[U-Boot] [PATCH] Fix CFI flash driver for 8-bit bus support
This patch corrects the addresses used when working with Spansion/AMD FLASH chips. Addressing for 8 and 16 bits is almost identical except in the 16-bit case the LSB of the address is always 0. The confusion arose because the addresses in the datasheet for 16-bit mode are word addresses but this code assumed it was byte addresses.
I have only been able to test this on our Octeon boards which use either an 8-bit or 16-bit bus. I have not tested the case where there's an 8-bit part on a 16-bit bus.
This patch also adds some delays as suggested by Spansion.
If a part can be both 8 and 16-bits, it forces it to work in 8-bit mode if an 8-bit bus is detected.
-Aaron Williams
Signed-off-by: Aaron Williams aaron.williams@caviumnetworks.com --- drivers/mtd/cfi_flash.c | 93 ++++++++++++++++++++++++++++++++++------------- include/mtd/cfi_flash.h | 40 ++++++++++---------- 2 files changed, 87 insertions(+), 46 deletions(-)
diff --git a/drivers/mtd/cfi_flash.c b/drivers/mtd/cfi_flash.c index 0909fe7..eab1fbe 100644 --- a/drivers/mtd/cfi_flash.c +++ b/drivers/mtd/cfi_flash.c @@ -10,6 +10,9 @@ * * Copyright (C) 2006 * Tolunay Orkun listmember@orkun.us + * + * Copyright (C) 2011 Cavium Networks, Inc. + * Aaron Williams Aaron.Williams@caviumnetworks.com * * See file CREDITS for list of people who contributed to this * project. @@ -32,7 +35,6 @@ */
/* The DEBUG define must be before common to enable debugging */ -/* #define DEBUG */
#include <common.h> #include <asm/processor.h> @@ -209,9 +211,11 @@ unsigned long flash_sector_size(flash_info_t *info, flash_sect_t sect) static inline void * flash_map (flash_info_t * info, flash_sect_t sect, uint offset) { - unsigned int byte_offset = offset * info->portwidth; - - return (void *)(info->start[sect] + byte_offset); + unsigned int byte_offset = offset * info->portwidth / info->chipwidth; + unsigned int addr = (info->start[sect] + byte_offset); + unsigned int mask = 0xffffffff << (info->portwidth - 1); + + return (void *)(addr & mask); }
static inline void flash_unmap(flash_info_t *info, flash_sect_t sect, @@ -397,6 +401,8 @@ void flash_write_cmd (flash_info_t * info, flash_sect_t sect, #endif flash_write64(cword.ll, addr); break; + default: + debug ("fwc: Unknown port width %d\n", info->portwidth); }
/* Ensure all the instructions are fully finished */ @@ -581,6 +587,7 @@ static int flash_status_check (flash_info_t * info, flash_sect_t sector, prompt, info->start[sector], flash_read_long (info, sector, 0)); flash_write_cmd (info, sector, 0, info->cmd_reset); + udelay(1); return ERR_TIMOUT; } udelay (1); /* also triggers watchdog */ @@ -628,6 +635,7 @@ static int flash_full_status_check (flash_info_t * info, flash_sect_t sector, puts ("Vpp Low Error.\n"); } flash_write_cmd (info, sector, 0, info->cmd_reset); + udelay(1); break; default: break; @@ -744,12 +752,8 @@ static void flash_add_byte (flash_info_t * info, cfiword_t * cword, uchar c) static flash_sect_t find_sector (flash_info_t * info, ulong addr) { static flash_sect_t saved_sector = 0; /* previously found sector */ - static flash_info_t *saved_info = 0; /* previously used flash bank */ flash_sect_t sector = saved_sector;
