261/partition.c create mode 100644 board/olimex/sam9_l9261/sam9_l9261.c create mode 100644 include/configs/sam9_l9261.h create mode 100644 tools/logos/olimex.bmp
diff --git a/MAINTAINERS b/MAINTAINERS index 575a7ec..dfcccf5 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -133,6 +133,9 @@ Jon Diekema jon.diekema@smiths-aerospace.com
sbc8260 MPC8260
+Dimitar Dimitrov dinuxbg@gmail.com + sam9_l9261 AT91SAM9261 + Dirk Eibach eibach@gdsys.de
gdppc440etx PPC440EP/GR diff --git a/MAKEALL b/MAKEALL index 020ff73..ecabfcf 100755 --- a/MAKEALL +++ b/MAKEALL @@ -599,6 +599,7 @@ LIST_at91=" \ m501sk \ pm9261 \ pm9263 \ + sam9_l9261 \ "
######################################################################### diff --git a/Makefile b/Makefile index 090e645..b19c3b0 100644 --- a/Makefile +++ b/Makefile @@ -2847,6 +2847,23 @@ at91sam9g45ekes_config : unconfig pm9263_config : unconfig @$(MKCONFIG) $(@:_config=) arm arm926ejs pm9263 ronetix at91
+sam9_l9261_nandflash_config \ +sam9_l9261_dataflash_cs0_config \ +sam9_l9261_dataflash_cs3_config \ +sam9_l9261_config : unconfig + @mkdir -p $(obj)include + @if [ "$(findstring _nandflash,$@)" ] ; then \ + echo "#define CONFIG_SYS_USE_NANDFLASH 1" >>$(obj)include/config.h ; \ + $(XECHO) "... with environment variable in NAND FLASH" ; \ + elif [ "$(findstring dataflash_cs3,$@)" ] ; then \ + echo "#define CONFIG_SYS_USE_DATAFLASH_CS3 1" >>$(obj)include/config.h ; \ + $(XECHO) "... with environment variable in SPI DATAFLASH CS3" ; \ + else \ + echo "#define CONFIG_SYS_USE_DATAFLASH_CS0 1" >>$(obj)include/config.h ; \ + $(XECHO) "... with environment variable in SPI DATAFLASH CS0" ; \ + fi; + @$(MKCONFIG) -a sam9_l9261 arm arm926ejs sam9_l9261 olimex at91 + ######################################################################## ## ARM Integrator boards - see doc/README-integrator for more info. integratorap_config \ diff --git a/board/olimex/sam9_l9261/Makefile b/board/olimex/sam9_l9261/Makefile new file mode 100644 index 0000000..3a1e163 --- /dev/null +++ b/board/olimex/sam9_l9261/Makefile @@ -0,0 +1,56 @@ +# +# (C) Copyright 2003-2008 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# (C) Copyright 2008 +# Stelian Pop stelian.pop@leadtechdesign.com +# Lead Tech Design <www.leadtechdesign.com> +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).a + +COBJS-y += sam9_l9261.o +COBJS-y += led.o +COBJS-$(CONFIG_HAS_DATAFLASH) += partition.o + +SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS-y)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) $(SOBJS) + +clean: + rm -f $(SOBJS) $(OBJS) + +distclean: clean + rm -f $(LIB) core *.bak $(obj).depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/olimex/sam9_l9261/config.mk b/board/olimex/sam9_l9261/config.mk new file mode 100644 index 0000000..ff2cfd1 --- /dev/null +++ b/board/olimex/sam9_l9261/config.mk @@ -0,0 +1 @@ +TEXT_BASE = 0x23f00000 diff --git a/board/olimex/sam9_l9261/led.c b/board/olimex/sam9_l9261/led.c new file mode 100644 index 0000000..5d1c5f2 --- /dev/null +++ b/board/olimex/sam9_l9261/led.c @@ -0,0 +1,43 @@ +/* + * (C) Copyright 2007-2008 + * Stelian Pop stelian.pop@leadtechdesign.com + * Lead Tech Design <www.leadtechdesign.com> + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/arch/at91sam9261.h> +#include <asm/arch/at91_pmc.h> +#include <asm/arch/gpio.h> +#include <asm/arch/io.h> + +void coloured_LED_init(void) +{ + /* Enable clock */ + at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9261_ID_PIOA); + + at91_set_gpio_output(CONFIG_RED_LED, 1); + at91_set_gpio_output(CONFIG_GREEN_LED, 1); + at91_set_gpio_output(CONFIG_YELLOW_LED, 1); + + at91_set_gpio_value(CONFIG_RED_LED, 0); + at91_set_gpio_value(CONFIG_GREEN_LED, 1); + at91_set_gpio_value(CONFIG_YELLOW_LED, 1); +} diff --git a/board/olimex/sam9_l9261/partition.c b/board/olimex/sam9_l9261/partition.c new file mode 100644 index 0000000..c739b11 --- /dev/null +++ b/board/olimex/sam9_l9261/partition.c @@ -0,0 +1,40 @@ +/* + * (C) Copyright 2008 + * Ulf Samuelsson ulf@atmel.