[U-Boot] [PATCH 1/2] arm: add a weak function reset_cpu
This commit 4bdcbe60a142b08eefccb0e326a37ba81d3389e8 removes reset_cpu which breaks SPL build when DEBUG macro defined.
Introudce a weak function reset_cpu to avoid build failure when building SPL for i.MX with DEBUG enabled. " arch/arm/lib/built-in.o: In function `do_reset': ~/uboot/arch/arm/lib/reset.c:45: undefined reference to `reset_cpu' scripts/Makefile.spl:244: recipe for target 'spl/u-boot-spl' failed "
Signed-off-by: Peng Fan peng.fan@nxp.com Cc: Albert Aribaud albert.u.boot@aribaud.net Cc: Stefano Babic sbabic@denx.de Cc: Fabio Estevam fabio.estevam@freescale.com --- arch/arm/lib/reset.c | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/arch/arm/lib/reset.c b/arch/arm/lib/reset.c index 9a95f08..4dd0131 100644 --- a/arch/arm/lib/reset.c +++ b/arch/arm/lib/reset.c @@ -27,6 +27,10 @@ __weak void reset_misc(void) { }
+__weak void reset_cpu(ulong addr) +{ +} + int do_reset(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { puts ("resetting ...\n");
With DEBUG macro enabled, SPL build failure: " arch/arm/cpu/armv7/built-in.o: In function `reset_misc': ~/uboot/arch/arm/cpu/armv7/mx6/soc.c:406: undefined reference to `lcdif_power_down' scripts/Makefile.spl:244: recipe for target 'spl/u-boot-spl' failed " Wrap VIDEO settings with ifndef CONFIG_SPL_BUILD
Signed-off-by: Peng Fan peng.fan@nxp.com Cc: Stefano Babic sbabic@denx.de --- include/configs/mx6ul_14x14_evk.h | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/include/configs/mx6ul_14x14_evk.h b/include/configs/mx6ul_14x14_evk.h index 5779632..a4f624c 100644 --- a/include/configs/mx6ul_14x14_evk.h +++ b/include/configs/mx6ul_14x14_evk.h @@ -243,6 +243,7 @@
#define CONFIG_IMX_THERMAL
+#ifndef CONFIG_SPL_BUILD #define CONFIG_VIDEO #ifdef CONFIG_VIDEO #define CONFIG_CFB_CONSOLE @@ -259,5 +260,6 @@ #define CONFIG_VIDEO_BMP_LOGO #define MXS_LCDIF_BASE MX6UL_LCDIF1_BASE_ADDR #endif +#endif
#endif
#endif
Reviewed-by: Stefano Babic sbabic@denx.de
Best regards, Stefano Babic
Applied (fix) to u-boot-imx, thanks !
Hi Peng,
I do not like to add a weak function just to fix the build, if this is not strictly necessary. IMHO the build fails because we moved reset_cpu() inside the watchdog driver to make it available for all CPUs. Is imx_watchdog not built together with SPL ?
Hi Stefano, On Mon, Jan 04, 2016 at 09:59:10AM +0100, Stefano Babic wrote:
Hi Peng,
Will switch to enable "#define CONFIG_SPL_WATCHDOG_SUPPORT" in imx6_spl.h to fix this issue.
Thanks, Peng.
DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: +49-8142-66989-53 Fax: +49-8142-66989-80 Email: sbabic@denx.de =====================================================================
Peng Fan
Stefano Babic