- if ((info != saved_info) || (sector >= info->sector_count)) - sector = 0; - while ((info->start[sector] < addr) && (sector < info->sector_count - 1)) sector++; @@ -761,7 +765,6 @@ static flash_sect_t find_sector (flash_info_t * info, ulong addr) sector--;
saved_sector = sector; - saved_info = info; return sector; }
@@ -825,12 +828,15 @@ static int flash_write_cfiword (flash_info_t * info, ulong dest,
switch (info->portwidth) { case FLASH_CFI_8BIT: + debug("%s: 8-bit 0x%02x\n", __func__, cword.c); flash_write8(cword.c, dstaddr); break; case FLASH_CFI_16BIT: + debug("%s: 16-bit 0x%04x\n", __func__, cword.w); flash_write16(cword.w, dstaddr); break; case FLASH_CFI_32BIT: + debug("%s: 32-bit 0x%08lx\n", __func__, cword.l); flash_write32(cword.l, dstaddr); break; case FLASH_CFI_64BIT: @@ -1043,6 +1049,8 @@ int flash_erase (flash_info_t * info, int s_first, int s_last) int prot; flash_sect_t sect; int st; + + debug("%s: erasing sectors %d to %d\n", __func__, s_first, s_last);
if (info->flash_id != FLASH_MAN_CFI) { puts ("Can't erase unknown flash type - aborted\n"); @@ -1082,6 +1090,7 @@ int flash_erase (flash_info_t * info, int s_first, int s_last) break; case CFI_CMDSET_AMD_STANDARD: case CFI_CMDSET_AMD_EXTENDED: + flash_write_cmd (info, 0, 0, AMD_CMD_RESET); flash_unlock_seq (info, sect); flash_write_cmd (info, sect, info->addr_unlock1, @@ -1121,6 +1130,8 @@ int flash_erase (flash_info_t * info, int s_first, int s_last) rcode = 1; else if (flash_verbose) putc ('.'); + } else { + debug("\nSector %d is protected.\n", sect); } }
@@ -1490,6 +1501,7 @@ void flash_read_user_serial (flash_info_t * info, void *buffer, int offset, flash_write_cmd (info, 0, 0, FLASH_CMD_READ_ID); memcpy (dst, src + offset, len); flash_write_cmd (info, 0, 0, info->cmd_reset); + udelay(1); flash_unmap(info, 0, FLASH_OFFSET_USER_PROTECTION, src); }
@@ -1505,6 +1517,7 @@ void flash_read_factory_serial (flash_info_t * info, void *buffer, int offset, flash_write_cmd (info, 0, 0, FLASH_CMD_READ_ID); memcpy (buffer, src + offset, len); flash_write_cmd (info, 0, 0, info->cmd_reset); + udelay(1); flash_unmap(info, 0, FLASH_OFFSET_INTEL_PROTECTION, src); }
@@ -1536,6 +1549,7 @@ static void cfi_reverse_geometry(struct cfi_qry *qry) static void cmdset_intel_read_jedec_ids(flash_info_t *info) { flash_write_cmd(info, 0, 0, FLASH_CMD_RESET); + udelay(1); flash_write_cmd(info, 0, 0, FLASH_CMD_READ_ID); udelay(1000); /* some flash are slow to respond */ info->manufacturer_id = flash_read_uchar (info, @@ -1573,8 +1587,7 @@ static void cmdset_amd_read_jedec_ids(flash_info_t *info) flash_unlock_seq(info, 0); flash_write_cmd(info, 0, info->addr_unlock1, FLASH_CMD_READ_ID); udelay(1000); /* some flash are slow to respond */ - - manuId = flash_read_uchar (info, FLASH_OFFSET_MANUFACTURER_ID); + manuId = flash_read_uchar(info, FLASH_OFFSET_MANUFACTURER_ID); /* JEDEC JEP106Z specifies ID codes up to bank 7 */ while (manuId == FLASH_CONTINUATION_CODE && bankId < 0x800) { bankId += 0x100; @@ -1604,6 +1617,7 @@ static void cmdset_amd_read_jedec_ids(flash_info_t *info) break; } flash_write_cmd(info, 0, 0, AMD_CMD_RESET); + udelay(1); }
