[U-Boot] [PATCH 1/4] omap3_logic: Rework MACH_TYPE and fdtfile logic
The MACH_TYPE values for the omap37xx based platforms are no longer officially valid, so we must not set and pass them. In order to not reference them but still be able to set the default fdtfile based on the board detection logic we need to combine the two steps into one.
Cc: Adam Ford aford173@gmail.com Signed-off-by: Tom Rini trini@konsulko.com --- board/logicpd/omap3som/omap3logic.c | 54 ++++++++++++++----------------------- 1 file changed, 20 insertions(+), 34 deletions(-)
diff --git a/board/logicpd/omap3som/omap3logic.c b/board/logicpd/omap3som/omap3logic.c index de6a06021c2c..21b3fdcf49cf 100644 --- a/board/logicpd/omap3som/omap3logic.c +++ b/board/logicpd/omap3som/omap3logic.c @@ -60,25 +60,28 @@ U_BOOT_DEVICE(omap3logic_uart) = { static struct board_id { char *name; int machine_id; + char *fdtfile; } boards[2][2] = { { { .name = "OMAP35xx SOM LV", .machine_id = MACH_TYPE_OMAP3530_LV_SOM, + .fdtfile = "logicpd-som-lv-35xx-devkit.dtb", }, { .name = "OMAP35xx Torpedo", .machine_id = MACH_TYPE_OMAP3_TORPEDO, + .fdtfile = "logicpd-torpedo-35xx-devkit.dtb", }, }, { { .name = "DM37xx SOM LV", - .machine_id = MACH_TYPE_DM3730_SOM_LV, + .fdtfile = "logicpd-som-lv-37xx-devkit.dtb", }, { .name = "DM37xx Torpedo", - .machine_id = MACH_TYPE_DM3730_TORPEDO, + .fdtfile = "logicpd-torpedo-37xx-devkit.dtb", }, }, }; @@ -165,14 +168,20 @@ int misc_init_r(void) */ int board_init(void) { - struct board_id *board; - unsigned int val; - gpmc_init(); /* in SRAM or SDRAM, finish GPMC */
/* boot param addr */ gd->bd->bi_boot_params = (OMAP34XX_SDRC_CS0 + 0x100);
+ return 0; +} + +#ifdef CONFIG_BOARD_LATE_INIT +int board_late_init(void) +{ + struct board_id *board; + unsigned int val; + /* * To identify between a SOM LV and Torpedo module, * a pulldown resistor is on hsusb0_data5 for the SOM LV module. @@ -207,39 +216,16 @@ int board_init(void) printf("Board: %s\n", board->name);
/* Set the machine_id passed to Linux */ - gd->bd->bi_arch_number = board->machine_id; + if (board->machine_id) + gd->bd->bi_arch_number = board->machine_id; + + /* If the user has not set fdtimage, set the default */ + if (!getenv("fdtimage")) + setenv("fdtimage", board->fdtfile); }
/* restore hsusb0_data5 pin as hsusb0_data5 */ MUX_VAL(CP(HSUSB0_DATA5), (IEN | PTD | DIS | M0)); - - return 0; -} - -#ifdef CONFIG_BOARD_LATE_INIT -int board_late_init(void) -{ - /* If we do not have an fdtimage, let's autodetect it*/ - if (getenv("fdtimage")) - return 0; - - switch (gd->bd->bi_arch_number) { - case MACH_TYPE_DM3730_TORPEDO: - setenv("fdtimage", "logicpd-torpedo-37xx-devkit.dtb"); - break; - case MACH_TYPE_DM3730_SOM_LV: - setenv("fdtimage", "logicpd-som-lv-37xx-devkit.dtb"); - break; - case MACH_TYPE_OMAP3_TORPEDO: - setenv("fdtimage", "logicpd-torpedo-35xx-devkit.dtb"); - break; - case MACH_TYPE_OMAP3530_LV_SOM: - setenv("fdtimage", "logicpd-som-lv-35xx-devkit.dtb"); - break; - default: - /* unknown machine type */ - break; - } return 0; } #endif
The MACH_TYPE for IGEP0032 was never officially used and has been removed from upstream, so we must not use it. In order to remove this we need to rework the status LED logic.
Cc: Enric Balletbo i Serra eballetbo@gmail.com Signed-off-by: Tom Rini trini@konsulko.com --- configs/igep0032_defconfig | 1 - include/configs/omap3_igep00x0.h | 5 ++--- 2 files changed, 2 insertions(+), 4 deletions(-)
diff --git a/configs/igep0032_defconfig b/configs/igep0032_defconfig index dad8dfaf0c22..cd48e45171cb 100644 --- a/configs/igep0032_defconfig +++ b/configs/igep0032_defconfig @@ -3,7 +3,6 @@ CONFIG_OMAP34XX=y # CONFIG_SPL_EXT_SUPPORT is not set CONFIG_TARGET_OMAP3_IGEP00X0=y CONFIG_DISTRO_DEFAULTS=y -CONFIG_SYS_EXTRA_OPTIONS="MACH_TYPE=MACH_TYPE_IGEP0032" CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_INFO_QUIET=y diff --git a/include/configs/omap3_igep00x0.h b/include/configs/omap3_igep00x0.h index 30d3aa897f1b..e6d7db0da692 100644 --- a/include/configs/omap3_igep00x0.h +++ b/include/configs/omap3_igep00x0.h @@ -28,7 +28,8 @@ #define CONFIG_REVISION_TAG 1
/* Status LED available for IGEP0020 and IGEP0030 but not IGEP0032 */ -#if (CONFIG_MACH_TYPE != MACH_TYPE_IGEP0032) +#if (CONFIG_MACH_TYPE == MACH_TYPE_IGEP0020) || \ + (CONFIG_MACH_TYPE == MACH_TYPE_IGEP0030) #define CONFIG_STATUS_LED #define CONFIG_BOARD_SPECIFIC_LED #define CONFIG_GPIO_LED @@ -36,8 +37,6 @@ #define RED_LED_GPIO 27 #elif (CONFIG_MACH_TYPE == MACH_TYPE_IGEP0030) #define RED_LED_GPIO 16 -#else -#error "status LED not defined for this machine." #endif #define RED_LED_DEV 0 #define STATUS_LED_BIT RED_LED_GPIO
2017-01-10 23:22 GMT+01:00 Tom Rini trini@konsulko.com:
1.9.1
cc: Eduard and Pau
I think that there are few boards in the field, an seems that anyone take care to upstream the dts files to the kernel. Currently I don't have this board so I can't support it, so from my side
Acked-by: Enric Balletbo i Serra eballetbo@gmail.com
1.9.1
cc: Eduard and Pau
Note that all the above patch does is remove ATAGS-based support as the MACH_TYPE for the 0032 was reserved, but never used and thus the name was removed. DT based support is unchanged.
2017-01-11 16:05 GMT+01:00 Tom Rini trini@konsulko.com:
#define CONFIG_STATUS_LED #define CONFIG_BOARD_SPECIFIC_LED #define CONFIG_GPIO_LED @@ -36,8 +37,6 @@ #define RED_LED_GPIO 27 #elif (CONFIG_MACH_TYPE == MACH_TYPE_IGEP0030) #define RED_LED_GPIO 16 -#else -#error "status LED not defined for this machine."drivers/iio/common/cros_ec_sensors/Makefile #endif #define RED_LED_DEV 0
1.9.1
cc: Eduard and Pau
-- Tom
Yes, I saw it, thus my ack ... I just wondering if this board is really used and if we should completely remove it or not. Sorry for not having better explained
Cc: Enric Balletbo i Serra eballetbo@gmail.com Signed-off-by: Tom Rini trini@konsulko.com Acked-by: Enric Balletbo i Serra eballetbo@gmail.com
Before we can sync with the latest mach-types.h file from the Linux Kernel we need to remove some instances of MACH_TYPE_xxx from our sources. As these values have been removed from the canonical upstream source we should not be using them either, so drop.
Cc: Tom Warren twarren@nvidia.com Cc: Lucas Stach dev@lynxeye.de Cc: Luka Perkov luka@openwrt.org Cc: Stephen Warren swarren@wwwdotorg.org Cc: Heiko Schocher hs@denx.de Cc: Thomas Weber weber@corscience.de Cc: Lucile Quirion lucile.quirion@savoirfairelinux.com Cc: Matthias Weisser weisserm@arcor.de Cc: Suriyan Ramasami suriyan.r@gmail.com Cc: Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com Cc: Bo Shen voice.shen@atmel.com Cc: Nick Thompson nick.thompson@gefanuc.com Cc: Stefano Babic sbabic@denx.de Cc: Erik van Luijk evanluijk@interact.nl Cc: Lokesh Vutla lokeshvutla@ti.com Signed-off-by: Tom Rini trini@konsulko.com --- board/Seagate/goflexhome/goflexhome.c | 5 ----- board/atmark-techno/armadillo-800eva/armadillo-800eva.c | 2 -- board/atmel/at91sam9x5ek/at91sam9x5ek.c | 3 --- board/davinci/da8xxevm/omapl138_lcdk.c | 3 --- board/davinci/ea20/ea20.c | 3 --- board/mini-box/picosam9g45/picosam9g45.c | 2 -- board/ti/omap5_uevm/evm.c | 1 - include/configs/cardhu.h | 2 -- include/configs/colibri_t20.h | 2 -- include/configs/iconnect.h | 5 ----- include/configs/rpi.h | 15 --------------- include/configs/smartweb.h | 1 - include/configs/tricorder.h | 1 - include/configs/ts4800.h | 2 -- include/configs/ventana.h | 2 -- include/configs/whistler.h | 2 -- include/configs/zmx25.h | 1 - 17 files changed, 52 deletions(-)
diff --git a/board/Seagate/goflexhome/goflexhome.c b/board/Seagate/goflexhome/goflexhome.c index 1f4fb924942a..ad8245aaaa55 100644 --- a/board/Seagate/goflexhome/goflexhome.c +++ b/board/Seagate/goflexhome/goflexhome.c @@ -92,11 +92,6 @@ int board_early_init_f(void)
int board_init(void) { - /* - * arch number of board - */ - gd->bd->bi_arch_number = MACH_TYPE_GOFLEXHOME; - /* address of boot parameters */ gd->bd->bi_boot_params = mvebu_sdram_bar(0) + 0x100;
diff --git a/board/atmark-techno/armadillo-800eva/armadillo-800eva.c b/board/atmark-techno/armadillo-800eva/armadillo-800eva.c index 28e61116a39d..0227d703e3ad 100644 --- a/board/atmark-techno/armadillo-800eva/armadillo-800eva.c +++ b/board/atmark-techno/armadillo-800eva/armadillo-800eva.c @@ -271,8 +271,6 @@ int board_early_init_f(void) DECLARE_GLOBAL_DATA_PTR; int board_init(void) { - /* board id for linux */ - gd->bd->bi_arch_number = MACH_TYPE_ARMADILLO_800EVA; /* adress of boot parameters */ gd->bd->bi_boot_params = ARMADILLO_800EVA_SDRAM_BASE + 0x100;
diff --git a/board/atmel/at91sam9x5ek/at91sam9x5ek.c b/board/atmel/at91sam9x5ek/at91sam9x5ek.c index b0d440d728a6..649312228016 100644 --- a/board/atmel/at91sam9x5ek/at91sam9x5ek.c +++ b/board/atmel/at91sam9x5ek/at91sam9x5ek.c @@ -256,9 +256,6 @@ int board_early_init_f(void)
int board_init(void) { - /* arch number of AT91SAM9X5EK-Board */ - gd->bd->bi_arch_number = MACH_TYPE_AT91SAM9X5EK; - /* adress of boot parameters */ gd->bd->bi_boot_params = CONFIG_SYS_SDRAM_BASE + 0x100;
diff --git a/board/davinci/da8xxevm/omapl138_lcdk.c b/board/davinci/da8xxevm/omapl138_lcdk.c index 9c1a48331236..1b7afb32f68f 100644 --- a/board/davinci/da8xxevm/omapl138_lcdk.c +++ b/board/davinci/da8xxevm/omapl138_lcdk.c @@ -175,9 +175,6 @@ int board_init(void) irq_init(); #endif
- /* arch number of the board */ - gd->bd->bi_arch_number = MACH_TYPE_OMAPL138_LCDK; - /* address of boot parameters */ gd->bd->bi_boot_params = LINUX_BOOT_PARAM_ADDR;
diff --git a/board/davinci/ea20/ea20.c b/board/davinci/ea20/ea20.c index 66804d75bd04..30e4c7d4de45 100644 --- a/board/davinci/ea20/ea20.c +++ b/board/davinci/ea20/ea20.c @@ -277,9 +277,6 @@ int overwrite_console(void)
int board_init(void) { - /* arch number of the board */ - gd->bd->bi_arch_number = MACH_TYPE_EA20; - /* address of boot parameters */ gd->bd->bi_boot_params = LINUX_BOOT_PARAM_ADDR;
diff --git a/board/mini-box/picosam9g45/picosam9g45.c b/board/mini-box/picosam9g45/picosam9g45.c index 32ba9c622590..8a4a39275386 100644 --- a/board/mini-box/picosam9g45/picosam9g45.c +++ b/board/mini-box/picosam9g45/picosam9g45.c @@ -252,8 +252,6 @@ int board_early_init_f(void)
int board_init(void) { - gd->bd->bi_arch_number = MACH_TYPE_PICOSAM9G45; - /* adress of boot parameters */ gd->bd->bi_boot_params = CONFIG_SYS_SDRAM_BASE + 0x100;
diff --git a/board/ti/omap5_uevm/evm.c b/board/ti/omap5_uevm/evm.c index b5d5ba9bdf9b..d84ec5747bed 100644 --- a/board/ti/omap5_uevm/evm.c +++ b/board/ti/omap5_uevm/evm.c @@ -138,7 +138,6 @@ int usb_gadget_handle_interrupts(int index) int board_init(void) { gpmc_init(); - gd->bd->bi_arch_number = MACH_TYPE_OMAP5_SEVM; gd->bd->bi_boot_params = (0x80000000 + 0x100); /* boot param addr */
tca642x_set_inital_state(CONFIG_SYS_I2C_TCA642X_ADDR, tca642x_init); diff --git a/include/configs/cardhu.h b/include/configs/cardhu.h index b7df2bce4c82..e426a4c71849 100644 --- a/include/configs/cardhu.h +++ b/include/configs/cardhu.h @@ -25,8 +25,6 @@ #define CONFIG_TEGRA_ENABLE_UARTA #define CONFIG_SYS_NS16550_COM1 NV_PA_APB_UARTA_BASE
-#define CONFIG_MACH_TYPE MACH_TYPE_CARDHU - /* I2C */ #define CONFIG_SYS_I2C_TEGRA
diff --git a/include/configs/colibri_t20.h b/include/configs/colibri_t20.h index e9db97f1adc8..7aa12629b4cc 100644 --- a/include/configs/colibri_t20.h +++ b/include/configs/colibri_t20.h @@ -21,8 +21,6 @@ #define CONFIG_TEGRA_UARTA_SDIO1 #define CONFIG_SYS_NS16550_COM1 NV_PA_APB_UARTA_BASE
-#define CONFIG_MACH_TYPE MACH_TYPE_COLIBRI_T20 - /* I2C */ #define CONFIG_SYS_I2C_TEGRA
diff --git a/include/configs/iconnect.h b/include/configs/iconnect.h index 633941b7dd56..0ea6fcb82c09 100644 --- a/include/configs/iconnect.h +++ b/include/configs/iconnect.h @@ -17,11 +17,6 @@ #define CONFIG_SKIP_LOWLEVEL_INIT /* disable board lowlevel_init */
/* - * Machine type - */ -#define CONFIG_MACH_TYPE MACH_TYPE_ICONNECT - -/* * Compression configuration */ #define CONFIG_BZIP2 diff --git a/include/configs/rpi.h b/include/configs/rpi.h index 45d88247afa0..ce539a008cce 100644 --- a/include/configs/rpi.h +++ b/include/configs/rpi.h @@ -24,21 +24,6 @@ (&((struct bcm2835_timer_regs *)BCM2835_TIMER_PHYSADDR)->clo) #endif
-/* - * 2835 is a SKU in a series for which the 2708 is the first or primary SoC, - * so 2708 has historically been used rather than a dedicated 2835 ID. - * - * We don't define a machine type for bcm2709/bcm2836 since the RPi Foundation - * chose to use someone else's previously registered machine ID (3139, MX51_GGC) - * rather than obtaining a valid ID:-/ - * - * For the bcm2837, hopefully a machine type is not needed, since everything - * is DT. - */ -#ifdef CONFIG_BCM2835 -#define CONFIG_MACH_TYPE MACH_TYPE_BCM2708 -#endif - /* Memory layout */ #define CONFIG_NR_DRAM_BANKS 1 #define CONFIG_SYS_SDRAM_BASE 0x00000000 diff --git a/include/configs/smartweb.h b/include/configs/smartweb.h index df5fe2163f05..fd35f71f913c 100644 --- a/include/configs/smartweb.h +++ b/include/configs/smartweb.h @@ -52,7 +52,6 @@ #define CONFIG_SYS_MAXARGS 32
/* setting board specific options */ -#define CONFIG_MACH_TYPE MACH_TYPE_SMARTWEB #define CONFIG_AUTO_COMPLETE #define CONFIG_ENV_OVERWRITE 1 /* Overwrite ethaddr / serial# */ #define CONFIG_AUTO_COMPLETE diff --git a/include/configs/tricorder.h b/include/configs/tricorder.h index 1c36d0751c4c..b003b1414842 100644 --- a/include/configs/tricorder.h +++ b/include/configs/tricorder.h @@ -24,7 +24,6 @@ #define CONFIG_ARM_ERRATA_430973 #define CONFIG_ARM_ERRATA_621766
-#define CONFIG_MACH_TYPE MACH_TYPE_TRICORDER /* * 1MB into the SDRAM to allow for SPL's bss at the beginning of SDRAM * 64 bytes before this address should be set aside for u-boot.img's diff --git a/include/configs/ts4800.h b/include/configs/ts4800.h index a451acf1f4bf..261daef9aa3f 100644 --- a/include/configs/ts4800.h +++ b/include/configs/ts4800.h @@ -21,8 +21,6 @@
#define CONFIG_HW_WATCHDOG
-#define CONFIG_MACH_TYPE MACH_TYPE_TS48XX - /* text base address used when linking */ #define CONFIG_SYS_TEXT_BASE 0x90008000
diff --git a/include/configs/ventana.h b/include/configs/ventana.h index f5459a894906..b04e28ce9785 100644 --- a/include/configs/ventana.h +++ b/include/configs/ventana.h @@ -18,8 +18,6 @@ #define CONFIG_TEGRA_ENABLE_UARTD #define CONFIG_SYS_NS16550_COM1 NV_PA_APB_UARTD_BASE
-#define CONFIG_MACH_TYPE MACH_TYPE_VENTANA - /* SD/MMC */ #define CONFIG_GENERIC_MMC #define CONFIG_TEGRA_MMC diff --git a/include/configs/whistler.h b/include/configs/whistler.h index ffd9a2c24219..c4d6e32ccc90 100644 --- a/include/configs/whistler.h +++ b/include/configs/whistler.h @@ -19,8 +19,6 @@ #define CONFIG_TEGRA_UARTA_UAA_UAB #define CONFIG_SYS_NS16550_COM1 NV_PA_APB_UARTA_BASE
-#define CONFIG_MACH_TYPE MACH_TYPE_WHISTLER - /* I2C */ #define CONFIG_SYS_I2C_TEGRA
diff --git a/include/configs/zmx25.h b/include/configs/zmx25.h index 7038e6b22c5c..e3e19dcbe193 100644 --- a/include/configs/zmx25.h +++ b/include/configs/zmx25.h @@ -19,7 +19,6 @@ #define CONFIG_SYS_TIMER_COUNTER \ (&((struct gpt_regs *)IMX_GPT1_BASE)->counter)
-#define CONFIG_MACH_TYPE MACH_TYPE_ZMX25 /* * Environment settings */
The Tegra and RPi changes only affect non-DT booting, right?
It would be nice if the Tegra config headers could be kept consistent, i.e. delete all places that define CONFIG_MACH_TYPE from all Tegra config headers, rather than just removing a few. Perhaps it even makes sense to do that source-tree-wide, at least for ARM boards?
Correct. MACH_TYPE_xxx is only used for ATAG booting.
I leave the decision to remove MACH_TYPE_xxx up to the SoC custodians. I know that for example for TI parts we do not want to as people are using RTOSes that do use ATAGS still.
This re-syncs the MACH_TYPE_xxx values from the Linux Kernel v4.9 release. In addition this removes all of the machine_arch_type and machine_is_xxx logic that is unused in U-Boot. This removal removes a large number of otherwise unused CONFIG values from the list to be converted.
Cc: Masahiro Yamada yamada.masahiro@socionext.com Signed-off-by: Tom Rini trini@konsulko.com --- arch/arm/include/asm/mach-types.h | 14174 ++---------------------------------- scripts/config_whitelist.txt | 1077 --- 2 files changed, 486 insertions(+), 14765 deletions(-)
diff --git a/arch/arm/include/asm/mach-types.h b/arch/arm/include/asm/mach-types.h index d51be0b1d2f8..c90caa85c82c 100644 --- a/arch/arm/include/asm/mach-types.h +++ b/arch/arm/include/asm/mach-types.h @@ -6,11 +6,6 @@ #ifndef __ASM_ARM_MACH_TYPE_H #define __ASM_ARM_MACH_TYPE_H
-#ifndef __ASSEMBLY__ -/* The type of machine we're running on */ -extern unsigned int __machine_arch_type; -#endif - /* see arch/arm/kernel/arch.c for a description of these */ #define MACH_TYPE_EBSA110 0 #define MACH_TYPE_RISCPC 1 @@ -87,6 +82,7 @@ extern unsigned int __machine_arch_type; #define MACH_TYPE_LPD7A404 390 #define MACH_TYPE_CSB337 399 #define MACH_TYPE_MAINSTONE 406 +#define MACH_TYPE_LITE300 408 #define MACH_TYPE_XCEP 413 #define MACH_TYPE_ARCOM_VULCAN 414 #define MACH_TYPE_NOMADIK 420 @@ -123,12 +119,14 @@ extern unsigned int __machine_arch_type; #define MACH_TYPE_SX1 613 #define MACH_TYPE_IXDP465 618 #define MACH_TYPE_IXDP2351 619 +#define MACH_TYPE_CM4008 624 #define MACH_TYPE_IQ80332 629 #define MACH_TYPE_GTWX5715 641 #define MACH_TYPE_CSB637 648 #define MACH_TYPE_N30 656 #define MACH_TYPE_NEC_MP900 659 #define MACH_TYPE_KAFA 662 +#define MACH_TYPE_CM41XX 672 #define MACH_TYPE_TS72XX 673 #define MACH_TYPE_OTOM 680 #define MACH_TYPE_NEXCODER_2440 681 @@ -141,6 +139,7 @@ extern unsigned int __machine_arch_type; #define MACH_TYPE_GATEWAY7001 731 #define MACH_TYPE_PCM027 732 #define MACH_TYPE_ANUBIS 734 +#define MACH_TYPE_XBOARDGP8 742 #define MACH_TYPE_AKITA 744 #define MACH_TYPE_E330 753 #define MACH_TYPE_NOKIA770 755 @@ -150,8 +149,10 @@ extern unsigned int __machine_arch_type; #define MACH_TYPE_INTELMOTE2 775 #define MACH_TYPE_TRIZEPS4 776 #define MACH_TYPE_PNX4008 782 +#define MACH_TYPE_CPUAT91 787 #define MACH_TYPE_IQ81340SC 799 #define MACH_TYPE_IQ81340MC 801 +#define MACH_TYPE_SE4200 809 #define MACH_TYPE_MICRO9 811 #define MACH_TYPE_MICRO9L 812 #define MACH_TYPE_OMAP_PALMTE 817 @@ -170,6 +171,7 @@ extern unsigned int __machine_arch_type; #define MACH_TYPE_AMS_DELTA 862 #define MACH_TYPE_NAS100D 865 #define MACH_TYPE_MAGICIAN 875 +#define MACH_TYPE_CM4002 876 #define MACH_TYPE_NXDKN 880 #define MACH_TYPE_PALMTX 885 #define MACH_TYPE_S3C2413 887 @@ -178,6 +180,7 @@ extern unsigned int __machine_arch_type; #define MACH_TYPE_DAVINCI_EVM 901 #define MACH_TYPE_PALMZ72 904 #define MACH_TYPE_NXDB500 905 +#define MACH_TYPE_APF9328 906 #define MACH_TYPE_PALMT5 917 #define MACH_TYPE_PALMTC 918 #define MACH_TYPE_OMAP_APOLLON 919 @@ -196,6 +199,7 @@ extern unsigned int __machine_arch_type; #define MACH_TYPE_SMDK2412 1009 #define MACH_TYPE_SMDK2413 1022 #define MACH_TYPE_AML_M5900 1024 +#define MACH_TYPE_BALLOON3 1029 #define MACH_TYPE_ECBAT91 1072 #define MACH_TYPE_ONEARM 1075 #define MACH_TYPE_SMDK2443 1084 @@ -203,6 +207,7 @@ extern unsigned int __machine_arch_type; #define MACH_TYPE_AT91SAM9260EK 1099 #define MACH_TYPE_GLANTANK 1100 #define MACH_TYPE_N2100 1101 +#define MACH_TYPE_IM42XX 1105 #define MACH_TYPE_QT2410 1108 #define MACH_TYPE_KIXRP435 1109 #define MACH_TYPE_CC9P9360DEV 1114 @@ -221,6 +226,7 @@ extern unsigned int __machine_arch_type; #define MACH_TYPE_MIOA701 1257 #define MACH_TYPE_ARMADILLO5X0 1260 #define MACH_TYPE_CC9P9360JS 1264 +#define MACH_TYPE_SMDK6400 1270 #define MACH_TYPE_NOKIA_N800 1271 #define MACH_TYPE_EP80219 1281 #define MACH_TYPE_GORAMO_MLR 1292 @@ -235,6 +241,7 @@ extern unsigned int __machine_arch_type; #define MACH_TYPE_DAVINCI_DM6467_EVM 1380 #define MACH_TYPE_DAVINCI_DM355_EVM 1381 #define MACH_TYPE_LITTLETON 1388 +#define MACH_TYPE_IM4004 1400 #define MACH_TYPE_REALVIEW_PB11MP 1407 #define MACH_TYPE_MX27_3DS 1430 #define MACH_TYPE_HALIBUT 1439 @@ -256,13 +263,16 @@ extern unsigned int __machine_arch_type; #define MACH_TYPE_OMAP3_BEAGLE 1546 #define MACH_TYPE_NOKIA_N810 1548 #define MACH_TYPE_PCM038 1551 +#define MACH_TYPE_SG310 1564 #define MACH_TYPE_TS209 1565 #define MACH_TYPE_AT91CAP9ADK 1566 #define MACH_TYPE_MX31MOBOARD 1574 +#define MACH_TYPE_VISION_EP9307 1578 #define MACH_TYPE_TERASTATION_PRO2 1584 #define MACH_TYPE_LINKSTATION_PRO 1585 #define MACH_TYPE_E350 1596 #define MACH_TYPE_TS409 1601 +#define MACH_TYPE_RSI_EWS 1609 #define MACH_TYPE_CM_X300 1616 #define MACH_TYPE_AT91SAM9G20EK 1624 #define MACH_TYPE_SMDK6410 1626 @@ -274,7 +284,6 @@ extern unsigned int __machine_arch_type; #define MACH_TYPE_TRIZEPS4WL 1649 #define MACH_TYPE_TS78XX 1652 #define MACH_TYPE_SFFSDR 1657 -#define MACH_TYPE_SMARTWEB 1668 #define MACH_TYPE_PCM037 1673 #define MACH_TYPE_DB88F6281_BP 1680 #define MACH_TYPE_RD88F6192_NAS 1681 @@ -307,7 +316,6 @@ extern unsigned int __machine_arch_type; #define MACH_TYPE_MX25_3DS 1771 #define MACH_TYPE_OMAP3530_LV_SOM 1773 #define MACH_TYPE_DAVINCI_DA830_EVM 1781 -#define MACH_TYPE_AT572D940HFEB 1783 #define MACH_TYPE_DOVE_DB 1788 #define MACH_TYPE_OVERO 1798 #define MACH_TYPE_AT2440EVB 1799 @@ -320,6 +328,7 @@ extern unsigned int __machine_arch_type; #define MACH_TYPE_TAVOREVB 1827 #define MACH_TYPE_SAAR 1828 #define MACH_TYPE_AT91SAM9M10G45EK 1830 +#define MACH_TYPE_USB_A9G20 1841 #define MACH_TYPE_MXLADS 1851 #define MACH_TYPE_LINKSTATION_MINI 1858 #define MACH_TYPE_AFEB9260 1859 @@ -366,13 +375,12 @@ extern unsigned int __machine_arch_type; #define MACH_TYPE_AT91SAM9G10EK 2159 #define MACH_TYPE_OMAP_4430SDP 2160 #define MACH_TYPE_MAGX_ZN5 2162 -#define MACH_TYPE_BTMAVB101 2172 -#define MACH_TYPE_BTMAWB101 2173 #define MACH_TYPE_OMAP3_TORPEDO 2178 #define MACH_TYPE_ANW6410 2183 #define MACH_TYPE_IMX27_VISSTRIM_M10 2187 #define MACH_TYPE_PORTUXG20 2191 #define MACH_TYPE_SMDKC110 2193 +#define MACH_TYPE_CABESPRESSO 2194 #define MACH_TYPE_OMAP3517EVM 2200 #define MACH_TYPE_NETSPACE_V2 2201 #define MACH_TYPE_NETSPACE_MAX_V2 2202 @@ -381,7 +389,6 @@ extern unsigned int __machine_arch_type; #define MACH_TYPE_NET5BIG_V2 2206 #define MACH_TYPE_INETSPACE_V2 2208 #define MACH_TYPE_AT91SAM9G45EKES 2212 -#define MACH_TYPE_PC7302 2220 #define MACH_TYPE_SPEAR600 2236 #define MACH_TYPE_SPEAR300 2237 #define MACH_TYPE_LILLY1131 2239 @@ -391,8 +398,8 @@ extern unsigned int __machine_arch_type; #define MACH_TYPE_BIGDISK 2283 #define MACH_TYPE_AT91SAM9G20EK_2MMC 2288 #define MACH_TYPE_BCMRING 2289 -#define MACH_TYPE_DP6XX 2302 #define MACH_TYPE_MAHIMAHI 2304 +#define MACH_TYPE_CEREBRIC 2311 #define MACH_TYPE_SMDK6442 2324 #define MACH_TYPE_OPENRD_BASE 2325 #define MACH_TYPE_DEVKIT8000 2330 @@ -402,6 +409,7 @@ extern unsigned int __machine_arch_type; #define MACH_TYPE_IGEP0020 2344 #define MACH_TYPE_NUC932EVB 2356 #define MACH_TYPE_OPENRD_CLIENT 2361 +#define MACH_TYPE_U8500 2368 #define MACH_TYPE_MX51_EFIKASB 2370 #define MACH_TYPE_MARVELL_JASPER 2382 #define MACH_TYPE_FLINT 2383 @@ -414,6 +422,7 @@ extern unsigned int __machine_arch_type; #define MACH_TYPE_SMDKV210 2456 #define MACH_TYPE_OMAP_ZOOM3 2464 #define MACH_TYPE_OMAP_3630SDP 2465 +#define MACH_TYPE_CYBOOK2440 2466 #define MACH_TYPE_SMARTQ7 2479 #define MACH_TYPE_WATSON_EFM_PLUGIN 2491 #define MACH_TYPE_G4EVM 2493 @@ -425,10 +434,9 @@ extern unsigned int __machine_arch_type; #define MACH_TYPE_SMARTQ5 2534 #define MACH_TYPE_DAVINCI_DM6467TEVM 2548 #define MACH_TYPE_MXT_TD60 2550 -#define MACH_TYPE_RIOT_BEI2 2576 -#define MACH_TYPE_RIOT_X37 2578 #define MACH_TYPE_CAPC7117 2612 #define MACH_TYPE_ICONTROL 2624 +#define MACH_TYPE_GPLUGD 2625 #define MACH_TYPE_QSD8X50A_ST1_5 2627 #define MACH_TYPE_MX23EVK 2629 #define MACH_TYPE_AP4EVB 2630 @@ -439,7 +447,6 @@ extern unsigned int __machine_arch_type; #define MACH_TYPE_AQUILA 2676 #define MACH_TYPE_ESATA_SHEEVAPLUG 2678 #define MACH_TYPE_MSM7X30_SURF 2679 -#define MACH_TYPE_EA2478DEVKIT 2683 #define MACH_TYPE_TERASTATION_WXL 2697 #define MACH_TYPE_MSM7X25_SURF 2703 #define MACH_TYPE_MSM7X25_FFA 2704 @@ -452,14 +459,13 @@ extern unsigned int __machine_arch_type; #define MACH_TYPE_SBC3530 2722 #define MACH_TYPE_SAARB 2727 #define MACH_TYPE_HARMONY 2731 +#define MACH_TYPE_CYBOOK_ORIZON 2733 #define MACH_TYPE_MSM7X30_FLUID 2741 #define MACH_TYPE_CM_T3517 2750 #define MACH_TYPE_WBD222 2753 #define MACH_TYPE_MSM8X60_SURF 2755 #define MACH_TYPE_MSM8X60_SIM 2756 #define MACH_TYPE_TCC8000_SDK 2758 -#define MACH_TYPE_NANOS 2759 -#define MACH_TYPE_STAMP9G45 2761 #define MACH_TYPE_CNS3420VB 2776 #define MACH_TYPE_OMAP4_PANDA 2791 #define MACH_TYPE_TI8168EVM 2800 @@ -469,13731 +475,523 @@ extern unsigned int __machine_arch_type; #define MACH_TYPE_EUKREA_CPUIMX51SD 2822 #define MACH_TYPE_EUKREA_CPUIMX51 2823 #define MACH_TYPE_SMDKC210 2838 -#define MACH_TYPE_OMAP3_BRAILLO 2839 -#define MACH_TYPE_SPYPLUG 2840 -#define MACH_TYPE_GINGER 2841 -#define MACH_TYPE_TNY_T3530 2842 -#define MACH_TYPE_PCA102 2843 -#define MACH_TYPE_SPADE 2844 -#define MACH_TYPE_MXC25_TOPAZ 2845 #define MACH_TYPE_T5325 2846 -#define MACH_TYPE_GW2361 2847 -#define MACH_TYPE_ELOG 2848 #define MACH_TYPE_INCOME 2849 -#define MACH_TYPE_BCM589X 2850 -#define MACH_TYPE_ETNA 2851 -#define MACH_TYPE_HAWKS 2852 -#define MACH_TYPE_MESON 2853 -#define MACH_TYPE_XSBASE255 2854 -#define MACH_TYPE_PVM2030 2855 -#define MACH_TYPE_MIOA502 2856 -#define MACH_TYPE_VVBOX_SDORIG2 2857 -#define MACH_TYPE_VVBOX_SDLITE2 2858 -#define MACH_TYPE_VVBOX_SDPRO4 2859 -#define MACH_TYPE_HTC_SPV_M700 2860 -#define MACH_TYPE_MX257SX 2861 #define MACH_TYPE_GONI 2862 -#define MACH_TYPE_MSM8X55_SVLTE_FFA 2863 -#define MACH_TYPE_MSM8X55_SVLTE_SURF 2864 -#define MACH_TYPE_QUICKSTEP 2865 -#define MACH_TYPE_DMW96 2866 -#define MACH_TYPE_HAMMERHEAD 2867 -#define MACH_TYPE_TRIDENT 2868 -#define MACH_TYPE_LIGHTNING 2869 -#define MACH_TYPE_ICONNECT 2870 -#define MACH_TYPE_AUTOBOT 2871 -#define MACH_TYPE_COCONUT 2872 -#define MACH_TYPE_DURIAN 2873 -#define MACH_TYPE_CAYENNE 2874 -#define MACH_TYPE_FUJI 2875 -#define MACH_TYPE_SYNOLOGY_6282 2876 -#define MACH_TYPE_EM1SY 2877 -#define MACH_TYPE_M502 2878 -#define MACH_TYPE_MATRIX518 2879 -#define MACH_TYPE_TINY_GURNARD 2880 -#define MACH_TYPE_SPEAR1310 2881 #define MACH_TYPE_BV07 2882 -#define MACH_TYPE_MXT_TD61 2883 #define MACH_TYPE_OPENRD_ULTIMATE 2884 #define MACH_TYPE_DEVIXP 2885 #define MACH_TYPE_MICCPT 2886 #define MACH_TYPE_MIC256 2887 -#define MACH_TYPE_AS1167 2888 -#define MACH_TYPE_OMAP3_IBIZA 2889 #define MACH_TYPE_U5500 2890 -#define MACH_TYPE_DAVINCI_PICTO 2891 -#define MACH_TYPE_MECHA 2892 -#define MACH_TYPE_BUBBA3 2893 -#define MACH_TYPE_PUPITRE 2894 -#define MACH_TYPE_TEGRA_VOGUE 2896 -#define MACH_TYPE_TEGRA_E1165 2897 -#define MACH_TYPE_SIMPLENET 2898 -#define MACH_TYPE_EC4350TBM 2899 -#define MACH_TYPE_PEC_TC 2900 -#define MACH_TYPE_PEC_HC2 2901 -#define MACH_TYPE_ESL_MOBILIS_A 2902 -#define MACH_TYPE_ESL_MOBILIS_B 2903 -#define MACH_TYPE_ESL_WAVE_A 2904 -#define MACH_TYPE_ESL_WAVE_B 2905 -#define MACH_TYPE_UNISENSE_MMM 2906 -#define MACH_TYPE_BLUESHARK 2907 -#define MACH_TYPE_E10 2908 -#define MACH_TYPE_APP3K_ROBIN 2909 -#define MACH_TYPE_POV15HD 2910 -#define MACH_TYPE_STELLA 2911 #define MACH_TYPE_LINKSTATION_LSCHL 2913 -#define MACH_TYPE_NETWALKER 2914 -#define MACH_TYPE_ACSX106 2915 -#define MACH_TYPE_ATLAS5_C1 2916 -#define MACH_TYPE_NSB3AST 2917 -#define MACH_TYPE_GNET_SLC 2918 -#define MACH_TYPE_AF4000 2919 -#define MACH_TYPE_ARK9431 2920 -#define MACH_TYPE_FS_S5PC100 2921 -#define MACH_TYPE_OMAP3505NOVA8 2922 -#define MACH_TYPE_OMAP3621_EDP1 2923 -#define MACH_TYPE_ORATISAES 2924 #define MACH_TYPE_SMDKV310 2925 -#define MACH_TYPE_SIEMENS_L0 2926 -#define MACH_TYPE_VENTANA 2927 #define MACH_TYPE_WM8505_7IN_NETBOOK 2928 -#define MACH_TYPE_EC4350SDB 2929 -#define MACH_TYPE_MIMAS 2930 -#define MACH_TYPE_TITAN 2931 #define MACH_TYPE_CRANEBOARD 2932 -#define MACH_TYPE_ES2440 2933 -#define MACH_TYPE_NAJAY_A9263 2934 -#define MACH_TYPE_HTCTORNADO 2935 -#define MACH_TYPE_DIMM_MX257 2936 -#define MACH_TYPE_JIGEN 2937 #define MACH_TYPE_SMDK6450 2938 -#define MACH_TYPE_MENO_QNG 2939 -#define MACH_TYPE_NS2416 2940 -#define MACH_TYPE_RPC353 2941 -#define MACH_TYPE_TQ6410 2942 -#define MACH_TYPE_SKY6410 2943 -#define MACH_TYPE_DYNASTY 2944 -#define MACH_TYPE_VIVO 2945 -#define MACH_TYPE_BURY_BL7582 2946 -#define MACH_TYPE_BURY_BPS5270 2947 -#define MACH_TYPE_BASI 2948 -#define MACH_TYPE_TN200 2949 -#define MACH_TYPE_C2MMI 2950 -#define MACH_TYPE_MESON_6236M 2951 -#define MACH_TYPE_MESON_8626M 2952 -#define MACH_TYPE_TUBE 2953 -#define MACH_TYPE_MESSINA 2954 -#define MACH_TYPE_MX50_ARM2 2955 -#define MACH_TYPE_CETUS9263 2956 #define MACH_TYPE_BROWNSTONE 2957 -#define MACH_TYPE_VMX25 2958 -#define MACH_TYPE_VMX51 2959 -#define MACH_TYPE_ABACUS 2960 -#define MACH_TYPE_CM4745 2961 -#define MACH_TYPE_ORATISLINK 2962 -#define MACH_TYPE_DAVINCI_DM365_DVR 2963 -#define MACH_TYPE_NETVIZ 2964 #define MACH_TYPE_FLEXIBITY 2965 -#define MACH_TYPE_WLAN_COMPUTER 2966 -#define MACH_TYPE_LPC24XX 2967 -#define MACH_TYPE_SPICA 2968 -#define MACH_TYPE_GPSDISPLAY 2969 -#define MACH_TYPE_BIPNET 2970 -#define MACH_TYPE_OVERO_CTU_INERTIAL 2971 -#define MACH_TYPE_DAVINCI_DM355_MMM 2972 -#define MACH_TYPE_PC9260_V2 2973 -#define MACH_TYPE_PTX7545 2974 -#define MACH_TYPE_TM_EFDC 2975 -#define MACH_TYPE_OMAP3_WALDO1 2977 -#define MACH_TYPE_FLYER 2978 -#define MACH_TYPE_TORNADO3240 2979 -#define MACH_TYPE_SOLI_01 2980 -#define MACH_TYPE_OMAPL138_EUROPALC 2981 -#define MACH_TYPE_HELIOS_V1 2982 -#define MACH_TYPE_NETSPACE_LITE_V2 2983 -#define MACH_TYPE_SSC 2984 -#define MACH_TYPE_PREMIERWAVE_EN 2985 -#define MACH_TYPE_WASABI 2986 #define MACH_TYPE_MX50_RDP 2988 #define MACH_TYPE_UNIVERSAL_C210 2989 #define MACH_TYPE_REAL6410 2990 -#define MACH_TYPE_SPX_SAKURA 2991 -#define MACH_TYPE_IJ3K_2440 2992 -#define MACH_TYPE_OMAP3_BC10 2993 -#define MACH_TYPE_THEBE 2994 -#define MACH_TYPE_RV082 2995 -#define MACH_TYPE_ARMLGUEST 2996 -#define MACH_TYPE_TJINC1000 2997 #define MACH_TYPE_DOCKSTAR 2998 -#define MACH_TYPE_AX8008 2999 -#define MACH_TYPE_GNET_SGCE 3000 -#define MACH_TYPE_PXWNAS_500_1000 3001 -#define MACH_TYPE_EA20 3002 -#define MACH_TYPE_AWM2 3003 #define MACH_TYPE_TI8148EVM 3004 #define MACH_TYPE_SEABOARD 3005 -#define MACH_TYPE_LINKSTATION_CHLV2 3006 -#define MACH_TYPE_TERA_PRO2_RACK 3007 -#define MACH_TYPE_RUBYS 3008 -#define MACH_TYPE_AQUARIUS 3009 #define MACH_TYPE_MX53_ARD 3010 #define MACH_TYPE_MX53_SMD 3011 -#define MACH_TYPE_LSWXL 3012 -#define MACH_TYPE_DOVE_AVNG_V3 3013 -#define MACH_TYPE_SDI_ESS_9263 3014 -#define MACH_TYPE_JOCPU550 3015 #define MACH_TYPE_MSM8X60_RUMI3 3016 #define MACH_TYPE_MSM8X60_FFA 3017 -#define MACH_TYPE_YANOMAMI 3018 -#define MACH_TYPE_GTA04 3019 #define MACH_TYPE_CM_A510 3020 -#define MACH_TYPE_OMAP3_RFS200 3021 -#define MACH_TYPE_KX33XX 3022 -#define MACH_TYPE_PTX7510 3023 -#define MACH_TYPE_TOP9000 3024 -#define MACH_TYPE_TEENOTE 3025 -#define MACH_TYPE_TS3 3026 -#define MACH_TYPE_A0 3027 -#define MACH_TYPE_FSM9XXX_SURF 3028 -#define MACH_TYPE_FSM9XXX_FFA 3029 -#define MACH_TYPE_FRRHWCDMA60W 3030 -#define MACH_TYPE_REMUS 3031 -#define MACH_TYPE_AT91CAP7XDK 3032 -#define MACH_TYPE_AT91CAP7STK 3033 -#define MACH_TYPE_KT_SBC_SAM9_1 3034 -#define MACH_TYPE_ARMADA_XP_DB 3036 -#define MACH_TYPE_SPDM 3037 -#define MACH_TYPE_GTIB 3038 -#define MACH_TYPE_DGM3240 3039 -#define MACH_TYPE_HTCMEGA 3041 -#define MACH_TYPE_TRICORDER 3042 #define MACH_TYPE_TX28 3043 -#define MACH_TYPE_BSTBRD 3044 -#define MACH_TYPE_PWB3090 3045 -#define MACH_TYPE_IDEA6410 3046 -#define MACH_TYPE_QBC9263 3047 -#define MACH_TYPE_BORABORA 3048 -#define MACH_TYPE_VALDEZ 3049 -#define MACH_TYPE_LS9G20 3050 -#define MACH_TYPE_MIOS_V1 3051 -#define MACH_TYPE_S5PC110_CRESPO 3052 -#define MACH_TYPE_CONTROLTEK9G20 3053 -#define MACH_TYPE_TIN307 3054 -#define MACH_TYPE_TIN510 3055 -#define MACH_TYPE_BLUECHEESE 3057 -#define MACH_TYPE_TEM3X30 3058 -#define MACH_TYPE_HARVEST_DESOTO 3059 -#define MACH_TYPE_MSM8X60_QRDC 3060 -#define MACH_TYPE_SPEAR900 3061 #define MACH_TYPE_PCONTROL_G20 3062 -#define MACH_TYPE_RDSTOR 3063 -#define MACH_TYPE_USDLOADER 3064 -#define MACH_TYPE_TSOPLOADER 3065 -#define MACH_TYPE_KRONOS 3066 -#define MACH_TYPE_FFCORE 3067 -#define MACH_TYPE_MONE 3068 -#define MACH_TYPE_UNIT2S 3069 -#define MACH_TYPE_ACER_A5 3070 -#define MACH_TYPE_ETHERPRO_ISP 3071 -#define MACH_TYPE_STRETCHS7000 3072 -#define MACH_TYPE_P87_SMARTSIM 3073 -#define MACH_TYPE_TULIP 3074 -#define MACH_TYPE_SUNFLOWER 3075 -#define MACH_TYPE_RIB 3076 -#define MACH_TYPE_CLOD 3077 -#define MACH_TYPE_RUMP 3078 -#define MACH_TYPE_TENDERLOIN 3079 -#define MACH_TYPE_SHORTLOIN 3080 -#define MACH_TYPE_ANTARES 3082 -#define MACH_TYPE_WB40N 3083 -#define MACH_TYPE_HERRING 3084 -#define MACH_TYPE_NAXY400 3085 -#define MACH_TYPE_NAXY1200 3086 #define MACH_TYPE_VPR200 3087 -#define MACH_TYPE_BUG20 3088 -#define MACH_TYPE_GOFLEXNET 3089 #define MACH_TYPE_TORBRECK 3090 -#define MACH_TYPE_SAARB_MG1 3091 -#define MACH_TYPE_CALLISTO 3092 -#define MACH_TYPE_MULTHSU 3093 -#define MACH_TYPE_SALUDA 3094 -#define MACH_TYPE_PEMP_OMAP3_APOLLO 3095 -#define MACH_TYPE_VC0718 3096 -#define MACH_TYPE_MVBLX 3097 -#define MACH_TYPE_INHAND_APEIRON 3098 -#define MACH_TYPE_INHAND_FURY 3099 -#define MACH_TYPE_INHAND_SIREN 3100 -#define MACH_TYPE_HDNVP 3101 -#define MACH_TYPE_SOFTWINNER 3102 #define MACH_TYPE_PRIMA2_EVB 3103 -#define MACH_TYPE_NAS6210 3104 -#define MACH_TYPE_UNISDEV 3105 -#define MACH_TYPE_SBCA11 3106 -#define MACH_TYPE_SAGA 3107 -#define MACH_TYPE_NS_K330 3108 -#define MACH_TYPE_TANNA 3109 -#define MACH_TYPE_IMATE8502 3110 -#define MACH_TYPE_ASPEN 3111 -#define MACH_TYPE_DAINTREE_CWAC 3112 -#define MACH_TYPE_ZMX25 3113 -#define MACH_TYPE_MAPLE1 3114 -#define MACH_TYPE_QSD8X72_SURF 3115 -#define MACH_TYPE_QSD8X72_FFA 3116 -#define MACH_TYPE_ABILENE 3117 -#define MACH_TYPE_EIGEN_TTR 3118 -#define MACH_TYPE_IOMEGA_IX2_200 3119 -#define MACH_TYPE_CORETEC_VCX7400 3120 -#define MACH_TYPE_SANTIAGO 3121 -#define MACH_TYPE_MX257SOL 3122 -#define MACH_TYPE_STRASBOURG 3123 -#define MACH_TYPE_MSM8X60_FLUID 3124 -#define MACH_TYPE_SMARTQV5 3125 -#define MACH_TYPE_SMARTQV3 3126 -#define MACH_TYPE_SMARTQV7 3127 #define MACH_TYPE_PAZ00 3128 #define MACH_TYPE_ACMENETUSFOXG20 3129 -#define MACH_TYPE_FWBD_0404 3131 -#define MACH_TYPE_HDGU 3132 -#define MACH_TYPE_PYRAMID 3133 -#define MACH_TYPE_EPIPHAN 3134 -#define MACH_TYPE_OMAP_BENDER 3135 -#define MACH_TYPE_GURNARD 3136 -#define MACH_TYPE_GTL_IT5100 3137 -#define MACH_TYPE_BCM2708 3138 -#define MACH_TYPE_MX51_GGC 3139 -#define MACH_TYPE_SHARESPACE 3140 -#define MACH_TYPE_HABA_KNX_EXPLORER 3141 -#define MACH_TYPE_SIMTEC_KIRKMOD 3142 -#define MACH_TYPE_CRUX 3143 -#define MACH_TYPE_MX51_BRAVO 3144 -#define MACH_TYPE_CHARON 3145 -#define MACH_TYPE_PICOCOM3 3146 -#define MACH_TYPE_PICOCOM4 3147 -#define MACH_TYPE_SERRANO 3148 -#define MACH_TYPE_DOUBLESHOT 3149 -#define MACH_TYPE_EVSY 3150 -#define MACH_TYPE_HUASHAN 3151 -#define MACH_TYPE_LAUSANNE 3152 -#define MACH_TYPE_EMERALD 3153 -#define MACH_TYPE_TQMA35 3154 -#define MACH_TYPE_MARVEL 3155 -#define MACH_TYPE_MANUAE 3156 -#define MACH_TYPE_CHACHA 3157 -#define MACH_TYPE_LEMON 3158 -#define MACH_TYPE_CSC 3159 -#define MACH_TYPE_GIRA_KNXIP_ROUTER 3160 -#define MACH_TYPE_T20 3161 -#define MACH_TYPE_HDMINI 3162 -#define MACH_TYPE_SCIPHONE_G2 3163 -#define MACH_TYPE_EXPRESS 3164 -#define MACH_TYPE_EXPRESS_KT 3165 -#define MACH_TYPE_MAXIMASP 3166 -#define MACH_TYPE_NITROGEN_IMX51 3167 -#define MACH_TYPE_NITROGEN_IMX53 3168 -#define MACH_TYPE_SUNFIRE 3169 -#define MACH_TYPE_AROWANA 3170 -#define MACH_TYPE_TEGRA_DAYTONA 3171 -#define MACH_TYPE_TEGRA_SWORDFISH 3172 -#define MACH_TYPE_EDISON 3173 -#define MACH_TYPE_SVP8500V1 3174 -#define MACH_TYPE_SVP8500V2 3175 -#define MACH_TYPE_SVP5500 3176 -#define MACH_TYPE_B5500 3177 -#define MACH_TYPE_S5500 3178 -#define MACH_TYPE_ICON 3179 -#define MACH_TYPE_ELEPHANT 3180 -#define MACH_TYPE_SHOOTER 3182 -#define MACH_TYPE_SPADE_LTE 3183 -#define MACH_TYPE_PHILHWANI 3184 -#define MACH_TYPE_GSNCOMM 3185 -#define MACH_TYPE_STRASBOURG_A2 3186 -#define MACH_TYPE_MMM 3187 -#define MACH_TYPE_DAVINCI_DM365_BV 3188 #define MACH_TYPE_AG5EVM 3189 -#define MACH_TYPE_SC575PLC 3190 -#define MACH_TYPE_SC575IPC 3191 -#define MACH_TYPE_OMAP3_TDM3730 3192 -#define MACH_TYPE_TOP9000_EVAL 3194 -#define MACH_TYPE_TOP9000_SU 3195 -#define MACH_TYPE_UTM300 3196 -#define MACH_TYPE_TSUNAGI 3197 -#define MACH_TYPE_TS75XX 3198 -#define MACH_TYPE_TS47XX 3200 -#define MACH_TYPE_DA850_K5 3201 -#define MACH_TYPE_AX502 3202 -#define MACH_TYPE_IGEP0032 3203 -#define MACH_TYPE_ANTERO 3204 -#define MACH_TYPE_SYNERGY 3205 #define MACH_TYPE_ICS_IF_VOIP 3206 #define MACH_TYPE_WLF_CRAGG_6410 3207 -#define MACH_TYPE_PUNICA 3208 #define MACH_TYPE_TRIMSLICE 3209 -#define MACH_TYPE_MX27_WMULTRA 3210 -#define MACH_TYPE_MACKEREL 3211 -#define MACH_TYPE_FA9X27 3213 -#define MACH_TYPE_NS2816TB 3214 -#define MACH_TYPE_NS2816_NTPAD 3215 -#define MACH_TYPE_NS2816_NTNB 3216 #define MACH_TYPE_KAEN 3217 -#define MACH_TYPE_NV1000 3218 -#define MACH_TYPE_NUC950TS 3219 #define MACH_TYPE_NOKIA_RM680 3220 -#define MACH_TYPE_AST2200 3221 -#define MACH_TYPE_LEAD 3222 -#define MACH_TYPE_UNINO1 3223 -#define MACH_TYPE_GREECO 3224 -#define MACH_TYPE_VERDI 3225 -#define MACH_TYPE_DM6446_ADBOX 3226 -#define MACH_TYPE_QUAD_SALSA 3227 -#define MACH_TYPE_ABB_GMA_1_1 3228 -#define MACH_TYPE_SVCID 3229 #define MACH_TYPE_MSM8960_SIM 3230 #define MACH_TYPE_MSM8960_RUMI3 3231 -#define MACH_TYPE_ICON_G 3232 -#define MACH_TYPE_MB3 3233 #define MACH_TYPE_GSIA18S 3234 -#define MACH_TYPE_PIVICC 3235 -#define MACH_TYPE_PCM048 3236 -#define MACH_TYPE_DDS 3237 -#define MACH_TYPE_CHALTEN_XA1 3238 -#define MACH_TYPE_TS48XX 3239 -#define MACH_TYPE_TONGA2_TFTTIMER 3240 -#define MACH_TYPE_WHISTLER 3241 -#define MACH_TYPE_ASL_PHOENIX 3242 -#define MACH_TYPE_AT91SAM9263OTLITE 3243 -#define MACH_TYPE_DDPLUG 3244 -#define MACH_TYPE_D2PLUG 3245 -#define MACH_TYPE_KZM9D 3246 -#define MACH_TYPE_VERDI_LTE 3247 -#define MACH_TYPE_NANOZOOM 3248 -#define MACH_TYPE_DM3730_SOM_LV 3249 -#define MACH_TYPE_DM3730_TORPEDO 3250 -#define MACH_TYPE_ANCHOVY 3251 -#define MACH_TYPE_RE2REV20 3253 -#define MACH_TYPE_RE2REV21 3254 -#define MACH_TYPE_CNS21XX 3255 -#define MACH_TYPE_RIDER 3257 -#define MACH_TYPE_NSK330 3258 -#define MACH_TYPE_CNS2133EVB 3259 -#define MACH_TYPE_Z3_816X_MOD 3260 -#define MACH_TYPE_Z3_814X_MOD 3261 -#define MACH_TYPE_BEECT 3262 -#define MACH_TYPE_DMA_THUNDERBUG 3263 -#define MACH_TYPE_OMN_AT91SAM9G20 3264 -#define MACH_TYPE_MX25_E2S_UC 3265 -#define MACH_TYPE_MIONE 3266 -#define MACH_TYPE_TOP9000_TCU 3267 -#define MACH_TYPE_TOP9000_BSL 3268 -#define MACH_TYPE_KINGDOM 3269 -#define MACH_TYPE_ARMADILLO460 3270 -#define MACH_TYPE_LQ2 3271 -#define MACH_TYPE_SWEDA_TMS2 3272 #define MACH_TYPE_MX53_LOCO 3273 -#define MACH_TYPE_ACER_A8 3275 -#define MACH_TYPE_ACER_GAUGUIN 3276 -#define MACH_TYPE_GUPPY 3277 -#define MACH_TYPE_MX61_ARD 3278 -#define MACH_TYPE_TX53 3279 -#define MACH_TYPE_OMAPL138_CASE_A3 3280 -#define MACH_TYPE_UEMD 3281 -#define MACH_TYPE_CCWMX51MUT 3282 -#define MACH_TYPE_ROCKHOPPER 3283 -#define MACH_TYPE_ENCORE 3284 -#define MACH_TYPE_HKDKC100 3285 -#define MACH_TYPE_TS42XX 3286 -#define MACH_TYPE_AEBL 3287 #define MACH_TYPE_WARIO 3288 -#define MACH_TYPE_GFS_SPM 3289 #define MACH_TYPE_CM_T3730 3290 -#define MACH_TYPE_ISC3 3291 -#define MACH_TYPE_RASCAL 3292 #define MACH_TYPE_HREFV60 3293 -#define MACH_TYPE_TPT_2_0 3294 -#define MACH_TYPE_SPLENDOR 3296 -#define MACH_TYPE_MSM8X60_QT 3298 -#define MACH_TYPE_HTC_HD_MINI 3299 -#define MACH_TYPE_ATHENE 3300 -#define MACH_TYPE_DEEP_R_EK_1 3301 -#define MACH_TYPE_VIVOW_CT 3302 -#define MACH_TYPE_NERY_1000 3303 -#define MACH_TYPE_RFL109145_SSRV 3304 -#define MACH_TYPE_NMH 3305 -#define MACH_TYPE_WN802T 3306 -#define MACH_TYPE_DRAGONET 3307 -#define MACH_TYPE_AT91SAM9263DESK16L 3309 -#define MACH_TYPE_BCMHANA_SV 3310 -#define MACH_TYPE_BCMHANA_TABLET 3311 -#define MACH_TYPE_KOI 3312 -#define MACH_TYPE_TS4800 3313 -#define MACH_TYPE_TQMA9263 3314 -#define MACH_TYPE_HOLIDAY 3315 -#define MACH_TYPE_DMA6410 3316 -#define MACH_TYPE_PCATS_OVERLAY 3317 -#define MACH_TYPE_HWGW6410 3318 -#define MACH_TYPE_SHENZHOU 3319 -#define MACH_TYPE_CWME9210 3320 -#define MACH_TYPE_CWME9210JS 3321 -#define MACH_TYPE_PGS_SITARA 3322 -#define MACH_TYPE_COLIBRI_T20 3323 -#define MACH_TYPE_W21 3324 -#define MACH_TYPE_POLYSAT1 3325 -#define MACH_TYPE_DATAWAY 3326 -#define MACH_TYPE_COBRAL138 3327 -#define MACH_TYPE_ROVERPCS8 3328 -#define MACH_TYPE_MARVELC 3329 -#define MACH_TYPE_NAVEFIHID 3330 -#define MACH_TYPE_DM365_CV100 3331 -#define MACH_TYPE_ABLE 3332 -#define MACH_TYPE_LEGACY 3333 -#define MACH_TYPE_ICONG 3334 -#define MACH_TYPE_ROVER_G8 3335 -#define MACH_TYPE_T5388P 3336 -#define MACH_TYPE_DINGO 3337 -#define MACH_TYPE_GOFLEXHOME 3338 -#define MACH_TYPE_LANREADYFN511 3340 -#define MACH_TYPE_OMAP3_BAIA 3341 -#define MACH_TYPE_OMAP3SMARTDISPLAY 3342 -#define MACH_TYPE_XILINX 3343 -#define MACH_TYPE_A2F 3344 -#define MACH_TYPE_SKY25 3345 -#define MACH_TYPE_CCMX53 3346 -#define MACH_TYPE_CCMX53JS 3347 -#define MACH_TYPE_CCWMX53 3348 -#define MACH_TYPE_CCWMX53JS 3349 -#define MACH_TYPE_FRISMS 3350 -#define MACH_TYPE_MSM7X27A_FFA 3351 -#define MACH_TYPE_MSM7X27A_SURF 3352 -#define MACH_TYPE_MSM7X27A_RUMI3 3353 -#define MACH_TYPE_DIMMSAM9G20 3354 -#define MACH_TYPE_DIMM_IMX28 3355 -#define MACH_TYPE_AMK_A4 3356 -#define MACH_TYPE_GNET_SGME 3357 -#define MACH_TYPE_SHOOTER_U 3358 -#define MACH_TYPE_VMX53 3359 -#define MACH_TYPE_RHINO 3360 #define MACH_TYPE_ARMLEX4210 3361 -#define MACH_TYPE_SWARCOEXTMODEM 3362 -#define MACH_TYPE_PCM049 3364 -#define MACH_TYPE_VIGOR 3365 -#define MACH_TYPE_OSLO_AMUNDSEN 3366 -#define MACH_TYPE_GSL_DIAMOND 3367 -#define MACH_TYPE_CV2201 3368 -#define MACH_TYPE_CV2202 3369 -#define MACH_TYPE_CV2203 3370 -#define MACH_TYPE_VIT_IBOX 3371 -#define MACH_TYPE_DM6441_ESP 3372 -#define MACH_TYPE_AT91SAM9X5EK 3373 -#define MACH_TYPE_LIBRA 3374 -#define MACH_TYPE_EASYCRRH 3375 -#define MACH_TYPE_TRIPEL 3376 -#define MACH_TYPE_ENDIAN_MINI 3377 +#define MACH_TYPE_SNOWBALL 3363 #define MACH_TYPE_XILINX_EP107 3378 #define MACH_TYPE_NURI 3379 -#define MACH_TYPE_JANUS 3380 -#define MACH_TYPE_DDNAS 3381 -#define MACH_TYPE_TAG 3382 -#define MACH_TYPE_TAGW 3383 -#define MACH_TYPE_NITROGEN_VM_IMX51 3384 -#define MACH_TYPE_VIPRINET 3385 -#define MACH_TYPE_BOCKW 3386 -#define MACH_TYPE_EVA2000 3387 -#define MACH_TYPE_STEELYARD 3388 -#define MACH_TYPE_MACH_SDH001 3390 -#define MACH_TYPE_NSSLSBOARD 3392 -#define MACH_TYPE_GENEVA_B5 3393 -#define MACH_TYPE_SPEAR1340 3394 -#define MACH_TYPE_REXMAS 3395 -#define MACH_TYPE_MSM8960_CDP 3396 -#define MACH_TYPE_MSM8960_MDP 3397 -#define MACH_TYPE_MSM8960_FLUID 3398 -#define MACH_TYPE_MSM8960_APQ 3399 -#define MACH_TYPE_HELIOS_V2 3400 -#define MACH_TYPE_MIF10P 3401 -#define MACH_TYPE_IAM28 3402 -#define MACH_TYPE_PICASSO 3403 -#define MACH_TYPE_MR301A 3404 -#define MACH_TYPE_NOTLE 3405 -#define MACH_TYPE_EELX2 3406 -#define MACH_TYPE_MOON 3407 -#define MACH_TYPE_RUBY 3408 -#define MACH_TYPE_GOLDENGATE 3409 -#define MACH_TYPE_CTBU_GEN2 3410 -#define MACH_TYPE_KMP_AM17_01 3411 -#define MACH_TYPE_WTPLUG 3412 -#define MACH_TYPE_MX27SU2 3413 -#define MACH_TYPE_NB31 3414 -#define MACH_TYPE_HJSDU 3415 -#define MACH_TYPE_TD3_REV1 3416 -#define MACH_TYPE_EAG_CI4000 3417 -#define MACH_TYPE_NET5BIG_NAND_V2 3418 -#define MACH_TYPE_CPX2 3419 -#define MACH_TYPE_NET2BIG_NAND_V2 3420 -#define MACH_TYPE_ECUV5 3421 -#define MACH_TYPE_HSGX6D 3422 -#define MACH_TYPE_DAWAD7 3423 -#define MACH_TYPE_SAM9REPEATER 3424 -#define MACH_TYPE_GT_I5700 3425 -#define MACH_TYPE_CTERA_PLUG_C2 3426 -#define MACH_TYPE_MARVELCT 3427 -#define MACH_TYPE_AG11005 3428 -#define MACH_TYPE_VANGOGH 3430 -#define MACH_TYPE_MATRIX505 3431 -#define MACH_TYPE_OCE_NIGMA 3432 -#define MACH_TYPE_T55 3433 -#define MACH_TYPE_BIO3K 3434 -#define MACH_TYPE_EXPRESSCT 3435 -#define MACH_TYPE_CARDHU 3436 -#define MACH_TYPE_ARUBA 3437 -#define MACH_TYPE_BONAIRE 3438 -#define MACH_TYPE_NUC700EVB 3439 -#define MACH_TYPE_NUC710EVB 3440 -#define MACH_TYPE_NUC740EVB 3441 -#define MACH_TYPE_NUC745EVB 3442 -#define MACH_TYPE_TRANSCEDE 3443 -#define MACH_TYPE_MORA 3444 -#define MACH_TYPE_NDA_EVM 3445 -#define MACH_TYPE_TIMU 3446 -#define MACH_TYPE_EXPRESSH 3447 -#define MACH_TYPE_VERIDIS_A300 3448 -#define MACH_TYPE_DM368_LEOPARD 3449 -#define MACH_TYPE_OMAP_MCOP 3450 -#define MACH_TYPE_TRITIP 3451 -#define MACH_TYPE_SM1K 3452 -#define MACH_TYPE_MONCH 3453 -#define MACH_TYPE_CURACAO 3454 #define MACH_TYPE_ORIGEN 3455 -#define MACH_TYPE_EPC10 3456 -#define MACH_TYPE_SGH_I740 3457 -#define MACH_TYPE_TUNA 3458 -#define MACH_TYPE_MX51_TULIP 3459 -#define MACH_TYPE_MX51_ASTER7 3460 -#define MACH_TYPE_ACRO37XBRD 3461 -#define MACH_TYPE_ELKE 3462 -#define MACH_TYPE_SBC6000X 3463 -#define MACH_TYPE_R1801E 3464 -#define MACH_TYPE_H1600 3465 -#define MACH_TYPE_MINI210 3466 -#define MACH_TYPE_MINI8168 3467 -#define MACH_TYPE_PC7308 3468 -#define MACH_TYPE_KMM2M01 3470 -#define MACH_TYPE_MX51EREBUS 3471 -#define MACH_TYPE_WM8650REFBOARD 3472 -#define MACH_TYPE_TUXRAIL 3473 -#define MACH_TYPE_ARTHUR 3474 -#define MACH_TYPE_DOORBOY 3475 -#define MACH_TYPE_XARINA 3476 -#define MACH_TYPE_ROVERX7 3477 -#define MACH_TYPE_SDVR 3478 -#define MACH_TYPE_ACER_MAYA 3479 -#define MACH_TYPE_PICO 3480 -#define MACH_TYPE_CWMX233 3481 -#define MACH_TYPE_CWAM1808 3482 -#define MACH_TYPE_CWDM365 3483 -#define MACH_TYPE_MX51_MORAY 3484 -#define MACH_TYPE_THALES_CBC 3485 -#define MACH_TYPE_BLUEPOINT 3486 -#define MACH_TYPE_DIR665 3487 -#define MACH_TYPE_ACMEROVER1 3488 -#define MACH_TYPE_SHOOTER_CT 3489 -#define MACH_TYPE_BLISS 3490 -#define MACH_TYPE_BLISSC 3491 -#define MACH_TYPE_THALES_ADC 3492 -#define MACH_TYPE_UBISYS_P9D_EVP 3493 -#define MACH_TYPE_ATDGP318 3494 -#define MACH_TYPE_OMAP5_SEVM 3777 -#define MACH_TYPE_PICOSAM9G45 3838 -#define MACH_TYPE_ARMADILLO_800EVA 3863 +#define MACH_TYPE_NSPIRE 3503 +#define MACH_TYPE_NOKIA_RM696 3522 +#define MACH_TYPE_MIKRAP_X168 3543 +#define MACH_TYPE_DETO_MACARM9 3568 +#define MACH_TYPE_M28EVK 3613 +#define MACH_TYPE_KOTA2 3616 +#define MACH_TYPE_BONITO 3623 +#define MACH_TYPE_OMAP3_EGF 3637 +#define MACH_TYPE_SMDK4212 3638 +#define MACH_TYPE_APX4DEVKIT 3712 +#define MACH_TYPE_SMDK4412 3765 +#define MACH_TYPE_MARZEN 3790 +#define MACH_TYPE_KROME 3797 +#define MACH_TYPE_ARMADILLO800EVA 3863 +#define MACH_TYPE_MX53_UMOBO 3927 +#define MACH_TYPE_MT4 3981 +#define MACH_TYPE_U8520 3990 +#define MACH_TYPE_CHUPACABRA 4098 +#define MACH_TYPE_SCORPION 4099 +#define MACH_TYPE_DAVINCI_HE_HMI10 4100 +#define MACH_TYPE_TOPKICK 4101 +#define MACH_TYPE_M3_AUGUESTRUSH 4102 +#define MACH_TYPE_IPC335X 4103 +#define MACH_TYPE_SUN4I 4104 +#define MACH_TYPE_IMX233_OLINUXINO 4105 +#define MACH_TYPE_K2_WL 4106 +#define MACH_TYPE_K2_UL 4107 +#define MACH_TYPE_K2_CL 4108 +#define MACH_TYPE_MINBARI_W 4109 +#define MACH_TYPE_MINBARI_M 4110 +#define MACH_TYPE_K035 4111 +#define MACH_TYPE_ARIEL 4112 +#define MACH_TYPE_ARIELSAARC 4113 +#define MACH_TYPE_ARIELDKB 4114 +#define MACH_TYPE_ARMADILLO810 4115 +#define MACH_TYPE_TAM335X 4116 +#define MACH_TYPE_GROUPER 4117 +#define MACH_TYPE_MPCSA21_9G20 4118 +#define MACH_TYPE_M6U_CPU 4119 +#define MACH_TYPE_GINKGO 4121 +#define MACH_TYPE_CGT_QMX6 4122 +#define MACH_TYPE_PROFPGA 4123 +#define MACH_TYPE_ACFX100OC 4124 +#define MACH_TYPE_ACFX100NB 4125 +#define MACH_TYPE_CAPRICORN 4126 +#define MACH_TYPE_PISCES 4127 +#define MACH_TYPE_ARIES 4128 +#define MACH_TYPE_CANCER 4129 +#define MACH_TYPE_LEO 4130 +#define MACH_TYPE_VIRGO 4131 +#define MACH_TYPE_SAGITTARIUS 4132 +#define MACH_TYPE_DEVIL 4133 +#define MACH_TYPE_BALLANTINES 4134 +#define MACH_TYPE_OMAP3_PROCERUSVPU 4135 +#define MACH_TYPE_MY27 4136 +#define MACH_TYPE_SUN6I 4137 +#define MACH_TYPE_SUN5I 4138 +#define MACH_TYPE_MX512_MX 4139 #define MACH_TYPE_KZM9G 4140 +#define MACH_TYPE_VDSTBN 4141 +#define MACH_TYPE_CFA10036 4142 +#define MACH_TYPE_CFA10049 4143 +#define MACH_TYPE_PCM051 4144 +#define MACH_TYPE_VYBRID_VF7XX 4145 +#define MACH_TYPE_VYBRID_VF6XX 4146 +#define MACH_TYPE_VYBRID_VF5XX 4147 +#define MACH_TYPE_VYBRID_VF4XX 4148 +#define MACH_TYPE_ARIA_G25 4149 +#define MACH_TYPE_BCM21553 4150 +#define MACH_TYPE_SMDK5410 4151 +#define MACH_TYPE_LPC18XX 4152 +#define MACH_TYPE_ORATISPARTY 4153 +#define MACH_TYPE_QSEVEN 4154 +#define MACH_TYPE_GMV_GENERIC 4155 +#define MACH_TYPE_TH_LINK_ETH 4156 +#define MACH_TYPE_TN_MUNINN 4157 +#define MACH_TYPE_RAMPAGE 4158 +#define MACH_TYPE_VISSTRIM_MV10 4159 +#define MACH_TYPE_MX28_WILMA 4164 +#define MACH_TYPE_MSM8625_FFA 4166 +#define MACH_TYPE_VPU101 4167 +#define MACH_TYPE_BAILEYS 4169 +#define MACH_TYPE_FAMILYBOX 4170 +#define MACH_TYPE_ENSEMBLE_MX35 4171 +#define MACH_TYPE_SC_SPS_1 4172 +#define MACH_TYPE_UCSIMPLY_SAM9260 4173 +#define MACH_TYPE_UNICORN 4174 +#define MACH_TYPE_M9G45A 4175 +#define MACH_TYPE_MTWEBIF 4176 +#define MACH_TYPE_PLAYSTONE 4177 +#define MACH_TYPE_CHELSEA 4178 +#define MACH_TYPE_BAYERN 4179 +#define MACH_TYPE_MITWO 4180 +#define MACH_TYPE_MX25_NOAH 4181 +#define MACH_TYPE_STM_B2020 4182 +#define MACH_TYPE_ANNAX_SRC 4183 +#define MACH_TYPE_IONICS_STRATUS 4184 +#define MACH_TYPE_HUGO 4185 +#define MACH_TYPE_EM300 4186 +#define MACH_TYPE_MMP3_QSEVEN 4187 +#define MACH_TYPE_BOSPHORUS2 4188 +#define MACH_TYPE_TT2200 4189 +#define MACH_TYPE_OCELOT3 4190 +#define MACH_TYPE_TEK_COBRA 4191 +#define MACH_TYPE_PROTOU 4192 +#define MACH_TYPE_MSM8625_EVT 4193 +#define MACH_TYPE_MX53_SELLWOOD 4194 +#define MACH_TYPE_SOMIQ_AM35 4195 +#define MACH_TYPE_SOMIQ_AM37 4196 +#define MACH_TYPE_K2_PLC_CL 4197 +#define MACH_TYPE_TC2 4198 +#define MACH_TYPE_DULEX_J 4199 +#define MACH_TYPE_STM_B2044 4200 +#define MACH_TYPE_DELUXE_J 4201 +#define MACH_TYPE_MANGO2443 4202 +#define MACH_TYPE_CP2DCG 4203 +#define MACH_TYPE_CP2DTG 4204 +#define MACH_TYPE_CP2DUG 4205 +#define MACH_TYPE_VAR_SOM_AM33 4206 +#define MACH_TYPE_PEPPER 4207 +#define MACH_TYPE_MANGO2450 4208 +#define MACH_TYPE_VALENTE_WX_C9 4209 +#define MACH_TYPE_MINITV 4210 +#define MACH_TYPE_U8540 4211 +#define MACH_TYPE_IV_ATLAS_I_Z7E 4212 +#define MACH_TYPE_MACH_TYPE_SKY 4214 +#define MACH_TYPE_BLUESKY 4215 +#define MACH_TYPE_NGROUTER 4216 +#define MACH_TYPE_MX53_DENETIM 4217 +#define MACH_TYPE_OPAL 4218 +#define MACH_TYPE_GNET_US3GREF 4219 +#define MACH_TYPE_GNET_NC3G 4220 +#define MACH_TYPE_GNET_GE3G 4221 +#define MACH_TYPE_ADP2 4222 +#define MACH_TYPE_TQMA28 4223 +#define MACH_TYPE_KACOM3 4224 +#define MACH_TYPE_RRHDEMO 4225 +#define MACH_TYPE_PROTODUG 4226 +#define MACH_TYPE_LAGO 4227 +#define MACH_TYPE_KTT30 4228 +#define MACH_TYPE_TS43XX 4229 +#define MACH_TYPE_MX6Q_DENSO 4230 +#define MACH_TYPE_COMSAT_GSMUMTS8 4231 +#define MACH_TYPE_DREAMX 4232 +#define MACH_TYPE_THUNDERSTONEM 4233 +#define MACH_TYPE_YOYOPAD 4234 +#define MACH_TYPE_YOYOPATIENT 4235 +#define MACH_TYPE_A10L 4236 +#define MACH_TYPE_MQ60 4237 +#define MACH_TYPE_LINKSTATION_LSQL 4238 +#define MACH_TYPE_AM3703GATEWAY 4239 +#define MACH_TYPE_ACCIPITER 4240 +#define MACH_TYPE_MAGNIDUG 4242 +#define MACH_TYPE_HYDRA 4243 +#define MACH_TYPE_SUN3I 4244 +#define MACH_TYPE_STM_B2078 4245 +#define MACH_TYPE_AT91SAM9263DESKV2 4246 +#define MACH_TYPE_DELUXE_R 4247 +#define MACH_TYPE_P_98_V 4248 +#define MACH_TYPE_P_98_C 4249 +#define MACH_TYPE_DAVINCI_AM18XX_OMN 4250 +#define MACH_TYPE_SOCFPGA_CYCLONE5 4251 +#define MACH_TYPE_CABATUIN 4252 +#define MACH_TYPE_YOYOPAD_FT 4253 +#define MACH_TYPE_DAN2400EVB 4254 +#define MACH_TYPE_DAN3400EVB 4255 +#define MACH_TYPE_EDM_SF_IMX6 4256 +#define MACH_TYPE_EDM_CF_IMX6 4257 +#define MACH_TYPE_VPOS3XX 4258 +#define MACH_TYPE_VULCANO_9X5 4259 +#define MACH_TYPE_SPMP8000 4260 +#define MACH_TYPE_CATALINA 4261 +#define MACH_TYPE_RD88F5181L_FE 4262 +#define MACH_TYPE_MX535_MX 4263 +#define MACH_TYPE_ARMADILLO840 4264 +#define MACH_TYPE_SPC9000BASEBOARD 4265 +#define MACH_TYPE_IRIS 4266 +#define MACH_TYPE_PROTODCG 4267 +#define MACH_TYPE_PALMTREE 4268 +#define MACH_TYPE_NOVENA 4269 +#define MACH_TYPE_MA_UM 4270 +#define MACH_TYPE_MA_AM 4271 +#define MACH_TYPE_EMS348 4272 +#define MACH_TYPE_CM_FX6 4273 +#define MACH_TYPE_ARNDALE 4274 +#define MACH_TYPE_Q5XR5 4275 +#define MACH_TYPE_WILLOW 4276 +#define MACH_TYPE_OMAP3621_ODYV3 4277 +#define MACH_TYPE_OMAPL138_PRESONUS 4278 +#define MACH_TYPE_DVF99 4279 +#define MACH_TYPE_IMPRESSION_J 4280 +#define MACH_TYPE_QBLISSA9 4281 +#define MACH_TYPE_ROBIN_HELIVIEW10 4282 +#define MACH_TYPE_SUN7I 4283 +#define MACH_TYPE_MX6Q_HDMIDONGLE 4284 +#define MACH_TYPE_MX6_SID2 4285 +#define MACH_TYPE_HELIOS_V3 4286 +#define MACH_TYPE_HELIOS_V4 4287 +#define MACH_TYPE_Q7_IMX6 4288 +#define MACH_TYPE_ODROIDX 4289 +#define MACH_TYPE_ROBPRO 4290 +#define MACH_TYPE_RESEARCH59IF_MK1 4291 +#define MACH_TYPE_BOBSLEIGH 4292 +#define MACH_TYPE_DCSHGWT3 4293 +#define MACH_TYPE_GLD1018 4294 +#define MACH_TYPE_EV10 4295 +#define MACH_TYPE_NITROGEN6X 4296 +#define MACH_TYPE_P_107_BB 4297 +#define MACH_TYPE_EVITA_UTL 4298 +#define MACH_TYPE_FALCONWING 4299 +#define MACH_TYPE_DCT3 4300 +#define MACH_TYPE_CPX2E_CELL 4301 +#define MACH_TYPE_AMIRO 4302 +#define MACH_TYPE_MX6Q_BRASSBOARD 4303 +#define MACH_TYPE_DALMORE 4304 +#define MACH_TYPE_OMAP3_PORTAL7CP 4305 +#define MACH_TYPE_TEGRA_PLUTO 4306 +#define MACH_TYPE_MX6SL_EVK 4307 +#define MACH_TYPE_M7 4308 +#define MACH_TYPE_PXM2 4309 +#define MACH_TYPE_HABA_KNX_LITE 4310 +#define MACH_TYPE_TAI 4311 +#define MACH_TYPE_PROTOTD 4312 +#define MACH_TYPE_DST_TONTO 4313 +#define MACH_TYPE_DRACO 4314 +#define MACH_TYPE_DXR2 4315 +#define MACH_TYPE_RUT 4316 +#define MACH_TYPE_AM180X_WSC 4317 +#define MACH_TYPE_DELUXE_U 4318 +#define MACH_TYPE_DELUXE_UL 4319 +#define MACH_TYPE_AT91SAM9260MEDTHS 4320 +#define MACH_TYPE_MATRIX516 4321 +#define MACH_TYPE_VID401X 4322 +#define MACH_TYPE_HELIOS_V5 4323 +#define MACH_TYPE_PLAYPAQ2 4324 +#define MACH_TYPE_IGAM 4325 +#define MACH_TYPE_AMICO_I 4326 +#define MACH_TYPE_AMICO_E 4327 +#define MACH_TYPE_SENTIENT_MM3_CK 4328 +#define MACH_TYPE_SMX6 4329 +#define MACH_TYPE_PANGO 4330 +#define MACH_TYPE_NS115_STICK 4331 +#define MACH_TYPE_BCTRM3 4332 +#define MACH_TYPE_DOCTORWS 4333 +#define MACH_TYPE_M2601 4334 +#define MACH_TYPE_VGG1111 4337 +#define MACH_TYPE_COUNTACH 4338 +#define MACH_TYPE_VISSTRIM_SM20 4339 +#define MACH_TYPE_A639 4340 +#define MACH_TYPE_SPACEMONKEY 4341 +#define MACH_TYPE_ZPDU_STAMP 4342 +#define MACH_TYPE_HTC_G7_CLONE 4343 +#define MACH_TYPE_FT2080_CORVUS 4344 +#define MACH_TYPE_FISLAND 4345 +#define MACH_TYPE_ZPDU 4346 +#define MACH_TYPE_URT 4347 +#define MACH_TYPE_CONTI_OVIP 4348 +#define MACH_TYPE_OMAPL138_NAGRA 4349 +#define MACH_TYPE_DA850_AT3KP1 4350 +#define MACH_TYPE_DA850_AT3KP2 4351 +#define MACH_TYPE_SURMA 4352 +#define MACH_TYPE_STM_B2092 4353 +#define MACH_TYPE_MX535_YCR 4354 +#define MACH_TYPE_M7_WL 4355 +#define MACH_TYPE_M7_U 4356 +#define MACH_TYPE_OMAP3_STNDT_EVM 4357 +#define MACH_TYPE_M7_WLV 4358 +#define MACH_TYPE_XAM3517 4359 +#define MACH_TYPE_A220 4360 +#define MACH_TYPE_ACLIMA_ODIE 4361 +#define MACH_TYPE_VIBBLE 4362 +#define MACH_TYPE_K2_U 4363 +#define MACH_TYPE_MX53_EGF 4364 +#define MACH_TYPE_NOVPEK_IMX53 4365 +#define MACH_TYPE_NOVPEK_IMX6X 4366 +#define MACH_TYPE_MX25_SMARTBOX 4367 +#define MACH_TYPE_EICG6410 4368 +#define MACH_TYPE_PICASSO_E3 4369 +#define MACH_TYPE_MOTONAVIGATOR 4370 +#define MACH_TYPE_VARIOCONNECT2 4371 +#define MACH_TYPE_DELUXE_TW 4372 +#define MACH_TYPE_KORE3 4374 +#define MACH_TYPE_MX6S_DRS 4375 +#define MACH_TYPE_CMIMX6 4376 +#define MACH_TYPE_ROTH 4377 +#define MACH_TYPE_EQ4UX 4378 +#define MACH_TYPE_X1PLUS 4379 +#define MACH_TYPE_MODIMX27 4380 +#define MACH_TYPE_VIDEON_HDUAC 4381 +#define MACH_TYPE_BLACKBIRD 4382 +#define MACH_TYPE_RUNMASTER 4383 +#define MACH_TYPE_CERES 4384 +#define MACH_TYPE_NAD435 4385 +#define MACH_TYPE_NS115_PROTO_TYPE 4386 +#define MACH_TYPE_FS20_VCC 4387 +#define MACH_TYPE_MESON6TV_SKT 4389 +#define MACH_TYPE_KEYSTONE 4390 +#define MACH_TYPE_PCM052 4391 +#define MACH_TYPE_QRD_SKUD_PRIME 4393 +#define MACH_TYPE_GUF_SANTARO 4395 +#define MACH_TYPE_SHEEPSHEAD 4396 +#define MACH_TYPE_MX6_IWG15M_MXM 4397 +#define MACH_TYPE_MX6_IWG15M_Q7 4398 +#define MACH_TYPE_AT91SAM9263IF8MIC 4399 +#define MACH_TYPE_MARCOPOLO 4401 +#define MACH_TYPE_MX535_SDCR 4402 +#define MACH_TYPE_MX53_CSB2733 4403 +#define MACH_TYPE_DIVA 4404 +#define MACH_TYPE_NCR_7744 4405 +#define MACH_TYPE_MACALLAN 4406 +#define MACH_TYPE_WNR3500 4407 +#define MACH_TYPE_PGAVRF 4408 +#define MACH_TYPE_HELIOS_V6 4409 +#define MACH_TYPE_LCCT 4410 +#define MACH_TYPE_CSNDUG 4411 +#define MACH_TYPE_WANDBOARD_IMX6 4412 +#define MACH_TYPE_OMAP4_JET 4413 +#define MACH_TYPE_TEGRA_ROTH 4414 +#define MACH_TYPE_M7DCG 4415 +#define MACH_TYPE_M7DUG 4416 +#define MACH_TYPE_M7DTG 4417 +#define MACH_TYPE_AP42X 4418 +#define MACH_TYPE_VAR_SOM_MX6 4419 +#define MACH_TYPE_PDLU 4420 +#define MACH_TYPE_HYDROGEN 4421 +#define MACH_TYPE_NPA211E 4422 +#define MACH_TYPE_ARCADIA 4423 +#define MACH_TYPE_ARCADIA_L 4424 +#define MACH_TYPE_MSM8930DT 4425 +#define MACH_TYPE_KTAM3874 4426 +#define MACH_TYPE_CEC4 4427 +#define MACH_TYPE_APE6EVM 4428 +#define MACH_TYPE_TX6 4429 +#define MACH_TYPE_CFA10037 4431 +#define MACH_TYPE_EZP1000 4433 +#define MACH_TYPE_WGR826V 4434 +#define MACH_TYPE_EXUMA 4435 +#define MACH_TYPE_FREGATE 4436 +#define MACH_TYPE_OSIRISIMX508 4437 +#define MACH_TYPE_ST_EXIGO 4438 +#define MACH_TYPE_PISMO 4439 +#define MACH_TYPE_ATC7 4440 +#define MACH_TYPE_NSPIRECLP 4441 +#define MACH_TYPE_NSPIRETP 4442 +#define MACH_TYPE_NSPIRECX 4443 +#define MACH_TYPE_MAYA 4444 +#define MACH_TYPE_WECCT 4445 +#define MACH_TYPE_M2S 4446 +#define MACH_TYPE_MSM8625Q_EVBD 4447 +#define MACH_TYPE_TINY210 4448 +#define MACH_TYPE_G3 4449 +#define MACH_TYPE_HURRICANE 4450 +#define MACH_TYPE_MX6_POD 4451 +#define MACH_TYPE_ELONDCN 4452 +#define MACH_TYPE_CWMX535 4453 +#define MACH_TYPE_M7_WLJ 4454 +#define MACH_TYPE_QSP_ARM 4455 +#define MACH_TYPE_MSM8625Q_SKUD 4456 +#define MACH_TYPE_HTCMONDRIAN 4457 +#define MACH_TYPE_WATSON_EAD 4458 +#define MACH_TYPE_MITWOA 4459 +#define MACH_TYPE_OMAP3_WOLVERINE 4460 +#define MACH_TYPE_MAPLETREE 4461 +#define MACH_TYPE_MSM8625_FIH_SAE 4462 +#define MACH_TYPE_EPC35 4463 +#define MACH_TYPE_SMARTRTU 4464 +#define MACH_TYPE_RCM101 4465 +#define MACH_TYPE_AMX_IMX53_MXX 4466 +#define MACH_TYPE_ACER_A12 4470 +#define MACH_TYPE_SBC6X 4471 +#define MACH_TYPE_U2 4472 +#define MACH_TYPE_SMDK4270 4473 +#define MACH_TYPE_PRISCILLAG 4474 +#define MACH_TYPE_PRISCILLAC 4475 +#define MACH_TYPE_PRISCILLA 4476 +#define MACH_TYPE_INNOVA_SHPU_V2 4477 +#define MACH_TYPE_MACH_TYPE_DEP2410 4479 +#define MACH_TYPE_BCTRE3 4480 +#define MACH_TYPE_OMAP_M100 4481 +#define MACH_TYPE_FLO 4482 +#define MACH_TYPE_NANOBONE 4483 +#define MACH_TYPE_STM_B2105 4484 +#define MACH_TYPE_OMAP4_BSC_BAP_V3 4485 +#define MACH_TYPE_SS1PAM 4486 +#define MACH_TYPE_PRIMOMINIU 4488 +#define MACH_TYPE_MRT_35HD_DUALNAS_E 4489 +#define MACH_TYPE_KIWI 4490 +#define MACH_TYPE_HW90496 4491 +#define MACH_TYPE_MEP2440 4492 #define MACH_TYPE_COLIBRI_T30 4493 +#define MACH_TYPE_CWV1 4494 +#define MACH_TYPE_NSA325 4495 +#define MACH_TYPE_DPXMTC 4497 +#define MACH_TYPE_TT_STUTTGART 4498 +#define MACH_TYPE_MIRANDA_APCII 4499 +#define MACH_TYPE_MX6Q_MODEROX 4500 +#define MACH_TYPE_MUDSKIPPER 4501 +#define MACH_TYPE_URANIA 4502 +#define MACH_TYPE_STM_B2112 4503 +#define MACH_TYPE_MX6Q_ATS_PHOENIX 4505 +#define MACH_TYPE_STM_B2116 4506 +#define MACH_TYPE_MYTHOLOGY 4507 +#define MACH_TYPE_FC360V1 4508 +#define MACH_TYPE_GPS_SENSOR 4509 +#define MACH_TYPE_GAZELLE 4510 +#define MACH_TYPE_MPQ8064_DMA 4511 +#define MACH_TYPE_WEMS_ASD01 4512 #define MACH_TYPE_APALIS_T30 4513 -#define MACH_TYPE_OMAPL138_LCDK 2495 - -#ifdef CONFIG_ARCH_EBSA110 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_EBSA110 -# endif -# define machine_is_ebsa110() (machine_arch_type == MACH_TYPE_EBSA110) -#else -# define machine_is_ebsa110() (0) -#endif - -#ifdef CONFIG_ARCH_RPC -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_RISCPC -# endif -# define machine_is_riscpc() (machine_arch_type == MACH_TYPE_RISCPC) -#else -# define machine_is_riscpc() (0) -#endif - -#ifdef CONFIG_ARCH_EBSA285 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_EBSA285 -# endif -# define machine_is_ebsa285() (machine_arch_type == MACH_TYPE_EBSA285) -#else -# define machine_is_ebsa285() (0) -#endif - -#ifdef CONFIG_ARCH_NETWINDER -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NETWINDER -# endif -# define machine_is_netwinder() (machine_arch_type == MACH_TYPE_NETWINDER) -#else -# define machine_is_netwinder() (0) -#endif - -#ifdef CONFIG_ARCH_CATS -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CATS -# endif -# define machine_is_cats() (machine_arch_type == MACH_TYPE_CATS) -#else -# define machine_is_cats() (0) -#endif - -#ifdef CONFIG_ARCH_SHARK -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SHARK -# endif -# define machine_is_shark() (machine_arch_type == MACH_TYPE_SHARK) -#else -# define machine_is_shark() (0) -#endif - -#ifdef CONFIG_SA1100_BRUTUS -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_BRUTUS -# endif -# define machine_is_brutus() (machine_arch_type == MACH_TYPE_BRUTUS) -#else -# define machine_is_brutus() (0) -#endif - -#ifdef CONFIG_ARCH_PERSONAL_SERVER -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_PERSONAL_SERVER -# endif -# define machine_is_personal_server() (machine_arch_type == MACH_TYPE_PERSONAL_SERVER) -#else -# define machine_is_personal_server() (0) -#endif - -#ifdef CONFIG_ARCH_L7200 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_L7200 -# endif -# define machine_is_l7200() (machine_arch_type == MACH_TYPE_L7200) -#else -# define machine_is_l7200() (0) -#endif - -#ifdef CONFIG_SA1100_PLEB -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_PLEB -# endif -# define machine_is_pleb() (machine_arch_type == MACH_TYPE_PLEB) -#else -# define machine_is_pleb() (0) -#endif - -#ifdef CONFIG_ARCH_INTEGRATOR -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_INTEGRATOR -# endif -# define machine_is_integrator() (machine_arch_type == MACH_TYPE_INTEGRATOR) -#else -# define machine_is_integrator() (0) -#endif - -#ifdef CONFIG_SA1100_H3600 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_H3600 -# endif -# define machine_is_h3600() (machine_arch_type == MACH_TYPE_H3600) -#else -# define machine_is_h3600() (0) -#endif - -#ifdef CONFIG_ARCH_P720T -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_P720T -# endif -# define machine_is_p720t() (machine_arch_type == MACH_TYPE_P720T) -#else -# define machine_is_p720t() (0) -#endif - -#ifdef CONFIG_SA1100_ASSABET -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ASSABET -# endif -# define machine_is_assabet() (machine_arch_type == MACH_TYPE_ASSABET) -#else -# define machine_is_assabet() (0) -#endif - -#ifdef CONFIG_SA1100_LART -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_LART -# endif -# define machine_is_lart() (machine_arch_type == MACH_TYPE_LART) -#else -# define machine_is_lart() (0) -#endif - -#ifdef CONFIG_SA1100_GRAPHICSCLIENT -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_GRAPHICSCLIENT -# endif -# define machine_is_graphicsclient() (machine_arch_type == MACH_TYPE_GRAPHICSCLIENT) -#else -# define machine_is_graphicsclient() (0) -#endif - -#ifdef CONFIG_SA1100_XP860 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_XP860 -# endif -# define machine_is_xp860() (machine_arch_type == MACH_TYPE_XP860) -#else -# define machine_is_xp860() (0) -#endif - -#ifdef CONFIG_SA1100_CERF -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CERF -# endif -# define machine_is_cerf() (machine_arch_type == MACH_TYPE_CERF) -#else -# define machine_is_cerf() (0) -#endif - -#ifdef CONFIG_SA1100_NANOENGINE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NANOENGINE -# endif -# define machine_is_nanoengine() (machine_arch_type == MACH_TYPE_NANOENGINE) -#else -# define machine_is_nanoengine() (0) -#endif - -#ifdef CONFIG_SA1100_JORNADA720 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_JORNADA720 -# endif -# define machine_is_jornada720() (machine_arch_type == MACH_TYPE_JORNADA720) -#else -# define machine_is_jornada720() (0) -#endif - -#ifdef CONFIG_ARCH_EDB7211 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_EDB7211 -# endif -# define machine_is_edb7211() (machine_arch_type == MACH_TYPE_EDB7211) -#else -# define machine_is_edb7211() (0) -#endif - -#ifdef CONFIG_SA1100_PFS168 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_PFS168 -# endif -# define machine_is_pfs168() (machine_arch_type == MACH_TYPE_PFS168) -#else -# define machine_is_pfs168() (0) -#endif - -#ifdef CONFIG_SA1100_FLEXANET -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_FLEXANET -# endif -# define machine_is_flexanet() (machine_arch_type == MACH_TYPE_FLEXANET) -#else -# define machine_is_flexanet() (0) -#endif - -#ifdef CONFIG_SA1100_SIMPAD -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SIMPAD -# endif -# define machine_is_simpad() (machine_arch_type == MACH_TYPE_SIMPAD) -#else -# define machine_is_simpad() (0) -#endif - -#ifdef CONFIG_ARCH_LUBBOCK -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_LUBBOCK -# endif -# define machine_is_lubbock() (machine_arch_type == MACH_TYPE_LUBBOCK) -#else -# define machine_is_lubbock() (0) -#endif - -#ifdef CONFIG_ARCH_CLEP7212 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CLEP7212 -# endif -# define machine_is_clep7212() (machine_arch_type == MACH_TYPE_CLEP7212) -#else -# define machine_is_clep7212() (0) -#endif - -#ifdef CONFIG_SA1100_SHANNON -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SHANNON -# endif -# define machine_is_shannon() (machine_arch_type == MACH_TYPE_SHANNON) -#else -# define machine_is_shannon() (0) -#endif - -#ifdef CONFIG_SA1100_CONSUS -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CONSUS -# endif -# define machine_is_consus() (machine_arch_type == MACH_TYPE_CONSUS) -#else -# define machine_is_consus() (0) -#endif - -#ifdef CONFIG_ARCH_AAED2000 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_AAED2000 -# endif -# define machine_is_aaed2000() (machine_arch_type == MACH_TYPE_AAED2000) -#else -# define machine_is_aaed2000() (0) -#endif - -#ifdef CONFIG_ARCH_CDB89712 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CDB89712 -# endif -# define machine_is_cdb89712() (machine_arch_type == MACH_TYPE_CDB89712) -#else -# define machine_is_cdb89712() (0) -#endif - -#ifdef CONFIG_SA1100_GRAPHICSMASTER -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_GRAPHICSMASTER -# endif -# define machine_is_graphicsmaster() (machine_arch_type == MACH_TYPE_GRAPHICSMASTER) -#else -# define machine_is_graphicsmaster() (0) -#endif - -#ifdef CONFIG_SA1100_ADSBITSY -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ADSBITSY -# endif -# define machine_is_adsbitsy() (machine_arch_type == MACH_TYPE_ADSBITSY) -#else -# define machine_is_adsbitsy() (0) -#endif - -#ifdef CONFIG_ARCH_PXA_IDP -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_PXA_IDP -# endif -# define machine_is_pxa_idp() (machine_arch_type == MACH_TYPE_PXA_IDP) -#else -# define machine_is_pxa_idp() (0) -#endif - -#ifdef CONFIG_SA1100_PT_SYSTEM3 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_PT_SYSTEM3 -# endif -# define machine_is_pt_system3() (machine_arch_type == MACH_TYPE_PT_SYSTEM3) -#else -# define machine_is_pt_system3() (0) -#endif - -#ifdef CONFIG_ARCH_AUTCPU12 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_AUTCPU12 -# endif -# define machine_is_autcpu12() (machine_arch_type == MACH_TYPE_AUTCPU12) -#else -# define machine_is_autcpu12() (0) -#endif - -#ifdef CONFIG_SA1100_H3100 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_H3100 -# endif -# define machine_is_h3100() (machine_arch_type == MACH_TYPE_H3100) -#else -# define machine_is_h3100() (0) -#endif - -#ifdef CONFIG_SA1100_COLLIE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_COLLIE -# endif -# define machine_is_collie() (machine_arch_type == MACH_TYPE_COLLIE) -#else -# define machine_is_collie() (0) -#endif - -#ifdef CONFIG_SA1100_BADGE4 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_BADGE4 -# endif -# define machine_is_badge4() (machine_arch_type == MACH_TYPE_BADGE4) -#else -# define machine_is_badge4() (0) -#endif - -#ifdef CONFIG_ARCH_FORTUNET -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_FORTUNET -# endif -# define machine_is_fortunet() (machine_arch_type == MACH_TYPE_FORTUNET) -#else -# define machine_is_fortunet() (0) -#endif - -#ifdef CONFIG_ARCH_MX1ADS -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MX1ADS -# endif -# define machine_is_mx1ads() (machine_arch_type == MACH_TYPE_MX1ADS) -#else -# define machine_is_mx1ads() (0) -#endif - -#ifdef CONFIG_ARCH_H7201 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_H7201 -# endif -# define machine_is_h7201() (machine_arch_type == MACH_TYPE_H7201) -#else -# define machine_is_h7201() (0) -#endif - -#ifdef CONFIG_ARCH_H7202 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_H7202 -# endif -# define machine_is_h7202() (machine_arch_type == MACH_TYPE_H7202) -#else -# define machine_is_h7202() (0) -#endif - -#ifdef CONFIG_ARCH_IQ80321 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_IQ80321 -# endif -# define machine_is_iq80321() (machine_arch_type == MACH_TYPE_IQ80321) -#else -# define machine_is_iq80321() (0) -#endif - -#ifdef CONFIG_ARCH_KS8695 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_KS8695 -# endif -# define machine_is_ks8695() (machine_arch_type == MACH_TYPE_KS8695) -#else -# define machine_is_ks8695() (0) -#endif - -#ifdef CONFIG_ARCH_SMDK2410 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SMDK2410 -# endif -# define machine_is_smdk2410() (machine_arch_type == MACH_TYPE_SMDK2410) -#else -# define machine_is_smdk2410() (0) -#endif - -#ifdef CONFIG_ARCH_CEIVA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CEIVA -# endif -# define machine_is_ceiva() (machine_arch_type == MACH_TYPE_CEIVA) -#else -# define machine_is_ceiva() (0) -#endif - -#ifdef CONFIG_MACH_VOICEBLUE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_VOICEBLUE -# endif -# define machine_is_voiceblue() (machine_arch_type == MACH_TYPE_VOICEBLUE) -#else -# define machine_is_voiceblue() (0) -#endif - -#ifdef CONFIG_ARCH_H5400 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_H5400 -# endif -# define machine_is_h5400() (machine_arch_type == MACH_TYPE_H5400) -#else -# define machine_is_h5400() (0) -#endif - -#ifdef CONFIG_MACH_OMAP_INNOVATOR -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OMAP_INNOVATOR -# endif -# define machine_is_omap_innovator() (machine_arch_type == MACH_TYPE_OMAP_INNOVATOR) -#else -# define machine_is_omap_innovator() (0) -#endif - -#ifdef CONFIG_ARCH_IXDP2400 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_IXDP2400 -# endif -# define machine_is_ixdp2400() (machine_arch_type == MACH_TYPE_IXDP2400) -#else -# define machine_is_ixdp2400() (0) -#endif - -#ifdef CONFIG_ARCH_IXDP2800 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_IXDP2800 -# endif -# define machine_is_ixdp2800() (machine_arch_type == MACH_TYPE_IXDP2800) -#else -# define machine_is_ixdp2800() (0) -#endif - -#ifdef CONFIG_ARCH_IXDP425 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_IXDP425 -# endif -# define machine_is_ixdp425() (machine_arch_type == MACH_TYPE_IXDP425) -#else -# define machine_is_ixdp425() (0) -#endif - -#ifdef CONFIG_SA1100_HACKKIT -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_HACKKIT -# endif -# define machine_is_hackkit() (machine_arch_type == MACH_TYPE_HACKKIT) -#else -# define machine_is_hackkit() (0) -#endif - -#ifdef CONFIG_ARCH_IXCDP1100 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_IXCDP1100 -# endif -# define machine_is_ixcdp1100() (machine_arch_type == MACH_TYPE_IXCDP1100) -#else -# define machine_is_ixcdp1100() (0) -#endif - -#ifdef CONFIG_ARCH_AT91RM9200DK -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_AT91RM9200DK -# endif -# define machine_is_at91rm9200dk() (machine_arch_type == MACH_TYPE_AT91RM9200DK) -#else -# define machine_is_at91rm9200dk() (0) -#endif - -#ifdef CONFIG_ARCH_CINTEGRATOR -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CINTEGRATOR -# endif -# define machine_is_cintegrator() (machine_arch_type == MACH_TYPE_CINTEGRATOR) -#else -# define machine_is_cintegrator() (0) -#endif - -#ifdef CONFIG_ARCH_VIPER -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_VIPER -# endif -# define machine_is_viper() (machine_arch_type == MACH_TYPE_VIPER) -#else -# define machine_is_viper() (0) -#endif - -#ifdef CONFIG_ARCH_ADI_COYOTE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ADI_COYOTE -# endif -# define machine_is_adi_coyote() (machine_arch_type == MACH_TYPE_ADI_COYOTE) -#else -# define machine_is_adi_coyote() (0) -#endif - -#ifdef CONFIG_ARCH_IXDP2401 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_IXDP2401 -# endif -# define machine_is_ixdp2401() (machine_arch_type == MACH_TYPE_IXDP2401) -#else -# define machine_is_ixdp2401() (0) -#endif - -#ifdef CONFIG_ARCH_IXDP2801 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_IXDP2801 -# endif -# define machine_is_ixdp2801() (machine_arch_type == MACH_TYPE_IXDP2801) -#else -# define machine_is_ixdp2801() (0) -#endif - -#ifdef CONFIG_ARCH_IQ31244 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_IQ31244 -# endif -# define machine_is_iq31244() (machine_arch_type == MACH_TYPE_IQ31244) -#else -# define machine_is_iq31244() (0) -#endif - -#ifdef CONFIG_ARCH_BAST -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_BAST -# endif -# define machine_is_bast() (machine_arch_type == MACH_TYPE_BAST) -#else -# define machine_is_bast() (0) -#endif - -#ifdef CONFIG_ARCH_H1940 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_H1940 -# endif -# define machine_is_h1940() (machine_arch_type == MACH_TYPE_H1940) -#else -# define machine_is_h1940() (0) -#endif - -#ifdef CONFIG_ARCH_ENP2611 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ENP2611 -# endif -# define machine_is_enp2611() (machine_arch_type == MACH_TYPE_ENP2611) -#else -# define machine_is_enp2611() (0) -#endif - -#ifdef CONFIG_ARCH_S3C2440 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_S3C2440 -# endif -# define machine_is_s3c2440() (machine_arch_type == MACH_TYPE_S3C2440) -#else -# define machine_is_s3c2440() (0) -#endif - -#ifdef CONFIG_ARCH_GUMSTIX -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_GUMSTIX -# endif -# define machine_is_gumstix() (machine_arch_type == MACH_TYPE_GUMSTIX) -#else -# define machine_is_gumstix() (0) -#endif - -#ifdef CONFIG_MACH_OMAP_H2 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OMAP_H2 -# endif -# define machine_is_omap_h2() (machine_arch_type == MACH_TYPE_OMAP_H2) -#else -# define machine_is_omap_h2() (0) -#endif - -#ifdef CONFIG_MACH_E740 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_E740 -# endif -# define machine_is_e740() (machine_arch_type == MACH_TYPE_E740) -#else -# define machine_is_e740() (0) -#endif - -#ifdef CONFIG_ARCH_IQ80331 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_IQ80331 -# endif -# define machine_is_iq80331() (machine_arch_type == MACH_TYPE_IQ80331) -#else -# define machine_is_iq80331() (0) -#endif - -#ifdef CONFIG_ARCH_VERSATILE_PB -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_VERSATILE_PB -# endif -# define machine_is_versatile_pb() (machine_arch_type == MACH_TYPE_VERSATILE_PB) -#else -# define machine_is_versatile_pb() (0) -#endif - -#ifdef CONFIG_MACH_KEV7A400 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_KEV7A400 -# endif -# define machine_is_kev7a400() (machine_arch_type == MACH_TYPE_KEV7A400) -#else -# define machine_is_kev7a400() (0) -#endif - -#ifdef CONFIG_MACH_LPD7A400 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_LPD7A400 -# endif -# define machine_is_lpd7a400() (machine_arch_type == MACH_TYPE_LPD7A400) -#else -# define machine_is_lpd7a400() (0) -#endif - -#ifdef CONFIG_MACH_LPD7A404 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_LPD7A404 -# endif -# define machine_is_lpd7a404() (machine_arch_type == MACH_TYPE_LPD7A404) -#else -# define machine_is_lpd7a404() (0) -#endif - -#ifdef CONFIG_MACH_CSB337 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CSB337 -# endif -# define machine_is_csb337() (machine_arch_type == MACH_TYPE_CSB337) -#else -# define machine_is_csb337() (0) -#endif - -#ifdef CONFIG_MACH_MAINSTONE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MAINSTONE -# endif -# define machine_is_mainstone() (machine_arch_type == MACH_TYPE_MAINSTONE) -#else -# define machine_is_mainstone() (0) -#endif - -#ifdef CONFIG_MACH_XCEP -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_XCEP -# endif -# define machine_is_xcep() (machine_arch_type == MACH_TYPE_XCEP) -#else -# define machine_is_xcep() (0) -#endif - -#ifdef CONFIG_MACH_ARCOM_VULCAN -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ARCOM_VULCAN -# endif -# define machine_is_arcom_vulcan() (machine_arch_type == MACH_TYPE_ARCOM_VULCAN) -#else -# define machine_is_arcom_vulcan() (0) -#endif - -#ifdef CONFIG_MACH_NOMADIK -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NOMADIK -# endif -# define machine_is_nomadik() (machine_arch_type == MACH_TYPE_NOMADIK) -#else -# define machine_is_nomadik() (0) -#endif - -#ifdef CONFIG_MACH_CORGI -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CORGI -# endif -# define machine_is_corgi() (machine_arch_type == MACH_TYPE_CORGI) -#else -# define machine_is_corgi() (0) -#endif - -#ifdef CONFIG_MACH_POODLE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_POODLE -# endif -# define machine_is_poodle() (machine_arch_type == MACH_TYPE_POODLE) -#else -# define machine_is_poodle() (0) -#endif - -#ifdef CONFIG_MACH_ARMCORE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ARMCORE -# endif -# define machine_is_armcore() (machine_arch_type == MACH_TYPE_ARMCORE) -#else -# define machine_is_armcore() (0) -#endif - -#ifdef CONFIG_MACH_MX31ADS -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MX31ADS -# endif -# define machine_is_mx31ads() (machine_arch_type == MACH_TYPE_MX31ADS) -#else -# define machine_is_mx31ads() (0) -#endif - -#ifdef CONFIG_MACH_HIMALAYA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_HIMALAYA -# endif -# define machine_is_himalaya() (machine_arch_type == MACH_TYPE_HIMALAYA) -#else -# define machine_is_himalaya() (0) -#endif - -#ifdef CONFIG_MACH_EDB9312 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_EDB9312 -# endif -# define machine_is_edb9312() (machine_arch_type == MACH_TYPE_EDB9312) -#else -# define machine_is_edb9312() (0) -#endif - -#ifdef CONFIG_MACH_OMAP_GENERIC -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OMAP_GENERIC -# endif -# define machine_is_omap_generic() (machine_arch_type == MACH_TYPE_OMAP_GENERIC) -#else -# define machine_is_omap_generic() (0) -#endif - -#ifdef CONFIG_MACH_EDB9301 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_EDB9301 -# endif -# define machine_is_edb9301() (machine_arch_type == MACH_TYPE_EDB9301) -#else -# define machine_is_edb9301() (0) -#endif - -#ifdef CONFIG_MACH_EDB9315 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_EDB9315 -# endif -# define machine_is_edb9315() (machine_arch_type == MACH_TYPE_EDB9315) -#else -# define machine_is_edb9315() (0) -#endif - -#ifdef CONFIG_MACH_VR1000 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_VR1000 -# endif -# define machine_is_vr1000() (machine_arch_type == MACH_TYPE_VR1000) -#else -# define machine_is_vr1000() (0) -#endif - -#ifdef CONFIG_MACH_OMAP_PERSEUS2 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OMAP_PERSEUS2 -# endif -# define machine_is_omap_perseus2() (machine_arch_type == MACH_TYPE_OMAP_PERSEUS2) -#else -# define machine_is_omap_perseus2() (0) -#endif - -#ifdef CONFIG_MACH_E800 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_E800 -# endif -# define machine_is_e800() (machine_arch_type == MACH_TYPE_E800) -#else -# define machine_is_e800() (0) -#endif - -#ifdef CONFIG_MACH_E750 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_E750 -# endif -# define machine_is_e750() (machine_arch_type == MACH_TYPE_E750) -#else -# define machine_is_e750() (0) -#endif - -#ifdef CONFIG_MACH_SCB9328 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SCB9328 -# endif -# define machine_is_scb9328() (machine_arch_type == MACH_TYPE_SCB9328) -#else -# define machine_is_scb9328() (0) -#endif - -#ifdef CONFIG_MACH_OMAP_H3 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OMAP_H3 -# endif -# define machine_is_omap_h3() (machine_arch_type == MACH_TYPE_OMAP_H3) -#else -# define machine_is_omap_h3() (0) -#endif - -#ifdef CONFIG_MACH_OMAP_H4 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OMAP_H4 -# endif -# define machine_is_omap_h4() (machine_arch_type == MACH_TYPE_OMAP_H4) -#else -# define machine_is_omap_h4() (0) -#endif - -#ifdef CONFIG_MACH_OMAP_OSK -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OMAP_OSK -# endif -# define machine_is_omap_osk() (machine_arch_type == MACH_TYPE_OMAP_OSK) -#else -# define machine_is_omap_osk() (0) -#endif - -#ifdef CONFIG_MACH_TOSA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TOSA -# endif -# define machine_is_tosa() (machine_arch_type == MACH_TYPE_TOSA) -#else -# define machine_is_tosa() (0) -#endif - -#ifdef CONFIG_MACH_AVILA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_AVILA -# endif -# define machine_is_avila() (machine_arch_type == MACH_TYPE_AVILA) -#else -# define machine_is_avila() (0) -#endif - -#ifdef CONFIG_MACH_EDB9302 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_EDB9302 -# endif -# define machine_is_edb9302() (machine_arch_type == MACH_TYPE_EDB9302) -#else -# define machine_is_edb9302() (0) -#endif - -#ifdef CONFIG_MACH_HUSKY -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_HUSKY -# endif -# define machine_is_husky() (machine_arch_type == MACH_TYPE_HUSKY) -#else -# define machine_is_husky() (0) -#endif - -#ifdef CONFIG_MACH_SHEPHERD -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SHEPHERD -# endif -# define machine_is_shepherd() (machine_arch_type == MACH_TYPE_SHEPHERD) -#else -# define machine_is_shepherd() (0) -#endif - -#ifdef CONFIG_MACH_H4700 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_H4700 -# endif -# define machine_is_h4700() (machine_arch_type == MACH_TYPE_H4700) -#else -# define machine_is_h4700() (0) -#endif - -#ifdef CONFIG_MACH_RX3715 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_RX3715 -# endif -# define machine_is_rx3715() (machine_arch_type == MACH_TYPE_RX3715) -#else -# define machine_is_rx3715() (0) -#endif - -#ifdef CONFIG_MACH_NSLU2 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NSLU2 -# endif -# define machine_is_nslu2() (machine_arch_type == MACH_TYPE_NSLU2) -#else -# define machine_is_nslu2() (0) -#endif - -#ifdef CONFIG_MACH_E400 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_E400 -# endif -# define machine_is_e400() (machine_arch_type == MACH_TYPE_E400) -#else -# define machine_is_e400() (0) -#endif - -#ifdef CONFIG_MACH_IXDPG425 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_IXDPG425 -# endif -# define machine_is_ixdpg425() (machine_arch_type == MACH_TYPE_IXDPG425) -#else -# define machine_is_ixdpg425() (0) -#endif - -#ifdef CONFIG_MACH_VERSATILE_AB -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_VERSATILE_AB -# endif -# define machine_is_versatile_ab() (machine_arch_type == MACH_TYPE_VERSATILE_AB) -#else -# define machine_is_versatile_ab() (0) -#endif - -#ifdef CONFIG_MACH_EDB9307 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_EDB9307 -# endif -# define machine_is_edb9307() (machine_arch_type == MACH_TYPE_EDB9307) -#else -# define machine_is_edb9307() (0) -#endif - -#ifdef CONFIG_MACH_KB9200 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_KB9200 -# endif -# define machine_is_kb9200() (machine_arch_type == MACH_TYPE_KB9200) -#else -# define machine_is_kb9200() (0) -#endif - -#ifdef CONFIG_MACH_SX1 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SX1 -# endif -# define machine_is_sx1() (machine_arch_type == MACH_TYPE_SX1) -#else -# define machine_is_sx1() (0) -#endif - -#ifdef CONFIG_MACH_IXDP465 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_IXDP465 -# endif -# define machine_is_ixdp465() (machine_arch_type == MACH_TYPE_IXDP465) -#else -# define machine_is_ixdp465() (0) -#endif - -#ifdef CONFIG_MACH_IXDP2351 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_IXDP2351 -# endif -# define machine_is_ixdp2351() (machine_arch_type == MACH_TYPE_IXDP2351) -#else -# define machine_is_ixdp2351() (0) -#endif - -#ifdef CONFIG_MACH_IQ80332 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_IQ80332 -# endif -# define machine_is_iq80332() (machine_arch_type == MACH_TYPE_IQ80332) -#else -# define machine_is_iq80332() (0) -#endif - -#ifdef CONFIG_MACH_GTWX5715 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_GTWX5715 -# endif -# define machine_is_gtwx5715() (machine_arch_type == MACH_TYPE_GTWX5715) -#else -# define machine_is_gtwx5715() (0) -#endif - -#ifdef CONFIG_MACH_CSB637 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CSB637 -# endif -# define machine_is_csb637() (machine_arch_type == MACH_TYPE_CSB637) -#else -# define machine_is_csb637() (0) -#endif - -#ifdef CONFIG_MACH_N30 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_N30 -# endif -# define machine_is_n30() (machine_arch_type == MACH_TYPE_N30) -#else -# define machine_is_n30() (0) -#endif - -#ifdef CONFIG_MACH_NEC_MP900 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NEC_MP900 -# endif -# define machine_is_nec_mp900() (machine_arch_type == MACH_TYPE_NEC_MP900) -#else -# define machine_is_nec_mp900() (0) -#endif - -#ifdef CONFIG_MACH_KAFA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_KAFA -# endif -# define machine_is_kafa() (machine_arch_type == MACH_TYPE_KAFA) -#else -# define machine_is_kafa() (0) -#endif - -#ifdef CONFIG_MACH_TS72XX -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TS72XX -# endif -# define machine_is_ts72xx() (machine_arch_type == MACH_TYPE_TS72XX) -#else -# define machine_is_ts72xx() (0) -#endif - -#ifdef CONFIG_MACH_OTOM -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OTOM -# endif -# define machine_is_otom() (machine_arch_type == MACH_TYPE_OTOM) -#else -# define machine_is_otom() (0) -#endif - -#ifdef CONFIG_MACH_NEXCODER_2440 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NEXCODER_2440 -# endif -# define machine_is_nexcoder_2440() (machine_arch_type == MACH_TYPE_NEXCODER_2440) -#else -# define machine_is_nexcoder_2440() (0) -#endif - -#ifdef CONFIG_MACH_ECO920 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ECO920 -# endif -# define machine_is_eco920() (machine_arch_type == MACH_TYPE_ECO920) -#else -# define machine_is_eco920() (0) -#endif - -#ifdef CONFIG_MACH_ROADRUNNER -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ROADRUNNER -# endif -# define machine_is_roadrunner() (machine_arch_type == MACH_TYPE_ROADRUNNER) -#else -# define machine_is_roadrunner() (0) -#endif - -#ifdef CONFIG_MACH_AT91RM9200EK -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_AT91RM9200EK -# endif -# define machine_is_at91rm9200ek() (machine_arch_type == MACH_TYPE_AT91RM9200EK) -#else -# define machine_is_at91rm9200ek() (0) -#endif - -#ifdef CONFIG_MACH_SPITZ -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SPITZ -# endif -# define machine_is_spitz() (machine_arch_type == MACH_TYPE_SPITZ) -#else -# define machine_is_spitz() (0) -#endif - -#ifdef CONFIG_MACH_ADSSPHERE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ADSSPHERE -# endif -# define machine_is_adssphere() (machine_arch_type == MACH_TYPE_ADSSPHERE) -#else -# define machine_is_adssphere() (0) -#endif - -#ifdef CONFIG_MACH_COLIBRI -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_COLIBRI -# endif -# define machine_is_colibri() (machine_arch_type == MACH_TYPE_COLIBRI) -#else -# define machine_is_colibri() (0) -#endif - -#ifdef CONFIG_MACH_GATEWAY7001 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_GATEWAY7001 -# endif -# define machine_is_gateway7001() (machine_arch_type == MACH_TYPE_GATEWAY7001) -#else -# define machine_is_gateway7001() (0) -#endif - -#ifdef CONFIG_MACH_PCM027 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_PCM027 -# endif -# define machine_is_pcm027() (machine_arch_type == MACH_TYPE_PCM027) -#else -# define machine_is_pcm027() (0) -#endif - -#ifdef CONFIG_MACH_ANUBIS -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ANUBIS -# endif -# define machine_is_anubis() (machine_arch_type == MACH_TYPE_ANUBIS) -#else -# define machine_is_anubis() (0) -#endif - -#ifdef CONFIG_MACH_AKITA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_AKITA -# endif -# define machine_is_akita() (machine_arch_type == MACH_TYPE_AKITA) -#else -# define machine_is_akita() (0) -#endif - -#ifdef CONFIG_MACH_E330 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_E330 -# endif -# define machine_is_e330() (machine_arch_type == MACH_TYPE_E330) -#else -# define machine_is_e330() (0) -#endif - -#ifdef CONFIG_MACH_NOKIA770 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NOKIA770 -# endif -# define machine_is_nokia770() (machine_arch_type == MACH_TYPE_NOKIA770) -#else -# define machine_is_nokia770() (0) -#endif - -#ifdef CONFIG_MACH_CARMEVA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CARMEVA -# endif -# define machine_is_carmeva() (machine_arch_type == MACH_TYPE_CARMEVA) -#else -# define machine_is_carmeva() (0) -#endif - -#ifdef CONFIG_MACH_EDB9315A -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_EDB9315A -# endif -# define machine_is_edb9315a() (machine_arch_type == MACH_TYPE_EDB9315A) -#else -# define machine_is_edb9315a() (0) -#endif - -#ifdef CONFIG_MACH_STARGATE2 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_STARGATE2 -# endif -# define machine_is_stargate2() (machine_arch_type == MACH_TYPE_STARGATE2) -#else -# define machine_is_stargate2() (0) -#endif - -#ifdef CONFIG_MACH_INTELMOTE2 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_INTELMOTE2 -# endif -# define machine_is_intelmote2() (machine_arch_type == MACH_TYPE_INTELMOTE2) -#else -# define machine_is_intelmote2() (0) -#endif - -#ifdef CONFIG_MACH_TRIZEPS4 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TRIZEPS4 -# endif -# define machine_is_trizeps4() (machine_arch_type == MACH_TYPE_TRIZEPS4) -#else -# define machine_is_trizeps4() (0) -#endif - -#ifdef CONFIG_MACH_PNX4008 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_PNX4008 -# endif -# define machine_is_pnx4008() (machine_arch_type == MACH_TYPE_PNX4008) -#else -# define machine_is_pnx4008() (0) -#endif - -#ifdef CONFIG_MACH_IQ81340SC -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_IQ81340SC -# endif -# define machine_is_iq81340sc() (machine_arch_type == MACH_TYPE_IQ81340SC) -#else -# define machine_is_iq81340sc() (0) -#endif - -#ifdef CONFIG_MACH_IQ81340MC -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_IQ81340MC -# endif -# define machine_is_iq81340mc() (machine_arch_type == MACH_TYPE_IQ81340MC) -#else -# define machine_is_iq81340mc() (0) -#endif - -#ifdef CONFIG_MACH_MICRO9 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MICRO9 -# endif -# define machine_is_micro9() (machine_arch_type == MACH_TYPE_MICRO9) -#else -# define machine_is_micro9() (0) -#endif - -#ifdef CONFIG_MACH_MICRO9L -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MICRO9L -# endif -# define machine_is_micro9l() (machine_arch_type == MACH_TYPE_MICRO9L) -#else -# define machine_is_micro9l() (0) -#endif - -#ifdef CONFIG_MACH_OMAP_PALMTE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OMAP_PALMTE -# endif -# define machine_is_omap_palmte() (machine_arch_type == MACH_TYPE_OMAP_PALMTE) -#else -# define machine_is_omap_palmte() (0) -#endif - -#ifdef CONFIG_MACH_REALVIEW_EB -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_REALVIEW_EB -# endif -# define machine_is_realview_eb() (machine_arch_type == MACH_TYPE_REALVIEW_EB) -#else -# define machine_is_realview_eb() (0) -#endif - -#ifdef CONFIG_MACH_BORZOI -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_BORZOI -# endif -# define machine_is_borzoi() (machine_arch_type == MACH_TYPE_BORZOI) -#else -# define machine_is_borzoi() (0) -#endif - -#ifdef CONFIG_MACH_PALMLD -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_PALMLD -# endif -# define machine_is_palmld() (machine_arch_type == MACH_TYPE_PALMLD) -#else -# define machine_is_palmld() (0) -#endif - -#ifdef CONFIG_MACH_IXDP28X5 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_IXDP28X5 -# endif -# define machine_is_ixdp28x5() (machine_arch_type == MACH_TYPE_IXDP28X5) -#else -# define machine_is_ixdp28x5() (0) -#endif - -#ifdef CONFIG_MACH_OMAP_PALMTT -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OMAP_PALMTT -# endif -# define machine_is_omap_palmtt() (machine_arch_type == MACH_TYPE_OMAP_PALMTT) -#else -# define machine_is_omap_palmtt() (0) -#endif - -#ifdef CONFIG_MACH_ARCOM_ZEUS -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ARCOM_ZEUS -# endif -# define machine_is_arcom_zeus() (machine_arch_type == MACH_TYPE_ARCOM_ZEUS) -#else -# define machine_is_arcom_zeus() (0) -#endif - -#ifdef CONFIG_MACH_OSIRIS -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OSIRIS -# endif -# define machine_is_osiris() (machine_arch_type == MACH_TYPE_OSIRIS) -#else -# define machine_is_osiris() (0) -#endif - -#ifdef CONFIG_MACH_PALMTE2 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_PALMTE2 -# endif -# define machine_is_palmte2() (machine_arch_type == MACH_TYPE_PALMTE2) -#else -# define machine_is_palmte2() (0) -#endif - -#ifdef CONFIG_MACH_MX27ADS -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MX27ADS -# endif -# define machine_is_mx27ads() (machine_arch_type == MACH_TYPE_MX27ADS) -#else -# define machine_is_mx27ads() (0) -#endif - -#ifdef CONFIG_MACH_AT91SAM9261EK -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_AT91SAM9261EK -# endif -# define machine_is_at91sam9261ek() (machine_arch_type == MACH_TYPE_AT91SAM9261EK) -#else -# define machine_is_at91sam9261ek() (0) -#endif - -#ifdef CONFIG_MACH_LOFT -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_LOFT -# endif -# define machine_is_loft() (machine_arch_type == MACH_TYPE_LOFT) -#else -# define machine_is_loft() (0) -#endif - -#ifdef CONFIG_MACH_MX21ADS -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MX21ADS -# endif -# define machine_is_mx21ads() (machine_arch_type == MACH_TYPE_MX21ADS) -#else -# define machine_is_mx21ads() (0) -#endif - -#ifdef CONFIG_MACH_AMS_DELTA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_AMS_DELTA -# endif -# define machine_is_ams_delta() (machine_arch_type == MACH_TYPE_AMS_DELTA) -#else -# define machine_is_ams_delta() (0) -#endif - -#ifdef CONFIG_MACH_NAS100D -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NAS100D -# endif -# define machine_is_nas100d() (machine_arch_type == MACH_TYPE_NAS100D) -#else -# define machine_is_nas100d() (0) -#endif - -#ifdef CONFIG_MACH_MAGICIAN -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MAGICIAN -# endif -# define machine_is_magician() (machine_arch_type == MACH_TYPE_MAGICIAN) -#else -# define machine_is_magician() (0) -#endif - -#ifdef CONFIG_MACH_NXDKN -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NXDKN -# endif -# define machine_is_nxdkn() (machine_arch_type == MACH_TYPE_NXDKN) -#else -# define machine_is_nxdkn() (0) -#endif - -#ifdef CONFIG_MACH_PALMTX -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_PALMTX -# endif -# define machine_is_palmtx() (machine_arch_type == MACH_TYPE_PALMTX) -#else -# define machine_is_palmtx() (0) -#endif - -#ifdef CONFIG_MACH_S3C2413 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_S3C2413 -# endif -# define machine_is_s3c2413() (machine_arch_type == MACH_TYPE_S3C2413) -#else -# define machine_is_s3c2413() (0) -#endif - -#ifdef CONFIG_MACH_WG302V2 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_WG302V2 -# endif -# define machine_is_wg302v2() (machine_arch_type == MACH_TYPE_WG302V2) -#else -# define machine_is_wg302v2() (0) -#endif - -#ifdef CONFIG_MACH_OMAP_2430SDP -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OMAP_2430SDP -# endif -# define machine_is_omap_2430sdp() (machine_arch_type == MACH_TYPE_OMAP_2430SDP) -#else -# define machine_is_omap_2430sdp() (0) -#endif - -#ifdef CONFIG_MACH_DAVINCI_EVM -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DAVINCI_EVM -# endif -# define machine_is_davinci_evm() (machine_arch_type == MACH_TYPE_DAVINCI_EVM) -#else -# define machine_is_davinci_evm() (0) -#endif - -#ifdef CONFIG_MACH_PALMZ72 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_PALMZ72 -# endif -# define machine_is_palmz72() (machine_arch_type == MACH_TYPE_PALMZ72) -#else -# define machine_is_palmz72() (0) -#endif - -#ifdef CONFIG_MACH_NXDB500 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NXDB500 -# endif -# define machine_is_nxdb500() (machine_arch_type == MACH_TYPE_NXDB500) -#else -# define machine_is_nxdb500() (0) -#endif - -#ifdef CONFIG_MACH_PALMT5 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_PALMT5 -# endif -# define machine_is_palmt5() (machine_arch_type == MACH_TYPE_PALMT5) -#else -# define machine_is_palmt5() (0) -#endif - -#ifdef CONFIG_MACH_PALMTC -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_PALMTC -# endif -# define machine_is_palmtc() (machine_arch_type == MACH_TYPE_PALMTC) -#else -# define machine_is_palmtc() (0) -#endif - -#ifdef CONFIG_MACH_OMAP_APOLLON -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OMAP_APOLLON -# endif -# define machine_is_omap_apollon() (machine_arch_type == MACH_TYPE_OMAP_APOLLON) -#else -# define machine_is_omap_apollon() (0) -#endif - -#ifdef CONFIG_MACH_ATEB9200 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ATEB9200 -# endif -# define machine_is_ateb9200() (machine_arch_type == MACH_TYPE_ATEB9200) -#else -# define machine_is_ateb9200() (0) -#endif - -#ifdef CONFIG_MACH_N35 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_N35 -# endif -# define machine_is_n35() (machine_arch_type == MACH_TYPE_N35) -#else -# define machine_is_n35() (0) -#endif - -#ifdef CONFIG_MACH_LOGICPD_PXA270 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_LOGICPD_PXA270 -# endif -# define machine_is_logicpd_pxa270() (machine_arch_type == MACH_TYPE_LOGICPD_PXA270) -#else -# define machine_is_logicpd_pxa270() (0) -#endif - -#ifdef CONFIG_MACH_NXEB500HMI -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NXEB500HMI -# endif -# define machine_is_nxeb500hmi() (machine_arch_type == MACH_TYPE_NXEB500HMI) -#else -# define machine_is_nxeb500hmi() (0) -#endif - -#ifdef CONFIG_MACH_ESPRESSO -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ESPRESSO -# endif -# define machine_is_espresso() (machine_arch_type == MACH_TYPE_ESPRESSO) -#else -# define machine_is_espresso() (0) -#endif - -#ifdef CONFIG_MACH_RX1950 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_RX1950 -# endif -# define machine_is_rx1950() (machine_arch_type == MACH_TYPE_RX1950) -#else -# define machine_is_rx1950() (0) -#endif - -#ifdef CONFIG_MACH_GESBC9312 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_GESBC9312 -# endif -# define machine_is_gesbc9312() (machine_arch_type == MACH_TYPE_GESBC9312) -#else -# define machine_is_gesbc9312() (0) -#endif - -#ifdef CONFIG_MACH_PICOTUX2XX -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_PICOTUX2XX -# endif -# define machine_is_picotux2xx() (machine_arch_type == MACH_TYPE_PICOTUX2XX) -#else -# define machine_is_picotux2xx() (0) -#endif - -#ifdef CONFIG_MACH_DSMG600 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DSMG600 -# endif -# define machine_is_dsmg600() (machine_arch_type == MACH_TYPE_DSMG600) -#else -# define machine_is_dsmg600() (0) -#endif - -#ifdef CONFIG_MACH_OMAP_FSAMPLE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OMAP_FSAMPLE -# endif -# define machine_is_omap_fsample() (machine_arch_type == MACH_TYPE_OMAP_FSAMPLE) -#else -# define machine_is_omap_fsample() (0) -#endif - -#ifdef CONFIG_MACH_SNAPPER_CL15 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SNAPPER_CL15 -# endif -# define machine_is_snapper_cl15() (machine_arch_type == MACH_TYPE_SNAPPER_CL15) -#else -# define machine_is_snapper_cl15() (0) -#endif - -#ifdef CONFIG_MACH_OMAP_PALMZ71 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OMAP_PALMZ71 -# endif -# define machine_is_omap_palmz71() (machine_arch_type == MACH_TYPE_OMAP_PALMZ71) -#else -# define machine_is_omap_palmz71() (0) -#endif - -#ifdef CONFIG_MACH_SMDK2412 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SMDK2412 -# endif -# define machine_is_smdk2412() (machine_arch_type == MACH_TYPE_SMDK2412) -#else -# define machine_is_smdk2412() (0) -#endif - -#ifdef CONFIG_MACH_SMDK2413 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SMDK2413 -# endif -# define machine_is_smdk2413() (machine_arch_type == MACH_TYPE_SMDK2413) -#else -# define machine_is_smdk2413() (0) -#endif - -#ifdef CONFIG_MACH_AML_M5900 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_AML_M5900 -# endif -# define machine_is_aml_m5900() (machine_arch_type == MACH_TYPE_AML_M5900) -#else -# define machine_is_aml_m5900() (0) -#endif - -#ifdef CONFIG_MACH_ECBAT91 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ECBAT91 -# endif -# define machine_is_ecbat91() (machine_arch_type == MACH_TYPE_ECBAT91) -#else -# define machine_is_ecbat91() (0) -#endif - -#ifdef CONFIG_MACH_ONEARM -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ONEARM -# endif -# define machine_is_onearm() (machine_arch_type == MACH_TYPE_ONEARM) -#else -# define machine_is_onearm() (0) -#endif - -#ifdef CONFIG_MACH_SMDK2443 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SMDK2443 -# endif -# define machine_is_smdk2443() (machine_arch_type == MACH_TYPE_SMDK2443) -#else -# define machine_is_smdk2443() (0) -#endif - -#ifdef CONFIG_MACH_FSG -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_FSG -# endif -# define machine_is_fsg() (machine_arch_type == MACH_TYPE_FSG) -#else -# define machine_is_fsg() (0) -#endif - -#ifdef CONFIG_MACH_AT91SAM9260EK -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_AT91SAM9260EK -# endif -# define machine_is_at91sam9260ek() (machine_arch_type == MACH_TYPE_AT91SAM9260EK) -#else -# define machine_is_at91sam9260ek() (0) -#endif - -#ifdef CONFIG_MACH_GLANTANK -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_GLANTANK -# endif -# define machine_is_glantank() (machine_arch_type == MACH_TYPE_GLANTANK) -#else -# define machine_is_glantank() (0) -#endif - -#ifdef CONFIG_MACH_N2100 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_N2100 -# endif -# define machine_is_n2100() (machine_arch_type == MACH_TYPE_N2100) -#else -# define machine_is_n2100() (0) -#endif - -#ifdef CONFIG_MACH_QT2410 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_QT2410 -# endif -# define machine_is_qt2410() (machine_arch_type == MACH_TYPE_QT2410) -#else -# define machine_is_qt2410() (0) -#endif - -#ifdef CONFIG_MACH_KIXRP435 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_KIXRP435 -# endif -# define machine_is_kixrp435() (machine_arch_type == MACH_TYPE_KIXRP435) -#else -# define machine_is_kixrp435() (0) -#endif - -#ifdef CONFIG_MACH_CC9P9360DEV -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CC9P9360DEV -# endif -# define machine_is_cc9p9360dev() (machine_arch_type == MACH_TYPE_CC9P9360DEV) -#else -# define machine_is_cc9p9360dev() (0) -#endif - -#ifdef CONFIG_MACH_EDB9302A -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_EDB9302A -# endif -# define machine_is_edb9302a() (machine_arch_type == MACH_TYPE_EDB9302A) -#else -# define machine_is_edb9302a() (0) -#endif - -#ifdef CONFIG_MACH_EDB9307A -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_EDB9307A -# endif -# define machine_is_edb9307a() (machine_arch_type == MACH_TYPE_EDB9307A) -#else -# define machine_is_edb9307a() (0) -#endif - -#ifdef CONFIG_MACH_OMAP_3430SDP -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OMAP_3430SDP -# endif -# define machine_is_omap_3430sdp() (machine_arch_type == MACH_TYPE_OMAP_3430SDP) -#else -# define machine_is_omap_3430sdp() (0) -#endif - -#ifdef CONFIG_MACH_VSTMS -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_VSTMS -# endif -# define machine_is_vstms() (machine_arch_type == MACH_TYPE_VSTMS) -#else -# define machine_is_vstms() (0) -#endif - -#ifdef CONFIG_MACH_MICRO9M -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MICRO9M -# endif -# define machine_is_micro9m() (machine_arch_type == MACH_TYPE_MICRO9M) -#else -# define machine_is_micro9m() (0) -#endif - -#ifdef CONFIG_MACH_BUG -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_BUG -# endif -# define machine_is_bug() (machine_arch_type == MACH_TYPE_BUG) -#else -# define machine_is_bug() (0) -#endif - -#ifdef CONFIG_MACH_AT91SAM9263EK -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_AT91SAM9263EK -# endif -# define machine_is_at91sam9263ek() (machine_arch_type == MACH_TYPE_AT91SAM9263EK) -#else -# define machine_is_at91sam9263ek() (0) -#endif - -#ifdef CONFIG_MACH_EM7210 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_EM7210 -# endif -# define machine_is_em7210() (machine_arch_type == MACH_TYPE_EM7210) -#else -# define machine_is_em7210() (0) -#endif - -#ifdef CONFIG_MACH_VPAC270 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_VPAC270 -# endif -# define machine_is_vpac270() (machine_arch_type == MACH_TYPE_VPAC270) -#else -# define machine_is_vpac270() (0) -#endif - -#ifdef CONFIG_MACH_TREO680 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TREO680 -# endif -# define machine_is_treo680() (machine_arch_type == MACH_TYPE_TREO680) -#else -# define machine_is_treo680() (0) -#endif - -#ifdef CONFIG_MACH_ZYLONITE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ZYLONITE -# endif -# define machine_is_zylonite() (machine_arch_type == MACH_TYPE_ZYLONITE) -#else -# define machine_is_zylonite() (0) -#endif - -#ifdef CONFIG_MACH_MX31LITE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MX31LITE -# endif -# define machine_is_mx31lite() (machine_arch_type == MACH_TYPE_MX31LITE) -#else -# define machine_is_mx31lite() (0) -#endif - -#ifdef CONFIG_MACH_MIOA701 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MIOA701 -# endif -# define machine_is_mioa701() (machine_arch_type == MACH_TYPE_MIOA701) -#else -# define machine_is_mioa701() (0) -#endif - -#ifdef CONFIG_MACH_ARMADILLO5X0 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ARMADILLO5X0 -# endif -# define machine_is_armadillo5x0() (machine_arch_type == MACH_TYPE_ARMADILLO5X0) -#else -# define machine_is_armadillo5x0() (0) -#endif - -#ifdef CONFIG_MACH_CC9P9360JS -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CC9P9360JS -# endif -# define machine_is_cc9p9360js() (machine_arch_type == MACH_TYPE_CC9P9360JS) -#else -# define machine_is_cc9p9360js() (0) -#endif - -#ifdef CONFIG_MACH_NOKIA_N800 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NOKIA_N800 -# endif -# define machine_is_nokia_n800() (machine_arch_type == MACH_TYPE_NOKIA_N800) -#else -# define machine_is_nokia_n800() (0) -#endif - -#ifdef CONFIG_MACH_EP80219 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_EP80219 -# endif -# define machine_is_ep80219() (machine_arch_type == MACH_TYPE_EP80219) -#else -# define machine_is_ep80219() (0) -#endif - -#ifdef CONFIG_MACH_GORAMO_MLR -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_GORAMO_MLR -# endif -# define machine_is_goramo_mlr() (machine_arch_type == MACH_TYPE_GORAMO_MLR) -#else -# define machine_is_goramo_mlr() (0) -#endif - -#ifdef CONFIG_MACH_EM_X270 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_EM_X270 -# endif -# define machine_is_em_x270() (machine_arch_type == MACH_TYPE_EM_X270) -#else -# define machine_is_em_x270() (0) -#endif - -#ifdef CONFIG_MACH_NEO1973_GTA02 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NEO1973_GTA02 -# endif -# define machine_is_neo1973_gta02() (machine_arch_type == MACH_TYPE_NEO1973_GTA02) -#else -# define machine_is_neo1973_gta02() (0) -#endif - -#ifdef CONFIG_MACH_AT91SAM9RLEK -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_AT91SAM9RLEK -# endif -# define machine_is_at91sam9rlek() (machine_arch_type == MACH_TYPE_AT91SAM9RLEK) -#else -# define machine_is_at91sam9rlek() (0) -#endif - -#ifdef CONFIG_MACH_COLIBRI320 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_COLIBRI320 -# endif -# define machine_is_colibri320() (machine_arch_type == MACH_TYPE_COLIBRI320) -#else -# define machine_is_colibri320() (0) -#endif - -#ifdef CONFIG_MACH_CAM60 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CAM60 -# endif -# define machine_is_cam60() (machine_arch_type == MACH_TYPE_CAM60) -#else -# define machine_is_cam60() (0) -#endif - -#ifdef CONFIG_MACH_AT91EB01 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_AT91EB01 -# endif -# define machine_is_at91eb01() (machine_arch_type == MACH_TYPE_AT91EB01) -#else -# define machine_is_at91eb01() (0) -#endif - -#ifdef CONFIG_MACH_DB88F5281 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DB88F5281 -# endif -# define machine_is_db88f5281() (machine_arch_type == MACH_TYPE_DB88F5281) -#else -# define machine_is_db88f5281() (0) -#endif - -#ifdef CONFIG_MACH_CSB726 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CSB726 -# endif -# define machine_is_csb726() (machine_arch_type == MACH_TYPE_CSB726) -#else -# define machine_is_csb726() (0) -#endif - -#ifdef CONFIG_MACH_DAVINCI_DM6467_EVM -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DAVINCI_DM6467_EVM -# endif -# define machine_is_davinci_dm6467_evm() (machine_arch_type == MACH_TYPE_DAVINCI_DM6467_EVM) -#else -# define machine_is_davinci_dm6467_evm() (0) -#endif - -#ifdef CONFIG_MACH_DAVINCI_DM355_EVM -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DAVINCI_DM355_EVM -# endif -# define machine_is_davinci_dm355_evm() (machine_arch_type == MACH_TYPE_DAVINCI_DM355_EVM) -#else -# define machine_is_davinci_dm355_evm() (0) -#endif - -#ifdef CONFIG_MACH_LITTLETON -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_LITTLETON -# endif -# define machine_is_littleton() (machine_arch_type == MACH_TYPE_LITTLETON) -#else -# define machine_is_littleton() (0) -#endif - -#ifdef CONFIG_MACH_REALVIEW_PB11MP -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_REALVIEW_PB11MP -# endif -# define machine_is_realview_pb11mp() (machine_arch_type == MACH_TYPE_REALVIEW_PB11MP) -#else -# define machine_is_realview_pb11mp() (0) -#endif - -#ifdef CONFIG_MACH_MX27_3DS -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MX27_3DS -# endif -# define machine_is_mx27_3ds() (machine_arch_type == MACH_TYPE_MX27_3DS) -#else -# define machine_is_mx27_3ds() (0) -#endif - -#ifdef CONFIG_MACH_HALIBUT -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_HALIBUT -# endif -# define machine_is_halibut() (machine_arch_type == MACH_TYPE_HALIBUT) -#else -# define machine_is_halibut() (0) -#endif - -#ifdef CONFIG_MACH_TROUT -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TROUT -# endif -# define machine_is_trout() (machine_arch_type == MACH_TYPE_TROUT) -#else -# define machine_is_trout() (0) -#endif - -#ifdef CONFIG_MACH_TCT_HAMMER -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TCT_HAMMER -# endif -# define machine_is_tct_hammer() (machine_arch_type == MACH_TYPE_TCT_HAMMER) -#else -# define machine_is_tct_hammer() (0) -#endif - -#ifdef CONFIG_MACH_HERALD -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_HERALD -# endif -# define machine_is_herald() (machine_arch_type == MACH_TYPE_HERALD) -#else -# define machine_is_herald() (0) -#endif - -#ifdef CONFIG_MACH_SIM_ONE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SIM_ONE -# endif -# define machine_is_sim_one() (machine_arch_type == MACH_TYPE_SIM_ONE) -#else -# define machine_is_sim_one() (0) -#endif - -#ifdef CONFIG_MACH_JIVE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_JIVE -# endif -# define machine_is_jive() (machine_arch_type == MACH_TYPE_JIVE) -#else -# define machine_is_jive() (0) -#endif - -#ifdef CONFIG_MACH_SAM9_L9260 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SAM9_L9260 -# endif -# define machine_is_sam9_l9260() (machine_arch_type == MACH_TYPE_SAM9_L9260) -#else -# define machine_is_sam9_l9260() (0) -#endif - -#ifdef CONFIG_MACH_REALVIEW_PB1176 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_REALVIEW_PB1176 -# endif -# define machine_is_realview_pb1176() (machine_arch_type == MACH_TYPE_REALVIEW_PB1176) -#else -# define machine_is_realview_pb1176() (0) -#endif - -#ifdef CONFIG_MACH_YL9200 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_YL9200 -# endif -# define machine_is_yl9200() (machine_arch_type == MACH_TYPE_YL9200) -#else -# define machine_is_yl9200() (0) -#endif - -#ifdef CONFIG_MACH_RD88F5182 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_RD88F5182 -# endif -# define machine_is_rd88f5182() (machine_arch_type == MACH_TYPE_RD88F5182) -#else -# define machine_is_rd88f5182() (0) -#endif - -#ifdef CONFIG_MACH_KUROBOX_PRO -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_KUROBOX_PRO -# endif -# define machine_is_kurobox_pro() (machine_arch_type == MACH_TYPE_KUROBOX_PRO) -#else -# define machine_is_kurobox_pro() (0) -#endif - -#ifdef CONFIG_MACH_MX31_3DS -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MX31_3DS -# endif -# define machine_is_mx31_3ds() (machine_arch_type == MACH_TYPE_MX31_3DS) -#else -# define machine_is_mx31_3ds() (0) -#endif - -#ifdef CONFIG_MACH_QONG -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_QONG -# endif -# define machine_is_qong() (machine_arch_type == MACH_TYPE_QONG) -#else -# define machine_is_qong() (0) -#endif - -#ifdef CONFIG_MACH_OMAP2EVM -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OMAP2EVM -# endif -# define machine_is_omap2evm() (machine_arch_type == MACH_TYPE_OMAP2EVM) -#else -# define machine_is_omap2evm() (0) -#endif - -#ifdef CONFIG_MACH_OMAP3EVM -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OMAP3EVM -# endif -# define machine_is_omap3evm() (machine_arch_type == MACH_TYPE_OMAP3EVM) -#else -# define machine_is_omap3evm() (0) -#endif - -#ifdef CONFIG_MACH_DNS323 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DNS323 -# endif -# define machine_is_dns323() (machine_arch_type == MACH_TYPE_DNS323) -#else -# define machine_is_dns323() (0) -#endif - -#ifdef CONFIG_MACH_OMAP3_BEAGLE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OMAP3_BEAGLE -# endif -# define machine_is_omap3_beagle() (machine_arch_type == MACH_TYPE_OMAP3_BEAGLE) -#else -# define machine_is_omap3_beagle() (0) -#endif - -#ifdef CONFIG_MACH_NOKIA_N810 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NOKIA_N810 -# endif -# define machine_is_nokia_n810() (machine_arch_type == MACH_TYPE_NOKIA_N810) -#else -# define machine_is_nokia_n810() (0) -#endif - -#ifdef CONFIG_MACH_PCM038 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_PCM038 -# endif -# define machine_is_pcm038() (machine_arch_type == MACH_TYPE_PCM038) -#else -# define machine_is_pcm038() (0) -#endif - -#ifdef CONFIG_MACH_TS209 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TS209 -# endif -# define machine_is_ts_x09() (machine_arch_type == MACH_TYPE_TS209) -#else -# define machine_is_ts_x09() (0) -#endif - -#ifdef CONFIG_MACH_AT91CAP9ADK -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_AT91CAP9ADK -# endif -# define machine_is_at91cap9adk() (machine_arch_type == MACH_TYPE_AT91CAP9ADK) -#else -# define machine_is_at91cap9adk() (0) -#endif - -#ifdef CONFIG_MACH_MX31MOBOARD -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MX31MOBOARD -# endif -# define machine_is_mx31moboard() (machine_arch_type == MACH_TYPE_MX31MOBOARD) -#else -# define machine_is_mx31moboard() (0) -#endif - -#ifdef CONFIG_MACH_TERASTATION_PRO2 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TERASTATION_PRO2 -# endif -# define machine_is_terastation_pro2() (machine_arch_type == MACH_TYPE_TERASTATION_PRO2) -#else -# define machine_is_terastation_pro2() (0) -#endif - -#ifdef CONFIG_MACH_LINKSTATION_PRO -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_LINKSTATION_PRO -# endif -# define machine_is_linkstation_pro() (machine_arch_type == MACH_TYPE_LINKSTATION_PRO) -#else -# define machine_is_linkstation_pro() (0) -#endif - -#ifdef CONFIG_MACH_E350 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_E350 -# endif -# define machine_is_e350() (machine_arch_type == MACH_TYPE_E350) -#else -# define machine_is_e350() (0) -#endif - -#ifdef CONFIG_MACH_TS409 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TS409 -# endif -# define machine_is_ts409() (machine_arch_type == MACH_TYPE_TS409) -#else -# define machine_is_ts409() (0) -#endif - -#ifdef CONFIG_MACH_CM_X300 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CM_X300 -# endif -# define machine_is_cm_x300() (machine_arch_type == MACH_TYPE_CM_X300) -#else -# define machine_is_cm_x300() (0) -#endif - -#ifdef CONFIG_MACH_AT91SAM9G20EK -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_AT91SAM9G20EK -# endif -# define machine_is_at91sam9g20ek() (machine_arch_type == MACH_TYPE_AT91SAM9G20EK) -#else -# define machine_is_at91sam9g20ek() (0) -#endif - -#ifdef CONFIG_MACH_SMDK6410 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SMDK6410 -# endif -# define machine_is_smdk6410() (machine_arch_type == MACH_TYPE_SMDK6410) -#else -# define machine_is_smdk6410() (0) -#endif - -#ifdef CONFIG_MACH_U300 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_U300 -# endif -# define machine_is_u300() (machine_arch_type == MACH_TYPE_U300) -#else -# define machine_is_u300() (0) -#endif - -#ifdef CONFIG_MACH_WRT350N_V2 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_WRT350N_V2 -# endif -# define machine_is_wrt350n_v2() (machine_arch_type == MACH_TYPE_WRT350N_V2) -#else -# define machine_is_wrt350n_v2() (0) -#endif - -#ifdef CONFIG_MACH_OMAP_LDP -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OMAP_LDP -# endif -# define machine_is_omap_ldp() (machine_arch_type == MACH_TYPE_OMAP_LDP) -#else -# define machine_is_omap_ldp() (0) -#endif - -#ifdef CONFIG_MACH_MX35_3DS -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MX35_3DS -# endif -# define machine_is_mx35_3ds() (machine_arch_type == MACH_TYPE_MX35_3DS) -#else -# define machine_is_mx35_3ds() (0) -#endif - -#ifdef CONFIG_MACH_NEUROS_OSD2 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NEUROS_OSD2 -# endif -# define machine_is_neuros_osd2() (machine_arch_type == MACH_TYPE_NEUROS_OSD2) -#else -# define machine_is_neuros_osd2() (0) -#endif - -#ifdef CONFIG_MACH_TRIZEPS4WL -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TRIZEPS4WL -# endif -# define machine_is_trizeps4wl() (machine_arch_type == MACH_TYPE_TRIZEPS4WL) -#else -# define machine_is_trizeps4wl() (0) -#endif - -#ifdef CONFIG_MACH_TS78XX -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TS78XX -# endif -# define machine_is_ts78xx() (machine_arch_type == MACH_TYPE_TS78XX) -#else -# define machine_is_ts78xx() (0) -#endif - -#ifdef CONFIG_MACH_SFFSDR -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SFFSDR -# endif -# define machine_is_sffsdr() (machine_arch_type == MACH_TYPE_SFFSDR) -#else -# define machine_is_sffsdr() (0) -#endif - -#ifdef CONFIG_MACH_PCM037 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_PCM037 -# endif -# define machine_is_pcm037() (machine_arch_type == MACH_TYPE_PCM037) -#else -# define machine_is_pcm037() (0) -#endif - -#ifdef CONFIG_MACH_DB88F6281_BP -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DB88F6281_BP -# endif -# define machine_is_db88f6281_bp() (machine_arch_type == MACH_TYPE_DB88F6281_BP) -#else -# define machine_is_db88f6281_bp() (0) -#endif - -#ifdef CONFIG_MACH_RD88F6192_NAS -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_RD88F6192_NAS -# endif -# define machine_is_rd88f6192_nas() (machine_arch_type == MACH_TYPE_RD88F6192_NAS) -#else -# define machine_is_rd88f6192_nas() (0) -#endif - -#ifdef CONFIG_MACH_RD88F6281 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_RD88F6281 -# endif -# define machine_is_rd88f6281() (machine_arch_type == MACH_TYPE_RD88F6281) -#else -# define machine_is_rd88f6281() (0) -#endif - -#ifdef CONFIG_MACH_DB78X00_BP -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DB78X00_BP -# endif -# define machine_is_db78x00_bp() (machine_arch_type == MACH_TYPE_DB78X00_BP) -#else -# define machine_is_db78x00_bp() (0) -#endif - -#ifdef CONFIG_MACH_SMDK2416 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SMDK2416 -# endif -# define machine_is_smdk2416() (machine_arch_type == MACH_TYPE_SMDK2416) -#else -# define machine_is_smdk2416() (0) -#endif - -#ifdef CONFIG_MACH_WBD111 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_WBD111 -# endif -# define machine_is_wbd111() (machine_arch_type == MACH_TYPE_WBD111) -#else -# define machine_is_wbd111() (0) -#endif - -#ifdef CONFIG_MACH_MV2120 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MV2120 -# endif -# define machine_is_mv2120() (machine_arch_type == MACH_TYPE_MV2120) -#else -# define machine_is_mv2120() (0) -#endif - -#ifdef CONFIG_MACH_MX51_3DS -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MX51_3DS -# endif -# define machine_is_mx51_3ds() (machine_arch_type == MACH_TYPE_MX51_3DS) -#else -# define machine_is_mx51_3ds() (0) -#endif - -#ifdef CONFIG_MACH_IMX27LITE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_IMX27LITE -# endif -# define machine_is_imx27lite() (machine_arch_type == MACH_TYPE_IMX27LITE) -#else -# define machine_is_imx27lite() (0) -#endif - -#ifdef CONFIG_MACH_USB_A9260 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_USB_A9260 -# endif -# define machine_is_usb_a9260() (machine_arch_type == MACH_TYPE_USB_A9260) -#else -# define machine_is_usb_a9260() (0) -#endif - -#ifdef CONFIG_MACH_USB_A9263 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_USB_A9263 -# endif -# define machine_is_usb_a9263() (machine_arch_type == MACH_TYPE_USB_A9263) -#else -# define machine_is_usb_a9263() (0) -#endif - -#ifdef CONFIG_MACH_QIL_A9260 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_QIL_A9260 -# endif -# define machine_is_qil_a9260() (machine_arch_type == MACH_TYPE_QIL_A9260) -#else -# define machine_is_qil_a9260() (0) -#endif - -#ifdef CONFIG_MACH_KZM_ARM11_01 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_KZM_ARM11_01 -# endif -# define machine_is_kzm_arm11_01() (machine_arch_type == MACH_TYPE_KZM_ARM11_01) -#else -# define machine_is_kzm_arm11_01() (0) -#endif - -#ifdef CONFIG_MACH_NOKIA_N810_WIMAX -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NOKIA_N810_WIMAX -# endif -# define machine_is_nokia_n810_wimax() (machine_arch_type == MACH_TYPE_NOKIA_N810_WIMAX) -#else -# define machine_is_nokia_n810_wimax() (0) -#endif - -#ifdef CONFIG_MACH_SAPPHIRE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SAPPHIRE -# endif -# define machine_is_sapphire() (machine_arch_type == MACH_TYPE_SAPPHIRE) -#else -# define machine_is_sapphire() (0) -#endif - -#ifdef CONFIG_MACH_STMP37XX -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_STMP37XX -# endif -# define machine_is_stmp37xx() (machine_arch_type == MACH_TYPE_STMP37XX) -#else -# define machine_is_stmp37xx() (0) -#endif - -#ifdef CONFIG_MACH_STMP378X -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_STMP378X -# endif -# define machine_is_stmp378x() (machine_arch_type == MACH_TYPE_STMP378X) -#else -# define machine_is_stmp378x() (0) -#endif - -#ifdef CONFIG_MACH_EZX_A780 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_EZX_A780 -# endif -# define machine_is_ezx_a780() (machine_arch_type == MACH_TYPE_EZX_A780) -#else -# define machine_is_ezx_a780() (0) -#endif - -#ifdef CONFIG_MACH_EZX_E680 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_EZX_E680 -# endif -# define machine_is_ezx_e680() (machine_arch_type == MACH_TYPE_EZX_E680) -#else -# define machine_is_ezx_e680() (0) -#endif - -#ifdef CONFIG_MACH_EZX_A1200 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_EZX_A1200 -# endif -# define machine_is_ezx_a1200() (machine_arch_type == MACH_TYPE_EZX_A1200) -#else -# define machine_is_ezx_a1200() (0) -#endif - -#ifdef CONFIG_MACH_EZX_E6 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_EZX_E6 -# endif -# define machine_is_ezx_e6() (machine_arch_type == MACH_TYPE_EZX_E6) -#else -# define machine_is_ezx_e6() (0) -#endif - -#ifdef CONFIG_MACH_EZX_E2 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_EZX_E2 -# endif -# define machine_is_ezx_e2() (machine_arch_type == MACH_TYPE_EZX_E2) -#else -# define machine_is_ezx_e2() (0) -#endif - -#ifdef CONFIG_MACH_EZX_A910 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_EZX_A910 -# endif -# define machine_is_ezx_a910() (machine_arch_type == MACH_TYPE_EZX_A910) -#else -# define machine_is_ezx_a910() (0) -#endif - -#ifdef CONFIG_MACH_EDMINI_V2 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_EDMINI_V2 -# endif -# define machine_is_edmini_v2() (machine_arch_type == MACH_TYPE_EDMINI_V2) -#else -# define machine_is_edmini_v2() (0) -#endif - -#ifdef CONFIG_MACH_ZIPIT2 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ZIPIT2 -# endif -# define machine_is_zipit2() (machine_arch_type == MACH_TYPE_ZIPIT2) -#else -# define machine_is_zipit2() (0) -#endif - -#ifdef CONFIG_MACH_OMAP3_PANDORA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OMAP3_PANDORA -# endif -# define machine_is_omap3_pandora() (machine_arch_type == MACH_TYPE_OMAP3_PANDORA) -#else -# define machine_is_omap3_pandora() (0) -#endif - -#ifdef CONFIG_MACH_MSS2 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MSS2 -# endif -# define machine_is_mss2() (machine_arch_type == MACH_TYPE_MSS2) -#else -# define machine_is_mss2() (0) -#endif - -#ifdef CONFIG_MACH_LB88RC8480 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_LB88RC8480 -# endif -# define machine_is_lb88rc8480() (machine_arch_type == MACH_TYPE_LB88RC8480) -#else -# define machine_is_lb88rc8480() (0) -#endif - -#ifdef CONFIG_MACH_MX25_3DS -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MX25_3DS -# endif -# define machine_is_mx25_3ds() (machine_arch_type == MACH_TYPE_MX25_3DS) -#else -# define machine_is_mx25_3ds() (0) -#endif - -#ifdef CONFIG_MACH_OMAP3530_LV_SOM -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OMAP3530_LV_SOM -# endif -# define machine_is_omap3530_lv_som() (machine_arch_type == MACH_TYPE_OMAP3530_LV_SOM) -#else -# define machine_is_omap3530_lv_som() (0) -#endif - -#ifdef CONFIG_MACH_DAVINCI_DA830_EVM -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DAVINCI_DA830_EVM -# endif -# define machine_is_davinci_da830_evm() (machine_arch_type == MACH_TYPE_DAVINCI_DA830_EVM) -#else -# define machine_is_davinci_da830_evm() (0) -#endif - -#ifdef CONFIG_MACH_AT572D940HFEB -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_AT572D940HFEB -# endif -# define machine_is_at572d940hfek() (machine_arch_type == MACH_TYPE_AT572D940HFEB) -#else -# define machine_is_at572d940hfek() (0) -#endif - -#ifdef CONFIG_MACH_DOVE_DB -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DOVE_DB -# endif -# define machine_is_dove_db() (machine_arch_type == MACH_TYPE_DOVE_DB) -#else -# define machine_is_dove_db() (0) -#endif - -#ifdef CONFIG_MACH_OVERO -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OVERO -# endif -# define machine_is_overo() (machine_arch_type == MACH_TYPE_OVERO) -#else -# define machine_is_overo() (0) -#endif - -#ifdef CONFIG_MACH_AT2440EVB -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_AT2440EVB -# endif -# define machine_is_at2440evb() (machine_arch_type == MACH_TYPE_AT2440EVB) -#else -# define machine_is_at2440evb() (0) -#endif - -#ifdef CONFIG_MACH_NEOCORE926 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NEOCORE926 -# endif -# define machine_is_neocore926() (machine_arch_type == MACH_TYPE_NEOCORE926) -#else -# define machine_is_neocore926() (0) -#endif - -#ifdef CONFIG_MACH_WNR854T -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_WNR854T -# endif -# define machine_is_wnr854t() (machine_arch_type == MACH_TYPE_WNR854T) -#else -# define machine_is_wnr854t() (0) -#endif - -#ifdef CONFIG_MACH_RD88F5181L_GE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_RD88F5181L_GE -# endif -# define machine_is_rd88f5181l_ge() (machine_arch_type == MACH_TYPE_RD88F5181L_GE) -#else -# define machine_is_rd88f5181l_ge() (0) -#endif - -#ifdef CONFIG_MACH_RD88F5181L_FXO -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_RD88F5181L_FXO -# endif -# define machine_is_rd88f5181l_fxo() (machine_arch_type == MACH_TYPE_RD88F5181L_FXO) -#else -# define machine_is_rd88f5181l_fxo() (0) -#endif - -#ifdef CONFIG_MACH_STAMP9G20 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_STAMP9G20 -# endif -# define machine_is_stamp9g20() (machine_arch_type == MACH_TYPE_STAMP9G20) -#else -# define machine_is_stamp9g20() (0) -#endif - -#ifdef CONFIG_MACH_SMDKC100 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SMDKC100 -# endif -# define machine_is_smdkc100() (machine_arch_type == MACH_TYPE_SMDKC100) -#else -# define machine_is_smdkc100() (0) -#endif - -#ifdef CONFIG_MACH_TAVOREVB -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TAVOREVB -# endif -# define machine_is_tavorevb() (machine_arch_type == MACH_TYPE_TAVOREVB) -#else -# define machine_is_tavorevb() (0) -#endif - -#ifdef CONFIG_MACH_SAAR -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SAAR -# endif -# define machine_is_saar() (machine_arch_type == MACH_TYPE_SAAR) -#else -# define machine_is_saar() (0) -#endif - -#ifdef CONFIG_MACH_AT91SAM9M10G45EK -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_AT91SAM9M10G45EK -# endif -# define machine_is_at91sam9m10g45ek() (machine_arch_type == MACH_TYPE_AT91SAM9M10G45EK) -#else -# define machine_is_at91sam9m10g45ek() (0) -#endif - -#ifdef CONFIG_MACH_MXLADS -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MXLADS -# endif -# define machine_is_mxlads() (machine_arch_type == MACH_TYPE_MXLADS) -#else -# define machine_is_mxlads() (0) -#endif - -#ifdef CONFIG_MACH_LINKSTATION_MINI -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_LINKSTATION_MINI -# endif -# define machine_is_linkstation_mini() (machine_arch_type == MACH_TYPE_LINKSTATION_MINI) -#else -# define machine_is_linkstation_mini() (0) -#endif - -#ifdef CONFIG_MACH_AFEB9260 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_AFEB9260 -# endif -# define machine_is_afeb9260() (machine_arch_type == MACH_TYPE_AFEB9260) -#else -# define machine_is_afeb9260() (0) -#endif - -#ifdef CONFIG_MACH_IMX27IPCAM -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_IMX27IPCAM -# endif -# define machine_is_imx27ipcam() (machine_arch_type == MACH_TYPE_IMX27IPCAM) -#else -# define machine_is_imx27ipcam() (0) -#endif - -#ifdef CONFIG_MACH_RD88F6183AP_GE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_RD88F6183AP_GE -# endif -# define machine_is_rd88f6183ap_ge() (machine_arch_type == MACH_TYPE_RD88F6183AP_GE) -#else -# define machine_is_rd88f6183ap_ge() (0) -#endif - -#ifdef CONFIG_MACH_REALVIEW_PBA8 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_REALVIEW_PBA8 -# endif -# define machine_is_realview_pba8() (machine_arch_type == MACH_TYPE_REALVIEW_PBA8) -#else -# define machine_is_realview_pba8() (0) -#endif - -#ifdef CONFIG_MACH_REALVIEW_PBX -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_REALVIEW_PBX -# endif -# define machine_is_realview_pbx() (machine_arch_type == MACH_TYPE_REALVIEW_PBX) -#else -# define machine_is_realview_pbx() (0) -#endif - -#ifdef CONFIG_MACH_MICRO9S -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MICRO9S -# endif -# define machine_is_micro9s() (machine_arch_type == MACH_TYPE_MICRO9S) -#else -# define machine_is_micro9s() (0) -#endif - -#ifdef CONFIG_MACH_RUT100 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_RUT100 -# endif -# define machine_is_rut100() (machine_arch_type == MACH_TYPE_RUT100) -#else -# define machine_is_rut100() (0) -#endif - -#ifdef CONFIG_MACH_G3EVM -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_G3EVM -# endif -# define machine_is_g3evm() (machine_arch_type == MACH_TYPE_G3EVM) -#else -# define machine_is_g3evm() (0) -#endif - -#ifdef CONFIG_MACH_W90P910EVB -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_W90P910EVB -# endif -# define machine_is_w90p910evb() (machine_arch_type == MACH_TYPE_W90P910EVB) -#else -# define machine_is_w90p910evb() (0) -#endif - -#ifdef CONFIG_MACH_W90P950EVB -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_W90P950EVB -# endif -# define machine_is_w90p950evb() (machine_arch_type == MACH_TYPE_W90P950EVB) -#else -# define machine_is_w90p950evb() (0) -#endif - -#ifdef CONFIG_MACH_W90N960EVB -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_W90N960EVB -# endif -# define machine_is_w90n960evb() (machine_arch_type == MACH_TYPE_W90N960EVB) -#else -# define machine_is_w90n960evb() (0) -#endif - -#ifdef CONFIG_MACH_MV88F6281GTW_GE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MV88F6281GTW_GE -# endif -# define machine_is_mv88f6281gtw_ge() (machine_arch_type == MACH_TYPE_MV88F6281GTW_GE) -#else -# define machine_is_mv88f6281gtw_ge() (0) -#endif - -#ifdef CONFIG_MACH_NCP -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NCP -# endif -# define machine_is_ncp() (machine_arch_type == MACH_TYPE_NCP) -#else -# define machine_is_ncp() (0) -#endif - -#ifdef CONFIG_MACH_DAVINCI_DM365_EVM -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DAVINCI_DM365_EVM -# endif -# define machine_is_davinci_dm365_evm() (machine_arch_type == MACH_TYPE_DAVINCI_DM365_EVM) -#else -# define machine_is_davinci_dm365_evm() (0) -#endif - -#ifdef CONFIG_MACH_CENTRO -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CENTRO -# endif -# define machine_is_centro() (machine_arch_type == MACH_TYPE_CENTRO) -#else -# define machine_is_centro() (0) -#endif - -#ifdef CONFIG_MACH_NOKIA_RX51 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NOKIA_RX51 -# endif -# define machine_is_nokia_rx51() (machine_arch_type == MACH_TYPE_NOKIA_RX51) -#else -# define machine_is_nokia_rx51() (0) -#endif - -#ifdef CONFIG_MACH_OMAP_ZOOM2 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OMAP_ZOOM2 -# endif -# define machine_is_omap_zoom2() (machine_arch_type == MACH_TYPE_OMAP_ZOOM2) -#else -# define machine_is_omap_zoom2() (0) -#endif - -#ifdef CONFIG_MACH_ACS5K -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ACS5K -# endif -# define machine_is_acs5k() (machine_arch_type == MACH_TYPE_ACS5K) -#else -# define machine_is_acs5k() (0) -#endif - -#ifdef CONFIG_MACH_SNAPPER_9260 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SNAPPER_9260 -# endif -# define machine_is_snapper_9260() (machine_arch_type == MACH_TYPE_SNAPPER_9260) -#else -# define machine_is_snapper_9260() (0) -#endif - -#ifdef CONFIG_MACH_DSM320 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DSM320 -# endif -# define machine_is_dsm320() (machine_arch_type == MACH_TYPE_DSM320) -#else -# define machine_is_dsm320() (0) -#endif - -#ifdef CONFIG_MACH_EXEDA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_EXEDA -# endif -# define machine_is_exeda() (machine_arch_type == MACH_TYPE_EXEDA) -#else -# define machine_is_exeda() (0) -#endif - -#ifdef CONFIG_MACH_MINI2440 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MINI2440 -# endif -# define machine_is_mini2440() (machine_arch_type == MACH_TYPE_MINI2440) -#else -# define machine_is_mini2440() (0) -#endif - -#ifdef CONFIG_MACH_COLIBRI300 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_COLIBRI300 -# endif -# define machine_is_colibri300() (machine_arch_type == MACH_TYPE_COLIBRI300) -#else -# define machine_is_colibri300() (0) -#endif - -#ifdef CONFIG_MACH_LINKSTATION_LS_HGL -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_LINKSTATION_LS_HGL -# endif -# define machine_is_linkstation_ls_hgl() (machine_arch_type == MACH_TYPE_LINKSTATION_LS_HGL) -#else -# define machine_is_linkstation_ls_hgl() (0) -#endif - -#ifdef CONFIG_MACH_CPUAT9G20 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CPUAT9G20 -# endif -# define machine_is_cpuat9g20() (machine_arch_type == MACH_TYPE_CPUAT9G20) -#else -# define machine_is_cpuat9g20() (0) -#endif - -#ifdef CONFIG_MACH_SMDK6440 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SMDK6440 -# endif -# define machine_is_smdk6440() (machine_arch_type == MACH_TYPE_SMDK6440) -#else -# define machine_is_smdk6440() (0) -#endif - -#ifdef CONFIG_MACH_NAS4220B -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NAS4220B -# endif -# define machine_is_nas4220b() (machine_arch_type == MACH_TYPE_NAS4220B) -#else -# define machine_is_nas4220b() (0) -#endif - -#ifdef CONFIG_MACH_ZYLONITE2 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ZYLONITE2 -# endif -# define machine_is_zylonite2() (machine_arch_type == MACH_TYPE_ZYLONITE2) -#else -# define machine_is_zylonite2() (0) -#endif - -#ifdef CONFIG_MACH_ASPENITE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ASPENITE -# endif -# define machine_is_aspenite() (machine_arch_type == MACH_TYPE_ASPENITE) -#else -# define machine_is_aspenite() (0) -#endif - -#ifdef CONFIG_MACH_TTC_DKB -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TTC_DKB -# endif -# define machine_is_ttc_dkb() (machine_arch_type == MACH_TYPE_TTC_DKB) -#else -# define machine_is_ttc_dkb() (0) -#endif - -#ifdef CONFIG_MACH_PCM043 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_PCM043 -# endif -# define machine_is_pcm043() (machine_arch_type == MACH_TYPE_PCM043) -#else -# define machine_is_pcm043() (0) -#endif - -#ifdef CONFIG_MACH_SHEEVAPLUG -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SHEEVAPLUG -# endif -# define machine_is_sheevaplug() (machine_arch_type == MACH_TYPE_SHEEVAPLUG) -#else -# define machine_is_sheevaplug() (0) -#endif - -#ifdef CONFIG_MACH_AVENGERS_LITE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_AVENGERS_LITE -# endif -# define machine_is_avengers_lite() (machine_arch_type == MACH_TYPE_AVENGERS_LITE) -#else -# define machine_is_avengers_lite() (0) -#endif - -#ifdef CONFIG_MACH_MX51_BABBAGE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MX51_BABBAGE -# endif -# define machine_is_mx51_babbage() (machine_arch_type == MACH_TYPE_MX51_BABBAGE) -#else -# define machine_is_mx51_babbage() (0) -#endif - -#ifdef CONFIG_MACH_RD78X00_MASA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_RD78X00_MASA -# endif -# define machine_is_rd78x00_masa() (machine_arch_type == MACH_TYPE_RD78X00_MASA) -#else -# define machine_is_rd78x00_masa() (0) -#endif - -#ifdef CONFIG_MACH_DM355_LEOPARD -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DM355_LEOPARD -# endif -# define machine_is_dm355_leopard() (machine_arch_type == MACH_TYPE_DM355_LEOPARD) -#else -# define machine_is_dm355_leopard() (0) -#endif - -#ifdef CONFIG_MACH_TS219 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TS219 -# endif -# define machine_is_ts219() (machine_arch_type == MACH_TYPE_TS219) -#else -# define machine_is_ts219() (0) -#endif - -#ifdef CONFIG_MACH_PCA100 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_PCA100 -# endif -# define machine_is_pca100() (machine_arch_type == MACH_TYPE_PCA100) -#else -# define machine_is_pca100() (0) -#endif - -#ifdef CONFIG_MACH_DAVINCI_DA850_EVM -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DAVINCI_DA850_EVM -# endif -# define machine_is_davinci_da850_evm() (machine_arch_type == MACH_TYPE_DAVINCI_DA850_EVM) -#else -# define machine_is_davinci_da850_evm() (0) -#endif - -#ifdef CONFIG_MACH_AT91SAM9G10EK -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_AT91SAM9G10EK -# endif -# define machine_is_at91sam9g10ek() (machine_arch_type == MACH_TYPE_AT91SAM9G10EK) -#else -# define machine_is_at91sam9g10ek() (0) -#endif - -#ifdef CONFIG_MACH_OMAP_4430SDP -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OMAP_4430SDP -# endif -# define machine_is_omap_4430sdp() (machine_arch_type == MACH_TYPE_OMAP_4430SDP) -#else -# define machine_is_omap_4430sdp() (0) -#endif - -#ifdef CONFIG_MACH_MAGX_ZN5 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MAGX_ZN5 -# endif -# define machine_is_magx_zn5() (machine_arch_type == MACH_TYPE_MAGX_ZN5) -#else -# define machine_is_magx_zn5() (0) -#endif - -#ifdef CONFIG_MACH_BTMAVB101 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_BTMAVB101 -# endif -# define machine_is_btmavb101() (machine_arch_type == MACH_TYPE_BTMAVB101) -#else -# define machine_is_btmavb101() (0) -#endif - -#ifdef CONFIG_MACH_BTMAWB101 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_BTMAWB101 -# endif -# define machine_is_btmawb101() (machine_arch_type == MACH_TYPE_BTMAWB101) -#else -# define machine_is_btmawb101() (0) -#endif - -#ifdef CONFIG_MACH_OMAP3_TORPEDO -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OMAP3_TORPEDO -# endif -# define machine_is_omap3_torpedo() (machine_arch_type == MACH_TYPE_OMAP3_TORPEDO) -#else -# define machine_is_omap3_torpedo() (0) -#endif - -#ifdef CONFIG_MACH_ANW6410 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ANW6410 -# endif -# define machine_is_anw6410() (machine_arch_type == MACH_TYPE_ANW6410) -#else -# define machine_is_anw6410() (0) -#endif - -#ifdef CONFIG_MACH_IMX27_VISSTRIM_M10 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_IMX27_VISSTRIM_M10 -# endif -# define machine_is_imx27_visstrim_m10() (machine_arch_type == MACH_TYPE_IMX27_VISSTRIM_M10) -#else -# define machine_is_imx27_visstrim_m10() (0) -#endif - -#ifdef CONFIG_MACH_PORTUXG20 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_PORTUXG20 -# endif -# define machine_is_portuxg20() (machine_arch_type == MACH_TYPE_PORTUXG20) -#else -# define machine_is_portuxg20() (0) -#endif - -#ifdef CONFIG_MACH_SMDKC110 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SMDKC110 -# endif -# define machine_is_smdkc110() (machine_arch_type == MACH_TYPE_SMDKC110) -#else -# define machine_is_smdkc110() (0) -#endif - -#ifdef CONFIG_MACH_OMAP3517EVM -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OMAP3517EVM -# endif -# define machine_is_omap3517evm() (machine_arch_type == MACH_TYPE_OMAP3517EVM) -#else -# define machine_is_omap3517evm() (0) -#endif - -#ifdef CONFIG_MACH_NETSPACE_V2 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NETSPACE_V2 -# endif -# define machine_is_netspace_v2() (machine_arch_type == MACH_TYPE_NETSPACE_V2) -#else -# define machine_is_netspace_v2() (0) -#endif - -#ifdef CONFIG_MACH_NETSPACE_MAX_V2 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NETSPACE_MAX_V2 -# endif -# define machine_is_netspace_max_v2() (machine_arch_type == MACH_TYPE_NETSPACE_MAX_V2) -#else -# define machine_is_netspace_max_v2() (0) -#endif - -#ifdef CONFIG_MACH_D2NET_V2 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_D2NET_V2 -# endif -# define machine_is_d2net_v2() (machine_arch_type == MACH_TYPE_D2NET_V2) -#else -# define machine_is_d2net_v2() (0) -#endif - -#ifdef CONFIG_MACH_NET2BIG_V2 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NET2BIG_V2 -# endif -# define machine_is_net2big_v2() (machine_arch_type == MACH_TYPE_NET2BIG_V2) -#else -# define machine_is_net2big_v2() (0) -#endif - -#ifdef CONFIG_MACH_NET5BIG_V2 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NET5BIG_V2 -# endif -# define machine_is_net5big_v2() (machine_arch_type == MACH_TYPE_NET5BIG_V2) -#else -# define machine_is_net5big_v2() (0) -#endif - -#ifdef CONFIG_MACH_INETSPACE_V2 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_INETSPACE_V2 -# endif -# define machine_is_inetspace_v2() (machine_arch_type == MACH_TYPE_INETSPACE_V2) -#else -# define machine_is_inetspace_v2() (0) -#endif - -#ifdef CONFIG_MACH_AT91SAM9G45EKES -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_AT91SAM9G45EKES -# endif -# define machine_is_at91sam9g45ekes() (machine_arch_type == MACH_TYPE_AT91SAM9G45EKES) -#else -# define machine_is_at91sam9g45ekes() (0) -#endif - -#ifdef CONFIG_MACH_PC7302 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_PC7302 -# endif -# define machine_is_pc7302() (machine_arch_type == MACH_TYPE_PC7302) -#else -# define machine_is_pc7302() (0) -#endif - -#ifdef CONFIG_MACH_SPEAR600 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SPEAR600 -# endif -# define machine_is_spear600() (machine_arch_type == MACH_TYPE_SPEAR600) -#else -# define machine_is_spear600() (0) -#endif - -#ifdef CONFIG_MACH_SPEAR300 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SPEAR300 -# endif -# define machine_is_spear300() (machine_arch_type == MACH_TYPE_SPEAR300) -#else -# define machine_is_spear300() (0) -#endif - -#ifdef CONFIG_MACH_LILLY1131 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_LILLY1131 -# endif -# define machine_is_lilly1131() (machine_arch_type == MACH_TYPE_LILLY1131) -#else -# define machine_is_lilly1131() (0) -#endif - -#ifdef CONFIG_MACH_HMT -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_HMT -# endif -# define machine_is_hmt() (machine_arch_type == MACH_TYPE_HMT) -#else -# define machine_is_hmt() (0) -#endif - -#ifdef CONFIG_MACH_VEXPRESS -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_VEXPRESS -# endif -# define machine_is_vexpress() (machine_arch_type == MACH_TYPE_VEXPRESS) -#else -# define machine_is_vexpress() (0) -#endif - -#ifdef CONFIG_MACH_D2NET -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_D2NET -# endif -# define machine_is_d2net() (machine_arch_type == MACH_TYPE_D2NET) -#else -# define machine_is_d2net() (0) -#endif - -#ifdef CONFIG_MACH_BIGDISK -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_BIGDISK -# endif -# define machine_is_bigdisk() (machine_arch_type == MACH_TYPE_BIGDISK) -#else -# define machine_is_bigdisk() (0) -#endif - -#ifdef CONFIG_MACH_AT91SAM9G20EK_2MMC -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_AT91SAM9G20EK_2MMC -# endif -# define machine_is_at91sam9g20ek_2mmc() (machine_arch_type == MACH_TYPE_AT91SAM9G20EK_2MMC) -#else -# define machine_is_at91sam9g20ek_2mmc() (0) -#endif - -#ifdef CONFIG_MACH_BCMRING -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_BCMRING -# endif -# define machine_is_bcmring() (machine_arch_type == MACH_TYPE_BCMRING) -#else -# define machine_is_bcmring() (0) -#endif - -#ifdef CONFIG_MACH_DP6XX -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DP6XX -# endif -# define machine_is_dp6xx() (machine_arch_type == MACH_TYPE_DP6XX) -#else -# define machine_is_dp6xx() (0) -#endif - -#ifdef CONFIG_MACH_MAHIMAHI -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MAHIMAHI -# endif -# define machine_is_mahimahi() (machine_arch_type == MACH_TYPE_MAHIMAHI) -#else -# define machine_is_mahimahi() (0) -#endif - -#ifdef CONFIG_MACH_SMDK6442 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SMDK6442 -# endif -# define machine_is_smdk6442() (machine_arch_type == MACH_TYPE_SMDK6442) -#else -# define machine_is_smdk6442() (0) -#endif - -#ifdef CONFIG_MACH_OPENRD_BASE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OPENRD_BASE -# endif -# define machine_is_openrd_base() (machine_arch_type == MACH_TYPE_OPENRD_BASE) -#else -# define machine_is_openrd_base() (0) -#endif - -#ifdef CONFIG_MACH_DEVKIT8000 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DEVKIT8000 -# endif -# define machine_is_devkit8000() (machine_arch_type == MACH_TYPE_DEVKIT8000) -#else -# define machine_is_devkit8000() (0) -#endif - -#ifdef CONFIG_MACH_MX51_EFIKAMX -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MX51_EFIKAMX -# endif -# define machine_is_mx51_efikamx() (machine_arch_type == MACH_TYPE_MX51_EFIKAMX) -#else -# define machine_is_mx51_efikamx() (0) -#endif - -#ifdef CONFIG_MACH_CM_T35 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CM_T35 -# endif -# define machine_is_cm_t35() (machine_arch_type == MACH_TYPE_CM_T35) -#else -# define machine_is_cm_t35() (0) -#endif - -#ifdef CONFIG_MACH_NET2BIG -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NET2BIG -# endif -# define machine_is_net2big() (machine_arch_type == MACH_TYPE_NET2BIG) -#else -# define machine_is_net2big() (0) -#endif - -#ifdef CONFIG_MACH_IGEP0020 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_IGEP0020 -# endif -# define machine_is_igep0020() (machine_arch_type == MACH_TYPE_IGEP0020) -#else -# define machine_is_igep0020() (0) -#endif - -#ifdef CONFIG_MACH_NUC932EVB -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NUC932EVB -# endif -# define machine_is_nuc932evb() (machine_arch_type == MACH_TYPE_NUC932EVB) -#else -# define machine_is_nuc932evb() (0) -#endif - -#ifdef CONFIG_MACH_OPENRD_CLIENT -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OPENRD_CLIENT -# endif -# define machine_is_openrd_client() (machine_arch_type == MACH_TYPE_OPENRD_CLIENT) -#else -# define machine_is_openrd_client() (0) -#endif - -#ifdef CONFIG_MACH_MX51_EFIKASB -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MX51_EFIKASB -# endif -# define machine_is_mx51_efikasb() (machine_arch_type == MACH_TYPE_MX51_EFIKASB) -#else -# define machine_is_mx51_efikasb() (0) -#endif - -#ifdef CONFIG_MACH_MARVELL_JASPER -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MARVELL_JASPER -# endif -# define machine_is_marvell_jasper() (machine_arch_type == MACH_TYPE_MARVELL_JASPER) -#else -# define machine_is_marvell_jasper() (0) -#endif - -#ifdef CONFIG_MACH_FLINT -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_FLINT -# endif -# define machine_is_flint() (machine_arch_type == MACH_TYPE_FLINT) -#else -# define machine_is_flint() (0) -#endif - -#ifdef CONFIG_MACH_TAVOREVB3 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TAVOREVB3 -# endif -# define machine_is_tavorevb3() (machine_arch_type == MACH_TYPE_TAVOREVB3) -#else -# define machine_is_tavorevb3() (0) -#endif - -#ifdef CONFIG_MACH_TOUCHBOOK -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TOUCHBOOK -# endif -# define machine_is_touchbook() (machine_arch_type == MACH_TYPE_TOUCHBOOK) -#else -# define machine_is_touchbook() (0) -#endif - -#ifdef CONFIG_MACH_RAUMFELD_RC -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_RAUMFELD_RC -# endif -# define machine_is_raumfeld_rc() (machine_arch_type == MACH_TYPE_RAUMFELD_RC) -#else -# define machine_is_raumfeld_rc() (0) -#endif - -#ifdef CONFIG_MACH_RAUMFELD_CONNECTOR -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_RAUMFELD_CONNECTOR -# endif -# define machine_is_raumfeld_connector() (machine_arch_type == MACH_TYPE_RAUMFELD_CONNECTOR) -#else -# define machine_is_raumfeld_connector() (0) -#endif - -#ifdef CONFIG_MACH_RAUMFELD_SPEAKER -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_RAUMFELD_SPEAKER -# endif -# define machine_is_raumfeld_speaker() (machine_arch_type == MACH_TYPE_RAUMFELD_SPEAKER) -#else -# define machine_is_raumfeld_speaker() (0) -#endif - -#ifdef CONFIG_MACH_TNETV107X -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TNETV107X -# endif -# define machine_is_tnetv107x() (machine_arch_type == MACH_TYPE_TNETV107X) -#else -# define machine_is_tnetv107x() (0) -#endif - -#ifdef CONFIG_MACH_SMDKV210 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SMDKV210 -# endif -# define machine_is_smdkv210() (machine_arch_type == MACH_TYPE_SMDKV210) -#else -# define machine_is_smdkv210() (0) -#endif - -#ifdef CONFIG_MACH_OMAP_ZOOM3 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OMAP_ZOOM3 -# endif -# define machine_is_omap_zoom3() (machine_arch_type == MACH_TYPE_OMAP_ZOOM3) -#else -# define machine_is_omap_zoom3() (0) -#endif - -#ifdef CONFIG_MACH_OMAP_3630SDP -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OMAP_3630SDP -# endif -# define machine_is_omap_3630sdp() (machine_arch_type == MACH_TYPE_OMAP_3630SDP) -#else -# define machine_is_omap_3630sdp() (0) -#endif - -#ifdef CONFIG_MACH_SMARTQ7 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SMARTQ7 -# endif -# define machine_is_smartq7() (machine_arch_type == MACH_TYPE_SMARTQ7) -#else -# define machine_is_smartq7() (0) -#endif - -#ifdef CONFIG_MACH_WATSON_EFM_PLUGIN -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_WATSON_EFM_PLUGIN -# endif -# define machine_is_watson_efm_plugin() (machine_arch_type == MACH_TYPE_WATSON_EFM_PLUGIN) -#else -# define machine_is_watson_efm_plugin() (0) -#endif - -#ifdef CONFIG_MACH_G4EVM -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_G4EVM -# endif -# define machine_is_g4evm() (machine_arch_type == MACH_TYPE_G4EVM) -#else -# define machine_is_g4evm() (0) -#endif - -#ifdef CONFIG_MACH_OMAPL138_HAWKBOARD -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OMAPL138_HAWKBOARD -# endif -# define machine_is_omapl138_hawkboard() (machine_arch_type == MACH_TYPE_OMAPL138_HAWKBOARD) -#else -# define machine_is_omapl138_hawkboard() (0) -#endif - -#ifdef CONFIG_MACH_TS41X -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TS41X -# endif -# define machine_is_ts41x() (machine_arch_type == MACH_TYPE_TS41X) -#else -# define machine_is_ts41x() (0) -#endif - -#ifdef CONFIG_MACH_PHY3250 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_PHY3250 -# endif -# define machine_is_phy3250() (machine_arch_type == MACH_TYPE_PHY3250) -#else -# define machine_is_phy3250() (0) -#endif - -#ifdef CONFIG_MACH_MINI6410 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MINI6410 -# endif -# define machine_is_mini6410() (machine_arch_type == MACH_TYPE_MINI6410) -#else -# define machine_is_mini6410() (0) -#endif - -#ifdef CONFIG_MACH_MX28EVK -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MX28EVK -# endif -# define machine_is_mx28evk() (machine_arch_type == MACH_TYPE_MX28EVK) -#else -# define machine_is_mx28evk() (0) -#endif - -#ifdef CONFIG_MACH_SMARTQ5 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SMARTQ5 -# endif -# define machine_is_smartq5() (machine_arch_type == MACH_TYPE_SMARTQ5) -#else -# define machine_is_smartq5() (0) -#endif - -#ifdef CONFIG_MACH_DAVINCI_DM6467TEVM -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DAVINCI_DM6467TEVM -# endif -# define machine_is_davinci_dm6467tevm() (machine_arch_type == MACH_TYPE_DAVINCI_DM6467TEVM) -#else -# define machine_is_davinci_dm6467tevm() (0) -#endif - -#ifdef CONFIG_MACH_MXT_TD60 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MXT_TD60 -# endif -# define machine_is_mxt_td60() (machine_arch_type == MACH_TYPE_MXT_TD60) -#else -# define machine_is_mxt_td60() (0) -#endif - -#ifdef CONFIG_MACH_RIOT_BEI2 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_RIOT_BEI2 -# endif -# define machine_is_riot_bei2() (machine_arch_type == MACH_TYPE_RIOT_BEI2) -#else -# define machine_is_riot_bei2() (0) -#endif - -#ifdef CONFIG_MACH_RIOT_X37 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_RIOT_X37 -# endif -# define machine_is_riot_x37() (machine_arch_type == MACH_TYPE_RIOT_X37) -#else -# define machine_is_riot_x37() (0) -#endif - -#ifdef CONFIG_MACH_CAPC7117 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CAPC7117 -# endif -# define machine_is_capc7117() (machine_arch_type == MACH_TYPE_CAPC7117) -#else -# define machine_is_capc7117() (0) -#endif - -#ifdef CONFIG_MACH_ICONTROL -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ICONTROL -# endif -# define machine_is_icontrol() (machine_arch_type == MACH_TYPE_ICONTROL) -#else -# define machine_is_icontrol() (0) -#endif - -#ifdef CONFIG_MACH_QSD8X50A_ST1_5 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_QSD8X50A_ST1_5 -# endif -# define machine_is_qsd8x50a_st1_5() (machine_arch_type == MACH_TYPE_QSD8X50A_ST1_5) -#else -# define machine_is_qsd8x50a_st1_5() (0) -#endif - -#ifdef CONFIG_MACH_MX23EVK -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MX23EVK -# endif -# define machine_is_mx23evk() (machine_arch_type == MACH_TYPE_MX23EVK) -#else -# define machine_is_mx23evk() (0) -#endif - -#ifdef CONFIG_MACH_AP4EVB -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_AP4EVB -# endif -# define machine_is_ap4evb() (machine_arch_type == MACH_TYPE_AP4EVB) -#else -# define machine_is_ap4evb() (0) -#endif - -#ifdef CONFIG_MACH_MITYOMAPL138 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MITYOMAPL138 -# endif -# define machine_is_mityomapl138() (machine_arch_type == MACH_TYPE_MITYOMAPL138) -#else -# define machine_is_mityomapl138() (0) -#endif - -#ifdef CONFIG_MACH_GURUPLUG -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_GURUPLUG -# endif -# define machine_is_guruplug() (machine_arch_type == MACH_TYPE_GURUPLUG) -#else -# define machine_is_guruplug() (0) -#endif - -#ifdef CONFIG_MACH_SPEAR310 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SPEAR310 -# endif -# define machine_is_spear310() (machine_arch_type == MACH_TYPE_SPEAR310) -#else -# define machine_is_spear310() (0) -#endif - -#ifdef CONFIG_MACH_SPEAR320 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SPEAR320 -# endif -# define machine_is_spear320() (machine_arch_type == MACH_TYPE_SPEAR320) -#else -# define machine_is_spear320() (0) -#endif - -#ifdef CONFIG_MACH_AQUILA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_AQUILA -# endif -# define machine_is_aquila() (machine_arch_type == MACH_TYPE_AQUILA) -#else -# define machine_is_aquila() (0) -#endif - -#ifdef CONFIG_MACH_ESATA_SHEEVAPLUG -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ESATA_SHEEVAPLUG -# endif -# define machine_is_sheeva_esata() (machine_arch_type == MACH_TYPE_ESATA_SHEEVAPLUG) -#else -# define machine_is_sheeva_esata() (0) -#endif - -#ifdef CONFIG_MACH_MSM7X30_SURF -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MSM7X30_SURF -# endif -# define machine_is_msm7x30_surf() (machine_arch_type == MACH_TYPE_MSM7X30_SURF) -#else -# define machine_is_msm7x30_surf() (0) -#endif - -#ifdef CONFIG_MACH_EA2478DEVKIT -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_EA2478DEVKIT -# endif -# define machine_is_ea2478devkit() (machine_arch_type == MACH_TYPE_EA2478DEVKIT) -#else -# define machine_is_ea2478devkit() (0) -#endif - -#ifdef CONFIG_MACH_TERASTATION_WXL -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TERASTATION_WXL -# endif -# define machine_is_terastation_wxl() (machine_arch_type == MACH_TYPE_TERASTATION_WXL) -#else -# define machine_is_terastation_wxl() (0) -#endif - -#ifdef CONFIG_MACH_MSM7X25_SURF -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MSM7X25_SURF -# endif -# define machine_is_msm7x25_surf() (machine_arch_type == MACH_TYPE_MSM7X25_SURF) -#else -# define machine_is_msm7x25_surf() (0) -#endif - -#ifdef CONFIG_MACH_MSM7X25_FFA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MSM7X25_FFA -# endif -# define machine_is_msm7x25_ffa() (machine_arch_type == MACH_TYPE_MSM7X25_FFA) -#else -# define machine_is_msm7x25_ffa() (0) -#endif - -#ifdef CONFIG_MACH_MSM7X27_SURF -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MSM7X27_SURF -# endif -# define machine_is_msm7x27_surf() (machine_arch_type == MACH_TYPE_MSM7X27_SURF) -#else -# define machine_is_msm7x27_surf() (0) -#endif - -#ifdef CONFIG_MACH_MSM7X27_FFA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MSM7X27_FFA -# endif -# define machine_is_msm7x27_ffa() (machine_arch_type == MACH_TYPE_MSM7X27_FFA) -#else -# define machine_is_msm7x27_ffa() (0) -#endif - -#ifdef CONFIG_MACH_MSM7X30_FFA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MSM7X30_FFA -# endif -# define machine_is_msm7x30_ffa() (machine_arch_type == MACH_TYPE_MSM7X30_FFA) -#else -# define machine_is_msm7x30_ffa() (0) -#endif - -#ifdef CONFIG_MACH_QSD8X50_SURF -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_QSD8X50_SURF -# endif -# define machine_is_qsd8x50_surf() (machine_arch_type == MACH_TYPE_QSD8X50_SURF) -#else -# define machine_is_qsd8x50_surf() (0) -#endif - -#ifdef CONFIG_MACH_MX53_EVK -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MX53_EVK -# endif -# define machine_is_mx53_evk() (machine_arch_type == MACH_TYPE_MX53_EVK) -#else -# define machine_is_mx53_evk() (0) -#endif - -#ifdef CONFIG_MACH_IGEP0030 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_IGEP0030 -# endif -# define machine_is_igep0030() (machine_arch_type == MACH_TYPE_IGEP0030) -#else -# define machine_is_igep0030() (0) -#endif - -#ifdef CONFIG_MACH_SBC3530 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SBC3530 -# endif -# define machine_is_sbc3530() (machine_arch_type == MACH_TYPE_SBC3530) -#else -# define machine_is_sbc3530() (0) -#endif - -#ifdef CONFIG_MACH_SAARB -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SAARB -# endif -# define machine_is_saarb() (machine_arch_type == MACH_TYPE_SAARB) -#else -# define machine_is_saarb() (0) -#endif - -#ifdef CONFIG_MACH_HARMONY -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_HARMONY -# endif -# define machine_is_harmony() (machine_arch_type == MACH_TYPE_HARMONY) -#else -# define machine_is_harmony() (0) -#endif - -#ifdef CONFIG_MACH_MSM7X30_FLUID -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MSM7X30_FLUID -# endif -# define machine_is_msm7x30_fluid() (machine_arch_type == MACH_TYPE_MSM7X30_FLUID) -#else -# define machine_is_msm7x30_fluid() (0) -#endif - -#ifdef CONFIG_MACH_CM_T3517 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CM_T3517 -# endif -# define machine_is_cm_t3517() (machine_arch_type == MACH_TYPE_CM_T3517) -#else -# define machine_is_cm_t3517() (0) -#endif - -#ifdef CONFIG_MACH_WBD222 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_WBD222 -# endif -# define machine_is_wbd222() (machine_arch_type == MACH_TYPE_WBD222) -#else -# define machine_is_wbd222() (0) -#endif - -#ifdef CONFIG_MACH_MSM8X60_SURF -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MSM8X60_SURF -# endif -# define machine_is_msm8x60_surf() (machine_arch_type == MACH_TYPE_MSM8X60_SURF) -#else -# define machine_is_msm8x60_surf() (0) -#endif - -#ifdef CONFIG_MACH_MSM8X60_SIM -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MSM8X60_SIM -# endif -# define machine_is_msm8x60_sim() (machine_arch_type == MACH_TYPE_MSM8X60_SIM) -#else -# define machine_is_msm8x60_sim() (0) -#endif - -#ifdef CONFIG_MACH_TCC8000_SDK -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TCC8000_SDK -# endif -# define machine_is_tcc8000_sdk() (machine_arch_type == MACH_TYPE_TCC8000_SDK) -#else -# define machine_is_tcc8000_sdk() (0) -#endif - -#ifdef CONFIG_MACH_NANOS -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NANOS -# endif -# define machine_is_nanos() (machine_arch_type == MACH_TYPE_NANOS) -#else -# define machine_is_nanos() (0) -#endif - -#ifdef CONFIG_MACH_STAMP9G45 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_STAMP9G45 -# endif -# define machine_is_stamp9g45() (machine_arch_type == MACH_TYPE_STAMP9G45) -#else -# define machine_is_stamp9g45() (0) -#endif - -#ifdef CONFIG_MACH_CNS3420VB -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CNS3420VB -# endif -# define machine_is_cns3420vb() (machine_arch_type == MACH_TYPE_CNS3420VB) -#else -# define machine_is_cns3420vb() (0) -#endif - -#ifdef CONFIG_MACH_OMAP4_PANDA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OMAP4_PANDA -# endif -# define machine_is_omap4_panda() (machine_arch_type == MACH_TYPE_OMAP4_PANDA) -#else -# define machine_is_omap4_panda() (0) -#endif - -#ifdef CONFIG_MACH_TI8168EVM -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TI8168EVM -# endif -# define machine_is_ti8168evm() (machine_arch_type == MACH_TYPE_TI8168EVM) -#else -# define machine_is_ti8168evm() (0) -#endif - -#ifdef CONFIG_MACH_TETON_BGA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TETON_BGA -# endif -# define machine_is_teton_bga() (machine_arch_type == MACH_TYPE_TETON_BGA) -#else -# define machine_is_teton_bga() (0) -#endif - -#ifdef CONFIG_MACH_EUKREA_CPUIMX25SD -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_EUKREA_CPUIMX25SD -# endif -# define machine_is_eukrea_cpuimx25sd() (machine_arch_type == MACH_TYPE_EUKREA_CPUIMX25SD) -#else -# define machine_is_eukrea_cpuimx25sd() (0) -#endif - -#ifdef CONFIG_MACH_EUKREA_CPUIMX35SD -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_EUKREA_CPUIMX35SD -# endif -# define machine_is_eukrea_cpuimx35sd() (machine_arch_type == MACH_TYPE_EUKREA_CPUIMX35SD) -#else -# define machine_is_eukrea_cpuimx35sd() (0) -#endif - -#ifdef CONFIG_MACH_EUKREA_CPUIMX51SD -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_EUKREA_CPUIMX51SD -# endif -# define machine_is_eukrea_cpuimx51sd() (machine_arch_type == MACH_TYPE_EUKREA_CPUIMX51SD) -#else -# define machine_is_eukrea_cpuimx51sd() (0) -#endif - -#ifdef CONFIG_MACH_EUKREA_CPUIMX51 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_EUKREA_CPUIMX51 -# endif -# define machine_is_eukrea_cpuimx51() (machine_arch_type == MACH_TYPE_EUKREA_CPUIMX51) -#else -# define machine_is_eukrea_cpuimx51() (0) -#endif - -#ifdef CONFIG_MACH_SMDKC210 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SMDKC210 -# endif -# define machine_is_smdkc210() (machine_arch_type == MACH_TYPE_SMDKC210) -#else -# define machine_is_smdkc210() (0) -#endif - -#ifdef CONFIG_MACH_OMAP3_BRAILLO -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OMAP3_BRAILLO -# endif -# define machine_is_omap3_braillo() (machine_arch_type == MACH_TYPE_OMAP3_BRAILLO) -#else -# define machine_is_omap3_braillo() (0) -#endif - -#ifdef CONFIG_MACH_SPYPLUG -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SPYPLUG -# endif -# define machine_is_spyplug() (machine_arch_type == MACH_TYPE_SPYPLUG) -#else -# define machine_is_spyplug() (0) -#endif - -#ifdef CONFIG_MACH_GINGER -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_GINGER -# endif -# define machine_is_ginger() (machine_arch_type == MACH_TYPE_GINGER) -#else -# define machine_is_ginger() (0) -#endif - -#ifdef CONFIG_MACH_TNY_T3530 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TNY_T3530 -# endif -# define machine_is_tny_t3530() (machine_arch_type == MACH_TYPE_TNY_T3530) -#else -# define machine_is_tny_t3530() (0) -#endif - -#ifdef CONFIG_MACH_PCA102 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_PCA102 -# endif -# define machine_is_pca102() (machine_arch_type == MACH_TYPE_PCA102) -#else -# define machine_is_pca102() (0) -#endif - -#ifdef CONFIG_MACH_SPADE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SPADE -# endif -# define machine_is_spade() (machine_arch_type == MACH_TYPE_SPADE) -#else -# define machine_is_spade() (0) -#endif - -#ifdef CONFIG_MACH_MXC25_TOPAZ -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MXC25_TOPAZ -# endif -# define machine_is_mxc25_topaz() (machine_arch_type == MACH_TYPE_MXC25_TOPAZ) -#else -# define machine_is_mxc25_topaz() (0) -#endif - -#ifdef CONFIG_MACH_T5325 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_T5325 -# endif -# define machine_is_t5325() (machine_arch_type == MACH_TYPE_T5325) -#else -# define machine_is_t5325() (0) -#endif - -#ifdef CONFIG_MACH_GW2361 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_GW2361 -# endif -# define machine_is_gw2361() (machine_arch_type == MACH_TYPE_GW2361) -#else -# define machine_is_gw2361() (0) -#endif - -#ifdef CONFIG_MACH_ELOG -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ELOG -# endif -# define machine_is_elog() (machine_arch_type == MACH_TYPE_ELOG) -#else -# define machine_is_elog() (0) -#endif - -#ifdef CONFIG_MACH_INCOME -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_INCOME -# endif -# define machine_is_income() (machine_arch_type == MACH_TYPE_INCOME) -#else -# define machine_is_income() (0) -#endif - -#ifdef CONFIG_MACH_BCM589X -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_BCM589X -# endif -# define machine_is_bcm589x() (machine_arch_type == MACH_TYPE_BCM589X) -#else -# define machine_is_bcm589x() (0) -#endif - -#ifdef CONFIG_MACH_ETNA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ETNA -# endif -# define machine_is_etna() (machine_arch_type == MACH_TYPE_ETNA) -#else -# define machine_is_etna() (0) -#endif - -#ifdef CONFIG_MACH_HAWKS -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_HAWKS -# endif -# define machine_is_hawks() (machine_arch_type == MACH_TYPE_HAWKS) -#else -# define machine_is_hawks() (0) -#endif - -#ifdef CONFIG_MACH_MESON -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MESON -# endif -# define machine_is_meson() (machine_arch_type == MACH_TYPE_MESON) -#else -# define machine_is_meson() (0) -#endif - -#ifdef CONFIG_MACH_XSBASE255 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_XSBASE255 -# endif -# define machine_is_xsbase255() (machine_arch_type == MACH_TYPE_XSBASE255) -#else -# define machine_is_xsbase255() (0) -#endif - -#ifdef CONFIG_MACH_PVM2030 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_PVM2030 -# endif -# define machine_is_pvm2030() (machine_arch_type == MACH_TYPE_PVM2030) -#else -# define machine_is_pvm2030() (0) -#endif - -#ifdef CONFIG_MACH_MIOA502 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MIOA502 -# endif -# define machine_is_mioa502() (machine_arch_type == MACH_TYPE_MIOA502) -#else -# define machine_is_mioa502() (0) -#endif - -#ifdef CONFIG_MACH_VVBOX_SDORIG2 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_VVBOX_SDORIG2 -# endif -# define machine_is_vvbox_sdorig2() (machine_arch_type == MACH_TYPE_VVBOX_SDORIG2) -#else -# define machine_is_vvbox_sdorig2() (0) -#endif - -#ifdef CONFIG_MACH_VVBOX_SDLITE2 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_VVBOX_SDLITE2 -# endif -# define machine_is_vvbox_sdlite2() (machine_arch_type == MACH_TYPE_VVBOX_SDLITE2) -#else -# define machine_is_vvbox_sdlite2() (0) -#endif - -#ifdef CONFIG_MACH_VVBOX_SDPRO4 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_VVBOX_SDPRO4 -# endif -# define machine_is_vvbox_sdpro4() (machine_arch_type == MACH_TYPE_VVBOX_SDPRO4) -#else -# define machine_is_vvbox_sdpro4() (0) -#endif - -#ifdef CONFIG_MACH_HTC_SPV_M700 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_HTC_SPV_M700 -# endif -# define machine_is_htc_spv_m700() (machine_arch_type == MACH_TYPE_HTC_SPV_M700) -#else -# define machine_is_htc_spv_m700() (0) -#endif - -#ifdef CONFIG_MACH_MX257SX -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MX257SX -# endif -# define machine_is_mx257sx() (machine_arch_type == MACH_TYPE_MX257SX) -#else -# define machine_is_mx257sx() (0) -#endif - -#ifdef CONFIG_MACH_GONI -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_GONI -# endif -# define machine_is_goni() (machine_arch_type == MACH_TYPE_GONI) -#else -# define machine_is_goni() (0) -#endif - -#ifdef CONFIG_MACH_MSM8X55_SVLTE_FFA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MSM8X55_SVLTE_FFA -# endif -# define machine_is_msm8x55_svlte_ffa() (machine_arch_type == MACH_TYPE_MSM8X55_SVLTE_FFA) -#else -# define machine_is_msm8x55_svlte_ffa() (0) -#endif - -#ifdef CONFIG_MACH_MSM8X55_SVLTE_SURF -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MSM8X55_SVLTE_SURF -# endif -# define machine_is_msm8x55_svlte_surf() (machine_arch_type == MACH_TYPE_MSM8X55_SVLTE_SURF) -#else -# define machine_is_msm8x55_svlte_surf() (0) -#endif - -#ifdef CONFIG_MACH_QUICKSTEP -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_QUICKSTEP -# endif -# define machine_is_quickstep() (machine_arch_type == MACH_TYPE_QUICKSTEP) -#else -# define machine_is_quickstep() (0) -#endif - -#ifdef CONFIG_MACH_DMW96 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DMW96 -# endif -# define machine_is_dmw96() (machine_arch_type == MACH_TYPE_DMW96) -#else -# define machine_is_dmw96() (0) -#endif - -#ifdef CONFIG_MACH_HAMMERHEAD -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_HAMMERHEAD -# endif -# define machine_is_hammerhead() (machine_arch_type == MACH_TYPE_HAMMERHEAD) -#else -# define machine_is_hammerhead() (0) -#endif - -#ifdef CONFIG_MACH_TRIDENT -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TRIDENT -# endif -# define machine_is_trident() (machine_arch_type == MACH_TYPE_TRIDENT) -#else -# define machine_is_trident() (0) -#endif - -#ifdef CONFIG_MACH_LIGHTNING -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_LIGHTNING -# endif -# define machine_is_lightning() (machine_arch_type == MACH_TYPE_LIGHTNING) -#else -# define machine_is_lightning() (0) -#endif - -#ifdef CONFIG_MACH_ICONNECT -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ICONNECT -# endif -# define machine_is_iconnect() (machine_arch_type == MACH_TYPE_ICONNECT) -#else -# define machine_is_iconnect() (0) -#endif - -#ifdef CONFIG_MACH_AUTOBOT -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_AUTOBOT -# endif -# define machine_is_autobot() (machine_arch_type == MACH_TYPE_AUTOBOT) -#else -# define machine_is_autobot() (0) -#endif - -#ifdef CONFIG_MACH_COCONUT -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_COCONUT -# endif -# define machine_is_coconut() (machine_arch_type == MACH_TYPE_COCONUT) -#else -# define machine_is_coconut() (0) -#endif - -#ifdef CONFIG_MACH_DURIAN -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DURIAN -# endif -# define machine_is_durian() (machine_arch_type == MACH_TYPE_DURIAN) -#else -# define machine_is_durian() (0) -#endif - -#ifdef CONFIG_MACH_CAYENNE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CAYENNE -# endif -# define machine_is_cayenne() (machine_arch_type == MACH_TYPE_CAYENNE) -#else -# define machine_is_cayenne() (0) -#endif - -#ifdef CONFIG_MACH_FUJI -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_FUJI -# endif -# define machine_is_fuji() (machine_arch_type == MACH_TYPE_FUJI) -#else -# define machine_is_fuji() (0) -#endif - -#ifdef CONFIG_MACH_SYNOLOGY_6282 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SYNOLOGY_6282 -# endif -# define machine_is_synology_6282() (machine_arch_type == MACH_TYPE_SYNOLOGY_6282) -#else -# define machine_is_synology_6282() (0) -#endif - -#ifdef CONFIG_MACH_EM1SY -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_EM1SY -# endif -# define machine_is_em1sy() (machine_arch_type == MACH_TYPE_EM1SY) -#else -# define machine_is_em1sy() (0) -#endif - -#ifdef CONFIG_MACH_M502 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_M502 -# endif -# define machine_is_m502() (machine_arch_type == MACH_TYPE_M502) -#else -# define machine_is_m502() (0) -#endif - -#ifdef CONFIG_MACH_MATRIX518 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MATRIX518 -# endif -# define machine_is_matrix518() (machine_arch_type == MACH_TYPE_MATRIX518) -#else -# define machine_is_matrix518() (0) -#endif - -#ifdef CONFIG_MACH_TINY_GURNARD -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TINY_GURNARD -# endif -# define machine_is_tiny_gurnard() (machine_arch_type == MACH_TYPE_TINY_GURNARD) -#else -# define machine_is_tiny_gurnard() (0) -#endif - -#ifdef CONFIG_MACH_SPEAR1310 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SPEAR1310 -# endif -# define machine_is_spear1310() (machine_arch_type == MACH_TYPE_SPEAR1310) -#else -# define machine_is_spear1310() (0) -#endif - -#ifdef CONFIG_MACH_BV07 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_BV07 -# endif -# define machine_is_bv07() (machine_arch_type == MACH_TYPE_BV07) -#else -# define machine_is_bv07() (0) -#endif - -#ifdef CONFIG_MACH_MXT_TD61 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MXT_TD61 -# endif -# define machine_is_mxt_td61() (machine_arch_type == MACH_TYPE_MXT_TD61) -#else -# define machine_is_mxt_td61() (0) -#endif - -#ifdef CONFIG_MACH_OPENRD_ULTIMATE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OPENRD_ULTIMATE -# endif -# define machine_is_openrd_ultimate() (machine_arch_type == MACH_TYPE_OPENRD_ULTIMATE) -#else -# define machine_is_openrd_ultimate() (0) -#endif - -#ifdef CONFIG_MACH_DEVIXP -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DEVIXP -# endif -# define machine_is_devixp() (machine_arch_type == MACH_TYPE_DEVIXP) -#else -# define machine_is_devixp() (0) -#endif - -#ifdef CONFIG_MACH_MICCPT -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MICCPT -# endif -# define machine_is_miccpt() (machine_arch_type == MACH_TYPE_MICCPT) -#else -# define machine_is_miccpt() (0) -#endif - -#ifdef CONFIG_MACH_MIC256 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MIC256 -# endif -# define machine_is_mic256() (machine_arch_type == MACH_TYPE_MIC256) -#else -# define machine_is_mic256() (0) -#endif - -#ifdef CONFIG_MACH_AS1167 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_AS1167 -# endif -# define machine_is_as1167() (machine_arch_type == MACH_TYPE_AS1167) -#else -# define machine_is_as1167() (0) -#endif - -#ifdef CONFIG_MACH_OMAP3_IBIZA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OMAP3_IBIZA -# endif -# define machine_is_omap3_ibiza() (machine_arch_type == MACH_TYPE_OMAP3_IBIZA) -#else -# define machine_is_omap3_ibiza() (0) -#endif - -#ifdef CONFIG_MACH_U5500 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_U5500 -# endif -# define machine_is_u5500() (machine_arch_type == MACH_TYPE_U5500) -#else -# define machine_is_u5500() (0) -#endif - -#ifdef CONFIG_MACH_DAVINCI_PICTO -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DAVINCI_PICTO -# endif -# define machine_is_davinci_picto() (machine_arch_type == MACH_TYPE_DAVINCI_PICTO) -#else -# define machine_is_davinci_picto() (0) -#endif - -#ifdef CONFIG_MACH_MECHA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MECHA -# endif -# define machine_is_mecha() (machine_arch_type == MACH_TYPE_MECHA) -#else -# define machine_is_mecha() (0) -#endif - -#ifdef CONFIG_MACH_BUBBA3 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_BUBBA3 -# endif -# define machine_is_bubba3() (machine_arch_type == MACH_TYPE_BUBBA3) -#else -# define machine_is_bubba3() (0) -#endif - -#ifdef CONFIG_MACH_PUPITRE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_PUPITRE -# endif -# define machine_is_pupitre() (machine_arch_type == MACH_TYPE_PUPITRE) -#else -# define machine_is_pupitre() (0) -#endif - -#ifdef CONFIG_MACH_TEGRA_VOGUE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TEGRA_VOGUE -# endif -# define machine_is_tegra_vogue() (machine_arch_type == MACH_TYPE_TEGRA_VOGUE) -#else -# define machine_is_tegra_vogue() (0) -#endif - -#ifdef CONFIG_MACH_TEGRA_E1165 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TEGRA_E1165 -# endif -# define machine_is_tegra_e1165() (machine_arch_type == MACH_TYPE_TEGRA_E1165) -#else -# define machine_is_tegra_e1165() (0) -#endif - -#ifdef CONFIG_MACH_SIMPLENET -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SIMPLENET -# endif -# define machine_is_simplenet() (machine_arch_type == MACH_TYPE_SIMPLENET) -#else -# define machine_is_simplenet() (0) -#endif - -#ifdef CONFIG_MACH_EC4350TBM -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_EC4350TBM -# endif -# define machine_is_ec4350tbm() (machine_arch_type == MACH_TYPE_EC4350TBM) -#else -# define machine_is_ec4350tbm() (0) -#endif - -#ifdef CONFIG_MACH_PEC_TC -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_PEC_TC -# endif -# define machine_is_pec_tc() (machine_arch_type == MACH_TYPE_PEC_TC) -#else -# define machine_is_pec_tc() (0) -#endif - -#ifdef CONFIG_MACH_PEC_HC2 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_PEC_HC2 -# endif -# define machine_is_pec_hc2() (machine_arch_type == MACH_TYPE_PEC_HC2) -#else -# define machine_is_pec_hc2() (0) -#endif - -#ifdef CONFIG_MACH_ESL_MOBILIS_A -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ESL_MOBILIS_A -# endif -# define machine_is_esl_mobilis_a() (machine_arch_type == MACH_TYPE_ESL_MOBILIS_A) -#else -# define machine_is_esl_mobilis_a() (0) -#endif - -#ifdef CONFIG_MACH_ESL_MOBILIS_B -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ESL_MOBILIS_B -# endif -# define machine_is_esl_mobilis_b() (machine_arch_type == MACH_TYPE_ESL_MOBILIS_B) -#else -# define machine_is_esl_mobilis_b() (0) -#endif - -#ifdef CONFIG_MACH_ESL_WAVE_A -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ESL_WAVE_A -# endif -# define machine_is_esl_wave_a() (machine_arch_type == MACH_TYPE_ESL_WAVE_A) -#else -# define machine_is_esl_wave_a() (0) -#endif - -#ifdef CONFIG_MACH_ESL_WAVE_B -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ESL_WAVE_B -# endif -# define machine_is_esl_wave_b() (machine_arch_type == MACH_TYPE_ESL_WAVE_B) -#else -# define machine_is_esl_wave_b() (0) -#endif - -#ifdef CONFIG_MACH_UNISENSE_MMM -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_UNISENSE_MMM -# endif -# define machine_is_unisense_mmm() (machine_arch_type == MACH_TYPE_UNISENSE_MMM) -#else -# define machine_is_unisense_mmm() (0) -#endif - -#ifdef CONFIG_MACH_BLUESHARK -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_BLUESHARK -# endif -# define machine_is_blueshark() (machine_arch_type == MACH_TYPE_BLUESHARK) -#else -# define machine_is_blueshark() (0) -#endif - -#ifdef CONFIG_MACH_E10 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_E10 -# endif -# define machine_is_e10() (machine_arch_type == MACH_TYPE_E10) -#else -# define machine_is_e10() (0) -#endif - -#ifdef CONFIG_MACH_APP3K_ROBIN -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_APP3K_ROBIN -# endif -# define machine_is_app3k_robin() (machine_arch_type == MACH_TYPE_APP3K_ROBIN) -#else -# define machine_is_app3k_robin() (0) -#endif - -#ifdef CONFIG_MACH_POV15HD -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_POV15HD -# endif -# define machine_is_pov15hd() (machine_arch_type == MACH_TYPE_POV15HD) -#else -# define machine_is_pov15hd() (0) -#endif - -#ifdef CONFIG_MACH_STELLA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_STELLA -# endif -# define machine_is_stella() (machine_arch_type == MACH_TYPE_STELLA) -#else -# define machine_is_stella() (0) -#endif - -#ifdef CONFIG_MACH_LINKSTATION_LSCHL -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_LINKSTATION_LSCHL -# endif -# define machine_is_linkstation_lschl() (machine_arch_type == MACH_TYPE_LINKSTATION_LSCHL) -#else -# define machine_is_linkstation_lschl() (0) -#endif - -#ifdef CONFIG_MACH_NETWALKER -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NETWALKER -# endif -# define machine_is_netwalker() (machine_arch_type == MACH_TYPE_NETWALKER) -#else -# define machine_is_netwalker() (0) -#endif - -#ifdef CONFIG_MACH_ACSX106 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ACSX106 -# endif -# define machine_is_acsx106() (machine_arch_type == MACH_TYPE_ACSX106) -#else -# define machine_is_acsx106() (0) -#endif - -#ifdef CONFIG_MACH_ATLAS5_C1 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ATLAS5_C1 -# endif -# define machine_is_atlas5_c1() (machine_arch_type == MACH_TYPE_ATLAS5_C1) -#else -# define machine_is_atlas5_c1() (0) -#endif - -#ifdef CONFIG_MACH_NSB3AST -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NSB3AST -# endif -# define machine_is_nsb3ast() (machine_arch_type == MACH_TYPE_NSB3AST) -#else -# define machine_is_nsb3ast() (0) -#endif - -#ifdef CONFIG_MACH_GNET_SLC -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_GNET_SLC -# endif -# define machine_is_gnet_slc() (machine_arch_type == MACH_TYPE_GNET_SLC) -#else -# define machine_is_gnet_slc() (0) -#endif - -#ifdef CONFIG_MACH_AF4000 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_AF4000 -# endif -# define machine_is_af4000() (machine_arch_type == MACH_TYPE_AF4000) -#else -# define machine_is_af4000() (0) -#endif - -#ifdef CONFIG_MACH_ARK9431 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ARK9431 -# endif -# define machine_is_ark9431() (machine_arch_type == MACH_TYPE_ARK9431) -#else -# define machine_is_ark9431() (0) -#endif - -#ifdef CONFIG_MACH_FS_S5PC100 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_FS_S5PC100 -# endif -# define machine_is_fs_s5pc100() (machine_arch_type == MACH_TYPE_FS_S5PC100) -#else -# define machine_is_fs_s5pc100() (0) -#endif - -#ifdef CONFIG_MACH_OMAP3505NOVA8 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OMAP3505NOVA8 -# endif -# define machine_is_omap3505nova8() (machine_arch_type == MACH_TYPE_OMAP3505NOVA8) -#else -# define machine_is_omap3505nova8() (0) -#endif - -#ifdef CONFIG_MACH_OMAP3621_EDP1 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OMAP3621_EDP1 -# endif -# define machine_is_omap3621_edp1() (machine_arch_type == MACH_TYPE_OMAP3621_EDP1) -#else -# define machine_is_omap3621_edp1() (0) -#endif - -#ifdef CONFIG_MACH_ORATISAES -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ORATISAES -# endif -# define machine_is_oratisaes() (machine_arch_type == MACH_TYPE_ORATISAES) -#else -# define machine_is_oratisaes() (0) -#endif - -#ifdef CONFIG_MACH_SMDKV310 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SMDKV310 -# endif -# define machine_is_smdkv310() (machine_arch_type == MACH_TYPE_SMDKV310) -#else -# define machine_is_smdkv310() (0) -#endif - -#ifdef CONFIG_MACH_SIEMENS_L0 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SIEMENS_L0 -# endif -# define machine_is_siemens_l0() (machine_arch_type == MACH_TYPE_SIEMENS_L0) -#else -# define machine_is_siemens_l0() (0) -#endif - -#ifdef CONFIG_MACH_VENTANA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_VENTANA -# endif -# define machine_is_ventana() (machine_arch_type == MACH_TYPE_VENTANA) -#else -# define machine_is_ventana() (0) -#endif - -#ifdef CONFIG_MACH_WM8505_7IN_NETBOOK -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_WM8505_7IN_NETBOOK -# endif -# define machine_is_wm8505_7in_netbook() (machine_arch_type == MACH_TYPE_WM8505_7IN_NETBOOK) -#else -# define machine_is_wm8505_7in_netbook() (0) -#endif - -#ifdef CONFIG_MACH_EC4350SDB -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_EC4350SDB -# endif -# define machine_is_ec4350sdb() (machine_arch_type == MACH_TYPE_EC4350SDB) -#else -# define machine_is_ec4350sdb() (0) -#endif - -#ifdef CONFIG_MACH_MIMAS -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MIMAS -# endif -# define machine_is_mimas() (machine_arch_type == MACH_TYPE_MIMAS) -#else -# define machine_is_mimas() (0) -#endif - -#ifdef CONFIG_MACH_TITAN -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TITAN -# endif -# define machine_is_titan() (machine_arch_type == MACH_TYPE_TITAN) -#else -# define machine_is_titan() (0) -#endif - -#ifdef CONFIG_MACH_CRANEBOARD -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CRANEBOARD -# endif -# define machine_is_craneboard() (machine_arch_type == MACH_TYPE_CRANEBOARD) -#else -# define machine_is_craneboard() (0) -#endif - -#ifdef CONFIG_MACH_ES2440 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ES2440 -# endif -# define machine_is_es2440() (machine_arch_type == MACH_TYPE_ES2440) -#else -# define machine_is_es2440() (0) -#endif - -#ifdef CONFIG_MACH_NAJAY_A9263 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NAJAY_A9263 -# endif -# define machine_is_najay_a9263() (machine_arch_type == MACH_TYPE_NAJAY_A9263) -#else -# define machine_is_najay_a9263() (0) -#endif - -#ifdef CONFIG_MACH_HTCTORNADO -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_HTCTORNADO -# endif -# define machine_is_htctornado() (machine_arch_type == MACH_TYPE_HTCTORNADO) -#else -# define machine_is_htctornado() (0) -#endif - -#ifdef CONFIG_MACH_DIMM_MX257 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DIMM_MX257 -# endif -# define machine_is_dimm_mx257() (machine_arch_type == MACH_TYPE_DIMM_MX257) -#else -# define machine_is_dimm_mx257() (0) -#endif - -#ifdef CONFIG_MACH_JIGEN -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_JIGEN -# endif -# define machine_is_jigen301() (machine_arch_type == MACH_TYPE_JIGEN) -#else -# define machine_is_jigen301() (0) -#endif - -#ifdef CONFIG_MACH_SMDK6450 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SMDK6450 -# endif -# define machine_is_smdk6450() (machine_arch_type == MACH_TYPE_SMDK6450) -#else -# define machine_is_smdk6450() (0) -#endif - -#ifdef CONFIG_MACH_MENO_QNG -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MENO_QNG -# endif -# define machine_is_meno_qng() (machine_arch_type == MACH_TYPE_MENO_QNG) -#else -# define machine_is_meno_qng() (0) -#endif - -#ifdef CONFIG_MACH_NS2416 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NS2416 -# endif -# define machine_is_ns2416() (machine_arch_type == MACH_TYPE_NS2416) -#else -# define machine_is_ns2416() (0) -#endif - -#ifdef CONFIG_MACH_RPC353 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_RPC353 -# endif -# define machine_is_rpc353() (machine_arch_type == MACH_TYPE_RPC353) -#else -# define machine_is_rpc353() (0) -#endif - -#ifdef CONFIG_MACH_TQ6410 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TQ6410 -# endif -# define machine_is_tq6410() (machine_arch_type == MACH_TYPE_TQ6410) -#else -# define machine_is_tq6410() (0) -#endif - -#ifdef CONFIG_MACH_SKY6410 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SKY6410 -# endif -# define machine_is_sky6410() (machine_arch_type == MACH_TYPE_SKY6410) -#else -# define machine_is_sky6410() (0) -#endif - -#ifdef CONFIG_MACH_DYNASTY -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DYNASTY -# endif -# define machine_is_dynasty() (machine_arch_type == MACH_TYPE_DYNASTY) -#else -# define machine_is_dynasty() (0) -#endif - -#ifdef CONFIG_MACH_VIVO -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_VIVO -# endif -# define machine_is_vivo() (machine_arch_type == MACH_TYPE_VIVO) -#else -# define machine_is_vivo() (0) -#endif - -#ifdef CONFIG_MACH_BURY_BL7582 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_BURY_BL7582 -# endif -# define machine_is_bury_bl7582() (machine_arch_type == MACH_TYPE_BURY_BL7582) -#else -# define machine_is_bury_bl7582() (0) -#endif - -#ifdef CONFIG_MACH_BURY_BPS5270 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_BURY_BPS5270 -# endif -# define machine_is_bury_bps5270() (machine_arch_type == MACH_TYPE_BURY_BPS5270) -#else -# define machine_is_bury_bps5270() (0) -#endif - -#ifdef CONFIG_MACH_BASI -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_BASI -# endif -# define machine_is_basi() (machine_arch_type == MACH_TYPE_BASI) -#else -# define machine_is_basi() (0) -#endif - -#ifdef CONFIG_MACH_TN200 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TN200 -# endif -# define machine_is_tn200() (machine_arch_type == MACH_TYPE_TN200) -#else -# define machine_is_tn200() (0) -#endif - -#ifdef CONFIG_MACH_C2MMI -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_C2MMI -# endif -# define machine_is_c2mmi() (machine_arch_type == MACH_TYPE_C2MMI) -#else -# define machine_is_c2mmi() (0) -#endif - -#ifdef CONFIG_MACH_MESON_6236M -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MESON_6236M -# endif -# define machine_is_meson_6236m() (machine_arch_type == MACH_TYPE_MESON_6236M) -#else -# define machine_is_meson_6236m() (0) -#endif - -#ifdef CONFIG_MACH_MESON_8626M -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MESON_8626M -# endif -# define machine_is_meson_8626m() (machine_arch_type == MACH_TYPE_MESON_8626M) -#else -# define machine_is_meson_8626m() (0) -#endif - -#ifdef CONFIG_MACH_TUBE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TUBE -# endif -# define machine_is_tube() (machine_arch_type == MACH_TYPE_TUBE) -#else -# define machine_is_tube() (0) -#endif - -#ifdef CONFIG_MACH_MESSINA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MESSINA -# endif -# define machine_is_messina() (machine_arch_type == MACH_TYPE_MESSINA) -#else -# define machine_is_messina() (0) -#endif - -#ifdef CONFIG_MACH_MX50_ARM2 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MX50_ARM2 -# endif -# define machine_is_mx50_arm2() (machine_arch_type == MACH_TYPE_MX50_ARM2) -#else -# define machine_is_mx50_arm2() (0) -#endif - -#ifdef CONFIG_MACH_CETUS9263 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CETUS9263 -# endif -# define machine_is_cetus9263() (machine_arch_type == MACH_TYPE_CETUS9263) -#else -# define machine_is_cetus9263() (0) -#endif - -#ifdef CONFIG_MACH_BROWNSTONE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_BROWNSTONE -# endif -# define machine_is_brownstone() (machine_arch_type == MACH_TYPE_BROWNSTONE) -#else -# define machine_is_brownstone() (0) -#endif - -#ifdef CONFIG_MACH_VMX25 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_VMX25 -# endif -# define machine_is_vmx25() (machine_arch_type == MACH_TYPE_VMX25) -#else -# define machine_is_vmx25() (0) -#endif - -#ifdef CONFIG_MACH_VMX51 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_VMX51 -# endif -# define machine_is_vmx51() (machine_arch_type == MACH_TYPE_VMX51) -#else -# define machine_is_vmx51() (0) -#endif - -#ifdef CONFIG_MACH_ABACUS -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ABACUS -# endif -# define machine_is_abacus() (machine_arch_type == MACH_TYPE_ABACUS) -#else -# define machine_is_abacus() (0) -#endif - -#ifdef CONFIG_MACH_CM4745 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CM4745 -# endif -# define machine_is_cm4745() (machine_arch_type == MACH_TYPE_CM4745) -#else -# define machine_is_cm4745() (0) -#endif - -#ifdef CONFIG_MACH_ORATISLINK -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ORATISLINK -# endif -# define machine_is_oratislink() (machine_arch_type == MACH_TYPE_ORATISLINK) -#else -# define machine_is_oratislink() (0) -#endif - -#ifdef CONFIG_MACH_DAVINCI_DM365_DVR -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DAVINCI_DM365_DVR -# endif -# define machine_is_davinci_dm365_dvr() (machine_arch_type == MACH_TYPE_DAVINCI_DM365_DVR) -#else -# define machine_is_davinci_dm365_dvr() (0) -#endif - -#ifdef CONFIG_MACH_NETVIZ -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NETVIZ -# endif -# define machine_is_netviz() (machine_arch_type == MACH_TYPE_NETVIZ) -#else -# define machine_is_netviz() (0) -#endif - -#ifdef CONFIG_MACH_FLEXIBITY -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_FLEXIBITY -# endif -# define machine_is_flexibity() (machine_arch_type == MACH_TYPE_FLEXIBITY) -#else -# define machine_is_flexibity() (0) -#endif - -#ifdef CONFIG_MACH_WLAN_COMPUTER -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_WLAN_COMPUTER -# endif -# define machine_is_wlan_computer() (machine_arch_type == MACH_TYPE_WLAN_COMPUTER) -#else -# define machine_is_wlan_computer() (0) -#endif - -#ifdef CONFIG_MACH_LPC24XX -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_LPC24XX -# endif -# define machine_is_lpc24xx() (machine_arch_type == MACH_TYPE_LPC24XX) -#else -# define machine_is_lpc24xx() (0) -#endif - -#ifdef CONFIG_MACH_SPICA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SPICA -# endif -# define machine_is_spica() (machine_arch_type == MACH_TYPE_SPICA) -#else -# define machine_is_spica() (0) -#endif - -#ifdef CONFIG_MACH_GPSDISPLAY -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_GPSDISPLAY -# endif -# define machine_is_gpsdisplay() (machine_arch_type == MACH_TYPE_GPSDISPLAY) -#else -# define machine_is_gpsdisplay() (0) -#endif - -#ifdef CONFIG_MACH_BIPNET -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_BIPNET -# endif -# define machine_is_bipnet() (machine_arch_type == MACH_TYPE_BIPNET) -#else -# define machine_is_bipnet() (0) -#endif - -#ifdef CONFIG_MACH_OVERO_CTU_INERTIAL -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OVERO_CTU_INERTIAL -# endif -# define machine_is_overo_ctu_inertial() (machine_arch_type == MACH_TYPE_OVERO_CTU_INERTIAL) -#else -# define machine_is_overo_ctu_inertial() (0) -#endif - -#ifdef CONFIG_MACH_DAVINCI_DM355_MMM -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DAVINCI_DM355_MMM -# endif -# define machine_is_davinci_dm355_mmm() (machine_arch_type == MACH_TYPE_DAVINCI_DM355_MMM) -#else -# define machine_is_davinci_dm355_mmm() (0) -#endif - -#ifdef CONFIG_MACH_PC9260_V2 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_PC9260_V2 -# endif -# define machine_is_pc9260_v2() (machine_arch_type == MACH_TYPE_PC9260_V2) -#else -# define machine_is_pc9260_v2() (0) -#endif - -#ifdef CONFIG_MACH_PTX7545 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_PTX7545 -# endif -# define machine_is_ptx7545() (machine_arch_type == MACH_TYPE_PTX7545) -#else -# define machine_is_ptx7545() (0) -#endif - -#ifdef CONFIG_MACH_TM_EFDC -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TM_EFDC -# endif -# define machine_is_tm_efdc() (machine_arch_type == MACH_TYPE_TM_EFDC) -#else -# define machine_is_tm_efdc() (0) -#endif - -#ifdef CONFIG_MACH_OMAP3_WALDO1 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OMAP3_WALDO1 -# endif -# define machine_is_omap3_waldo1() (machine_arch_type == MACH_TYPE_OMAP3_WALDO1) -#else -# define machine_is_omap3_waldo1() (0) -#endif - -#ifdef CONFIG_MACH_FLYER -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_FLYER -# endif -# define machine_is_flyer() (machine_arch_type == MACH_TYPE_FLYER) -#else -# define machine_is_flyer() (0) -#endif - -#ifdef CONFIG_MACH_TORNADO3240 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TORNADO3240 -# endif -# define machine_is_tornado3240() (machine_arch_type == MACH_TYPE_TORNADO3240) -#else -# define machine_is_tornado3240() (0) -#endif - -#ifdef CONFIG_MACH_SOLI_01 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SOLI_01 -# endif -# define machine_is_soli_01() (machine_arch_type == MACH_TYPE_SOLI_01) -#else -# define machine_is_soli_01() (0) -#endif - -#ifdef CONFIG_MACH_OMAPL138_EUROPALC -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OMAPL138_EUROPALC -# endif -# define machine_is_omapl138_europalc() (machine_arch_type == MACH_TYPE_OMAPL138_EUROPALC) -#else -# define machine_is_omapl138_europalc() (0) -#endif - -#ifdef CONFIG_MACH_HELIOS_V1 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_HELIOS_V1 -# endif -# define machine_is_helios_v1() (machine_arch_type == MACH_TYPE_HELIOS_V1) -#else -# define machine_is_helios_v1() (0) -#endif - -#ifdef CONFIG_MACH_NETSPACE_LITE_V2 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NETSPACE_LITE_V2 -# endif -# define machine_is_netspace_lite_v2() (machine_arch_type == MACH_TYPE_NETSPACE_LITE_V2) -#else -# define machine_is_netspace_lite_v2() (0) -#endif - -#ifdef CONFIG_MACH_SSC -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SSC -# endif -# define machine_is_ssc() (machine_arch_type == MACH_TYPE_SSC) -#else -# define machine_is_ssc() (0) -#endif - -#ifdef CONFIG_MACH_PREMIERWAVE_EN -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_PREMIERWAVE_EN -# endif -# define machine_is_premierwave_en() (machine_arch_type == MACH_TYPE_PREMIERWAVE_EN) -#else -# define machine_is_premierwave_en() (0) -#endif - -#ifdef CONFIG_MACH_WASABI -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_WASABI -# endif -# define machine_is_wasabi() (machine_arch_type == MACH_TYPE_WASABI) -#else -# define machine_is_wasabi() (0) -#endif - -#ifdef CONFIG_MACH_MX50_RDP -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MX50_RDP -# endif -# define machine_is_mx50_rdp() (machine_arch_type == MACH_TYPE_MX50_RDP) -#else -# define machine_is_mx50_rdp() (0) -#endif - -#ifdef CONFIG_MACH_UNIVERSAL_C210 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_UNIVERSAL_C210 -# endif -# define machine_is_universal_c210() (machine_arch_type == MACH_TYPE_UNIVERSAL_C210) -#else -# define machine_is_universal_c210() (0) -#endif - -#ifdef CONFIG_MACH_REAL6410 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_REAL6410 -# endif -# define machine_is_real6410() (machine_arch_type == MACH_TYPE_REAL6410) -#else -# define machine_is_real6410() (0) -#endif - -#ifdef CONFIG_MACH_SPX_SAKURA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SPX_SAKURA -# endif -# define machine_is_spx_sakura() (machine_arch_type == MACH_TYPE_SPX_SAKURA) -#else -# define machine_is_spx_sakura() (0) -#endif - -#ifdef CONFIG_MACH_IJ3K_2440 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_IJ3K_2440 -# endif -# define machine_is_ij3k_2440() (machine_arch_type == MACH_TYPE_IJ3K_2440) -#else -# define machine_is_ij3k_2440() (0) -#endif - -#ifdef CONFIG_MACH_OMAP3_BC10 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OMAP3_BC10 -# endif -# define machine_is_omap3_bc10() (machine_arch_type == MACH_TYPE_OMAP3_BC10) -#else -# define machine_is_omap3_bc10() (0) -#endif - -#ifdef CONFIG_MACH_THEBE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_THEBE -# endif -# define machine_is_thebe() (machine_arch_type == MACH_TYPE_THEBE) -#else -# define machine_is_thebe() (0) -#endif - -#ifdef CONFIG_MACH_RV082 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_RV082 -# endif -# define machine_is_rv082() (machine_arch_type == MACH_TYPE_RV082) -#else -# define machine_is_rv082() (0) -#endif - -#ifdef CONFIG_MACH_ARMLGUEST -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ARMLGUEST -# endif -# define machine_is_armlguest() (machine_arch_type == MACH_TYPE_ARMLGUEST) -#else -# define machine_is_armlguest() (0) -#endif - -#ifdef CONFIG_MACH_TJINC1000 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TJINC1000 -# endif -# define machine_is_tjinc1000() (machine_arch_type == MACH_TYPE_TJINC1000) -#else -# define machine_is_tjinc1000() (0) -#endif - -#ifdef CONFIG_MACH_DOCKSTAR -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DOCKSTAR -# endif -# define machine_is_dockstar() (machine_arch_type == MACH_TYPE_DOCKSTAR) -#else -# define machine_is_dockstar() (0) -#endif - -#ifdef CONFIG_MACH_AX8008 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_AX8008 -# endif -# define machine_is_ax8008() (machine_arch_type == MACH_TYPE_AX8008) -#else -# define machine_is_ax8008() (0) -#endif - -#ifdef CONFIG_MACH_GNET_SGCE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_GNET_SGCE -# endif -# define machine_is_gnet_sgce() (machine_arch_type == MACH_TYPE_GNET_SGCE) -#else -# define machine_is_gnet_sgce() (0) -#endif - -#ifdef CONFIG_MACH_PXWNAS_500_1000 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_PXWNAS_500_1000 -# endif -# define machine_is_pxwnas_500_1000() (machine_arch_type == MACH_TYPE_PXWNAS_500_1000) -#else -# define machine_is_pxwnas_500_1000() (0) -#endif - -#ifdef CONFIG_MACH_EA20 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_EA20 -# endif -# define machine_is_ea20() (machine_arch_type == MACH_TYPE_EA20) -#else -# define machine_is_ea20() (0) -#endif - -#ifdef CONFIG_MACH_AWM2 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_AWM2 -# endif -# define machine_is_awm2() (machine_arch_type == MACH_TYPE_AWM2) -#else -# define machine_is_awm2() (0) -#endif - -#ifdef CONFIG_MACH_TI8148EVM -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TI8148EVM -# endif -# define machine_is_ti8148evm() (machine_arch_type == MACH_TYPE_TI8148EVM) -#else -# define machine_is_ti8148evm() (0) -#endif - -#ifdef CONFIG_MACH_SEABOARD -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SEABOARD -# endif -# define machine_is_seaboard() (machine_arch_type == MACH_TYPE_SEABOARD) -#else -# define machine_is_seaboard() (0) -#endif - -#ifdef CONFIG_MACH_LINKSTATION_CHLV2 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_LINKSTATION_CHLV2 -# endif -# define machine_is_linkstation_chlv2() (machine_arch_type == MACH_TYPE_LINKSTATION_CHLV2) -#else -# define machine_is_linkstation_chlv2() (0) -#endif - -#ifdef CONFIG_MACH_TERA_PRO2_RACK -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TERA_PRO2_RACK -# endif -# define machine_is_tera_pro2_rack() (machine_arch_type == MACH_TYPE_TERA_PRO2_RACK) -#else -# define machine_is_tera_pro2_rack() (0) -#endif - -#ifdef CONFIG_MACH_RUBYS -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_RUBYS -# endif -# define machine_is_rubys() (machine_arch_type == MACH_TYPE_RUBYS) -#else -# define machine_is_rubys() (0) -#endif - -#ifdef CONFIG_MACH_AQUARIUS -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_AQUARIUS -# endif -# define machine_is_aquarius() (machine_arch_type == MACH_TYPE_AQUARIUS) -#else -# define machine_is_aquarius() (0) -#endif - -#ifdef CONFIG_MACH_MX53_ARD -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MX53_ARD -# endif -# define machine_is_mx53_ard() (machine_arch_type == MACH_TYPE_MX53_ARD) -#else -# define machine_is_mx53_ard() (0) -#endif - -#ifdef CONFIG_MACH_MX53_SMD -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MX53_SMD -# endif -# define machine_is_mx53_smd() (machine_arch_type == MACH_TYPE_MX53_SMD) -#else -# define machine_is_mx53_smd() (0) -#endif - -#ifdef CONFIG_MACH_LSWXL -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_LSWXL -# endif -# define machine_is_lswxl() (machine_arch_type == MACH_TYPE_LSWXL) -#else -# define machine_is_lswxl() (0) -#endif - -#ifdef CONFIG_MACH_DOVE_AVNG_V3 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DOVE_AVNG_V3 -# endif -# define machine_is_dove_avng_v3() (machine_arch_type == MACH_TYPE_DOVE_AVNG_V3) -#else -# define machine_is_dove_avng_v3() (0) -#endif - -#ifdef CONFIG_MACH_SDI_ESS_9263 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SDI_ESS_9263 -# endif -# define machine_is_sdi_ess_9263() (machine_arch_type == MACH_TYPE_SDI_ESS_9263) -#else -# define machine_is_sdi_ess_9263() (0) -#endif - -#ifdef CONFIG_MACH_JOCPU550 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_JOCPU550 -# endif -# define machine_is_jocpu550() (machine_arch_type == MACH_TYPE_JOCPU550) -#else -# define machine_is_jocpu550() (0) -#endif - -#ifdef CONFIG_MACH_MSM8X60_RUMI3 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MSM8X60_RUMI3 -# endif -# define machine_is_msm8x60_rumi3() (machine_arch_type == MACH_TYPE_MSM8X60_RUMI3) -#else -# define machine_is_msm8x60_rumi3() (0) -#endif - -#ifdef CONFIG_MACH_MSM8X60_FFA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MSM8X60_FFA -# endif -# define machine_is_msm8x60_ffa() (machine_arch_type == MACH_TYPE_MSM8X60_FFA) -#else -# define machine_is_msm8x60_ffa() (0) -#endif - -#ifdef CONFIG_MACH_YANOMAMI -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_YANOMAMI -# endif -# define machine_is_yanomami() (machine_arch_type == MACH_TYPE_YANOMAMI) -#else -# define machine_is_yanomami() (0) -#endif - -#ifdef CONFIG_MACH_GTA04 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_GTA04 -# endif -# define machine_is_gta04() (machine_arch_type == MACH_TYPE_GTA04) -#else -# define machine_is_gta04() (0) -#endif - -#ifdef CONFIG_MACH_CM_A510 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CM_A510 -# endif -# define machine_is_cm_a510() (machine_arch_type == MACH_TYPE_CM_A510) -#else -# define machine_is_cm_a510() (0) -#endif - -#ifdef CONFIG_MACH_OMAP3_RFS200 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OMAP3_RFS200 -# endif -# define machine_is_omap3_rfs200() (machine_arch_type == MACH_TYPE_OMAP3_RFS200) -#else -# define machine_is_omap3_rfs200() (0) -#endif - -#ifdef CONFIG_MACH_KX33XX -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_KX33XX -# endif -# define machine_is_kx33xx() (machine_arch_type == MACH_TYPE_KX33XX) -#else -# define machine_is_kx33xx() (0) -#endif - -#ifdef CONFIG_MACH_PTX7510 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_PTX7510 -# endif -# define machine_is_ptx7510() (machine_arch_type == MACH_TYPE_PTX7510) -#else -# define machine_is_ptx7510() (0) -#endif - -#ifdef CONFIG_MACH_TOP9000 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TOP9000 -# endif -# define machine_is_top9000() (machine_arch_type == MACH_TYPE_TOP9000) -#else -# define machine_is_top9000() (0) -#endif - -#ifdef CONFIG_MACH_TEENOTE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TEENOTE -# endif -# define machine_is_teenote() (machine_arch_type == MACH_TYPE_TEENOTE) -#else -# define machine_is_teenote() (0) -#endif - -#ifdef CONFIG_MACH_TS3 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TS3 -# endif -# define machine_is_ts3() (machine_arch_type == MACH_TYPE_TS3) -#else -# define machine_is_ts3() (0) -#endif - -#ifdef CONFIG_MACH_A0 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_A0 -# endif -# define machine_is_a0() (machine_arch_type == MACH_TYPE_A0) -#else -# define machine_is_a0() (0) -#endif - -#ifdef CONFIG_MACH_FSM9XXX_SURF -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_FSM9XXX_SURF -# endif -# define machine_is_fsm9xxx_surf() (machine_arch_type == MACH_TYPE_FSM9XXX_SURF) -#else -# define machine_is_fsm9xxx_surf() (0) -#endif - -#ifdef CONFIG_MACH_FSM9XXX_FFA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_FSM9XXX_FFA -# endif -# define machine_is_fsm9xxx_ffa() (machine_arch_type == MACH_TYPE_FSM9XXX_FFA) -#else -# define machine_is_fsm9xxx_ffa() (0) -#endif - -#ifdef CONFIG_MACH_FRRHWCDMA60W -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_FRRHWCDMA60W -# endif -# define machine_is_frrhwcdma60w() (machine_arch_type == MACH_TYPE_FRRHWCDMA60W) -#else -# define machine_is_frrhwcdma60w() (0) -#endif - -#ifdef CONFIG_MACH_REMUS -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_REMUS -# endif -# define machine_is_remus() (machine_arch_type == MACH_TYPE_REMUS) -#else -# define machine_is_remus() (0) -#endif - -#ifdef CONFIG_MACH_AT91CAP7XDK -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_AT91CAP7XDK -# endif -# define machine_is_at91cap7xdk() (machine_arch_type == MACH_TYPE_AT91CAP7XDK) -#else -# define machine_is_at91cap7xdk() (0) -#endif - -#ifdef CONFIG_MACH_AT91CAP7STK -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_AT91CAP7STK -# endif -# define machine_is_at91cap7stk() (machine_arch_type == MACH_TYPE_AT91CAP7STK) -#else -# define machine_is_at91cap7stk() (0) -#endif - -#ifdef CONFIG_MACH_KT_SBC_SAM9_1 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_KT_SBC_SAM9_1 -# endif -# define machine_is_kt_sbc_sam9_1() (machine_arch_type == MACH_TYPE_KT_SBC_SAM9_1) -#else -# define machine_is_kt_sbc_sam9_1() (0) -#endif - -#ifdef CONFIG_MACH_ARMADA_XP_DB -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ARMADA_XP_DB -# endif -# define machine_is_armada_xp_db() (machine_arch_type == MACH_TYPE_ARMADA_XP_DB) -#else -# define machine_is_armada_xp_db() (0) -#endif - -#ifdef CONFIG_MACH_SPDM -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SPDM -# endif -# define machine_is_spdm() (machine_arch_type == MACH_TYPE_SPDM) -#else -# define machine_is_spdm() (0) -#endif - -#ifdef CONFIG_MACH_GTIB -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_GTIB -# endif -# define machine_is_gtib() (machine_arch_type == MACH_TYPE_GTIB) -#else -# define machine_is_gtib() (0) -#endif - -#ifdef CONFIG_MACH_DGM3240 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DGM3240 -# endif -# define machine_is_dgm3240() (machine_arch_type == MACH_TYPE_DGM3240) -#else -# define machine_is_dgm3240() (0) -#endif - -#ifdef CONFIG_MACH_HTCMEGA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_HTCMEGA -# endif -# define machine_is_htcmega() (machine_arch_type == MACH_TYPE_HTCMEGA) -#else -# define machine_is_htcmega() (0) -#endif - -#ifdef CONFIG_MACH_TRICORDER -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TRICORDER -# endif -# define machine_is_tricorder() (machine_arch_type == MACH_TYPE_TRICORDER) -#else -# define machine_is_tricorder() (0) -#endif - -#ifdef CONFIG_MACH_TX28 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TX28 -# endif -# define machine_is_tx28() (machine_arch_type == MACH_TYPE_TX28) -#else -# define machine_is_tx28() (0) -#endif - -#ifdef CONFIG_MACH_BSTBRD -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_BSTBRD -# endif -# define machine_is_bstbrd() (machine_arch_type == MACH_TYPE_BSTBRD) -#else -# define machine_is_bstbrd() (0) -#endif - -#ifdef CONFIG_MACH_PWB3090 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_PWB3090 -# endif -# define machine_is_pwb3090() (machine_arch_type == MACH_TYPE_PWB3090) -#else -# define machine_is_pwb3090() (0) -#endif - -#ifdef CONFIG_MACH_IDEA6410 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_IDEA6410 -# endif -# define machine_is_idea6410() (machine_arch_type == MACH_TYPE_IDEA6410) -#else -# define machine_is_idea6410() (0) -#endif - -#ifdef CONFIG_MACH_QBC9263 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_QBC9263 -# endif -# define machine_is_qbc9263() (machine_arch_type == MACH_TYPE_QBC9263) -#else -# define machine_is_qbc9263() (0) -#endif - -#ifdef CONFIG_MACH_BORABORA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_BORABORA -# endif -# define machine_is_borabora() (machine_arch_type == MACH_TYPE_BORABORA) -#else -# define machine_is_borabora() (0) -#endif - -#ifdef CONFIG_MACH_VALDEZ -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_VALDEZ -# endif -# define machine_is_valdez() (machine_arch_type == MACH_TYPE_VALDEZ) -#else -# define machine_is_valdez() (0) -#endif - -#ifdef CONFIG_MACH_LS9G20 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_LS9G20 -# endif -# define machine_is_ls9g20() (machine_arch_type == MACH_TYPE_LS9G20) -#else -# define machine_is_ls9g20() (0) -#endif - -#ifdef CONFIG_MACH_MIOS_V1 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MIOS_V1 -# endif -# define machine_is_mios_v1() (machine_arch_type == MACH_TYPE_MIOS_V1) -#else -# define machine_is_mios_v1() (0) -#endif - -#ifdef CONFIG_MACH_S5PC110_CRESPO -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_S5PC110_CRESPO -# endif -# define machine_is_s5pc110_crespo() (machine_arch_type == MACH_TYPE_S5PC110_CRESPO) -#else -# define machine_is_s5pc110_crespo() (0) -#endif - -#ifdef CONFIG_MACH_CONTROLTEK9G20 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CONTROLTEK9G20 -# endif -# define machine_is_controltek9g20() (machine_arch_type == MACH_TYPE_CONTROLTEK9G20) -#else -# define machine_is_controltek9g20() (0) -#endif - -#ifdef CONFIG_MACH_TIN307 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TIN307 -# endif -# define machine_is_tin307() (machine_arch_type == MACH_TYPE_TIN307) -#else -# define machine_is_tin307() (0) -#endif - -#ifdef CONFIG_MACH_TIN510 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TIN510 -# endif -# define machine_is_tin510() (machine_arch_type == MACH_TYPE_TIN510) -#else -# define machine_is_tin510() (0) -#endif - -#ifdef CONFIG_MACH_BLUECHEESE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_BLUECHEESE -# endif -# define machine_is_bluecheese() (machine_arch_type == MACH_TYPE_BLUECHEESE) -#else -# define machine_is_bluecheese() (0) -#endif - -#ifdef CONFIG_MACH_TEM3X30 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TEM3X30 -# endif -# define machine_is_tem3x30() (machine_arch_type == MACH_TYPE_TEM3X30) -#else -# define machine_is_tem3x30() (0) -#endif - -#ifdef CONFIG_MACH_HARVEST_DESOTO -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_HARVEST_DESOTO -# endif -# define machine_is_harvest_desoto() (machine_arch_type == MACH_TYPE_HARVEST_DESOTO) -#else -# define machine_is_harvest_desoto() (0) -#endif - -#ifdef CONFIG_MACH_MSM8X60_QRDC -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MSM8X60_QRDC -# endif -# define machine_is_msm8x60_qrdc() (machine_arch_type == MACH_TYPE_MSM8X60_QRDC) -#else -# define machine_is_msm8x60_qrdc() (0) -#endif - -#ifdef CONFIG_MACH_SPEAR900 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SPEAR900 -# endif -# define machine_is_spear900() (machine_arch_type == MACH_TYPE_SPEAR900) -#else -# define machine_is_spear900() (0) -#endif - -#ifdef CONFIG_MACH_PCONTROL_G20 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_PCONTROL_G20 -# endif -# define machine_is_pcontrol_g20() (machine_arch_type == MACH_TYPE_PCONTROL_G20) -#else -# define machine_is_pcontrol_g20() (0) -#endif - -#ifdef CONFIG_MACH_RDSTOR -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_RDSTOR -# endif -# define machine_is_rdstor() (machine_arch_type == MACH_TYPE_RDSTOR) -#else -# define machine_is_rdstor() (0) -#endif - -#ifdef CONFIG_MACH_USDLOADER -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_USDLOADER -# endif -# define machine_is_usdloader() (machine_arch_type == MACH_TYPE_USDLOADER) -#else -# define machine_is_usdloader() (0) -#endif - -#ifdef CONFIG_MACH_TSOPLOADER -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TSOPLOADER -# endif -# define machine_is_tsoploader() (machine_arch_type == MACH_TYPE_TSOPLOADER) -#else -# define machine_is_tsoploader() (0) -#endif - -#ifdef CONFIG_MACH_KRONOS -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_KRONOS -# endif -# define machine_is_kronos() (machine_arch_type == MACH_TYPE_KRONOS) -#else -# define machine_is_kronos() (0) -#endif - -#ifdef CONFIG_MACH_FFCORE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_FFCORE -# endif -# define machine_is_ffcore() (machine_arch_type == MACH_TYPE_FFCORE) -#else -# define machine_is_ffcore() (0) -#endif - -#ifdef CONFIG_MACH_MONE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MONE -# endif -# define machine_is_mone() (machine_arch_type == MACH_TYPE_MONE) -#else -# define machine_is_mone() (0) -#endif - -#ifdef CONFIG_MACH_UNIT2S -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_UNIT2S -# endif -# define machine_is_unit2s() (machine_arch_type == MACH_TYPE_UNIT2S) -#else -# define machine_is_unit2s() (0) -#endif - -#ifdef CONFIG_MACH_ACER_A5 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ACER_A5 -# endif -# define machine_is_acer_a5() (machine_arch_type == MACH_TYPE_ACER_A5) -#else -# define machine_is_acer_a5() (0) -#endif - -#ifdef CONFIG_MACH_ETHERPRO_ISP -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ETHERPRO_ISP -# endif -# define machine_is_etherpro_isp() (machine_arch_type == MACH_TYPE_ETHERPRO_ISP) -#else -# define machine_is_etherpro_isp() (0) -#endif - -#ifdef CONFIG_MACH_STRETCHS7000 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_STRETCHS7000 -# endif -# define machine_is_stretchs7000() (machine_arch_type == MACH_TYPE_STRETCHS7000) -#else -# define machine_is_stretchs7000() (0) -#endif - -#ifdef CONFIG_MACH_P87_SMARTSIM -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_P87_SMARTSIM -# endif -# define machine_is_p87_smartsim() (machine_arch_type == MACH_TYPE_P87_SMARTSIM) -#else -# define machine_is_p87_smartsim() (0) -#endif - -#ifdef CONFIG_MACH_TULIP -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TULIP -# endif -# define machine_is_tulip() (machine_arch_type == MACH_TYPE_TULIP) -#else -# define machine_is_tulip() (0) -#endif - -#ifdef CONFIG_MACH_SUNFLOWER -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SUNFLOWER -# endif -# define machine_is_sunflower() (machine_arch_type == MACH_TYPE_SUNFLOWER) -#else -# define machine_is_sunflower() (0) -#endif - -#ifdef CONFIG_MACH_RIB -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_RIB -# endif -# define machine_is_rib() (machine_arch_type == MACH_TYPE_RIB) -#else -# define machine_is_rib() (0) -#endif - -#ifdef CONFIG_MACH_CLOD -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CLOD -# endif -# define machine_is_clod() (machine_arch_type == MACH_TYPE_CLOD) -#else -# define machine_is_clod() (0) -#endif - -#ifdef CONFIG_MACH_RUMP -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_RUMP -# endif -# define machine_is_rump() (machine_arch_type == MACH_TYPE_RUMP) -#else -# define machine_is_rump() (0) -#endif - -#ifdef CONFIG_MACH_TENDERLOIN -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TENDERLOIN -# endif -# define machine_is_tenderloin() (machine_arch_type == MACH_TYPE_TENDERLOIN) -#else -# define machine_is_tenderloin() (0) -#endif - -#ifdef CONFIG_MACH_SHORTLOIN -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SHORTLOIN -# endif -# define machine_is_shortloin() (machine_arch_type == MACH_TYPE_SHORTLOIN) -#else -# define machine_is_shortloin() (0) -#endif - -#ifdef CONFIG_MACH_ANTARES -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ANTARES -# endif -# define machine_is_antares() (machine_arch_type == MACH_TYPE_ANTARES) -#else -# define machine_is_antares() (0) -#endif - -#ifdef CONFIG_MACH_WB40N -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_WB40N -# endif -# define machine_is_wb40n() (machine_arch_type == MACH_TYPE_WB40N) -#else -# define machine_is_wb40n() (0) -#endif - -#ifdef CONFIG_MACH_HERRING -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_HERRING -# endif -# define machine_is_herring() (machine_arch_type == MACH_TYPE_HERRING) -#else -# define machine_is_herring() (0) -#endif - -#ifdef CONFIG_MACH_NAXY400 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NAXY400 -# endif -# define machine_is_naxy400() (machine_arch_type == MACH_TYPE_NAXY400) -#else -# define machine_is_naxy400() (0) -#endif - -#ifdef CONFIG_MACH_NAXY1200 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NAXY1200 -# endif -# define machine_is_naxy1200() (machine_arch_type == MACH_TYPE_NAXY1200) -#else -# define machine_is_naxy1200() (0) -#endif - -#ifdef CONFIG_MACH_VPR200 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_VPR200 -# endif -# define machine_is_vpr200() (machine_arch_type == MACH_TYPE_VPR200) -#else -# define machine_is_vpr200() (0) -#endif - -#ifdef CONFIG_MACH_BUG20 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_BUG20 -# endif -# define machine_is_bug20() (machine_arch_type == MACH_TYPE_BUG20) -#else -# define machine_is_bug20() (0) -#endif - -#ifdef CONFIG_MACH_GOFLEXNET -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_GOFLEXNET -# endif -# define machine_is_goflexnet() (machine_arch_type == MACH_TYPE_GOFLEXNET) -#else -# define machine_is_goflexnet() (0) -#endif - -#ifdef CONFIG_MACH_TORBRECK -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TORBRECK -# endif -# define machine_is_torbreck() (machine_arch_type == MACH_TYPE_TORBRECK) -#else -# define machine_is_torbreck() (0) -#endif - -#ifdef CONFIG_MACH_SAARB_MG1 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SAARB_MG1 -# endif -# define machine_is_saarb_mg1() (machine_arch_type == MACH_TYPE_SAARB_MG1) -#else -# define machine_is_saarb_mg1() (0) -#endif - -#ifdef CONFIG_MACH_CALLISTO -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CALLISTO -# endif -# define machine_is_callisto() (machine_arch_type == MACH_TYPE_CALLISTO) -#else -# define machine_is_callisto() (0) -#endif - -#ifdef CONFIG_MACH_MULTHSU -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MULTHSU -# endif -# define machine_is_multhsu() (machine_arch_type == MACH_TYPE_MULTHSU) -#else -# define machine_is_multhsu() (0) -#endif - -#ifdef CONFIG_MACH_SALUDA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SALUDA -# endif -# define machine_is_saluda() (machine_arch_type == MACH_TYPE_SALUDA) -#else -# define machine_is_saluda() (0) -#endif - -#ifdef CONFIG_MACH_PEMP_OMAP3_APOLLO -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_PEMP_OMAP3_APOLLO -# endif -# define machine_is_pemp_omap3_apollo() (machine_arch_type == MACH_TYPE_PEMP_OMAP3_APOLLO) -#else -# define machine_is_pemp_omap3_apollo() (0) -#endif - -#ifdef CONFIG_MACH_VC0718 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_VC0718 -# endif -# define machine_is_vc0718() (machine_arch_type == MACH_TYPE_VC0718) -#else -# define machine_is_vc0718() (0) -#endif - -#ifdef CONFIG_MACH_MVBLX -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MVBLX -# endif -# define machine_is_mvblx() (machine_arch_type == MACH_TYPE_MVBLX) -#else -# define machine_is_mvblx() (0) -#endif - -#ifdef CONFIG_MACH_INHAND_APEIRON -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_INHAND_APEIRON -# endif -# define machine_is_inhand_apeiron() (machine_arch_type == MACH_TYPE_INHAND_APEIRON) -#else -# define machine_is_inhand_apeiron() (0) -#endif - -#ifdef CONFIG_MACH_INHAND_FURY -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_INHAND_FURY -# endif -# define machine_is_inhand_fury() (machine_arch_type == MACH_TYPE_INHAND_FURY) -#else -# define machine_is_inhand_fury() (0) -#endif - -#ifdef CONFIG_MACH_INHAND_SIREN -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_INHAND_SIREN -# endif -# define machine_is_inhand_siren() (machine_arch_type == MACH_TYPE_INHAND_SIREN) -#else -# define machine_is_inhand_siren() (0) -#endif - -#ifdef CONFIG_MACH_HDNVP -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_HDNVP -# endif -# define machine_is_hdnvp() (machine_arch_type == MACH_TYPE_HDNVP) -#else -# define machine_is_hdnvp() (0) -#endif - -#ifdef CONFIG_MACH_SOFTWINNER -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SOFTWINNER -# endif -# define machine_is_softwinner() (machine_arch_type == MACH_TYPE_SOFTWINNER) -#else -# define machine_is_softwinner() (0) -#endif - -#ifdef CONFIG_MACH_PRIMA2_EVB -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_PRIMA2_EVB -# endif -# define machine_is_prima2_evb() (machine_arch_type == MACH_TYPE_PRIMA2_EVB) -#else -# define machine_is_prima2_evb() (0) -#endif - -#ifdef CONFIG_MACH_NAS6210 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NAS6210 -# endif -# define machine_is_nas6210() (machine_arch_type == MACH_TYPE_NAS6210) -#else -# define machine_is_nas6210() (0) -#endif - -#ifdef CONFIG_MACH_UNISDEV -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_UNISDEV -# endif -# define machine_is_unisdev() (machine_arch_type == MACH_TYPE_UNISDEV) -#else -# define machine_is_unisdev() (0) -#endif - -#ifdef CONFIG_MACH_SBCA11 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SBCA11 -# endif -# define machine_is_sbca11() (machine_arch_type == MACH_TYPE_SBCA11) -#else -# define machine_is_sbca11() (0) -#endif - -#ifdef CONFIG_MACH_SAGA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SAGA -# endif -# define machine_is_saga() (machine_arch_type == MACH_TYPE_SAGA) -#else -# define machine_is_saga() (0) -#endif - -#ifdef CONFIG_MACH_NS_K330 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NS_K330 -# endif -# define machine_is_ns_k330() (machine_arch_type == MACH_TYPE_NS_K330) -#else -# define machine_is_ns_k330() (0) -#endif - -#ifdef CONFIG_MACH_TANNA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TANNA -# endif -# define machine_is_tanna() (machine_arch_type == MACH_TYPE_TANNA) -#else -# define machine_is_tanna() (0) -#endif - -#ifdef CONFIG_MACH_IMATE8502 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_IMATE8502 -# endif -# define machine_is_imate8502() (machine_arch_type == MACH_TYPE_IMATE8502) -#else -# define machine_is_imate8502() (0) -#endif - -#ifdef CONFIG_MACH_ASPEN -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ASPEN -# endif -# define machine_is_aspen() (machine_arch_type == MACH_TYPE_ASPEN) -#else -# define machine_is_aspen() (0) -#endif - -#ifdef CONFIG_MACH_DAINTREE_CWAC -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DAINTREE_CWAC -# endif -# define machine_is_daintree_cwac() (machine_arch_type == MACH_TYPE_DAINTREE_CWAC) -#else -# define machine_is_daintree_cwac() (0) -#endif - -#ifdef CONFIG_MACH_ZMX25 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ZMX25 -# endif -# define machine_is_zmx25() (machine_arch_type == MACH_TYPE_ZMX25) -#else -# define machine_is_zmx25() (0) -#endif - -#ifdef CONFIG_MACH_MAPLE1 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MAPLE1 -# endif -# define machine_is_maple1() (machine_arch_type == MACH_TYPE_MAPLE1) -#else -# define machine_is_maple1() (0) -#endif - -#ifdef CONFIG_MACH_QSD8X72_SURF -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_QSD8X72_SURF -# endif -# define machine_is_qsd8x72_surf() (machine_arch_type == MACH_TYPE_QSD8X72_SURF) -#else -# define machine_is_qsd8x72_surf() (0) -#endif - -#ifdef CONFIG_MACH_QSD8X72_FFA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_QSD8X72_FFA -# endif -# define machine_is_qsd8x72_ffa() (machine_arch_type == MACH_TYPE_QSD8X72_FFA) -#else -# define machine_is_qsd8x72_ffa() (0) -#endif - -#ifdef CONFIG_MACH_ABILENE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ABILENE -# endif -# define machine_is_abilene() (machine_arch_type == MACH_TYPE_ABILENE) -#else -# define machine_is_abilene() (0) -#endif - -#ifdef CONFIG_MACH_EIGEN_TTR -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_EIGEN_TTR -# endif -# define machine_is_eigen_ttr() (machine_arch_type == MACH_TYPE_EIGEN_TTR) -#else -# define machine_is_eigen_ttr() (0) -#endif - -#ifdef CONFIG_MACH_IOMEGA_IX2_200 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_IOMEGA_IX2_200 -# endif -# define machine_is_iomega_ix2_200() (machine_arch_type == MACH_TYPE_IOMEGA_IX2_200) -#else -# define machine_is_iomega_ix2_200() (0) -#endif - -#ifdef CONFIG_MACH_CORETEC_VCX7400 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CORETEC_VCX7400 -# endif -# define machine_is_coretec_vcx7400() (machine_arch_type == MACH_TYPE_CORETEC_VCX7400) -#else -# define machine_is_coretec_vcx7400() (0) -#endif - -#ifdef CONFIG_MACH_SANTIAGO -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SANTIAGO -# endif -# define machine_is_santiago() (machine_arch_type == MACH_TYPE_SANTIAGO) -#else -# define machine_is_santiago() (0) -#endif - -#ifdef CONFIG_MACH_MX257SOL -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MX257SOL -# endif -# define machine_is_mx257sol() (machine_arch_type == MACH_TYPE_MX257SOL) -#else -# define machine_is_mx257sol() (0) -#endif - -#ifdef CONFIG_MACH_STRASBOURG -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_STRASBOURG -# endif -# define machine_is_strasbourg() (machine_arch_type == MACH_TYPE_STRASBOURG) -#else -# define machine_is_strasbourg() (0) -#endif - -#ifdef CONFIG_MACH_MSM8X60_FLUID -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MSM8X60_FLUID -# endif -# define machine_is_msm8x60_fluid() (machine_arch_type == MACH_TYPE_MSM8X60_FLUID) -#else -# define machine_is_msm8x60_fluid() (0) -#endif - -#ifdef CONFIG_MACH_SMARTQV5 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SMARTQV5 -# endif -# define machine_is_smartqv5() (machine_arch_type == MACH_TYPE_SMARTQV5) -#else -# define machine_is_smartqv5() (0) -#endif - -#ifdef CONFIG_MACH_SMARTQV3 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SMARTQV3 -# endif -# define machine_is_smartqv3() (machine_arch_type == MACH_TYPE_SMARTQV3) -#else -# define machine_is_smartqv3() (0) -#endif - -#ifdef CONFIG_MACH_SMARTQV7 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SMARTQV7 -# endif -# define machine_is_smartqv7() (machine_arch_type == MACH_TYPE_SMARTQV7) -#else -# define machine_is_smartqv7() (0) -#endif - -#ifdef CONFIG_MACH_PAZ00 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_PAZ00 -# endif -# define machine_is_paz00() (machine_arch_type == MACH_TYPE_PAZ00) -#else -# define machine_is_paz00() (0) -#endif - -#ifdef CONFIG_MACH_ACMENETUSFOXG20 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ACMENETUSFOXG20 -# endif -# define machine_is_acmenetusfoxg20() (machine_arch_type == MACH_TYPE_ACMENETUSFOXG20) -#else -# define machine_is_acmenetusfoxg20() (0) -#endif - -#ifdef CONFIG_MACH_FWBD_0404 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_FWBD_0404 -# endif -# define machine_is_fwbd_0404() (machine_arch_type == MACH_TYPE_FWBD_0404) -#else -# define machine_is_fwbd_0404() (0) -#endif - -#ifdef CONFIG_MACH_HDGU -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_HDGU -# endif -# define machine_is_hdgu() (machine_arch_type == MACH_TYPE_HDGU) -#else -# define machine_is_hdgu() (0) -#endif - -#ifdef CONFIG_MACH_PYRAMID -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_PYRAMID -# endif -# define machine_is_pyramid() (machine_arch_type == MACH_TYPE_PYRAMID) -#else -# define machine_is_pyramid() (0) -#endif - -#ifdef CONFIG_MACH_EPIPHAN -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_EPIPHAN -# endif -# define machine_is_epiphan() (machine_arch_type == MACH_TYPE_EPIPHAN) -#else -# define machine_is_epiphan() (0) -#endif - -#ifdef CONFIG_MACH_OMAP_BENDER -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OMAP_BENDER -# endif -# define machine_is_omap_bender() (machine_arch_type == MACH_TYPE_OMAP_BENDER) -#else -# define machine_is_omap_bender() (0) -#endif - -#ifdef CONFIG_MACH_GURNARD -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_GURNARD -# endif -# define machine_is_gurnard() (machine_arch_type == MACH_TYPE_GURNARD) -#else -# define machine_is_gurnard() (0) -#endif - -#ifdef CONFIG_MACH_GTL_IT5100 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_GTL_IT5100 -# endif -# define machine_is_gtl_it5100() (machine_arch_type == MACH_TYPE_GTL_IT5100) -#else -# define machine_is_gtl_it5100() (0) -#endif - -#ifdef CONFIG_MACH_BCM2708 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_BCM2708 -# endif -# define machine_is_bcm2708() (machine_arch_type == MACH_TYPE_BCM2708) -#else -# define machine_is_bcm2708() (0) -#endif - -#ifdef CONFIG_MACH_MX51_GGC -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MX51_GGC -# endif -# define machine_is_mx51_ggc() (machine_arch_type == MACH_TYPE_MX51_GGC) -#else -# define machine_is_mx51_ggc() (0) -#endif - -#ifdef CONFIG_MACH_SHARESPACE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SHARESPACE -# endif -# define machine_is_sharespace() (machine_arch_type == MACH_TYPE_SHARESPACE) -#else -# define machine_is_sharespace() (0) -#endif - -#ifdef CONFIG_MACH_HABA_KNX_EXPLORER -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_HABA_KNX_EXPLORER -# endif -# define machine_is_haba_knx_explorer() (machine_arch_type == MACH_TYPE_HABA_KNX_EXPLORER) -#else -# define machine_is_haba_knx_explorer() (0) -#endif - -#ifdef CONFIG_MACH_SIMTEC_KIRKMOD -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SIMTEC_KIRKMOD -# endif -# define machine_is_simtec_kirkmod() (machine_arch_type == MACH_TYPE_SIMTEC_KIRKMOD) -#else -# define machine_is_simtec_kirkmod() (0) -#endif - -#ifdef CONFIG_MACH_CRUX -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CRUX -# endif -# define machine_is_crux() (machine_arch_type == MACH_TYPE_CRUX) -#else -# define machine_is_crux() (0) -#endif - -#ifdef CONFIG_MACH_MX51_BRAVO -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MX51_BRAVO -# endif -# define machine_is_mx51_bravo() (machine_arch_type == MACH_TYPE_MX51_BRAVO) -#else -# define machine_is_mx51_bravo() (0) -#endif - -#ifdef CONFIG_MACH_CHARON -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CHARON -# endif -# define machine_is_charon() (machine_arch_type == MACH_TYPE_CHARON) -#else -# define machine_is_charon() (0) -#endif - -#ifdef CONFIG_MACH_PICOCOM3 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_PICOCOM3 -# endif -# define machine_is_picocom3() (machine_arch_type == MACH_TYPE_PICOCOM3) -#else -# define machine_is_picocom3() (0) -#endif - -#ifdef CONFIG_MACH_PICOCOM4 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_PICOCOM4 -# endif -# define machine_is_picocom4() (machine_arch_type == MACH_TYPE_PICOCOM4) -#else -# define machine_is_picocom4() (0) -#endif - -#ifdef CONFIG_MACH_SERRANO -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SERRANO -# endif -# define machine_is_serrano() (machine_arch_type == MACH_TYPE_SERRANO) -#else -# define machine_is_serrano() (0) -#endif - -#ifdef CONFIG_MACH_DOUBLESHOT -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DOUBLESHOT -# endif -# define machine_is_doubleshot() (machine_arch_type == MACH_TYPE_DOUBLESHOT) -#else -# define machine_is_doubleshot() (0) -#endif - -#ifdef CONFIG_MACH_EVSY -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_EVSY -# endif -# define machine_is_evsy() (machine_arch_type == MACH_TYPE_EVSY) -#else -# define machine_is_evsy() (0) -#endif - -#ifdef CONFIG_MACH_HUASHAN -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_HUASHAN -# endif -# define machine_is_huashan() (machine_arch_type == MACH_TYPE_HUASHAN) -#else -# define machine_is_huashan() (0) -#endif - -#ifdef CONFIG_MACH_LAUSANNE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_LAUSANNE -# endif -# define machine_is_lausanne() (machine_arch_type == MACH_TYPE_LAUSANNE) -#else -# define machine_is_lausanne() (0) -#endif - -#ifdef CONFIG_MACH_EMERALD -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_EMERALD -# endif -# define machine_is_emerald() (machine_arch_type == MACH_TYPE_EMERALD) -#else -# define machine_is_emerald() (0) -#endif - -#ifdef CONFIG_MACH_TQMA35 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TQMA35 -# endif -# define machine_is_tqma35() (machine_arch_type == MACH_TYPE_TQMA35) -#else -# define machine_is_tqma35() (0) -#endif - -#ifdef CONFIG_MACH_MARVEL -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MARVEL -# endif -# define machine_is_marvel() (machine_arch_type == MACH_TYPE_MARVEL) -#else -# define machine_is_marvel() (0) -#endif - -#ifdef CONFIG_MACH_MANUAE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MANUAE -# endif -# define machine_is_manuae() (machine_arch_type == MACH_TYPE_MANUAE) -#else -# define machine_is_manuae() (0) -#endif - -#ifdef CONFIG_MACH_CHACHA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CHACHA -# endif -# define machine_is_chacha() (machine_arch_type == MACH_TYPE_CHACHA) -#else -# define machine_is_chacha() (0) -#endif - -#ifdef CONFIG_MACH_LEMON -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_LEMON -# endif -# define machine_is_lemon() (machine_arch_type == MACH_TYPE_LEMON) -#else -# define machine_is_lemon() (0) -#endif - -#ifdef CONFIG_MACH_CSC -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CSC -# endif -# define machine_is_csc() (machine_arch_type == MACH_TYPE_CSC) -#else -# define machine_is_csc() (0) -#endif - -#ifdef CONFIG_MACH_GIRA_KNXIP_ROUTER -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_GIRA_KNXIP_ROUTER -# endif -# define machine_is_gira_knxip_router() (machine_arch_type == MACH_TYPE_GIRA_KNXIP_ROUTER) -#else -# define machine_is_gira_knxip_router() (0) -#endif - -#ifdef CONFIG_MACH_T20 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_T20 -# endif -# define machine_is_t20() (machine_arch_type == MACH_TYPE_T20) -#else -# define machine_is_t20() (0) -#endif - -#ifdef CONFIG_MACH_HDMINI -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_HDMINI -# endif -# define machine_is_hdmini() (machine_arch_type == MACH_TYPE_HDMINI) -#else -# define machine_is_hdmini() (0) -#endif - -#ifdef CONFIG_MACH_SCIPHONE_G2 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SCIPHONE_G2 -# endif -# define machine_is_sciphone_g2() (machine_arch_type == MACH_TYPE_SCIPHONE_G2) -#else -# define machine_is_sciphone_g2() (0) -#endif - -#ifdef CONFIG_MACH_EXPRESS -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_EXPRESS -# endif -# define machine_is_express() (machine_arch_type == MACH_TYPE_EXPRESS) -#else -# define machine_is_express() (0) -#endif - -#ifdef CONFIG_MACH_EXPRESS_KT -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_EXPRESS_KT -# endif -# define machine_is_express_kt() (machine_arch_type == MACH_TYPE_EXPRESS_KT) -#else -# define machine_is_express_kt() (0) -#endif - -#ifdef CONFIG_MACH_MAXIMASP -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MAXIMASP -# endif -# define machine_is_maximasp() (machine_arch_type == MACH_TYPE_MAXIMASP) -#else -# define machine_is_maximasp() (0) -#endif - -#ifdef CONFIG_MACH_NITROGEN_IMX51 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NITROGEN_IMX51 -# endif -# define machine_is_nitrogen_imx51() (machine_arch_type == MACH_TYPE_NITROGEN_IMX51) -#else -# define machine_is_nitrogen_imx51() (0) -#endif - -#ifdef CONFIG_MACH_NITROGEN_IMX53 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NITROGEN_IMX53 -# endif -# define machine_is_nitrogen_imx53() (machine_arch_type == MACH_TYPE_NITROGEN_IMX53) -#else -# define machine_is_nitrogen_imx53() (0) -#endif - -#ifdef CONFIG_MACH_SUNFIRE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SUNFIRE -# endif -# define machine_is_sunfire() (machine_arch_type == MACH_TYPE_SUNFIRE) -#else -# define machine_is_sunfire() (0) -#endif - -#ifdef CONFIG_MACH_AROWANA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_AROWANA -# endif -# define machine_is_arowana() (machine_arch_type == MACH_TYPE_AROWANA) -#else -# define machine_is_arowana() (0) -#endif - -#ifdef CONFIG_MACH_TEGRA_DAYTONA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TEGRA_DAYTONA -# endif -# define machine_is_tegra_daytona() (machine_arch_type == MACH_TYPE_TEGRA_DAYTONA) -#else -# define machine_is_tegra_daytona() (0) -#endif - -#ifdef CONFIG_MACH_TEGRA_SWORDFISH -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TEGRA_SWORDFISH -# endif -# define machine_is_tegra_swordfish() (machine_arch_type == MACH_TYPE_TEGRA_SWORDFISH) -#else -# define machine_is_tegra_swordfish() (0) -#endif - -#ifdef CONFIG_MACH_EDISON -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_EDISON -# endif -# define machine_is_edison() (machine_arch_type == MACH_TYPE_EDISON) -#else -# define machine_is_edison() (0) -#endif - -#ifdef CONFIG_MACH_SVP8500V1 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SVP8500V1 -# endif -# define machine_is_svp8500v1() (machine_arch_type == MACH_TYPE_SVP8500V1) -#else -# define machine_is_svp8500v1() (0) -#endif - -#ifdef CONFIG_MACH_SVP8500V2 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SVP8500V2 -# endif -# define machine_is_svp8500v2() (machine_arch_type == MACH_TYPE_SVP8500V2) -#else -# define machine_is_svp8500v2() (0) -#endif - -#ifdef CONFIG_MACH_SVP5500 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SVP5500 -# endif -# define machine_is_svp5500() (machine_arch_type == MACH_TYPE_SVP5500) -#else -# define machine_is_svp5500() (0) -#endif - -#ifdef CONFIG_MACH_B5500 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_B5500 -# endif -# define machine_is_b5500() (machine_arch_type == MACH_TYPE_B5500) -#else -# define machine_is_b5500() (0) -#endif - -#ifdef CONFIG_MACH_S5500 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_S5500 -# endif -# define machine_is_s5500() (machine_arch_type == MACH_TYPE_S5500) -#else -# define machine_is_s5500() (0) -#endif - -#ifdef CONFIG_MACH_ICON -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ICON -# endif -# define machine_is_icon() (machine_arch_type == MACH_TYPE_ICON) -#else -# define machine_is_icon() (0) -#endif - -#ifdef CONFIG_MACH_ELEPHANT -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ELEPHANT -# endif -# define machine_is_elephant() (machine_arch_type == MACH_TYPE_ELEPHANT) -#else -# define machine_is_elephant() (0) -#endif - -#ifdef CONFIG_MACH_SHOOTER -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SHOOTER -# endif -# define machine_is_shooter() (machine_arch_type == MACH_TYPE_SHOOTER) -#else -# define machine_is_shooter() (0) -#endif - -#ifdef CONFIG_MACH_SPADE_LTE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SPADE_LTE -# endif -# define machine_is_spade_lte() (machine_arch_type == MACH_TYPE_SPADE_LTE) -#else -# define machine_is_spade_lte() (0) -#endif - -#ifdef CONFIG_MACH_PHILHWANI -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_PHILHWANI -# endif -# define machine_is_philhwani() (machine_arch_type == MACH_TYPE_PHILHWANI) -#else -# define machine_is_philhwani() (0) -#endif - -#ifdef CONFIG_MACH_GSNCOMM -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_GSNCOMM -# endif -# define machine_is_gsncomm() (machine_arch_type == MACH_TYPE_GSNCOMM) -#else -# define machine_is_gsncomm() (0) -#endif - -#ifdef CONFIG_MACH_STRASBOURG_A2 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_STRASBOURG_A2 -# endif -# define machine_is_strasbourg_a2() (machine_arch_type == MACH_TYPE_STRASBOURG_A2) -#else -# define machine_is_strasbourg_a2() (0) -#endif - -#ifdef CONFIG_MACH_MMM -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MMM -# endif -# define machine_is_mmm() (machine_arch_type == MACH_TYPE_MMM) -#else -# define machine_is_mmm() (0) -#endif - -#ifdef CONFIG_MACH_DAVINCI_DM365_BV -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DAVINCI_DM365_BV -# endif -# define machine_is_davinci_dm365_bv() (machine_arch_type == MACH_TYPE_DAVINCI_DM365_BV) -#else -# define machine_is_davinci_dm365_bv() (0) -#endif - -#ifdef CONFIG_MACH_AG5EVM -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_AG5EVM -# endif -# define machine_is_ag5evm() (machine_arch_type == MACH_TYPE_AG5EVM) -#else -# define machine_is_ag5evm() (0) -#endif - -#ifdef CONFIG_MACH_SC575PLC -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SC575PLC -# endif -# define machine_is_sc575plc() (machine_arch_type == MACH_TYPE_SC575PLC) -#else -# define machine_is_sc575plc() (0) -#endif - -#ifdef CONFIG_MACH_SC575IPC -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SC575IPC -# endif -# define machine_is_sc575hmi() (machine_arch_type == MACH_TYPE_SC575IPC) -#else -# define machine_is_sc575hmi() (0) -#endif - -#ifdef CONFIG_MACH_OMAP3_TDM3730 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OMAP3_TDM3730 -# endif -# define machine_is_omap3_tdm3730() (machine_arch_type == MACH_TYPE_OMAP3_TDM3730) -#else -# define machine_is_omap3_tdm3730() (0) -#endif - -#ifdef CONFIG_MACH_TOP9000_EVAL -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TOP9000_EVAL -# endif -# define machine_is_top9000_eval() (machine_arch_type == MACH_TYPE_TOP9000_EVAL) -#else -# define machine_is_top9000_eval() (0) -#endif - -#ifdef CONFIG_MACH_TOP9000_SU -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TOP9000_SU -# endif -# define machine_is_top9000_su() (machine_arch_type == MACH_TYPE_TOP9000_SU) -#else -# define machine_is_top9000_su() (0) -#endif - -#ifdef CONFIG_MACH_UTM300 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_UTM300 -# endif -# define machine_is_utm300() (machine_arch_type == MACH_TYPE_UTM300) -#else -# define machine_is_utm300() (0) -#endif - -#ifdef CONFIG_MACH_TSUNAGI -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TSUNAGI -# endif -# define machine_is_tsunagi() (machine_arch_type == MACH_TYPE_TSUNAGI) -#else -# define machine_is_tsunagi() (0) -#endif - -#ifdef CONFIG_MACH_TS75XX -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TS75XX -# endif -# define machine_is_ts75xx() (machine_arch_type == MACH_TYPE_TS75XX) -#else -# define machine_is_ts75xx() (0) -#endif - -#ifdef CONFIG_MACH_TS47XX -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TS47XX -# endif -# define machine_is_ts47xx() (machine_arch_type == MACH_TYPE_TS47XX) -#else -# define machine_is_ts47xx() (0) -#endif - -#ifdef CONFIG_MACH_DA850_K5 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DA850_K5 -# endif -# define machine_is_da850_k5() (machine_arch_type == MACH_TYPE_DA850_K5) -#else -# define machine_is_da850_k5() (0) -#endif - -#ifdef CONFIG_MACH_AX502 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_AX502 -# endif -# define machine_is_ax502() (machine_arch_type == MACH_TYPE_AX502) -#else -# define machine_is_ax502() (0) -#endif - -#ifdef CONFIG_MACH_IGEP0032 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_IGEP0032 -# endif -# define machine_is_igep0032() (machine_arch_type == MACH_TYPE_IGEP0032) -#else -# define machine_is_igep0032() (0) -#endif - -#ifdef CONFIG_MACH_ANTERO -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ANTERO -# endif -# define machine_is_antero() (machine_arch_type == MACH_TYPE_ANTERO) -#else -# define machine_is_antero() (0) -#endif - -#ifdef CONFIG_MACH_SYNERGY -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SYNERGY -# endif -# define machine_is_synergy() (machine_arch_type == MACH_TYPE_SYNERGY) -#else -# define machine_is_synergy() (0) -#endif - -#ifdef CONFIG_MACH_ICS_IF_VOIP -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ICS_IF_VOIP -# endif -# define machine_is_ics_if_voip() (machine_arch_type == MACH_TYPE_ICS_IF_VOIP) -#else -# define machine_is_ics_if_voip() (0) -#endif - -#ifdef CONFIG_MACH_WLF_CRAGG_6410 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_WLF_CRAGG_6410 -# endif -# define machine_is_wlf_cragg_6410() (machine_arch_type == MACH_TYPE_WLF_CRAGG_6410) -#else -# define machine_is_wlf_cragg_6410() (0) -#endif - -#ifdef CONFIG_MACH_PUNICA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_PUNICA -# endif -# define machine_is_punica() (machine_arch_type == MACH_TYPE_PUNICA) -#else -# define machine_is_punica() (0) -#endif - -#ifdef CONFIG_MACH_TRIMSLICE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TRIMSLICE -# endif -# define machine_is_trimslice() (machine_arch_type == MACH_TYPE_TRIMSLICE) -#else -# define machine_is_trimslice() (0) -#endif - -#ifdef CONFIG_MACH_MX27_WMULTRA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MX27_WMULTRA -# endif -# define machine_is_mx27_wmultra() (machine_arch_type == MACH_TYPE_MX27_WMULTRA) -#else -# define machine_is_mx27_wmultra() (0) -#endif - -#ifdef CONFIG_MACH_MACKEREL -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MACKEREL -# endif -# define machine_is_mackerel() (machine_arch_type == MACH_TYPE_MACKEREL) -#else -# define machine_is_mackerel() (0) -#endif - -#ifdef CONFIG_MACH_FA9X27 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_FA9X27 -# endif -# define machine_is_fa9x27() (machine_arch_type == MACH_TYPE_FA9X27) -#else -# define machine_is_fa9x27() (0) -#endif - -#ifdef CONFIG_MACH_NS2816TB -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NS2816TB -# endif -# define machine_is_ns2816tb() (machine_arch_type == MACH_TYPE_NS2816TB) -#else -# define machine_is_ns2816tb() (0) -#endif - -#ifdef CONFIG_MACH_NS2816_NTPAD -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NS2816_NTPAD -# endif -# define machine_is_ns2816_ntpad() (machine_arch_type == MACH_TYPE_NS2816_NTPAD) -#else -# define machine_is_ns2816_ntpad() (0) -#endif - -#ifdef CONFIG_MACH_NS2816_NTNB -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NS2816_NTNB -# endif -# define machine_is_ns2816_ntnb() (machine_arch_type == MACH_TYPE_NS2816_NTNB) -#else -# define machine_is_ns2816_ntnb() (0) -#endif - -#ifdef CONFIG_MACH_KAEN -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_KAEN -# endif -# define machine_is_kaen() (machine_arch_type == MACH_TYPE_KAEN) -#else -# define machine_is_kaen() (0) -#endif - -#ifdef CONFIG_MACH_NV1000 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NV1000 -# endif -# define machine_is_nv1000() (machine_arch_type == MACH_TYPE_NV1000) -#else -# define machine_is_nv1000() (0) -#endif - -#ifdef CONFIG_MACH_NUC950TS -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NUC950TS -# endif -# define machine_is_nuc950ts() (machine_arch_type == MACH_TYPE_NUC950TS) -#else -# define machine_is_nuc950ts() (0) -#endif - -#ifdef CONFIG_MACH_NOKIA_RM680 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NOKIA_RM680 -# endif -# define machine_is_nokia_rm680() (machine_arch_type == MACH_TYPE_NOKIA_RM680) -#else -# define machine_is_nokia_rm680() (0) -#endif - -#ifdef CONFIG_MACH_AST2200 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_AST2200 -# endif -# define machine_is_ast2200() (machine_arch_type == MACH_TYPE_AST2200) -#else -# define machine_is_ast2200() (0) -#endif - -#ifdef CONFIG_MACH_LEAD -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_LEAD -# endif -# define machine_is_lead() (machine_arch_type == MACH_TYPE_LEAD) -#else -# define machine_is_lead() (0) -#endif - -#ifdef CONFIG_MACH_UNINO1 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_UNINO1 -# endif -# define machine_is_unino1() (machine_arch_type == MACH_TYPE_UNINO1) -#else -# define machine_is_unino1() (0) -#endif - -#ifdef CONFIG_MACH_GREECO -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_GREECO -# endif -# define machine_is_greeco() (machine_arch_type == MACH_TYPE_GREECO) -#else -# define machine_is_greeco() (0) -#endif - -#ifdef CONFIG_MACH_VERDI -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_VERDI -# endif -# define machine_is_verdi() (machine_arch_type == MACH_TYPE_VERDI) -#else -# define machine_is_verdi() (0) -#endif - -#ifdef CONFIG_MACH_DM6446_ADBOX -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DM6446_ADBOX -# endif -# define machine_is_dm6446_adbox() (machine_arch_type == MACH_TYPE_DM6446_ADBOX) -#else -# define machine_is_dm6446_adbox() (0) -#endif - -#ifdef CONFIG_MACH_QUAD_SALSA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_QUAD_SALSA -# endif -# define machine_is_quad_salsa() (machine_arch_type == MACH_TYPE_QUAD_SALSA) -#else -# define machine_is_quad_salsa() (0) -#endif - -#ifdef CONFIG_MACH_ABB_GMA_1_1 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ABB_GMA_1_1 -# endif -# define machine_is_abb_gma_1_1() (machine_arch_type == MACH_TYPE_ABB_GMA_1_1) -#else -# define machine_is_abb_gma_1_1() (0) -#endif - -#ifdef CONFIG_MACH_SVCID -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SVCID -# endif -# define machine_is_svcid() (machine_arch_type == MACH_TYPE_SVCID) -#else -# define machine_is_svcid() (0) -#endif - -#ifdef CONFIG_MACH_MSM8960_SIM -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MSM8960_SIM -# endif -# define machine_is_msm8960_sim() (machine_arch_type == MACH_TYPE_MSM8960_SIM) -#else -# define machine_is_msm8960_sim() (0) -#endif - -#ifdef CONFIG_MACH_MSM8960_RUMI3 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MSM8960_RUMI3 -# endif -# define machine_is_msm8960_rumi3() (machine_arch_type == MACH_TYPE_MSM8960_RUMI3) -#else -# define machine_is_msm8960_rumi3() (0) -#endif - -#ifdef CONFIG_MACH_ICON_G -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ICON_G -# endif -# define machine_is_icon_g() (machine_arch_type == MACH_TYPE_ICON_G) -#else -# define machine_is_icon_g() (0) -#endif - -#ifdef CONFIG_MACH_MB3 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MB3 -# endif -# define machine_is_mb3() (machine_arch_type == MACH_TYPE_MB3) -#else -# define machine_is_mb3() (0) -#endif - -#ifdef CONFIG_MACH_GSIA18S -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_GSIA18S -# endif -# define machine_is_gsia18s() (machine_arch_type == MACH_TYPE_GSIA18S) -#else -# define machine_is_gsia18s() (0) -#endif - -#ifdef CONFIG_MACH_PIVICC -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_PIVICC -# endif -# define machine_is_pivicc() (machine_arch_type == MACH_TYPE_PIVICC) -#else -# define machine_is_pivicc() (0) -#endif - -#ifdef CONFIG_MACH_PCM048 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_PCM048 -# endif -# define machine_is_pcm048() (machine_arch_type == MACH_TYPE_PCM048) -#else -# define machine_is_pcm048() (0) -#endif - -#ifdef CONFIG_MACH_DDS -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DDS -# endif -# define machine_is_dds() (machine_arch_type == MACH_TYPE_DDS) -#else -# define machine_is_dds() (0) -#endif - -#ifdef CONFIG_MACH_CHALTEN_XA1 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CHALTEN_XA1 -# endif -# define machine_is_chalten_xa1() (machine_arch_type == MACH_TYPE_CHALTEN_XA1) -#else -# define machine_is_chalten_xa1() (0) -#endif - -#ifdef CONFIG_MACH_TS48XX -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TS48XX -# endif -# define machine_is_ts48xx() (machine_arch_type == MACH_TYPE_TS48XX) -#else -# define machine_is_ts48xx() (0) -#endif - -#ifdef CONFIG_MACH_TONGA2_TFTTIMER -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TONGA2_TFTTIMER -# endif -# define machine_is_tonga2_tfttimer() (machine_arch_type == MACH_TYPE_TONGA2_TFTTIMER) -#else -# define machine_is_tonga2_tfttimer() (0) -#endif - -#ifdef CONFIG_MACH_WHISTLER -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_WHISTLER -# endif -# define machine_is_whistler() (machine_arch_type == MACH_TYPE_WHISTLER) -#else -# define machine_is_whistler() (0) -#endif - -#ifdef CONFIG_MACH_ASL_PHOENIX -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ASL_PHOENIX -# endif -# define machine_is_asl_phoenix() (machine_arch_type == MACH_TYPE_ASL_PHOENIX) -#else -# define machine_is_asl_phoenix() (0) -#endif - -#ifdef CONFIG_MACH_AT91SAM9263OTLITE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_AT91SAM9263OTLITE -# endif -# define machine_is_at91sam9263otlite() (machine_arch_type == MACH_TYPE_AT91SAM9263OTLITE) -#else -# define machine_is_at91sam9263otlite() (0) -#endif - -#ifdef CONFIG_MACH_DDPLUG -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DDPLUG -# endif -# define machine_is_ddplug() (machine_arch_type == MACH_TYPE_DDPLUG) -#else -# define machine_is_ddplug() (0) -#endif - -#ifdef CONFIG_MACH_D2PLUG -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_D2PLUG -# endif -# define machine_is_d2plug() (machine_arch_type == MACH_TYPE_D2PLUG) -#else -# define machine_is_d2plug() (0) -#endif - -#ifdef CONFIG_MACH_KZM9D -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_KZM9D -# endif -# define machine_is_kzm9d() (machine_arch_type == MACH_TYPE_KZM9D) -#else -# define machine_is_kzm9d() (0) -#endif - -#ifdef CONFIG_MACH_VERDI_LTE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_VERDI_LTE -# endif -# define machine_is_verdi_lte() (machine_arch_type == MACH_TYPE_VERDI_LTE) -#else -# define machine_is_verdi_lte() (0) -#endif - -#ifdef CONFIG_MACH_NANOZOOM -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NANOZOOM -# endif -# define machine_is_nanozoom() (machine_arch_type == MACH_TYPE_NANOZOOM) -#else -# define machine_is_nanozoom() (0) -#endif - -#ifdef CONFIG_MACH_DM3730_SOM_LV -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DM3730_SOM_LV -# endif -# define machine_is_dm3730_som_lv() (machine_arch_type == MACH_TYPE_DM3730_SOM_LV) -#else -# define machine_is_dm3730_som_lv() (0) -#endif - -#ifdef CONFIG_MACH_DM3730_TORPEDO -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DM3730_TORPEDO -# endif -# define machine_is_dm3730_torpedo() (machine_arch_type == MACH_TYPE_DM3730_TORPEDO) -#else -# define machine_is_dm3730_torpedo() (0) -#endif - -#ifdef CONFIG_MACH_ANCHOVY -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ANCHOVY -# endif -# define machine_is_anchovy() (machine_arch_type == MACH_TYPE_ANCHOVY) -#else -# define machine_is_anchovy() (0) -#endif - -#ifdef CONFIG_MACH_RE2REV20 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_RE2REV20 -# endif -# define machine_is_re2rev20() (machine_arch_type == MACH_TYPE_RE2REV20) -#else -# define machine_is_re2rev20() (0) -#endif - -#ifdef CONFIG_MACH_RE2REV21 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_RE2REV21 -# endif -# define machine_is_re2rev21() (machine_arch_type == MACH_TYPE_RE2REV21) -#else -# define machine_is_re2rev21() (0) -#endif - -#ifdef CONFIG_MACH_CNS21XX -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CNS21XX -# endif -# define machine_is_cns21xx() (machine_arch_type == MACH_TYPE_CNS21XX) -#else -# define machine_is_cns21xx() (0) -#endif - -#ifdef CONFIG_MACH_RIDER -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_RIDER -# endif -# define machine_is_rider() (machine_arch_type == MACH_TYPE_RIDER) -#else -# define machine_is_rider() (0) -#endif - -#ifdef CONFIG_MACH_NSK330 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NSK330 -# endif -# define machine_is_nsk330() (machine_arch_type == MACH_TYPE_NSK330) -#else -# define machine_is_nsk330() (0) -#endif - -#ifdef CONFIG_MACH_CNS2133EVB -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CNS2133EVB -# endif -# define machine_is_cns2133evb() (machine_arch_type == MACH_TYPE_CNS2133EVB) -#else -# define machine_is_cns2133evb() (0) -#endif - -#ifdef CONFIG_MACH_Z3_816X_MOD -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_Z3_816X_MOD -# endif -# define machine_is_z3_816x_mod() (machine_arch_type == MACH_TYPE_Z3_816X_MOD) -#else -# define machine_is_z3_816x_mod() (0) -#endif - -#ifdef CONFIG_MACH_Z3_814X_MOD -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_Z3_814X_MOD -# endif -# define machine_is_z3_814x_mod() (machine_arch_type == MACH_TYPE_Z3_814X_MOD) -#else -# define machine_is_z3_814x_mod() (0) -#endif - -#ifdef CONFIG_MACH_BEECT -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_BEECT -# endif -# define machine_is_beect() (machine_arch_type == MACH_TYPE_BEECT) -#else -# define machine_is_beect() (0) -#endif - -#ifdef CONFIG_MACH_DMA_THUNDERBUG -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DMA_THUNDERBUG -# endif -# define machine_is_dma_thunderbug() (machine_arch_type == MACH_TYPE_DMA_THUNDERBUG) -#else -# define machine_is_dma_thunderbug() (0) -#endif - -#ifdef CONFIG_MACH_OMN_AT91SAM9G20 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OMN_AT91SAM9G20 -# endif -# define machine_is_omn_at91sam9g20() (machine_arch_type == MACH_TYPE_OMN_AT91SAM9G20) -#else -# define machine_is_omn_at91sam9g20() (0) -#endif - -#ifdef CONFIG_MACH_MX25_E2S_UC -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MX25_E2S_UC -# endif -# define machine_is_mx25_e2s_uc() (machine_arch_type == MACH_TYPE_MX25_E2S_UC) -#else -# define machine_is_mx25_e2s_uc() (0) -#endif - -#ifdef CONFIG_MACH_MIONE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MIONE -# endif -# define machine_is_mione() (machine_arch_type == MACH_TYPE_MIONE) -#else -# define machine_is_mione() (0) -#endif - -#ifdef CONFIG_MACH_TOP9000_TCU -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TOP9000_TCU -# endif -# define machine_is_top9000_tcu() (machine_arch_type == MACH_TYPE_TOP9000_TCU) -#else -# define machine_is_top9000_tcu() (0) -#endif - -#ifdef CONFIG_MACH_TOP9000_BSL -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TOP9000_BSL -# endif -# define machine_is_top9000_bsl() (machine_arch_type == MACH_TYPE_TOP9000_BSL) -#else -# define machine_is_top9000_bsl() (0) -#endif - -#ifdef CONFIG_MACH_KINGDOM -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_KINGDOM -# endif -# define machine_is_kingdom() (machine_arch_type == MACH_TYPE_KINGDOM) -#else -# define machine_is_kingdom() (0) -#endif - -#ifdef CONFIG_MACH_ARMADILLO460 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ARMADILLO460 -# endif -# define machine_is_armadillo460() (machine_arch_type == MACH_TYPE_ARMADILLO460) -#else -# define machine_is_armadillo460() (0) -#endif - -#ifdef CONFIG_MACH_LQ2 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_LQ2 -# endif -# define machine_is_lq2() (machine_arch_type == MACH_TYPE_LQ2) -#else -# define machine_is_lq2() (0) -#endif - -#ifdef CONFIG_MACH_SWEDA_TMS2 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SWEDA_TMS2 -# endif -# define machine_is_sweda_tms2() (machine_arch_type == MACH_TYPE_SWEDA_TMS2) -#else -# define machine_is_sweda_tms2() (0) -#endif - -#ifdef CONFIG_MACH_MX53_LOCO -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MX53_LOCO -# endif -# define machine_is_mx53_loco() (machine_arch_type == MACH_TYPE_MX53_LOCO) -#else -# define machine_is_mx53_loco() (0) -#endif - -#ifdef CONFIG_MACH_ACER_A8 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ACER_A8 -# endif -# define machine_is_acer_a8() (machine_arch_type == MACH_TYPE_ACER_A8) -#else -# define machine_is_acer_a8() (0) -#endif - -#ifdef CONFIG_MACH_ACER_GAUGUIN -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ACER_GAUGUIN -# endif -# define machine_is_acer_gauguin() (machine_arch_type == MACH_TYPE_ACER_GAUGUIN) -#else -# define machine_is_acer_gauguin() (0) -#endif - -#ifdef CONFIG_MACH_GUPPY -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_GUPPY -# endif -# define machine_is_guppy() (machine_arch_type == MACH_TYPE_GUPPY) -#else -# define machine_is_guppy() (0) -#endif - -#ifdef CONFIG_MACH_MX61_ARD -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MX61_ARD -# endif -# define machine_is_mx61_ard() (machine_arch_type == MACH_TYPE_MX61_ARD) -#else -# define machine_is_mx61_ard() (0) -#endif - -#ifdef CONFIG_MACH_TX53 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TX53 -# endif -# define machine_is_tx53() (machine_arch_type == MACH_TYPE_TX53) -#else -# define machine_is_tx53() (0) -#endif - -#ifdef CONFIG_MACH_OMAPL138_CASE_A3 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OMAPL138_CASE_A3 -# endif -# define machine_is_omapl138_case_a3() (machine_arch_type == MACH_TYPE_OMAPL138_CASE_A3) -#else -# define machine_is_omapl138_case_a3() (0) -#endif - -#ifdef CONFIG_MACH_UEMD -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_UEMD -# endif -# define machine_is_uemd() (machine_arch_type == MACH_TYPE_UEMD) -#else -# define machine_is_uemd() (0) -#endif - -#ifdef CONFIG_MACH_CCWMX51MUT -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CCWMX51MUT -# endif -# define machine_is_ccwmx51mut() (machine_arch_type == MACH_TYPE_CCWMX51MUT) -#else -# define machine_is_ccwmx51mut() (0) -#endif - -#ifdef CONFIG_MACH_ROCKHOPPER -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ROCKHOPPER -# endif -# define machine_is_rockhopper() (machine_arch_type == MACH_TYPE_ROCKHOPPER) -#else -# define machine_is_rockhopper() (0) -#endif - -#ifdef CONFIG_MACH_ENCORE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ENCORE -# endif -# define machine_is_encore() (machine_arch_type == MACH_TYPE_ENCORE) -#else -# define machine_is_encore() (0) -#endif - -#ifdef CONFIG_MACH_HKDKC100 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_HKDKC100 -# endif -# define machine_is_hkdkc100() (machine_arch_type == MACH_TYPE_HKDKC100) -#else -# define machine_is_hkdkc100() (0) -#endif - -#ifdef CONFIG_MACH_TS42XX -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TS42XX -# endif -# define machine_is_ts42xx() (machine_arch_type == MACH_TYPE_TS42XX) -#else -# define machine_is_ts42xx() (0) -#endif - -#ifdef CONFIG_MACH_AEBL -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_AEBL -# endif -# define machine_is_aebl() (machine_arch_type == MACH_TYPE_AEBL) -#else -# define machine_is_aebl() (0) -#endif - -#ifdef CONFIG_MACH_WARIO -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_WARIO -# endif -# define machine_is_wario() (machine_arch_type == MACH_TYPE_WARIO) -#else -# define machine_is_wario() (0) -#endif - -#ifdef CONFIG_MACH_GFS_SPM -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_GFS_SPM -# endif -# define machine_is_gfs_spm() (machine_arch_type == MACH_TYPE_GFS_SPM) -#else -# define machine_is_gfs_spm() (0) -#endif - -#ifdef CONFIG_MACH_CM_T3730 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CM_T3730 -# endif -# define machine_is_cm_t3730() (machine_arch_type == MACH_TYPE_CM_T3730) -#else -# define machine_is_cm_t3730() (0) -#endif - -#ifdef CONFIG_MACH_ISC3 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ISC3 -# endif -# define machine_is_isc3() (machine_arch_type == MACH_TYPE_ISC3) -#else -# define machine_is_isc3() (0) -#endif - -#ifdef CONFIG_MACH_RASCAL -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_RASCAL -# endif -# define machine_is_rascal() (machine_arch_type == MACH_TYPE_RASCAL) -#else -# define machine_is_rascal() (0) -#endif - -#ifdef CONFIG_MACH_HREFV60 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_HREFV60 -# endif -# define machine_is_hrefv60() (machine_arch_type == MACH_TYPE_HREFV60) -#else -# define machine_is_hrefv60() (0) -#endif - -#ifdef CONFIG_MACH_TPT_2_0 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TPT_2_0 -# endif -# define machine_is_tpt_2_0() (machine_arch_type == MACH_TYPE_TPT_2_0) -#else -# define machine_is_tpt_2_0() (0) -#endif - -#ifdef CONFIG_MACH_SPLENDOR -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SPLENDOR -# endif -# define machine_is_splendor() (machine_arch_type == MACH_TYPE_SPLENDOR) -#else -# define machine_is_splendor() (0) -#endif - -#ifdef CONFIG_MACH_MSM8X60_QT -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MSM8X60_QT -# endif -# define machine_is_msm8x60_qt() (machine_arch_type == MACH_TYPE_MSM8X60_QT) -#else -# define machine_is_msm8x60_qt() (0) -#endif - -#ifdef CONFIG_MACH_HTC_HD_MINI -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_HTC_HD_MINI -# endif -# define machine_is_htc_hd_mini() (machine_arch_type == MACH_TYPE_HTC_HD_MINI) -#else -# define machine_is_htc_hd_mini() (0) -#endif - -#ifdef CONFIG_MACH_ATHENE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ATHENE -# endif -# define machine_is_athene() (machine_arch_type == MACH_TYPE_ATHENE) -#else -# define machine_is_athene() (0) -#endif - -#ifdef CONFIG_MACH_DEEP_R_EK_1 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DEEP_R_EK_1 -# endif -# define machine_is_deep_r_ek_1() (machine_arch_type == MACH_TYPE_DEEP_R_EK_1) -#else -# define machine_is_deep_r_ek_1() (0) -#endif - -#ifdef CONFIG_MACH_VIVOW_CT -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_VIVOW_CT -# endif -# define machine_is_vivow_ct() (machine_arch_type == MACH_TYPE_VIVOW_CT) -#else -# define machine_is_vivow_ct() (0) -#endif - -#ifdef CONFIG_MACH_NERY_1000 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NERY_1000 -# endif -# define machine_is_nery_1000() (machine_arch_type == MACH_TYPE_NERY_1000) -#else -# define machine_is_nery_1000() (0) -#endif - -#ifdef CONFIG_MACH_RFL109145_SSRV -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_RFL109145_SSRV -# endif -# define machine_is_rfl109145_ssrv() (machine_arch_type == MACH_TYPE_RFL109145_SSRV) -#else -# define machine_is_rfl109145_ssrv() (0) -#endif - -#ifdef CONFIG_MACH_NMH -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NMH -# endif -# define machine_is_nmh() (machine_arch_type == MACH_TYPE_NMH) -#else -# define machine_is_nmh() (0) -#endif - -#ifdef CONFIG_MACH_WN802T -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_WN802T -# endif -# define machine_is_wn802t() (machine_arch_type == MACH_TYPE_WN802T) -#else -# define machine_is_wn802t() (0) -#endif - -#ifdef CONFIG_MACH_DRAGONET -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DRAGONET -# endif -# define machine_is_dragonet() (machine_arch_type == MACH_TYPE_DRAGONET) -#else -# define machine_is_dragonet() (0) -#endif - -#ifdef CONFIG_MACH_AT91SAM9263DESK16L -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_AT91SAM9263DESK16L -# endif -# define machine_is_at91sam9263desk16l() (machine_arch_type == MACH_TYPE_AT91SAM9263DESK16L) -#else -# define machine_is_at91sam9263desk16l() (0) -#endif - -#ifdef CONFIG_MACH_BCMHANA_SV -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_BCMHANA_SV -# endif -# define machine_is_bcmhana_sv() (machine_arch_type == MACH_TYPE_BCMHANA_SV) -#else -# define machine_is_bcmhana_sv() (0) -#endif - -#ifdef CONFIG_MACH_BCMHANA_TABLET -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_BCMHANA_TABLET -# endif -# define machine_is_bcmhana_tablet() (machine_arch_type == MACH_TYPE_BCMHANA_TABLET) -#else -# define machine_is_bcmhana_tablet() (0) -#endif - -#ifdef CONFIG_MACH_KOI -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_KOI -# endif -# define machine_is_koi() (machine_arch_type == MACH_TYPE_KOI) -#else -# define machine_is_koi() (0) -#endif - -#ifdef CONFIG_MACH_TS4800 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TS4800 -# endif -# define machine_is_ts4800() (machine_arch_type == MACH_TYPE_TS4800) -#else -# define machine_is_ts4800() (0) -#endif - -#ifdef CONFIG_MACH_TQMA9263 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TQMA9263 -# endif -# define machine_is_tqma9263() (machine_arch_type == MACH_TYPE_TQMA9263) -#else -# define machine_is_tqma9263() (0) -#endif - -#ifdef CONFIG_MACH_HOLIDAY -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_HOLIDAY -# endif -# define machine_is_holiday() (machine_arch_type == MACH_TYPE_HOLIDAY) -#else -# define machine_is_holiday() (0) -#endif - -#ifdef CONFIG_MACH_DMA6410 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DMA6410 -# endif -# define machine_is_dma_6410() (machine_arch_type == MACH_TYPE_DMA6410) -#else -# define machine_is_dma_6410() (0) -#endif - -#ifdef CONFIG_MACH_PCATS_OVERLAY -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_PCATS_OVERLAY -# endif -# define machine_is_pcats_overlay() (machine_arch_type == MACH_TYPE_PCATS_OVERLAY) -#else -# define machine_is_pcats_overlay() (0) -#endif - -#ifdef CONFIG_MACH_HWGW6410 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_HWGW6410 -# endif -# define machine_is_hwgw6410() (machine_arch_type == MACH_TYPE_HWGW6410) -#else -# define machine_is_hwgw6410() (0) -#endif - -#ifdef CONFIG_MACH_SHENZHOU -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SHENZHOU -# endif -# define machine_is_shenzhou() (machine_arch_type == MACH_TYPE_SHENZHOU) -#else -# define machine_is_shenzhou() (0) -#endif - -#ifdef