[U-Boot] environmental "baudrate" not used at boot up
Hi list,
I have a board based on an Atmel AT91SAM9263-EK running U-boot 2009.01. I can't seem to get the environmental variable "baudrate" to be used properly, though.
Here's the sequence:
1. Power on board, baudrate=115200 2. setenv baudrate 9600 (change terminal baud to 9600) saveenv saveenv reset 3. Gibberish is output to the terminal at 9600 4. Change terminal baud to 115200, everything ok
As much as I've looked through the code in lib_arm/board.c, serial_init() and init_baudrate() seem to be coded correctly.
Any advice on where to take it from here?
Thanks, Chris
Le 16/01/2011 15:01, chrisv@cyberswitching.com a écrit :
Hi list,
Hmm... 2009.1 is very old code. Current u-boot-at91/master seems to build at91sam9263ek; maybe you could try it.
Thanks, Chris
Amicalement,
On Sun, Jan 16, 2011 at 03:42:25PM +0100, Albert ARIBAUD wrote:
Le 16/01/2011 15:01, chrisv@cyberswitching.com a ?crit :
Hi Albert,
Thanks for the advice. I had considered that prior to sending the message to the list, but wanted to verify if the problem was fixed there before porting over all the board-specific code just for a test. (I don't have the -EK board anymore.)
If anyone out there has a -EK working with the latest and can provide some insights on whether this works, it would be much appreciated!
Thanks, Chris
On Sun, Jan 16, 2011 at 06:01:22AM -0800, chrisv@cyberswitching.com wrote:
... Any advice on where to take it from here?
Hi everyone,
I investigated this a little further, and I'm wondering if the problem is related to the initialization ordering in lib_arm/board.c.
start_armboot(): 1. init_baudrate() -> getenv_r() -> serial_setbrg() 2. env_relocate()
Note that init_baudrate() calls getenv_r("baudrate") and passes either the result (on success) or CONFIG_BAUDRATE (on error) to serial_setbrg(). Only after this does the environment get relocated using env_relocate().
Based on empirical testing, I've discovered that re-running init_baudrate() after env_relocate() fixes everything. The serial console uses the baud rate stored in the "baudrate" variable now, and some ordering of display outputs needs to be tweaked so that gibberish isn't output in the interim.
The attached patch (below) should give a code-centric view. Please ignore the minor style changes, as I was hacking code pretty feverishly to try and figure this out. To be clear: DO NOT IMPORT THIS CODE DIRECTLY INTO THE LATEST MASTER! It will need to be reviewed, tweaked, and the finally imported by someone who knows more of what they are doing than I. :-)
Hope this helps someone else out,
Chris
diff -p -r -U 3 a/drivers/mtd/nand/nand.c b/drivers/mtd/nand/nand.c --- a/drivers/mtd/nand/nand.c 2009-01-21 14:08:12.000000000 -0800 +++ b/drivers/mtd/nand/nand.c 2011-01-18 21:29:36.000000000 -0800 @@ -57,6 +57,17 @@ static void nand_init_chip(struct mtd_in
+void display_nand_config(void) +{ + int i; + unsigned int size = 0; + printf("NAND: "); + for (i = 0; i < CONFIG_SYS_MAX_NAND_DEVICE; i++) { + size += nand_info[i].size / 1024; + } + printf("%u MiB\n", size / 1024); +} + void nand_init(void) { int i; @@ -67,7 +78,6 @@ void nand_init(void) if (nand_curr_device == -1) nand_curr_device = i; } - printf("%u MiB\n", size / 1024);
#ifdef CONFIG_SYS_NAND_SELECT_DEVICE /* diff -p -r -U 3 a/include/nand.h b/include/nand.h --- a/include/nand.h 2009-01-21 14:08:12.000000000 -0800 +++ b/include/nand.h 2011-01-18 21:29:43.000000000 -0800 @@ -25,6 +25,7 @@ #define _NAND_H_
extern void nand_init(void); +extern void display_nand_config(void);
#ifndef CONFIG_NAND_LEGACY #include <linux/mtd/compat.h> diff -p -r -U 3 a/lib_arm/board.c b/lib_arm/board.c --- a/lib_arm/board.c 2009-01-21 14:08:12.000000000 -0800 +++ b/lib_arm/board.c 2011-01-18 21:29:24.000000000 -0800 @@ -148,10 +148,15 @@ void inline yellow_LED_off(void)__attrib static int init_baudrate (void) { char tmp[64]; /* long enough for environment variables */ - int i = getenv_r ("baudrate", tmp, sizeof (tmp)); - gd->bd->bi_baudrate = gd->baudrate = (i > 0) - ? (int) simple_strtoul (tmp, NULL, 10) - : CONFIG_BAUDRATE; + int i; + int baudrate = CONFIG_BAUDRATE; + + i = getenv_r ("baudrate", tmp, sizeof (tmp)); + if (i > 0) + baudrate = (int) simple_strtoul(tmp, NULL, 10); + + gd->baudrate = baudrate; + gd->bd->bi_baudrate = baudrate;
