[U-Boot] [Patch v2] powerpc/mpc8xxx: Move HWCONFIG_BUFFER_SIZE into config.h
Before proper environment is setup, we extract hwconfig and put it into a buffer with size HWCONFIG_BUFFER_SIZE. We need to enlarge the buffer to accommodate longer string. Since this macro is used in multiple files, we move it into arch/powerpc/include/asm/config.h.
Signed-off-by: York Sun yorksun@freescale.com --- Change since v1: Move HWCONFIG_BUFFER_SIZE under #ifdef
arch/powerpc/cpu/mpc85xx/fsl_corenet_serdes.c | 2 -- arch/powerpc/cpu/mpc8xxx/ddr/options.c | 1 - arch/powerpc/include/asm/config.h | 8 ++++++++ 3 files changed, 8 insertions(+), 3 deletions(-)
diff --git a/arch/powerpc/cpu/mpc85xx/fsl_corenet_serdes.c b/arch/powerpc/cpu/mpc85xx/fsl_corenet_serdes.c index 4b52dad..ef4ce09 100644 --- a/arch/powerpc/cpu/mpc85xx/fsl_corenet_serdes.c +++ b/arch/powerpc/cpu/mpc85xx/fsl_corenet_serdes.c @@ -46,8 +46,6 @@
static u32 serdes_prtcl_map;
-#define HWCONFIG_BUFFER_SIZE 128 - #ifdef DEBUG static const char *serdes_prtcl_str[] = { [NONE] = "NA", diff --git a/arch/powerpc/cpu/mpc8xxx/ddr/options.c b/arch/powerpc/cpu/mpc8xxx/ddr/options.c index 00ec57b..24c8a51 100644 --- a/arch/powerpc/cpu/mpc8xxx/ddr/options.c +++ b/arch/powerpc/cpu/mpc8xxx/ddr/options.c @@ -19,7 +19,6 @@ * This is pretty fragile on both the use of stack and if the buffer is big * enough. However we will get a warning from getenv_f for the later. */ -#define HWCONFIG_BUFFER_SIZE 128
/* Board-specific functions defined in each board's ddr.c */ extern void fsl_ddr_board_options(memctl_options_t *popts, diff --git a/arch/powerpc/include/asm/config.h b/arch/powerpc/include/asm/config.h index d138636..5038195 100644 --- a/arch/powerpc/include/asm/config.h +++ b/arch/powerpc/include/asm/config.h @@ -29,6 +29,14 @@ #include <asm/config_mpc86xx.h> #endif
+#if defined(CONFIG_MPC85xx) || \ + defined(CONFIG_MPC86xx) || \ + defined(CONFIG_MPC83xx) +#ifndef HWCONFIG_BUFFER_SIZE + #define HWCONFIG_BUFFER_SIZE 256 +#endif +#endif + /* CONFIG_HARD_SPI triggers SPI bus initialization in PowerPC */ #if defined(CONFIG_MPC8XXX_SPI) || defined(CONFIG_FSL_ESPI) # ifndef CONFIG_HARD_SPI
York Sun