CONFIG_MACH_CWME9210 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CWME9210 -# endif -# define machine_is_cwme9210() (machine_arch_type == MACH_TYPE_CWME9210) -#else -# define machine_is_cwme9210() (0) -#endif - -#ifdef CONFIG_MACH_CWME9210JS -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CWME9210JS -# endif -# define machine_is_cwme9210js() (machine_arch_type == MACH_TYPE_CWME9210JS) -#else -# define machine_is_cwme9210js() (0) -#endif - -#ifdef CONFIG_MACH_PGS_SITARA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_PGS_SITARA -# endif -# define machine_is_pgs_v1() (machine_arch_type == MACH_TYPE_PGS_SITARA) -#else -# define machine_is_pgs_v1() (0) -#endif - -#ifdef CONFIG_MACH_COLIBRI_T20 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_COLIBRI_T20 -# endif -# define machine_is_colibri_t20() (machine_arch_type == MACH_TYPE_COLIBRI_T20) -#else -# define machine_is_colibri_t20() (0) -#endif - -#ifdef CONFIG_MACH_W21 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_W21 -# endif -# define machine_is_w21() (machine_arch_type == MACH_TYPE_W21) -#else -# define machine_is_w21() (0) -#endif - -#ifdef CONFIG_MACH_POLYSAT1 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_POLYSAT1 -# endif -# define machine_is_polysat1() (machine_arch_type == MACH_TYPE_POLYSAT1) -#else -# define machine_is_polysat1() (0) -#endif - -#ifdef CONFIG_MACH_DATAWAY -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DATAWAY -# endif -# define machine_is_dataway() (machine_arch_type == MACH_TYPE_DATAWAY) -#else -# define machine_is_dataway() (0) -#endif - -#ifdef CONFIG_MACH_COBRAL138 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_COBRAL138 -# endif -# define machine_is_cobral138() (machine_arch_type == MACH_TYPE_COBRAL138) -#else -# define machine_is_cobral138() (0) -#endif - -#ifdef CONFIG_MACH_ROVERPCS8 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ROVERPCS8 -# endif -# define machine_is_roverpcs8() (machine_arch_type == MACH_TYPE_ROVERPCS8) -#else -# define machine_is_roverpcs8() (0) -#endif - -#ifdef CONFIG_MACH_MARVELC -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MARVELC -# endif -# define machine_is_marvelc() (machine_arch_type == MACH_TYPE_MARVELC) -#else -# define machine_is_marvelc() (0) -#endif - -#ifdef CONFIG_MACH_NAVEFIHID -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NAVEFIHID -# endif -# define machine_is_navefihid() (machine_arch_type == MACH_TYPE_NAVEFIHID) -#else -# define machine_is_navefihid() (0) -#endif - -#ifdef CONFIG_MACH_DM365_CV100 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DM365_CV100 -# endif -# define machine_is_dm365_cv100() (machine_arch_type == MACH_TYPE_DM365_CV100) -#else -# define machine_is_dm365_cv100() (0) -#endif - -#ifdef CONFIG_MACH_ABLE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ABLE -# endif -# define machine_is_able() (machine_arch_type == MACH_TYPE_ABLE) -#else -# define machine_is_able() (0) -#endif - -#ifdef CONFIG_MACH_LEGACY -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_LEGACY -# endif -# define machine_is_legacy() (machine_arch_type == MACH_TYPE_LEGACY) -#else -# define machine_is_legacy() (0) -#endif - -#ifdef CONFIG_MACH_ICONG -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ICONG -# endif -# define machine_is_icong() (machine_arch_type == MACH_TYPE_ICONG) -#else -# define machine_is_icong() (0) -#endif - -#ifdef CONFIG_MACH_ROVER_G8 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ROVER_G8 -# endif -# define machine_is_rover_g8() (machine_arch_type == MACH_TYPE_ROVER_G8) -#else -# define machine_is_rover_g8() (0) -#endif - -#ifdef CONFIG_MACH_T5388P -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_T5388P -# endif -# define machine_is_t5388p() (machine_arch_type == MACH_TYPE_T5388P) -#else -# define machine_is_t5388p() (0) -#endif - -#ifdef CONFIG_MACH_DINGO -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DINGO -# endif -# define machine_is_dingo() (machine_arch_type == MACH_TYPE_DINGO) -#else -# define machine_is_dingo() (0) -#endif - -#ifdef CONFIG_MACH_GOFLEXHOME -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_GOFLEXHOME -# endif -# define machine_is_goflexhome() (machine_arch_type == MACH_TYPE_GOFLEXHOME) -#else -# define machine_is_goflexhome() (0) -#endif - -#ifdef CONFIG_MACH_LANREADYFN511 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_LANREADYFN511 -# endif -# define machine_is_lanreadyfn511() (machine_arch_type == MACH_TYPE_LANREADYFN511) -#else -# define machine_is_lanreadyfn511() (0) -#endif - -#ifdef CONFIG_MACH_OMAP3_BAIA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OMAP3_BAIA -# endif -# define machine_is_omap3_baia() (machine_arch_type == MACH_TYPE_OMAP3_BAIA) -#else -# define machine_is_omap3_baia() (0) -#endif - -#ifdef CONFIG_MACH_OMAP3SMARTDISPLAY -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OMAP3SMARTDISPLAY -# endif -# define machine_is_omap3smartdisplay() (machine_arch_type == MACH_TYPE_OMAP3SMARTDISPLAY) -#else -# define machine_is_omap3smartdisplay() (0) -#endif - -#ifdef CONFIG_MACH_XILINX -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_XILINX -# endif -# define machine_is_xilinx() (machine_arch_type == MACH_TYPE_XILINX) -#else -# define machine_is_xilinx() (0) -#endif - -#ifdef CONFIG_MACH_A2F -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_A2F -# endif -# define machine_is_a2f() (machine_arch_type == MACH_TYPE_A2F) -#else -# define machine_is_a2f() (0) -#endif - -#ifdef CONFIG_MACH_SKY25 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SKY25 -# endif -# define machine_is_sky25() (machine_arch_type == MACH_TYPE_SKY25) -#else -# define machine_is_sky25() (0) -#endif - -#ifdef CONFIG_MACH_CCMX53 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CCMX53 -# endif -# define machine_is_ccmx53() (machine_arch_type == MACH_TYPE_CCMX53) -#else -# define machine_is_ccmx53() (0) -#endif - -#ifdef CONFIG_MACH_CCMX53JS -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CCMX53JS -# endif -# define machine_is_ccmx53js() (machine_arch_type == MACH_TYPE_CCMX53JS) -#else -# define machine_is_ccmx53js() (0) -#endif - -#ifdef CONFIG_MACH_CCWMX53 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CCWMX53 -# endif -# define machine_is_ccwmx53() (machine_arch_type == MACH_TYPE_CCWMX53) -#else -# define machine_is_ccwmx53() (0) -#endif - -#ifdef CONFIG_MACH_CCWMX53JS -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CCWMX53JS -# endif -# define machine_is_ccwmx53js() (machine_arch_type == MACH_TYPE_CCWMX53JS) -#else -# define machine_is_ccwmx53js() (0) -#endif - -#ifdef CONFIG_MACH_FRISMS -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_FRISMS -# endif -# define machine_is_frisms() (machine_arch_type == MACH_TYPE_FRISMS) -#else -# define machine_is_frisms() (0) -#endif - -#ifdef CONFIG_MACH_MSM7X27A_FFA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MSM7X27A_FFA -# endif -# define machine_is_msm7x27a_ffa() (machine_arch_type == MACH_TYPE_MSM7X27A_FFA) -#else -# define machine_is_msm7x27a_ffa() (0) -#endif - -#ifdef CONFIG_MACH_MSM7X27A_SURF -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MSM7X27A_SURF -# endif -# define machine_is_msm7x27a_surf() (machine_arch_type == MACH_TYPE_MSM7X27A_SURF) -#else -# define machine_is_msm7x27a_surf() (0) -#endif - -#ifdef CONFIG_MACH_MSM7X27A_RUMI3 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MSM7X27A_RUMI3 -# endif -# define machine_is_msm7x27a_rumi3() (machine_arch_type == MACH_TYPE_MSM7X27A_RUMI3) -#else -# define machine_is_msm7x27a_rumi3() (0) -#endif - -#ifdef CONFIG_MACH_DIMMSAM9G20 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DIMMSAM9G20 -# endif -# define machine_is_dimmsam9g20() (machine_arch_type == MACH_TYPE_DIMMSAM9G20) -#else -# define machine_is_dimmsam9g20() (0) -#endif - -#ifdef CONFIG_MACH_DIMM_IMX28 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DIMM_IMX28 -# endif -# define machine_is_dimm_imx28() (machine_arch_type == MACH_TYPE_DIMM_IMX28) -#else -# define machine_is_dimm_imx28() (0) -#endif - -#ifdef CONFIG_MACH_AMK_A4 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_AMK_A4 -# endif -# define machine_is_amk_a4() (machine_arch_type == MACH_TYPE_AMK_A4) -#else -# define machine_is_amk_a4() (0) -#endif - -#ifdef CONFIG_MACH_GNET_SGME -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_GNET_SGME -# endif -# define machine_is_gnet_sgme() (machine_arch_type == MACH_TYPE_GNET_SGME) -#else -# define machine_is_gnet_sgme() (0) -#endif - -#ifdef CONFIG_MACH_SHOOTER_U -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SHOOTER_U -# endif -# define machine_is_shooter_u() (machine_arch_type == MACH_TYPE_SHOOTER_U) -#else -# define machine_is_shooter_u() (0) -#endif - -#ifdef CONFIG_MACH_VMX53 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_VMX53 -# endif -# define machine_is_vmx53() (machine_arch_type == MACH_TYPE_VMX53) -#else -# define machine_is_vmx53() (0) -#endif - -#ifdef CONFIG_MACH_RHINO -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_RHINO -# endif -# define machine_is_rhino() (machine_arch_type == MACH_TYPE_RHINO) -#else -# define machine_is_rhino() (0) -#endif - -#ifdef CONFIG_MACH_ARMLEX4210 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ARMLEX4210 -# endif -# define machine_is_armlex4210() (machine_arch_type == MACH_TYPE_ARMLEX4210) -#else -# define machine_is_armlex4210() (0) -#endif - -#ifdef CONFIG_MACH_SWARCOEXTMODEM -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SWARCOEXTMODEM -# endif -# define machine_is_swarcoextmodem() (machine_arch_type == MACH_TYPE_SWARCOEXTMODEM) -#else -# define machine_is_swarcoextmodem() (0) -#endif - -#ifdef CONFIG_MACH_PCM049 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_PCM049 -# endif -# define machine_is_pcm049() (machine_arch_type == MACH_TYPE_PCM049) -#else -# define machine_is_pcm049() (0) -#endif - -#ifdef CONFIG_MACH_VIGOR -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_VIGOR -# endif -# define machine_is_vigor() (machine_arch_type == MACH_TYPE_VIGOR) -#else -# define machine_is_vigor() (0) -#endif - -#ifdef CONFIG_MACH_OSLO_AMUNDSEN -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OSLO_AMUNDSEN -# endif -# define machine_is_oslo_amundsen() (machine_arch_type == MACH_TYPE_OSLO_AMUNDSEN) -#else -# define machine_is_oslo_amundsen() (0) -#endif - -#ifdef CONFIG_MACH_GSL_DIAMOND -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_GSL_DIAMOND -# endif -# define machine_is_gsl_diamond() (machine_arch_type == MACH_TYPE_GSL_DIAMOND) -#else -# define machine_is_gsl_diamond() (0) -#endif - -#ifdef CONFIG_MACH_CV2201 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CV2201 -# endif -# define machine_is_cv2201() (machine_arch_type == MACH_TYPE_CV2201) -#else -# define machine_is_cv2201() (0) -#endif - -#ifdef CONFIG_MACH_CV2202 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CV2202 -# endif -# define machine_is_cv2202() (machine_arch_type == MACH_TYPE_CV2202) -#else -# define machine_is_cv2202() (0) -#endif - -#ifdef CONFIG_MACH_CV2203 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CV2203 -# endif -# define machine_is_cv2203() (machine_arch_type == MACH_TYPE_CV2203) -#else -# define machine_is_cv2203() (0) -#endif - -#ifdef CONFIG_MACH_VIT_IBOX -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_VIT_IBOX -# endif -# define machine_is_vit_ibox() (machine_arch_type == MACH_TYPE_VIT_IBOX) -#else -# define machine_is_vit_ibox() (0) -#endif - -#ifdef CONFIG_MACH_DM6441_ESP -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DM6441_ESP -# endif -# define machine_is_dm6441_esp() (machine_arch_type == MACH_TYPE_DM6441_ESP) -#else -# define machine_is_dm6441_esp() (0) -#endif - -#ifdef CONFIG_MACH_AT91SAM9X5EK -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_AT91SAM9X5EK -# endif -# define machine_is_at91sam9x5ek() (machine_arch_type == MACH_TYPE_AT91SAM9X5EK) -#else -# define machine_is_at91sam9x5ek() (0) -#endif - -#ifdef CONFIG_MACH_LIBRA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_LIBRA -# endif -# define machine_is_libra() (machine_arch_type == MACH_TYPE_LIBRA) -#else -# define machine_is_libra() (0) -#endif - -#ifdef CONFIG_MACH_EASYCRRH -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_EASYCRRH -# endif -# define machine_is_easycrrh() (machine_arch_type == MACH_TYPE_EASYCRRH) -#else -# define machine_is_easycrrh() (0) -#endif - -#ifdef CONFIG_MACH_TRIPEL -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TRIPEL -# endif -# define machine_is_tripel() (machine_arch_type == MACH_TYPE_TRIPEL) -#else -# define machine_is_tripel() (0) -#endif - -#ifdef CONFIG_MACH_ENDIAN_MINI -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ENDIAN_MINI -# endif -# define machine_is_endian_mini() (machine_arch_type == MACH_TYPE_ENDIAN_MINI) -#else -# define machine_is_endian_mini() (0) -#endif - -#ifdef CONFIG_MACH_XILINX_EP107 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_XILINX_EP107 -# endif -# define machine_is_xilinx_ep107() (machine_arch_type == MACH_TYPE_XILINX_EP107) -#else -# define machine_is_xilinx_ep107() (0) -#endif - -#ifdef CONFIG_MACH_NURI -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NURI -# endif -# define machine_is_nuri() (machine_arch_type == MACH_TYPE_NURI) -#else -# define machine_is_nuri() (0) -#endif - -#ifdef CONFIG_MACH_JANUS -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_JANUS -# endif -# define machine_is_janus() (machine_arch_type == MACH_TYPE_JANUS) -#else -# define machine_is_janus() (0) -#endif - -#ifdef CONFIG_MACH_DDNAS -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DDNAS -# endif -# define machine_is_ddnas() (machine_arch_type == MACH_TYPE_DDNAS) -#else -# define machine_is_ddnas() (0) -#endif - -#ifdef CONFIG_MACH_TAG -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TAG -# endif -# define machine_is_tag() (machine_arch_type == MACH_TYPE_TAG) -#else -# define machine_is_tag() (0) -#endif - -#ifdef CONFIG_MACH_TAGW -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TAGW -# endif -# define machine_is_tagw() (machine_arch_type == MACH_TYPE_TAGW) -#else -# define machine_is_tagw() (0) -#endif - -#ifdef CONFIG_MACH_NITROGEN_VM_IMX51 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NITROGEN_VM_IMX51 -# endif -# define machine_is_nitrogen_vm_imx51() (machine_arch_type == MACH_TYPE_NITROGEN_VM_IMX51) -#else -# define machine_is_nitrogen_vm_imx51() (0) -#endif - -#ifdef CONFIG_MACH_VIPRINET -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_VIPRINET -# endif -# define machine_is_viprinet() (machine_arch_type == MACH_TYPE_VIPRINET) -#else -# define machine_is_viprinet() (0) -#endif - -#ifdef CONFIG_MACH_BOCKW -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_BOCKW -# endif -# define machine_is_bockw() (machine_arch_type == MACH_TYPE_BOCKW) -#else -# define machine_is_bockw() (0) -#endif - -#ifdef CONFIG_MACH_EVA2000 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_EVA2000 -# endif -# define machine_is_eva2000() (machine_arch_type == MACH_TYPE_EVA2000) -#else -# define machine_is_eva2000() (0) -#endif - -#ifdef CONFIG_MACH_STEELYARD -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_STEELYARD -# endif -# define machine_is_steelyard() (machine_arch_type == MACH_TYPE_STEELYARD) -#else -# define machine_is_steelyard() (0) -#endif - -#ifdef CONFIG_MACH_MACH_SDH001 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MACH_SDH001 -# endif -# define machine_is_sdh001() (machine_arch_type == MACH_TYPE_MACH_SDH001) -#else -# define machine_is_sdh001() (0) -#endif - -#ifdef CONFIG_MACH_NSSLSBOARD -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NSSLSBOARD -# endif -# define machine_is_nsslsboard() (machine_arch_type == MACH_TYPE_NSSLSBOARD) -#else -# define machine_is_nsslsboard() (0) -#endif - -#ifdef CONFIG_MACH_GENEVA_B5 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_GENEVA_B5 -# endif -# define machine_is_geneva_b5() (machine_arch_type == MACH_TYPE_GENEVA_B5) -#else -# define machine_is_geneva_b5() (0) -#endif - -#ifdef CONFIG_MACH_SPEAR1340 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SPEAR1340 -# endif -# define machine_is_spear1340() (machine_arch_type == MACH_TYPE_SPEAR1340) -#else -# define machine_is_spear1340() (0) -#endif - -#ifdef CONFIG_MACH_REXMAS -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_REXMAS -# endif -# define machine_is_rexmas() (machine_arch_type == MACH_TYPE_REXMAS) -#else -# define machine_is_rexmas() (0) -#endif - -#ifdef CONFIG_MACH_MSM8960_CDP -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MSM8960_CDP -# endif -# define machine_is_msm8960_cdp() (machine_arch_type == MACH_TYPE_MSM8960_CDP) -#else -# define machine_is_msm8960_cdp() (0) -#endif - -#ifdef CONFIG_MACH_MSM8960_MDP -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MSM8960_MDP -# endif -# define machine_is_msm8960_mdp() (machine_arch_type == MACH_TYPE_MSM8960_MDP) -#else -# define machine_is_msm8960_mdp() (0) -#endif - -#ifdef CONFIG_MACH_MSM8960_FLUID -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MSM8960_FLUID -# endif -# define machine_is_msm8960_fluid() (machine_arch_type == MACH_TYPE_MSM8960_FLUID) -#else -# define machine_is_msm8960_fluid() (0) -#endif - -#ifdef CONFIG_MACH_MSM8960_APQ -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MSM8960_APQ -# endif -# define machine_is_msm8960_apq() (machine_arch_type == MACH_TYPE_MSM8960_APQ) -#else -# define machine_is_msm8960_apq() (0) -#endif - -#ifdef CONFIG_MACH_HELIOS_V2 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_HELIOS_V2 -# endif -# define machine_is_helios_v2() (machine_arch_type == MACH_TYPE_HELIOS_V2) -#else -# define machine_is_helios_v2() (0) -#endif - -#ifdef CONFIG_MACH_MIF10P -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MIF10P -# endif -# define machine_is_mif10p() (machine_arch_type == MACH_TYPE_MIF10P) -#else -# define machine_is_mif10p() (0) -#endif - -#ifdef CONFIG_MACH_IAM28 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_IAM28 -# endif -# define machine_is_iam28() (machine_arch_type == MACH_TYPE_IAM28) -#else -# define machine_is_iam28() (0) -#endif - -#ifdef CONFIG_MACH_PICASSO -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_PICASSO -# endif -# define machine_is_picasso() (machine_arch_type == MACH_TYPE_PICASSO) -#else -# define machine_is_picasso() (0) -#endif - -#ifdef CONFIG_MACH_MR301A -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MR301A -# endif -# define machine_is_mr301a() (machine_arch_type == MACH_TYPE_MR301A) -#else -# define machine_is_mr301a() (0) -#endif - -#ifdef CONFIG_MACH_NOTLE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NOTLE -# endif -# define machine_is_notle() (machine_arch_type == MACH_TYPE_NOTLE) -#else -# define machine_is_notle() (0) -#endif - -#ifdef CONFIG_MACH_EELX2 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_EELX2 -# endif -# define machine_is_eelx2() (machine_arch_type == MACH_TYPE_EELX2) -#else -# define machine_is_eelx2() (0) -#endif - -#ifdef CONFIG_MACH_MOON -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MOON -# endif -# define machine_is_moon() (machine_arch_type == MACH_TYPE_MOON) -#else -# define machine_is_moon() (0) -#endif - -#ifdef CONFIG_MACH_RUBY -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_RUBY -# endif -# define machine_is_ruby() (machine_arch_type == MACH_TYPE_RUBY) -#else -# define machine_is_ruby() (0) -#endif - -#ifdef CONFIG_MACH_GOLDENGATE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_GOLDENGATE -# endif -# define machine_is_goldengate() (machine_arch_type == MACH_TYPE_GOLDENGATE) -#else -# define machine_is_goldengate() (0) -#endif - -#ifdef CONFIG_MACH_CTBU_GEN2 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CTBU_GEN2 -# endif -# define machine_is_ctbu_gen2() (machine_arch_type == MACH_TYPE_CTBU_GEN2) -#else -# define machine_is_ctbu_gen2() (0) -#endif - -#ifdef CONFIG_MACH_KMP_AM17_01 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_KMP_AM17_01 -# endif -# define machine_is_kmp_am17_01() (machine_arch_type == MACH_TYPE_KMP_AM17_01) -#else -# define machine_is_kmp_am17_01() (0) -#endif - -#ifdef CONFIG_MACH_WTPLUG -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_WTPLUG -# endif -# define machine_is_wtplug() (machine_arch_type == MACH_TYPE_WTPLUG) -#else -# define machine_is_wtplug() (0) -#endif - -#ifdef CONFIG_MACH_MX27SU2 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MX27SU2 -# endif -# define machine_is_mx27su2() (machine_arch_type == MACH_TYPE_MX27SU2) -#else -# define machine_is_mx27su2() (0) -#endif - -#ifdef CONFIG_MACH_NB31 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NB31 -# endif -# define machine_is_nb31() (machine_arch_type == MACH_TYPE_NB31) -#else -# define machine_is_nb31() (0) -#endif - -#ifdef CONFIG_MACH_HJSDU -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_HJSDU -# endif -# define machine_is_hjsdu() (machine_arch_type == MACH_TYPE_HJSDU) -#else -# define machine_is_hjsdu() (0) -#endif - -#ifdef CONFIG_MACH_TD3_REV1 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TD3_REV1 -# endif -# define machine_is_td3_rev1() (machine_arch_type == MACH_TYPE_TD3_REV1) -#else -# define machine_is_td3_rev1() (0) -#endif - -#ifdef CONFIG_MACH_EAG_CI4000 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_EAG_CI4000 -# endif -# define machine_is_eag_ci4000() (machine_arch_type == MACH_TYPE_EAG_CI4000) -#else -# define machine_is_eag_ci4000() (0) -#endif - -#ifdef CONFIG_MACH_NET5BIG_NAND_V2 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NET5BIG_NAND_V2 -# endif -# define machine_is_net5big_nand_v2() (machine_arch_type == MACH_TYPE_NET5BIG_NAND_V2) -#else -# define machine_is_net5big_nand_v2() (0) -#endif - -#ifdef CONFIG_MACH_CPX2 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CPX2 -# endif -# define machine_is_cpx2() (machine_arch_type == MACH_TYPE_CPX2) -#else -# define machine_is_cpx2() (0) -#endif - -#ifdef CONFIG_MACH_NET2BIG_NAND_V2 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NET2BIG_NAND_V2 -# endif -# define machine_is_net2big_nand_v2() (machine_arch_type == MACH_TYPE_NET2BIG_NAND_V2) -#else -# define machine_is_net2big_nand_v2() (0) -#endif - -#ifdef CONFIG_MACH_ECUV5 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ECUV5 -# endif -# define machine_is_ecuv5() (machine_arch_type == MACH_TYPE_ECUV5) -#else -# define machine_is_ecuv5() (0) -#endif - -#ifdef CONFIG_MACH_HSGX6D -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_HSGX6D -# endif -# define machine_is_hsgx6d() (machine_arch_type == MACH_TYPE_HSGX6D) -#else -# define machine_is_hsgx6d() (0) -#endif - -#ifdef CONFIG_MACH_DAWAD7 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DAWAD7 -# endif -# define machine_is_dawad7() (machine_arch_type == MACH_TYPE_DAWAD7) -#else -# define machine_is_dawad7() (0) -#endif - -#ifdef CONFIG_MACH_SAM9REPEATER -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SAM9REPEATER -# endif -# define machine_is_sam9repeater() (machine_arch_type == MACH_TYPE_SAM9REPEATER) -#else -# define machine_is_sam9repeater() (0) -#endif - -#ifdef CONFIG_MACH_GT_I5700 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_GT_I5700 -# endif -# define machine_is_gt_i5700() (machine_arch_type == MACH_TYPE_GT_I5700) -#else -# define machine_is_gt_i5700() (0) -#endif - -#ifdef CONFIG_MACH_CTERA_PLUG_C2 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CTERA_PLUG_C2 -# endif -# define machine_is_ctera_plug_c2() (machine_arch_type == MACH_TYPE_CTERA_PLUG_C2) -#else -# define machine_is_ctera_plug_c2() (0) -#endif - -#ifdef CONFIG_MACH_MARVELCT -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MARVELCT -# endif -# define machine_is_marvelct() (machine_arch_type == MACH_TYPE_MARVELCT) -#else -# define machine_is_marvelct() (0) -#endif - -#ifdef CONFIG_MACH_AG11005 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_AG11005 -# endif -# define machine_is_ag11005() (machine_arch_type == MACH_TYPE_AG11005) -#else -# define machine_is_ag11005() (0) -#endif - -#ifdef CONFIG_MACH_VANGOGH -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_VANGOGH -# endif -# define machine_is_vangogh() (machine_arch_type == MACH_TYPE_VANGOGH) -#else -# define machine_is_vangogh() (0) -#endif - -#ifdef CONFIG_MACH_MATRIX505 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MATRIX505 -# endif -# define machine_is_matrix505() (machine_arch_type == MACH_TYPE_MATRIX505) -#else -# define machine_is_matrix505() (0) -#endif - -#ifdef CONFIG_MACH_OCE_NIGMA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OCE_NIGMA -# endif -# define machine_is_oce_nigma() (machine_arch_type == MACH_TYPE_OCE_NIGMA) -#else -# define machine_is_oce_nigma() (0) -#endif - -#ifdef CONFIG_MACH_T55 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_T55 -# endif -# define machine_is_t55() (machine_arch_type == MACH_TYPE_T55) -#else -# define machine_is_t55() (0) -#endif - -#ifdef CONFIG_MACH_BIO3K -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_BIO3K -# endif -# define machine_is_bio3k() (machine_arch_type == MACH_TYPE_BIO3K) -#else -# define machine_is_bio3k() (0) -#endif - -#ifdef CONFIG_MACH_EXPRESSCT -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_EXPRESSCT -# endif -# define machine_is_expressct() (machine_arch_type == MACH_TYPE_EXPRESSCT) -#else -# define machine_is_expressct() (0) -#endif - -#ifdef CONFIG_MACH_CARDHU -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CARDHU -# endif -# define machine_is_cardhu() (machine_arch_type == MACH_TYPE_CARDHU) -#else -# define machine_is_cardhu() (0) -#endif - -#ifdef CONFIG_MACH_ARUBA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ARUBA -# endif -# define machine_is_aruba() (machine_arch_type == MACH_TYPE_ARUBA) -#else -# define machine_is_aruba() (0) -#endif - -#ifdef CONFIG_MACH_BONAIRE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_BONAIRE -# endif -# define machine_is_bonaire() (machine_arch_type == MACH_TYPE_BONAIRE) -#else -# define machine_is_bonaire() (0) -#endif - -#ifdef CONFIG_MACH_NUC700EVB -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NUC700EVB -# endif -# define machine_is_nuc700evb() (machine_arch_type == MACH_TYPE_NUC700EVB) -#else -# define machine_is_nuc700evb() (0) -#endif - -#ifdef CONFIG_MACH_NUC710EVB -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NUC710EVB -# endif -# define machine_is_nuc710evb() (machine_arch_type == MACH_TYPE_NUC710EVB) -#else -# define machine_is_nuc710evb() (0) -#endif - -#ifdef CONFIG_MACH_NUC740EVB -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NUC740EVB -# endif -# define machine_is_nuc740evb() (machine_arch_type == MACH_TYPE_NUC740EVB) -#else -# define machine_is_nuc740evb() (0) -#endif - -#ifdef CONFIG_MACH_NUC745EVB -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NUC745EVB -# endif -# define machine_is_nuc745evb() (machine_arch_type == MACH_TYPE_NUC745EVB) -#else -# define machine_is_nuc745evb() (0) -#endif - -#ifdef CONFIG_MACH_TRANSCEDE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TRANSCEDE -# endif -# define machine_is_transcede() (machine_arch_type == MACH_TYPE_TRANSCEDE) -#else -# define machine_is_transcede() (0) -#endif - -#ifdef CONFIG_MACH_MORA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MORA -# endif -# define machine_is_mora() (machine_arch_type == MACH_TYPE_MORA) -#else -# define machine_is_mora() (0) -#endif - -#ifdef CONFIG_MACH_NDA_EVM -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NDA_EVM -# endif -# define machine_is_nda_evm() (machine_arch_type == MACH_TYPE_NDA_EVM) -#else -# define machine_is_nda_evm() (0) -#endif - -#ifdef CONFIG_MACH_TIMU -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TIMU -# endif -# define machine_is_timu() (machine_arch_type == MACH_TYPE_TIMU) -#else -# define machine_is_timu() (0) -#endif - -#ifdef CONFIG_MACH_EXPRESSH -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_EXPRESSH -# endif -# define machine_is_expressh() (machine_arch_type == MACH_TYPE_EXPRESSH) -#else -# define machine_is_expressh() (0) -#endif - -#ifdef CONFIG_MACH_VERIDIS_A300 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_VERIDIS_A300 -# endif -# define machine_is_veridis_a300() (machine_arch_type == MACH_TYPE_VERIDIS_A300) -#else -# define machine_is_veridis_a300() (0) -#endif - -#ifdef CONFIG_MACH_DM368_LEOPARD -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DM368_LEOPARD -# endif -# define machine_is_dm368_leopard() (machine_arch_type == MACH_TYPE_DM368_LEOPARD) -#else -# define machine_is_dm368_leopard() (0) -#endif - -#ifdef CONFIG_MACH_OMAP_MCOP -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OMAP_MCOP -# endif -# define machine_is_omap_mcop() (machine_arch_type == MACH_TYPE_OMAP_MCOP) -#else -# define machine_is_omap_mcop() (0) -#endif - -#ifdef CONFIG_MACH_TRITIP -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TRITIP -# endif -# define machine_is_tritip() (machine_arch_type == MACH_TYPE_TRITIP) -#else -# define machine_is_tritip() (0) -#endif - -#ifdef CONFIG_MACH_SM1K -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SM1K -# endif -# define machine_is_sm1k() (machine_arch_type == MACH_TYPE_SM1K) -#else -# define machine_is_sm1k() (0) -#endif - -#ifdef CONFIG_MACH_MONCH -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MONCH -# endif -# define machine_is_monch() (machine_arch_type == MACH_TYPE_MONCH) -#else -# define machine_is_monch() (0) -#endif - -#ifdef CONFIG_MACH_CURACAO -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CURACAO -# endif -# define machine_is_curacao() (machine_arch_type == MACH_TYPE_CURACAO) -#else -# define machine_is_curacao() (0) -#endif - -#ifdef CONFIG_MACH_ORIGEN -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ORIGEN -# endif -# define machine_is_origen() (machine_arch_type == MACH_TYPE_ORIGEN) -#else -# define machine_is_origen() (0) -#endif - -#ifdef CONFIG_MACH_EPC10 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_EPC10 -# endif -# define machine_is_epc10() (machine_arch_type == MACH_TYPE_EPC10) -#else -# define machine_is_epc10() (0) -#endif - -#ifdef CONFIG_MACH_SGH_I740 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SGH_I740 -# endif -# define machine_is_sgh_i740() (machine_arch_type == MACH_TYPE_SGH_I740) -#else -# define machine_is_sgh_i740() (0) -#endif - -#ifdef CONFIG_MACH_TUNA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TUNA -# endif -# define machine_is_tuna() (machine_arch_type == MACH_TYPE_TUNA) -#else -# define machine_is_tuna() (0) -#endif - -#ifdef CONFIG_MACH_MX51_TULIP -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MX51_TULIP -# endif -# define machine_is_mx51_tulip() (machine_arch_type == MACH_TYPE_MX51_TULIP) -#else -# define machine_is_mx51_tulip() (0) -#endif - -#ifdef CONFIG_MACH_MX51_ASTER7 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MX51_ASTER7 -# endif -# define machine_is_mx51_aster7() (machine_arch_type == MACH_TYPE_MX51_ASTER7) -#else -# define machine_is_mx51_aster7() (0) -#endif - -#ifdef CONFIG_MACH_ACRO37XBRD -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ACRO37XBRD -# endif -# define machine_is_acro37xbrd() (machine_arch_type == MACH_TYPE_ACRO37XBRD) -#else -# define machine_is_acro37xbrd() (0) -#endif - -#ifdef CONFIG_MACH_ELKE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ELKE -# endif -# define machine_is_elke() (machine_arch_type == MACH_TYPE_ELKE) -#else -# define machine_is_elke() (0) -#endif - -#ifdef CONFIG_MACH_SBC6000X -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SBC6000X -# endif -# define machine_is_sbc6000x() (machine_arch_type == MACH_TYPE_SBC6000X) -#else -# define machine_is_sbc6000x() (0) -#endif - -#ifdef CONFIG_MACH_R1801E -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_R1801E -# endif -# define machine_is_r1801e() (machine_arch_type == MACH_TYPE_R1801E) -#else -# define machine_is_r1801e() (0) -#endif - -#ifdef CONFIG_MACH_H1600 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_H1600 -# endif -# define machine_is_h1600() (machine_arch_type == MACH_TYPE_H1600) -#else -# define machine_is_h1600() (0) -#endif - -#ifdef CONFIG_MACH_MINI210 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MINI210 -# endif -# define machine_is_mini210() (machine_arch_type == MACH_TYPE_MINI210) -#else -# define machine_is_mini210() (0) -#endif - -#ifdef CONFIG_MACH_MINI8168 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MINI8168 -# endif -# define machine_is_mini8168() (machine_arch_type == MACH_TYPE_MINI8168) -#else -# define machine_is_mini8168() (0) -#endif - -#ifdef CONFIG_MACH_PC7308 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_PC7308 -# endif -# define machine_is_pc7308() (machine_arch_type == MACH_TYPE_PC7308) -#else -# define machine_is_pc7308() (0) -#endif - -#ifdef CONFIG_MACH_KMM2M01 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_KMM2M01 -# endif -# define machine_is_kmm2m01() (machine_arch_type == MACH_TYPE_KMM2M01) -#else -# define machine_is_kmm2m01() (0) -#endif - -#ifdef CONFIG_MACH_MX51EREBUS -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MX51EREBUS -# endif -# define machine_is_mx51erebus() (machine_arch_type == MACH_TYPE_MX51EREBUS) -#else -# define machine_is_mx51erebus() (0) -#endif - -#ifdef CONFIG_MACH_WM8650REFBOARD -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_WM8650REFBOARD -# endif -# define machine_is_wm8650refboard() (machine_arch_type == MACH_TYPE_WM8650REFBOARD) -#else -# define machine_is_wm8650refboard() (0) -#endif - -#ifdef CONFIG_MACH_TUXRAIL -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TUXRAIL -# endif -# define machine_is_tuxrail() (machine_arch_type == MACH_TYPE_TUXRAIL) -#else -# define machine_is_tuxrail() (0) -#endif - -#ifdef CONFIG_MACH_ARTHUR -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ARTHUR -# endif -# define machine_is_arthur() (machine_arch_type == MACH_TYPE_ARTHUR) -#else -# define machine_is_arthur() (0) -#endif - -#ifdef CONFIG_MACH_DOORBOY -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DOORBOY -# endif -# define machine_is_doorboy() (machine_arch_type == MACH_TYPE_DOORBOY) -#else -# define machine_is_doorboy() (0) -#endif - -#ifdef CONFIG_MACH_XARINA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_XARINA -# endif -# define machine_is_xarina() (machine_arch_type == MACH_TYPE_XARINA) -#else -# define machine_is_xarina() (0) -#endif - -#ifdef CONFIG_MACH_ROVERX7 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ROVERX7 -# endif -# define machine_is_roverx7() (machine_arch_type == MACH_TYPE_ROVERX7) -#else -# define machine_is_roverx7() (0) -#endif - -#ifdef CONFIG_MACH_SDVR -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SDVR -# endif -# define machine_is_sdvr() (machine_arch_type == MACH_TYPE_SDVR) -#else -# define machine_is_sdvr() (0) -#endif - -#ifdef CONFIG_MACH_ACER_MAYA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ACER_MAYA -# endif -# define machine_is_acer_maya() (machine_arch_type == MACH_TYPE_ACER_MAYA) -#else -# define machine_is_acer_maya() (0) -#endif - -#ifdef CONFIG_MACH_PICO -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_PICO -# endif -# define machine_is_pico() (machine_arch_type == MACH_TYPE_PICO) -#else -# define machine_is_pico() (0) -#endif - -#ifdef CONFIG_MACH_CWMX233 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CWMX233 -# endif -# define machine_is_cwmx233() (machine_arch_type == MACH_TYPE_CWMX233) -#else -# define machine_is_cwmx233() (0) -#endif - -#ifdef CONFIG_MACH_CWAM1808 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CWAM1808 -# endif -# define machine_is_cwam1808() (machine_arch_type == MACH_TYPE_CWAM1808) -#else -# define machine_is_cwam1808() (0) -#endif - -#ifdef CONFIG_MACH_CWDM365 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CWDM365 -# endif -# define machine_is_cwdm365() (machine_arch_type == MACH_TYPE_CWDM365) -#else -# define machine_is_cwdm365() (0) -#endif - -#ifdef CONFIG_MACH_MX51_MORAY -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MX51_MORAY -# endif -# define machine_is_mx51_moray() (machine_arch_type == MACH_TYPE_MX51_MORAY) -#else -# define machine_is_mx51_moray() (0) -#endif - -#ifdef CONFIG_MACH_THALES_CBC -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_THALES_CBC -# endif -# define machine_is_thales_cbc() (machine_arch_type == MACH_TYPE_THALES_CBC) -#else -# define machine_is_thales_cbc() (0) -#endif - -#ifdef CONFIG_MACH_BLUEPOINT -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_BLUEPOINT -# endif -# define machine_is_bluepoint() (machine_arch_type == MACH_TYPE_BLUEPOINT) -#else -# define machine_is_bluepoint() (0) -#endif - -#ifdef CONFIG_MACH_DIR665 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DIR665 -# endif -# define machine_is_dir665() (machine_arch_type == MACH_TYPE_DIR665) -#else -# define machine_is_dir665() (0) -#endif - -#ifdef CONFIG_MACH_ACMEROVER1 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ACMEROVER1 -# endif -# define machine_is_acmerover1() (machine_arch_type == MACH_TYPE_ACMEROVER1) -#else -# define machine_is_acmerover1() (0) -#endif - -#ifdef CONFIG_MACH_SHOOTER_CT -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SHOOTER_CT -# endif -# define machine_is_shooter_ct() (machine_arch_type == MACH_TYPE_SHOOTER_CT) -#else -# define machine_is_shooter_ct() (0) -#endif - -#ifdef CONFIG_MACH_BLISS -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_BLISS -# endif -# define machine_is_bliss() (machine_arch_type == MACH_TYPE_BLISS) -#else -# define machine_is_bliss() (0) -#endif - -#ifdef CONFIG_MACH_BLISSC -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_BLISSC -# endif -# define machine_is_blissc() (machine_arch_type == MACH_TYPE_BLISSC) -#else -# define machine_is_blissc() (0) -#endif - -#ifdef CONFIG_MACH_THALES_ADC -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_THALES_ADC -# endif -# define machine_is_thales_adc() (machine_arch_type == MACH_TYPE_THALES_ADC) -#else -# define machine_is_thales_adc() (0) -#endif - -#ifdef CONFIG_MACH_UBISYS_P9D_EVP -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_UBISYS_P9D_EVP -# endif -# define machine_is_ubisys_p9d_evp() (machine_arch_type == MACH_TYPE_UBISYS_P9D_EVP) -#else -# define machine_is_ubisys_p9d_evp() (0) -#endif - -#ifdef CONFIG_MACH_ATDGP318 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ATDGP318 -# endif -# define machine_is_atdgp318() (machine_arch_type == MACH_TYPE_ATDGP318) -#else -# define machine_is_atdgp318() (0) -#endif - -#ifdef CONFIG_MACH_OMAP5_SEVM -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OMAP5_SEVM -# endif -# define machine_is_omap5_sevm() (machine_arch_type == MACH_TYPE_OMAP5_SEVM) -#else -# define machine_is_omap5_sevm() (0) -#endif - -#ifdef CONFIG_MACH_ARMADILLO800EVA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ARMADILLO800EVA -# endif -# define machine_is_armadillo800eva() (machine_arch_type == MACH_TYPE_ARMADILLO800EVA) -#else -# define machine_is_armadillo800eva() (0) -#endif - -#ifdef CONFIG_MACH_KZM9G -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_KZM9G -# endif -# define machine_is_kzm9g() (machine_arch_type == MACH_TYPE_KZM9G) -#else -# define machine_is_kzm9g() (0) -#endif - -#ifdef CONFIG_MACH_COLIBRI_T30 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_COLIBRI_T30 -# endif -# define machine_is_colibri_t30() (machine_arch_type == MACH_TYPE_COLIBRI_T30) -#else -# define machine_is_colibri_t30() (0) -#endif - -#ifdef CONFIG_MACH_APALIS_T30 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_APALIS_T30 -# endif -# define machine_is_apalis_t30() (machine_arch_type == MACH_TYPE_APALIS_T30) -#else -# define machine_is_apalis_t30() (0) -#endif - -/* - * These have not yet been registered - */ - -#ifndef machine_arch_type -#define machine_arch_type __machine_arch_type -#endif +#define MACH_TYPE_ARMSTONEA9 4515 +#define MACH_TYPE_OMAP_BLAZETABLET 4516 +#define MACH_TYPE_AR6MXQ 4517 +#define MACH_TYPE_AR6MXS 4518 +#define MACH_TYPE_GWVENTANA 4520 +#define MACH_TYPE_IGEP0033 4521 +#define MACH_TYPE_H52C1_CONCERTO 4524 +#define MACH_TYPE_FCMBRD 4525 +#define MACH_TYPE_PCAAXS1 4526 +#define MACH_TYPE_LS_ORCA 4527 +#define MACH_TYPE_PCM051LB 4528 +#define MACH_TYPE_MX6S_LP507_GVCI 4529 +#define MACH_TYPE_DIDO 4530 +#define MACH_TYPE_SWARCO_ITC3_9G20 4531 +#define MACH_TYPE_ROBO_ROADY 4532 +#define MACH_TYPE_RSKRZA1 4533 +#define MACH_TYPE_SWARCO_SID 4534 +#define MACH_TYPE_MX6_IWG15S_SBC 4535 +#define MACH_TYPE_MX6Q_CAMARO 4536 +#define MACH_TYPE_HB6MXS 4537 +#define MACH_TYPE_LAGER 4538 +#define MACH_TYPE_LP8X4X 4539 +#define MACH_TYPE_TEGRATAB7 4540 +#define MACH_TYPE_ANDROMEDA 4541 +#define MACH_TYPE_BOOTES 4542 +#define MACH_TYPE_NETHMI 4543 +#define MACH_TYPE_TEGRATAB 4544 +#define MACH_TYPE_SOM5_EVB 4545 +#define MACH_TYPE_VENATICORUM 4546 +#define MACH_TYPE_STM_B2110 4547 +#define MACH_TYPE_ELUX_HATHOR 4548 +#define MACH_TYPE_HELIOS_V7 4549 +#define MACH_TYPE_XC10V1 4550 +#define MACH_TYPE_CP2U 4551 +#define MACH_TYPE_IAP_F 4552 +#define MACH_TYPE_IAP_G 4553 +#define MACH_TYPE_AAE 4554 +#define MACH_TYPE_PEGASUS 4555 +#define MACH_TYPE_CYGNUS 4556 +#define MACH_TYPE_CENTAURUS 4557 +#define MACH_TYPE_MSM8930_QRD8930 4558 +#define MACH_TYPE_QUBY_TIM 4559 +#define MACH_TYPE_ZEDI3250A 4560 +#define MACH_TYPE_GRUS 4561 +#define MACH_TYPE_APOLLO3 4562 +#define MACH_TYPE_COWON_R7 4563 +#define MACH_TYPE_TONGA3 4564 +#define MACH_TYPE_P535 4565 +#define MACH_TYPE_SA3874I 4566 +#define MACH_TYPE_MX6_NAVICO_COM 4567 +#define MACH_TYPE_PROXMOBIL2 4568 +#define MACH_TYPE_UBINUX1 4569 +#define MACH_TYPE_ISTOS 4570 +#define MACH_TYPE_BENVOLIO4 4571 +#define MACH_TYPE_ECO5_BX2 4572 +#define MACH_TYPE_EUKREA_CPUIMX28SD 4573 +#define MACH_TYPE_DOMOTAB 4574 +#define MACH_TYPE_PFLA03 4575
#endif diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 00ee3f10cdae..1ad9f7e9e7ab 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -106,66 +106,27 @@ CONFIG_APER_SIZE CONFIG_API CONFIG_APUS_FAST_EXCEPT CONFIG_AP_SH4A_4A -CONFIG_ARCH_AAED2000 -CONFIG_ARCH_ADI_COYOTE CONFIG_ARCH_ADPAG101P -CONFIG_ARCH_AT91RM9200DK -CONFIG_ARCH_AUTCPU12 -CONFIG_ARCH_BAST -CONFIG_ARCH_CATS -CONFIG_ARCH_CDB89712 -CONFIG_ARCH_CEIVA -CONFIG_ARCH_CLEP7212 CONFIG_ARCH_CPU_INIT CONFIG_ARCH_CSB226 CONFIG_ARCH_DMA_PIO_WORDS CONFIG_ARCH_EARLY_INIT_R -CONFIG_ARCH_EBSA110 -CONFIG_ARCH_EBSA285 -CONFIG_ARCH_EDB7211 -CONFIG_ARCH_ENP2611 -CONFIG_ARCH_FORTUNET -CONFIG_ARCH_GUMSTIX -CONFIG_ARCH_H1940 -CONFIG_ARCH_H5400 -CONFIG_ARCH_H7201 -CONFIG_ARCH_H7202 CONFIG_ARCH_HAS_ILOG2_U32 CONFIG_ARCH_HAS_ILOG2_U64 CONFIG_ARCH_INNOKOM -CONFIG_ARCH_IQ31244 -CONFIG_ARCH_IQ80321 -CONFIG_ARCH_IQ80331 -CONFIG_ARCH_IXCDP1100 -CONFIG_ARCH_IXDP2400 -CONFIG_ARCH_IXDP2401 -CONFIG_ARCH_IXDP2800 -CONFIG_ARCH_IXDP2801 -CONFIG_ARCH_IXDP425 CONFIG_ARCH_KIRKWOOD -CONFIG_ARCH_KS8695 -CONFIG_ARCH_L7200 CONFIG_ARCH_LUBBOCK CONFIG_ARCH_MAP_SYSMEM CONFIG_ARCH_MISC_INIT -CONFIG_ARCH_MX1ADS -CONFIG_ARCH_NETWINDER CONFIG_ARCH_OMAP4 CONFIG_ARCH_ORION5X -CONFIG_ARCH_P720T -CONFIG_ARCH_PERSONAL_SERVER CONFIG_ARCH_PLEB CONFIG_ARCH_PXA_CERF CONFIG_ARCH_PXA_IDP CONFIG_ARCH_RMOBILE_BOARD_STRING CONFIG_ARCH_RMOBILE_EXTRAM_BOOT -CONFIG_ARCH_RPC -CONFIG_ARCH_S3C2440 -CONFIG_ARCH_SHARK CONFIG_ARCH_TEGRA CONFIG_ARCH_USE_BUILTIN_BSWAP -CONFIG_ARCH_VERSATILE_PB -CONFIG_ARCH_VIPER CONFIG_ARC_MMU_VER CONFIG_ARC_SERIAL CONFIG_ARC_UART_BASE @@ -1931,1037 +1892,21 @@ CONFIG_MACB1_PHY CONFIG_MACB2_PHY CONFIG_MACB3_PHY CONFIG_MACB_SEARCH_PHY -CONFIG_MACH_A0 -CONFIG_MACH_A2F -CONFIG_MACH_ABACUS -CONFIG_MACH_ABB_GMA_1_1 -CONFIG_MACH_ABILENE -CONFIG_MACH_ABLE -CONFIG_MACH_ACER_A5 -CONFIG_MACH_ACER_A8 -CONFIG_MACH_ACER_GAUGUIN -CONFIG_MACH_ACER_MAYA -CONFIG_MACH_ACMENETUSFOXG20 -CONFIG_MACH_ACMEROVER1 -CONFIG_MACH_ACRO37XBRD -CONFIG_MACH_ACS5K -CONFIG_MACH_ACSX106 -CONFIG_MACH_ADSSPHERE -CONFIG_MACH_AEBL -CONFIG_MACH_AF4000 -CONFIG_MACH_AFEB9260 -CONFIG_MACH_AG11005 -CONFIG_MACH_AG5EVM -CONFIG_MACH_AKITA -CONFIG_MACH_AMK_A4 -CONFIG_MACH_AML_M5900 -CONFIG_MACH_AMS_DELTA -CONFIG_MACH_ANCHOVY -CONFIG_MACH_ANTARES -CONFIG_MACH_ANTERO -CONFIG_MACH_ANUBIS -CONFIG_MACH_ANW6410 -CONFIG_MACH_AP4EVB -CONFIG_MACH_APALIS_T30 -CONFIG_MACH_APP3K_ROBIN -CONFIG_MACH_AQUARIUS -CONFIG_MACH_AQUILA -CONFIG_MACH_ARCOM_VULCAN -CONFIG_MACH_ARCOM_ZEUS -CONFIG_MACH_ARK9431 -CONFIG_MACH_ARMADA_XP_DB -CONFIG_MACH_ARMADILLO460 -CONFIG_MACH_ARMADILLO5X0 -CONFIG_MACH_ARMADILLO800EVA -CONFIG_MACH_ARMCORE -CONFIG_MACH_ARMLEX4210 -CONFIG_MACH_ARMLGUEST -CONFIG_MACH_AROWANA -CONFIG_MACH_ARTHUR -CONFIG_MACH_ARUBA -CONFIG_MACH_AS1167 -CONFIG_MACH_ASL_PHOENIX -CONFIG_MACH_ASPEN CONFIG_MACH_ASPENITE -CONFIG_MACH_AST2200 -CONFIG_MACH_AT2440EVB -CONFIG_MACH_AT572D940HFEB -CONFIG_MACH_AT91CAP7STK -CONFIG_MACH_AT91CAP7XDK -CONFIG_MACH_AT91CAP9ADK -CONFIG_MACH_AT91EB01 -CONFIG_MACH_AT91RM9200EK -CONFIG_MACH_AT91SAM9260EK -CONFIG_MACH_AT91SAM9261EK -CONFIG_MACH_AT91SAM9263DESK16L -CONFIG_MACH_AT91SAM9263EK -CONFIG_MACH_AT91SAM9263OTLITE -CONFIG_MACH_AT91SAM9G10EK -CONFIG_MACH_AT91SAM9G20EK -CONFIG_MACH_AT91SAM9G20EK_2MMC -CONFIG_MACH_AT91SAM9G45EKES -CONFIG_MACH_AT91SAM9M10G45EK -CONFIG_MACH_AT91SAM9RLEK -CONFIG_MACH_AT91SAM9X5EK -CONFIG_MACH_ATDGP318 -CONFIG_MACH_ATEB9200 -CONFIG_MACH_ATHENE -CONFIG_MACH_ATLAS5_C1 -CONFIG_MACH_AUTOBOT -CONFIG_MACH_AVENGERS_LITE -CONFIG_MACH_AVILA -CONFIG_MACH_AWM2 -CONFIG_MACH_AX502 -CONFIG_MACH_AX8008 -CONFIG_MACH_B5500 -CONFIG_MACH_BASI -CONFIG_MACH_BCM2708 -CONFIG_MACH_BCM589X -CONFIG_MACH_BCMHANA_SV -CONFIG_MACH_BCMHANA_TABLET -CONFIG_MACH_BCMRING -CONFIG_MACH_BEECT -CONFIG_MACH_BIGDISK -CONFIG_MACH_BIO3K -CONFIG_MACH_BIPNET -CONFIG_MACH_BLISS -CONFIG_MACH_BLISSC -CONFIG_MACH_BLUECHEESE -CONFIG_MACH_BLUEPOINT -CONFIG_MACH_BLUESHARK -CONFIG_MACH_BOCKW -CONFIG_MACH_BONAIRE -CONFIG_MACH_BORABORA -CONFIG_MACH_BORZOI -CONFIG_MACH_BROWNSTONE -CONFIG_MACH_BSTBRD -CONFIG_MACH_BTMAVB101 -CONFIG_MACH_BTMAWB101 -CONFIG_MACH_BUBBA3 -CONFIG_MACH_BUG -CONFIG_MACH_BUG20 -CONFIG_MACH_BURY_BL7582 -CONFIG_MACH_BURY_BPS5270 -CONFIG_MACH_BV07 -CONFIG_MACH_C2MMI -CONFIG_MACH_CALLISTO -CONFIG_MACH_CAM60 -CONFIG_MACH_CAPC7117 -CONFIG_MACH_CARDHU -CONFIG_MACH_CARMEVA -CONFIG_MACH_CAYENNE -CONFIG_MACH_CC9P9360DEV -CONFIG_MACH_CC9P9360JS -CONFIG_MACH_CCMX53 -CONFIG_MACH_CCMX53JS -CONFIG_MACH_CCWMX51MUT -CONFIG_MACH_CCWMX53 -CONFIG_MACH_CCWMX53JS -CONFIG_MACH_CENTRO -CONFIG_MACH_CETUS9263 -CONFIG_MACH_CHACHA -CONFIG_MACH_CHALTEN_XA1 -CONFIG_MACH_CHARON -CONFIG_MACH_CLOD -CONFIG_MACH_CM4745 -CONFIG_MACH_CM_A510 -CONFIG_MACH_CM_T35 -CONFIG_MACH_CM_T3517 -CONFIG_MACH_CM_T3730 -CONFIG_MACH_CM_X300 -CONFIG_MACH_CNS2133EVB -CONFIG_MACH_CNS21XX -CONFIG_MACH_CNS3420VB -CONFIG_MACH_COBRAL138 -CONFIG_MACH_COCONUT -CONFIG_MACH_COLIBRI -CONFIG_MACH_COLIBRI300 -CONFIG_MACH_COLIBRI320 -CONFIG_MACH_COLIBRI_T20 -CONFIG_MACH_COLIBRI_T30 -CONFIG_MACH_CONTROLTEK9G20 -CONFIG_MACH_CORETEC_VCX7400 -CONFIG_MACH_CORGI -CONFIG_MACH_CPUAT9G20 -CONFIG_MACH_CPX2 -CONFIG_MACH_CRANEBOARD -CONFIG_MACH_CRUX -CONFIG_MACH_CSB337 -CONFIG_MACH_CSB637 -CONFIG_MACH_CSB726 -CONFIG_MACH_CSC -CONFIG_MACH_CTBU_GEN2 -CONFIG_MACH_CTERA_PLUG_C2 -CONFIG_MACH_CURACAO -CONFIG_MACH_CV2201 -CONFIG_MACH_CV2202 -CONFIG_MACH_CV2203 -CONFIG_MACH_CWAM1808 -CONFIG_MACH_CWDM365 -CONFIG_MACH_CWME9210 -CONFIG_MACH_CWME9210JS -CONFIG_MACH_CWMX233 -CONFIG_MACH_D2NET -CONFIG_MACH_D2NET_V2 -CONFIG_MACH_D2PLUG -CONFIG_MACH_DA850_K5 -CONFIG_MACH_DAINTREE_CWAC -CONFIG_MACH_DATAWAY CONFIG_MACH_DAVINCI_CALIMAIN -CONFIG_MACH_DAVINCI_DA830_EVM CONFIG_MACH_DAVINCI_DA850_EVM -CONFIG_MACH_DAVINCI_DM355_EVM -CONFIG_MACH_DAVINCI_DM355_MMM -CONFIG_MACH_DAVINCI_DM365_BV -CONFIG_MACH_DAVINCI_DM365_DVR -CONFIG_MACH_DAVINCI_DM365_EVM -CONFIG_MACH_DAVINCI_DM6467TEVM -CONFIG_MACH_DAVINCI_DM6467_EVM -CONFIG_MACH_DAVINCI_EVM -CONFIG_MACH_DAVINCI_PICTO -CONFIG_MACH_DAWAD7 -CONFIG_MACH_DB78X00_BP -CONFIG_MACH_DB88F5281 -CONFIG_MACH_DB88F6281_BP -CONFIG_MACH_DDNAS -CONFIG_MACH_DDPLUG -CONFIG_MACH_DDS -CONFIG_MACH_DEEP_R_EK_1 -CONFIG_MACH_DEVIXP -CONFIG_MACH_DEVKIT8000 -CONFIG_MACH_DGM3240 -CONFIG_MACH_DIMMSAM9G20 -CONFIG_MACH_DIMM_IMX28 -CONFIG_MACH_DIMM_MX257 -CONFIG_MACH_DINGO -CONFIG_MACH_DIR665 -CONFIG_MACH_DM355_LEOPARD -CONFIG_MACH_DM365_CV100 -CONFIG_MACH_DM368_LEOPARD -CONFIG_MACH_DM3730_SOM_LV -CONFIG_MACH_DM3730_TORPEDO -CONFIG_MACH_DM6441_ESP -CONFIG_MACH_DM6446_ADBOX -CONFIG_MACH_DMA6410 -CONFIG_MACH_DMA_THUNDERBUG -CONFIG_MACH_DMW96 -CONFIG_MACH_DNS323 CONFIG_MACH_DOCKSTAR -CONFIG_MACH_DOORBOY -CONFIG_MACH_DOUBLESHOT -CONFIG_MACH_DOVE_AVNG_V3 -CONFIG_MACH_DOVE_DB -CONFIG_MACH_DP6XX -CONFIG_MACH_DRAGONET -CONFIG_MACH_DSM320 -CONFIG_MACH_DSMG600 -CONFIG_MACH_DURIAN -CONFIG_MACH_DYNASTY -CONFIG_MACH_E10 -CONFIG_MACH_E330 -CONFIG_MACH_E350 -CONFIG_MACH_E400 -CONFIG_MACH_E740 -CONFIG_MACH_E750 -CONFIG_MACH_E800 -CONFIG_MACH_EA20 -CONFIG_MACH_EA2478DEVKIT -CONFIG_MACH_EAG_CI4000 -CONFIG_MACH_EASYCRRH -CONFIG_MACH_EC4350SDB -CONFIG_MACH_EC4350TBM -CONFIG_MACH_ECBAT91 -CONFIG_MACH_ECO920 -CONFIG_MACH_ECUV5 -CONFIG_MACH_EDB9301 -CONFIG_MACH_EDB9302 -CONFIG_MACH_EDB9302A -CONFIG_MACH_EDB9307 -CONFIG_MACH_EDB9307A -CONFIG_MACH_EDB9312 -CONFIG_MACH_EDB9315 -CONFIG_MACH_EDB9315A -CONFIG_MACH_EDISON CONFIG_MACH_EDMINIV2 -CONFIG_MACH_EDMINI_V2 -CONFIG_MACH_EELX2 -CONFIG_MACH_EIGEN_TTR -CONFIG_MACH_ELEPHANT -CONFIG_MACH_ELKE -CONFIG_MACH_ELOG -CONFIG_MACH_EM1SY -CONFIG_MACH_EM7210 -CONFIG_MACH_EMERALD -CONFIG_MACH_EM_X270 -CONFIG_MACH_ENCORE -CONFIG_MACH_ENDIAN_MINI -CONFIG_MACH_EP80219 -CONFIG_MACH_EPC10 -CONFIG_MACH_EPIPHAN -CONFIG_MACH_ES2440 -CONFIG_MACH_ESATA_SHEEVAPLUG -CONFIG_MACH_ESL_MOBILIS_A -CONFIG_MACH_ESL_MOBILIS_B -CONFIG_MACH_ESL_WAVE_A -CONFIG_MACH_ESL_WAVE_B -CONFIG_MACH_ESPRESSO -CONFIG_MACH_ETHERPRO_ISP -CONFIG_MACH_ETNA -CONFIG_MACH_EUKREA_CPUIMX25SD -CONFIG_MACH_EUKREA_CPUIMX35SD -CONFIG_MACH_EUKREA_CPUIMX51 -CONFIG_MACH_EUKREA_CPUIMX51SD -CONFIG_MACH_EVA2000 -CONFIG_MACH_EVSY -CONFIG_MACH_EXEDA -CONFIG_MACH_EXPRESS -CONFIG_MACH_EXPRESSCT -CONFIG_MACH_EXPRESSH -CONFIG_MACH_EXPRESS_KT -CONFIG_MACH_EZX_A1200 -CONFIG_MACH_EZX_A780 -CONFIG_MACH_EZX_A910 -CONFIG_MACH_EZX_E2 -CONFIG_MACH_EZX_E6 -CONFIG_MACH_EZX_E680 -CONFIG_MACH_FA9X27 -CONFIG_MACH_FFCORE -CONFIG_MACH_FLEXIBITY -CONFIG_MACH_FLINT -CONFIG_MACH_FLYER -CONFIG_MACH_FRISMS -CONFIG_MACH_FRRHWCDMA60W -CONFIG_MACH_FSG -CONFIG_MACH_FSM9XXX_FFA -CONFIG_MACH_FSM9XXX_SURF -CONFIG_MACH_FS_S5PC100 -CONFIG_MACH_FUJI -CONFIG_MACH_FWBD_0404 -CONFIG_MACH_G3EVM -CONFIG_MACH_G4EVM -CONFIG_MACH_GATEWAY7001 -CONFIG_MACH_GENEVA_B5 -CONFIG_MACH_GESBC9312 -CONFIG_MACH_GFS_SPM -CONFIG_MACH_GINGER -CONFIG_MACH_GIRA_KNXIP_ROUTER -CONFIG_MACH_GLANTANK -CONFIG_MACH_GNET_SGCE -CONFIG_MACH_GNET_SGME -CONFIG_MACH_GNET_SLC CONFIG_MACH_GOFLEXHOME -CONFIG_MACH_GOFLEXNET -CONFIG_MACH_GOLDENGATE CONFIG_MACH_GONI -CONFIG_MACH_GORAMO_MLR -CONFIG_MACH_GPSDISPLAY -CONFIG_MACH_GREECO -CONFIG_MACH_GSIA18S -CONFIG_MACH_GSL_DIAMOND -CONFIG_MACH_GSNCOMM -CONFIG_MACH_GTA04 -CONFIG_MACH_GTIB -CONFIG_MACH_GTL_IT5100 -CONFIG_MACH_GTWX5715 -CONFIG_MACH_GT_I5700 -CONFIG_MACH_GUPPY -CONFIG_MACH_GURNARD CONFIG_MACH_GURUPLUG -CONFIG_MACH_GW2361 -CONFIG_MACH_H1600 -CONFIG_MACH_H4700 -CONFIG_MACH_HABA_KNX_EXPLORER -CONFIG_MACH_HALIBUT -CONFIG_MACH_HAMMERHEAD -CONFIG_MACH_HARMONY -CONFIG_MACH_HARVEST_DESOTO -CONFIG_MACH_HAWKS -CONFIG_MACH_HDGU -CONFIG_MACH_HDMINI -CONFIG_MACH_HDNVP -CONFIG_MACH_HELIOS_V1 -CONFIG_MACH_HELIOS_V2 -CONFIG_MACH_HERALD -CONFIG_MACH_HERRING -CONFIG_MACH_HIMALAYA -CONFIG_MACH_HJSDU -CONFIG_MACH_HKDKC100 -CONFIG_MACH_HMT -CONFIG_MACH_HOLIDAY -CONFIG_MACH_HREFV60 -CONFIG_MACH_HSGX6D -CONFIG_MACH_HTCMEGA -CONFIG_MACH_HTCTORNADO -CONFIG_MACH_HTC_HD_MINI -CONFIG_MACH_HTC_SPV_M700 -CONFIG_MACH_HUASHAN -CONFIG_MACH_HUSKY -CONFIG_MACH_HWGW6410 -CONFIG_MACH_IAM28 -CONFIG_MACH_ICON -CONFIG_MACH_ICONG -CONFIG_MACH_ICONNECT -CONFIG_MACH_ICONTROL -CONFIG_MACH_ICON_G -CONFIG_MACH_ICS_IF_VOIP -CONFIG_MACH_IDEA6410 -CONFIG_MACH_IGEP0020 -CONFIG_MACH_IGEP0030 -CONFIG_MACH_IGEP0032 -CONFIG_MACH_IJ3K_2440 -CONFIG_MACH_IMATE8502 -CONFIG_MACH_IMX27IPCAM -CONFIG_MACH_IMX27LITE -CONFIG_MACH_IMX27_VISSTRIM_M10 -CONFIG_MACH_INCOME -CONFIG_MACH_INETSPACE_V2 -CONFIG_MACH_INHAND_APEIRON -CONFIG_MACH_INHAND_FURY -CONFIG_MACH_INHAND_SIREN -CONFIG_MACH_INTELMOTE2 -CONFIG_MACH_IOMEGA_IX2_200 -CONFIG_MACH_IQ80332 -CONFIG_MACH_IQ81340MC -CONFIG_MACH_IQ81340SC -CONFIG_MACH_ISC3 -CONFIG_MACH_IXDP2351 -CONFIG_MACH_IXDP28X5 -CONFIG_MACH_IXDP465 -CONFIG_MACH_IXDPG425 -CONFIG_MACH_JANUS -CONFIG_MACH_JIGEN -CONFIG_MACH_JIVE -CONFIG_MACH_JOCPU550 -CONFIG_MACH_KAEN -CONFIG_MACH_KAFA -CONFIG_MACH_KB9200 -CONFIG_MACH_KEV7A400 -CONFIG_MACH_KINGDOM -CONFIG_MACH_KIXRP435 -CONFIG_MACH_KMM2M01 -CONFIG_MACH_KMP_AM17_01 CONFIG_MACH_KM_KIRKWOOD -CONFIG_MACH_KOI -CONFIG_MACH_KRONOS -CONFIG_MACH_KT_SBC_SAM9_1 -CONFIG_MACH_KUROBOX_PRO -CONFIG_MACH_KX33XX -CONFIG_MACH_KZM9D -CONFIG_MACH_KZM9G -CONFIG_MACH_KZM_ARM11_01 -CONFIG_MACH_LANREADYFN511 -CONFIG_MACH_LAUSANNE -CONFIG_MACH_LB88RC8480 -CONFIG_MACH_LEAD -CONFIG_MACH_LEGACY -CONFIG_MACH_LEMON -CONFIG_MACH_LIBRA -CONFIG_MACH_LIGHTNING -CONFIG_MACH_LILLY1131 -CONFIG_MACH_LINKSTATION_CHLV2 -CONFIG_MACH_LINKSTATION_LSCHL -CONFIG_MACH_LINKSTATION_LS_HGL -CONFIG_MACH_LINKSTATION_MINI -CONFIG_MACH_LINKSTATION_PRO -CONFIG_MACH_LITTLETON -CONFIG_MACH_LOFT -CONFIG_MACH_LOGICPD_PXA270 -CONFIG_MACH_LPC24XX -CONFIG_MACH_LPD7A400 -CONFIG_MACH_LPD7A404 -CONFIG_MACH_LQ2 -CONFIG_MACH_LS9G20 -CONFIG_MACH_LSWXL -CONFIG_MACH_M502 -CONFIG_MACH_MACH_SDH001 -CONFIG_MACH_MACKEREL -CONFIG_MACH_MAGICIAN -CONFIG_MACH_MAGX_ZN5 -CONFIG_MACH_MAHIMAHI -CONFIG_MACH_MAINSTONE -CONFIG_MACH_MANUAE -CONFIG_MACH_MAPLE1 -CONFIG_MACH_MARVEL -CONFIG_MACH_MARVELC -CONFIG_MACH_MARVELCT -CONFIG_MACH_MARVELL_JASPER -CONFIG_MACH_MATRIX505 -CONFIG_MACH_MATRIX518 -CONFIG_MACH_MAXIMASP -CONFIG_MACH_MB3 -CONFIG_MACH_MECHA -CONFIG_MACH_MENO_QNG -CONFIG_MACH_MESON -CONFIG_MACH_MESON_6236M -CONFIG_MACH_MESON_8626M -CONFIG_MACH_MESSINA -CONFIG_MACH_MIC256 -CONFIG_MACH_MICCPT -CONFIG_MACH_MICRO9 -CONFIG_MACH_MICRO9L -CONFIG_MACH_MICRO9M -CONFIG_MACH_MICRO9S -CONFIG_MACH_MIF10P -CONFIG_MACH_MIMAS -CONFIG_MACH_MINI210 -CONFIG_MACH_MINI2440 -CONFIG_MACH_MINI6410 -CONFIG_MACH_MINI8168 -CONFIG_MACH_MIOA502 -CONFIG_MACH_MIOA701 -CONFIG_MACH_MIONE -CONFIG_MACH_MIOS_V1 -CONFIG_MACH_MITYOMAPL138 -CONFIG_MACH_MMM -CONFIG_MACH_MONCH -CONFIG_MACH_MONE -CONFIG_MACH_MOON -CONFIG_MACH_MORA -CONFIG_MACH_MR301A -CONFIG_MACH_MSM7X25_FFA -CONFIG_MACH_MSM7X25_SURF -CONFIG_MACH_MSM7X27A_FFA -CONFIG_MACH_MSM7X27A_RUMI3 -CONFIG_MACH_MSM7X27A_SURF -CONFIG_MACH_MSM7X27_FFA -CONFIG_MACH_MSM7X27_SURF -CONFIG_MACH_MSM7X30_FFA -CONFIG_MACH_MSM7X30_FLUID -CONFIG_MACH_MSM7X30_SURF -CONFIG_MACH_MSM8960_APQ -CONFIG_MACH_MSM8960_CDP -CONFIG_MACH_MSM8960_FLUID -CONFIG_MACH_MSM8960_MDP -CONFIG_MACH_MSM8960_RUMI3 -CONFIG_MACH_MSM8960_SIM -CONFIG_MACH_MSM8X55_SVLTE_FFA -CONFIG_MACH_MSM8X55_SVLTE_SURF -CONFIG_MACH_MSM8X60_FFA -CONFIG_MACH_MSM8X60_FLUID -CONFIG_MACH_MSM8X60_QRDC -CONFIG_MACH_MSM8X60_QT -CONFIG_MACH_MSM8X60_RUMI3 -CONFIG_MACH_MSM8X60_SIM -CONFIG_MACH_MSM8X60_SURF -CONFIG_MACH_MSS2 -CONFIG_MACH_MULTHSU -CONFIG_MACH_MV2120 -CONFIG_MACH_MV88F6281GTW_GE -CONFIG_MACH_MVBLX -CONFIG_MACH_MX21ADS -CONFIG_MACH_MX23EVK -CONFIG_MACH_MX257SOL -CONFIG_MACH_MX257SX -CONFIG_MACH_MX25_3DS -CONFIG_MACH_MX25_E2S_UC -CONFIG_MACH_MX27ADS -CONFIG_MACH_MX27SU2 -CONFIG_MACH_MX27_3DS -CONFIG_MACH_MX27_WMULTRA -CONFIG_MACH_MX28EVK -CONFIG_MACH_MX31ADS -CONFIG_MACH_MX31LITE -CONFIG_MACH_MX31MOBOARD -CONFIG_MACH_MX31_3DS -CONFIG_MACH_MX35_3DS -CONFIG_MACH_MX50_ARM2 -CONFIG_MACH_MX50_RDP -CONFIG_MACH_MX51EREBUS -CONFIG_MACH_MX51_3DS -CONFIG_MACH_MX51_ASTER7 -CONFIG_MACH_MX51_BABBAGE -CONFIG_MACH_MX51_BRAVO -CONFIG_MACH_MX51_EFIKAMX -CONFIG_MACH_MX51_EFIKASB -CONFIG_MACH_MX51_GGC -CONFIG_MACH_MX51_MORAY -CONFIG_MACH_MX51_TULIP -CONFIG_MACH_MX53_ARD -CONFIG_MACH_MX53_EVK -CONFIG_MACH_MX53_LOCO -CONFIG_MACH_MX53_SMD -CONFIG_MACH_MX61_ARD -CONFIG_MACH_MXC25_TOPAZ -CONFIG_MACH_MXLADS -CONFIG_MACH_MXT_TD60 -CONFIG_MACH_MXT_TD61 -CONFIG_MACH_N2100 -CONFIG_MACH_N30 -CONFIG_MACH_N35 -CONFIG_MACH_NAJAY_A9263 -CONFIG_MACH_NANOS -CONFIG_MACH_NANOZOOM -CONFIG_MACH_NAS100D -CONFIG_MACH_NAS4220B -CONFIG_MACH_NAS6210 -CONFIG_MACH_NAVEFIHID -CONFIG_MACH_NAXY1200 -CONFIG_MACH_NAXY400 -CONFIG_MACH_NB31 -CONFIG_MACH_NCP -CONFIG_MACH_NDA_EVM -CONFIG_MACH_NEC_MP900 -CONFIG_MACH_NEO1973_GTA02 -CONFIG_MACH_NEOCORE926 -CONFIG_MACH_NERY_1000 -CONFIG_MACH_NET2BIG -CONFIG_MACH_NET2BIG_NAND_V2 -CONFIG_MACH_NET2BIG_V2 -CONFIG_MACH_NET5BIG_NAND_V2 -CONFIG_MACH_NET5BIG_V2 -CONFIG_MACH_NETSPACE_LITE_V2 -CONFIG_MACH_NETSPACE_MAX_V2 -CONFIG_MACH_NETSPACE_V2 -CONFIG_MACH_NETVIZ -CONFIG_MACH_NETWALKER -CONFIG_MACH_NEUROS_OSD2 -CONFIG_MACH_NEXCODER_2440 -CONFIG_MACH_NITROGEN_IMX51 -CONFIG_MACH_NITROGEN_IMX53 -CONFIG_MACH_NITROGEN_VM_IMX51 -CONFIG_MACH_NMH -CONFIG_MACH_NOKIA770 -CONFIG_MACH_NOKIA_N800 -CONFIG_MACH_NOKIA_N810 -CONFIG_MACH_NOKIA_N810_WIMAX -CONFIG_MACH_NOKIA_RM680 -CONFIG_MACH_NOKIA_RX51 -CONFIG_MACH_NOMADIK -CONFIG_MACH_NOTLE -CONFIG_MACH_NS2416 -CONFIG_MACH_NS2816TB -CONFIG_MACH_NS2816_NTNB -CONFIG_MACH_NS2816_NTPAD -CONFIG_MACH_NSB3AST -CONFIG_MACH_NSK330 -CONFIG_MACH_NSLU2 -CONFIG_MACH_NSSLSBOARD -CONFIG_MACH_NS_K330 -CONFIG_MACH_NUC700EVB -CONFIG_MACH_NUC710EVB -CONFIG_MACH_NUC740EVB -CONFIG_MACH_NUC745EVB -CONFIG_MACH_NUC932EVB -CONFIG_MACH_NUC950TS -CONFIG_MACH_NURI -CONFIG_MACH_NV1000 -CONFIG_MACH_NXDB500 -CONFIG_MACH_NXDKN -CONFIG_MACH_NXEB500HMI -CONFIG_MACH_OCE_NIGMA -CONFIG_MACH_OMAP2EVM -CONFIG_MACH_OMAP3505NOVA8 -CONFIG_MACH_OMAP3517EVM -CONFIG_MACH_OMAP3530_LV_SOM -CONFIG_MACH_OMAP3621_EDP1 -CONFIG_MACH_OMAP3EVM -CONFIG_MACH_OMAP3SMARTDISPLAY -CONFIG_MACH_OMAP3_BAIA -CONFIG_MACH_OMAP3_BC10 -CONFIG_MACH_OMAP3_BEAGLE -CONFIG_MACH_OMAP3_BRAILLO -CONFIG_MACH_OMAP3_IBIZA -CONFIG_MACH_OMAP3_PANDORA -CONFIG_MACH_OMAP3_RFS200 -CONFIG_MACH_OMAP3_TDM3730 -CONFIG_MACH_OMAP3_TORPEDO -CONFIG_MACH_OMAP3_WALDO1 -CONFIG_MACH_OMAP4_PANDA -CONFIG_MACH_OMAP5_SEVM -CONFIG_MACH_OMAPL138_CASE_A3 -CONFIG_MACH_OMAPL138_EUROPALC -CONFIG_MACH_OMAPL138_HAWKBOARD CONFIG_MACH_OMAPL138_LCDK -CONFIG_MACH_OMAP_2430SDP -CONFIG_MACH_OMAP_3430SDP -CONFIG_MACH_OMAP_3630SDP -CONFIG_MACH_OMAP_4430SDP -CONFIG_MACH_OMAP_APOLLON -CONFIG_MACH_OMAP_BENDER -CONFIG_MACH_OMAP_FSAMPLE -CONFIG_MACH_OMAP_GENERIC -CONFIG_MACH_OMAP_H2 -CONFIG_MACH_OMAP_H3 -CONFIG_MACH_OMAP_H4 -CONFIG_MACH_OMAP_INNOVATOR -CONFIG_MACH_OMAP_LDP -CONFIG_MACH_OMAP_MCOP -CONFIG_MACH_OMAP_OSK -CONFIG_MACH_OMAP_PALMTE -CONFIG_MACH_OMAP_PALMTT -CONFIG_MACH_OMAP_PALMZ71 -CONFIG_MACH_OMAP_PERSEUS2 -CONFIG_MACH_OMAP_ZOOM2 -CONFIG_MACH_OMAP_ZOOM3 -CONFIG_MACH_OMN_AT91SAM9G20 -CONFIG_MACH_ONEARM CONFIG_MACH_OPENRD_BASE -CONFIG_MACH_OPENRD_CLIENT -CONFIG_MACH_OPENRD_ULTIMATE -CONFIG_MACH_ORATISAES -CONFIG_MACH_ORATISLINK -CONFIG_MACH_ORIGEN -CONFIG_MACH_OSIRIS -CONFIG_MACH_OSLO_AMUNDSEN -CONFIG_MACH_OTOM -CONFIG_MACH_OVERO -CONFIG_MACH_OVERO_CTU_INERTIAL -CONFIG_MACH_P87_SMARTSIM -CONFIG_MACH_PALMLD -CONFIG_MACH_PALMT5 -CONFIG_MACH_PALMTC -CONFIG_MACH_PALMTE2 -CONFIG_MACH_PALMTX -CONFIG_MACH_PALMZ72 -CONFIG_MACH_PAZ00 -CONFIG_MACH_PC7302 -CONFIG_MACH_PC7308 -CONFIG_MACH_PC9260_V2 -CONFIG_MACH_PCA100 -CONFIG_MACH_PCA102 -CONFIG_MACH_PCATS_OVERLAY -CONFIG_MACH_PCM027 -CONFIG_MACH_PCM037 -CONFIG_MACH_PCM038 -CONFIG_MACH_PCM043 -CONFIG_MACH_PCM048 -CONFIG_MACH_PCM049 -CONFIG_MACH_PCONTROL_G20 -CONFIG_MACH_PEC_HC2 -CONFIG_MACH_PEC_TC -CONFIG_MACH_PEMP_OMAP3_APOLLO -CONFIG_MACH_PGS_SITARA -CONFIG_MACH_PHILHWANI -CONFIG_MACH_PHY3250 -CONFIG_MACH_PICASSO -CONFIG_MACH_PICO -CONFIG_MACH_PICOCOM3 -CONFIG_MACH_PICOCOM4 -CONFIG_MACH_PICOTUX2XX -CONFIG_MACH_PIVICC -CONFIG_MACH_PNX4008 -CONFIG_MACH_POLYSAT1 -CONFIG_MACH_POODLE -CONFIG_MACH_PORTUXG20 -CONFIG_MACH_POV15HD -CONFIG_MACH_PREMIERWAVE_EN -CONFIG_MACH_PRIMA2_EVB -CONFIG_MACH_PTX7510 -CONFIG_MACH_PTX7545 -CONFIG_MACH_PUNICA -CONFIG_MACH_PUPITRE -CONFIG_MACH_PVM2030 -CONFIG_MACH_PWB3090 -CONFIG_MACH_PXWNAS_500_1000 -CONFIG_MACH_PYRAMID -CONFIG_MACH_QBC9263 -CONFIG_MACH_QIL_A9260 -CONFIG_MACH_QONG -CONFIG_MACH_QSD8X50A_ST1_5 -CONFIG_MACH_QSD8X50_SURF -CONFIG_MACH_QSD8X72_FFA -CONFIG_MACH_QSD8X72_SURF -CONFIG_MACH_QT2410 -CONFIG_MACH_QUAD_SALSA -CONFIG_MACH_QUICKSTEP -CONFIG_MACH_R1801E -CONFIG_MACH_RASCAL -CONFIG_MACH_RAUMFELD_CONNECTOR -CONFIG_MACH_RAUMFELD_RC -CONFIG_MACH_RAUMFELD_SPEAKER -CONFIG_MACH_RD78X00_MASA -CONFIG_MACH_RD88F5181L_FXO -CONFIG_MACH_RD88F5181L_GE -CONFIG_MACH_RD88F5182 -CONFIG_MACH_RD88F6183AP_GE -CONFIG_MACH_RD88F6192_NAS -CONFIG_MACH_RD88F6281 -CONFIG_MACH_RDSTOR -CONFIG_MACH_RE2REV20 -CONFIG_MACH_RE2REV21 -CONFIG_MACH_REAL6410 -CONFIG_MACH_REALVIEW_EB -CONFIG_MACH_REALVIEW_PB1176 -CONFIG_MACH_REALVIEW_PB11MP -CONFIG_MACH_REALVIEW_PBA8 -CONFIG_MACH_REALVIEW_PBX -CONFIG_MACH_REMUS -CONFIG_MACH_REXMAS -CONFIG_MACH_RFL109145_SSRV -CONFIG_MACH_RHINO -CONFIG_MACH_RIB -CONFIG_MACH_RIDER -CONFIG_MACH_RIOT_BEI2 -CONFIG_MACH_RIOT_X37 -CONFIG_MACH_ROADRUNNER -CONFIG_MACH_ROCKHOPPER -CONFIG_MACH_ROVERPCS8 -CONFIG_MACH_ROVERX7 -CONFIG_MACH_ROVER_G8 -CONFIG_MACH_RPC353 -CONFIG_MACH_RUBY -CONFIG_MACH_RUBYS -CONFIG_MACH_RUMP -CONFIG_MACH_RUT100 -CONFIG_MACH_RV082 -CONFIG_MACH_RX1950 -CONFIG_MACH_RX3715 -CONFIG_MACH_S3C2413 -CONFIG_MACH_S5500 -CONFIG_MACH_S5PC110_CRESPO -CONFIG_MACH_SAAR -CONFIG_MACH_SAARB -CONFIG_MACH_SAARB_MG1 -CONFIG_MACH_SAGA -CONFIG_MACH_SALUDA -CONFIG_MACH_SAM9REPEATER -CONFIG_MACH_SAM9_L9260 -CONFIG_MACH_SANTIAGO -CONFIG_MACH_SAPPHIRE -CONFIG_MACH_SBC3530 -CONFIG_MACH_SBC6000X -CONFIG_MACH_SBCA11 -CONFIG_MACH_SC575IPC -CONFIG_MACH_SC575PLC -CONFIG_MACH_SCB9328 -CONFIG_MACH_SCIPHONE_G2 -CONFIG_MACH_SDI_ESS_9263 -CONFIG_MACH_SDVR -CONFIG_MACH_SEABOARD -CONFIG_MACH_SERRANO -CONFIG_MACH_SFFSDR -CONFIG_MACH_SGH_I740 -CONFIG_MACH_SHARESPACE CONFIG_MACH_SHEEVAPLUG -CONFIG_MACH_SHENZHOU -CONFIG_MACH_SHEPHERD -CONFIG_MACH_SHOOTER -CONFIG_MACH_SHOOTER_CT -CONFIG_MACH_SHOOTER_U -CONFIG_MACH_SHORTLOIN -CONFIG_MACH_SIEMENS_L0 -CONFIG_MACH_SIMPLENET -CONFIG_MACH_SIMTEC_KIRKMOD -CONFIG_MACH_SIM_ONE -CONFIG_MACH_SKY25 -CONFIG_MACH_SKY6410 -CONFIG_MACH_SM1K -CONFIG_MACH_SMARTQ5 -CONFIG_MACH_SMARTQ7 -CONFIG_MACH_SMARTQV3 -CONFIG_MACH_SMARTQV5 -CONFIG_MACH_SMARTQV7 -CONFIG_MACH_SMDK2412 -CONFIG_MACH_SMDK2413 -CONFIG_MACH_SMDK2416 -CONFIG_MACH_SMDK2443 -CONFIG_MACH_SMDK6410 -CONFIG_MACH_SMDK6440 -CONFIG_MACH_SMDK6442 -CONFIG_MACH_SMDK6450 -CONFIG_MACH_SMDKC100 -CONFIG_MACH_SMDKC110 -CONFIG_MACH_SMDKC210 -CONFIG_MACH_SMDKV210 -CONFIG_MACH_SMDKV310 -CONFIG_MACH_SNAPPER_9260 -CONFIG_MACH_SNAPPER_CL15 -CONFIG_MACH_SOFTWINNER -CONFIG_MACH_SOLI_01 -CONFIG_MACH_SPADE -CONFIG_MACH_SPADE_LTE -CONFIG_MACH_SPDM -CONFIG_MACH_SPEAR1310 -CONFIG_MACH_SPEAR1340 -CONFIG_MACH_SPEAR300 -CONFIG_MACH_SPEAR310 -CONFIG_MACH_SPEAR320 -CONFIG_MACH_SPEAR600 -CONFIG_MACH_SPEAR900 CONFIG_MACH_SPECIFIC -CONFIG_MACH_SPICA -CONFIG_MACH_SPITZ -CONFIG_MACH_SPLENDOR -CONFIG_MACH_SPX_SAKURA -CONFIG_MACH_SPYPLUG -CONFIG_MACH_SSC -CONFIG_MACH_STAMP9G20 -CONFIG_MACH_STAMP9G45 -CONFIG_MACH_STARGATE2 -CONFIG_MACH_STEELYARD -CONFIG_MACH_STELLA -CONFIG_MACH_STMP378X -CONFIG_MACH_STMP37XX -CONFIG_MACH_STRASBOURG -CONFIG_MACH_STRASBOURG_A2 -CONFIG_MACH_STRETCHS7000 -CONFIG_MACH_SUNFIRE -CONFIG_MACH_SUNFLOWER -CONFIG_MACH_SVCID -CONFIG_MACH_SVP5500 -CONFIG_MACH_SVP8500V1 -CONFIG_MACH_SVP8500V2 -CONFIG_MACH_SWARCOEXTMODEM -CONFIG_MACH_SWEDA_TMS2 -CONFIG_MACH_SX1 -CONFIG_MACH_SYNERGY -CONFIG_MACH_SYNOLOGY_6282 -CONFIG_MACH_T20 -CONFIG_MACH_T5325 -CONFIG_MACH_T5388P -CONFIG_MACH_T55 -CONFIG_MACH_TAG -CONFIG_MACH_TAGW -CONFIG_MACH_TANNA -CONFIG_MACH_TAVOREVB -CONFIG_MACH_TAVOREVB3 -CONFIG_MACH_TCC8000_SDK -CONFIG_MACH_TCT_HAMMER -CONFIG_MACH_TD3_REV1 -CONFIG_MACH_TEENOTE -CONFIG_MACH_TEGRA_DAYTONA -CONFIG_MACH_TEGRA_E1165 -CONFIG_MACH_TEGRA_SWORDFISH -CONFIG_MACH_TEGRA_VOGUE -CONFIG_MACH_TEM3X30 -CONFIG_MACH_TENDERLOIN -CONFIG_MACH_TERASTATION_PRO2 -CONFIG_MACH_TERASTATION_WXL -CONFIG_MACH_TERA_PRO2_RACK -CONFIG_MACH_TETON_BGA -CONFIG_MACH_THALES_ADC -CONFIG_MACH_THALES_CBC -CONFIG_MACH_THEBE -CONFIG_MACH_TI8148EVM -CONFIG_MACH_TI8168EVM -CONFIG_MACH_TIMU -CONFIG_MACH_TIN307 -CONFIG_MACH_TIN510 -CONFIG_MACH_TINY_GURNARD -CONFIG_MACH_TITAN -CONFIG_MACH_TJINC1000 -CONFIG_MACH_TM_EFDC -CONFIG_MACH_TN200 -CONFIG_MACH_TNETV107X -CONFIG_MACH_TNY_T3530 -CONFIG_MACH_TONGA2_TFTTIMER -CONFIG_MACH_TOP9000 -CONFIG_MACH_TOP9000_BSL -CONFIG_MACH_TOP9000_EVAL -CONFIG_MACH_TOP9000_SU -CONFIG_MACH_TOP9000_TCU -CONFIG_MACH_TORBRECK -CONFIG_MACH_TORNADO3240 -CONFIG_MACH_TOSA -CONFIG_MACH_TOUCHBOOK -CONFIG_MACH_TPT_2_0 -CONFIG_MACH_TQ6410 -CONFIG_MACH_TQMA35 -CONFIG_MACH_TQMA9263 -CONFIG_MACH_TRANSCEDE -CONFIG_MACH_TREO680 -CONFIG_MACH_TRICORDER -CONFIG_MACH_TRIDENT -CONFIG_MACH_TRIMSLICE -CONFIG_MACH_TRIPEL -CONFIG_MACH_TRITIP -CONFIG_MACH_TRIZEPS4 -CONFIG_MACH_TRIZEPS4WL -CONFIG_MACH_TROUT -CONFIG_MACH_TS209 -CONFIG_MACH_TS219 -CONFIG_MACH_TS3 -CONFIG_MACH_TS409 -CONFIG_MACH_TS41X -CONFIG_MACH_TS42XX -CONFIG_MACH_TS47XX -CONFIG_MACH_TS4800 -CONFIG_MACH_TS48XX -CONFIG_MACH_TS72XX -CONFIG_MACH_TS75XX -CONFIG_MACH_TS78XX -CONFIG_MACH_TSOPLOADER -CONFIG_MACH_TSUNAGI -CONFIG_MACH_TTC_DKB -CONFIG_MACH_TUBE -CONFIG_MACH_TULIP -CONFIG_MACH_TUNA -CONFIG_MACH_TUXRAIL -CONFIG_MACH_TX28 -CONFIG_MACH_TX53 CONFIG_MACH_TYPE CONFIG_MACH_TYPE_COMPAT_REV -CONFIG_MACH_U300 -CONFIG_MACH_U5500 -CONFIG_MACH_UBISYS_P9D_EVP -CONFIG_MACH_UEMD -CONFIG_MACH_UNINO1 -CONFIG_MACH_UNISDEV -CONFIG_MACH_UNISENSE_MMM -CONFIG_MACH_UNIT2S -CONFIG_MACH_UNIVERSAL_C210 -CONFIG_MACH_USB_A9260 -CONFIG_MACH_USB_A9263 -CONFIG_MACH_USDLOADER -CONFIG_MACH_UTM300 -CONFIG_MACH_VALDEZ -CONFIG_MACH_VANGOGH -CONFIG_MACH_VC0718 -CONFIG_MACH_VENTANA -CONFIG_MACH_VERDI -CONFIG_MACH_VERDI_LTE -CONFIG_MACH_VERIDIS_A300 -CONFIG_MACH_VERSATILE_AB -CONFIG_MACH_VEXPRESS -CONFIG_MACH_VIGOR -CONFIG_MACH_VIPRINET -CONFIG_MACH_VIT_IBOX -CONFIG_MACH_VIVO -CONFIG_MACH_VIVOW_CT -CONFIG_MACH_VMX25 -CONFIG_MACH_VMX51 -CONFIG_MACH_VMX53 -CONFIG_MACH_VOICEBLUE -CONFIG_MACH_VPAC270 -CONFIG_MACH_VPR200 -CONFIG_MACH_VR1000 -CONFIG_MACH_VSTMS -CONFIG_MACH_VVBOX_SDLITE2 -CONFIG_MACH_VVBOX_SDORIG2 -CONFIG_MACH_VVBOX_SDPRO4 -CONFIG_MACH_W21 -CONFIG_MACH_W90N960EVB -CONFIG_MACH_W90P910EVB -CONFIG_MACH_W90P950EVB -CONFIG_MACH_WARIO -CONFIG_MACH_WASABI -CONFIG_MACH_WATSON_EFM_PLUGIN -CONFIG_MACH_WB40N -CONFIG_MACH_WBD111 -CONFIG_MACH_WBD222 -CONFIG_MACH_WG302V2 -CONFIG_MACH_WHISTLER -CONFIG_MACH_WLAN_COMPUTER -CONFIG_MACH_WLF_CRAGG_6410 -CONFIG_MACH_WM8505_7IN_NETBOOK -CONFIG_MACH_WM8650REFBOARD -CONFIG_MACH_WN802T -CONFIG_MACH_WNR854T -CONFIG_MACH_WRT350N_V2 -CONFIG_MACH_WTPLUG -CONFIG_MACH_XARINA -CONFIG_MACH_XCEP -CONFIG_MACH_XILINX -CONFIG_MACH_XILINX_EP107 -CONFIG_MACH_XSBASE255 -CONFIG_MACH_YANOMAMI -CONFIG_MACH_YL9200 -CONFIG_MACH_Z3_814X_MOD -CONFIG_MACH_Z3_816X_MOD -CONFIG_MACH_ZIPIT2 -CONFIG_MACH_ZMX25 -CONFIG_MACH_ZYLONITE -CONFIG_MACH_ZYLONITE2 CONFIG_MACPWR CONFIG_MACRESET_TIMEOUT CONFIG_MAC_ADDR_IN_EEPROM @@ -3751,28 +2696,6 @@ CONFIG_S5PC110 CONFIG_S5P_PA_SYSRAM CONFIG_S6E63D6 CONFIG_S6E8AX0 -CONFIG_SA1100_ADSBITSY -CONFIG_SA1100_ASSABET -CONFIG_SA1100_BADGE4 -CONFIG_SA1100_BRUTUS -CONFIG_SA1100_CERF -CONFIG_SA1100_COLLIE -CONFIG_SA1100_CONSUS -CONFIG_SA1100_FLEXANET -CONFIG_SA1100_GRAPHICSCLIENT -CONFIG_SA1100_GRAPHICSMASTER -CONFIG_SA1100_H3100 -CONFIG_SA1100_H3600 -CONFIG_SA1100_HACKKIT -CONFIG_SA1100_JORNADA720 -CONFIG_SA1100_LART -CONFIG_SA1100_NANOENGINE -CONFIG_SA1100_PFS168 -CONFIG_SA1100_PLEB -CONFIG_SA1100_PT_SYSTEM3 -CONFIG_SA1100_SHANNON -CONFIG_SA1100_SIMPAD -CONFIG_SA1100_XP860 CONFIG_SABRELITE CONFIG_SAMA5D2 CONFIG_SAMA5D3
On Tue, Jan 10, 2017 at 4:22 PM, Tom Rini trini@konsulko.com wrote:
This re-syncs the MACH_TYPE_xxx values from the Linux Kernel v4.9 release. In addition this removes all of the machine_arch_type and machine_is_xxx logic that is unused in U-Boot. This removal removes a large number of otherwise unused CONFIG values from the list to be converted.