static int cmdset_amd_init(flash_info_t *info, struct cfi_qry *qry) @@ -1719,7 +1733,7 @@ static void flash_read_cfi (flash_info_t *info, void *buf, unsigned int i;
for (i = 0; i < len; i++) - p[i] = flash_read_uchar(info, start + i); + p[i] = flash_read_uchar(info, start + (i * 2)); }
void __flash_cmd_reset(flash_info_t *info) @@ -1730,6 +1744,7 @@ void __flash_cmd_reset(flash_info_t *info) * that AMD flash roms ignore the Intel command. */ flash_write_cmd(info, 0, 0, AMD_CMD_RESET); + udelay(1); flash_write_cmd(info, 0, 0, FLASH_CMD_RESET); } void flash_cmd_reset(flash_info_t *info) @@ -1739,21 +1754,38 @@ static int __flash_detect_cfi (flash_info_t * info, struct cfi_qry *qry) { int cfi_offset;
- /* Issue FLASH reset command */ - flash_cmd_reset(info); - for (cfi_offset=0; cfi_offset < sizeof(flash_offset_cfi) / sizeof(uint); cfi_offset++) { + /* Issue FLASH reset command */ + flash_cmd_reset(info); flash_write_cmd (info, 0, flash_offset_cfi[cfi_offset], FLASH_CMD_CFI); if (flash_isequal (info, 0, FLASH_OFFSET_CFI_RESP, 'Q') - && flash_isequal (info, 0, FLASH_OFFSET_CFI_RESP + 1, 'R') - && flash_isequal (info, 0, FLASH_OFFSET_CFI_RESP + 2, 'Y')) { + && flash_isequal (info, 0, FLASH_OFFSET_CFI_RESP + 2, 'R') + && flash_isequal (info, 0, FLASH_OFFSET_CFI_RESP + 4, 'Y')) { flash_read_cfi(info, qry, FLASH_OFFSET_CFI_RESP, sizeof(struct cfi_qry)); +#ifdef CONFIG_SYS_FLASH_INTERFACE_WIDTH + info->interface = CONFIG_SYS_FLASH_INTERFACE_WIDTH; +#else info->interface = le16_to_cpu(qry->interface_desc); - + /* Some flash chips can support multiple bus widths. + * In this case, override the interface width and + * limit it to the port width. + */ + if ((info->interface == FLASH_CFI_X8X16) && + (info->portwidth == FLASH_CFI_8BIT)) { + debug("Overriding 16-bit interface width to " + " 8-bit port width.\n"); + info->interface = FLASH_CFI_X8; + } else if ((info->interface == FLASH_CFI_X16X32) && + (info->portwidth == FLASH_CFI_16BIT)) { + debug("Overriding 16-bit interface width to " + " 16-bit port width.\n"); + info->interface = FLASH_CFI_X16; + } +#endif info->cfi_offset = flash_offset_cfi[cfi_offset]; debug ("device interface is %d\n", info->interface); @@ -1764,8 +1796,8 @@ static int __flash_detect_cfi (flash_info_t * info, struct cfi_qry *qry) info->chipwidth << CFI_FLASH_SHIFT_WIDTH);
/* calculate command offsets as in the Linux driver */ - info->addr_unlock1 = 0x555; - info->addr_unlock2 = 0x2aa; + info->addr_unlock1 = 0xaaa; + info->addr_unlock2 = 0x555;
/* * modify the unlock address if we are @@ -1799,8 +1831,11 @@ static int flash_detect_cfi (flash_info_t * info, struct cfi_qry *qry) for (info->chipwidth = FLASH_CFI_BY8; info->chipwidth <= info->portwidth; info->chipwidth <<= 1) - if (__flash_detect_cfi(info, qry)) + if (__flash_detect_cfi(info, qry)) { + debug("Found CFI flash, portwidth %d, chipwidth %d\n", + info->portwidth, info->chipwidth); return 1; + } } debug ("not found\n"); return 0; @@ -1819,7 +1854,7 @@ static void flash_fixup_amd(flash_info_t *info, struct cfi_qry *qry) /* CFI < 1.1, try to guess from device id */ if ((info->device_id & 0x80) != 0) cfi_reverse_geometry(qry); - } else if (flash_read_uchar(info, info->ext_addr + 0xf) == 3) { + } else if (flash_read_uchar(info, info->ext_addr + 0x1e) == 3) { /* CFI >= 1.1, deduct from top/bottom flag */ /* note: ext_addr is valid since cfi_version > 0 */ cfi_reverse_geometry(qry); @@ -1891,14 +1926,15 @@ ulong flash_get_size (phys_addr_t base, int banknum)