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + * + */ +#include <common.h> +#include <config.h> +#include <asm/hardware.h> +#include <dataflash.h> + +AT91S_DATAFLASH_INFO dataflash_info[CONFIG_SYS_MAX_DATAFLASH_BANKS]; + +struct dataflash_addr cs[CONFIG_SYS_MAX_DATAFLASH_BANKS] = { + {CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS0, 0}, /* Logical adress, CS */ + {CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS3, 3} +}; + +/*define the area offsets*/ +dataflash_protect_t area_list[NB_DATAFLASH_AREA] = { + {0x00000000, 0x000041FF, FLAG_PROTECT_SET, 0, "Bootstrap"}, + {0x00004200, 0x000083FF, FLAG_PROTECT_CLEAR, 0, "Environment"}, + {0x00008400, 0x00041FFF, FLAG_PROTECT_SET, 0, "U-Boot"}, + {0x00042000, 0x00251FFF, FLAG_PROTECT_CLEAR, 0, "Kernel"}, + {0x00252000, 0xFFFFFFFF, FLAG_PROTECT_CLEAR, 0, "FS"}, +}; diff --git a/board/olimex/sam9_l9261/sam9_l9261.c b/board/olimex/sam9_l9261/sam9_l9261.c new file mode 100644 index 0000000..3880204 --- /dev/null +++ b/board/olimex/sam9_l9261/sam9_l9261.c @@ -0,0 +1,214 @@ +/* + * (C) Copyright 2007-2008 + * Stelian Pop stelian.pop@leadtechdesign.com + * Lead Tech Design <www.leadtechdesign.com> + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/arch/at91sam9261.h> +#include <asm/arch/at91sam9261_matrix.h> +#include <asm/arch/at91sam9_smc.h> +#include <asm/arch/at91_common.h> +#include <asm/arch/at91_pmc.h> +#include <asm/arch/at91_rstc.h> +#include <asm/arch/clk.h> +#include <asm/arch/gpio.h> +#include <asm/arch/io.h> +#include <lcd.h> +#include <atmel_lcdc.h> + +DECLARE_GLOBAL_DATA_PTR; + +/* ------------------------------------------------------------------------- */ +/* + * Miscelaneous platform dependent initialisations + */ + +#ifdef CONFIG_CMD_NAND +static void at91sam9261_nand_hw_init(void) +{ + unsigned long csa; + + /* Enable CS3 */ + csa = at91_sys_read(AT91_MATRIX_EBICSA); + at91_sys_write(AT91_MATRIX_EBICSA, + csa | AT91_MATRIX_CS3A_SMC_SMARTMEDIA); + + /* Configure SMC CS3 for NAND/SmartMedia */ + at91_sys_write(AT91_SMC_SETUP(3), + AT91_SMC_NWESETUP_(1) | AT91_SMC_NCS_WRSETUP_(0) | + AT91_SMC_NRDSETUP_(1) | AT91_SMC_NCS_RDSETUP_(0)); + at91_sys_write(AT91_SMC_PULSE(3), + AT91_SMC_NWEPULSE_(3) | AT91_SMC_NCS_WRPULSE_(3) | + AT91_SMC_NRDPULSE_(3) | AT91_SMC_NCS_RDPULSE_(3)); + at91_sys_write(AT91_SMC_CYCLE(3), + AT91_SMC_NWECYCLE_(5) | AT91_SMC_NRDCYCLE_(5)); + at91_sys_write(AT91_SMC_MODE(3), + AT91_SMC_READMODE | AT91_SMC_WRITEMODE | + AT91_SMC_EXNWMODE_DISABLE | +#ifdef CONFIG_SYS_NAND_DBW_16 + AT91_SMC_DBW_16 | +#else /* CONFIG_SYS_NAND_DBW_8 */ + AT91_SMC_DBW_8 | +#endif + AT91_SMC_TDF_(2)); + + at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9261_ID_PIOC); + + /* Configure RDY/BSY */ + at91_set_gpio_input(CONFIG_SYS_NAND_READY_PIN, 1); + + /* Enable NandFlash */ + at91_set_gpio_output(CONFIG_SYS_NAND_ENABLE_PIN, 1); + at91_set_gpio_output(AT91_PIN_PC14, 1); + + at91_set_A_periph(AT91_PIN_PC0, 0); /* NANDOE */ + at91_set_A_periph(AT91_PIN_PC1, 0); /* NANDWE */ +} +#endif + +#ifdef CONFIG_LCD +vidinfo_t panel_info = { + vl_col: 320, + vl_row: 240, + vl_clk: 4965000, + vl_sync: 0 /*ATMEL_LCDC_INVLINE_INVERTED | + ATMEL_LCDC_INVFRAME_INVERTED */, + vl_bpix: 3, + vl_tft: 1, + vl_hsync_len: 30, + vl_left_margin: 20, + vl_right_margin:38, + vl_vsync_len: 3, + vl_upper_margin:4, + vl_lower_margin:15, + mmio: AT91SAM9261_LCDC_BASE, +}; + +void lcd_enable(void) +{ + at91_set_gpio_output(AT91_PIN_PA12, 0); /* power up */ +} + +void lcd_disable(void) +{ + at91_set_gpio_output(AT91_PIN_PA12, 1); /* power down */ +} + +static void at91sam9261_lcd_hw_init(void) +{ + at91_set_A_periph(AT91_PIN_PB0, 0); /* LCDVSYNC */ + at91_set_A_periph(AT91_PIN_PB1, 0); /* LCDHSYNC */ + at91_set_A_periph(AT91_PIN_PB2, 0); /* LCDDOTCK */ + at91_set_A_periph(AT91_PIN_PB3, 0); /* LCDDEN */ + + at91_set_A_periph(AT91_PIN_PB5, 0); /* LCDD R0 */ + at91_set_A_periph(AT91_PIN_PB6, 0); /* LCDD R1 */ + at91_set_A_periph(AT91_PIN_PB7, 0); /* LCDD R2 */ + at91_set_A_periph(AT91_PIN_PB8, 0); /* LCDD R3 */ + at91_set_A_periph(AT91_PIN_PB9, 0); /* LCDD R4 */ + at91_set_A_periph(AT91_PIN_PB10, 0); /* LCDD R5 */ + at91_set_A_periph(AT91_PIN_PB11, 0); /* LCDD R6 */ + at91_set_A_periph(AT91_PIN_PB12, 0); /* LCDD R7 */ + + at91_set_A_periph(AT91_PIN_PB13, 0); /* LCDD G0 */ + at91_set_A_periph(AT91_PIN_PB14, 0); /* LCDD G1 */ + at91_set_A_periph(AT91_PIN_PB15, 0); /* LCDD G2 */ + at91_set_A_periph(AT91_PIN_PB16, 0); /* LCDD G3 */ + at91_set_A_periph(AT91_PIN_PB17, 