Tested on omap3_logic (DM3730) Torpedo. Tested-by: Adam Ford aford173@gmail.com
Cc: Masahiro Yamada yamada.masahiro@socionext.com Signed-off-by: Tom Rini trini@konsulko.com
arch/arm/include/asm/mach-types.h | 14174 ++---------------------------------- scripts/config_whitelist.txt | 1077 --- 2 files changed, 486 insertions(+), 14765 deletions(-)
diff --git a/arch/arm/include/asm/mach-types.h b/arch/arm/include/asm/mach-types.h index d51be0b1d2f8..c90caa85c82c 100644 --- a/arch/arm/include/asm/mach-types.h +++ b/arch/arm/include/asm/mach-types.h @@ -6,11 +6,6 @@ #ifndef __ASM_ARM_MACH_TYPE_H #define __ASM_ARM_MACH_TYPE_H
-#ifndef __ASSEMBLY__ -/* The type of machine we're running on */ -extern unsigned int __machine_arch_type; -#endif
/* see arch/arm/kernel/arch.c for a description of these */ #define MACH_TYPE_EBSA110 0 #define MACH_TYPE_RISCPC 1 @@ -87,6 +82,7 @@ extern unsigned int __machine_arch_type; #define MACH_TYPE_LPD7A404 390 #define MACH_TYPE_CSB337 399 #define MACH_TYPE_MAINSTONE 406 +#define MACH_TYPE_LITE300 408 #define MACH_TYPE_XCEP 413 #define MACH_TYPE_ARCOM_VULCAN 414 #define MACH_TYPE_NOMADIK 420 @@ -123,12 +119,14 @@ extern unsigned int __machine_arch_type; #define MACH_TYPE_SX1 613 #define MACH_TYPE_IXDP465 618 #define MACH_TYPE_IXDP2351 619 +#define MACH_TYPE_CM4008 624 #define MACH_TYPE_IQ80332 629 #define MACH_TYPE_GTWX5715 641 #define MACH_TYPE_CSB637 648 #define MACH_TYPE_N30 656 #define MACH_TYPE_NEC_MP900 659 #define MACH_TYPE_KAFA 662 +#define MACH_TYPE_CM41XX 672 #define MACH_TYPE_TS72XX 673 #define MACH_TYPE_OTOM 680 #define MACH_TYPE_NEXCODER_2440 681 @@ -141,6 +139,7 @@ extern unsigned int __machine_arch_type; #define MACH_TYPE_GATEWAY7001 731 #define MACH_TYPE_PCM027 732 #define MACH_TYPE_ANUBIS 734 +#define MACH_TYPE_XBOARDGP8 742 #define MACH_TYPE_AKITA 744 #define MACH_TYPE_E330 753 #define MACH_TYPE_NOKIA770 755 @@ -150,8 +149,10 @@ extern unsigned int __machine_arch_type; #define MACH_TYPE_INTELMOTE2 775 #define MACH_TYPE_TRIZEPS4 776 #define MACH_TYPE_PNX4008 782 +#define MACH_TYPE_CPUAT91 787 #define MACH_TYPE_IQ81340SC 799 #define MACH_TYPE_IQ81340MC 801 +#define MACH_TYPE_SE4200 809 #define MACH_TYPE_MICRO9 811 #define MACH_TYPE_MICRO9L 812 #define MACH_TYPE_OMAP_PALMTE 817 @@ -170,6 +171,7 @@ extern unsigned int __machine_arch_type; #define MACH_TYPE_AMS_DELTA 862 #define MACH_TYPE_NAS100D 865 #define MACH_TYPE_MAGICIAN 875 +#define MACH_TYPE_CM4002 876 #define MACH_TYPE_NXDKN 880 #define MACH_TYPE_PALMTX 885 #define MACH_TYPE_S3C2413 887 @@ -178,6 +180,7 @@ extern unsigned int __machine_arch_type; #define MACH_TYPE_DAVINCI_EVM 901 #define MACH_TYPE_PALMZ72 904 #define MACH_TYPE_NXDB500 905 +#define MACH_TYPE_APF9328 906 #define MACH_TYPE_PALMT5 917 #define MACH_TYPE_PALMTC 918 #define MACH_TYPE_OMAP_APOLLON 919 @@ -196,6 +199,7 @@ extern unsigned int __machine_arch_type; #define MACH_TYPE_SMDK2412 1009 #define MACH_TYPE_SMDK2413 1022 #define MACH_TYPE_AML_M5900 1024 +#define MACH_TYPE_BALLOON3 1029 #define MACH_TYPE_ECBAT91 1072 #define MACH_TYPE_ONEARM 1075 #define MACH_TYPE_SMDK2443 1084 @@ -203,6 +207,7 @@ extern unsigned int __machine_arch_type; #define MACH_TYPE_AT91SAM9260EK 1099 #define MACH_TYPE_GLANTANK 1100 #define MACH_TYPE_N2100 1101 +#define MACH_TYPE_IM42XX 1105 #define MACH_TYPE_QT2410 1108 #define MACH_TYPE_KIXRP435 1109 #define MACH_TYPE_CC9P9360DEV 1114 @@ -221,6 +226,7 @@ extern unsigned int __machine_arch_type; #define MACH_TYPE_MIOA701 1257 #define MACH_TYPE_ARMADILLO5X0 1260 #define MACH_TYPE_CC9P9360JS 1264 +#define MACH_TYPE_SMDK6400 1270 #define MACH_TYPE_NOKIA_N800 1271 #define MACH_TYPE_EP80219 1281 #define MACH_TYPE_GORAMO_MLR 1292 @@ -235,6 +241,7 @@ extern unsigned int __machine_arch_type; #define MACH_TYPE_DAVINCI_DM6467_EVM 1380 #define MACH_TYPE_DAVINCI_DM355_EVM 1381 #define MACH_TYPE_LITTLETON 1388 +#define MACH_TYPE_IM4004 1400 #define MACH_TYPE_REALVIEW_PB11MP 1407 #define MACH_TYPE_MX27_3DS 1430 #define MACH_TYPE_HALIBUT 1439 @@ -256,13 +263,16 @@ extern unsigned int __machine_arch_type; #define MACH_TYPE_OMAP3_BEAGLE 1546 #define MACH_TYPE_NOKIA_N810 1548 #define MACH_TYPE_PCM038 1551 +#define MACH_TYPE_SG310 1564 #define MACH_TYPE_TS209 1565 #define MACH_TYPE_AT91CAP9ADK 1566 #define MACH_TYPE_MX31MOBOARD 1574 +#define MACH_TYPE_VISION_EP9307 1578 #define MACH_TYPE_TERASTATION_PRO2 1584 #define MACH_TYPE_LINKSTATION_PRO 1585 #define MACH_TYPE_E350 1596 #define MACH_TYPE_TS409 1601 +#define MACH_TYPE_RSI_EWS 1609 #define MACH_TYPE_CM_X300 1616 #define MACH_TYPE_AT91SAM9G20EK 1624 #define MACH_TYPE_SMDK6410 1626 @@ -274,7 +284,6 @@ extern unsigned int __machine_arch_type; #define MACH_TYPE_TRIZEPS4WL 1649 #define MACH_TYPE_TS78XX 1652 #define MACH_TYPE_SFFSDR 1657 -#define MACH_TYPE_SMARTWEB 1668 #define MACH_TYPE_PCM037 1673 #define MACH_TYPE_DB88F6281_BP 1680 #define MACH_TYPE_RD88F6192_NAS 1681 @@ -307,7 +316,6 @@ extern unsigned int __machine_arch_type; #define MACH_TYPE_MX25_3DS 1771 #define MACH_TYPE_OMAP3530_LV_SOM 1773 #define MACH_TYPE_DAVINCI_DA830_EVM 1781 -#define MACH_TYPE_AT572D940HFEB 1783 #define MACH_TYPE_DOVE_DB 1788 #define MACH_TYPE_OVERO 1798 #define MACH_TYPE_AT2440EVB 1799 @@ -320,6 +328,7 @@ extern unsigned int __machine_arch_type; #define MACH_TYPE_TAVOREVB 1827 #define MACH_TYPE_SAAR 1828 #define MACH_TYPE_AT91SAM9M10G45EK 1830 +#define MACH_TYPE_USB_A9G20 1841 #define MACH_TYPE_MXLADS 1851 #define MACH_TYPE_LINKSTATION_MINI 1858 #define MACH_TYPE_AFEB9260 1859 @@ -366,13 +375,12 @@ extern unsigned int __machine_arch_type; #define MACH_TYPE_AT91SAM9G10EK 2159 #define MACH_TYPE_OMAP_4430SDP 2160 #define MACH_TYPE_MAGX_ZN5 2162 -#define MACH_TYPE_BTMAVB101 2172 -#define MACH_TYPE_BTMAWB101 2173 #define MACH_TYPE_OMAP3_TORPEDO 2178 #define MACH_TYPE_ANW6410 2183 #define MACH_TYPE_IMX27_VISSTRIM_M10 2187 #define MACH_TYPE_PORTUXG20 2191 #define MACH_TYPE_SMDKC110 2193 +#define MACH_TYPE_CABESPRESSO 2194 #define MACH_TYPE_OMAP3517EVM 2200 #define MACH_TYPE_NETSPACE_V2 2201 #define MACH_TYPE_NETSPACE_MAX_V2 2202 @@ -381,7 +389,6 @@ extern unsigned int __machine_arch_type; #define MACH_TYPE_NET5BIG_V2 2206 #define MACH_TYPE_INETSPACE_V2 2208 #define MACH_TYPE_AT91SAM9G45EKES 2212 -#define MACH_TYPE_PC7302 2220 #define MACH_TYPE_SPEAR600 2236 #define MACH_TYPE_SPEAR300 2237 #define MACH_TYPE_LILLY1131 2239 @@ -391,8 +398,8 @@ extern unsigned int __machine_arch_type; #define MACH_TYPE_BIGDISK 2283 #define MACH_TYPE_AT91SAM9G20EK_2MMC 2288 #define MACH_TYPE_BCMRING 2289 -#define MACH_TYPE_DP6XX 2302 #define MACH_TYPE_MAHIMAHI 2304 +#define MACH_TYPE_CEREBRIC 2311 #define MACH_TYPE_SMDK6442 2324 #define MACH_TYPE_OPENRD_BASE 2325 #define MACH_TYPE_DEVKIT8000 2330 @@ -402,6 +409,7 @@ extern unsigned int __machine_arch_type; #define MACH_TYPE_IGEP0020 2344 #define MACH_TYPE_NUC932EVB 2356 #define MACH_TYPE_OPENRD_CLIENT 2361 +#define MACH_TYPE_U8500 2368 #define MACH_TYPE_MX51_EFIKASB 2370 #define MACH_TYPE_MARVELL_JASPER 2382 #define MACH_TYPE_FLINT 2383 @@ -414,6 +422,7 @@ extern unsigned int __machine_arch_type; #define MACH_TYPE_SMDKV210 2456 #define MACH_TYPE_OMAP_ZOOM3 2464 #define MACH_TYPE_OMAP_3630SDP 2465 +#define MACH_TYPE_CYBOOK2440 2466 #define MACH_TYPE_SMARTQ7 2479 #define MACH_TYPE_WATSON_EFM_PLUGIN 2491 #define MACH_TYPE_G4EVM 2493 @@ -425,10 +434,9 @@ extern unsigned int __machine_arch_type; #define MACH_TYPE_SMARTQ5 2534 #define MACH_TYPE_DAVINCI_DM6467TEVM 2548 #define MACH_TYPE_MXT_TD60 2550 -#define MACH_TYPE_RIOT_BEI2 2576 -#define MACH_TYPE_RIOT_X37 2578 #define MACH_TYPE_CAPC7117 2612 #define MACH_TYPE_ICONTROL 2624 +#define MACH_TYPE_GPLUGD 2625 #define MACH_TYPE_QSD8X50A_ST1_5 2627 #define MACH_TYPE_MX23EVK 2629 #define MACH_TYPE_AP4EVB 2630 @@ -439,7 +447,6 @@ extern unsigned int __machine_arch_type; #define MACH_TYPE_AQUILA 2676 #define MACH_TYPE_ESATA_SHEEVAPLUG 2678 #define MACH_TYPE_MSM7X30_SURF 2679 -#define MACH_TYPE_EA2478DEVKIT 2683 #define MACH_TYPE_TERASTATION_WXL 2697 #define MACH_TYPE_MSM7X25_SURF 2703 #define MACH_TYPE_MSM7X25_FFA 2704 @@ -452,14 +459,13 @@ extern unsigned int __machine_arch_type; #define MACH_TYPE_SBC3530 2722 #define MACH_TYPE_SAARB 2727 #define MACH_TYPE_HARMONY 2731 +#define MACH_TYPE_CYBOOK_ORIZON 2733 #define MACH_TYPE_MSM7X30_FLUID 2741 #define MACH_TYPE_CM_T3517 2750 #define MACH_TYPE_WBD222 2753 #define MACH_TYPE_MSM8X60_SURF 2755 #define MACH_TYPE_MSM8X60_SIM 2756 #define MACH_TYPE_TCC8000_SDK 2758 -#define MACH_TYPE_NANOS 2759 -#define MACH_TYPE_STAMP9G45 2761 #define MACH_TYPE_CNS3420VB 2776 #define MACH_TYPE_OMAP4_PANDA 2791 #define MACH_TYPE_TI8168EVM 2800 @@ -469,13731 +475,523 @@ extern unsigned int __machine_arch_type; #define MACH_TYPE_EUKREA_CPUIMX51SD 2822 #define MACH_TYPE_EUKREA_CPUIMX51 2823 #define MACH_TYPE_SMDKC210 2838 -#define MACH_TYPE_OMAP3_BRAILLO 2839 -#define MACH_TYPE_SPYPLUG 2840 -#define MACH_TYPE_GINGER 2841 -#define MACH_TYPE_TNY_T3530 2842 -#define MACH_TYPE_PCA102 2843 -#define MACH_TYPE_SPADE 2844 -#define MACH_TYPE_MXC25_TOPAZ 2845 #define MACH_TYPE_T5325 2846 -#define MACH_TYPE_GW2361 2847 -#define MACH_TYPE_ELOG 2848 #define MACH_TYPE_INCOME 2849 -#define MACH_TYPE_BCM589X 2850 -#define MACH_TYPE_ETNA 2851 -#define MACH_TYPE_HAWKS 2852 -#define MACH_TYPE_MESON 2853 -#define MACH_TYPE_XSBASE255 2854 -#define MACH_TYPE_PVM2030 2855 -#define MACH_TYPE_MIOA502 2856 -#define MACH_TYPE_VVBOX_SDORIG2 2857 -#define MACH_TYPE_VVBOX_SDLITE2 2858 -#define MACH_TYPE_VVBOX_SDPRO4 2859 -#define MACH_TYPE_HTC_SPV_M700 2860 -#define MACH_TYPE_MX257SX 2861 #define MACH_TYPE_GONI 2862 -#define MACH_TYPE_MSM8X55_SVLTE_FFA 2863 -#define MACH_TYPE_MSM8X55_SVLTE_SURF 2864 -#define MACH_TYPE_QUICKSTEP 2865 -#define MACH_TYPE_DMW96 2866 -#define MACH_TYPE_HAMMERHEAD 2867 -#define MACH_TYPE_TRIDENT 2868 -#define MACH_TYPE_LIGHTNING 2869 -#define MACH_TYPE_ICONNECT 2870 -#define MACH_TYPE_AUTOBOT 2871 -#define MACH_TYPE_COCONUT 2872 -#define MACH_TYPE_DURIAN 2873 -#define MACH_TYPE_CAYENNE 2874 -#define MACH_TYPE_FUJI 2875 -#define MACH_TYPE_SYNOLOGY_6282 2876 -#define MACH_TYPE_EM1SY 2877 -#define MACH_TYPE_M502 2878 -#define MACH_TYPE_MATRIX518 2879 -#define MACH_TYPE_TINY_GURNARD 2880 -#define MACH_TYPE_SPEAR1310 2881 #define MACH_TYPE_BV07 2882 -#define MACH_TYPE_MXT_TD61 2883 #define MACH_TYPE_OPENRD_ULTIMATE 2884 #define MACH_TYPE_DEVIXP 2885 #define MACH_TYPE_MICCPT 2886 #define MACH_TYPE_MIC256 2887 -#define MACH_TYPE_AS1167 2888 -#define MACH_TYPE_OMAP3_IBIZA 2889 #define MACH_TYPE_U5500 2890 -#define MACH_TYPE_DAVINCI_PICTO 2891 -#define MACH_TYPE_MECHA 2892 -#define MACH_TYPE_BUBBA3 2893 -#define MACH_TYPE_PUPITRE 2894 -#define MACH_TYPE_TEGRA_VOGUE 2896 -#define MACH_TYPE_TEGRA_E1165 2897 -#define MACH_TYPE_SIMPLENET 2898 -#define MACH_TYPE_EC4350TBM 2899 -#define MACH_TYPE_PEC_TC 2900 -#define MACH_TYPE_PEC_HC2 2901 -#define MACH_TYPE_ESL_MOBILIS_A 2902 -#define MACH_TYPE_ESL_MOBILIS_B 2903 -#define MACH_TYPE_ESL_WAVE_A 2904 -#define MACH_TYPE_ESL_WAVE_B 2905 -#define MACH_TYPE_UNISENSE_MMM 2906 -#define MACH_TYPE_BLUESHARK 2907 -#define MACH_TYPE_E10 2908 -#define MACH_TYPE_APP3K_ROBIN 2909 -#define MACH_TYPE_POV15HD 2910 -#define MACH_TYPE_STELLA 2911 #define MACH_TYPE_LINKSTATION_LSCHL 2913 -#define MACH_TYPE_NETWALKER 2914 -#define MACH_TYPE_ACSX106 2915 -#define MACH_TYPE_ATLAS5_C1 2916 -#define MACH_TYPE_NSB3AST 2917 -#define MACH_TYPE_GNET_SLC 2918 -#define MACH_TYPE_AF4000 2919 -#define MACH_TYPE_ARK9431 2920 -#define MACH_TYPE_FS_S5PC100 2921 -#define MACH_TYPE_OMAP3505NOVA8 2922 -#define MACH_TYPE_OMAP3621_EDP1 2923 -#define MACH_TYPE_ORATISAES 2924 #define MACH_TYPE_SMDKV310 2925 -#define MACH_TYPE_SIEMENS_L0 2926 -#define MACH_TYPE_VENTANA 2927 #define MACH_TYPE_WM8505_7IN_NETBOOK 2928 -#define MACH_TYPE_EC4350SDB 2929 -#define MACH_TYPE_MIMAS 2930 -#define MACH_TYPE_TITAN 2931 #define MACH_TYPE_CRANEBOARD 2932 -#define MACH_TYPE_ES2440 2933 -#define MACH_TYPE_NAJAY_A9263 2934 -#define MACH_TYPE_HTCTORNADO 2935 -#define MACH_TYPE_DIMM_MX257 2936 -#define MACH_TYPE_JIGEN 2937 #define MACH_TYPE_SMDK6450 2938 -#define MACH_TYPE_MENO_QNG 2939 -#define MACH_TYPE_NS2416 2940 -#define MACH_TYPE_RPC353 2941 -#define MACH_TYPE_TQ6410 2942 -#define MACH_TYPE_SKY6410 2943 -#define MACH_TYPE_DYNASTY 2944 -#define MACH_TYPE_VIVO 2945 -#define MACH_TYPE_BURY_BL7582 2946 -#define MACH_TYPE_BURY_BPS5270 2947 -#define MACH_TYPE_BASI 2948 -#define MACH_TYPE_TN200 2949 -#define MACH_TYPE_C2MMI 2950 -#define MACH_TYPE_MESON_6236M 2951 -#define MACH_TYPE_MESON_8626M 2952 -#define MACH_TYPE_TUBE 2953 -#define MACH_TYPE_MESSINA 2954 -#define MACH_TYPE_MX50_ARM2 2955 -#define MACH_TYPE_CETUS9263 2956 #define MACH_TYPE_BROWNSTONE 2957 -#define MACH_TYPE_VMX25 2958 -#define MACH_TYPE_VMX51 2959 -#define MACH_TYPE_ABACUS 2960 -#define MACH_TYPE_CM4745 2961 -#define MACH_TYPE_ORATISLINK 2962 -#define MACH_TYPE_DAVINCI_DM365_DVR 2963 -#define MACH_TYPE_NETVIZ 2964 #define MACH_TYPE_FLEXIBITY 2965 -#define MACH_TYPE_WLAN_COMPUTER 2966 -#define MACH_TYPE_LPC24XX 2967 -#define MACH_TYPE_SPICA 2968 -#define MACH_TYPE_GPSDISPLAY 2969 -#define MACH_TYPE_BIPNET 2970 -#define MACH_TYPE_OVERO_CTU_INERTIAL 2971 -#define MACH_TYPE_DAVINCI_DM355_MMM 2972 -#define MACH_TYPE_PC9260_V2 2973 -#define MACH_TYPE_PTX7545 2974 -#define MACH_TYPE_TM_EFDC 2975 -#define MACH_TYPE_OMAP3_WALDO1 2977 -#define MACH_TYPE_FLYER 2978 -#define MACH_TYPE_TORNADO3240 2979 -#define MACH_TYPE_SOLI_01 2980 -#define MACH_TYPE_OMAPL138_EUROPALC 2981 -#define MACH_TYPE_HELIOS_V1 2982 -#define MACH_TYPE_NETSPACE_LITE_V2 2983 -#define MACH_TYPE_SSC 2984 -#define MACH_TYPE_PREMIERWAVE_EN 2985 -#define MACH_TYPE_WASABI 2986 #define MACH_TYPE_MX50_RDP 2988 #define MACH_TYPE_UNIVERSAL_C210 2989 #define MACH_TYPE_REAL6410 2990 -#define MACH_TYPE_SPX_SAKURA 2991 -#define MACH_TYPE_IJ3K_2440 2992 -#define MACH_TYPE_OMAP3_BC10 2993 -#define MACH_TYPE_THEBE 2994 -#define MACH_TYPE_RV082 2995 -#define MACH_TYPE_ARMLGUEST 2996 -#define MACH_TYPE_TJINC1000 2997 #define MACH_TYPE_DOCKSTAR 2998 -#define MACH_TYPE_AX8008 2999 -#define MACH_TYPE_GNET_SGCE 3000 -#define MACH_TYPE_PXWNAS_500_1000 3001 -#define MACH_TYPE_EA20 3002 -#define MACH_TYPE_AWM2 3003 #define MACH_TYPE_TI8148EVM 3004 #define MACH_TYPE_SEABOARD 3005 -#define MACH_TYPE_LINKSTATION_CHLV2 3006 -#define MACH_TYPE_TERA_PRO2_RACK 3007 -#define MACH_TYPE_RUBYS 3008 -#define MACH_TYPE_AQUARIUS 3009 #define MACH_TYPE_MX53_ARD 3010 #define MACH_TYPE_MX53_SMD 3011 -#define MACH_TYPE_LSWXL 3012 -#define MACH_TYPE_DOVE_AVNG_V3 3013 -#define MACH_TYPE_SDI_ESS_9263 3014 -#define MACH_TYPE_JOCPU550 3015 #define MACH_TYPE_MSM8X60_RUMI3 3016 #define MACH_TYPE_MSM8X60_FFA 3017 -#define MACH_TYPE_YANOMAMI 3018 -#define MACH_TYPE_GTA04 3019 #define MACH_TYPE_CM_A510 3020 -#define MACH_TYPE_OMAP3_RFS200 3021 -#define MACH_TYPE_KX33XX 3022 -#define MACH_TYPE_PTX7510 3023 -#define MACH_TYPE_TOP9000 3024 -#define MACH_TYPE_TEENOTE 3025 -#define MACH_TYPE_TS3 3026 -#define MACH_TYPE_A0 3027 -#define MACH_TYPE_FSM9XXX_SURF 3028 -#define MACH_TYPE_FSM9XXX_FFA 3029 -#define MACH_TYPE_FRRHWCDMA60W 3030 -#define MACH_TYPE_REMUS 3031 -#define MACH_TYPE_AT91CAP7XDK 3032 -#define MACH_TYPE_AT91CAP7STK 3033 -#define MACH_TYPE_KT_SBC_SAM9_1 3034 -#define MACH_TYPE_ARMADA_XP_DB 3036 -#define MACH_TYPE_SPDM 3037 -#define MACH_TYPE_GTIB 3038 -#define MACH_TYPE_DGM3240 3039 -#define MACH_TYPE_HTCMEGA 3041 -#define MACH_TYPE_TRICORDER 3042 #define MACH_TYPE_TX28 3043 -#define MACH_TYPE_BSTBRD 3044 -#define MACH_TYPE_PWB3090 3045 -#define MACH_TYPE_IDEA6410 3046 -#define MACH_TYPE_QBC9263 3047 -#define MACH_TYPE_BORABORA 3048 -#define MACH_TYPE_VALDEZ 3049 -#define MACH_TYPE_LS9G20 3050 -#define MACH_TYPE_MIOS_V1 3051 -#define MACH_TYPE_S5PC110_CRESPO 3052 -#define MACH_TYPE_CONTROLTEK9G20 3053 -#define MACH_TYPE_TIN307 3054 -#define MACH_TYPE_TIN510 3055 -#define MACH_TYPE_BLUECHEESE 3057 -#define MACH_TYPE_TEM3X30 3058 -#define MACH_TYPE_HARVEST_DESOTO 3059 -#define MACH_TYPE_MSM8X60_QRDC 3060 -#define MACH_TYPE_SPEAR900 3061 #define MACH_TYPE_PCONTROL_G20 3062 -#define MACH_TYPE_RDSTOR 3063 -#define MACH_TYPE_USDLOADER 3064 -#define MACH_TYPE_TSOPLOADER 3065 -#define MACH_TYPE_KRONOS 3066 -#define MACH_TYPE_FFCORE 3067 -#define MACH_TYPE_MONE 3068 -#define MACH_TYPE_UNIT2S 3069 -#define MACH_TYPE_ACER_A5 3070 -#define MACH_TYPE_ETHERPRO_ISP 3071 -#define MACH_TYPE_STRETCHS7000 3072 -#define MACH_TYPE_P87_SMARTSIM 3073 -#define MACH_TYPE_TULIP 3074 -#define MACH_TYPE_SUNFLOWER 3075 -#define MACH_TYPE_RIB 3076 -#define MACH_TYPE_CLOD 3077 -#define MACH_TYPE_RUMP 3078 -#define MACH_TYPE_TENDERLOIN 3079 -#define MACH_TYPE_SHORTLOIN 3080 -#define MACH_TYPE_ANTARES 3082 -#define MACH_TYPE_WB40N 3083 -#define MACH_TYPE_HERRING 3084 -#define MACH_TYPE_NAXY400 3085 -#define MACH_TYPE_NAXY1200 3086 #define MACH_TYPE_VPR200 3087 -#define MACH_TYPE_BUG20 3088 -#define MACH_TYPE_GOFLEXNET 3089 #define MACH_TYPE_TORBRECK 3090 -#define MACH_TYPE_SAARB_MG1 3091 -#define MACH_TYPE_CALLISTO 3092 -#define MACH_TYPE_MULTHSU 3093 -#define MACH_TYPE_SALUDA 3094 -#define MACH_TYPE_PEMP_OMAP3_APOLLO 3095 -#define MACH_TYPE_VC0718 3096 -#define MACH_TYPE_MVBLX 3097 -#define MACH_TYPE_INHAND_APEIRON 3098 -#define MACH_TYPE_INHAND_FURY 3099 -#define MACH_TYPE_INHAND_SIREN 3100 -#define MACH_TYPE_HDNVP 3101 -#define MACH_TYPE_SOFTWINNER 3102 #define MACH_TYPE_PRIMA2_EVB 3103 -#define MACH_TYPE_NAS6210 3104 -#define MACH_TYPE_UNISDEV 3105 -#define MACH_TYPE_SBCA11 3106 -#define MACH_TYPE_SAGA 3107 -#define MACH_TYPE_NS_K330 3108 -#define MACH_TYPE_TANNA 3109 -#define MACH_TYPE_IMATE8502 3110 -#define MACH_TYPE_ASPEN 3111 -#define MACH_TYPE_DAINTREE_CWAC 3112 -#define MACH_TYPE_ZMX25 3113 -#define MACH_TYPE_MAPLE1 3114 -#define MACH_TYPE_QSD8X72_SURF 3115 -#define MACH_TYPE_QSD8X72_FFA 3116 -#define MACH_TYPE_ABILENE 3117 -#define MACH_TYPE_EIGEN_TTR 3118 -#define MACH_TYPE_IOMEGA_IX2_200 3119 -#define MACH_TYPE_CORETEC_VCX7400 3120 -#define MACH_TYPE_SANTIAGO 3121 -#define MACH_TYPE_MX257SOL 3122 -#define MACH_TYPE_STRASBOURG 3123 -#define MACH_TYPE_MSM8X60_FLUID 3124 -#define MACH_TYPE_SMARTQV5 3125 -#define MACH_TYPE_SMARTQV3 3126 -#define MACH_TYPE_SMARTQV7 3127 #define MACH_TYPE_PAZ00 3128 #define MACH_TYPE_ACMENETUSFOXG20 3129 -#define MACH_TYPE_FWBD_0404 3131 -#define MACH_TYPE_HDGU 3132 -#define MACH_TYPE_PYRAMID 3133 -#define MACH_TYPE_EPIPHAN 3134 -#define MACH_TYPE_OMAP_BENDER 3135 -#define MACH_TYPE_GURNARD 3136 -#define MACH_TYPE_GTL_IT5100 3137 -#define MACH_TYPE_BCM2708 3138 -#define MACH_TYPE_MX51_GGC 3139 -#define MACH_TYPE_SHARESPACE 3140 -#define MACH_TYPE_HABA_KNX_EXPLORER 3141 -#define MACH_TYPE_SIMTEC_KIRKMOD 3142 -#define MACH_TYPE_CRUX 3143 -#define MACH_TYPE_MX51_BRAVO 3144 -#define MACH_TYPE_CHARON 3145 -#define MACH_TYPE_PICOCOM3 3146 -#define MACH_TYPE_PICOCOM4 3147 -#define MACH_TYPE_SERRANO 3148 -#define MACH_TYPE_DOUBLESHOT 3149 -#define MACH_TYPE_EVSY 3150 -#define MACH_TYPE_HUASHAN 3151 -#define MACH_TYPE_LAUSANNE 3152 -#define MACH_TYPE_EMERALD 3153 -#define MACH_TYPE_TQMA35 3154 -#define MACH_TYPE_MARVEL 3155 -#define MACH_TYPE_MANUAE 3156 -#define MACH_TYPE_CHACHA 3157 -#define MACH_TYPE_LEMON 3158 -#define MACH_TYPE_CSC 3159 -#define MACH_TYPE_GIRA_KNXIP_ROUTER 3160 -#define MACH_TYPE_T20 3161 -#define MACH_TYPE_HDMINI 3162 -#define MACH_TYPE_SCIPHONE_G2 3163 -#define MACH_TYPE_EXPRESS 3164 -#define MACH_TYPE_EXPRESS_KT 3165 -#define MACH_TYPE_MAXIMASP 3166 -#define MACH_TYPE_NITROGEN_IMX51 3167 -#define MACH_TYPE_NITROGEN_IMX53 3168 -#define MACH_TYPE_SUNFIRE 3169 -#define MACH_TYPE_AROWANA 3170 -#define MACH_TYPE_TEGRA_DAYTONA 3171 -#define MACH_TYPE_TEGRA_SWORDFISH 3172 -#define MACH_TYPE_EDISON 3173 -#define MACH_TYPE_SVP8500V1 3174 -#define MACH_TYPE_SVP8500V2 3175 -#define MACH_TYPE_SVP5500 3176 -#define MACH_TYPE_B5500 3177 -#define MACH_TYPE_S5500 3178 -#define MACH_TYPE_ICON 3179 -#define MACH_TYPE_ELEPHANT 3180 -#define MACH_TYPE_SHOOTER 3182 -#define MACH_TYPE_SPADE_LTE 3183 -#define MACH_TYPE_PHILHWANI 3184 -#define MACH_TYPE_GSNCOMM 3185 -#define MACH_TYPE_STRASBOURG_A2 3186 -#define MACH_TYPE_MMM 3187 -#define MACH_TYPE_DAVINCI_DM365_BV 3188 #define MACH_TYPE_AG5EVM 3189 -#define MACH_TYPE_SC575PLC 3190 -#define MACH_TYPE_SC575IPC 3191 -#define MACH_TYPE_OMAP3_TDM3730 3192 -#define MACH_TYPE_TOP9000_EVAL 3194 -#define MACH_TYPE_TOP9000_SU 3195 -#define MACH_TYPE_UTM300 3196 -#define MACH_TYPE_TSUNAGI 3197 -#define MACH_TYPE_TS75XX 3198 -#define MACH_TYPE_TS47XX 3200 -#define MACH_TYPE_DA850_K5 3201 -#define MACH_TYPE_AX502 3202 -#define MACH_TYPE_IGEP0032 3203 -#define MACH_TYPE_ANTERO 3204 -#define MACH_TYPE_SYNERGY 3205 #define MACH_TYPE_ICS_IF_VOIP 3206 #define MACH_TYPE_WLF_CRAGG_6410 3207 -#define MACH_TYPE_PUNICA 3208 #define MACH_TYPE_TRIMSLICE 3209 -#define MACH_TYPE_MX27_WMULTRA 3210 -#define MACH_TYPE_MACKEREL 3211 -#define MACH_TYPE_FA9X27 3213 -#define MACH_TYPE_NS2816TB 3214 -#define MACH_TYPE_NS2816_NTPAD 3215 -#define MACH_TYPE_NS2816_NTNB 3216 #define MACH_TYPE_KAEN 3217 -#define MACH_TYPE_NV1000 3218 -#define MACH_TYPE_NUC950TS 3219 #define MACH_TYPE_NOKIA_RM680 3220 -#define MACH_TYPE_AST2200 3221 -#define MACH_TYPE_LEAD 3222 -#define MACH_TYPE_UNINO1 3223 -#define MACH_TYPE_GREECO 3224 -#define MACH_TYPE_VERDI 3225 -#define MACH_TYPE_DM6446_ADBOX 3226 -#define MACH_TYPE_QUAD_SALSA 3227 -#define MACH_TYPE_ABB_GMA_1_1 3228 -#define MACH_TYPE_SVCID 3229 #define MACH_TYPE_MSM8960_SIM 3230 #define MACH_TYPE_MSM8960_RUMI3 3231 -#define MACH_TYPE_ICON_G 3232 -#define MACH_TYPE_MB3 3233 #define MACH_TYPE_GSIA18S 3234 -#define MACH_TYPE_PIVICC 3235 -#define MACH_TYPE_PCM048 3236 -#define MACH_TYPE_DDS 3237 -#define MACH_TYPE_CHALTEN_XA1 3238 -#define MACH_TYPE_TS48XX 3239 -#define MACH_TYPE_TONGA2_TFTTIMER 3240 -#define MACH_TYPE_WHISTLER 3241 -#define MACH_TYPE_ASL_PHOENIX 3242 -#define MACH_TYPE_AT91SAM9263OTLITE 3243 -#define MACH_TYPE_DDPLUG 3244 -#define MACH_TYPE_D2PLUG 3245 -#define MACH_TYPE_KZM9D 3246 -#define MACH_TYPE_VERDI_LTE 3247 -#define MACH_TYPE_NANOZOOM 3248 -#define MACH_TYPE_DM3730_SOM_LV 3249 -#define MACH_TYPE_DM3730_TORPEDO 3250 -#define MACH_TYPE_ANCHOVY 3251 -#define MACH_TYPE_RE2REV20 3253 -#define MACH_TYPE_RE2REV21 3254 -#define MACH_TYPE_CNS21XX 3255 -#define MACH_TYPE_RIDER 3257 -#define MACH_TYPE_NSK330 3258 -#define MACH_TYPE_CNS2133EVB 3259 -#define MACH_TYPE_Z3_816X_MOD 3260 -#define MACH_TYPE_Z3_814X_MOD 3261 -#define MACH_TYPE_BEECT 3262 -#define MACH_TYPE_DMA_THUNDERBUG 3263 -#define MACH_TYPE_OMN_AT91SAM9G20 3264 -#define MACH_TYPE_MX25_E2S_UC 3265 -#define MACH_TYPE_MIONE 3266 -#define MACH_TYPE_TOP9000_TCU 3267 -#define MACH_TYPE_TOP9000_BSL 3268 -#define MACH_TYPE_KINGDOM 3269 -#define MACH_TYPE_ARMADILLO460 3270 -#define MACH_TYPE_LQ2 3271 -#define MACH_TYPE_SWEDA_TMS2 3272 #define MACH_TYPE_MX53_LOCO 3273 -#define MACH_TYPE_ACER_A8 3275 -#define MACH_TYPE_ACER_GAUGUIN 3276 -#define MACH_TYPE_GUPPY 3277 -#define MACH_TYPE_MX61_ARD 3278 -#define MACH_TYPE_TX53 3279 -#define MACH_TYPE_OMAPL138_CASE_A3 3280 -#define MACH_TYPE_UEMD 3281 -#define MACH_TYPE_CCWMX51MUT 3282 -#define MACH_TYPE_ROCKHOPPER 3283 -#define MACH_TYPE_ENCORE 3284 -#define MACH_TYPE_HKDKC100 3285 -#define MACH_TYPE_TS42XX 3286 -#define MACH_TYPE_AEBL 3287 #define MACH_TYPE_WARIO 3288 -#define MACH_TYPE_GFS_SPM 3289 #define MACH_TYPE_CM_T3730 3290 -#define MACH_TYPE_ISC3 3291 -#define MACH_TYPE_RASCAL 3292 #define MACH_TYPE_HREFV60 3293 -#define MACH_TYPE_TPT_2_0 3294 -#define MACH_TYPE_SPLENDOR 3296 -#define MACH_TYPE_MSM8X60_QT 3298 -#define MACH_TYPE_HTC_HD_MINI 3299 -#define MACH_TYPE_ATHENE 3300 -#define MACH_TYPE_DEEP_R_EK_1 3301 -#define MACH_TYPE_VIVOW_CT 3302 -#define MACH_TYPE_NERY_1000 3303 -#define MACH_TYPE_RFL109145_SSRV 3304 -#define MACH_TYPE_NMH 3305 -#define MACH_TYPE_WN802T 3306 -#define MACH_TYPE_DRAGONET 3307 -#define MACH_TYPE_AT91SAM9263DESK16L 3309 -#define MACH_TYPE_BCMHANA_SV 3310 -#define MACH_TYPE_BCMHANA_TABLET 3311 -#define MACH_TYPE_KOI 3312 -#define MACH_TYPE_TS4800 3313 -#define MACH_TYPE_TQMA9263 3314 -#define MACH_TYPE_HOLIDAY 3315 -#define MACH_TYPE_DMA6410 3316 -#define MACH_TYPE_PCATS_OVERLAY 3317 -#define MACH_TYPE_HWGW6410 3318 -#define MACH_TYPE_SHENZHOU 3319 -#define MACH_TYPE_CWME9210 3320 -#define MACH_TYPE_CWME9210JS 3321 -#define MACH_TYPE_PGS_SITARA 3322 -#define MACH_TYPE_COLIBRI_T20 3323 -#define MACH_TYPE_W21 3324 -#define MACH_TYPE_POLYSAT1 3325 -#define MACH_TYPE_DATAWAY 3326 -#define MACH_TYPE_COBRAL138 3327 -#define MACH_TYPE_ROVERPCS8 3328 -#define MACH_TYPE_MARVELC 3329 -#define MACH_TYPE_NAVEFIHID 3330 -#define MACH_TYPE_DM365_CV100 3331 -#define MACH_TYPE_ABLE 3332 -#define MACH_TYPE_LEGACY 3333 -#define MACH_TYPE_ICONG 3334 -#define MACH_TYPE_ROVER_G8 3335 -#define MACH_TYPE_T5388P 3336 -#define MACH_TYPE_DINGO 3337 -#define MACH_TYPE_GOFLEXHOME 3338 -#define MACH_TYPE_LANREADYFN511 3340 -#define MACH_TYPE_OMAP3_BAIA 3341 -#define MACH_TYPE_OMAP3SMARTDISPLAY 3342 -#define MACH_TYPE_XILINX 3343 -#define MACH_TYPE_A2F 3344 -#define MACH_TYPE_SKY25 3345 -#define MACH_TYPE_CCMX53 3346 -#define MACH_TYPE_CCMX53JS 3347 -#define MACH_TYPE_CCWMX53 3348 -#define MACH_TYPE_CCWMX53JS 3349 -#define MACH_TYPE_FRISMS 3350 -#define MACH_TYPE_MSM7X27A_FFA 3351 -#define MACH_TYPE_MSM7X27A_SURF 3352 -#define MACH_TYPE_MSM7X27A_RUMI3 3353 -#define MACH_TYPE_DIMMSAM9G20 3354 -#define MACH_TYPE_DIMM_IMX28 3355 -#define MACH_TYPE_AMK_A4 3356 -#define MACH_TYPE_GNET_SGME 3357 -#define MACH_TYPE_SHOOTER_U 3358 -#define MACH_TYPE_VMX53 3359 -#define MACH_TYPE_RHINO 3360 #define MACH_TYPE_ARMLEX4210 3361 -#define MACH_TYPE_SWARCOEXTMODEM 3362 -#define MACH_TYPE_PCM049 3364 -#define MACH_TYPE_VIGOR 3365 -#define MACH_TYPE_OSLO_AMUNDSEN 3366 -#define MACH_TYPE_GSL_DIAMOND 3367 -#define MACH_TYPE_CV2201 3368 -#define MACH_TYPE_CV2202 3369 -#define MACH_TYPE_CV2203 3370 -#define MACH_TYPE_VIT_IBOX 3371 -#define MACH_TYPE_DM6441_ESP 3372 -#define MACH_TYPE_AT91SAM9X5EK 3373 -#define MACH_TYPE_LIBRA 3374 -#define MACH_TYPE_EASYCRRH 3375 -#define MACH_TYPE_TRIPEL 3376 -#define MACH_TYPE_ENDIAN_MINI 3377 +#define MACH_TYPE_SNOWBALL 3363 #define MACH_TYPE_XILINX_EP107 3378 #define MACH_TYPE_NURI 3379 -#define MACH_TYPE_JANUS 3380 -#define MACH_TYPE_DDNAS 3381 -#define MACH_TYPE_TAG 3382 -#define MACH_TYPE_TAGW 3383 -#define MACH_TYPE_NITROGEN_VM_IMX51 3384 -#define MACH_TYPE_VIPRINET 3385 -#define MACH_TYPE_BOCKW 3386 -#define MACH_TYPE_EVA2000 3387 -#define MACH_TYPE_STEELYARD 3388 -#define MACH_TYPE_MACH_SDH001 3390 -#define MACH_TYPE_NSSLSBOARD 3392 -#define MACH_TYPE_GENEVA_B5 3393 -#define MACH_TYPE_SPEAR1340 3394 -#define MACH_TYPE_REXMAS 3395 -#define MACH_TYPE_MSM8960_CDP 3396 -#define MACH_TYPE_MSM8960_MDP 3397 -#define MACH_TYPE_MSM8960_FLUID 3398 -#define MACH_TYPE_MSM8960_APQ 3399 -#define MACH_TYPE_HELIOS_V2 3400 -#define MACH_TYPE_MIF10P 3401 -#define MACH_TYPE_IAM28 3402 -#define MACH_TYPE_PICASSO 3403 -#define MACH_TYPE_MR301A 3404 -#define MACH_TYPE_NOTLE 3405 -#define MACH_TYPE_EELX2 3406 -#define MACH_TYPE_MOON 3407 -#define MACH_TYPE_RUBY 3408 -#define MACH_TYPE_GOLDENGATE 3409 -#define MACH_TYPE_CTBU_GEN2 3410 -#define MACH_TYPE_KMP_AM17_01 3411 -#define MACH_TYPE_WTPLUG 3412 -#define MACH_TYPE_MX27SU2 3413 -#define MACH_TYPE_NB31 3414 -#define MACH_TYPE_HJSDU 3415 -#define MACH_TYPE_TD3_REV1 3416 -#define MACH_TYPE_EAG_CI4000 3417 -#define MACH_TYPE_NET5BIG_NAND_V2 3418 -#define MACH_TYPE_CPX2 3419 -#define MACH_TYPE_NET2BIG_NAND_V2 3420 -#define MACH_TYPE_ECUV5 3421 -#define MACH_TYPE_HSGX6D 3422 -#define MACH_TYPE_DAWAD7 3423 -#define MACH_TYPE_SAM9REPEATER 3424 -#define MACH_TYPE_GT_I5700 3425 -#define MACH_TYPE_CTERA_PLUG_C2 3426 -#define MACH_TYPE_MARVELCT 3427 -#define MACH_TYPE_AG11005 3428 -#define MACH_TYPE_VANGOGH 3430 -#define MACH_TYPE_MATRIX505 3431 -#define MACH_TYPE_OCE_NIGMA 3432 -#define MACH_TYPE_T55 3433 -#define MACH_TYPE_BIO3K 3434 -#define MACH_TYPE_EXPRESSCT 3435 -#define MACH_TYPE_CARDHU 3436 -#define MACH_TYPE_ARUBA 3437 -#define MACH_TYPE_BONAIRE 3438 -#define MACH_TYPE_NUC700EVB 3439 -#define MACH_TYPE_NUC710EVB 3440 -#define MACH_TYPE_NUC740EVB 3441 -#define MACH_TYPE_NUC745EVB 3442 -#define MACH_TYPE_TRANSCEDE 3443 -#define MACH_TYPE_MORA 3444 -#define MACH_TYPE_NDA_EVM 3445 -#define MACH_TYPE_TIMU 3446 -#define MACH_TYPE_EXPRESSH 3447 -#define MACH_TYPE_VERIDIS_A300 3448 -#define MACH_TYPE_DM368_LEOPARD 3449 -#define MACH_TYPE_OMAP_MCOP 3450 -#define MACH_TYPE_TRITIP 3451 -#define MACH_TYPE_SM1K 3452 -#define MACH_TYPE_MONCH 3453 -#define MACH_TYPE_CURACAO 3454 #define MACH_TYPE_ORIGEN 3455 -#define MACH_TYPE_EPC10 3456 -#define MACH_TYPE_SGH_I740 3457 -#define MACH_TYPE_TUNA 3458 -#define MACH_TYPE_MX51_TULIP 3459 -#define MACH_TYPE_MX51_ASTER7 3460 -#define MACH_TYPE_ACRO37XBRD 3461 -#define MACH_TYPE_ELKE 3462 -#define MACH_TYPE_SBC6000X 3463 -#define MACH_TYPE_R1801E 3464 -#define MACH_TYPE_H1600 3465 -#define MACH_TYPE_MINI210 3466 -#define MACH_TYPE_MINI8168 3467 -#define MACH_TYPE_PC7308 3468 -#define MACH_TYPE_KMM2M01 3470 -#define MACH_TYPE_MX51EREBUS 3471 -#define MACH_TYPE_WM8650REFBOARD 3472 -#define MACH_TYPE_TUXRAIL 3473 -#define MACH_TYPE_ARTHUR 3474 -#define MACH_TYPE_DOORBOY 3475 -#define MACH_TYPE_XARINA 3476 -#define MACH_TYPE_ROVERX7 3477 -#define MACH_TYPE_SDVR 3478 -#define MACH_TYPE_ACER_MAYA 3479 -#define MACH_TYPE_PICO 3480 -#define MACH_TYPE_CWMX233 3481 -#define MACH_TYPE_CWAM1808 3482 -#define MACH_TYPE_CWDM365 3483 -#define MACH_TYPE_MX51_MORAY 3484 -#define MACH_TYPE_THALES_CBC 3485 -#define MACH_TYPE_BLUEPOINT 3486 -#define MACH_TYPE_DIR665 3487 -#define MACH_TYPE_ACMEROVER1 3488 -#define MACH_TYPE_SHOOTER_CT 3489 -#define MACH_TYPE_BLISS 3490 -#define MACH_TYPE_BLISSC 3491 -#define MACH_TYPE_THALES_ADC 3492 -#define MACH_TYPE_UBISYS_P9D_EVP 3493 -#define MACH_TYPE_ATDGP318 3494 -#define MACH_TYPE_OMAP5_SEVM 3777 -#define MACH_TYPE_PICOSAM9G45 3838 -#define MACH_TYPE_ARMADILLO_800EVA 3863 +#define MACH_TYPE_NSPIRE 3503 +#define MACH_TYPE_NOKIA_RM696 3522 +#define MACH_TYPE_MIKRAP_X168 3543 +#define MACH_TYPE_DETO_MACARM9 3568 +#define MACH_TYPE_M28EVK 3613 +#define MACH_TYPE_KOTA2 3616 +#define MACH_TYPE_BONITO 3623 +#define MACH_TYPE_OMAP3_EGF 3637 +#define MACH_TYPE_SMDK4212 3638 +#define MACH_TYPE_APX4DEVKIT 3712 +#define MACH_TYPE_SMDK4412 3765 +#define MACH_TYPE_MARZEN 3790 +#define MACH_TYPE_KROME 3797 +#define MACH_TYPE_ARMADILLO800EVA 3863 +#define MACH_TYPE_MX53_UMOBO 3927 +#define MACH_TYPE_MT4 3981 +#define MACH_TYPE_U8520 3990 +#define MACH_TYPE_CHUPACABRA 4098 +#define MACH_TYPE_SCORPION 4099 +#define MACH_TYPE_DAVINCI_HE_HMI10 4100 +#define MACH_TYPE_TOPKICK 4101 +#define MACH_TYPE_M3_AUGUESTRUSH 4102 +#define MACH_TYPE_IPC335X 4103 +#define MACH_TYPE_SUN4I 4104 +#define MACH_TYPE_IMX233_OLINUXINO 4105 +#define MACH_TYPE_K2_WL 4106 +#define MACH_TYPE_K2_UL 4107 +#define MACH_TYPE_K2_CL 4108 +#define MACH_TYPE_MINBARI_W 4109 +#define MACH_TYPE_MINBARI_M 4110 +#define MACH_TYPE_K035 4111 +#define MACH_TYPE_ARIEL 4112 +#define MACH_TYPE_ARIELSAARC 4113 +#define MACH_TYPE_ARIELDKB 4114 +#define MACH_TYPE_ARMADILLO810 4115 +#define MACH_TYPE_TAM335X 4116 +#define MACH_TYPE_GROUPER 4117 +#define MACH_TYPE_MPCSA21_9G20 4118 +#define MACH_TYPE_M6U_CPU 4119 +#define MACH_TYPE_GINKGO 4121 +#define MACH_TYPE_CGT_QMX6 4122 +#define MACH_TYPE_PROFPGA 4123 +#define MACH_TYPE_ACFX100OC 4124 +#define MACH_TYPE_ACFX100NB 4125 +#define MACH_TYPE_CAPRICORN 4126 +#define MACH_TYPE_PISCES 4127 +#define MACH_TYPE_ARIES 4128 +#define MACH_TYPE_CANCER 4129 +#define MACH_TYPE_LEO 4130 +#define MACH_TYPE_VIRGO 4131 +#define MACH_TYPE_SAGITTARIUS 4132 +#define MACH_TYPE_DEVIL 4133 +#define MACH_TYPE_BALLANTINES 4134 +#define MACH_TYPE_OMAP3_PROCERUSVPU 4135 +#define MACH_TYPE_MY27 4136 +#define MACH_TYPE_SUN6I 4137 +#define MACH_TYPE_SUN5I 4138 +#define MACH_TYPE_MX512_MX 4139 #define MACH_TYPE_KZM9G 4140 +#define MACH_TYPE_VDSTBN 4141 +#define MACH_TYPE_CFA10036 4142 +#define MACH_TYPE_CFA10049 4143 +#define MACH_TYPE_PCM051 4144 +#define MACH_TYPE_VYBRID_VF7XX 4145 +#define MACH_TYPE_VYBRID_VF6XX 4146 +#define MACH_TYPE_VYBRID_VF5XX 4147 +#define MACH_TYPE_VYBRID_VF4XX 4148 +#define MACH_TYPE_ARIA_G25 4149 +#define MACH_TYPE_BCM21553 4150 +#define MACH_TYPE_SMDK5410 4151 +#define MACH_TYPE_LPC18XX 4152 +#define MACH_TYPE_ORATISPARTY 4153 +#define MACH_TYPE_QSEVEN 4154 +#define MACH_TYPE_GMV_GENERIC 4155 +#define MACH_TYPE_TH_LINK_ETH 4156 +#define MACH_TYPE_TN_MUNINN 4157 +#define MACH_TYPE_RAMPAGE 4158 +#define MACH_TYPE_VISSTRIM_MV10 4159 +#define MACH_TYPE_MX28_WILMA 4164 +#define MACH_TYPE_MSM8625_FFA 4166 +#define MACH_TYPE_VPU101 4167 +#define MACH_TYPE_BAILEYS 4169 +#define MACH_TYPE_FAMILYBOX 4170 +#define MACH_TYPE_ENSEMBLE_MX35 4171 +#define MACH_TYPE_SC_SPS_1 4172 +#define MACH_TYPE_UCSIMPLY_SAM9260 4173 +#define MACH_TYPE_UNICORN 4174 +#define MACH_TYPE_M9G45A 4175 +#define MACH_TYPE_MTWEBIF 4176 +#define MACH_TYPE_PLAYSTONE 4177 +#define MACH_TYPE_CHELSEA 4178 +#define MACH_TYPE_BAYERN 4179 +#define MACH_TYPE_MITWO 4180 +#define MACH_TYPE_MX25_NOAH 4181 +#define MACH_TYPE_STM_B2020 4182 +#define MACH_TYPE_ANNAX_SRC 4183 +#define MACH_TYPE_IONICS_STRATUS 4184 +#define MACH_TYPE_HUGO 4185 +#define MACH_TYPE_EM300 4186 +#define MACH_TYPE_MMP3_QSEVEN 4187 +#define MACH_TYPE_BOSPHORUS2 4188 +#define MACH_TYPE_TT2200 4189 +#define MACH_TYPE_OCELOT3 4190 +#define MACH_TYPE_TEK_COBRA 4191 +#define MACH_TYPE_PROTOU 4192 +#define MACH_TYPE_MSM8625_EVT 4193 +#define MACH_TYPE_MX53_SELLWOOD 4194 +#define MACH_TYPE_SOMIQ_AM35 4195 +#define MACH_TYPE_SOMIQ_AM37 4196 +#define MACH_TYPE_K2_PLC_CL 4197 +#define MACH_TYPE_TC2 4198 +#define MACH_TYPE_DULEX_J 4199 +#define MACH_TYPE_STM_B2044 4200 +#define MACH_TYPE_DELUXE_J 4201 +#define MACH_TYPE_MANGO2443 4202 +#define MACH_TYPE_CP2DCG 4203 +#define MACH_TYPE_CP2DTG 4204 +#define MACH_TYPE_CP2DUG 4205 +#define MACH_TYPE_VAR_SOM_AM33 4206 +#define MACH_TYPE_PEPPER 4207 +#define MACH_TYPE_MANGO2450 4208 +#define MACH_TYPE_VALENTE_WX_C9 4209 +#define MACH_TYPE_MINITV 4210 +#define MACH_TYPE_U8540 4211 +#define MACH_TYPE_IV_ATLAS_I_Z7E 4212 +#define MACH_TYPE_MACH_TYPE_SKY 4214 +#define MACH_TYPE_BLUESKY 4215 +#define MACH_TYPE_NGROUTER 4216 +#define MACH_TYPE_MX53_DENETIM 4217 +#define MACH_TYPE_OPAL 4218 +#define MACH_TYPE_GNET_US3GREF 4219 +#define MACH_TYPE_GNET_NC3G 4220 +#define MACH_TYPE_GNET_GE3G 4221 +#define MACH_TYPE_ADP2 4222 +#define MACH_TYPE_TQMA28 4223 +#define MACH_TYPE_KACOM3 4224 +#define MACH_TYPE_RRHDEMO 4225 +#define MACH_TYPE_PROTODUG 4226 +#define MACH_TYPE_LAGO 4227 +#define MACH_TYPE_KTT30 4228 +#define MACH_TYPE_TS43XX 4229 +#define MACH_TYPE_MX6Q_DENSO 4230 +#define MACH_TYPE_COMSAT_GSMUMTS8 4231 +#define MACH_TYPE_DREAMX 4232 +#define MACH_TYPE_THUNDERSTONEM 4233 +#define MACH_TYPE_YOYOPAD 4234 +#define MACH_TYPE_YOYOPATIENT 4235 +#define MACH_TYPE_A10L 4236 +#define MACH_TYPE_MQ60 4237 +#define MACH_TYPE_LINKSTATION_LSQL 4238 +#define MACH_TYPE_AM3703GATEWAY 4239 +#define MACH_TYPE_ACCIPITER 4240 +#define MACH_TYPE_MAGNIDUG 4242 +#define MACH_TYPE_HYDRA 4243 +#define MACH_TYPE_SUN3I 4244 +#define MACH_TYPE_STM_B2078 4245 +#define MACH_TYPE_AT91SAM9263DESKV2 4246 +#define MACH_TYPE_DELUXE_R 4247 +#define MACH_TYPE_P_98_V 4248 +#define MACH_TYPE_P_98_C 4249 +#define MACH_TYPE_DAVINCI_AM18XX_OMN 4250 +#define MACH_TYPE_SOCFPGA_CYCLONE5 4251 +#define MACH_TYPE_CABATUIN 4252 +#define MACH_TYPE_YOYOPAD_FT 4253 +#define MACH_TYPE_DAN2400EVB 4254 +#define MACH_TYPE_DAN3400EVB 4255 +#define MACH_TYPE_EDM_SF_IMX6 4256 +#define MACH_TYPE_EDM_CF_IMX6 4257 +#define MACH_TYPE_VPOS3XX 4258 +#define MACH_TYPE_VULCANO_9X5 4259 +#define MACH_TYPE_SPMP8000 4260 +#define MACH_TYPE_CATALINA 4261 +#define MACH_TYPE_RD88F5181L_FE 4262 +#define MACH_TYPE_MX535_MX 4263 +#define MACH_TYPE_ARMADILLO840 4264 +#define MACH_TYPE_SPC9000BASEBOARD 4265 +#define MACH_TYPE_IRIS 4266 +#define MACH_TYPE_PROTODCG 4267 +#define MACH_TYPE_PALMTREE 4268 +#define MACH_TYPE_NOVENA 4269 +#define MACH_TYPE_MA_UM 4270 +#define MACH_TYPE_MA_AM 4271 +#define MACH_TYPE_EMS348 4272 +#define MACH_TYPE_CM_FX6 4273 +#define MACH_TYPE_ARNDALE 4274 +#define MACH_TYPE_Q5XR5 4275 +#define MACH_TYPE_WILLOW 4276 +#define MACH_TYPE_OMAP3621_ODYV3 4277 +#define MACH_TYPE_OMAPL138_PRESONUS 4278 +#define MACH_TYPE_DVF99 4279 +#define MACH_TYPE_IMPRESSION_J 4280 +#define MACH_TYPE_QBLISSA9 4281 +#define MACH_TYPE_ROBIN_HELIVIEW10 4282 +#define MACH_TYPE_SUN7I 4283 +#define MACH_TYPE_MX6Q_HDMIDONGLE 4284 +#define MACH_TYPE_MX6_SID2 4285 +#define MACH_TYPE_HELIOS_V3 4286 +#define MACH_TYPE_HELIOS_V4 4287 +#define MACH_TYPE_Q7_IMX6 4288 +#define MACH_TYPE_ODROIDX 4289 +#define MACH_TYPE_ROBPRO 4290 +#define MACH_TYPE_RESEARCH59IF_MK1 4291 +#define MACH_TYPE_BOBSLEIGH 4292 +#define MACH_TYPE_DCSHGWT3 4293 +#define MACH_TYPE_GLD1018 4294 +#define MACH_TYPE_EV10 4295 +#define MACH_TYPE_NITROGEN6X 4296 +#define MACH_TYPE_P_107_BB 4297 +#define MACH_TYPE_EVITA_UTL 4298 +#define MACH_TYPE_FALCONWING 4299 +#define MACH_TYPE_DCT3 4300 +#define MACH_TYPE_CPX2E_CELL 4301 +#define MACH_TYPE_AMIRO 4302 +#define MACH_TYPE_MX6Q_BRASSBOARD 4303 +#define MACH_TYPE_DALMORE 4304 +#define MACH_TYPE_OMAP3_PORTAL7CP 4305 +#define MACH_TYPE_TEGRA_PLUTO 4306 +#define MACH_TYPE_MX6SL_EVK 4307 +#define MACH_TYPE_M7 4308 +#define MACH_TYPE_PXM2 4309 +#define MACH_TYPE_HABA_KNX_LITE 4310 +#define MACH_TYPE_TAI 4311 +#define MACH_TYPE_PROTOTD 4312 +#define MACH_TYPE_DST_TONTO 4313 +#define MACH_TYPE_DRACO 4314 +#define MACH_TYPE_DXR2 4315 +#define MACH_TYPE_RUT 4316 +#define MACH_TYPE_AM180X_WSC 4317 +#define MACH_TYPE_DELUXE_U 4318 +#define MACH_TYPE_DELUXE_UL 4319 +#define MACH_TYPE_AT91SAM9260MEDTHS 4320 +#define MACH_TYPE_MATRIX516 4321 +#define MACH_TYPE_VID401X 4322 +#define MACH_TYPE_HELIOS_V5 4323 +#define MACH_TYPE_PLAYPAQ2 4324 +#define MACH_TYPE_IGAM 4325 +#define MACH_TYPE_AMICO_I 4326 +#define MACH_TYPE_AMICO_E 4327 +#define MACH_TYPE_SENTIENT_MM3_CK 4328 +#define MACH_TYPE_SMX6 4329 +#define MACH_TYPE_PANGO 4330 +#define MACH_TYPE_NS115_STICK 4331 +#define MACH_TYPE_BCTRM3 4332 +#define MACH_TYPE_DOCTORWS 4333 +#define MACH_TYPE_M2601 4334 +#define MACH_TYPE_VGG1111 4337 +#define MACH_TYPE_COUNTACH 4338 +#define MACH_TYPE_VISSTRIM_SM20 4339 +#define MACH_TYPE_A639 4340 +#define MACH_TYPE_SPACEMONKEY 4341 +#define MACH_TYPE_ZPDU_STAMP 4342 +#define MACH_TYPE_HTC_G7_CLONE 4343 +#define MACH_TYPE_FT2080_CORVUS 4344 +#define MACH_TYPE_FISLAND 4345 +#define MACH_TYPE_ZPDU 4346 +#define MACH_TYPE_URT 4347 +#define MACH_TYPE_CONTI_OVIP 4348 +#define MACH_TYPE_OMAPL138_NAGRA 4349 +#define MACH_TYPE_DA850_AT3KP1 4350 +#define MACH_TYPE_DA850_AT3KP2 4351 +#define MACH_TYPE_SURMA 4352 +#define MACH_TYPE_STM_B2092 4353 +#define MACH_TYPE_MX535_YCR 4354 +#define MACH_TYPE_M7_WL 4355 +#define MACH_TYPE_M7_U 4356 +#define MACH_TYPE_OMAP3_STNDT_EVM 4357 +#define MACH_TYPE_M7_WLV 4358 +#define MACH_TYPE_XAM3517 4359 +#define MACH_TYPE_A220 4360 +#define MACH_TYPE_ACLIMA_ODIE 4361 +#define MACH_TYPE_VIBBLE 4362 +#define MACH_TYPE_K2_U 4363 +#define MACH_TYPE_MX53_EGF 4364 +#define MACH_TYPE_NOVPEK_IMX53 4365 +#define MACH_TYPE_NOVPEK_IMX6X 4366 +#define MACH_TYPE_MX25_SMARTBOX 4367 +#define MACH_TYPE_EICG6410 4368 +#define MACH_TYPE_PICASSO_E3 4369 +#define MACH_TYPE_MOTONAVIGATOR 4370 +#define MACH_TYPE_VARIOCONNECT2 4371 +#define MACH_TYPE_DELUXE_TW 4372 +#define MACH_TYPE_KORE3 4374 +#define MACH_TYPE_MX6S_DRS 4375 +#define MACH_TYPE_CMIMX6 4376 +#define MACH_TYPE_ROTH 4377 +#define MACH_TYPE_EQ4UX 4378 +#define MACH_TYPE_X1PLUS 4379 +#define MACH_TYPE_MODIMX27 4380 +#define MACH_TYPE_VIDEON_HDUAC 4381 +#define MACH_TYPE_BLACKBIRD 4382 +#define MACH_TYPE_RUNMASTER 4383 +#define MACH_TYPE_CERES 4384 +#define MACH_TYPE_NAD435 4385 +#define MACH_TYPE_NS115_PROTO_TYPE 4386 +#define MACH_TYPE_FS20_VCC 4387 +#define MACH_TYPE_MESON6TV_SKT 4389 +#define MACH_TYPE_KEYSTONE 4390 +#define MACH_TYPE_PCM052 4391 +#define MACH_TYPE_QRD_SKUD_PRIME 4393 +#define MACH_TYPE_GUF_SANTARO 4395 +#define MACH_TYPE_SHEEPSHEAD 4396 +#define MACH_TYPE_MX6_IWG15M_MXM 4397 +#define MACH_TYPE_MX6_IWG15M_Q7 4398 +#define MACH_TYPE_AT91SAM9263IF8MIC 4399 +#define MACH_TYPE_MARCOPOLO 4401 +#define MACH_TYPE_MX535_SDCR 4402 +#define MACH_TYPE_MX53_CSB2733 4403 +#define MACH_TYPE_DIVA 4404 +#define MACH_TYPE_NCR_7744 4405 +#define MACH_TYPE_MACALLAN 4406 +#define MACH_TYPE_WNR3500 4407 +#define MACH_TYPE_PGAVRF 4408 +#define MACH_TYPE_HELIOS_V6 4409 +#define MACH_TYPE_LCCT 4410 +#define MACH_TYPE_CSNDUG 4411 +#define MACH_TYPE_WANDBOARD_IMX6 4412 +#define MACH_TYPE_OMAP4_JET 4413 +#define MACH_TYPE_TEGRA_ROTH 4414 +#define MACH_TYPE_M7DCG 4415 +#define MACH_TYPE_M7DUG 4416 +#define MACH_TYPE_M7DTG 4417 +#define MACH_TYPE_AP42X 4418 +#define MACH_TYPE_VAR_SOM_MX6 4419 +#define MACH_TYPE_PDLU 4420 +#define MACH_TYPE_HYDROGEN 4421 +#define MACH_TYPE_NPA211E 4422 +#define MACH_TYPE_ARCADIA 4423 +#define MACH_TYPE_ARCADIA_L 4424 +#define MACH_TYPE_MSM8930DT 4425 +#define MACH_TYPE_KTAM3874 4426 +#define MACH_TYPE_CEC4 4427 +#define MACH_TYPE_APE6EVM 4428 +#define MACH_TYPE_TX6 4429 +#define MACH_TYPE_CFA10037 4431 +#define MACH_TYPE_EZP1000 4433 +#define MACH_TYPE_WGR826V 4434 +#define MACH_TYPE_EXUMA 4435 +#define MACH_TYPE_FREGATE 4436 +#define MACH_TYPE_OSIRISIMX508 4437 +#define MACH_TYPE_ST_EXIGO 4438 +#define MACH_TYPE_PISMO 4439 +#define MACH_TYPE_ATC7 4440 +#define MACH_TYPE_NSPIRECLP 4441 +#define MACH_TYPE_NSPIRETP 4442 +#define MACH_TYPE_NSPIRECX 4443 +#define MACH_TYPE_MAYA 4444 +#define MACH_TYPE_WECCT 4445 +#define MACH_TYPE_M2S 4446 +#define MACH_TYPE_MSM8625Q_EVBD 4447 +#define MACH_TYPE_TINY210 4448 +#define MACH_TYPE_G3 4449 +#define MACH_TYPE_HURRICANE 4450 +#define MACH_TYPE_MX6_POD 4451 +#define MACH_TYPE_ELONDCN 4452 +#define MACH_TYPE_CWMX535 4453 +#define MACH_TYPE_M7_WLJ 4454 +#define MACH_TYPE_QSP_ARM 4455 +#define MACH_TYPE_MSM8625Q_SKUD 4456 +#define MACH_TYPE_HTCMONDRIAN 4457 +#define MACH_TYPE_WATSON_EAD 4458 +#define MACH_TYPE_MITWOA 4459 +#define MACH_TYPE_OMAP3_WOLVERINE 4460 +#define MACH_TYPE_MAPLETREE 4461 +#define MACH_TYPE_MSM8625_FIH_SAE 4462 +#define MACH_TYPE_EPC35 4463 +#define MACH_TYPE_SMARTRTU 4464 +#define MACH_TYPE_RCM101 4465 +#define MACH_TYPE_AMX_IMX53_MXX 4466 +#define MACH_TYPE_ACER_A12 4470 +#define MACH_TYPE_SBC6X 4471 +#define MACH_TYPE_U2 4472 +#define MACH_TYPE_SMDK4270 4473 +#define MACH_TYPE_PRISCILLAG 4474 +#define MACH_TYPE_PRISCILLAC 4475 +#define MACH_TYPE_PRISCILLA 4476 +#define MACH_TYPE_INNOVA_SHPU_V2 4477 +#define MACH_TYPE_MACH_TYPE_DEP2410 4479 +#define MACH_TYPE_BCTRE3 4480 +#define MACH_TYPE_OMAP_M100 4481 +#define MACH_TYPE_FLO 4482 +#define MACH_TYPE_NANOBONE 4483 +#define MACH_TYPE_STM_B2105 4484 +#define MACH_TYPE_OMAP4_BSC_BAP_V3 4485 +#define MACH_TYPE_SS1PAM 4486 +#define MACH_TYPE_PRIMOMINIU 4488 +#define MACH_TYPE_MRT_35HD_DUALNAS_E 4489 +#define MACH_TYPE_KIWI 4490 +#define MACH_TYPE_HW90496 4491 +#define MACH_TYPE_MEP2440 4492 #define MACH_TYPE_COLIBRI_T30 4493 +#define MACH_TYPE_CWV1 4494 +#define MACH_TYPE_NSA325 4495 +#define MACH_TYPE_DPXMTC 4497 +#define MACH_TYPE_TT_STUTTGART 4498 +#define MACH_TYPE_MIRANDA_APCII 4499 +#define MACH_TYPE_MX6Q_MODEROX 4500 +#define MACH_TYPE_MUDSKIPPER 4501 +#define MACH_TYPE_URANIA 4502 +#define MACH_TYPE_STM_B2112 4503 +#define MACH_TYPE_MX6Q_ATS_PHOENIX 4505 +#define MACH_TYPE_STM_B2116 4506 +#define MACH_TYPE_MYTHOLOGY 4507 +#define MACH_TYPE_FC360V1 4508 +#define MACH_TYPE_GPS_SENSOR 4509 +#define MACH_TYPE_GAZELLE 4510 +#define MACH_TYPE_MPQ8064_DMA 4511 +#define MACH_TYPE_WEMS_ASD01 4512 #define MACH_TYPE_APALIS_T30 4513 -#define MACH_TYPE_OMAPL138_LCDK 2495
-#ifdef CONFIG_ARCH_EBSA110 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_EBSA110 -# endif -# define machine_is_ebsa110() (machine_arch_type == MACH_TYPE_EBSA110) -#else -# define machine_is_ebsa110() (0) -#endif
-#ifdef CONFIG_ARCH_RPC -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_RISCPC -# endif -# define machine_is_riscpc() (machine_arch_type == MACH_TYPE_RISCPC) -#else -# define machine_is_riscpc() (0) -#endif
-#ifdef CONFIG_ARCH_EBSA285 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_EBSA285 -# endif -# define machine_is_ebsa285() (machine_arch_type == MACH_TYPE_EBSA285) -#else -# define machine_is_ebsa285() (0) -#endif
-#ifdef CONFIG_ARCH_NETWINDER -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NETWINDER -# endif -# define machine_is_netwinder() (machine_arch_type == MACH_TYPE_NETWINDER) -#else -# define machine_is_netwinder() (0) -#endif
-#ifdef CONFIG_ARCH_CATS -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CATS -# endif -# define machine_is_cats() (machine_arch_type == MACH_TYPE_CATS) -#else -# define machine_is_cats() (0) -#endif
-#ifdef CONFIG_ARCH_SHARK -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SHARK -# endif -# define machine_is_shark() (machine_arch_type == MACH_TYPE_SHARK) -#else -# define machine_is_shark() (0) -#endif
-#ifdef CONFIG_SA1100_BRUTUS -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_BRUTUS -# endif -# define machine_is_brutus() (machine_arch_type == MACH_TYPE_BRUTUS) -#else -# define machine_is_brutus() (0) -#endif
-#ifdef CONFIG_ARCH_PERSONAL_SERVER -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_PERSONAL_SERVER -# endif -# define machine_is_personal_server() (machine_arch_type == MACH_TYPE_PERSONAL_SERVER) -#else -# define machine_is_personal_server() (0) -#endif
-#ifdef CONFIG_ARCH_L7200 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_L7200 -# endif -# define machine_is_l7200() (machine_arch_type == MACH_TYPE_L7200) -#else -# define machine_is_l7200() (0) -#endif
-#ifdef CONFIG_SA1100_PLEB -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_PLEB -# endif -# define machine_is_pleb() (machine_arch_type == MACH_TYPE_PLEB) -#else -# define machine_is_pleb() (0) -#endif
-#ifdef CONFIG_ARCH_INTEGRATOR -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_INTEGRATOR -# endif -# define machine_is_integrator() (machine_arch_type == MACH_TYPE_INTEGRATOR) -#else -# define machine_is_integrator() (0) -#endif
-#ifdef CONFIG_SA1100_H3600 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_H3600 -# endif -# define machine_is_h3600() (machine_arch_type == MACH_TYPE_H3600) -#else -# define machine_is_h3600() (0) -#endif
-#ifdef CONFIG_ARCH_P720T -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_P720T -# endif -# define machine_is_p720t() (machine_arch_type == MACH_TYPE_P720T) -#else -# define machine_is_p720t() (0) -#endif
-#ifdef CONFIG_SA1100_ASSABET -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ASSABET -# endif -# define machine_is_assabet() (machine_arch_type == MACH_TYPE_ASSABET) -#else -# define machine_is_assabet() (0) -#endif
-#ifdef CONFIG_SA1100_LART -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_LART -# endif -# define machine_is_lart() (machine_arch_type == MACH_TYPE_LART) -#else -# define machine_is_lart() (0) -#endif
-#ifdef CONFIG_SA1100_GRAPHICSCLIENT -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_GRAPHICSCLIENT -# endif -# define machine_is_graphicsclient() (machine_arch_type == MACH_TYPE_GRAPHICSCLIENT) -#else -# define machine_is_graphicsclient() (0) -#endif
-#ifdef CONFIG_SA1100_XP860 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_XP860 -# endif -# define machine_is_xp860() (machine_arch_type == MACH_TYPE_XP860) -#else -# define machine_is_xp860() (0) -#endif
-#ifdef CONFIG_SA1100_CERF -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CERF -# endif -# define machine_is_cerf() (machine_arch_type == MACH_TYPE_CERF) -#else -# define machine_is_cerf() (0) -#endif
-#ifdef CONFIG_SA1100_NANOENGINE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NANOENGINE -# endif -# define machine_is_nanoengine() (machine_arch_type == MACH_TYPE_NANOENGINE) -#else -# define machine_is_nanoengine() (0) -#endif
-#ifdef CONFIG_SA1100_JORNADA720 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_JORNADA720 -# endif -# define machine_is_jornada720() (machine_arch_type == MACH_TYPE_JORNADA720) -#else -# define machine_is_jornada720() (0) -#endif
-#ifdef CONFIG_ARCH_EDB7211 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_EDB7211 -# endif -# define machine_is_edb7211() (machine_arch_type == MACH_TYPE_EDB7211) -#else -# define machine_is_edb7211() (0) -#endif
-#ifdef CONFIG_SA1100_PFS168 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_PFS168 -# endif -# define machine_is_pfs168() (machine_arch_type == MACH_TYPE_PFS168) -#else -# define machine_is_pfs168() (0) -#endif
-#ifdef CONFIG_SA1100_FLEXANET -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_FLEXANET -# endif -# define machine_is_flexanet() (machine_arch_type == MACH_TYPE_FLEXANET) -#else -# define machine_is_flexanet() (0) -#endif
-#ifdef CONFIG_SA1100_SIMPAD -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SIMPAD -# endif -# define machine_is_simpad() (machine_arch_type == MACH_TYPE_SIMPAD) -#else -# define machine_is_simpad() (0) -#endif
-#ifdef CONFIG_ARCH_LUBBOCK -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_LUBBOCK -# endif -# define machine_is_lubbock() (machine_arch_type == MACH_TYPE_LUBBOCK) -#else -# define machine_is_lubbock() (0) -#endif
-#ifdef CONFIG_ARCH_CLEP7212 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CLEP7212 -# endif -# define machine_is_clep7212() (machine_arch_type == MACH_TYPE_CLEP7212) -#else -# define machine_is_clep7212() (0) -#endif
-#ifdef CONFIG_SA1100_SHANNON -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SHANNON -# endif -# define machine_is_shannon() (machine_arch_type == MACH_TYPE_SHANNON) -#else -# define machine_is_shannon() (0) -#endif
-#ifdef CONFIG_SA1100_CONSUS -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CONSUS -# endif -# define machine_is_consus() (machine_arch_type == MACH_TYPE_CONSUS) -#else -# define machine_is_consus() (0) -#endif
-#ifdef CONFIG_ARCH_AAED2000 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_AAED2000 -# endif -# define machine_is_aaed2000() (machine_arch_type == MACH_TYPE_AAED2000) -#else -# define machine_is_aaed2000() (0) -#endif
-#ifdef CONFIG_ARCH_CDB89712 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CDB89712 -# endif -# define machine_is_cdb89712() (machine_arch_type == MACH_TYPE_CDB89712) -#else -# define machine_is_cdb89712() (0) -#endif
-#ifdef CONFIG_SA1100_GRAPHICSMASTER -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_GRAPHICSMASTER -# endif -# define machine_is_graphicsmaster() (machine_arch_type == MACH_TYPE_GRAPHICSMASTER) -#else -# define machine_is_graphicsmaster() (0) -#endif
-#ifdef CONFIG_SA1100_ADSBITSY -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ADSBITSY -# endif -# define machine_is_adsbitsy() (machine_arch_type == MACH_TYPE_ADSBITSY) -#else -# define machine_is_adsbitsy() (0) -#endif
-#ifdef CONFIG_ARCH_PXA_IDP -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_PXA_IDP -# endif -# define machine_is_pxa_idp() (machine_arch_type == MACH_TYPE_PXA_IDP) -#else -# define machine_is_pxa_idp() (0) -#endif
-#ifdef CONFIG_SA1100_PT_SYSTEM3 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_PT_SYSTEM3 -# endif -# define machine_is_pt_system3() (machine_arch_type == MACH_TYPE_PT_SYSTEM3) -#else -# define machine_is_pt_system3() (0) -#endif
-#ifdef CONFIG_ARCH_AUTCPU12 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_AUTCPU12 -# endif -# define machine_is_autcpu12() (machine_arch_type == MACH_TYPE_AUTCPU12) -#else -# define machine_is_autcpu12() (0) -#endif
-#ifdef CONFIG_SA1100_H3100 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_H3100 -# endif -# define machine_is_h3100() (machine_arch_type == MACH_TYPE_H3100) -#else -# define machine_is_h3100() (0) -#endif
-#ifdef CONFIG_SA1100_COLLIE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_COLLIE -# endif -# define machine_is_collie() (machine_arch_type == MACH_TYPE_COLLIE) -#else -# define machine_is_collie() (0) -#endif
-#ifdef CONFIG_SA1100_BADGE4 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_BADGE4 -# endif -# define machine_is_badge4() (machine_arch_type == MACH_TYPE_BADGE4) -#else -# define machine_is_badge4() (0) -#endif
-#ifdef CONFIG_ARCH_FORTUNET -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_FORTUNET -# endif -# define machine_is_fortunet() (machine_arch_type == MACH_TYPE_FORTUNET) -#else -# define machine_is_fortunet() (0) -#endif
-#ifdef CONFIG_ARCH_MX1ADS -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MX1ADS -# endif -# define machine_is_mx1ads() (machine_arch_type == MACH_TYPE_MX1ADS) -#else -# define machine_is_mx1ads() (0) -#endif
-#ifdef CONFIG_ARCH_H7201 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_H7201 -# endif -# define machine_is_h7201() (machine_arch_type == MACH_TYPE_H7201) -#else -# define machine_is_h7201() (0) -#endif
-#ifdef CONFIG_ARCH_H7202 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_H7202 -# endif -# define machine_is_h7202() (machine_arch_type == MACH_TYPE_H7202) -#else -# define machine_is_h7202() (0) -#endif
-#ifdef CONFIG_ARCH_IQ80321 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_IQ80321 -# endif -# define machine_is_iq80321() (machine_arch_type == MACH_TYPE_IQ80321) -#else -# define machine_is_iq80321() (0) -#endif
-#ifdef CONFIG_ARCH_KS8695 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_KS8695 -# endif -# define machine_is_ks8695() (machine_arch_type == MACH_TYPE_KS8695) -#else -# define machine_is_ks8695() (0) -#endif
-#ifdef CONFIG_ARCH_SMDK2410 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SMDK2410 -# endif -# define machine_is_smdk2410() (machine_arch_type == MACH_TYPE_SMDK2410) -#else -# define machine_is_smdk2410() (0) -#endif
-#ifdef CONFIG_ARCH_CEIVA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CEIVA -# endif -# define machine_is_ceiva() (machine_arch_type == MACH_TYPE_CEIVA) -#else -# define machine_is_ceiva() (0) -#endif
-#ifdef CONFIG_MACH_VOICEBLUE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_VOICEBLUE -# endif -# define machine_is_voiceblue() (machine_arch_type == MACH_TYPE_VOICEBLUE) -#else -# define machine_is_voiceblue() (0) -#endif
-#ifdef CONFIG_ARCH_H5400 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_H5400 -# endif -# define machine_is_h5400() (machine_arch_type == MACH_TYPE_H5400) -#else -# define machine_is_h5400() (0) -#endif
-#ifdef CONFIG_MACH_OMAP_INNOVATOR -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OMAP_INNOVATOR -# endif -# define machine_is_omap_innovator() (machine_arch_type == MACH_TYPE_OMAP_INNOVATOR) -#else -# define machine_is_omap_innovator() (0) -#endif
-#ifdef CONFIG_ARCH_IXDP2400 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_IXDP2400 -# endif -# define machine_is_ixdp2400() (machine_arch_type == MACH_TYPE_IXDP2400) -#else -# define machine_is_ixdp2400() (0) -#endif
-#ifdef CONFIG_ARCH_IXDP2800 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_IXDP2800 -# endif -# define machine_is_ixdp2800() (machine_arch_type == MACH_TYPE_IXDP2800) -#else -# define machine_is_ixdp2800() (0) -#endif
-#ifdef CONFIG_ARCH_IXDP425 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_IXDP425 -# endif -# define machine_is_ixdp425() (machine_arch_type == MACH_TYPE_IXDP425) -#else -# define machine_is_ixdp425() (0) -#endif
-#ifdef CONFIG_SA1100_HACKKIT -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_HACKKIT -# endif -# define machine_is_hackkit() (machine_arch_type == MACH_TYPE_HACKKIT) -#else -# define machine_is_hackkit() (0) -#endif
-#ifdef CONFIG_ARCH_IXCDP1100 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_IXCDP1100 -# endif -# define machine_is_ixcdp1100() (machine_arch_type == MACH_TYPE_IXCDP1100) -#else -# define machine_is_ixcdp1100() (0) -#endif
-#ifdef CONFIG_ARCH_AT91RM9200DK -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_AT91RM9200DK -# endif -# define machine_is_at91rm9200dk() (machine_arch_type == MACH_TYPE_AT91RM9200DK) -#else -# define machine_is_at91rm9200dk() (0) -#endif
-#ifdef CONFIG_ARCH_CINTEGRATOR -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CINTEGRATOR -# endif -# define machine_is_cintegrator() (machine_arch_type == MACH_TYPE_CINTEGRATOR) -#else -# define machine_is_cintegrator() (0) -#endif
-#ifdef CONFIG_ARCH_VIPER -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_VIPER -# endif -# define machine_is_viper() (machine_arch_type == MACH_TYPE_VIPER) -#else -# define machine_is_viper() (0) -#endif
-#ifdef CONFIG_ARCH_ADI_COYOTE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ADI_COYOTE -# endif -# define machine_is_adi_coyote() (machine_arch_type == MACH_TYPE_ADI_COYOTE) -#else -# define machine_is_adi_coyote() (0) -#endif
-#ifdef CONFIG_ARCH_IXDP2401 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_IXDP2401 -# endif -# define machine_is_ixdp2401() (machine_arch_type == MACH_TYPE_IXDP2401) -#else -# define machine_is_ixdp2401() (0) -#endif
-#ifdef CONFIG_ARCH_IXDP2801 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_IXDP2801 -# endif -# define machine_is_ixdp2801() (machine_arch_type == MACH_TYPE_IXDP2801) -#else -# define machine_is_ixdp2801() (0) -#endif
-#ifdef CONFIG_ARCH_IQ31244 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_IQ31244 -# endif -# define machine_is_iq31244() (machine_arch_type == MACH_TYPE_IQ31244) -#else -# define machine_is_iq31244() (0) -#endif
-#ifdef CONFIG_ARCH_BAST -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_BAST -# endif -# define machine_is_bast() (machine_arch_type == MACH_TYPE_BAST) -#else -# define machine_is_bast() (0) -#endif
-#ifdef CONFIG_ARCH_H1940 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_H1940 -# endif -# define machine_is_h1940() (machine_arch_type == MACH_TYPE_H1940) -#else -# define machine_is_h1940() (0) -#endif
-#ifdef CONFIG_ARCH_ENP2611 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ENP2611 -# endif -# define machine_is_enp2611() (machine_arch_type == MACH_TYPE_ENP2611) -#else -# define machine_is_enp2611() (0) -#endif
-#ifdef CONFIG_ARCH_S3C2440 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_S3C2440 -# endif -# define machine_is_s3c2440() (machine_arch_type == MACH_TYPE_S3C2440) -#else -# define machine_is_s3c2440() (0) -#endif
-#ifdef CONFIG_ARCH_GUMSTIX -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_GUMSTIX -# endif -# define machine_is_gumstix() (machine_arch_type == MACH_TYPE_GUMSTIX) -#else -# define machine_is_gumstix() (0) -#endif
-#ifdef CONFIG_MACH_OMAP_H2 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OMAP_H2 -# endif -# define machine_is_omap_h2() (machine_arch_type == MACH_TYPE_OMAP_H2) -#else -# define machine_is_omap_h2() (0) -#endif
-#ifdef CONFIG_MACH_E740 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_E740 -# endif -# define machine_is_e740() (machine_arch_type == MACH_TYPE_E740) -#else -# define machine_is_e740() (0) -#endif
-#ifdef CONFIG_ARCH_IQ80331 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_IQ80331 -# endif -# define machine_is_iq80331() (machine_arch_type == MACH_TYPE_IQ80331) -#else -# define machine_is_iq80331() (0) -#endif
-#ifdef CONFIG_ARCH_VERSATILE_PB -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_VERSATILE_PB -# endif -# define machine_is_versatile_pb() (machine_arch_type == MACH_TYPE_VERSATILE_PB) -#else -# define machine_is_versatile_pb() (0) -#endif
-#ifdef CONFIG_MACH_KEV7A400 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_KEV7A400 -# endif -# define machine_is_kev7a400() (machine_arch_type == MACH_TYPE_KEV7A400) -#else -# define machine_is_kev7a400() (0) -#endif
-#ifdef CONFIG_MACH_LPD7A400 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_LPD7A400 -# endif -# define machine_is_lpd7a400() (machine_arch_type == MACH_TYPE_LPD7A400) -#else -# define machine_is_lpd7a400() (0) -#endif
-#ifdef CONFIG_MACH_LPD7A404 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_LPD7A404 -# endif -# define machine_is_lpd7a404() (machine_arch_type == MACH_TYPE_LPD7A404) -#else -# define machine_is_lpd7a404() (0) -#endif
-#ifdef CONFIG_MACH_CSB337 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CSB337 -# endif -# define machine_is_csb337() (machine_arch_type == MACH_TYPE_CSB337) -#else -# define machine_is_csb337() (0) -#endif
-#ifdef CONFIG_MACH_MAINSTONE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MAINSTONE -# endif -# define machine_is_mainstone() (machine_arch_type == MACH_TYPE_MAINSTONE) -#else -# define machine_is_mainstone() (0) -#endif
-#ifdef CONFIG_MACH_XCEP -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_XCEP -# endif -# define machine_is_xcep() (machine_arch_type == MACH_TYPE_XCEP) -#else -# define machine_is_xcep() (0) -#endif
-#ifdef CONFIG_MACH_ARCOM_VULCAN -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ARCOM_VULCAN -# endif -# define machine_is_arcom_vulcan() (machine_arch_type == MACH_TYPE_ARCOM_VULCAN) -#else -# define machine_is_arcom_vulcan() (0) -#endif
-#ifdef CONFIG_MACH_NOMADIK -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NOMADIK -# endif -# define machine_is_nomadik() (machine_arch_type == MACH_TYPE_NOMADIK) -#else -# define machine_is_nomadik() (0) -#endif
-#ifdef CONFIG_MACH_CORGI -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CORGI -# endif -# define machine_is_corgi() (machine_arch_type == MACH_TYPE_CORGI) -#else -# define machine_is_corgi() (0) -#endif
-#ifdef CONFIG_MACH_POODLE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_POODLE -# endif -# define machine_is_poodle() (machine_arch_type == MACH_TYPE_POODLE) -#else -# define machine_is_poodle() (0) -#endif
-#ifdef CONFIG_MACH_ARMCORE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ARMCORE -# endif -# define machine_is_armcore() (machine_arch_type == MACH_TYPE_ARMCORE) -#else -# define machine_is_armcore() (0) -#endif
-#ifdef CONFIG_MACH_MX31ADS -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MX31ADS -# endif -# define machine_is_mx31ads() (machine_arch_type == MACH_TYPE_MX31ADS) -#else -# define machine_is_mx31ads() (0) -#endif
-#ifdef CONFIG_MACH_HIMALAYA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_HIMALAYA -# endif -# define machine_is_himalaya() (machine_arch_type == MACH_TYPE_HIMALAYA) -#else -# define machine_is_himalaya() (0) -#endif
-#ifdef CONFIG_MACH_EDB9312 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_EDB9312 -# endif -# define machine_is_edb9312() (machine_arch_type == MACH_TYPE_EDB9312) -#else -# define machine_is_edb9312() (0) -#endif
-#ifdef CONFIG_MACH_OMAP_GENERIC -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OMAP_GENERIC -# endif -# define machine_is_omap_generic() (machine_arch_type == MACH_TYPE_OMAP_GENERIC) -#else -# define machine_is_omap_generic() (0) -#endif
-#ifdef CONFIG_MACH_EDB9301 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_EDB9301 -# endif -# define machine_is_edb9301() (machine_arch_type == MACH_TYPE_EDB9301) -#else -# define machine_is_edb9301() (0) -#endif
-#ifdef CONFIG_MACH_EDB9315 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_EDB9315 -# endif -# define machine_is_edb9315() (machine_arch_type == MACH_TYPE_EDB9315) -#else -# define machine_is_edb9315() (0) -#endif
-#ifdef CONFIG_MACH_VR1000 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_VR1000 -# endif -# define machine_is_vr1000() (machine_arch_type == MACH_TYPE_VR1000) -#else -# define machine_is_vr1000() (0) -#endif
-#ifdef CONFIG_MACH_OMAP_PERSEUS2 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OMAP_PERSEUS2 -# endif -# define machine_is_omap_perseus2() (machine_arch_type == MACH_TYPE_OMAP_PERSEUS2) -#else -# define machine_is_omap_perseus2() (0) -#endif
-#ifdef CONFIG_MACH_E800 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_E800 -# endif -# define machine_is_e800() (machine_arch_type == MACH_TYPE_E800) -#else -# define machine_is_e800() (0) -#endif
-#ifdef CONFIG_MACH_E750 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_E750 -# endif -# define machine_is_e750() (machine_arch_type == MACH_TYPE_E750) -#else -# define machine_is_e750() (0) -#endif
-#ifdef CONFIG_MACH_SCB9328 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SCB9328 -# endif -# define machine_is_scb9328() (machine_arch_type == MACH_TYPE_SCB9328) -#else -# define machine_is_scb9328() (0) -#endif
-#ifdef CONFIG_MACH_OMAP_H3 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OMAP_H3 -# endif -# define machine_is_omap_h3() (machine_arch_type == MACH_TYPE_OMAP_H3) -#else -# define machine_is_omap_h3() (0) -#endif
-#ifdef CONFIG_MACH_OMAP_H4 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OMAP_H4 -# endif -# define machine_is_omap_h4() (machine_arch_type == MACH_TYPE_OMAP_H4) -#else -# define machine_is_omap_h4() (0) -#endif
-#ifdef CONFIG_MACH_OMAP_OSK -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OMAP_OSK -# endif -# define machine_is_omap_osk() (machine_arch_type == MACH_TYPE_OMAP_OSK) -#else -# define machine_is_omap_osk() (0) -#endif
-#ifdef CONFIG_MACH_TOSA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TOSA -# endif -# define machine_is_tosa() (machine_arch_type == MACH_TYPE_TOSA) -#else -# define machine_is_tosa() (0) -#endif
-#ifdef CONFIG_MACH_AVILA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_AVILA -# endif -# define machine_is_avila() (machine_arch_type == MACH_TYPE_AVILA) -#else -# define machine_is_avila() (0) -#endif
-#ifdef CONFIG_MACH_EDB9302 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_EDB9302 -# endif -# define machine_is_edb9302() (machine_arch_type == MACH_TYPE_EDB9302) -#else -# define machine_is_edb9302() (0) -#endif
-#ifdef CONFIG_MACH_HUSKY -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_HUSKY -# endif -# define machine_is_husky() (machine_arch_type == MACH_TYPE_HUSKY) -#else -# define machine_is_husky() (0) -#endif
-#ifdef CONFIG_MACH_SHEPHERD -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SHEPHERD -# endif -# define machine_is_shepherd() (machine_arch_type == MACH_TYPE_SHEPHERD) -#else -# define machine_is_shepherd() (0) -#endif
-#ifdef CONFIG_MACH_H4700 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_H4700 -# endif -# define machine_is_h4700() (machine_arch_type == MACH_TYPE_H4700) -#else -# define machine_is_h4700() (0) -#endif
-#ifdef CONFIG_MACH_RX3715 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_RX3715 -# endif -# define machine_is_rx3715() (machine_arch_type == MACH_TYPE_RX3715) -#else -# define machine_is_rx3715() (0) -#endif
-#ifdef CONFIG_MACH_NSLU2 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NSLU2 -# endif -# define machine_is_nslu2() (machine_arch_type == MACH_TYPE_NSLU2) -#else -# define machine_is_nslu2() (0) -#endif
-#ifdef CONFIG_MACH_E400 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_E400 -# endif -# define machine_is_e400() (machine_arch_type == MACH_TYPE_E400) -#else -# define machine_is_e400() (0) -#endif
-#ifdef CONFIG_MACH_IXDPG425 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_IXDPG425 -# endif -# define machine_is_ixdpg425() (machine_arch_type == MACH_TYPE_IXDPG425) -#else -# define machine_is_ixdpg425() (0) -#endif
-#ifdef CONFIG_MACH_VERSATILE_AB -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_VERSATILE_AB -# endif -# define machine_is_versatile_ab() (machine_arch_type == MACH_TYPE_VERSATILE_AB) -#else -# define machine_is_versatile_ab() (0) -#endif
-#ifdef CONFIG_MACH_EDB9307 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_EDB9307 -# endif -# define machine_is_edb9307() (machine_arch_type == MACH_TYPE_EDB9307) -#else -# define machine_is_edb9307() (0) -#endif
-#ifdef CONFIG_MACH_KB9200 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_KB9200 -# endif -# define machine_is_kb9200() (machine_arch_type == MACH_TYPE_KB9200) -#else -# define machine_is_kb9200() (0) -#endif
-#ifdef CONFIG_MACH_SX1 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SX1 -# endif -# define machine_is_sx1() (machine_arch_type == MACH_TYPE_SX1) -#else -# define machine_is_sx1() (0) -#endif
-#ifdef CONFIG_MACH_IXDP465 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_IXDP465 -# endif -# define machine_is_ixdp465() (machine_arch_type == MACH_TYPE_IXDP465) -#else -# define machine_is_ixdp465() (0) -#endif
-#ifdef CONFIG_MACH_IXDP2351 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_IXDP2351 -# endif -# define machine_is_ixdp2351() (machine_arch_type == MACH_TYPE_IXDP2351) -#else -# define machine_is_ixdp2351() (0) -#endif
-#ifdef CONFIG_MACH_IQ80332 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_IQ80332 -# endif -# define machine_is_iq80332() (machine_arch_type == MACH_TYPE_IQ80332) -#else -# define machine_is_iq80332() (0) -#endif
-#ifdef CONFIG_MACH_GTWX5715 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_GTWX5715 -# endif -# define machine_is_gtwx5715() (machine_arch_type == MACH_TYPE_GTWX5715) -#else -# define machine_is_gtwx5715() (0) -#endif
-#ifdef CONFIG_MACH_CSB637 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CSB637 -# endif -# define machine_is_csb637() (machine_arch_type == MACH_TYPE_CSB637) -#else -# define machine_is_csb637() (0) -#endif
-#ifdef CONFIG_MACH_N30 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_N30 -# endif -# define machine_is_n30() (machine_arch_type == MACH_TYPE_N30) -#else -# define machine_is_n30() (0) -#endif