if (flash_detect_cfi (info, &qry)) { info->vendor = le16_to_cpu(qry.p_id); - info->ext_addr = le16_to_cpu(qry.p_adr); + info->ext_addr = le16_to_cpu(qry.p_adr) * 2; + debug("extended address is 0x%x\n", info->ext_addr); num_erase_regions = qry.num_erase_regions;
if (info->ext_addr) { info->cfi_version = (ushort) flash_read_uchar (info, - info->ext_addr + 3) << 8; + info->ext_addr + 6) << 8; info->cfi_version |= (ushort) flash_read_uchar (info, - info->ext_addr + 4); + info->ext_addr + 8); }
#ifdef DEBUG @@ -1945,13 +1981,16 @@ ulong flash_get_size (phys_addr_t base, int banknum) debug ("device id is 0x%x\n", info->device_id); debug ("device id2 is 0x%x\n", info->device_id2); debug ("cfi version is 0x%04x\n", info->cfi_version); - + debug ("port width: %d, chipwidth: %d, interface: %d\n", + info->portwidth, info->chipwidth, info->interface); size_ratio = info->portwidth / info->chipwidth; +#if 0 /* if the chip is x8/x16 reduce the ratio by half */ if ((info->interface == FLASH_CFI_X8X16) && (info->chipwidth == FLASH_CFI_BY8)) { size_ratio >>= 1; } +#endif debug ("size_ratio %d port %d bits chip %d bits\n", size_ratio, info->portwidth << CFI_FLASH_SHIFT_WIDTH, info->chipwidth << CFI_FLASH_SHIFT_WIDTH); @@ -2023,6 +2062,8 @@ ulong flash_get_size (phys_addr_t base, int banknum) sect_cnt++; } } + debug ("port width: %d, chipwidth: %d, interface: %d\n", + info->portwidth, info->chipwidth, info->interface);
info->sector_count = sect_cnt; info->buffer_size = 1 << le16_to_cpu(qry.max_buf_write_size); diff --git a/include/mtd/cfi_flash.h b/include/mtd/cfi_flash.h index 3245b44..edcf9be 100644 --- a/include/mtd/cfi_flash.h +++ b/include/mtd/cfi_flash.h @@ -71,29 +71,29 @@ #define FLASH_CONTINUATION_CODE 0x7F
#define FLASH_OFFSET_MANUFACTURER_ID 0x00 -#define FLASH_OFFSET_DEVICE_ID 0x01 -#define FLASH_OFFSET_DEVICE_ID2 0x0E -#define FLASH_OFFSET_DEVICE_ID3 0x0F -#define FLASH_OFFSET_CFI 0x55 +#define FLASH_OFFSET_DEVICE_ID 0x02 +#define FLASH_OFFSET_DEVICE_ID2 0x1C +#define FLASH_OFFSET_DEVICE_ID3 0x1E +#define FLASH_OFFSET_CFI 0xAA #define FLASH_OFFSET_CFI_ALT 0x555 -#define FLASH_OFFSET_CFI_RESP 0x10 -#define FLASH_OFFSET_PRIMARY_VENDOR 0x13 +#define FLASH_OFFSET_CFI_RESP 0x20 +#define FLASH_OFFSET_PRIMARY_VENDOR 0x26 /* extended query table primary address */ -#define FLASH_OFFSET_EXT_QUERY_T_P_ADDR 0x15 +#define FLASH_OFFSET_EXT_QUERY_T_P_ADDR 0x2A #define FLASH_OFFSET_WTOUT 0x1F -#define FLASH_OFFSET_WBTOUT 0x20 -#define FLASH_OFFSET_ETOUT 0x21 -#define FLASH_OFFSET_CETOUT 0x22 -#define FLASH_OFFSET_WMAX_TOUT 0x23 -#define FLASH_OFFSET_WBMAX_TOUT 0x24 -#define FLASH_OFFSET_EMAX_TOUT 0x25 -#define FLASH_OFFSET_CEMAX_TOUT 0x26 -#define FLASH_OFFSET_SIZE 0x27 -#define FLASH_OFFSET_INTERFACE 