0); /* LCDD G4 */ + at91_set_A_periph(AT91_PIN_PB18, 0); /* LCDD G5 */ + at91_set_A_periph(AT91_PIN_PB19, 0); /* LCDD G6 */ + at91_set_A_periph(AT91_PIN_PB20, 0); /* LCDD G7 */ + + at91_set_B_periph(AT91_PIN_PB21, 0); /* LCDD B0 */ + at91_set_B_periph(AT91_PIN_PB22, 0); /* LCDD B1 */ + at91_set_B_periph(AT91_PIN_PB23, 0); /* LCDD B2 */ + at91_set_B_periph(AT91_PIN_PB24, 0); /* LCDD B3 */ + at91_set_B_periph(AT91_PIN_PB25, 0); /* LCDD B4 */ + at91_set_B_periph(AT91_PIN_PB26, 0); /* LCDD B5 */ + at91_set_B_periph(AT91_PIN_PB27, 0); /* LCDD B6 */ + at91_set_B_periph(AT91_PIN_PB28, 0); /* LCDD B7 */ + + at91_sys_write(AT91_PMC_SCER, AT91_PMC_HCK1); + + gd->fb_base = AT91SAM9261_SRAM_BASE; +} + +#ifdef CONFIG_LCD_INFO +#include <nand.h> +#include <version.h> + +void lcd_show_board_info(void) +{ + ulong dram_size, nand_size; + int i; + char temp[32]; + + lcd_printf ("%s\n", U_BOOT_VERSION); + lcd_printf ("(C) 2009 Olimex Ltd\n"); + lcd_printf ("support@olimex.com\n"); + lcd_printf ("%s CPU at %s MHz\n", + AT91_CPU_NAME, + strmhz(temp, get_cpu_clk_rate())); + + dram_size = 0; + for (i = 0; i < CONFIG_NR_DRAM_BANKS; i++) + dram_size += gd->bd->bi_dram[i].size; + nand_size = 0; + for (i = 0; i < CONFIG_SYS_MAX_NAND_DEVICE; i++) + nand_size += nand_info[i].size; + lcd_printf (" %ld MB SDRAM, %ld MB NAND\n", + dram_size >> 20, + nand_size >> 20 ); +} +#endif /* CONFIG_LCD_INFO */ +#endif + +int board_init(void) +{ + /* Enable Ctrlc */ + console_init_f(); + + /* arch number of AT91SAM9261EK-Board */ + gd->bd->bi_arch_number = MACH_TYPE_SAM9_L9261; + /* adress of boot parameters */ + gd->bd->bi_boot_params = PHYS_SDRAM + 0x100; + + at91_serial_hw_init(); +#ifdef CONFIG_CMD_NAND + at91sam9261_nand_hw_init(); +#endif +#ifdef CONFIG_HAS_DATAFLASH + at91_spi0_hw_init(1 << 0); +#endif +#ifdef CONFIG_LCD + at91sam9261_lcd_hw_init(); +#endif + return 0; +} + +int dram_init(void) +{ + gd->bd->bi_dram[0].start = PHYS_SDRAM; + gd->bd->bi_dram[0].size = PHYS_SDRAM_SIZE; + return 0; +} + diff --git a/include/configs/sam9_l9261.h b/include/configs/sam9_l9261.h new file mode 100644 index 0000000..5cc550a --- /dev/null +++ b/include/configs/sam9_l9261.h @@ -0,0 +1,230 @@ +/* + * (C) Copyright 2007-2008 + * Stelian Pop stelian.pop@leadtechdesign.com + * Lead Tech Design <www.leadtechdesign.com> + * + * Configuation settings for the SAM9-L9261 board, based on the + * AT91SAM9261EK board configuration. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +/* ARM asynchronous clock */ +#define AT91_CPU_NAME "AT91SAM9261" +#define AT91_MAIN_CLOCK 18432000 /* 18.432 MHz crystal */ +#define CONFIG_SYS_HZ 1000 + +#define CONFIG_ARM926EJS 1 /* This is an ARM926EJS Core */ +#define CONFIG_AT91SAM9261 1 /* It's an Atmel AT91SAM9261 SoC*/ +#define CONFIG_SAM9_L9261 1 /* on an SAM9_L9261 Board */ +#define CONFIG_ARCH_CPU_INIT +#undef CONFIG_USE_IRQ /* we don't need IRQ/FIQ stuff */ + +#define CONFIG_CMDLINE_TAG 1 /* enable passing of ATAGs */ +#define CONFIG_SETUP_MEMORY_TAGS 1 +#define CONFIG_INITRD_TAG 1 + +#define CONFIG_SKIP_LOWLEVEL_INIT +#define CONFIG_SKIP_RELOCATE_UBOOT + +/* + * Hardware drivers + */ +#define CONFIG_ATMEL_USART 1 +#undef CONFIG_USART0 +#undef CONFIG_USART1 +#undef CONFIG_USART2 +#define CONFIG_USART3 1 /* USART 3 is DBGU */ + +/* LCD */ +#define CONFIG_LCD 1 +#define LCD_BPP LCD_COLOR8 +#define CONFIG_LCD_LOGO 1 +#undef LCD_TEST_PATTERN +#define CONFIG_LCD_INFO 1 +#define CONFIG_LCD_INFO_BELOW_LOGO 1 +#define CONFIG_LCD_INVERTED_CLOCK 1 +#define CONFIG_SYS_WHITE_ON_BLACK 1 +#define CONFIG_ATMEL_LCD 1 +#define CONFIG_ATMEL_LCD_BGR555 1 +#define CONFIG_SYS_CONSOLE_IS_IN_ENV 1 + +/* LED */ +#define CONFIG_AT91_LED +#define CONFIG_RED_LED AT91_PIN_PA23 /* this is the power led */ +#define CONFIG_GREEN_LED AT91_PIN_PA13 /* this is the user1 led */ +#define CONFIG_YELLOW_LED AT91_PIN_PA14 /* this is the user2 led */ + +#define CONFIG_BOOTDELAY 3 + +/* + * BOOTP options + */ +#define CONFIG_BOOTP_BOOTFILESIZE 1 +#define CONFIG_BOOTP_BOOTPATH 1 +#define CONFIG_BOOTP_GATEWAY 1 +#define CONFIG_BOOTP_HOSTNAME 1 + +/* + * Command line configuration. + */ +#include <config_cmd_default.h> +#undef CONFIG_CMD_BDI +#undef CONFIG_CMD_FPGA +#undef CONFIG_CMD_IMI +#undef CONFIG_CMD_IMLS +#undef CONFIG_CMD_LOADS +#undef CONFIG_CMD_SOURCE + +#define CONFIG_CMD_PING 1 +#define CONFIG_CMD_DHCP 1 +#define CONFIG_CMD_NAND 1 +#define CONFIG_CMD_USB 1 + +/* SDRAM */ +#define CONFIG_NR_DRAM_BANKS 1 +#define PHYS_SDRAM 0x20000000 +#define PHYS_SDRAM_SIZE 0x04000000 /* 64 megs */ + +/* DataFlash */ +#define CONFIG_ATMEL_DATAFLASH_SPI +#define CONFIG_HAS_DATAFLASH 1 +#define CONFIG_SYS_SPI_WRITE_TOUT (5*CONFIG_SYS_HZ) +#define CONFIG_SYS_MAX_DATAFLASH_BANKS 2 +#define CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS0 0xC0000000 /* CS0 */ +#define CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS3 0xD0000000 /* CS3 */ +#define AT91_SPI_CLK 15000000 +#define DATAFLASH_TCSS (0x1a << 16) +#define DATAFLASH_TCHS (0x1 << 24) + +/* NAND flash */ +#ifdef CONFIG_CMD_NAND +#define CONFIG_NAND_ATMEL +#define CONFIG_SYS_MAX_NAND_DEVICE 1 +#define CONFIG_SYS_NAND_BASE 0x40000000 +#define CONFIG_SYS_NAND_DBW_8 1 +/* our ALE is AD22 */ +#define CONFIG_SYS_NAND_MASK_ALE (1 << 22) +/* our CLE is AD21 */ +#define CONFIG_SYS_NAND_MASK_CLE (1 << 21) +#define CONFIG_SYS_NAND_ENABLE_PIN AT91_PIN_PC14 +#define CONFIG_SYS_NAND_READY_PIN AT91_PIN_PC15 +#endif + +/* NOR flash - no real flash on this board */ +#define CONFIG_SYS_NO_FLASH 1 + +/* Ethernet */ +#define CONFIG_NET_MULTI 1 +#define CONFIG_DRIVER_DM9000 1 +#define CONFIG_DM9000_BASE 0x30000000 +#define DM9000_IO CONFIG_DM9000_BASE +#define DM9000_DATA (CONFIG_DM9000_BASE + 4) +#define CONFIG_DM9000_USE_16BIT 1 +#define CONFIG_DM9000_NO_SROM 1 +#define CONFIG_NET_RETRY_COUNT 20 + +/* USB */ +#define CONFIG_USB_ATMEL +#define CONFIG_USB_OHCI_NEW 1 +#define CONFIG_DOS_PARTITION 1 +#define CONFIG_SYS_USB_OHCI_CPU_INIT 1 +#define CONFIG_SYS_USB_OHCI_REGS_BASE 0x00500000 +#define CONFIG_SYS_USB_OHCI_SLOT_NAME "at91sam9261" +#define CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS 2 +#define CONFIG_USB_STORAGE 1 +#define CONFIG_CMD_FAT 1 + +#define CONFIG_SYS_LOAD_ADDR 0x22000000 + +#define CONFIG_SYS_MEMTEST_START PHYS_SDRAM +#define CONFIG_SYS_MEMTEST_END 0x23e00000 + +#ifdef CONFIG_SYS_USE_DATAFLASH_CS0 + +/* bootstrap + u-boot + env + linux in dataflash on CS0 */ +#define CONFIG_ENV_IS_IN_DATAFLASH 1 +#define CONFIG_SYS_MONITOR_BASE (CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS0 + 0x8400) +#define CONFIG_ENV_OFFSET 0x4200 +#define CONFIG_ENV_ADDR (CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS0 + CONFIG_ENV_OFFSET) +#define CONFIG_ENV_SIZE 0x4200 +#define CONFIG_BOOTCOMMAND "cp.b 0xC0042000 0x22000000 0x210000; bootm" +#define CONFIG_BOOTARGS "console=ttyS0,115200 " \ + "root=/dev/mtdblock0 " \ + "mtdparts=at91_nand:-(root) " \ + "rw rootfstype=jffs2" + +#elif CONFIG_SYS_USE_DATAFLASH_CS3 + +/* bootstrap + u-boot + env + linux in dataflash on CS3 */ +#define CONFIG_ENV_IS_IN_DATAFLASH 1 +#define CONFIG_SYS_MONITOR_BASE (CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS3 + 0x8400) +#define CONFIG_ENV_OFFSET 0x4200 +#define CONFIG_ENV_ADDR (CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS3 + CONFIG_ENV_OFFSET) +#define CONFIG_ENV_SIZE 0x4200 +#define CONFIG_BOOTCOMMAND "cp.b 0xD0042000 0x22000000 0x210000; bootm" +#define CONFIG_BOOTARGS "console=ttyS0,115200 " \ + "root=/dev/mtdblock0 " \ + "mtdparts=at91_nand:-(root) " \ + "rw rootfstype=jffs2" + +#else /* CONFIG_SYS_USE_NANDFLASH */ + +/* bootstrap + u-boot + env + linux in nandflash */ +#define CONFIG_ENV_IS_IN_NAND 1 +#define CONFIG_ENV_OFFSET 0x60000 +#define CONFIG_ENV_OFFSET_REDUND 0x80000 +#define CONFIG_ENV_SIZE 0x20000 /* 1 sector = 128 kB */ +#define CONFIG_BOOTCOMMAND "nand read 0x22000000 0xA0000 0x200000; bootm" +#define CONFIG_BOOTARGS "console=ttyS0,115200 " \ + "root=/dev/mtdblock5 " \ + "mtdparts=at91_nand:128k(bootstrap)ro," \ + "256k(uboot)ro,128k(env1)ro," \ + "128k(env2)ro,2M(linux),-(root) " \ + "rw rootfstype=jffs2" + +#endif + +#define CONFIG_BAUDRATE 115200 +#define CONFIG_SYS_BAUDRATE_TABLE {115200 , 19200, 38400, 57600, 9600 } + +#define CONFIG_SYS_PROMPT "U-Boot> " +#define CONFIG_SYS_CBSIZE 256 +#define CONFIG_SYS_MAXARGS 16 +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_LONGHELP 1 +#define CONFIG_CMDLINE_EDITING 1 + +#define ROUND(A, B) (((A) + (B)) & ~((B) - 1)) +/* + * Size of malloc() pool + */ +#define CONFIG_SYS_MALLOC_LEN ROUND(3 * CONFIG_ENV_SIZE + 128*1024, 0x1000) +#define CONFIG_SYS_GBL_DATA_SIZE 128 /* 128 bytes for initial data */ + +#define CONFIG_STACKSIZE (32*1024) /* regular stack */ + +#ifdef CONFIG_USE_IRQ +#error CONFIG_USE_IRQ not supported +#endif + +#endif diff --git a/tools/Makefile b/tools/Makefile index 43c284c..c56c56a 100644 --- a/tools/Makefile +++ b/tools/Makefile @@ -122,6 +122,9 @@ endif ifeq ($(VENDOR),atmel) LOGO_BMP= logos/atmel.bmp endif +ifeq ($(VENDOR),olimex) +LOGO_BMP= logos/olimex.bmp +endif ifeq ($(VENDOR),ronetix) LOGO_BMP= logos/ronetix.bmp endif diff --git a/tools/logos/olimex.bmp b/tools/logos/olimex.bmp new file mode 100644 index 0000000000000000000000000000000000000000..a787d71dd6b9da0f3122d0cce16845bf18e04610 GIT binary patch literal 27510 zcmeI0J8~w)7KDGn5J3bUHVeRH4fyNd+@PYu2z66UB=$c~y5yNX!JS%c!$5zdTi4 z`e)|CufP5I$76i`-M;_ae*N_Hc>La;Pmk~0_s8R}&yUBCKg?ghv~~aW^77KZ%Ri6j z=jXQmdcL04*EjO@?fTMJ`0juEb>B_>qrdOwzMJ|6>g4|1+;>yoK%Ly5oBM9+8>kcg zzcIJCZ{WUx`v&eCxNqRTf%^vT8@O-a?KdF*T0)b=YX9-@<d-&{&Ua3Z9+=F((s?^8 zyY}at#?Hw%eMRNU$!Yv?jbN7BB7>Fg16;P9xx%B0%XxWu{9%Eov)&b%t90-CY&Uad z2NfTi_3?Ov%ZIzHIhvMbCA>0~AbTCFsp^rM>?=NXYn@UF$8Ud|d)BOr4Ggnc#H-mJ zW$hLQ@+m^-4Tcl#@!f#}YmH=j^1`<Bq#qWbs?veRlwn%o<4d@Cnqgrf#THB%2pGav zPmoX*E52;oUTRsrOA@1^!VqcD-AK57#+l?uvsqJ8=A@wY(-m~)z9IX{6SX+cIx-gx z+>K-hPdm`Aq^jd>jFo`fC-9-RY!5rNpePRiVvuSdBU_DqX)S*FltO&QN@Ru;!PK$s z6fq{hlmy{D?NDBYihOP)IPv6ptdlCoq!Ti=sG{$fg5Ja}X~MG#t?Uwld4IQ-j(sK# z3+O5#3rj24u7-bK$YhKvm7wdnIOiTMv*}qU<F37>PRPcWUT@h@=WK=Ttlv`3JY2>d z(n`dd<4DgGv9<T5nVN<#<ZDxrKW*HBW7D?cANoG;>o{dN7LAb2Wr}q}i(?5hPqO^U z4cXZJFtehmwS{GT8UVr#OTI{x>qf>El%EQ~RLh+fgjZ-#g-mj}%0$<@%*BklAA=bq zoY`ub><M@DMCXW<91S{HYD!~12^kWpPiQV6RZOdCMS_rJ+06=_4P+uT=p9ni)cg+| zpB(B=>3VL-xQk?&AY=)3_(bOrT>u&v@5cRsEtf;{x;#7v@fAym%p<F61s|Od6$Toz zZv#^^3?OPqTbyYqd4q=dNY;eN8Oajr@QKbLx&Sm}-xj21oJd$MV<k9L4B0XWku#E2 zwStdMi256+rgo63l~z)YDk=fiO5u7dLgWp|N=G9{oOvTX5y-xc2Tdk+fg&)G;A%y+ z3L->~Lsr^CjyUsr3g7>DD9OgiVUSrx^&l--tf*BG+2M~`$T2kYS_-=>;5LF!JWNqD zv@0rz6yV?~czaePA;OTAwvZ#vJbyJZf40ydKQ-4blF6pBc29|qo>Z$)Lgb8Or7h%$ zGtYf$8Uo(j8*Gd*Yy&8fh%IOg+bc9=Uf>B4hOB^h13BW%BXGswd5Y|7Mw8iFnBUc! zW6il*(eZ=I6--F7W!gdoapvg@HEibK#Th<qjM=Nzh!92{De6`zA@6lJee1amAA&Z9 zP3B&%iia@iP*JsF3Hb`|Mn9VKHL91)e0uRL?j9lUbvJG9+Jz568^b0ulR8L_isn^i z#usH~7D859LXJ4|<VMnr!)y#nP@P*VR9>erw5wtULkl4*Eg?sodGa1<#$h%FC8*A= z6)LY&7&=rwgrP-{m3ELL&OCXKG~+NEgA!Ed)(Vx^DGVJdAHvWg$VxlN5oeyhh=jnK z60<$wlew2tv6Q&SPurstaFwCulf|TJ<Z98I!fOg>QzqdEf#G+HRq+TW9jH~56XrBe zj~k{PR1jxgPvN_($rHl2a%~(LoM^9RQxBNKJbn>mr5)smGjF6P0=hNOTNMwgIF7Vc zlW&NM1lOTWteC8%AmciP7#(;+oe0t~WcE22gKdqc3%7r<RD6n@VrUU$r5)smGjF6P z0=fp!WX@d>tzBVQg+pzWt%S||mijTEUOF8);>;WAiGWT9noR7%iclw+s`RM}Lu(LO z>1gDLGjF6P0=fp!WMUUmL<UJ%DNU)Mm{|x}X$d*v%p2*6fUW^Fnb-x2z(j&8m1z|e zGYcUrEg?soc_Td$&^3T26T7G)E|m(_f_fE1h#ZHkw1pgT=8d!r=&zn^j2s3TDGaR? z!G)w|LC^``<<DX|fqz>>I2$}qgK>YM_eyGUBhe?eB1DcuRx*>%ffyZlO~LNUM3liN z9;R0WP1%9e^i5uKfql{mLKcCL$oF16F!-kSW86hj6TPKoR@hXu((pEt6(h?dODOY1 z4m<Pc?IlLx)psMK^eHpd5FtVS6ly**#t;i2FRRciBSt6lkkZEiW>JAn3azD(Z6ZLb z9Id_z3oM&V1z8}6n|QE{(hgj;=-PV<UlmGAY0^XphrtAC4^uRx%_SvQEPhgq)3bS5 z>-5V_9AM1I`#RnV5ARaVsH7eQrA>-&-HR(3QvKxXacEAJlb%}Z9L`(}pcJMk3WvPB zj~~$1GP^yKbYoF*caDfnXEWJE)F+?ZB`F-Tusyb2^DbM^h1?VEkhzr5KT|lE+@g@} zp(&ek5y5ApF}w`g>=M$_Fg0CdxQ1S2u=h-dLgV*^WU3Y+e)b$l7KpcIoERmI{<JNu z!1zOgQ3beCiVi`P4ccmD-6yFFs;ZnbbeV`r==X$3EX9LRxFu5u1ct(e067#<E|I;) z&un26p^lR>!r8nOM4p^gTG;G4J0l^Pk<F_%$eTomc`NHaNnKFY#A8kjBQrNFNew1f ze8*U*0&TX=OhjlAQ)U=B5$dqCeNI?gs;@ZBbZoFA4IRT_)Pl$7mJMOmkA8PtJ%<9; zTNOHeH`gyi*#mAJ_+>b(FA0q)g+ngF+nn)`vm75Hba-H@eItebee*xs_S%cMLtZPt zfwud;VbFV4%^}}&BR8A(b<vlzq(gq_p|J0VZhLXFb;^sa8^3ShzJdD&?i;vo;Dc}A w)2B!K=P|#1@ZMkgcI|4~#f<-b=|}zW^Q~*?AD#Ql-GKat8c&zqOTB@A01O0K1ONa4
literal 0 HcmV?d00001
this patch look at 80% similar as the at91sam9261ek
could you regenerate it with git format-patch -M -B -C
<snip>
- Miscelaneous platform dependent initialisations
why don't you configure the dm9000 SMC? <snip>
no-need please remove
- Hardware drivers
please fix the indent
- BOOTP options
<snip>
- Size of malloc() pool
Best Regards, J.
The SAM9-L9260 board support is based on code for AT91SAM9260EK. Networking is missing and will be added after the MACB support for AT91 boards is fixed to comply with U-Boot guide-lines.