-#ifdef CONFIG_MACH_NEC_MP900 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NEC_MP900 -# endif -# define machine_is_nec_mp900() (machine_arch_type == MACH_TYPE_NEC_MP900) -#else -# define machine_is_nec_mp900() (0) -#endif
-#ifdef CONFIG_MACH_KAFA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_KAFA -# endif -# define machine_is_kafa() (machine_arch_type == MACH_TYPE_KAFA) -#else -# define machine_is_kafa() (0) -#endif
-#ifdef CONFIG_MACH_TS72XX -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TS72XX -# endif -# define machine_is_ts72xx() (machine_arch_type == MACH_TYPE_TS72XX) -#else -# define machine_is_ts72xx() (0) -#endif
-#ifdef CONFIG_MACH_OTOM -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OTOM -# endif -# define machine_is_otom() (machine_arch_type == MACH_TYPE_OTOM) -#else -# define machine_is_otom() (0) -#endif
-#ifdef CONFIG_MACH_NEXCODER_2440 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NEXCODER_2440 -# endif -# define machine_is_nexcoder_2440() (machine_arch_type == MACH_TYPE_NEXCODER_2440) -#else -# define machine_is_nexcoder_2440() (0) -#endif
-#ifdef CONFIG_MACH_ECO920 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ECO920 -# endif -# define machine_is_eco920() (machine_arch_type == MACH_TYPE_ECO920) -#else -# define machine_is_eco920() (0) -#endif
-#ifdef CONFIG_MACH_ROADRUNNER -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ROADRUNNER -# endif -# define machine_is_roadrunner() (machine_arch_type == MACH_TYPE_ROADRUNNER) -#else -# define machine_is_roadrunner() (0) -#endif
-#ifdef CONFIG_MACH_AT91RM9200EK -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_AT91RM9200EK -# endif -# define machine_is_at91rm9200ek() (machine_arch_type == MACH_TYPE_AT91RM9200EK) -#else -# define machine_is_at91rm9200ek() (0) -#endif
-#ifdef CONFIG_MACH_SPITZ -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SPITZ -# endif -# define machine_is_spitz() (machine_arch_type == MACH_TYPE_SPITZ) -#else -# define machine_is_spitz() (0) -#endif
-#ifdef CONFIG_MACH_ADSSPHERE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ADSSPHERE -# endif -# define machine_is_adssphere() (machine_arch_type == MACH_TYPE_ADSSPHERE) -#else -# define machine_is_adssphere() (0) -#endif
-#ifdef CONFIG_MACH_COLIBRI -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_COLIBRI -# endif -# define machine_is_colibri() (machine_arch_type == MACH_TYPE_COLIBRI) -#else -# define machine_is_colibri() (0) -#endif
-#ifdef CONFIG_MACH_GATEWAY7001 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_GATEWAY7001 -# endif -# define machine_is_gateway7001() (machine_arch_type == MACH_TYPE_GATEWAY7001) -#else -# define machine_is_gateway7001() (0) -#endif
-#ifdef CONFIG_MACH_PCM027 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_PCM027 -# endif -# define machine_is_pcm027() (machine_arch_type == MACH_TYPE_PCM027) -#else -# define machine_is_pcm027() (0) -#endif
-#ifdef CONFIG_MACH_ANUBIS -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ANUBIS -# endif -# define machine_is_anubis() (machine_arch_type == MACH_TYPE_ANUBIS) -#else -# define machine_is_anubis() (0) -#endif
-#ifdef CONFIG_MACH_AKITA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_AKITA -# endif -# define machine_is_akita() (machine_arch_type == MACH_TYPE_AKITA) -#else -# define machine_is_akita() (0) -#endif
-#ifdef CONFIG_MACH_E330 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_E330 -# endif -# define machine_is_e330() (machine_arch_type == MACH_TYPE_E330) -#else -# define machine_is_e330() (0) -#endif
-#ifdef CONFIG_MACH_NOKIA770 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NOKIA770 -# endif -# define machine_is_nokia770() (machine_arch_type == MACH_TYPE_NOKIA770) -#else -# define machine_is_nokia770() (0) -#endif
-#ifdef CONFIG_MACH_CARMEVA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CARMEVA -# endif -# define machine_is_carmeva() (machine_arch_type == MACH_TYPE_CARMEVA) -#else -# define machine_is_carmeva() (0) -#endif
-#ifdef CONFIG_MACH_EDB9315A -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_EDB9315A -# endif -# define machine_is_edb9315a() (machine_arch_type == MACH_TYPE_EDB9315A) -#else -# define machine_is_edb9315a() (0) -#endif
-#ifdef CONFIG_MACH_STARGATE2 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_STARGATE2 -# endif -# define machine_is_stargate2() (machine_arch_type == MACH_TYPE_STARGATE2) -#else -# define machine_is_stargate2() (0) -#endif
-#ifdef CONFIG_MACH_INTELMOTE2 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_INTELMOTE2 -# endif -# define machine_is_intelmote2() (machine_arch_type == MACH_TYPE_INTELMOTE2) -#else -# define machine_is_intelmote2() (0) -#endif
-#ifdef CONFIG_MACH_TRIZEPS4 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TRIZEPS4 -# endif -# define machine_is_trizeps4() (machine_arch_type == MACH_TYPE_TRIZEPS4) -#else -# define machine_is_trizeps4() (0) -#endif
-#ifdef CONFIG_MACH_PNX4008 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_PNX4008 -# endif -# define machine_is_pnx4008() (machine_arch_type == MACH_TYPE_PNX4008) -#else -# define machine_is_pnx4008() (0) -#endif
-#ifdef CONFIG_MACH_IQ81340SC -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_IQ81340SC -# endif -# define machine_is_iq81340sc() (machine_arch_type == MACH_TYPE_IQ81340SC) -#else -# define machine_is_iq81340sc() (0) -#endif
-#ifdef CONFIG_MACH_IQ81340MC -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_IQ81340MC -# endif -# define machine_is_iq81340mc() (machine_arch_type == MACH_TYPE_IQ81340MC) -#else -# define machine_is_iq81340mc() (0) -#endif
-#ifdef CONFIG_MACH_MICRO9 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MICRO9 -# endif -# define machine_is_micro9() (machine_arch_type == MACH_TYPE_MICRO9) -#else -# define machine_is_micro9() (0) -#endif
-#ifdef CONFIG_MACH_MICRO9L -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MICRO9L -# endif -# define machine_is_micro9l() (machine_arch_type == MACH_TYPE_MICRO9L) -#else -# define machine_is_micro9l() (0) -#endif
-#ifdef CONFIG_MACH_OMAP_PALMTE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OMAP_PALMTE -# endif -# define machine_is_omap_palmte() (machine_arch_type == MACH_TYPE_OMAP_PALMTE) -#else -# define machine_is_omap_palmte() (0) -#endif
-#ifdef CONFIG_MACH_REALVIEW_EB -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_REALVIEW_EB -# endif -# define machine_is_realview_eb() (machine_arch_type == MACH_TYPE_REALVIEW_EB) -#else -# define machine_is_realview_eb() (0) -#endif
-#ifdef CONFIG_MACH_BORZOI -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_BORZOI -# endif -# define machine_is_borzoi() (machine_arch_type == MACH_TYPE_BORZOI) -#else -# define machine_is_borzoi() (0) -#endif
-#ifdef CONFIG_MACH_PALMLD -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_PALMLD -# endif -# define machine_is_palmld() (machine_arch_type == MACH_TYPE_PALMLD) -#else -# define machine_is_palmld() (0) -#endif
-#ifdef CONFIG_MACH_IXDP28X5 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_IXDP28X5 -# endif -# define machine_is_ixdp28x5() (machine_arch_type == MACH_TYPE_IXDP28X5) -#else -# define machine_is_ixdp28x5() (0) -#endif
-#ifdef CONFIG_MACH_OMAP_PALMTT -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OMAP_PALMTT -# endif -# define machine_is_omap_palmtt() (machine_arch_type == MACH_TYPE_OMAP_PALMTT) -#else -# define machine_is_omap_palmtt() (0) -#endif
-#ifdef CONFIG_MACH_ARCOM_ZEUS -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ARCOM_ZEUS -# endif -# define machine_is_arcom_zeus() (machine_arch_type == MACH_TYPE_ARCOM_ZEUS) -#else -# define machine_is_arcom_zeus() (0) -#endif
-#ifdef CONFIG_MACH_OSIRIS -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OSIRIS -# endif -# define machine_is_osiris() (machine_arch_type == MACH_TYPE_OSIRIS) -#else -# define machine_is_osiris() (0) -#endif
-#ifdef CONFIG_MACH_PALMTE2 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_PALMTE2 -# endif -# define machine_is_palmte2() (machine_arch_type == MACH_TYPE_PALMTE2) -#else -# define machine_is_palmte2() (0) -#endif
-#ifdef CONFIG_MACH_MX27ADS -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MX27ADS -# endif -# define machine_is_mx27ads() (machine_arch_type == MACH_TYPE_MX27ADS) -#else -# define machine_is_mx27ads() (0) -#endif
-#ifdef CONFIG_MACH_AT91SAM9261EK -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_AT91SAM9261EK -# endif -# define machine_is_at91sam9261ek() (machine_arch_type == MACH_TYPE_AT91SAM9261EK) -#else -# define machine_is_at91sam9261ek() (0) -#endif
-#ifdef CONFIG_MACH_LOFT -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_LOFT -# endif -# define machine_is_loft() (machine_arch_type == MACH_TYPE_LOFT) -#else -# define machine_is_loft() (0) -#endif
-#ifdef CONFIG_MACH_MX21ADS -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MX21ADS -# endif -# define machine_is_mx21ads() (machine_arch_type == MACH_TYPE_MX21ADS) -#else -# define machine_is_mx21ads() (0) -#endif
-#ifdef CONFIG_MACH_AMS_DELTA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_AMS_DELTA -# endif -# define machine_is_ams_delta() (machine_arch_type == MACH_TYPE_AMS_DELTA) -#else -# define machine_is_ams_delta() (0) -#endif
-#ifdef CONFIG_MACH_NAS100D -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NAS100D -# endif -# define machine_is_nas100d() (machine_arch_type == MACH_TYPE_NAS100D) -#else -# define machine_is_nas100d() (0) -#endif
-#ifdef CONFIG_MACH_MAGICIAN -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MAGICIAN -# endif -# define machine_is_magician() (machine_arch_type == MACH_TYPE_MAGICIAN) -#else -# define machine_is_magician() (0) -#endif
-#ifdef CONFIG_MACH_NXDKN -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NXDKN -# endif -# define machine_is_nxdkn() (machine_arch_type == MACH_TYPE_NXDKN) -#else -# define machine_is_nxdkn() (0) -#endif
-#ifdef CONFIG_MACH_PALMTX -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_PALMTX -# endif -# define machine_is_palmtx() (machine_arch_type == MACH_TYPE_PALMTX) -#else -# define machine_is_palmtx() (0) -#endif
-#ifdef CONFIG_MACH_S3C2413 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_S3C2413 -# endif -# define machine_is_s3c2413() (machine_arch_type == MACH_TYPE_S3C2413) -#else -# define machine_is_s3c2413() (0) -#endif
-#ifdef CONFIG_MACH_WG302V2 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_WG302V2 -# endif -# define machine_is_wg302v2() (machine_arch_type == MACH_TYPE_WG302V2) -#else -# define machine_is_wg302v2() (0) -#endif
-#ifdef CONFIG_MACH_OMAP_2430SDP -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OMAP_2430SDP -# endif -# define machine_is_omap_2430sdp() (machine_arch_type == MACH_TYPE_OMAP_2430SDP) -#else -# define machine_is_omap_2430sdp() (0) -#endif
-#ifdef CONFIG_MACH_DAVINCI_EVM -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DAVINCI_EVM -# endif -# define machine_is_davinci_evm() (machine_arch_type == MACH_TYPE_DAVINCI_EVM) -#else -# define machine_is_davinci_evm() (0) -#endif
-#ifdef CONFIG_MACH_PALMZ72 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_PALMZ72 -# endif -# define machine_is_palmz72() (machine_arch_type == MACH_TYPE_PALMZ72) -#else -# define machine_is_palmz72() (0) -#endif
-#ifdef CONFIG_MACH_NXDB500 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NXDB500 -# endif -# define machine_is_nxdb500() (machine_arch_type == MACH_TYPE_NXDB500) -#else -# define machine_is_nxdb500() (0) -#endif
-#ifdef CONFIG_MACH_PALMT5 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_PALMT5 -# endif -# define machine_is_palmt5() (machine_arch_type == MACH_TYPE_PALMT5) -#else -# define machine_is_palmt5() (0) -#endif
-#ifdef CONFIG_MACH_PALMTC -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_PALMTC -# endif -# define machine_is_palmtc() (machine_arch_type == MACH_TYPE_PALMTC) -#else -# define machine_is_palmtc() (0) -#endif
-#ifdef CONFIG_MACH_OMAP_APOLLON -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OMAP_APOLLON -# endif -# define machine_is_omap_apollon() (machine_arch_type == MACH_TYPE_OMAP_APOLLON) -#else -# define machine_is_omap_apollon() (0) -#endif
-#ifdef CONFIG_MACH_ATEB9200 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ATEB9200 -# endif -# define machine_is_ateb9200() (machine_arch_type == MACH_TYPE_ATEB9200) -#else -# define machine_is_ateb9200() (0) -#endif
-#ifdef CONFIG_MACH_N35 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_N35 -# endif -# define machine_is_n35() (machine_arch_type == MACH_TYPE_N35) -#else -# define machine_is_n35() (0) -#endif
-#ifdef CONFIG_MACH_LOGICPD_PXA270 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_LOGICPD_PXA270 -# endif -# define machine_is_logicpd_pxa270() (machine_arch_type == MACH_TYPE_LOGICPD_PXA270) -#else -# define machine_is_logicpd_pxa270() (0) -#endif
-#ifdef CONFIG_MACH_NXEB500HMI -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NXEB500HMI -# endif -# define machine_is_nxeb500hmi() (machine_arch_type == MACH_TYPE_NXEB500HMI) -#else -# define machine_is_nxeb500hmi() (0) -#endif
-#ifdef CONFIG_MACH_ESPRESSO -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ESPRESSO -# endif -# define machine_is_espresso() (machine_arch_type == MACH_TYPE_ESPRESSO) -#else -# define machine_is_espresso() (0) -#endif
-#ifdef CONFIG_MACH_RX1950 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_RX1950 -# endif -# define machine_is_rx1950() (machine_arch_type == MACH_TYPE_RX1950) -#else -# define machine_is_rx1950() (0) -#endif
-#ifdef CONFIG_MACH_GESBC9312 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_GESBC9312 -# endif -# define machine_is_gesbc9312() (machine_arch_type == MACH_TYPE_GESBC9312) -#else -# define machine_is_gesbc9312() (0) -#endif
-#ifdef CONFIG_MACH_PICOTUX2XX -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_PICOTUX2XX -# endif -# define machine_is_picotux2xx() (machine_arch_type == MACH_TYPE_PICOTUX2XX) -#else -# define machine_is_picotux2xx() (0) -#endif
-#ifdef CONFIG_MACH_DSMG600 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DSMG600 -# endif -# define machine_is_dsmg600() (machine_arch_type == MACH_TYPE_DSMG600) -#else -# define machine_is_dsmg600() (0) -#endif
-#ifdef CONFIG_MACH_OMAP_FSAMPLE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OMAP_FSAMPLE -# endif -# define machine_is_omap_fsample() (machine_arch_type == MACH_TYPE_OMAP_FSAMPLE) -#else -# define machine_is_omap_fsample() (0) -#endif
-#ifdef CONFIG_MACH_SNAPPER_CL15 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SNAPPER_CL15 -# endif -# define machine_is_snapper_cl15() (machine_arch_type == MACH_TYPE_SNAPPER_CL15) -#else -# define machine_is_snapper_cl15() (0) -#endif
-#ifdef CONFIG_MACH_OMAP_PALMZ71 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OMAP_PALMZ71 -# endif -# define machine_is_omap_palmz71() (machine_arch_type == MACH_TYPE_OMAP_PALMZ71) -#else -# define machine_is_omap_palmz71() (0) -#endif
-#ifdef CONFIG_MACH_SMDK2412 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SMDK2412 -# endif -# define machine_is_smdk2412() (machine_arch_type == MACH_TYPE_SMDK2412) -#else -# define machine_is_smdk2412() (0) -#endif
-#ifdef CONFIG_MACH_SMDK2413 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SMDK2413 -# endif -# define machine_is_smdk2413() (machine_arch_type == MACH_TYPE_SMDK2413) -#else -# define machine_is_smdk2413() (0) -#endif
-#ifdef CONFIG_MACH_AML_M5900 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_AML_M5900 -# endif -# define machine_is_aml_m5900() (machine_arch_type == MACH_TYPE_AML_M5900) -#else -# define machine_is_aml_m5900() (0) -#endif
-#ifdef CONFIG_MACH_ECBAT91 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ECBAT91 -# endif -# define machine_is_ecbat91() (machine_arch_type == MACH_TYPE_ECBAT91) -#else -# define machine_is_ecbat91() (0) -#endif
-#ifdef CONFIG_MACH_ONEARM -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ONEARM -# endif -# define machine_is_onearm() (machine_arch_type == MACH_TYPE_ONEARM) -#else -# define machine_is_onearm() (0) -#endif
-#ifdef CONFIG_MACH_SMDK2443 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SMDK2443 -# endif -# define machine_is_smdk2443() (machine_arch_type == MACH_TYPE_SMDK2443) -#else -# define machine_is_smdk2443() (0) -#endif
-#ifdef CONFIG_MACH_FSG -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_FSG -# endif -# define machine_is_fsg() (machine_arch_type == MACH_TYPE_FSG) -#else -# define machine_is_fsg() (0) -#endif
-#ifdef CONFIG_MACH_AT91SAM9260EK -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_AT91SAM9260EK -# endif -# define machine_is_at91sam9260ek() (machine_arch_type == MACH_TYPE_AT91SAM9260EK) -#else -# define machine_is_at91sam9260ek() (0) -#endif
-#ifdef CONFIG_MACH_GLANTANK -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_GLANTANK -# endif -# define machine_is_glantank() (machine_arch_type == MACH_TYPE_GLANTANK) -#else -# define machine_is_glantank() (0) -#endif
-#ifdef CONFIG_MACH_N2100 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_N2100 -# endif -# define machine_is_n2100() (machine_arch_type == MACH_TYPE_N2100) -#else -# define machine_is_n2100() (0) -#endif
-#ifdef CONFIG_MACH_QT2410 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_QT2410 -# endif -# define machine_is_qt2410() (machine_arch_type == MACH_TYPE_QT2410) -#else -# define machine_is_qt2410() (0) -#endif
-#ifdef CONFIG_MACH_KIXRP435 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_KIXRP435 -# endif -# define machine_is_kixrp435() (machine_arch_type == MACH_TYPE_KIXRP435) -#else -# define machine_is_kixrp435() (0) -#endif
-#ifdef CONFIG_MACH_CC9P9360DEV -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CC9P9360DEV -# endif -# define machine_is_cc9p9360dev() (machine_arch_type == MACH_TYPE_CC9P9360DEV) -#else -# define machine_is_cc9p9360dev() (0) -#endif
-#ifdef CONFIG_MACH_EDB9302A -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_EDB9302A -# endif -# define machine_is_edb9302a() (machine_arch_type == MACH_TYPE_EDB9302A) -#else -# define machine_is_edb9302a() (0) -#endif
-#ifdef CONFIG_MACH_EDB9307A -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_EDB9307A -# endif -# define machine_is_edb9307a() (machine_arch_type == MACH_TYPE_EDB9307A) -#else -# define machine_is_edb9307a() (0) -#endif
-#ifdef CONFIG_MACH_OMAP_3430SDP -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OMAP_3430SDP -# endif -# define machine_is_omap_3430sdp() (machine_arch_type == MACH_TYPE_OMAP_3430SDP) -#else -# define machine_is_omap_3430sdp() (0) -#endif
-#ifdef CONFIG_MACH_VSTMS -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_VSTMS -# endif -# define machine_is_vstms() (machine_arch_type == MACH_TYPE_VSTMS) -#else -# define machine_is_vstms() (0) -#endif
-#ifdef CONFIG_MACH_MICRO9M -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MICRO9M -# endif -# define machine_is_micro9m() (machine_arch_type == MACH_TYPE_MICRO9M) -#else -# define machine_is_micro9m() (0) -#endif
-#ifdef CONFIG_MACH_BUG -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_BUG -# endif -# define machine_is_bug() (machine_arch_type == MACH_TYPE_BUG) -#else -# define machine_is_bug() (0) -#endif
-#ifdef CONFIG_MACH_AT91SAM9263EK -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_AT91SAM9263EK -# endif -# define machine_is_at91sam9263ek() (machine_arch_type == MACH_TYPE_AT91SAM9263EK) -#else -# define machine_is_at91sam9263ek() (0) -#endif
-#ifdef CONFIG_MACH_EM7210 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_EM7210 -# endif -# define machine_is_em7210() (machine_arch_type == MACH_TYPE_EM7210) -#else -# define machine_is_em7210() (0) -#endif
-#ifdef CONFIG_MACH_VPAC270 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_VPAC270 -# endif -# define machine_is_vpac270() (machine_arch_type == MACH_TYPE_VPAC270) -#else -# define machine_is_vpac270() (0) -#endif
-#ifdef CONFIG_MACH_TREO680 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TREO680 -# endif -# define machine_is_treo680() (machine_arch_type == MACH_TYPE_TREO680) -#else -# define machine_is_treo680() (0) -#endif
-#ifdef CONFIG_MACH_ZYLONITE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ZYLONITE -# endif -# define machine_is_zylonite() (machine_arch_type == MACH_TYPE_ZYLONITE) -#else -# define machine_is_zylonite() (0) -#endif
-#ifdef CONFIG_MACH_MX31LITE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MX31LITE -# endif -# define machine_is_mx31lite() (machine_arch_type == MACH_TYPE_MX31LITE) -#else -# define machine_is_mx31lite() (0) -#endif
-#ifdef CONFIG_MACH_MIOA701 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MIOA701 -# endif -# define machine_is_mioa701() (machine_arch_type == MACH_TYPE_MIOA701) -#else -# define machine_is_mioa701() (0) -#endif
-#ifdef CONFIG_MACH_ARMADILLO5X0 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ARMADILLO5X0 -# endif -# define machine_is_armadillo5x0() (machine_arch_type == MACH_TYPE_ARMADILLO5X0) -#else -# define machine_is_armadillo5x0() (0) -#endif
-#ifdef CONFIG_MACH_CC9P9360JS -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CC9P9360JS -# endif -# define machine_is_cc9p9360js() (machine_arch_type == MACH_TYPE_CC9P9360JS) -#else -# define machine_is_cc9p9360js() (0) -#endif
-#ifdef CONFIG_MACH_NOKIA_N800 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NOKIA_N800 -# endif -# define machine_is_nokia_n800() (machine_arch_type == MACH_TYPE_NOKIA_N800) -#else -# define machine_is_nokia_n800() (0) -#endif
-#ifdef CONFIG_MACH_EP80219 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_EP80219 -# endif -# define machine_is_ep80219() (machine_arch_type == MACH_TYPE_EP80219) -#else -# define machine_is_ep80219() (0) -#endif
-#ifdef CONFIG_MACH_GORAMO_MLR -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_GORAMO_MLR -# endif -# define machine_is_goramo_mlr() (machine_arch_type == MACH_TYPE_GORAMO_MLR) -#else -# define machine_is_goramo_mlr() (0) -#endif
-#ifdef CONFIG_MACH_EM_X270 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_EM_X270 -# endif -# define machine_is_em_x270() (machine_arch_type == MACH_TYPE_EM_X270) -#else -# define machine_is_em_x270() (0) -#endif
-#ifdef CONFIG_MACH_NEO1973_GTA02 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NEO1973_GTA02 -# endif -# define machine_is_neo1973_gta02() (machine_arch_type == MACH_TYPE_NEO1973_GTA02) -#else -# define machine_is_neo1973_gta02() (0) -#endif
-#ifdef CONFIG_MACH_AT91SAM9RLEK -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_AT91SAM9RLEK -# endif -# define machine_is_at91sam9rlek() (machine_arch_type == MACH_TYPE_AT91SAM9RLEK) -#else -# define machine_is_at91sam9rlek() (0) -#endif
-#ifdef CONFIG_MACH_COLIBRI320 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_COLIBRI320 -# endif -# define machine_is_colibri320() (machine_arch_type == MACH_TYPE_COLIBRI320) -#else -# define machine_is_colibri320() (0) -#endif
-#ifdef CONFIG_MACH_CAM60 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CAM60 -# endif -# define machine_is_cam60() (machine_arch_type == MACH_TYPE_CAM60) -#else -# define machine_is_cam60() (0) -#endif
-#ifdef CONFIG_MACH_AT91EB01 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_AT91EB01 -# endif -# define machine_is_at91eb01() (machine_arch_type == MACH_TYPE_AT91EB01) -#else -# define machine_is_at91eb01() (0) -#endif
-#ifdef CONFIG_MACH_DB88F5281 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DB88F5281 -# endif -# define machine_is_db88f5281() (machine_arch_type == MACH_TYPE_DB88F5281) -#else -# define machine_is_db88f5281() (0) -#endif
-#ifdef CONFIG_MACH_CSB726 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CSB726 -# endif -# define machine_is_csb726() (machine_arch_type == MACH_TYPE_CSB726) -#else -# define machine_is_csb726() (0) -#endif
-#ifdef CONFIG_MACH_DAVINCI_DM6467_EVM -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DAVINCI_DM6467_EVM -# endif -# define machine_is_davinci_dm6467_evm() (machine_arch_type == MACH_TYPE_DAVINCI_DM6467_EVM) -#else -# define machine_is_davinci_dm6467_evm() (0) -#endif
-#ifdef CONFIG_MACH_DAVINCI_DM355_EVM -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DAVINCI_DM355_EVM -# endif -# define machine_is_davinci_dm355_evm() (machine_arch_type == MACH_TYPE_DAVINCI_DM355_EVM) -#else -# define machine_is_davinci_dm355_evm() (0) -#endif
-#ifdef CONFIG_MACH_LITTLETON -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_LITTLETON -# endif -# define machine_is_littleton() (machine_arch_type == MACH_TYPE_LITTLETON) -#else -# define machine_is_littleton() (0) -#endif
-#ifdef CONFIG_MACH_REALVIEW_PB11MP -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_REALVIEW_PB11MP -# endif -# define machine_is_realview_pb11mp() (machine_arch_type == MACH_TYPE_REALVIEW_PB11MP) -#else -# define machine_is_realview_pb11mp() (0) -#endif
-#ifdef CONFIG_MACH_MX27_3DS -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MX27_3DS -# endif -# define machine_is_mx27_3ds() (machine_arch_type == MACH_TYPE_MX27_3DS) -#else -# define machine_is_mx27_3ds() (0) -#endif
-#ifdef CONFIG_MACH_HALIBUT -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_HALIBUT -# endif -# define machine_is_halibut() (machine_arch_type == MACH_TYPE_HALIBUT) -#else -# define machine_is_halibut() (0) -#endif
-#ifdef CONFIG_MACH_TROUT -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TROUT -# endif -# define machine_is_trout() (machine_arch_type == MACH_TYPE_TROUT) -#else -# define machine_is_trout() (0) -#endif
-#ifdef CONFIG_MACH_TCT_HAMMER -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TCT_HAMMER -# endif -# define machine_is_tct_hammer() (machine_arch_type == MACH_TYPE_TCT_HAMMER) -#else -# define machine_is_tct_hammer() (0) -#endif
-#ifdef CONFIG_MACH_HERALD -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_HERALD -# endif -# define machine_is_herald() (machine_arch_type == MACH_TYPE_HERALD) -#else -# define machine_is_herald() (0) -#endif
-#ifdef CONFIG_MACH_SIM_ONE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SIM_ONE -# endif -# define machine_is_sim_one() (machine_arch_type == MACH_TYPE_SIM_ONE) -#else -# define machine_is_sim_one() (0) -#endif
-#ifdef CONFIG_MACH_JIVE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_JIVE -# endif -# define machine_is_jive() (machine_arch_type == MACH_TYPE_JIVE) -#else -# define machine_is_jive() (0) -#endif
-#ifdef CONFIG_MACH_SAM9_L9260 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SAM9_L9260 -# endif -# define machine_is_sam9_l9260() (machine_arch_type == MACH_TYPE_SAM9_L9260) -#else -# define machine_is_sam9_l9260() (0) -#endif
-#ifdef CONFIG_MACH_REALVIEW_PB1176 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_REALVIEW_PB1176 -# endif -# define machine_is_realview_pb1176() (machine_arch_type == MACH_TYPE_REALVIEW_PB1176) -#else -# define machine_is_realview_pb1176() (0) -#endif
-#ifdef CONFIG_MACH_YL9200 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_YL9200 -# endif -# define machine_is_yl9200() (machine_arch_type == MACH_TYPE_YL9200) -#else -# define machine_is_yl9200() (0) -#endif
-#ifdef CONFIG_MACH_RD88F5182 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_RD88F5182 -# endif -# define machine_is_rd88f5182() (machine_arch_type == MACH_TYPE_RD88F5182) -#else -# define machine_is_rd88f5182() (0) -#endif
-#ifdef CONFIG_MACH_KUROBOX_PRO -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_KUROBOX_PRO -# endif -# define machine_is_kurobox_pro() (machine_arch_type == MACH_TYPE_KUROBOX_PRO) -#else -# define machine_is_kurobox_pro() (0) -#endif
-#ifdef CONFIG_MACH_MX31_3DS -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MX31_3DS -# endif -# define machine_is_mx31_3ds() (machine_arch_type == MACH_TYPE_MX31_3DS) -#else -# define machine_is_mx31_3ds() (0) -#endif
-#ifdef CONFIG_MACH_QONG -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_QONG -# endif -# define machine_is_qong() (machine_arch_type == MACH_TYPE_QONG) -#else -# define machine_is_qong() (0) -#endif
-#ifdef CONFIG_MACH_OMAP2EVM -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OMAP2EVM -# endif -# define machine_is_omap2evm() (machine_arch_type == MACH_TYPE_OMAP2EVM) -#else -# define machine_is_omap2evm() (0) -#endif
-#ifdef CONFIG_MACH_OMAP3EVM -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OMAP3EVM -# endif -# define machine_is_omap3evm() (machine_arch_type == MACH_TYPE_OMAP3EVM) -#else -# define machine_is_omap3evm() (0) -#endif
-#ifdef CONFIG_MACH_DNS323 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DNS323 -# endif -# define machine_is_dns323() (machine_arch_type == MACH_TYPE_DNS323) -#else -# define machine_is_dns323() (0) -#endif
-#ifdef CONFIG_MACH_OMAP3_BEAGLE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OMAP3_BEAGLE -# endif -# define machine_is_omap3_beagle() (machine_arch_type == MACH_TYPE_OMAP3_BEAGLE) -#else -# define machine_is_omap3_beagle() (0) -#endif
-#ifdef CONFIG_MACH_NOKIA_N810 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NOKIA_N810 -# endif -# define machine_is_nokia_n810() (machine_arch_type == MACH_TYPE_NOKIA_N810) -#else -# define machine_is_nokia_n810() (0) -#endif
-#ifdef CONFIG_MACH_PCM038 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_PCM038 -# endif -# define machine_is_pcm038() (machine_arch_type == MACH_TYPE_PCM038) -#else -# define machine_is_pcm038() (0) -#endif
-#ifdef CONFIG_MACH_TS209 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TS209 -# endif -# define machine_is_ts_x09() (machine_arch_type == MACH_TYPE_TS209) -#else -# define machine_is_ts_x09() (0) -#endif
-#ifdef CONFIG_MACH_AT91CAP9ADK -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_AT91CAP9ADK -# endif -# define machine_is_at91cap9adk() (machine_arch_type == MACH_TYPE_AT91CAP9ADK) -#else -# define machine_is_at91cap9adk() (0) -#endif
-#ifdef CONFIG_MACH_MX31MOBOARD -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MX31MOBOARD -# endif -# define machine_is_mx31moboard() (machine_arch_type == MACH_TYPE_MX31MOBOARD) -#else -# define machine_is_mx31moboard() (0) -#endif
-#ifdef CONFIG_MACH_TERASTATION_PRO2 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TERASTATION_PRO2 -# endif -# define machine_is_terastation_pro2() (machine_arch_type == MACH_TYPE_TERASTATION_PRO2) -#else -# define machine_is_terastation_pro2() (0) -#endif
-#ifdef CONFIG_MACH_LINKSTATION_PRO -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_LINKSTATION_PRO -# endif -# define machine_is_linkstation_pro() (machine_arch_type == MACH_TYPE_LINKSTATION_PRO) -#else -# define machine_is_linkstation_pro() (0) -#endif
-#ifdef CONFIG_MACH_E350 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_E350 -# endif -# define machine_is_e350() (machine_arch_type == MACH_TYPE_E350) -#else -# define machine_is_e350() (0) -#endif
-#ifdef CONFIG_MACH_TS409 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TS409 -# endif -# define machine_is_ts409() (machine_arch_type == MACH_TYPE_TS409) -#else -# define machine_is_ts409() (0) -#endif
-#ifdef CONFIG_MACH_CM_X300 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CM_X300 -# endif -# define machine_is_cm_x300() (machine_arch_type == MACH_TYPE_CM_X300) -#else -# define machine_is_cm_x300() (0) -#endif
-#ifdef CONFIG_MACH_AT91SAM9G20EK -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_AT91SAM9G20EK -# endif -# define machine_is_at91sam9g20ek() (machine_arch_type == MACH_TYPE_AT91SAM9G20EK) -#else -# define machine_is_at91sam9g20ek() (0) -#endif
-#ifdef CONFIG_MACH_SMDK6410 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SMDK6410 -# endif -# define machine_is_smdk6410() (machine_arch_type == MACH_TYPE_SMDK6410) -#else -# define machine_is_smdk6410() (0) -#endif
-#ifdef CONFIG_MACH_U300 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_U300 -# endif -# define machine_is_u300() (machine_arch_type == MACH_TYPE_U300) -#else -# define machine_is_u300() (0) -#endif
-#ifdef CONFIG_MACH_WRT350N_V2 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_WRT350N_V2 -# endif -# define machine_is_wrt350n_v2() (machine_arch_type == MACH_TYPE_WRT350N_V2) -#else -# define machine_is_wrt350n_v2() (0) -#endif
-#ifdef CONFIG_MACH_OMAP_LDP -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OMAP_LDP -# endif -# define machine_is_omap_ldp() (machine_arch_type == MACH_TYPE_OMAP_LDP) -#else -# define machine_is_omap_ldp() (0) -#endif
-#ifdef CONFIG_MACH_MX35_3DS -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MX35_3DS -# endif -# define machine_is_mx35_3ds() (machine_arch_type == MACH_TYPE_MX35_3DS) -#else -# define machine_is_mx35_3ds() (0) -#endif
-#ifdef CONFIG_MACH_NEUROS_OSD2 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NEUROS_OSD2 -# endif -# define machine_is_neuros_osd2() (machine_arch_type == MACH_TYPE_NEUROS_OSD2) -#else -# define machine_is_neuros_osd2() (0) -#endif
-#ifdef CONFIG_MACH_TRIZEPS4WL -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TRIZEPS4WL -# endif -# define machine_is_trizeps4wl() (machine_arch_type == MACH_TYPE_TRIZEPS4WL) -#else -# define machine_is_trizeps4wl() (0) -#endif
-#ifdef CONFIG_MACH_TS78XX -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TS78XX -# endif -# define machine_is_ts78xx() (machine_arch_type == MACH_TYPE_TS78XX) -#else -# define machine_is_ts78xx() (0) -#endif
-#ifdef CONFIG_MACH_SFFSDR -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SFFSDR -# endif -# define machine_is_sffsdr() (machine_arch_type == MACH_TYPE_SFFSDR) -#else -# define machine_is_sffsdr() (0) -#endif
-#ifdef CONFIG_MACH_PCM037 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_PCM037 -# endif -# define machine_is_pcm037() (machine_arch_type == MACH_TYPE_PCM037) -#else -# define machine_is_pcm037() (0) -#endif
-#ifdef CONFIG_MACH_DB88F6281_BP -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DB88F6281_BP -# endif -# define machine_is_db88f6281_bp() (machine_arch_type == MACH_TYPE_DB88F6281_BP) -#else -# define machine_is_db88f6281_bp() (0) -#endif
-#ifdef CONFIG_MACH_RD88F6192_NAS -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_RD88F6192_NAS -# endif -# define machine_is_rd88f6192_nas() (machine_arch_type == MACH_TYPE_RD88F6192_NAS) -#else -# define machine_is_rd88f6192_nas() (0) -#endif
-#ifdef CONFIG_MACH_RD88F6281 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_RD88F6281 -# endif -# define machine_is_rd88f6281() (machine_arch_type == MACH_TYPE_RD88F6281) -#else -# define machine_is_rd88f6281() (0) -#endif
-#ifdef CONFIG_MACH_DB78X00_BP -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DB78X00_BP -# endif -# define machine_is_db78x00_bp() (machine_arch_type == MACH_TYPE_DB78X00_BP) -#else -# define machine_is_db78x00_bp() (0) -#endif
-#ifdef CONFIG_MACH_SMDK2416 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SMDK2416 -# endif -# define machine_is_smdk2416() (machine_arch_type == MACH_TYPE_SMDK2416) -#else -# define machine_is_smdk2416() (0) -#endif
-#ifdef CONFIG_MACH_WBD111 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_WBD111 -# endif -# define machine_is_wbd111() (machine_arch_type == MACH_TYPE_WBD111) -#else -# define machine_is_wbd111() (0) -#endif
-#ifdef CONFIG_MACH_MV2120 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MV2120 -# endif -# define machine_is_mv2120() (machine_arch_type == MACH_TYPE_MV2120) -#else -# define machine_is_mv2120() (0) -#endif
-#ifdef CONFIG_MACH_MX51_3DS -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MX51_3DS -# endif -# define machine_is_mx51_3ds() (machine_arch_type == MACH_TYPE_MX51_3DS) -#else -# define machine_is_mx51_3ds() (0) -#endif
-#ifdef CONFIG_MACH_IMX27LITE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_IMX27LITE -# endif -# define machine_is_imx27lite() (machine_arch_type == MACH_TYPE_IMX27LITE) -#else -# define machine_is_imx27lite() (0) -#endif
-#ifdef CONFIG_MACH_USB_A9260 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_USB_A9260 -# endif -# define machine_is_usb_a9260() (machine_arch_type == MACH_TYPE_USB_A9260) -#else -# define machine_is_usb_a9260() (0) -#endif
-#ifdef CONFIG_MACH_USB_A9263 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_USB_A9263 -# endif -# define machine_is_usb_a9263() (machine_arch_type == MACH_TYPE_USB_A9263) -#else -# define machine_is_usb_a9263() (0) -#endif
-#ifdef CONFIG_MACH_QIL_A9260 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_QIL_A9260 -# endif -# define machine_is_qil_a9260() (machine_arch_type == MACH_TYPE_QIL_A9260) -#else -# define machine_is_qil_a9260() (0) -#endif
-#ifdef CONFIG_MACH_KZM_ARM11_01 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_KZM_ARM11_01 -# endif -# define machine_is_kzm_arm11_01() (machine_arch_type == MACH_TYPE_KZM_ARM11_01) -#else -# define machine_is_kzm_arm11_01() (0) -#endif
-#ifdef CONFIG_MACH_NOKIA_N810_WIMAX -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NOKIA_N810_WIMAX -# endif -# define machine_is_nokia_n810_wimax() (machine_arch_type == MACH_TYPE_NOKIA_N810_WIMAX) -#else -# define machine_is_nokia_n810_wimax() (0) -#endif
-#ifdef CONFIG_MACH_SAPPHIRE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SAPPHIRE -# endif -# define machine_is_sapphire() (machine_arch_type == MACH_TYPE_SAPPHIRE) -#else -# define machine_is_sapphire() (0) -#endif
-#ifdef CONFIG_MACH_STMP37XX -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_STMP37XX -# endif -# define machine_is_stmp37xx() (machine_arch_type == MACH_TYPE_STMP37XX) -#else -# define machine_is_stmp37xx() (0) -#endif
-#ifdef CONFIG_MACH_STMP378X -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_STMP378X -# endif -# define machine_is_stmp378x() (machine_arch_type == MACH_TYPE_STMP378X) -#else -# define machine_is_stmp378x() (0) -#endif
-#ifdef CONFIG_MACH_EZX_A780 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_EZX_A780 -# endif -# define machine_is_ezx_a780() (machine_arch_type == MACH_TYPE_EZX_A780) -#else -# define machine_is_ezx_a780() (0) -#endif
-#ifdef CONFIG_MACH_EZX_E680 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_EZX_E680 -# endif -# define machine_is_ezx_e680() (machine_arch_type == MACH_TYPE_EZX_E680) -#else -# define machine_is_ezx_e680() (0) -#endif
-#ifdef CONFIG_MACH_EZX_A1200 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_EZX_A1200 -# endif -# define machine_is_ezx_a1200() (machine_arch_type == MACH_TYPE_EZX_A1200) -#else -# define machine_is_ezx_a1200() (0) -#endif
-#ifdef CONFIG_MACH_EZX_E6 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_EZX_E6 -# endif -# define machine_is_ezx_e6() (machine_arch_type == MACH_TYPE_EZX_E6) -#else -# define machine_is_ezx_e6() (0) -#endif
-#ifdef CONFIG_MACH_EZX_E2 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_EZX_E2 -# endif -# define machine_is_ezx_e2() (machine_arch_type == MACH_TYPE_EZX_E2) -#else -# define machine_is_ezx_e2() (0) -#endif
-#ifdef CONFIG_MACH_EZX_A910 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_EZX_A910 -# endif -# define machine_is_ezx_a910() (machine_arch_type == MACH_TYPE_EZX_A910) -#else -# define machine_is_ezx_a910() (0) -#endif
-#ifdef CONFIG_MACH_EDMINI_V2 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_EDMINI_V2 -# endif -# define machine_is_edmini_v2() (machine_arch_type == MACH_TYPE_EDMINI_V2) -#else -# define machine_is_edmini_v2() (0) -#endif
-#ifdef CONFIG_MACH_ZIPIT2 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ZIPIT2 -# endif -# define machine_is_zipit2() (machine_arch_type == MACH_TYPE_ZIPIT2) -#else -# define machine_is_zipit2() (0) -#endif
-#ifdef CONFIG_MACH_OMAP3_PANDORA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OMAP3_PANDORA -# endif -# define machine_is_omap3_pandora() (machine_arch_type == MACH_TYPE_OMAP3_PANDORA) -#else -# define machine_is_omap3_pandora() (0) -#endif
-#ifdef CONFIG_MACH_MSS2 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MSS2 -# endif -# define machine_is_mss2() (machine_arch_type == MACH_TYPE_MSS2) -#else -# define machine_is_mss2() (0) -#endif
-#ifdef CONFIG_MACH_LB88RC8480 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_LB88RC8480 -# endif -# define machine_is_lb88rc8480() (machine_arch_type == MACH_TYPE_LB88RC8480) -#else -# define machine_is_lb88rc8480() (0) -#endif
-#ifdef CONFIG_MACH_MX25_3DS -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MX25_3DS -# endif -# define machine_is_mx25_3ds() (machine_arch_type == MACH_TYPE_MX25_3DS) -#else -# define machine_is_mx25_3ds() (0) -#endif
-#ifdef CONFIG_MACH_OMAP3530_LV_SOM -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OMAP3530_LV_SOM -# endif -# define machine_is_omap3530_lv_som() (machine_arch_type == MACH_TYPE_OMAP3530_LV_SOM) -#else -# define machine_is_omap3530_lv_som() (0) -#endif
-#ifdef CONFIG_MACH_DAVINCI_DA830_EVM -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DAVINCI_DA830_EVM -# endif -# define machine_is_davinci_da830_evm() (machine_arch_type == MACH_TYPE_DAVINCI_DA830_EVM) -#else -# define machine_is_davinci_da830_evm() (0) -#endif
-#ifdef CONFIG_MACH_AT572D940HFEB -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_AT572D940HFEB -# endif -# define machine_is_at572d940hfek() (machine_arch_type == MACH_TYPE_AT572D940HFEB) -#else -# define machine_is_at572d940hfek() (0) -#endif
-#ifdef CONFIG_MACH_DOVE_DB -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DOVE_DB -# endif -# define machine_is_dove_db() (machine_arch_type == MACH_TYPE_DOVE_DB) -#else -# define machine_is_dove_db() (0) -#endif
-#ifdef CONFIG_MACH_OVERO -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OVERO -# endif -# define machine_is_overo() (machine_arch_type == MACH_TYPE_OVERO) -#else -# define machine_is_overo() (0) -#endif
-#ifdef CONFIG_MACH_AT2440EVB -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_AT2440EVB -# endif -# define machine_is_at2440evb() (machine_arch_type == MACH_TYPE_AT2440EVB) -#else -# define machine_is_at2440evb() (0) -#endif
-#ifdef CONFIG_MACH_NEOCORE926 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NEOCORE926 -# endif -# define machine_is_neocore926() (machine_arch_type == MACH_TYPE_NEOCORE926) -#else -# define machine_is_neocore926() (0) -#endif
-#ifdef CONFIG_MACH_WNR854T -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_WNR854T -# endif -# define machine_is_wnr854t() (machine_arch_type == MACH_TYPE_WNR854T) -#else -# define machine_is_wnr854t() (0) -#endif
-#ifdef CONFIG_MACH_RD88F5181L_GE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_RD88F5181L_GE -# endif -# define machine_is_rd88f5181l_ge() (machine_arch_type == MACH_TYPE_RD88F5181L_GE) -#else -# define machine_is_rd88f5181l_ge() (0) -#endif
-#ifdef CONFIG_MACH_RD88F5181L_FXO -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_RD88F5181L_FXO -# endif -# define machine_is_rd88f5181l_fxo() (machine_arch_type == MACH_TYPE_RD88F5181L_FXO) -#else -# define machine_is_rd88f5181l_fxo() (0) -#endif
-#ifdef CONFIG_MACH_STAMP9G20 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_STAMP9G20 -# endif -# define machine_is_stamp9g20() (machine_arch_type == MACH_TYPE_STAMP9G20) -#else -# define machine_is_stamp9g20() (0) -#endif
-#ifdef CONFIG_MACH_SMDKC100 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SMDKC100 -# endif -# define machine_is_smdkc100() (machine_arch_type == MACH_TYPE_SMDKC100) -#else -# define machine_is_smdkc100() (0) -#endif
-#ifdef CONFIG_MACH_TAVOREVB -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TAVOREVB -# endif -# define machine_is_tavorevb() (machine_arch_type == MACH_TYPE_TAVOREVB) -#else -# define machine_is_tavorevb() (0) -#endif
-#ifdef CONFIG_MACH_SAAR -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SAAR -# endif -# define machine_is_saar() (machine_arch_type == MACH_TYPE_SAAR) -#else -# define machine_is_saar() (0) -#endif
-#ifdef CONFIG_MACH_AT91SAM9M10G45EK -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_AT91SAM9M10G45EK -# endif -# define machine_is_at91sam9m10g45ek() (machine_arch_type == MACH_TYPE_AT91SAM9M10G45EK) -#else -# define machine_is_at91sam9m10g45ek() (0) -#endif
-#ifdef CONFIG_MACH_MXLADS -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MXLADS -# endif -# define machine_is_mxlads() (machine_arch_type == MACH_TYPE_MXLADS) -#else -# define machine_is_mxlads() (0) -#endif
-#ifdef CONFIG_MACH_LINKSTATION_MINI -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_LINKSTATION_MINI -# endif -# define machine_is_linkstation_mini() (machine_arch_type == MACH_TYPE_LINKSTATION_MINI) -#else -# define machine_is_linkstation_mini() (0) -#endif
-#ifdef CONFIG_MACH_AFEB9260 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_AFEB9260 -# endif -# define machine_is_afeb9260() (machine_arch_type == MACH_TYPE_AFEB9260) -#else -# define machine_is_afeb9260() (0) -#endif
-#ifdef CONFIG_MACH_IMX27IPCAM -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_IMX27IPCAM -# endif -# define machine_is_imx27ipcam() (machine_arch_type == MACH_TYPE_IMX27IPCAM) -#else -# define machine_is_imx27ipcam() (0) -#endif
-#ifdef CONFIG_MACH_RD88F6183AP_GE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_RD88F6183AP_GE -# endif -# define machine_is_rd88f6183ap_ge() (machine_arch_type == MACH_TYPE_RD88F6183AP_GE) -#else -# define machine_is_rd88f6183ap_ge() (0) -#endif
-#ifdef CONFIG_MACH_REALVIEW_PBA8 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_REALVIEW_PBA8 -# endif -# define machine_is_realview_pba8() (machine_arch_type == MACH_TYPE_REALVIEW_PBA8) -#else -# define machine_is_realview_pba8() (0) -#endif
-#ifdef CONFIG_MACH_REALVIEW_PBX -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_REALVIEW_PBX -# endif -# define machine_is_realview_pbx() (machine_arch_type == MACH_TYPE_REALVIEW_PBX) -#else -# define machine_is_realview_pbx() (0) -#endif
-#ifdef CONFIG_MACH_MICRO9S -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MICRO9S -# endif -# define machine_is_micro9s() (machine_arch_type == MACH_TYPE_MICRO9S) -#else -# define machine_is_micro9s() (0) -#endif
-#ifdef CONFIG_MACH_RUT100 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_RUT100 -# endif -# define machine_is_rut100() (machine_arch_type == MACH_TYPE_RUT100) -#else -# define machine_is_rut100() (0) -#endif
-#ifdef CONFIG_MACH_G3EVM -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_G3EVM -# endif -# define machine_is_g3evm() (machine_arch_type == MACH_TYPE_G3EVM) -#else -# define machine_is_g3evm() (0) -#endif
-#ifdef CONFIG_MACH_W90P910EVB -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_W90P910EVB -# endif -# define machine_is_w90p910evb() (machine_arch_type == MACH_TYPE_W90P910EVB) -#else -# define machine_is_w90p910evb() (0) -#endif
-#ifdef CONFIG_MACH_W90P950EVB -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_W90P950EVB -# endif -# define machine_is_w90p950evb() (machine_arch_type == MACH_TYPE_W90P950EVB) -#else -# define machine_is_w90p950evb() (0) -#endif
-#ifdef CONFIG_MACH_W90N960EVB -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_W90N960EVB -# endif -# define machine_is_w90n960evb() (machine_arch_type == MACH_TYPE_W90N960EVB) -#else -# define machine_is_w90n960evb() (0) -#endif
-#ifdef CONFIG_MACH_MV88F6281GTW_GE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MV88F6281GTW_GE -# endif -# define machine_is_mv88f6281gtw_ge() (machine_arch_type == MACH_TYPE_MV88F6281GTW_GE) -#else -# define machine_is_mv88f6281gtw_ge() (0) -#endif
-#ifdef CONFIG_MACH_NCP -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NCP -# endif -# define machine_is_ncp() (machine_arch_type == MACH_TYPE_NCP) -#else -# define machine_is_ncp() (0) -#endif
-#ifdef CONFIG_MACH_DAVINCI_DM365_EVM -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DAVINCI_DM365_EVM -# endif -# define machine_is_davinci_dm365_evm() (machine_arch_type == MACH_TYPE_DAVINCI_DM365_EVM) -#else -# define machine_is_davinci_dm365_evm() (0) -#endif
-#ifdef CONFIG_MACH_CENTRO -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CENTRO -# endif -# define machine_is_centro() (machine_arch_type == MACH_TYPE_CENTRO) -#else -# define machine_is_centro() (0) -#endif
-#ifdef CONFIG_MACH_NOKIA_RX51 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NOKIA_RX51 -# endif -# define machine_is_nokia_rx51() (machine_arch_type == MACH_TYPE_NOKIA_RX51) -#else -# define machine_is_nokia_rx51() (0) -#endif
-#ifdef CONFIG_MACH_OMAP_ZOOM2 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OMAP_ZOOM2 -# endif -# define machine_is_omap_zoom2() (machine_arch_type == MACH_TYPE_OMAP_ZOOM2) -#else -# define machine_is_omap_zoom2() (0) -#endif
-#ifdef CONFIG_MACH_ACS5K -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ACS5K -# endif -# define machine_is_acs5k() (machine_arch_type == MACH_TYPE_ACS5K) -#else -# define machine_is_acs5k() (0) -#endif
-#ifdef CONFIG_MACH_SNAPPER_9260 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SNAPPER_9260 -# endif -# define machine_is_snapper_9260() (machine_arch_type == MACH_TYPE_SNAPPER_9260) -#else -# define machine_is_snapper_9260() (0) -#endif
-#ifdef CONFIG_MACH_DSM320 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DSM320 -# endif -# define machine_is_dsm320() (machine_arch_type == MACH_TYPE_DSM320) -#else -# define machine_is_dsm320() (0) -#endif
-#ifdef CONFIG_MACH_EXEDA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_EXEDA -# endif -# define machine_is_exeda() (machine_arch_type == MACH_TYPE_EXEDA) -#else -# define machine_is_exeda() (0) -#endif
-#ifdef CONFIG_MACH_MINI2440 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MINI2440 -# endif -# define machine_is_mini2440() (machine_arch_type == MACH_TYPE_MINI2440) -#else -# define machine_is_mini2440() (0) -#endif
-#ifdef CONFIG_MACH_COLIBRI300 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_COLIBRI300 -# endif -# define machine_is_colibri300() (machine_arch_type == MACH_TYPE_COLIBRI300) -#else -# define machine_is_colibri300() (0) -#endif
-#ifdef CONFIG_MACH_LINKSTATION_LS_HGL -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_LINKSTATION_LS_HGL -# endif -# define machine_is_linkstation_ls_hgl() (machine_arch_type == MACH_TYPE_LINKSTATION_LS_HGL) -#else -# define machine_is_linkstation_ls_hgl() (0) -#endif
-#ifdef CONFIG_MACH_CPUAT9G20 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CPUAT9G20 -# endif -# define machine_is_cpuat9g20() (machine_arch_type == MACH_TYPE_CPUAT9G20) -#else -# define machine_is_cpuat9g20() (0) -#endif
-#ifdef CONFIG_MACH_SMDK6440 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SMDK6440 -# endif -# define machine_is_smdk6440() (machine_arch_type == MACH_TYPE_SMDK6440) -#else -# define machine_is_smdk6440() (0) -#endif
-#ifdef CONFIG_MACH_NAS4220B -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NAS4220B -# endif -# define machine_is_nas4220b() (machine_arch_type == MACH_TYPE_NAS4220B) -#else -# define machine_is_nas4220b() (0) -#endif
-#ifdef CONFIG_MACH_ZYLONITE2 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ZYLONITE2 -# endif -# define machine_is_zylonite2() (machine_arch_type == MACH_TYPE_ZYLONITE2) -#else -# define machine_is_zylonite2() (0) -#endif
-#ifdef CONFIG_MACH_ASPENITE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ASPENITE -# endif -# define machine_is_aspenite() (machine_arch_type == MACH_TYPE_ASPENITE) -#else -# define machine_is_aspenite() (0) -#endif
-#ifdef CONFIG_MACH_TTC_DKB -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TTC_DKB -# endif -# define machine_is_ttc_dkb() (machine_arch_type == MACH_TYPE_TTC_DKB) -#else -# define machine_is_ttc_dkb() (0) -#endif
-#ifdef CONFIG_MACH_PCM043 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_PCM043 -# endif -# define machine_is_pcm043() (machine_arch_type == MACH_TYPE_PCM043) -#else -# define machine_is_pcm043() (0) -#endif
-#ifdef CONFIG_MACH_SHEEVAPLUG -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SHEEVAPLUG -# endif -# define machine_is_sheevaplug() (machine_arch_type == MACH_TYPE_SHEEVAPLUG) -#else -# define machine_is_sheevaplug() (0) -#endif
-#ifdef CONFIG_MACH_AVENGERS_LITE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_AVENGERS_LITE -# endif -# define machine_is_avengers_lite() (machine_arch_type == MACH_TYPE_AVENGERS_LITE) -#else -# define machine_is_avengers_lite() (0) -#endif
-#ifdef CONFIG_MACH_MX51_BABBAGE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MX51_BABBAGE -# endif -# define machine_is_mx51_babbage() (machine_arch_type == MACH_TYPE_MX51_BABBAGE) -#else -# define machine_is_mx51_babbage() (0) -#endif
-#ifdef CONFIG_MACH_RD78X00_MASA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_RD78X00_MASA -# endif -# define machine_is_rd78x00_masa() (machine_arch_type == MACH_TYPE_RD78X00_MASA) -#else -# define machine_is_rd78x00_masa() (0) -#endif
-#ifdef CONFIG_MACH_DM355_LEOPARD -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DM355_LEOPARD -# endif -# define machine_is_dm355_leopard() (machine_arch_type == MACH_TYPE_DM355_LEOPARD) -#else -# define machine_is_dm355_leopard() (0) -#endif
-#ifdef CONFIG_MACH_TS219 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TS219 -# endif -# define machine_is_ts219() (machine_arch_type == MACH_TYPE_TS219) -#else -# define machine_is_ts219() (0) -#endif
-#ifdef CONFIG_MACH_PCA100 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_PCA100 -# endif -# define machine_is_pca100() (machine_arch_type == MACH_TYPE_PCA100) -#else -# define machine_is_pca100() (0) -#endif
-#ifdef CONFIG_MACH_DAVINCI_DA850_EVM -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DAVINCI_DA850_EVM -# endif -# define machine_is_davinci_da850_evm() (machine_arch_type == MACH_TYPE_DAVINCI_DA850_EVM) -#else -# define machine_is_davinci_da850_evm() (0) -#endif
-#ifdef CONFIG_MACH_AT91SAM9G10EK -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_AT91SAM9G10EK -# endif -# define machine_is_at91sam9g10ek() (machine_arch_type == MACH_TYPE_AT91SAM9G10EK) -#else -# define machine_is_at91sam9g10ek() (0) -#endif
-#ifdef CONFIG_MACH_OMAP_4430SDP -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OMAP_4430SDP -# endif -# define machine_is_omap_4430sdp() (machine_arch_type == MACH_TYPE_OMAP_4430SDP) -#else -# define machine_is_omap_4430sdp() (0) -#endif
-#ifdef CONFIG_MACH_MAGX_ZN5 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MAGX_ZN5 -# endif -# define machine_is_magx_zn5() (machine_arch_type == MACH_TYPE_MAGX_ZN5) -#else -# define machine_is_magx_zn5() (0) -#endif
-#ifdef CONFIG_MACH_BTMAVB101 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_BTMAVB101 -# endif -# define machine_is_btmavb101() (machine_arch_type == MACH_TYPE_BTMAVB101) -#else -# define machine_is_btmavb101() (0) -#endif
-#ifdef CONFIG_MACH_BTMAWB101 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_BTMAWB101 -# endif -# define machine_is_btmawb101() (machine_arch_type == MACH_TYPE_BTMAWB101) -#else -# define machine_is_btmawb101() (0) -#endif
-#ifdef CONFIG_MACH_OMAP3_TORPEDO -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OMAP3_TORPEDO -# endif -# define machine_is_omap3_torpedo() (machine_arch_type == MACH_TYPE_OMAP3_TORPEDO) -#else -# define machine_is_omap3_torpedo() (0) -#endif
-#ifdef CONFIG_MACH_ANW6410 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ANW6410 -# endif -# define machine_is_anw6410() (machine_arch_type == MACH_TYPE_ANW6410) -#else -# define machine_is_anw6410() (0) -#endif
-#ifdef CONFIG_MACH_IMX27_VISSTRIM_M10 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_IMX27_VISSTRIM_M10 -# endif -# define machine_is_imx27_visstrim_m10() (machine_arch_type == MACH_TYPE_IMX27_VISSTRIM_M10) -#else -# define machine_is_imx27_visstrim_m10() (0) -#endif
-#ifdef CONFIG_MACH_PORTUXG20 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_PORTUXG20 -# endif -# define machine_is_portuxg20() (machine_arch_type == MACH_TYPE_PORTUXG20) -#else -# define machine_is_portuxg20() (0) -#endif
-#ifdef CONFIG_MACH_SMDKC110 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SMDKC110 -# endif -# define machine_is_smdkc110() (machine_arch_type == MACH_TYPE_SMDKC110) -#else -# define machine_is_smdkc110() (0) -#endif
-#ifdef CONFIG_MACH_OMAP3517EVM -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OMAP3517EVM -# endif -# define machine_is_omap3517evm() (machine_arch_type == MACH_TYPE_OMAP3517EVM) -#else -# define machine_is_omap3517evm() (0) -#endif
-#ifdef CONFIG_MACH_NETSPACE_V2 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NETSPACE_V2 -# endif -# define machine_is_netspace_v2() (machine_arch_type == MACH_TYPE_NETSPACE_V2) -#else -# define machine_is_netspace_v2() (0) -#endif
-#ifdef CONFIG_MACH_NETSPACE_MAX_V2 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NETSPACE_MAX_V2 -# endif -# define machine_is_netspace_max_v2() (machine_arch_type == MACH_TYPE_NETSPACE_MAX_V2) -#else -# define machine_is_netspace_max_v2() (0) -#endif
-#ifdef CONFIG_MACH_D2NET_V2 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_D2NET_V2 -# endif -# define machine_is_d2net_v2() (machine_arch_type == MACH_TYPE_D2NET_V2) -#else -# define machine_is_d2net_v2() (0) -#endif
-#ifdef CONFIG_MACH_NET2BIG_V2 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NET2BIG_V2 -# endif -# define machine_is_net2big_v2() (machine_arch_type == MACH_TYPE_NET2BIG_V2) -#else -# define machine_is_net2big_v2() (0) -#endif
-#ifdef CONFIG_MACH_NET5BIG_V2 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NET5BIG_V2 -# endif -# define machine_is_net5big_v2() (machine_arch_type == MACH_TYPE_NET5BIG_V2) -#else -# define machine_is_net5big_v2() (0) -#endif
-#ifdef CONFIG_MACH_INETSPACE_V2 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_INETSPACE_V2 -# endif -# define machine_is_inetspace_v2() (machine_arch_type == MACH_TYPE_INETSPACE_V2) -#else -# define machine_is_inetspace_v2() (0) -#endif
-#ifdef CONFIG_MACH_AT91SAM9G45EKES -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_AT91SAM9G45EKES -# endif -# define machine_is_at91sam9g45ekes() (machine_arch_type == MACH_TYPE_AT91SAM9G45EKES) -#else -# define machine_is_at91sam9g45ekes() (0) -#endif
-#ifdef CONFIG_MACH_PC7302 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_PC7302 -# endif -# define machine_is_pc7302() (machine_arch_type == MACH_TYPE_PC7302) -#else -# define machine_is_pc7302() (0) -#endif
-#ifdef CONFIG_MACH_SPEAR600 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SPEAR600 -# endif -# define machine_is_spear600() (machine_arch_type == MACH_TYPE_SPEAR600) -#else -# define machine_is_spear600() (0) -#endif
-#ifdef CONFIG_MACH_SPEAR300 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SPEAR300 -# endif -# define machine_is_spear300() (machine_arch_type == MACH_TYPE_SPEAR300) -#else -# define machine_is_spear300() (0) -#endif
-#ifdef CONFIG_MACH_LILLY1131 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_LILLY1131 -# endif -# define machine_is_lilly1131() (machine_arch_type == MACH_TYPE_LILLY1131) -#else -# define machine_is_lilly1131() (0) -#endif
-#ifdef CONFIG_MACH_HMT -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_HMT -# endif -# define machine_is_hmt() (machine_arch_type == MACH_TYPE_HMT) -#else -# define machine_is_hmt() (0) -#endif
-#ifdef CONFIG_MACH_VEXPRESS -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_VEXPRESS -# endif -# define machine_is_vexpress() (machine_arch_type == MACH_TYPE_VEXPRESS) -#else -# define machine_is_vexpress() (0) -#endif
-#ifdef CONFIG_MACH_D2NET -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_D2NET -# endif -# define machine_is_d2net() (machine_arch_type == MACH_TYPE_D2NET) -#else -# define machine_is_d2net() (0) -#endif
-#ifdef CONFIG_MACH_BIGDISK -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_BIGDISK -# endif -# define machine_is_bigdisk() (machine_arch_type == MACH_TYPE_BIGDISK) -#else -# define machine_is_bigdisk() (0) -#endif
-#ifdef CONFIG_MACH_AT91SAM9G20EK_2MMC -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_AT91SAM9G20EK_2MMC -# endif -# define machine_is_at91sam9g20ek_2mmc() (machine_arch_type == MACH_TYPE_AT91SAM9G20EK_2MMC) -#else -# define machine_is_at91sam9g20ek_2mmc() (0) -#endif
-#ifdef CONFIG_MACH_BCMRING -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_BCMRING -# endif -# define machine_is_bcmring() (machine_arch_type == MACH_TYPE_BCMRING) -#else -# define machine_is_bcmring() (0) -#endif
-#ifdef CONFIG_MACH_DP6XX -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DP6XX -# endif -# define machine_is_dp6xx() (machine_arch_type == MACH_TYPE_DP6XX) -#else -# define machine_is_dp6xx() (0) -#endif
-#ifdef CONFIG_MACH_MAHIMAHI -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MAHIMAHI -# endif -# define machine_is_mahimahi() (machine_arch_type == MACH_TYPE_MAHIMAHI) -#else -# define machine_is_mahimahi() (0) -#endif
-#ifdef CONFIG_MACH_SMDK6442 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SMDK6442 -# endif -# define machine_is_smdk6442() (machine_arch_type == MACH_TYPE_SMDK6442) -#else -# define machine_is_smdk6442() (0) -#endif
-#ifdef CONFIG_MACH_OPENRD_BASE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OPENRD_BASE -# endif -# define machine_is_openrd_base() (machine_arch_type == MACH_TYPE_OPENRD_BASE) -#else -# define machine_is_openrd_base() (0) -#endif
-#ifdef CONFIG_MACH_DEVKIT8000 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DEVKIT8000 -# endif -# define machine_is_devkit8000() (machine_arch_type == MACH_TYPE_DEVKIT8000) -#else -# define machine_is_devkit8000() (0) -#endif
-#ifdef CONFIG_MACH_MX51_EFIKAMX -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MX51_EFIKAMX -# endif -# define machine_is_mx51_efikamx() (machine_arch_type == MACH_TYPE_MX51_EFIKAMX) -#else -# define machine_is_mx51_efikamx() (0) -#endif
-#ifdef CONFIG_MACH_CM_T35 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CM_T35 -# endif -# define machine_is_cm_t35() (machine_arch_type == MACH_TYPE_CM_T35) -#else -# define machine_is_cm_t35() (0) -#endif
-#ifdef CONFIG_MACH_NET2BIG -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NET2BIG -# endif -# define machine_is_net2big() (machine_arch_type == MACH_TYPE_NET2BIG) -#else -# define machine_is_net2big() (0) -#endif
-#ifdef CONFIG_MACH_IGEP0020 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_IGEP0020 -# endif -# define machine_is_igep0020() (machine_arch_type == MACH_TYPE_IGEP0020) -#else -# define machine_is_igep0020() (0) -#endif
-#ifdef CONFIG_MACH_NUC932EVB -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NUC932EVB -# endif -# define machine_is_nuc932evb() (machine_arch_type == MACH_TYPE_NUC932EVB) -#else -# define machine_is_nuc932evb() (0) -#endif
-#ifdef CONFIG_MACH_OPENRD_CLIENT -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OPENRD_CLIENT -# endif -# define machine_is_openrd_client() (machine_arch_type == MACH_TYPE_OPENRD_CLIENT) -#else -# define machine_is_openrd_client() (0) -#endif
-#ifdef CONFIG_MACH_MX51_EFIKASB -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MX51_EFIKASB -# endif -# define machine_is_mx51_efikasb() (machine_arch_type == MACH_TYPE_MX51_EFIKASB) -#else -# define machine_is_mx51_efikasb() (0) -#endif
-#ifdef CONFIG_MACH_MARVELL_JASPER -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MARVELL_JASPER -# endif -# define machine_is_marvell_jasper() (machine_arch_type == MACH_TYPE_MARVELL_JASPER) -#else -# define machine_is_marvell_jasper() (0) -#endif
-#ifdef CONFIG_MACH_FLINT -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_FLINT -# endif -# define machine_is_flint() (machine_arch_type == MACH_TYPE_FLINT) -#else -# define machine_is_flint() (0) -#endif
-#ifdef CONFIG_MACH_TAVOREVB3 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TAVOREVB3 -# endif -# define machine_is_tavorevb3() (machine_arch_type == MACH_TYPE_TAVOREVB3) -#else -# define machine_is_tavorevb3() (0) -#endif
-#ifdef CONFIG_MACH_TOUCHBOOK -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TOUCHBOOK -# endif -# define machine_is_touchbook() (machine_arch_type == MACH_TYPE_TOUCHBOOK) -#else -# define machine_is_touchbook() (0) -#endif
-#ifdef CONFIG_MACH_RAUMFELD_RC -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_RAUMFELD_RC -# endif -# define machine_is_raumfeld_rc() (machine_arch_type == MACH_TYPE_RAUMFELD_RC) -#else -# define machine_is_raumfeld_rc() (0) -#endif
-#ifdef CONFIG_MACH_RAUMFELD_CONNECTOR -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_RAUMFELD_CONNECTOR -# endif -# define machine_is_raumfeld_connector() (machine_arch_type == MACH_TYPE_RAUMFELD_CONNECTOR) -#else -# define machine_is_raumfeld_connector() (0) -#endif
-#ifdef CONFIG_MACH_RAUMFELD_SPEAKER -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_RAUMFELD_SPEAKER -# endif -# define machine_is_raumfeld_speaker() (machine_arch_type == MACH_TYPE_RAUMFELD_SPEAKER) -#else -# define machine_is_raumfeld_speaker() (0) -#endif
-#ifdef CONFIG_MACH_TNETV107X -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TNETV107X -# endif -# define machine_is_tnetv107x() (machine_arch_type == MACH_TYPE_TNETV107X) -#else -# define machine_is_tnetv107x() (0) -#endif
-#ifdef CONFIG_MACH_SMDKV210 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SMDKV210 -# endif -# define machine_is_smdkv210() (machine_arch_type == MACH_TYPE_SMDKV210) -#else -# define machine_is_smdkv210() (0) -#endif
-#ifdef CONFIG_MACH_OMAP_ZOOM3 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OMAP_ZOOM3 -# endif -# define machine_is_omap_zoom3() (machine_arch_type == MACH_TYPE_OMAP_ZOOM3) -#else -# define machine_is_omap_zoom3() (0) -#endif
-#ifdef CONFIG_MACH_OMAP_3630SDP -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OMAP_3630SDP -# endif -# define machine_is_omap_3630sdp() (machine_arch_type == MACH_TYPE_OMAP_3630SDP) -#else -# define machine_is_omap_3630sdp() (0) -#endif
-#ifdef CONFIG_MACH_SMARTQ7 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SMARTQ7 -# endif -# define machine_is_smartq7() (machine_arch_type == MACH_TYPE_SMARTQ7) -#else -# define machine_is_smartq7() (0) -#endif
-#ifdef CONFIG_MACH_WATSON_EFM_PLUGIN -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_WATSON_EFM_PLUGIN -# endif -# define machine_is_watson_efm_plugin() (machine_arch_type == MACH_TYPE_WATSON_EFM_PLUGIN) -#else -# define machine_is_watson_efm_plugin() (0) -#endif
-#ifdef CONFIG_MACH_G4EVM -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_G4EVM -# endif -# define machine_is_g4evm() (machine_arch_type == MACH_TYPE_G4EVM) -#else -# define machine_is_g4evm() (0) -#endif
-#ifdef CONFIG_MACH_OMAPL138_HAWKBOARD -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OMAPL138_HAWKBOARD -# endif -# define machine_is_omapl138_hawkboard() (machine_arch_type == MACH_TYPE_OMAPL138_HAWKBOARD) -#else -# define machine_is_omapl138_hawkboard() (0) -#endif
-#ifdef CONFIG_MACH_TS41X -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TS41X -# endif -# define machine_is_ts41x() (machine_arch_type == MACH_TYPE_TS41X) -#else -# define machine_is_ts41x() (0) -#endif
-#ifdef CONFIG_MACH_PHY3250 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_PHY3250 -# endif -# define machine_is_phy3250() (machine_arch_type == MACH_TYPE_PHY3250) -#else -# define machine_is_phy3250() (0) -#endif
-#ifdef CONFIG_MACH_MINI6410 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MINI6410 -# endif -# define machine_is_mini6410() (machine_arch_type == MACH_TYPE_MINI6410) -#else -# define machine_is_mini6410() (0) -#endif
-#ifdef CONFIG_MACH_MX28EVK -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MX28EVK -# endif -# define machine_is_mx28evk() (machine_arch_type == MACH_TYPE_MX28EVK) -#else -# define machine_is_mx28evk() (0) -#endif
-#ifdef CONFIG_MACH_SMARTQ5 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SMARTQ5 -# endif -# define machine_is_smartq5() (machine_arch_type == MACH_TYPE_SMARTQ5) -#else -# define machine_is_smartq5() (0) -#endif
-#ifdef CONFIG_MACH_DAVINCI_DM6467TEVM -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DAVINCI_DM6467TEVM -# endif -# define machine_is_davinci_dm6467tevm() (machine_arch_type == MACH_TYPE_DAVINCI_DM6467TEVM) -#else -# define machine_is_davinci_dm6467tevm() (0) -#endif
-#ifdef CONFIG_MACH_MXT_TD60 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MXT_TD60 -# endif -# define machine_is_mxt_td60() (machine_arch_type == MACH_TYPE_MXT_TD60) -#else -# define machine_is_mxt_td60() (0) -#endif
-#ifdef CONFIG_MACH_RIOT_BEI2 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_RIOT_BEI2 -# endif -# define machine_is_riot_bei2() (machine_arch_type == MACH_TYPE_RIOT_BEI2) -#else -# define machine_is_riot_bei2() (0) -#endif
-#ifdef CONFIG_MACH_RIOT_X37 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_RIOT_X37 -# endif -# define machine_is_riot_x37() (machine_arch_type == MACH_TYPE_RIOT_X37) -#else -# define machine_is_riot_x37() (0) -#endif
-#ifdef CONFIG_MACH_CAPC7117 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CAPC7117 -# endif -# define machine_is_capc7117() (machine_arch_type == MACH_TYPE_CAPC7117) -#else -# define machine_is_capc7117() (0) -#endif
-#ifdef CONFIG_MACH_ICONTROL -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ICONTROL -# endif -# define machine_is_icontrol() (machine_arch_type == MACH_TYPE_ICONTROL) -#else -# define machine_is_icontrol() (0) -#endif