0x28 -#define FLASH_OFFSET_BUFFER_SIZE 0x2A -#define FLASH_OFFSET_NUM_ERASE_REGIONS 0x2C -#define FLASH_OFFSET_ERASE_REGIONS 0x2D -#define FLASH_OFFSET_PROTECT 0x02 +#define FLASH_OFFSET_WBTOUT 0x40 +#define FLASH_OFFSET_ETOUT 0x4A +#define FLASH_OFFSET_CETOUT 0x44 +#define FLASH_OFFSET_WMAX_TOUT 0x46 +#define FLASH_OFFSET_WBMAX_TOUT 0x48 +#define FLASH_OFFSET_EMAX_TOUT 0x4A +#define FLASH_OFFSET_CEMAX_TOUT 0x4C +#define FLASH_OFFSET_SIZE 0x4E +#define FLASH_OFFSET_INTERFACE 0x50 +#define FLASH_OFFSET_BUFFER_SIZE 0x54 +#define FLASH_OFFSET_NUM_ERASE_REGIONS 0x58 +#define FLASH_OFFSET_ERASE_REGIONS 0x5A +#define FLASH_OFFSET_PROTECT 0x04 #define FLASH_OFFSET_USER_PROTECTION 0x85 #define FLASH_OFFSET_INTEL_PROTECTION 0x81
Hi Aaron,
-Aaron Williams
Signed-off-by: Aaron Williamsaaron.williams@caviumnetworks.com
Comments related to testing and 'signatures' should not be part of the commit message and thus should go below the commit message delimiter.
- Copyright (C) 2006
- Tolunay Orkunlistmember@orkun.us
There is a space between the asterisk and end of line. You can check if your patch is whitespace-clean by applying it locally as if you were another u-boot user; 'git apply' will tell you where in the patch there are undue whitespace.
- Copyright (C) 2011 Cavium Networks, Inc.
- Aaron WilliamsAaron.Williams@caviumnetworks.com
- project.
#include<common.h> #include<asm/processor.h> @@ -209,9 +211,11 @@ unsigned long flash_sector_size(flash_info_t *info, flash_sect_t sect) static inline void * flash_map (flash_info_t * info, flash_sect_t sect, uint offset) {
Whitespace (see 'git apply' comment above).
unsigned int mask = 0xffffffff<< (info->portwidth - 1);
return (void *)(addr& mask); }
default:
} udelay (1); /* also triggers watchdog */udelay(1); return ERR_TIMOUT;
break; default: break;udelay(1);
if ((info != saved_info) || (sector>= info->sector_count))
sector = 0;
while ((info->start[sector]< addr) && (sector< info->sector_count - 1)) sector++;
flash_write8(cword.c, dstaddr); break; case FLASH_CFI_16BIT:debug("%s: 8-bit 0x%02x\n", __func__, cword.c);
flash_write16(cword.w, dstaddr); break; case FLASH_CFI_32BIT:debug("%s: 16-bit 0x%04x\n", __func__, cword.w);
flash_write32(cword.l, dstaddr); break; case FLASH_CFI_64BIT:debug("%s: 32-bit 0x%08lx\n", __func__, cword.l);
} else {
} }debug("\nSector %d is protected.\n", sect);
- udelay(1); flash_unmap(info, 0, FLASH_OFFSET_USER_PROTECTION, src); }
- udelay(1); flash_unmap(info, 0, FLASH_OFFSET_INTEL_PROTECTION, src); }
- udelay(1); flash_write_cmd(info, 0, 0, FLASH_CMD_READ_ID); udelay(1000); /* some flash are slow to respond */ info->manufacturer_id = flash_read_uchar (info,
- manuId = flash_read_uchar(info, FLASH_OFFSET_MANUFACTURER_ID); /* JEDEC JEP106Z specifies ID codes up to bank 7 */ while (manuId == FLASH_CONTINUATION_CODE&& bankId< 0x800) { bankId += 0x100;
udelay(1); }
for (i = 0; i< len; i++)
This "2" seems a bit magical to me -- apparently the semantics of flash_read_uchar seem to change with your patch If they do, please add comments before the definition of flash_read_uchar() to make the meaning of its arguments completely clear.