Signed-off-by: Dimitar Dimitrov dinuxbg@gmail.com --- MAINTAINERS | 1 + MAKEALL | 1 + Makefile | 17 +++ board/olimex/sam9_l9260/Makefile | 56 +++++++++ board/olimex/sam9_l9260/config.mk | 1 + board/olimex/sam9_l9260/led.c | 41 +++++++ board/olimex/sam9_l9260/partition.c | 40 +++++++ board/olimex/sam9_l9260/sam9_l9260.c | 111 ++++++++++++++++++ include/configs/sam9_l9260.h | 214 ++++++++++++++++++++++++++++++++++ 9 files changed, 482 insertions(+), 0 deletions(-) create mode 100644 board/olimex/sam9_l9260/Makefile create mode 100644 board/olimex/sam9_l9260/config.mk create mode 100644 board/olimex/sam9_l9260/led.c create mode 100644 board/olimex/sam9_l9260/partition.c create mode 100644 board/olimex/sam9_l9260/sam9_l9260.c create mode 100644 include/configs/sam9_l9260.h
diff --git a/MAINTAINERS b/MAINTAINERS index dfcccf5..8487c36 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -134,6 +134,7 @@ Jon Diekema jon.diekema@smiths-aerospace.com sbc8260 MPC8260
Dimitar Dimitrov dinuxbg@gmail.com + sam9_l9260 AT91SAM9260 sam9_l9261 AT91SAM9261
Dirk Eibach eibach@gdsys.de diff --git a/MAKEALL b/MAKEALL index ecabfcf..57d04de 100755 --- a/MAKEALL +++ b/MAKEALL @@ -599,6 +599,7 @@ LIST_at91=" \ m501sk \ pm9261 \ pm9263 \ + sam9_l9260 \ sam9_l9261 \ "
diff --git a/Makefile b/Makefile index b19c3b0..1e39850 100644 --- a/Makefile +++ b/Makefile @@ -2847,6 +2847,23 @@ at91sam9g45ekes_config : unconfig pm9263_config : unconfig @$(MKCONFIG) $(@:_config=) arm arm926ejs pm9263 ronetix at91
+sam9_l9260_nandflash_config \ +sam9_l9260_dataflash_cs0_config \ +sam9_l9260_dataflash_cs1_config \ +sam9_l9260_config : unconfig + @mkdir -p $(obj)include + @if [ "$(findstring _nandflash,$@)" ] ; then \ + echo "#define CONFIG_SYS_USE_NANDFLASH 1" >>$(obj)include/config.h ; \ + $(XECHO) "... with environment variable in NAND FLASH" ; \ + elif [ "$(findstring dataflash_cs0,$@)" ] ; then \ + echo "#define CONFIG_SYS_USE_DATAFLASH_CS0 1" >>$(obj)include/config.h ; \ + $(XECHO) "... with environment variable in SPI DATAFLASH CS0" ; \ + else \ + echo "#define CONFIG_SYS_USE_DATAFLASH_CS1 1" >>$(obj)include/config.h ; \ + $(XECHO) "... with environment variable in SPI DATAFLASH CS1" ; \ + fi; + @$(MKCONFIG) -a sam9_l9260 arm arm926ejs sam9_l9260 olimex at91 + sam9_l9261_nandflash_config \ sam9_l9261_dataflash_cs0_config \ sam9_l9261_dataflash_cs3_config \ diff --git a/board/olimex/sam9_l9260/Makefile b/board/olimex/sam9_l9260/Makefile new file mode 100644 index 0000000..39db0ea --- /dev/null +++ b/board/olimex/sam9_l9260/Makefile @@ -0,0 +1,56 @@ +# +# (C) Copyright 2003-2008 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# (C) Copyright 2008 +# Stelian Pop stelian.pop@leadtechdesign.com +# Lead Tech Design <www.leadtechdesign.com> +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).a + +COBJS-y += sam9_l9260.o +COBJS-y += led.o +COBJS-$(CONFIG_HAS_DATAFLASH) += partition.o + +SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS-y)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) $(SOBJS) + +clean: + rm -f $(SOBJS) $(OBJS) + +distclean: clean + rm -f $(LIB) core *.bak $(obj).depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/olimex/sam9_l9260/config.mk b/board/olimex/sam9_l9260/config.mk new file mode 100644 index 0000000..ff2cfd1 --- /dev/null +++ b/board/olimex/sam9_l9260/config.mk @@ -0,0 +1 @@ +TEXT_BASE = 0x23f00000 diff --git a/board/olimex/sam9_l9260/led.c b/board/olimex/sam9_l9260/led.c new file mode 100644 index 0000000..2424d27 --- /dev/null +++ b/board/olimex/sam9_l9260/led.c @@ -0,0 +1,41 @@ +/* + * (C) Copyright 2007-2008 + * Stelian Pop stelian.pop@leadtechdesign.com + * Lead Tech Design <www.leadtechdesign.com> + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/arch/at91sam9260.h> +#include <asm/arch/at91_pmc.h> +#include <asm/arch/gpio.h> +#include <asm/arch/io.h> + +void coloured_LED_init(void) +{ + /* Enable clock */ + at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9260_ID_PIOA); + + at91_set_gpio_output(CONFIG_RED_LED, 1); + at91_set_gpio_output(CONFIG_GREEN_LED, 1); + + at91_set_gpio_value(CONFIG_RED_LED, 0); + at91_set_gpio_value(CONFIG_GREEN_LED, 1); +} diff --git a/board/olimex/sam9_l9260/partition.c b/board/olimex/sam9_l9260/partition.c new file mode 100644 index 0000000..2629c67 --- /dev/null +++ b/board/olimex/sam9_l9260/partition.c @@ -0,0 +1,40 @@ +/* + * (C) Copyright 2008 + * Ulf Samuelsson ulf@atmel.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + * + */ +#include <common.h> +#include <config.h> +#include <asm/hardware.h> +#include <dataflash.h> + +AT91S_DATAFLASH_INFO dataflash_info[CONFIG_SYS_MAX_DATAFLASH_BANKS]; + +struct dataflash_addr cs[CONFIG_SYS_MAX_DATAFLASH_BANKS] = { + {CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS0, 0}, /* Logical adress, CS */ + {CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS1, 1} +}; + +/*define the area offsets*/ +dataflash_protect_t area_list[NB_DATAFLASH_AREA] = { + {0x00000000, 0x000041FF, FLAG_PROTECT_SET, 0, "Bootstrap"}, + {0x00004200, 0x000083FF, FLAG_PROTECT_CLEAR, 0, "Environment"}, + {0x00008400, 0x00041FFF, FLAG_PROTECT_SET, 0, "U-Boot"}, + {0x00042000, 0x00251FFF, FLAG_PROTECT_CLEAR, 0, "Kernel"}, + {0x00252000, 0xFFFFFFFF, FLAG_PROTECT_CLEAR, 0, "FS"}, +}; diff --git a/board/olimex/sam9_l9260/sam9_l9260.c b/board/olimex/sam9_l9260/sam9_l9260.c new file mode 100644 index 0000000..30ea3d0 --- /dev/null +++ b/board/olimex/sam9_l9260/sam9_l9260.c @@ -0,0 +1,111 @@ +/* + * (C) Copyright 2007-2008 + * Stelian Pop stelian.pop@leadtechdesign.com + * Lead Tech Design <www.leadtechdesign.com> + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/arch/at91sam9260.h> +#include <asm/arch/at91sam9260_matrix.h> +#include <asm/arch/at91sam9_smc.h> +#include <asm/arch/at91_common.h> +#include <asm/arch/at91_pmc.h> +#include <asm/arch/at91_rstc.h> +#include <asm/arch/gpio.h> +#include <asm/arch/io.h> +#include <asm/arch/hardware.h> +#include <netdev.h> + +DECLARE_GLOBAL_DATA_PTR; + +/* ------------------------------------------------------------------------- */ +/* + * Miscelaneous platform dependent initialisations + */ + +#ifdef CONFIG_CMD_NAND +static void at91sam9260_nand_hw_init(void) +{ + unsigned long csa; + + /* Enable CS3 */ + csa = at91_sys_read(AT91_MATRIX_EBICSA); + at91_sys_write(AT91_MATRIX_EBICSA, + csa | AT91_MATRIX_CS3A_SMC_SMARTMEDIA); + + /* Configure SMC CS3 for NAND/SmartMedia */ + at91_sys_write(AT91_SMC_SETUP(3), + AT91_SMC_NWESETUP_(1) | AT91_SMC_NCS_WRSETUP_(0) | + AT91_SMC_NRDSETUP_(1) | AT91_SMC_NCS_RDSETUP_(0)); + at91_sys_write(AT91_SMC_PULSE(3), + AT91_SMC_NWEPULSE_(3) | AT91_SMC_NCS_WRPULSE_(3) | + AT91_SMC_NRDPULSE_(3) | AT91_SMC_NCS_RDPULSE_(3)); + at91_sys_write(AT91_SMC_CYCLE(3), + AT91_SMC_NWECYCLE_(5) | AT91_SMC_NRDCYCLE_(5)); + at91_sys_write(AT91_SMC_MODE(3), + AT91_SMC_READMODE | AT91_SMC_WRITEMODE | + AT91_SMC_EXNWMODE_DISABLE | +#ifdef CONFIG_SYS_NAND_DBW_16 + AT91_SMC_DBW_16 | +#else /* CONFIG_SYS_NAND_DBW_8 */ + AT91_SMC_DBW_8 | +#endif + AT91_SMC_TDF_(2)); + + at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9260_ID_PIOC); + + /* Configure RDY/BSY */ + at91_set_gpio_input(CONFIG_SYS_NAND_READY_PIN, 1); + + /* Enable NandFlash */ + at91_set_gpio_output(CONFIG_SYS_NAND_ENABLE_PIN, 1); +} +#endif + + +int board_init(void) +{ + /* Enable Ctrlc */ + console_init_f(); + + /* arch number of SAM9_L9260-Board */ + gd->bd->bi_arch_number = MACH_TYPE_SAM9_L9260; + /* adress of boot parameters */ + gd->bd->bi_boot_params = PHYS_SDRAM + 0x100; + + at91_serial_hw_init(); +#ifdef CONFIG_CMD_NAND + at91sam9260_nand_hw_init(); +#endif +#ifdef CONFIG_HAS_DATAFLASH + at91_spi0_hw_init((1 << 0) || (1 << 1)); +#endif + + return 0; +} + +int dram_init(void) +{ + gd->bd->bi_dram[0].start = PHYS_SDRAM; + gd->bd->bi_dram[0].size = PHYS_SDRAM_SIZE; + return 0; +} + diff --git a/include/configs/sam9_l9260.h b/include/configs/sam9_l9260.h new file mode 100644 index 0000000..9232c13 --- /dev/null +++ b/include/configs/sam9_l9260.h @@ -0,0 +1,214 @@ +/* + * (C) Copyright 2007-2008 + * Stelian Pop stelian.pop@leadtechdesign.com + * Lead Tech Design <www.leadtechdesign.com> + * Dimitar Dimitrov dimitar@olimex.com + * + * Configuation settings for the SAM9-L9260 board. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +/* ARM asynchronous clock */ +#define AT91_MAIN_CLOCK 18432000 /* 18.432 MHz crystal */ +#define CONFIG_SYS_HZ 1000 + +#define CONFIG_ARM926EJS 1 /* This is an ARM926EJS Core */ + +#define AT91_CPU_NAME "AT91SAM9260" +#define CONFIG_AT91SAM9260 1 /* It's an Atmel AT91SAM9260 SoC*/ +#define CONFIG_SAM9_L9260 1 /* on an SAM9_L9260 Board */ + +#define CONFIG_ARCH_CPU_INIT +#undef CONFIG_USE_IRQ /* we don't need IRQ/FIQ stuff */ + +#define CONFIG_CMDLINE_TAG 1 /* enable passing of ATAGs */ +#define CONFIG_SETUP_MEMORY_TAGS 1 +#define CONFIG_INITRD_TAG 1 + +#define CONFIG_SKIP_LOWLEVEL_INIT +#define CONFIG_SKIP_RELOCATE_UBOOT + +/* + * Hardware drivers + */ +#define CONFIG_ATMEL_USART 1 +#undef CONFIG_USART0 +#undef CONFIG_USART1 +#undef CONFIG_USART2 +#define CONFIG_USART3 1 /* USART 3 is DBGU */ + +/* LED */ +#define CONFIG_AT91_LED +#define CONFIG_RED_LED AT91_PIN_PA9 /* this is the power led */ +#define CONFIG_GREEN_LED AT91_PIN_PA6 /* this is the user led */ + +#define CONFIG_BOOTDELAY 3 + +/* + * BOOTP options + */ +#define CONFIG_BOOTP_BOOTFILESIZE 1 +#define CONFIG_BOOTP_BOOTPATH 1 +#define CONFIG_BOOTP_GATEWAY 1 +#define CONFIG_BOOTP_HOSTNAME 1 + +/* + * Command line configuration. + */ +#include <config_cmd_default.h> +#undef CONFIG_CMD_BDI +#undef CONFIG_CMD_FPGA +#undef CONFIG_CMD_IMI +#undef CONFIG_CMD_IMLS +#undef CONFIG_CMD_LOADS +#undef CONFIG_CMD_SOURCE + +#define CONFIG_CMD_PING 1 +#define CONFIG_CMD_DHCP 1 +#define CONFIG_CMD_NAND 1 +#define CONFIG_CMD_USB 1 + +/* SDRAM */ +#define CONFIG_NR_DRAM_BANKS 1 +#define PHYS_SDRAM 0x20000000 +#define PHYS_SDRAM_SIZE 0x04000000 /* 64 megs */ + +/* DataFlash */ +#define CONFIG_ATMEL_DATAFLASH_SPI +#define CONFIG_HAS_DATAFLASH 1 +#define CONFIG_SYS_SPI_WRITE_TOUT (5*CONFIG_SYS_HZ) +#define CONFIG_SYS_MAX_DATAFLASH_BANKS 2 +#define CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS0 0xC0000000 /* CS0 */ +#define CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS1 0xD0000000 /* CS1 */ +#define AT91_SPI_CLK 15000000 +#define DATAFLASH_TCSS (0x1a << 16) +#define DATAFLASH_TCHS (0x1 << 24) + +/* NAND flash */ +#ifdef CONFIG_CMD_NAND +#define CONFIG_NAND_ATMEL +#define CONFIG_SYS_MAX_NAND_DEVICE 1 +#define CONFIG_SYS_NAND_BASE 0x40000000 +#define CONFIG_SYS_NAND_DBW_8 1 +/* our ALE is AD21 */ +#define CONFIG_SYS_NAND_MASK_ALE (1 << 21) +/* our CLE is AD22 */ +#define CONFIG_SYS_NAND_MASK_CLE (1 << 22) +#define CONFIG_SYS_NAND_ENABLE_PIN AT91_PIN_PC14 +#define CONFIG_SYS_NAND_READY_PIN AT91_PIN_PC13 +#endif + +/* NOR flash - no real flash on this board */ +#define CONFIG_SYS_NO_FLASH 1 + +/* Ethernet */ +#define CONFIG_MACB 1 +#undef CONFIG_RMII +#define CONFIG_NET_MULTI 1 +#define CONFIG_NET_RETRY_COUNT 20 + +/* USB */ +#define CONFIG_USB_ATMEL +#define CONFIG_USB_OHCI_NEW 1 +#define CONFIG_DOS_PARTITION 1 +#define CONFIG_SYS_USB_OHCI_CPU_INIT 