return (0); } @@ -256,6 +261,14 @@ init_fnc_t *init_sequence[] = { init_baudrate, /* initialze baudrate settings */ serial_init, /* serial communications setup */ console_init_f, /* stage 1 init of console */ +#if defined(CONFIG_HARD_I2C) || defined(CONFIG_SOFT_I2C) + init_func_i2c, +#endif + dram_init, /* configure available RAM banks */ + NULL, +}; + +init_fnc_t *display_sequence[] = { display_banner, /* say that we are here */ #if defined(CONFIG_DISPLAY_CPUINFO) print_cpuinfo, /* display cpu info (and speed) */ @@ -263,10 +276,9 @@ init_fnc_t *init_sequence[] = { #if defined(CONFIG_DISPLAY_BOARDINFO) checkboard, /* display board info */ #endif -#if defined(CONFIG_HARD_I2C) || defined(CONFIG_SOFT_I2C) - init_func_i2c, +#if defined(CONFIG_CMD_NAND) + display_nand_config, #endif - dram_init, /* configure available RAM banks */ display_dram_config, NULL, }; @@ -340,7 +352,6 @@ void start_armboot (void) mem_malloc_init (_armboot_start - CONFIG_SYS_MALLOC_LEN);
#if defined(CONFIG_CMD_NAND) - puts ("NAND: "); nand_init(); /* go init the NAND */ #endif
@@ -396,6 +407,18 @@ void start_armboot (void) #endif }
+ /* Reinitialize the baud rate since the environment wasn't ready */ + init_baudrate(); + serial_setbrg(); + udelay(50000); + + /* Now display the information to the serial console */ + for (init_fnc_ptr = display_sequence; *init_fnc_ptr; ++init_fnc_ptr) { + if ((*init_fnc_ptr)() != 0) { + hang (); + } + } + devices_init (); /* get the devices list going. */
#ifdef CONFIG_CMC_PU2
Dear chrisv@cyberswitching.com,
In message 20110119053445.GA9776@cslinux-build01.cyberswitching.local you wrote:
start_armboot():
- init_baudrate() -> getenv_r() -> serial_setbrg()
- env_relocate()
Right. This is the intended sequence.
You have diagnosed where the problem is, but you come to the wrong conclusions and instead of fixing the problem you paint over it.
Obviously getenv_r("baudrate") is not returning the right value for you.
You should first check, what exactly it returns.
Then you should check why it is not reading the correct data, as it is supposed to do.
Then you should fix _that_ problem.
Thanks for the feedback. I hope that someone else can continue this work now that I've identified the problem and have developed a solution that works for my needs with no obvious side-effects.
Given that this is such base functionality, I'm surprised that no one else has mentioned anything up to this point; I guess no one else attempts to change the baud rate for subsequent reboots? (Rhetorical, no need to answer.)
All the best with the upcoming release,
Chris
In message 20110119144640.GA8828@cslinux-build01.cyberswitching.local you wrote:
Who said there are no side-effects? Just try setting a different baud rate, save it, and reboot.
You are probably right - few people test such changes.
Dear Wolfgang Denk,
In message20110119144640.GA8828@cslinux-build01.cyberswitching.local you wrote:
I just want to point out that this works fine on our AT91SAM9260/9XE, however the environment is read from I2C EEPROM. Not sure where his ENV is coming from, whether it is read before use, or if there is static data involved before relocation...
Best Regards, Reinhard
ENV is coming from nandflash. Config is based on at91sam9263ek_nandflash_config.
Chris
Hi everyone,
start_armboot():
- env_relocate()
The full NAND code only works after relocation. So you cannot read out the NAND environment, in the normal way, before serial init -- you get the default environment instead.
If you are booting from NAND, I suggest using CONFIG_NAND_ENV_DST to have the NAND SPL load the environment at the same time as it loads U-Boot. If you're using some preloader other than U-Boot's NAND SPL, you'll need to see if it supports something similar.
-Scott
-----Original Message----- From: u-boot-bounces@lists.denx.de [mailto:u-boot-bounces@lists.denx.de] On Behalf Of Wood Scott-B07421 Sent: Thursday, January 20, 2011 1:28 AM To: chrisv@cyberswitching.com Cc: u-boot@lists.denx.de Subject: Re: [U-Boot] environmental "baudrate" not used at boot up
Hi everyone,
start_armboot():
- env_relocate()
Hello Scott
Is this feature available/tested on any FSL platform. The code you pointed to does not seem to be used by FSL platforms.
It would be good idea to pull this in for P1/P2 RDB nand boot loader.
Regards Poonam
-Scott
On Thu, 20 Jan 2011 22:45:34 -0600 Aggrwal Poonam-B10812 B10812@freescale.com wrote:
Hello Scott
It is currently only supported in nand_boot.c, but it should be trivial to add it to nand_boot_fsl_elbc.c. Just copy the extra nand_boot() invocations.
-Scott
participants (6)
Albert ARIBAUD
Reinhard Meyer
Scott Wood