Besides, does this still work with pure 8 bit devices, where the CFI area is byte-spaced?
- udelay(1); flash_write_cmd(info, 0, 0, FLASH_CMD_RESET); } void flash_cmd_reset(flash_info_t *info)
- for (cfi_offset=0; cfi_offset< sizeof(flash_offset_cfi) / sizeof(uint); cfi_offset++) {
flash_write_cmd (info, 0, flash_offset_cfi[cfi_offset], FLASH_CMD_CFI); if (flash_isequal (info, 0, FLASH_OFFSET_CFI_RESP, 'Q')flash_cmd_reset(info);
Here too, the change requires that the semantics of flash_isequal be explicited in a comment before the definition of flash_isequal() to make the meaning of its arguments completely clear.
if ((info->interface == FLASH_CFI_X8X16)&&
} else if ((info->interface == FLASH_CFI_X16X32)&&
+#endif info->cfi_offset = flash_offset_cfi[cfi_offset]; debug ("device interface is %d\n", info->interface); @@ -1764,8 +1796,8 @@ static int __flash_detect_cfi (flash_info_t * info, struct cfi_qry *qry) info->chipwidth<< CFI_FLASH_SHIFT_WIDTH);
info->addr_unlock2 = 0x555; /* * modify the unlock address if we are
@@ -1799,8 +1831,11 @@ static int flash_detect_cfi (flash_info_t * info, struct cfi_qry *qry) for (info->chipwidth = FLASH_CFI_BY8; info->chipwidth<= info->portwidth; info->chipwidth<<= 1)
} debug ("not found\n"); return 0;}
@@ -1819,7 +1854,7 @@ static void flash_fixup_amd(flash_info_t *info, struct cfi_qry *qry) /* CFI< 1.1, try to guess from device id */ if ((info->device_id& 0x80) != 0) cfi_reverse_geometry(qry);
Please add comments to explain what the '0x1e' actually means -- that's not a fault of your patch, btw, as the 0xf in the original code could already have used some commenting; since you're at it, you might as well improve on code understandability as well. :)
/* CFI>= 1.1, deduct from top/bottom flag */ /* note: ext_addr is valid since cfi_version> 0 */ cfi_reverse_geometry(qry);
if (flash_detect_cfi (info,&qry)) { info->vendor = le16_to_cpu(qry.p_id);
info->ext_addr + 3)<< 8;
info->ext_addr + 6)<< 8; info->cfi_version |= (ushort) flash_read_uchar (info,
}info->ext_addr + 8);
Same remark re: "magic" for the changes above: tell readers what units (bytes, words, something else) these offsets are expressed in.
size_ratio = info->portwidth / info->chipwidth;info->portwidth, info->chipwidth, info->interface);
+#if 0 /* if the chip is x8/x16 reduce the ratio by half */ if ((info->interface == FLASH_CFI_X8X16) && (info->chipwidth == FLASH_CFI_BY8)) { size_ratio>>= 1; } +#endif
NAK on this one. If you want to remove some code, remove it. If you still want it, dont comment it out.
debug ("size_ratio %d port %d bits chip %d bits\n", size_ratio, info->portwidth<< CFI_FLASH_SHIFT_WIDTH, info->chipwidth<< CFI_FLASH_SHIFT_WIDTH);
info->sector_count = sect_cnt; info->buffer_size = 1<< le16_to_cpu(qry.max_buf_write_size);
Overall remark on the .h file: please explain what unit the values are expressed in (byte offets, word offsets, width-independent, whatever.