1 +#define CONFIG_SYS_USB_OHCI_REGS_BASE 0x00500000 +#define CONFIG_SYS_USB_OHCI_SLOT_NAME "at91sam9260" +#define CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS 2 +#define CONFIG_USB_STORAGE 1 +#define CONFIG_CMD_FAT 1 + +#define CONFIG_SYS_LOAD_ADDR 0x22000000 + +#define CONFIG_SYS_MEMTEST_START PHYS_SDRAM +#define CONFIG_SYS_MEMTEST_END 0x23e00000 + +#ifdef CONFIG_SYS_USE_DATAFLASH_CS0 + +/* bootstrap + u-boot + env + linux in dataflash on CS0 */ +#define CONFIG_ENV_IS_IN_DATAFLASH 1 +#define CONFIG_SYS_MONITOR_BASE (CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS0 + 0x8400) +#define CONFIG_ENV_OFFSET 0x4200 +#define CONFIG_ENV_ADDR (CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS0 + CONFIG_ENV_OFFSET) +#define CONFIG_ENV_SIZE 0x4200 +#define CONFIG_BOOTCOMMAND "cp.b 0xC0042000 0x22000000 0x210000; bootm" +#define CONFIG_BOOTARGS "console=ttyS0,115200 " \ + "root=/dev/mtdblock0 " \ + "mtdparts=at91_nand:-(root) " \ + "rw rootfstype=jffs2" + +#elif CONFIG_SYS_USE_DATAFLASH_CS1 + +/* bootstrap + u-boot + env + linux in dataflash on CS1 */ +#define CONFIG_ENV_IS_IN_DATAFLASH 1 +#define CONFIG_SYS_MONITOR_BASE (CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS1 + 0x8400) +#define CONFIG_ENV_OFFSET 0x4200 +#define CONFIG_ENV_ADDR (CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS1 + CONFIG_ENV_OFFSET) +#define CONFIG_ENV_SIZE 0x4200 +#define CONFIG_BOOTCOMMAND "cp.b 0xD0042000 0x22000000 0x210000; bootm" +#define CONFIG_BOOTARGS "console=ttyS0,115200 " \ + "root=/dev/mtdblock0 " \ + "mtdparts=at91_nand:-(root) " \ + "rw rootfstype=jffs2" + +#else /* CONFIG_SYS_USE_NANDFLASH */ + +/* bootstrap + u-boot + env + linux in nandflash */ +#define CONFIG_ENV_IS_IN_NAND 1 +#define CONFIG_ENV_OFFSET 0x60000 +#define CONFIG_ENV_OFFSET_REDUND 0x80000 +#define CONFIG_ENV_SIZE 0x20000 /* 1 sector = 128 kB */ +#define CONFIG_BOOTCOMMAND "nand read 0x22000000 0xA0000 0x200000; bootm" +#define CONFIG_BOOTARGS "console=ttyS0,115200 " \ + "root=/dev/mtdblock5 " \ + "mtdparts=at91_nand:128k(bootstrap)ro," \ + "256k(uboot)ro,128k(env1)ro," \ + "128k(env2)ro,2M(linux),-(root) " \ + "rw rootfstype=jffs2" + +#endif + +#define CONFIG_BAUDRATE 115200 +#define CONFIG_SYS_BAUDRATE_TABLE {115200 , 19200, 38400, 57600, 9600 } + +#define CONFIG_SYS_PROMPT "U-Boot> " +#define CONFIG_SYS_CBSIZE 256 +#define CONFIG_SYS_MAXARGS 16 +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_LONGHELP 1 +#define CONFIG_CMDLINE_EDITING 1 + +#define ROUND(A, B) (((A) + (B)) & ~((B) - 1)) +/* + * Size of malloc() pool + */ +#define CONFIG_SYS_MALLOC_LEN ROUND(3 * CONFIG_ENV_SIZE + 128*1024, 0x1000) +#define CONFIG_SYS_GBL_DATA_SIZE 128 /* 128 bytes for initial data */ + +#define CONFIG_STACKSIZE (32*1024) /* regular stack */ + +#ifdef CONFIG_USE_IRQ +#error CONFIG_USE_IRQ not supported +#endif + +#endif
same as 9261 could you regenerate it with git format-patch -M -B -C
<snip>
- Hardware drivers
- BOOTP options
<snip>
Best Regards, J.
Applied to u-boot-video after fixing commit message and adding your Signed-off-by line. Also please check for trailing white spaces next time. Thanks!
Best regards, Anatolij
now i removed this patch from u-boot-video due to NACK from Jean-Christophe.
- value |= ATMEL_LCDC_INVCLK_INVERTED;
NACK do this throught the struct via vl_sync as in linux
Best Regards, J.
actually the "vl_sync" is supposed to contain HSYNC and VSYNC polarity flags and not the dot clock polarity. The Linux driver in mainline uses var.sync for this purpose too, and doesn't set inverted dot clock polarity at all. This definition in struct vidinfo for Atmel LCD /* LCD configuration register */ u_long vl_sync; /* Horizontal / vertical sync */ u_long vl_bpix; /* Bits per pixel, 0 = 1, 1 = 2, 2 = 4, 3 = 8, 4 = 16 */ u_long vl_tft; /* 0 = passive, 1 = TFT */
is confusing. If these fields are supposed to contain flags for LCD configuration register LCDCON2 then we should define only one "u_long lcdcon2" field containing all the flags/fields for sync polarity, bpp, clock polarity, scan mode, display type, interface width, LCDD, LCDDEN polarities, LCDDOTCLK mode and memory ordering format. We are wasting tree u_longs here and are not even able to use half of the possible settings for LCDCON2 register. I would rather fix the struct vidinfo for Atmel LCD so that people could set needed flags in the board code, e.g.:
vidinfo_t panel_info = { ... lcdcon2: ATMEL_LCDC_INVLINE_INVERTED | ATMEL_LCDC_INVFRAME_INVERTED | ATMEL_LCDC_INVCLK_INVERTED; ... }
I don't have the Atmel hardware to test/fix this change however.
I disagree here we must not make the panel_info atmel specific that way we can add fields to pass atmel specific info which are pass via struct atmel_lcdfb_info in Linux But we need to be sync with linux as possible to simplify port and bugfix.
btw on Linux you do not specify it directly you specific this FB_SYNC_HOR_HIGH_ACT => ATMEL_LCDC_INVLINE_INVERTED FB_SYNC_VERT_HIGH_ACT => ATMEL_LCDC_INVFRAME_INVERTED
Best Regards, J.
Dear Dimitar Dimitrov,
I think we are stillw aiting for a re-submit of this patch after cleaning up?
I can regenerate the patches for the latest GIT. If someone is willing to try them please let me know.
Unfortunately I don't have the boards anymore so I can't verify that the new patches and new u-boot will work. That's why I avoid resubmission in this RC window.
Regards, Dimitar
Please clean up and resubmit, and mark the patches as "for `next'" so we know they should go into the "next" branch. Thanks in advance.
Anatolij Gustschin
Dimitar Dimitrov