Apart from this, I am happy to report that this code works well with my ED Mini V2, allowing me to remove the CONFIG_FLASH_CFI_LEGACY config option and use the standard driver, so:
Tested-by: Albert ARIBAUD albert.aribaud@free.fr
Thanks a lot, Aaron!
Amicalement,
On 2011/04/02 1:23 PM, Albert ARIBAUD wrote:
Hi Aaron,
-Aaron Williams
- project.
Not sure why you removed this?
default:
Is there a point to introducing a delay if you are already returning a timeout error?
sector = 0;
} else {
udelay(1); }
Amicalement,
Also tested with the DNS323, this patch allows me to remove the "horrible hacks" that allowed CFI to work on that board too.
Thanks Aaron!
Rogan
Hi Aaron,
Thanks.
Apart from the comments from Albert and Rogan, here some further notes:
- Please explain why the delay() calls are added. If really needed, please move them into a separate patch, as this seems unrelated to the 8/16 bit issue.
- Please add a short description and rationale to the commit text (and perhaps to cfi_flash.h), why the offsets for the CFI data are now changed (e.g. 0x10 -> 0x20).
And one further comment below:
Is this correct? A reset command in every flash_erase() call?
Thanks.
Cheers, Stefan
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-0 Fax: (+49)-8142-66989-80 Email: office@denx.de
I believe this is correct. I have redone the patch as two patches. The first patch fixes the 8-bit addressing and has been tested with both 8 and 16-bit support with Spansion. The second patch adds a 1us delay after every reset call. In my email correspondence with Spansion they said that at least some devices require a 500ns delay after the reset command.
-Aaron
On Monday, April 04, 2011 03:14:17 AM Stefan Roese wrote:
Hi Aaron,
Thanks.
Thanks.
Cheers, Stefan
Hi Aaron,
Hmmm, I'm still not convinced about this reset call in the erase function. Do you really need it for the CFI driver to work correctly on your board? Could you please test without this reset command?
Thanks. The only real concern I still have is the new reset command as mentioned above. Please either explain why it is needed, or remove it from your patch. I'll push the patches upstream once this issue is resolved.
<snip>
Thanks.
Cheers, Stefan
Cheers, Stefan
Hi Stefan,
It looks like the other reset is not needed. The delay is needed. Without it sometimes the reset would fail on some of our boards.
Here's what Garret Swalling at Spansion told me:
... The CFI reset calls into two subroutines that resove to: flash_write_cmd(info, 0, 0, AMD_CMD_RESET); flash_write_cmd(info, 0, 0, FLASH_CMD_RESET);
According to the GL-N datasheet, even when there is no embedded operation ongoing, we need to allow at least 500ns for the reset to complete. Maybe the extra command write and two additional function returns are allowing the flash enough time to complete the reset and respond to the next command. ---
While it seems to work without the delay at least on the one board I'm testing at the moment, I added it at at suggestion of Garret. I could try testing on all of the boards I'm supporting but I'd prefer not to (I'm supporting 15 different boards and 7 different processor families at the moment).
-Aaron
On Tuesday, April 12, 2011 01:09:18 AM Stefan Roese wrote:
Hi Aaron,
<snip>
Thanks.
Cheers, Stefan
Cheers, Stefan
Hi Aaron,
Good. Then please remove it from your patch and resend a new version labled "v2" [PATCH v2]. And please include the patch revision history as mentioned by Albert. See this link for details (especially "Sending updated patch versions"):
http://www.denx.de/wiki/view/U-Boot/Patches
Understood.
I see. I have no problems with your "cfi_flash driver - Add delay after reset command" patch. But please resend the 8/16 bit patch as mentioned above.
Thanks.
Cheers, Stefan
participants (5)
Aaron Williams
Aaron Williams
Albert ARIBAUD
Rogan Dawes
Stefan Roese