-#ifdef CONFIG_MACH_QSD8X50A_ST1_5 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_QSD8X50A_ST1_5 -# endif -# define machine_is_qsd8x50a_st1_5() (machine_arch_type == MACH_TYPE_QSD8X50A_ST1_5) -#else -# define machine_is_qsd8x50a_st1_5() (0) -#endif
-#ifdef CONFIG_MACH_MX23EVK -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MX23EVK -# endif -# define machine_is_mx23evk() (machine_arch_type == MACH_TYPE_MX23EVK) -#else -# define machine_is_mx23evk() (0) -#endif
-#ifdef CONFIG_MACH_AP4EVB -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_AP4EVB -# endif -# define machine_is_ap4evb() (machine_arch_type == MACH_TYPE_AP4EVB) -#else -# define machine_is_ap4evb() (0) -#endif
-#ifdef CONFIG_MACH_MITYOMAPL138 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MITYOMAPL138 -# endif -# define machine_is_mityomapl138() (machine_arch_type == MACH_TYPE_MITYOMAPL138) -#else -# define machine_is_mityomapl138() (0) -#endif
-#ifdef CONFIG_MACH_GURUPLUG -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_GURUPLUG -# endif -# define machine_is_guruplug() (machine_arch_type == MACH_TYPE_GURUPLUG) -#else -# define machine_is_guruplug() (0) -#endif
-#ifdef CONFIG_MACH_SPEAR310 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SPEAR310 -# endif -# define machine_is_spear310() (machine_arch_type == MACH_TYPE_SPEAR310) -#else -# define machine_is_spear310() (0) -#endif
-#ifdef CONFIG_MACH_SPEAR320 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SPEAR320 -# endif -# define machine_is_spear320() (machine_arch_type == MACH_TYPE_SPEAR320) -#else -# define machine_is_spear320() (0) -#endif
-#ifdef CONFIG_MACH_AQUILA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_AQUILA -# endif -# define machine_is_aquila() (machine_arch_type == MACH_TYPE_AQUILA) -#else -# define machine_is_aquila() (0) -#endif
-#ifdef CONFIG_MACH_ESATA_SHEEVAPLUG -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ESATA_SHEEVAPLUG -# endif -# define machine_is_sheeva_esata() (machine_arch_type == MACH_TYPE_ESATA_SHEEVAPLUG) -#else -# define machine_is_sheeva_esata() (0) -#endif
-#ifdef CONFIG_MACH_MSM7X30_SURF -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MSM7X30_SURF -# endif -# define machine_is_msm7x30_surf() (machine_arch_type == MACH_TYPE_MSM7X30_SURF) -#else -# define machine_is_msm7x30_surf() (0) -#endif
-#ifdef CONFIG_MACH_EA2478DEVKIT -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_EA2478DEVKIT -# endif -# define machine_is_ea2478devkit() (machine_arch_type == MACH_TYPE_EA2478DEVKIT) -#else -# define machine_is_ea2478devkit() (0) -#endif
-#ifdef CONFIG_MACH_TERASTATION_WXL -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TERASTATION_WXL -# endif -# define machine_is_terastation_wxl() (machine_arch_type == MACH_TYPE_TERASTATION_WXL) -#else -# define machine_is_terastation_wxl() (0) -#endif
-#ifdef CONFIG_MACH_MSM7X25_SURF -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MSM7X25_SURF -# endif -# define machine_is_msm7x25_surf() (machine_arch_type == MACH_TYPE_MSM7X25_SURF) -#else -# define machine_is_msm7x25_surf() (0) -#endif
-#ifdef CONFIG_MACH_MSM7X25_FFA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MSM7X25_FFA -# endif -# define machine_is_msm7x25_ffa() (machine_arch_type == MACH_TYPE_MSM7X25_FFA) -#else -# define machine_is_msm7x25_ffa() (0) -#endif
-#ifdef CONFIG_MACH_MSM7X27_SURF -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MSM7X27_SURF -# endif -# define machine_is_msm7x27_surf() (machine_arch_type == MACH_TYPE_MSM7X27_SURF) -#else -# define machine_is_msm7x27_surf() (0) -#endif
-#ifdef CONFIG_MACH_MSM7X27_FFA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MSM7X27_FFA -# endif -# define machine_is_msm7x27_ffa() (machine_arch_type == MACH_TYPE_MSM7X27_FFA) -#else -# define machine_is_msm7x27_ffa() (0) -#endif
-#ifdef CONFIG_MACH_MSM7X30_FFA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MSM7X30_FFA -# endif -# define machine_is_msm7x30_ffa() (machine_arch_type == MACH_TYPE_MSM7X30_FFA) -#else -# define machine_is_msm7x30_ffa() (0) -#endif
-#ifdef CONFIG_MACH_QSD8X50_SURF -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_QSD8X50_SURF -# endif -# define machine_is_qsd8x50_surf() (machine_arch_type == MACH_TYPE_QSD8X50_SURF) -#else -# define machine_is_qsd8x50_surf() (0) -#endif
-#ifdef CONFIG_MACH_MX53_EVK -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MX53_EVK -# endif -# define machine_is_mx53_evk() (machine_arch_type == MACH_TYPE_MX53_EVK) -#else -# define machine_is_mx53_evk() (0) -#endif
-#ifdef CONFIG_MACH_IGEP0030 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_IGEP0030 -# endif -# define machine_is_igep0030() (machine_arch_type == MACH_TYPE_IGEP0030) -#else -# define machine_is_igep0030() (0) -#endif
-#ifdef CONFIG_MACH_SBC3530 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SBC3530 -# endif -# define machine_is_sbc3530() (machine_arch_type == MACH_TYPE_SBC3530) -#else -# define machine_is_sbc3530() (0) -#endif
-#ifdef CONFIG_MACH_SAARB -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SAARB -# endif -# define machine_is_saarb() (machine_arch_type == MACH_TYPE_SAARB) -#else -# define machine_is_saarb() (0) -#endif
-#ifdef CONFIG_MACH_HARMONY -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_HARMONY -# endif -# define machine_is_harmony() (machine_arch_type == MACH_TYPE_HARMONY) -#else -# define machine_is_harmony() (0) -#endif
-#ifdef CONFIG_MACH_MSM7X30_FLUID -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MSM7X30_FLUID -# endif -# define machine_is_msm7x30_fluid() (machine_arch_type == MACH_TYPE_MSM7X30_FLUID) -#else -# define machine_is_msm7x30_fluid() (0) -#endif
-#ifdef CONFIG_MACH_CM_T3517 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CM_T3517 -# endif -# define machine_is_cm_t3517() (machine_arch_type == MACH_TYPE_CM_T3517) -#else -# define machine_is_cm_t3517() (0) -#endif
-#ifdef CONFIG_MACH_WBD222 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_WBD222 -# endif -# define machine_is_wbd222() (machine_arch_type == MACH_TYPE_WBD222) -#else -# define machine_is_wbd222() (0) -#endif
-#ifdef CONFIG_MACH_MSM8X60_SURF -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MSM8X60_SURF -# endif -# define machine_is_msm8x60_surf() (machine_arch_type == MACH_TYPE_MSM8X60_SURF) -#else -# define machine_is_msm8x60_surf() (0) -#endif
-#ifdef CONFIG_MACH_MSM8X60_SIM -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MSM8X60_SIM -# endif -# define machine_is_msm8x60_sim() (machine_arch_type == MACH_TYPE_MSM8X60_SIM) -#else -# define machine_is_msm8x60_sim() (0) -#endif
-#ifdef CONFIG_MACH_TCC8000_SDK -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TCC8000_SDK -# endif -# define machine_is_tcc8000_sdk() (machine_arch_type == MACH_TYPE_TCC8000_SDK) -#else -# define machine_is_tcc8000_sdk() (0) -#endif
-#ifdef CONFIG_MACH_NANOS -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NANOS -# endif -# define machine_is_nanos() (machine_arch_type == MACH_TYPE_NANOS) -#else -# define machine_is_nanos() (0) -#endif
-#ifdef CONFIG_MACH_STAMP9G45 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_STAMP9G45 -# endif -# define machine_is_stamp9g45() (machine_arch_type == MACH_TYPE_STAMP9G45) -#else -# define machine_is_stamp9g45() (0) -#endif
-#ifdef CONFIG_MACH_CNS3420VB -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CNS3420VB -# endif -# define machine_is_cns3420vb() (machine_arch_type == MACH_TYPE_CNS3420VB) -#else -# define machine_is_cns3420vb() (0) -#endif
-#ifdef CONFIG_MACH_OMAP4_PANDA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OMAP4_PANDA -# endif -# define machine_is_omap4_panda() (machine_arch_type == MACH_TYPE_OMAP4_PANDA) -#else -# define machine_is_omap4_panda() (0) -#endif
-#ifdef CONFIG_MACH_TI8168EVM -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TI8168EVM -# endif -# define machine_is_ti8168evm() (machine_arch_type == MACH_TYPE_TI8168EVM) -#else -# define machine_is_ti8168evm() (0) -#endif
-#ifdef CONFIG_MACH_TETON_BGA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TETON_BGA -# endif -# define machine_is_teton_bga() (machine_arch_type == MACH_TYPE_TETON_BGA) -#else -# define machine_is_teton_bga() (0) -#endif
-#ifdef CONFIG_MACH_EUKREA_CPUIMX25SD -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_EUKREA_CPUIMX25SD -# endif -# define machine_is_eukrea_cpuimx25sd() (machine_arch_type == MACH_TYPE_EUKREA_CPUIMX25SD) -#else -# define machine_is_eukrea_cpuimx25sd() (0) -#endif
-#ifdef CONFIG_MACH_EUKREA_CPUIMX35SD -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_EUKREA_CPUIMX35SD -# endif -# define machine_is_eukrea_cpuimx35sd() (machine_arch_type == MACH_TYPE_EUKREA_CPUIMX35SD) -#else -# define machine_is_eukrea_cpuimx35sd() (0) -#endif
-#ifdef CONFIG_MACH_EUKREA_CPUIMX51SD -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_EUKREA_CPUIMX51SD -# endif -# define machine_is_eukrea_cpuimx51sd() (machine_arch_type == MACH_TYPE_EUKREA_CPUIMX51SD) -#else -# define machine_is_eukrea_cpuimx51sd() (0) -#endif
-#ifdef CONFIG_MACH_EUKREA_CPUIMX51 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_EUKREA_CPUIMX51 -# endif -# define machine_is_eukrea_cpuimx51() (machine_arch_type == MACH_TYPE_EUKREA_CPUIMX51) -#else -# define machine_is_eukrea_cpuimx51() (0) -#endif
-#ifdef CONFIG_MACH_SMDKC210 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SMDKC210 -# endif -# define machine_is_smdkc210() (machine_arch_type == MACH_TYPE_SMDKC210) -#else -# define machine_is_smdkc210() (0) -#endif
-#ifdef CONFIG_MACH_OMAP3_BRAILLO -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OMAP3_BRAILLO -# endif -# define machine_is_omap3_braillo() (machine_arch_type == MACH_TYPE_OMAP3_BRAILLO) -#else -# define machine_is_omap3_braillo() (0) -#endif
-#ifdef CONFIG_MACH_SPYPLUG -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SPYPLUG -# endif -# define machine_is_spyplug() (machine_arch_type == MACH_TYPE_SPYPLUG) -#else -# define machine_is_spyplug() (0) -#endif
-#ifdef CONFIG_MACH_GINGER -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_GINGER -# endif -# define machine_is_ginger() (machine_arch_type == MACH_TYPE_GINGER) -#else -# define machine_is_ginger() (0) -#endif
-#ifdef CONFIG_MACH_TNY_T3530 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TNY_T3530 -# endif -# define machine_is_tny_t3530() (machine_arch_type == MACH_TYPE_TNY_T3530) -#else -# define machine_is_tny_t3530() (0) -#endif
-#ifdef CONFIG_MACH_PCA102 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_PCA102 -# endif -# define machine_is_pca102() (machine_arch_type == MACH_TYPE_PCA102) -#else -# define machine_is_pca102() (0) -#endif
-#ifdef CONFIG_MACH_SPADE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SPADE -# endif -# define machine_is_spade() (machine_arch_type == MACH_TYPE_SPADE) -#else -# define machine_is_spade() (0) -#endif
-#ifdef CONFIG_MACH_MXC25_TOPAZ -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MXC25_TOPAZ -# endif -# define machine_is_mxc25_topaz() (machine_arch_type == MACH_TYPE_MXC25_TOPAZ) -#else -# define machine_is_mxc25_topaz() (0) -#endif
-#ifdef CONFIG_MACH_T5325 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_T5325 -# endif -# define machine_is_t5325() (machine_arch_type == MACH_TYPE_T5325) -#else -# define machine_is_t5325() (0) -#endif
-#ifdef CONFIG_MACH_GW2361 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_GW2361 -# endif -# define machine_is_gw2361() (machine_arch_type == MACH_TYPE_GW2361) -#else -# define machine_is_gw2361() (0) -#endif
-#ifdef CONFIG_MACH_ELOG -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ELOG -# endif -# define machine_is_elog() (machine_arch_type == MACH_TYPE_ELOG) -#else -# define machine_is_elog() (0) -#endif
-#ifdef CONFIG_MACH_INCOME -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_INCOME -# endif -# define machine_is_income() (machine_arch_type == MACH_TYPE_INCOME) -#else -# define machine_is_income() (0) -#endif
-#ifdef CONFIG_MACH_BCM589X -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_BCM589X -# endif -# define machine_is_bcm589x() (machine_arch_type == MACH_TYPE_BCM589X) -#else -# define machine_is_bcm589x() (0) -#endif
-#ifdef CONFIG_MACH_ETNA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ETNA -# endif -# define machine_is_etna() (machine_arch_type == MACH_TYPE_ETNA) -#else -# define machine_is_etna() (0) -#endif
-#ifdef CONFIG_MACH_HAWKS -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_HAWKS -# endif -# define machine_is_hawks() (machine_arch_type == MACH_TYPE_HAWKS) -#else -# define machine_is_hawks() (0) -#endif
-#ifdef CONFIG_MACH_MESON -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MESON -# endif -# define machine_is_meson() (machine_arch_type == MACH_TYPE_MESON) -#else -# define machine_is_meson() (0) -#endif
-#ifdef CONFIG_MACH_XSBASE255 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_XSBASE255 -# endif -# define machine_is_xsbase255() (machine_arch_type == MACH_TYPE_XSBASE255) -#else -# define machine_is_xsbase255() (0) -#endif
-#ifdef CONFIG_MACH_PVM2030 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_PVM2030 -# endif -# define machine_is_pvm2030() (machine_arch_type == MACH_TYPE_PVM2030) -#else -# define machine_is_pvm2030() (0) -#endif
-#ifdef CONFIG_MACH_MIOA502 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MIOA502 -# endif -# define machine_is_mioa502() (machine_arch_type == MACH_TYPE_MIOA502) -#else -# define machine_is_mioa502() (0) -#endif
-#ifdef CONFIG_MACH_VVBOX_SDORIG2 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_VVBOX_SDORIG2 -# endif -# define machine_is_vvbox_sdorig2() (machine_arch_type == MACH_TYPE_VVBOX_SDORIG2) -#else -# define machine_is_vvbox_sdorig2() (0) -#endif
-#ifdef CONFIG_MACH_VVBOX_SDLITE2 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_VVBOX_SDLITE2 -# endif -# define machine_is_vvbox_sdlite2() (machine_arch_type == MACH_TYPE_VVBOX_SDLITE2) -#else -# define machine_is_vvbox_sdlite2() (0) -#endif
-#ifdef CONFIG_MACH_VVBOX_SDPRO4 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_VVBOX_SDPRO4 -# endif -# define machine_is_vvbox_sdpro4() (machine_arch_type == MACH_TYPE_VVBOX_SDPRO4) -#else -# define machine_is_vvbox_sdpro4() (0) -#endif
-#ifdef CONFIG_MACH_HTC_SPV_M700 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_HTC_SPV_M700 -# endif -# define machine_is_htc_spv_m700() (machine_arch_type == MACH_TYPE_HTC_SPV_M700) -#else -# define machine_is_htc_spv_m700() (0) -#endif
-#ifdef CONFIG_MACH_MX257SX -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MX257SX -# endif -# define machine_is_mx257sx() (machine_arch_type == MACH_TYPE_MX257SX) -#else -# define machine_is_mx257sx() (0) -#endif
-#ifdef CONFIG_MACH_GONI -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_GONI -# endif -# define machine_is_goni() (machine_arch_type == MACH_TYPE_GONI) -#else -# define machine_is_goni() (0) -#endif
-#ifdef CONFIG_MACH_MSM8X55_SVLTE_FFA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MSM8X55_SVLTE_FFA -# endif -# define machine_is_msm8x55_svlte_ffa() (machine_arch_type == MACH_TYPE_MSM8X55_SVLTE_FFA) -#else -# define machine_is_msm8x55_svlte_ffa() (0) -#endif
-#ifdef CONFIG_MACH_MSM8X55_SVLTE_SURF -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MSM8X55_SVLTE_SURF -# endif -# define machine_is_msm8x55_svlte_surf() (machine_arch_type == MACH_TYPE_MSM8X55_SVLTE_SURF) -#else -# define machine_is_msm8x55_svlte_surf() (0) -#endif
-#ifdef CONFIG_MACH_QUICKSTEP -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_QUICKSTEP -# endif -# define machine_is_quickstep() (machine_arch_type == MACH_TYPE_QUICKSTEP) -#else -# define machine_is_quickstep() (0) -#endif
-#ifdef CONFIG_MACH_DMW96 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DMW96 -# endif -# define machine_is_dmw96() (machine_arch_type == MACH_TYPE_DMW96) -#else -# define machine_is_dmw96() (0) -#endif
-#ifdef CONFIG_MACH_HAMMERHEAD -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_HAMMERHEAD -# endif -# define machine_is_hammerhead() (machine_arch_type == MACH_TYPE_HAMMERHEAD) -#else -# define machine_is_hammerhead() (0) -#endif
-#ifdef CONFIG_MACH_TRIDENT -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TRIDENT -# endif -# define machine_is_trident() (machine_arch_type == MACH_TYPE_TRIDENT) -#else -# define machine_is_trident() (0) -#endif
-#ifdef CONFIG_MACH_LIGHTNING -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_LIGHTNING -# endif -# define machine_is_lightning() (machine_arch_type == MACH_TYPE_LIGHTNING) -#else -# define machine_is_lightning() (0) -#endif
-#ifdef CONFIG_MACH_ICONNECT -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ICONNECT -# endif -# define machine_is_iconnect() (machine_arch_type == MACH_TYPE_ICONNECT) -#else -# define machine_is_iconnect() (0) -#endif
-#ifdef CONFIG_MACH_AUTOBOT -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_AUTOBOT -# endif -# define machine_is_autobot() (machine_arch_type == MACH_TYPE_AUTOBOT) -#else -# define machine_is_autobot() (0) -#endif
-#ifdef CONFIG_MACH_COCONUT -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_COCONUT -# endif -# define machine_is_coconut() (machine_arch_type == MACH_TYPE_COCONUT) -#else -# define machine_is_coconut() (0) -#endif
-#ifdef CONFIG_MACH_DURIAN -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DURIAN -# endif -# define machine_is_durian() (machine_arch_type == MACH_TYPE_DURIAN) -#else -# define machine_is_durian() (0) -#endif
-#ifdef CONFIG_MACH_CAYENNE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CAYENNE -# endif -# define machine_is_cayenne() (machine_arch_type == MACH_TYPE_CAYENNE) -#else -# define machine_is_cayenne() (0) -#endif
-#ifdef CONFIG_MACH_FUJI -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_FUJI -# endif -# define machine_is_fuji() (machine_arch_type == MACH_TYPE_FUJI) -#else -# define machine_is_fuji() (0) -#endif
-#ifdef CONFIG_MACH_SYNOLOGY_6282 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SYNOLOGY_6282 -# endif -# define machine_is_synology_6282() (machine_arch_type == MACH_TYPE_SYNOLOGY_6282) -#else -# define machine_is_synology_6282() (0) -#endif
-#ifdef CONFIG_MACH_EM1SY -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_EM1SY -# endif -# define machine_is_em1sy() (machine_arch_type == MACH_TYPE_EM1SY) -#else -# define machine_is_em1sy() (0) -#endif
-#ifdef CONFIG_MACH_M502 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_M502 -# endif -# define machine_is_m502() (machine_arch_type == MACH_TYPE_M502) -#else -# define machine_is_m502() (0) -#endif
-#ifdef CONFIG_MACH_MATRIX518 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MATRIX518 -# endif -# define machine_is_matrix518() (machine_arch_type == MACH_TYPE_MATRIX518) -#else -# define machine_is_matrix518() (0) -#endif
-#ifdef CONFIG_MACH_TINY_GURNARD -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TINY_GURNARD -# endif -# define machine_is_tiny_gurnard() (machine_arch_type == MACH_TYPE_TINY_GURNARD) -#else -# define machine_is_tiny_gurnard() (0) -#endif
-#ifdef CONFIG_MACH_SPEAR1310 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SPEAR1310 -# endif -# define machine_is_spear1310() (machine_arch_type == MACH_TYPE_SPEAR1310) -#else -# define machine_is_spear1310() (0) -#endif
-#ifdef CONFIG_MACH_BV07 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_BV07 -# endif -# define machine_is_bv07() (machine_arch_type == MACH_TYPE_BV07) -#else -# define machine_is_bv07() (0) -#endif
-#ifdef CONFIG_MACH_MXT_TD61 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MXT_TD61 -# endif -# define machine_is_mxt_td61() (machine_arch_type == MACH_TYPE_MXT_TD61) -#else -# define machine_is_mxt_td61() (0) -#endif
-#ifdef CONFIG_MACH_OPENRD_ULTIMATE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OPENRD_ULTIMATE -# endif -# define machine_is_openrd_ultimate() (machine_arch_type == MACH_TYPE_OPENRD_ULTIMATE) -#else -# define machine_is_openrd_ultimate() (0) -#endif
-#ifdef CONFIG_MACH_DEVIXP -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DEVIXP -# endif -# define machine_is_devixp() (machine_arch_type == MACH_TYPE_DEVIXP) -#else -# define machine_is_devixp() (0) -#endif
-#ifdef CONFIG_MACH_MICCPT -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MICCPT -# endif -# define machine_is_miccpt() (machine_arch_type == MACH_TYPE_MICCPT) -#else -# define machine_is_miccpt() (0) -#endif
-#ifdef CONFIG_MACH_MIC256 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MIC256 -# endif -# define machine_is_mic256() (machine_arch_type == MACH_TYPE_MIC256) -#else -# define machine_is_mic256() (0) -#endif
-#ifdef CONFIG_MACH_AS1167 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_AS1167 -# endif -# define machine_is_as1167() (machine_arch_type == MACH_TYPE_AS1167) -#else -# define machine_is_as1167() (0) -#endif
-#ifdef CONFIG_MACH_OMAP3_IBIZA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OMAP3_IBIZA -# endif -# define machine_is_omap3_ibiza() (machine_arch_type == MACH_TYPE_OMAP3_IBIZA) -#else -# define machine_is_omap3_ibiza() (0) -#endif
-#ifdef CONFIG_MACH_U5500 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_U5500 -# endif -# define machine_is_u5500() (machine_arch_type == MACH_TYPE_U5500) -#else -# define machine_is_u5500() (0) -#endif
-#ifdef CONFIG_MACH_DAVINCI_PICTO -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DAVINCI_PICTO -# endif -# define machine_is_davinci_picto() (machine_arch_type == MACH_TYPE_DAVINCI_PICTO) -#else -# define machine_is_davinci_picto() (0) -#endif
-#ifdef CONFIG_MACH_MECHA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MECHA -# endif -# define machine_is_mecha() (machine_arch_type == MACH_TYPE_MECHA) -#else -# define machine_is_mecha() (0) -#endif
-#ifdef CONFIG_MACH_BUBBA3 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_BUBBA3 -# endif -# define machine_is_bubba3() (machine_arch_type == MACH_TYPE_BUBBA3) -#else -# define machine_is_bubba3() (0) -#endif
-#ifdef CONFIG_MACH_PUPITRE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_PUPITRE -# endif -# define machine_is_pupitre() (machine_arch_type == MACH_TYPE_PUPITRE) -#else -# define machine_is_pupitre() (0) -#endif
-#ifdef CONFIG_MACH_TEGRA_VOGUE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TEGRA_VOGUE -# endif -# define machine_is_tegra_vogue() (machine_arch_type == MACH_TYPE_TEGRA_VOGUE) -#else -# define machine_is_tegra_vogue() (0) -#endif
-#ifdef CONFIG_MACH_TEGRA_E1165 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TEGRA_E1165 -# endif -# define machine_is_tegra_e1165() (machine_arch_type == MACH_TYPE_TEGRA_E1165) -#else -# define machine_is_tegra_e1165() (0) -#endif
-#ifdef CONFIG_MACH_SIMPLENET -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SIMPLENET -# endif -# define machine_is_simplenet() (machine_arch_type == MACH_TYPE_SIMPLENET) -#else -# define machine_is_simplenet() (0) -#endif
-#ifdef CONFIG_MACH_EC4350TBM -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_EC4350TBM -# endif -# define machine_is_ec4350tbm() (machine_arch_type == MACH_TYPE_EC4350TBM) -#else -# define machine_is_ec4350tbm() (0) -#endif
-#ifdef CONFIG_MACH_PEC_TC -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_PEC_TC -# endif -# define machine_is_pec_tc() (machine_arch_type == MACH_TYPE_PEC_TC) -#else -# define machine_is_pec_tc() (0) -#endif
-#ifdef CONFIG_MACH_PEC_HC2 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_PEC_HC2 -# endif -# define machine_is_pec_hc2() (machine_arch_type == MACH_TYPE_PEC_HC2) -#else -# define machine_is_pec_hc2() (0) -#endif
-#ifdef CONFIG_MACH_ESL_MOBILIS_A -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ESL_MOBILIS_A -# endif -# define machine_is_esl_mobilis_a() (machine_arch_type == MACH_TYPE_ESL_MOBILIS_A) -#else -# define machine_is_esl_mobilis_a() (0) -#endif
-#ifdef CONFIG_MACH_ESL_MOBILIS_B -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ESL_MOBILIS_B -# endif -# define machine_is_esl_mobilis_b() (machine_arch_type == MACH_TYPE_ESL_MOBILIS_B) -#else -# define machine_is_esl_mobilis_b() (0) -#endif
-#ifdef CONFIG_MACH_ESL_WAVE_A -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ESL_WAVE_A -# endif -# define machine_is_esl_wave_a() (machine_arch_type == MACH_TYPE_ESL_WAVE_A) -#else -# define machine_is_esl_wave_a() (0) -#endif
-#ifdef CONFIG_MACH_ESL_WAVE_B -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ESL_WAVE_B -# endif -# define machine_is_esl_wave_b() (machine_arch_type == MACH_TYPE_ESL_WAVE_B) -#else -# define machine_is_esl_wave_b() (0) -#endif
-#ifdef CONFIG_MACH_UNISENSE_MMM -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_UNISENSE_MMM -# endif -# define machine_is_unisense_mmm() (machine_arch_type == MACH_TYPE_UNISENSE_MMM) -#else -# define machine_is_unisense_mmm() (0) -#endif
-#ifdef CONFIG_MACH_BLUESHARK -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_BLUESHARK -# endif -# define machine_is_blueshark() (machine_arch_type == MACH_TYPE_BLUESHARK) -#else -# define machine_is_blueshark() (0) -#endif
-#ifdef CONFIG_MACH_E10 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_E10 -# endif -# define machine_is_e10() (machine_arch_type == MACH_TYPE_E10) -#else -# define machine_is_e10() (0) -#endif
-#ifdef CONFIG_MACH_APP3K_ROBIN -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_APP3K_ROBIN -# endif -# define machine_is_app3k_robin() (machine_arch_type == MACH_TYPE_APP3K_ROBIN) -#else -# define machine_is_app3k_robin() (0) -#endif
-#ifdef CONFIG_MACH_POV15HD -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_POV15HD -# endif -# define machine_is_pov15hd() (machine_arch_type == MACH_TYPE_POV15HD) -#else -# define machine_is_pov15hd() (0) -#endif
-#ifdef CONFIG_MACH_STELLA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_STELLA -# endif -# define machine_is_stella() (machine_arch_type == MACH_TYPE_STELLA) -#else -# define machine_is_stella() (0) -#endif
-#ifdef CONFIG_MACH_LINKSTATION_LSCHL -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_LINKSTATION_LSCHL -# endif -# define machine_is_linkstation_lschl() (machine_arch_type == MACH_TYPE_LINKSTATION_LSCHL) -#else -# define machine_is_linkstation_lschl() (0) -#endif
-#ifdef CONFIG_MACH_NETWALKER -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NETWALKER -# endif -# define machine_is_netwalker() (machine_arch_type == MACH_TYPE_NETWALKER) -#else -# define machine_is_netwalker() (0) -#endif
-#ifdef CONFIG_MACH_ACSX106 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ACSX106 -# endif -# define machine_is_acsx106() (machine_arch_type == MACH_TYPE_ACSX106) -#else -# define machine_is_acsx106() (0) -#endif
-#ifdef CONFIG_MACH_ATLAS5_C1 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ATLAS5_C1 -# endif -# define machine_is_atlas5_c1() (machine_arch_type == MACH_TYPE_ATLAS5_C1) -#else -# define machine_is_atlas5_c1() (0) -#endif
-#ifdef CONFIG_MACH_NSB3AST -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NSB3AST -# endif -# define machine_is_nsb3ast() (machine_arch_type == MACH_TYPE_NSB3AST) -#else -# define machine_is_nsb3ast() (0) -#endif
-#ifdef CONFIG_MACH_GNET_SLC -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_GNET_SLC -# endif -# define machine_is_gnet_slc() (machine_arch_type == MACH_TYPE_GNET_SLC) -#else -# define machine_is_gnet_slc() (0) -#endif
-#ifdef CONFIG_MACH_AF4000 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_AF4000 -# endif -# define machine_is_af4000() (machine_arch_type == MACH_TYPE_AF4000) -#else -# define machine_is_af4000() (0) -#endif
-#ifdef CONFIG_MACH_ARK9431 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ARK9431 -# endif -# define machine_is_ark9431() (machine_arch_type == MACH_TYPE_ARK9431) -#else -# define machine_is_ark9431() (0) -#endif
-#ifdef CONFIG_MACH_FS_S5PC100 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_FS_S5PC100 -# endif -# define machine_is_fs_s5pc100() (machine_arch_type == MACH_TYPE_FS_S5PC100) -#else -# define machine_is_fs_s5pc100() (0) -#endif
-#ifdef CONFIG_MACH_OMAP3505NOVA8 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OMAP3505NOVA8 -# endif -# define machine_is_omap3505nova8() (machine_arch_type == MACH_TYPE_OMAP3505NOVA8) -#else -# define machine_is_omap3505nova8() (0) -#endif
-#ifdef CONFIG_MACH_OMAP3621_EDP1 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OMAP3621_EDP1 -# endif -# define machine_is_omap3621_edp1() (machine_arch_type == MACH_TYPE_OMAP3621_EDP1) -#else -# define machine_is_omap3621_edp1() (0) -#endif
-#ifdef CONFIG_MACH_ORATISAES -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ORATISAES -# endif -# define machine_is_oratisaes() (machine_arch_type == MACH_TYPE_ORATISAES) -#else -# define machine_is_oratisaes() (0) -#endif
-#ifdef CONFIG_MACH_SMDKV310 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SMDKV310 -# endif -# define machine_is_smdkv310() (machine_arch_type == MACH_TYPE_SMDKV310) -#else -# define machine_is_smdkv310() (0) -#endif
-#ifdef CONFIG_MACH_SIEMENS_L0 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SIEMENS_L0 -# endif -# define machine_is_siemens_l0() (machine_arch_type == MACH_TYPE_SIEMENS_L0) -#else -# define machine_is_siemens_l0() (0) -#endif
-#ifdef CONFIG_MACH_VENTANA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_VENTANA -# endif -# define machine_is_ventana() (machine_arch_type == MACH_TYPE_VENTANA) -#else -# define machine_is_ventana() (0) -#endif
-#ifdef CONFIG_MACH_WM8505_7IN_NETBOOK -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_WM8505_7IN_NETBOOK -# endif -# define machine_is_wm8505_7in_netbook() (machine_arch_type == MACH_TYPE_WM8505_7IN_NETBOOK) -#else -# define machine_is_wm8505_7in_netbook() (0) -#endif
-#ifdef CONFIG_MACH_EC4350SDB -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_EC4350SDB -# endif -# define machine_is_ec4350sdb() (machine_arch_type == MACH_TYPE_EC4350SDB) -#else -# define machine_is_ec4350sdb() (0) -#endif
-#ifdef CONFIG_MACH_MIMAS -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MIMAS -# endif -# define machine_is_mimas() (machine_arch_type == MACH_TYPE_MIMAS) -#else -# define machine_is_mimas() (0) -#endif
-#ifdef CONFIG_MACH_TITAN -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TITAN -# endif -# define machine_is_titan() (machine_arch_type == MACH_TYPE_TITAN) -#else -# define machine_is_titan() (0) -#endif
-#ifdef CONFIG_MACH_CRANEBOARD -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CRANEBOARD -# endif -# define machine_is_craneboard() (machine_arch_type == MACH_TYPE_CRANEBOARD) -#else -# define machine_is_craneboard() (0) -#endif
-#ifdef CONFIG_MACH_ES2440 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ES2440 -# endif -# define machine_is_es2440() (machine_arch_type == MACH_TYPE_ES2440) -#else -# define machine_is_es2440() (0) -#endif
-#ifdef CONFIG_MACH_NAJAY_A9263 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NAJAY_A9263 -# endif -# define machine_is_najay_a9263() (machine_arch_type == MACH_TYPE_NAJAY_A9263) -#else -# define machine_is_najay_a9263() (0) -#endif
-#ifdef CONFIG_MACH_HTCTORNADO -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_HTCTORNADO -# endif -# define machine_is_htctornado() (machine_arch_type == MACH_TYPE_HTCTORNADO) -#else -# define machine_is_htctornado() (0) -#endif
-#ifdef CONFIG_MACH_DIMM_MX257 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DIMM_MX257 -# endif -# define machine_is_dimm_mx257() (machine_arch_type == MACH_TYPE_DIMM_MX257) -#else -# define machine_is_dimm_mx257() (0) -#endif
-#ifdef CONFIG_MACH_JIGEN -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_JIGEN -# endif -# define machine_is_jigen301() (machine_arch_type == MACH_TYPE_JIGEN) -#else -# define machine_is_jigen301() (0) -#endif
-#ifdef CONFIG_MACH_SMDK6450 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SMDK6450 -# endif -# define machine_is_smdk6450() (machine_arch_type == MACH_TYPE_SMDK6450) -#else -# define machine_is_smdk6450() (0) -#endif
-#ifdef CONFIG_MACH_MENO_QNG -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MENO_QNG -# endif -# define machine_is_meno_qng() (machine_arch_type == MACH_TYPE_MENO_QNG) -#else -# define machine_is_meno_qng() (0) -#endif
-#ifdef CONFIG_MACH_NS2416 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NS2416 -# endif -# define machine_is_ns2416() (machine_arch_type == MACH_TYPE_NS2416) -#else -# define machine_is_ns2416() (0) -#endif
-#ifdef CONFIG_MACH_RPC353 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_RPC353 -# endif -# define machine_is_rpc353() (machine_arch_type == MACH_TYPE_RPC353) -#else -# define machine_is_rpc353() (0) -#endif
-#ifdef CONFIG_MACH_TQ6410 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TQ6410 -# endif -# define machine_is_tq6410() (machine_arch_type == MACH_TYPE_TQ6410) -#else -# define machine_is_tq6410() (0) -#endif
-#ifdef CONFIG_MACH_SKY6410 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SKY6410 -# endif -# define machine_is_sky6410() (machine_arch_type == MACH_TYPE_SKY6410) -#else -# define machine_is_sky6410() (0) -#endif
-#ifdef CONFIG_MACH_DYNASTY -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DYNASTY -# endif -# define machine_is_dynasty() (machine_arch_type == MACH_TYPE_DYNASTY) -#else -# define machine_is_dynasty() (0) -#endif
-#ifdef CONFIG_MACH_VIVO -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_VIVO -# endif -# define machine_is_vivo() (machine_arch_type == MACH_TYPE_VIVO) -#else -# define machine_is_vivo() (0) -#endif
-#ifdef CONFIG_MACH_BURY_BL7582 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_BURY_BL7582 -# endif -# define machine_is_bury_bl7582() (machine_arch_type == MACH_TYPE_BURY_BL7582) -#else -# define machine_is_bury_bl7582() (0) -#endif
-#ifdef CONFIG_MACH_BURY_BPS5270 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_BURY_BPS5270 -# endif -# define machine_is_bury_bps5270() (machine_arch_type == MACH_TYPE_BURY_BPS5270) -#else -# define machine_is_bury_bps5270() (0) -#endif
-#ifdef CONFIG_MACH_BASI -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_BASI -# endif -# define machine_is_basi() (machine_arch_type == MACH_TYPE_BASI) -#else -# define machine_is_basi() (0) -#endif
-#ifdef CONFIG_MACH_TN200 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TN200 -# endif -# define machine_is_tn200() (machine_arch_type == MACH_TYPE_TN200) -#else -# define machine_is_tn200() (0) -#endif
-#ifdef CONFIG_MACH_C2MMI -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_C2MMI -# endif -# define machine_is_c2mmi() (machine_arch_type == MACH_TYPE_C2MMI) -#else -# define machine_is_c2mmi() (0) -#endif
-#ifdef CONFIG_MACH_MESON_6236M -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MESON_6236M -# endif -# define machine_is_meson_6236m() (machine_arch_type == MACH_TYPE_MESON_6236M) -#else -# define machine_is_meson_6236m() (0) -#endif
-#ifdef CONFIG_MACH_MESON_8626M -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MESON_8626M -# endif -# define machine_is_meson_8626m() (machine_arch_type == MACH_TYPE_MESON_8626M) -#else -# define machine_is_meson_8626m() (0) -#endif
-#ifdef CONFIG_MACH_TUBE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TUBE -# endif -# define machine_is_tube() (machine_arch_type == MACH_TYPE_TUBE) -#else -# define machine_is_tube() (0) -#endif
-#ifdef CONFIG_MACH_MESSINA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MESSINA -# endif -# define machine_is_messina() (machine_arch_type == MACH_TYPE_MESSINA) -#else -# define machine_is_messina() (0) -#endif
-#ifdef CONFIG_MACH_MX50_ARM2 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MX50_ARM2 -# endif -# define machine_is_mx50_arm2() (machine_arch_type == MACH_TYPE_MX50_ARM2) -#else -# define machine_is_mx50_arm2() (0) -#endif
-#ifdef CONFIG_MACH_CETUS9263 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CETUS9263 -# endif -# define machine_is_cetus9263() (machine_arch_type == MACH_TYPE_CETUS9263) -#else -# define machine_is_cetus9263() (0) -#endif
-#ifdef CONFIG_MACH_BROWNSTONE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_BROWNSTONE -# endif -# define machine_is_brownstone() (machine_arch_type == MACH_TYPE_BROWNSTONE) -#else -# define machine_is_brownstone() (0) -#endif
-#ifdef CONFIG_MACH_VMX25 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_VMX25 -# endif -# define machine_is_vmx25() (machine_arch_type == MACH_TYPE_VMX25) -#else -# define machine_is_vmx25() (0) -#endif
-#ifdef CONFIG_MACH_VMX51 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_VMX51 -# endif -# define machine_is_vmx51() (machine_arch_type == MACH_TYPE_VMX51) -#else -# define machine_is_vmx51() (0) -#endif
-#ifdef CONFIG_MACH_ABACUS -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ABACUS -# endif -# define machine_is_abacus() (machine_arch_type == MACH_TYPE_ABACUS) -#else -# define machine_is_abacus() (0) -#endif
-#ifdef CONFIG_MACH_CM4745 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CM4745 -# endif -# define machine_is_cm4745() (machine_arch_type == MACH_TYPE_CM4745) -#else -# define machine_is_cm4745() (0) -#endif
-#ifdef CONFIG_MACH_ORATISLINK -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ORATISLINK -# endif -# define machine_is_oratislink() (machine_arch_type == MACH_TYPE_ORATISLINK) -#else -# define machine_is_oratislink() (0) -#endif
-#ifdef CONFIG_MACH_DAVINCI_DM365_DVR -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DAVINCI_DM365_DVR -# endif -# define machine_is_davinci_dm365_dvr() (machine_arch_type == MACH_TYPE_DAVINCI_DM365_DVR) -#else -# define machine_is_davinci_dm365_dvr() (0) -#endif
-#ifdef CONFIG_MACH_NETVIZ -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NETVIZ -# endif -# define machine_is_netviz() (machine_arch_type == MACH_TYPE_NETVIZ) -#else -# define machine_is_netviz() (0) -#endif
-#ifdef CONFIG_MACH_FLEXIBITY -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_FLEXIBITY -# endif -# define machine_is_flexibity() (machine_arch_type == MACH_TYPE_FLEXIBITY) -#else -# define machine_is_flexibity() (0) -#endif
-#ifdef CONFIG_MACH_WLAN_COMPUTER -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_WLAN_COMPUTER -# endif -# define machine_is_wlan_computer() (machine_arch_type == MACH_TYPE_WLAN_COMPUTER) -#else -# define machine_is_wlan_computer() (0) -#endif
-#ifdef CONFIG_MACH_LPC24XX -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_LPC24XX -# endif -# define machine_is_lpc24xx() (machine_arch_type == MACH_TYPE_LPC24XX) -#else -# define machine_is_lpc24xx() (0) -#endif
-#ifdef CONFIG_MACH_SPICA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SPICA -# endif -# define machine_is_spica() (machine_arch_type == MACH_TYPE_SPICA) -#else -# define machine_is_spica() (0) -#endif
-#ifdef CONFIG_MACH_GPSDISPLAY -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_GPSDISPLAY -# endif -# define machine_is_gpsdisplay() (machine_arch_type == MACH_TYPE_GPSDISPLAY) -#else -# define machine_is_gpsdisplay() (0) -#endif
-#ifdef CONFIG_MACH_BIPNET -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_BIPNET -# endif -# define machine_is_bipnet() (machine_arch_type == MACH_TYPE_BIPNET) -#else -# define machine_is_bipnet() (0) -#endif
-#ifdef CONFIG_MACH_OVERO_CTU_INERTIAL -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OVERO_CTU_INERTIAL -# endif -# define machine_is_overo_ctu_inertial() (machine_arch_type == MACH_TYPE_OVERO_CTU_INERTIAL) -#else -# define machine_is_overo_ctu_inertial() (0) -#endif
-#ifdef CONFIG_MACH_DAVINCI_DM355_MMM -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DAVINCI_DM355_MMM -# endif -# define machine_is_davinci_dm355_mmm() (machine_arch_type == MACH_TYPE_DAVINCI_DM355_MMM) -#else -# define machine_is_davinci_dm355_mmm() (0) -#endif
-#ifdef CONFIG_MACH_PC9260_V2 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_PC9260_V2 -# endif -# define machine_is_pc9260_v2() (machine_arch_type == MACH_TYPE_PC9260_V2) -#else -# define machine_is_pc9260_v2() (0) -#endif
-#ifdef CONFIG_MACH_PTX7545 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_PTX7545 -# endif -# define machine_is_ptx7545() (machine_arch_type == MACH_TYPE_PTX7545) -#else -# define machine_is_ptx7545() (0) -#endif
-#ifdef CONFIG_MACH_TM_EFDC -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TM_EFDC -# endif -# define machine_is_tm_efdc() (machine_arch_type == MACH_TYPE_TM_EFDC) -#else -# define machine_is_tm_efdc() (0) -#endif
-#ifdef CONFIG_MACH_OMAP3_WALDO1 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OMAP3_WALDO1 -# endif -# define machine_is_omap3_waldo1() (machine_arch_type == MACH_TYPE_OMAP3_WALDO1) -#else -# define machine_is_omap3_waldo1() (0) -#endif
-#ifdef CONFIG_MACH_FLYER -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_FLYER -# endif -# define machine_is_flyer() (machine_arch_type == MACH_TYPE_FLYER) -#else -# define machine_is_flyer() (0) -#endif
-#ifdef CONFIG_MACH_TORNADO3240 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TORNADO3240 -# endif -# define machine_is_tornado3240() (machine_arch_type == MACH_TYPE_TORNADO3240) -#else -# define machine_is_tornado3240() (0) -#endif
-#ifdef CONFIG_MACH_SOLI_01 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SOLI_01 -# endif -# define machine_is_soli_01() (machine_arch_type == MACH_TYPE_SOLI_01) -#else -# define machine_is_soli_01() (0) -#endif
-#ifdef CONFIG_MACH_OMAPL138_EUROPALC -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OMAPL138_EUROPALC -# endif -# define machine_is_omapl138_europalc() (machine_arch_type == MACH_TYPE_OMAPL138_EUROPALC) -#else -# define machine_is_omapl138_europalc() (0) -#endif
-#ifdef CONFIG_MACH_HELIOS_V1 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_HELIOS_V1 -# endif -# define machine_is_helios_v1() (machine_arch_type == MACH_TYPE_HELIOS_V1) -#else -# define machine_is_helios_v1() (0) -#endif
-#ifdef CONFIG_MACH_NETSPACE_LITE_V2 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NETSPACE_LITE_V2 -# endif -# define machine_is_netspace_lite_v2() (machine_arch_type == MACH_TYPE_NETSPACE_LITE_V2) -#else -# define machine_is_netspace_lite_v2() (0) -#endif
-#ifdef CONFIG_MACH_SSC -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SSC -# endif -# define machine_is_ssc() (machine_arch_type == MACH_TYPE_SSC) -#else -# define machine_is_ssc() (0) -#endif
-#ifdef CONFIG_MACH_PREMIERWAVE_EN -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_PREMIERWAVE_EN -# endif -# define machine_is_premierwave_en() (machine_arch_type == MACH_TYPE_PREMIERWAVE_EN) -#else -# define machine_is_premierwave_en() (0) -#endif
-#ifdef CONFIG_MACH_WASABI -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_WASABI -# endif -# define machine_is_wasabi() (machine_arch_type == MACH_TYPE_WASABI) -#else -# define machine_is_wasabi() (0) -#endif
-#ifdef CONFIG_MACH_MX50_RDP -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MX50_RDP -# endif -# define machine_is_mx50_rdp() (machine_arch_type == MACH_TYPE_MX50_RDP) -#else -# define machine_is_mx50_rdp() (0) -#endif
-#ifdef CONFIG_MACH_UNIVERSAL_C210 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_UNIVERSAL_C210 -# endif -# define machine_is_universal_c210() (machine_arch_type == MACH_TYPE_UNIVERSAL_C210) -#else -# define machine_is_universal_c210() (0) -#endif
-#ifdef CONFIG_MACH_REAL6410 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_REAL6410 -# endif -# define machine_is_real6410() (machine_arch_type == MACH_TYPE_REAL6410) -#else -# define machine_is_real6410() (0) -#endif
-#ifdef CONFIG_MACH_SPX_SAKURA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SPX_SAKURA -# endif -# define machine_is_spx_sakura() (machine_arch_type == MACH_TYPE_SPX_SAKURA) -#else -# define machine_is_spx_sakura() (0) -#endif
-#ifdef CONFIG_MACH_IJ3K_2440 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_IJ3K_2440 -# endif -# define machine_is_ij3k_2440() (machine_arch_type == MACH_TYPE_IJ3K_2440) -#else -# define machine_is_ij3k_2440() (0) -#endif
-#ifdef CONFIG_MACH_OMAP3_BC10 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OMAP3_BC10 -# endif -# define machine_is_omap3_bc10() (machine_arch_type == MACH_TYPE_OMAP3_BC10) -#else -# define machine_is_omap3_bc10() (0) -#endif
-#ifdef CONFIG_MACH_THEBE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_THEBE -# endif -# define machine_is_thebe() (machine_arch_type == MACH_TYPE_THEBE) -#else -# define machine_is_thebe() (0) -#endif
-#ifdef CONFIG_MACH_RV082 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_RV082 -# endif -# define machine_is_rv082() (machine_arch_type == MACH_TYPE_RV082) -#else -# define machine_is_rv082() (0) -#endif
-#ifdef CONFIG_MACH_ARMLGUEST -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ARMLGUEST -# endif -# define machine_is_armlguest() (machine_arch_type == MACH_TYPE_ARMLGUEST) -#else -# define machine_is_armlguest() (0) -#endif
-#ifdef CONFIG_MACH_TJINC1000 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TJINC1000 -# endif -# define machine_is_tjinc1000() (machine_arch_type == MACH_TYPE_TJINC1000) -#else -# define machine_is_tjinc1000() (0) -#endif
-#ifdef CONFIG_MACH_DOCKSTAR -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DOCKSTAR -# endif -# define machine_is_dockstar() (machine_arch_type == MACH_TYPE_DOCKSTAR) -#else -# define machine_is_dockstar() (0) -#endif
-#ifdef CONFIG_MACH_AX8008 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_AX8008 -# endif -# define machine_is_ax8008() (machine_arch_type == MACH_TYPE_AX8008) -#else -# define machine_is_ax8008() (0) -#endif
-#ifdef CONFIG_MACH_GNET_SGCE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_GNET_SGCE -# endif -# define machine_is_gnet_sgce() (machine_arch_type == MACH_TYPE_GNET_SGCE) -#else -# define machine_is_gnet_sgce() (0) -#endif
-#ifdef CONFIG_MACH_PXWNAS_500_1000 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_PXWNAS_500_1000 -# endif -# define machine_is_pxwnas_500_1000() (machine_arch_type == MACH_TYPE_PXWNAS_500_1000) -#else -# define machine_is_pxwnas_500_1000() (0) -#endif
-#ifdef CONFIG_MACH_EA20 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_EA20 -# endif -# define machine_is_ea20() (machine_arch_type == MACH_TYPE_EA20) -#else -# define machine_is_ea20() (0) -#endif
-#ifdef CONFIG_MACH_AWM2 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_AWM2 -# endif -# define machine_is_awm2() (machine_arch_type == MACH_TYPE_AWM2) -#else -# define machine_is_awm2() (0) -#endif
-#ifdef CONFIG_MACH_TI8148EVM -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TI8148EVM -# endif -# define machine_is_ti8148evm() (machine_arch_type == MACH_TYPE_TI8148EVM) -#else -# define machine_is_ti8148evm() (0) -#endif
-#ifdef CONFIG_MACH_SEABOARD -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SEABOARD -# endif -# define machine_is_seaboard() (machine_arch_type == MACH_TYPE_SEABOARD) -#else -# define machine_is_seaboard() (0) -#endif
-#ifdef CONFIG_MACH_LINKSTATION_CHLV2 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_LINKSTATION_CHLV2 -# endif -# define machine_is_linkstation_chlv2() (machine_arch_type == MACH_TYPE_LINKSTATION_CHLV2) -#else -# define machine_is_linkstation_chlv2() (0) -#endif
-#ifdef CONFIG_MACH_TERA_PRO2_RACK -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TERA_PRO2_RACK -# endif -# define machine_is_tera_pro2_rack() (machine_arch_type == MACH_TYPE_TERA_PRO2_RACK) -#else -# define machine_is_tera_pro2_rack() (0) -#endif
-#ifdef CONFIG_MACH_RUBYS -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_RUBYS -# endif -# define machine_is_rubys() (machine_arch_type == MACH_TYPE_RUBYS) -#else -# define machine_is_rubys() (0) -#endif
-#ifdef CONFIG_MACH_AQUARIUS -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_AQUARIUS -# endif -# define machine_is_aquarius() (machine_arch_type == MACH_TYPE_AQUARIUS) -#else -# define machine_is_aquarius() (0) -#endif
-#ifdef CONFIG_MACH_MX53_ARD -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MX53_ARD -# endif -# define machine_is_mx53_ard() (machine_arch_type == MACH_TYPE_MX53_ARD) -#else -# define machine_is_mx53_ard() (0) -#endif
-#ifdef CONFIG_MACH_MX53_SMD -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MX53_SMD -# endif -# define machine_is_mx53_smd() (machine_arch_type == MACH_TYPE_MX53_SMD) -#else -# define machine_is_mx53_smd() (0) -#endif
-#ifdef CONFIG_MACH_LSWXL -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_LSWXL -# endif -# define machine_is_lswxl() (machine_arch_type == MACH_TYPE_LSWXL) -#else -# define machine_is_lswxl() (0) -#endif
-#ifdef CONFIG_MACH_DOVE_AVNG_V3 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DOVE_AVNG_V3 -# endif -# define machine_is_dove_avng_v3() (machine_arch_type == MACH_TYPE_DOVE_AVNG_V3) -#else -# define machine_is_dove_avng_v3() (0) -#endif
-#ifdef CONFIG_MACH_SDI_ESS_9263 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SDI_ESS_9263 -# endif -# define machine_is_sdi_ess_9263() (machine_arch_type == MACH_TYPE_SDI_ESS_9263) -#else -# define machine_is_sdi_ess_9263() (0) -#endif
-#ifdef CONFIG_MACH_JOCPU550 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_JOCPU550 -# endif -# define machine_is_jocpu550() (machine_arch_type == MACH_TYPE_JOCPU550) -#else -# define machine_is_jocpu550() (0) -#endif
-#ifdef CONFIG_MACH_MSM8X60_RUMI3 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MSM8X60_RUMI3 -# endif -# define machine_is_msm8x60_rumi3() (machine_arch_type == MACH_TYPE_MSM8X60_RUMI3) -#else -# define machine_is_msm8x60_rumi3() (0) -#endif
-#ifdef CONFIG_MACH_MSM8X60_FFA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MSM8X60_FFA -# endif -# define machine_is_msm8x60_ffa() (machine_arch_type == MACH_TYPE_MSM8X60_FFA) -#else -# define machine_is_msm8x60_ffa() (0) -#endif
-#ifdef CONFIG_MACH_YANOMAMI -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_YANOMAMI -# endif -# define machine_is_yanomami() (machine_arch_type == MACH_TYPE_YANOMAMI) -#else -# define machine_is_yanomami() (0) -#endif
-#ifdef CONFIG_MACH_GTA04 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_GTA04 -# endif -# define machine_is_gta04() (machine_arch_type == MACH_TYPE_GTA04) -#else -# define machine_is_gta04() (0) -#endif
-#ifdef CONFIG_MACH_CM_A510 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CM_A510 -# endif -# define machine_is_cm_a510() (machine_arch_type == MACH_TYPE_CM_A510) -#else -# define machine_is_cm_a510() (0) -#endif
-#ifdef CONFIG_MACH_OMAP3_RFS200 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OMAP3_RFS200 -# endif -# define machine_is_omap3_rfs200() (machine_arch_type == MACH_TYPE_OMAP3_RFS200) -#else -# define machine_is_omap3_rfs200() (0) -#endif
-#ifdef CONFIG_MACH_KX33XX -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_KX33XX -# endif -# define machine_is_kx33xx() (machine_arch_type == MACH_TYPE_KX33XX) -#else -# define machine_is_kx33xx() (0) -#endif
-#ifdef CONFIG_MACH_PTX7510 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_PTX7510 -# endif -# define machine_is_ptx7510() (machine_arch_type == MACH_TYPE_PTX7510) -#else -# define machine_is_ptx7510() (0) -#endif
-#ifdef CONFIG_MACH_TOP9000 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TOP9000 -# endif -# define machine_is_top9000() (machine_arch_type == MACH_TYPE_TOP9000) -#else -# define machine_is_top9000() (0) -#endif
-#ifdef CONFIG_MACH_TEENOTE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TEENOTE -# endif -# define machine_is_teenote() (machine_arch_type == MACH_TYPE_TEENOTE) -#else -# define machine_is_teenote() (0) -#endif
-#ifdef CONFIG_MACH_TS3 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TS3 -# endif -# define machine_is_ts3() (machine_arch_type == MACH_TYPE_TS3) -#else -# define machine_is_ts3() (0) -#endif
-#ifdef CONFIG_MACH_A0 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_A0 -# endif -# define machine_is_a0() (machine_arch_type == MACH_TYPE_A0) -#else -# define machine_is_a0() (0) -#endif
-#ifdef CONFIG_MACH_FSM9XXX_SURF -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_FSM9XXX_SURF -# endif -# define machine_is_fsm9xxx_surf() (machine_arch_type == MACH_TYPE_FSM9XXX_SURF) -#else -# define machine_is_fsm9xxx_surf() (0) -#endif
-#ifdef CONFIG_MACH_FSM9XXX_FFA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_FSM9XXX_FFA -# endif -# define machine_is_fsm9xxx_ffa() (machine_arch_type == MACH_TYPE_FSM9XXX_FFA) -#else -# define machine_is_fsm9xxx_ffa() (0) -#endif
-#ifdef CONFIG_MACH_FRRHWCDMA60W -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_FRRHWCDMA60W -# endif -# define machine_is_frrhwcdma60w() (machine_arch_type == MACH_TYPE_FRRHWCDMA60W) -#else -# define machine_is_frrhwcdma60w() (0) -#endif
-#ifdef CONFIG_MACH_REMUS -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_REMUS -# endif -# define machine_is_remus() (machine_arch_type == MACH_TYPE_REMUS) -#else -# define machine_is_remus() (0) -#endif
-#ifdef CONFIG_MACH_AT91CAP7XDK -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_AT91CAP7XDK -# endif -# define machine_is_at91cap7xdk() (machine_arch_type == MACH_TYPE_AT91CAP7XDK) -#else -# define machine_is_at91cap7xdk() (0) -#endif
-#ifdef CONFIG_MACH_AT91CAP7STK -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_AT91CAP7STK -# endif -# define machine_is_at91cap7stk() (machine_arch_type == MACH_TYPE_AT91CAP7STK) -#else -# define machine_is_at91cap7stk() (0) -#endif
-#ifdef CONFIG_MACH_KT_SBC_SAM9_1 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_KT_SBC_SAM9_1 -# endif -# define machine_is_kt_sbc_sam9_1() (machine_arch_type == MACH_TYPE_KT_SBC_SAM9_1) -#else -# define machine_is_kt_sbc_sam9_1() (0) -#endif
-#ifdef CONFIG_MACH_ARMADA_XP_DB -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ARMADA_XP_DB -# endif -# define machine_is_armada_xp_db() (machine_arch_type == MACH_TYPE_ARMADA_XP_DB) -#else -# define machine_is_armada_xp_db() (0) -#endif
-#ifdef CONFIG_MACH_SPDM -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SPDM -# endif -# define machine_is_spdm() (machine_arch_type == MACH_TYPE_SPDM) -#else -# define machine_is_spdm() (0) -#endif
-#ifdef CONFIG_MACH_GTIB -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_GTIB -# endif -# define machine_is_gtib() (machine_arch_type == MACH_TYPE_GTIB) -#else -# define machine_is_gtib() (0) -#endif
-#ifdef CONFIG_MACH_DGM3240 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DGM3240 -# endif -# define machine_is_dgm3240() (machine_arch_type == MACH_TYPE_DGM3240) -#else -# define machine_is_dgm3240() (0) -#endif
-#ifdef CONFIG_MACH_HTCMEGA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_HTCMEGA -# endif -# define machine_is_htcmega() (machine_arch_type == MACH_TYPE_HTCMEGA) -#else -# define machine_is_htcmega() (0) -#endif
-#ifdef CONFIG_MACH_TRICORDER -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TRICORDER -# endif -# define machine_is_tricorder() (machine_arch_type == MACH_TYPE_TRICORDER) -#else -# define machine_is_tricorder() (0) -#endif
-#ifdef CONFIG_MACH_TX28 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TX28 -# endif -# define machine_is_tx28() (machine_arch_type == MACH_TYPE_TX28) -#else -# define machine_is_tx28() (0) -#endif
-#ifdef CONFIG_MACH_BSTBRD -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_BSTBRD -# endif -# define machine_is_bstbrd() (machine_arch_type == MACH_TYPE_BSTBRD) -#else -# define machine_is_bstbrd() (0) -#endif
-#ifdef CONFIG_MACH_PWB3090 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_PWB3090 -# endif -# define machine_is_pwb3090() (machine_arch_type == MACH_TYPE_PWB3090) -#else -# define machine_is_pwb3090() (0) -#endif
-#ifdef CONFIG_MACH_IDEA6410 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_IDEA6410 -# endif -# define machine_is_idea6410() (machine_arch_type == MACH_TYPE_IDEA6410) -#else -# define machine_is_idea6410() (0) -#endif
-#ifdef CONFIG_MACH_QBC9263 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_QBC9263 -# endif -# define machine_is_qbc9263() (machine_arch_type == MACH_TYPE_QBC9263) -#else -# define machine_is_qbc9263() (0) -#endif
-#ifdef CONFIG_MACH_BORABORA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_BORABORA -# endif -# define machine_is_borabora() (machine_arch_type == MACH_TYPE_BORABORA) -#else -# define machine_is_borabora() (0) -#endif
-#ifdef CONFIG_MACH_VALDEZ -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_VALDEZ -# endif -# define machine_is_valdez() (machine_arch_type == MACH_TYPE_VALDEZ) -#else -# define machine_is_valdez() (0) -#endif
-#ifdef CONFIG_MACH_LS9G20 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_LS9G20 -# endif -# define machine_is_ls9g20() (machine_arch_type == MACH_TYPE_LS9G20) -#else -# define machine_is_ls9g20() (0) -#endif
-#ifdef CONFIG_MACH_MIOS_V1 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MIOS_V1 -# endif -# define machine_is_mios_v1() (machine_arch_type == MACH_TYPE_MIOS_V1) -#else -# define machine_is_mios_v1() (0) -#endif
-#ifdef CONFIG_MACH_S5PC110_CRESPO -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_S5PC110_CRESPO -# endif -# define machine_is_s5pc110_crespo() (machine_arch_type == MACH_TYPE_S5PC110_CRESPO) -#else -# define machine_is_s5pc110_crespo() (0) -#endif
-#ifdef CONFIG_MACH_CONTROLTEK9G20 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CONTROLTEK9G20 -# endif -# define machine_is_controltek9g20() (machine_arch_type == MACH_TYPE_CONTROLTEK9G20) -#else -# define machine_is_controltek9g20() (0) -#endif
-#ifdef CONFIG_MACH_TIN307 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TIN307 -# endif -# define machine_is_tin307() (machine_arch_type == MACH_TYPE_TIN307) -#else -# define machine_is_tin307() (0) -#endif
-#ifdef CONFIG_MACH_TIN510 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TIN510 -# endif -# define machine_is_tin510() (machine_arch_type == MACH_TYPE_TIN510) -#else -# define machine_is_tin510() (0) -#endif
-#ifdef CONFIG_MACH_BLUECHEESE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_BLUECHEESE -# endif -# define machine_is_bluecheese() (machine_arch_type == MACH_TYPE_BLUECHEESE) -#else -# define machine_is_bluecheese() (0) -#endif
-#ifdef CONFIG_MACH_TEM3X30 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TEM3X30 -# endif -# define machine_is_tem3x30() (machine_arch_type == MACH_TYPE_TEM3X30) -#else -# define machine_is_tem3x30() (0) -#endif
-#ifdef CONFIG_MACH_HARVEST_DESOTO -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_HARVEST_DESOTO -# endif -# define machine_is_harvest_desoto() (machine_arch_type == MACH_TYPE_HARVEST_DESOTO) -#else -# define machine_is_harvest_desoto() (0) -#endif
-#ifdef CONFIG_MACH_MSM8X60_QRDC -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MSM8X60_QRDC -# endif -# define machine_is_msm8x60_qrdc() (machine_arch_type == MACH_TYPE_MSM8X60_QRDC) -#else -# define machine_is_msm8x60_qrdc() (0) -#endif
-#ifdef CONFIG_MACH_SPEAR900 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SPEAR900 -# endif -# define machine_is_spear900() (machine_arch_type == MACH_TYPE_SPEAR900) -#else -# define machine_is_spear900() (0) -#endif
-#ifdef CONFIG_MACH_PCONTROL_G20 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_PCONTROL_G20 -# endif -# define machine_is_pcontrol_g20() (machine_arch_type == MACH_TYPE_PCONTROL_G20) -#else -# define machine_is_pcontrol_g20() (0) -#endif
-#ifdef CONFIG_MACH_RDSTOR -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_RDSTOR -# endif -# define machine_is_rdstor() (machine_arch_type == MACH_TYPE_RDSTOR) -#else -# define machine_is_rdstor() (0) -#endif
-#ifdef CONFIG_MACH_USDLOADER -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_USDLOADER -# endif -# define machine_is_usdloader() (machine_arch_type == MACH_TYPE_USDLOADER) -#else -# define machine_is_usdloader() (0) -#endif
-#ifdef CONFIG_MACH_TSOPLOADER -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TSOPLOADER -# endif -# define machine_is_tsoploader() (machine_arch_type == MACH_TYPE_TSOPLOADER) -#else -# define machine_is_tsoploader() (0) -#endif
-#ifdef CONFIG_MACH_KRONOS -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_KRONOS -# endif -# define machine_is_kronos() (machine_arch_type == MACH_TYPE_KRONOS) -#else -# define machine_is_kronos() (0) -#endif
-#ifdef CONFIG_MACH_FFCORE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_FFCORE -# endif -# define machine_is_ffcore() (machine_arch_type == MACH_TYPE_FFCORE) -#else -# define machine_is_ffcore() (0) -#endif
-#ifdef CONFIG_MACH_MONE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MONE -# endif -# define machine_is_mone() (machine_arch_type == MACH_TYPE_MONE) -#else -# define machine_is_mone() (0) -#endif
-#ifdef CONFIG_MACH_UNIT2S -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_UNIT2S -# endif -# define machine_is_unit2s() (machine_arch_type == MACH_TYPE_UNIT2S) -#else -# define machine_is_unit2s() (0) -#endif
-#ifdef CONFIG_MACH_ACER_A5 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ACER_A5 -# endif -# define machine_is_acer_a5() (machine_arch_type == MACH_TYPE_ACER_A5) -#else -# define machine_is_acer_a5() (0) -#endif
-#ifdef CONFIG_MACH_ETHERPRO_ISP -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ETHERPRO_ISP -# endif -# define machine_is_etherpro_isp() (machine_arch_type == MACH_TYPE_ETHERPRO_ISP) -#else -# define machine_is_etherpro_isp() (0) -#endif
-#ifdef CONFIG_MACH_STRETCHS7000 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_STRETCHS7000 -# endif -# define machine_is_stretchs7000() (machine_arch_type == MACH_TYPE_STRETCHS7000) -#else -# define machine_is_stretchs7000() (0) -#endif
-#ifdef CONFIG_MACH_P87_SMARTSIM -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_P87_SMARTSIM -# endif -# define machine_is_p87_smartsim() (machine_arch_type == MACH_TYPE_P87_SMARTSIM) -#else -# define machine_is_p87_smartsim() (0) -#endif
-#ifdef CONFIG_MACH_TULIP -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TULIP -# endif -# define machine_is_tulip() (machine_arch_type == MACH_TYPE_TULIP) -#else -# define machine_is_tulip() (0) -#endif
-#ifdef CONFIG_MACH_SUNFLOWER -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SUNFLOWER -# endif -# define machine_is_sunflower() (machine_arch_type == MACH_TYPE_SUNFLOWER) -#else -# define machine_is_sunflower() (0) -#endif
-#ifdef CONFIG_MACH_RIB -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_RIB -# endif -# define machine_is_rib() (machine_arch_type == MACH_TYPE_RIB) -#else -# define machine_is_rib() (0) -#endif
-#ifdef CONFIG_MACH_CLOD -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CLOD -# endif -# define machine_is_clod() (machine_arch_type == MACH_TYPE_CLOD) -#else -# define machine_is_clod() (0) -#endif
-#ifdef CONFIG_MACH_RUMP -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_RUMP -# endif -# define machine_is_rump() (machine_arch_type == MACH_TYPE_RUMP) -#else -# define machine_is_rump() (0) -#endif
-#ifdef CONFIG_MACH_TENDERLOIN -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TENDERLOIN -# endif -# define machine_is_tenderloin() (machine_arch_type == MACH_TYPE_TENDERLOIN) -#else -# define machine_is_tenderloin() (0) -#endif
-#ifdef CONFIG_MACH_SHORTLOIN -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SHORTLOIN -# endif -# define machine_is_shortloin() (machine_arch_type == MACH_TYPE_SHORTLOIN) -#else -# define machine_is_shortloin() (0) -#endif
-#ifdef CONFIG_MACH_ANTARES -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ANTARES -# endif -# define machine_is_antares() (machine_arch_type == MACH_TYPE_ANTARES) -#else -# define machine_is_antares() (0) -#endif
-#ifdef CONFIG_MACH_WB40N -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_WB40N -# endif -# define machine_is_wb40n() (machine_arch_type == MACH_TYPE_WB40N) -#else -# define machine_is_wb40n() (0) -#endif
-#ifdef CONFIG_MACH_HERRING -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_HERRING -# endif -# define machine_is_herring() (machine_arch_type == MACH_TYPE_HERRING) -#else -# define machine_is_herring() (0) -#endif
-#ifdef CONFIG_MACH_NAXY400 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NAXY400 -# endif -# define machine_is_naxy400() (machine_arch_type == MACH_TYPE_NAXY400) -#else -# define machine_is_naxy400() (0) -#endif
-#ifdef CONFIG_MACH_NAXY1200 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NAXY1200 -# endif -# define machine_is_naxy1200() (machine_arch_type == MACH_TYPE_NAXY1200) -#else -# define machine_is_naxy1200() (0) -#endif
-#ifdef CONFIG_MACH_VPR200 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_VPR200 -# endif -# define machine_is_vpr200() (machine_arch_type == MACH_TYPE_VPR200) -#else -# define machine_is_vpr200() (0) -#endif
-#ifdef CONFIG_MACH_BUG20 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_BUG20 -# endif -# define machine_is_bug20() (machine_arch_type == MACH_TYPE_BUG20) -#else -# define machine_is_bug20() (0) -#endif
-#ifdef CONFIG_MACH_GOFLEXNET -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_GOFLEXNET -# endif -# define machine_is_goflexnet() (machine_arch_type == MACH_TYPE_GOFLEXNET) -#else -# define machine_is_goflexnet() (0) -#endif
-#ifdef CONFIG_MACH_TORBRECK -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TORBRECK -# endif -# define machine_is_torbreck() (machine_arch_type == MACH_TYPE_TORBRECK) -#else -# define machine_is_torbreck() (0) -#endif
-#ifdef CONFIG_MACH_SAARB_MG1 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SAARB_MG1 -# endif -# define machine_is_saarb_mg1() (machine_arch_type == MACH_TYPE_SAARB_MG1) -#else -# define machine_is_saarb_mg1() (0) -#endif
-#ifdef CONFIG_MACH_CALLISTO -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CALLISTO -# endif -# define machine_is_callisto() (machine_arch_type == MACH_TYPE_CALLISTO) -#else -# define machine_is_callisto() (0) -#endif
-#ifdef CONFIG_MACH_MULTHSU -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MULTHSU -# endif -# define machine_is_multhsu() (machine_arch_type == MACH_TYPE_MULTHSU) -#else -# define machine_is_multhsu() (0) -#endif
-#ifdef CONFIG_MACH_SALUDA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SALUDA -# endif -# define machine_is_saluda() (machine_arch_type == MACH_TYPE_SALUDA) -#else -# define machine_is_saluda() (0) -#endif
-#ifdef CONFIG_MACH_PEMP_OMAP3_APOLLO -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_PEMP_OMAP3_APOLLO -# endif -# define machine_is_pemp_omap3_apollo() (machine_arch_type == MACH_TYPE_PEMP_OMAP3_APOLLO) -#else -# define machine_is_pemp_omap3_apollo() (0) -#endif
-#ifdef CONFIG_MACH_VC0718 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_VC0718 -# endif -# define machine_is_vc0718() (machine_arch_type == MACH_TYPE_VC0718) -#else -# define machine_is_vc0718() (0) -#endif
-#ifdef CONFIG_MACH_MVBLX -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MVBLX -# endif -# define machine_is_mvblx() (machine_arch_type == MACH_TYPE_MVBLX) -#else -# define machine_is_mvblx() (0) -#endif
-#ifdef CONFIG_MACH_INHAND_APEIRON -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_INHAND_APEIRON -# endif -# define machine_is_inhand_apeiron() (machine_arch_type == MACH_TYPE_INHAND_APEIRON) -#else -# define machine_is_inhand_apeiron() (0) -#endif
-#ifdef CONFIG_MACH_INHAND_FURY -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_INHAND_FURY -# endif -# define machine_is_inhand_fury() (machine_arch_type == MACH_TYPE_INHAND_FURY) -#else -# define machine_is_inhand_fury() (0) -#endif
-#ifdef CONFIG_MACH_INHAND_SIREN -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_INHAND_SIREN -# endif -# define machine_is_inhand_siren() (machine_arch_type == MACH_TYPE_INHAND_SIREN) -#else -# define machine_is_inhand_siren() (0) -#endif
-#ifdef CONFIG_MACH_HDNVP -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_HDNVP -# endif -# define machine_is_hdnvp() (machine_arch_type == MACH_TYPE_HDNVP) -#else -# define machine_is_hdnvp() (0) -#endif
-#ifdef CONFIG_MACH_SOFTWINNER -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SOFTWINNER -# endif -# define machine_is_softwinner() (machine_arch_type == MACH_TYPE_SOFTWINNER) -#else -# define machine_is_softwinner() (0) -#endif
-#ifdef CONFIG_MACH_PRIMA2_EVB -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_PRIMA2_EVB -# endif -# define machine_is_prima2_evb() (machine_arch_type == MACH_TYPE_PRIMA2_EVB) -#else -# define machine_is_prima2_evb() (0) -#endif
-#ifdef CONFIG_MACH_NAS6210 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NAS6210 -# endif -# define machine_is_nas6210() (machine_arch_type == MACH_TYPE_NAS6210) -#else -# define machine_is_nas6210() (0) -#endif
-#ifdef CONFIG_MACH_UNISDEV -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_UNISDEV -# endif -# define machine_is_unisdev() (machine_arch_type == MACH_TYPE_UNISDEV) -#else -# define machine_is_unisdev() (0) -#endif
-#ifdef CONFIG_MACH_SBCA11 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SBCA11 -# endif -# define machine_is_sbca11() (machine_arch_type == MACH_TYPE_SBCA11) -#else -# define machine_is_sbca11() (0) -#endif
-#ifdef CONFIG_MACH_SAGA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SAGA -# endif -# define machine_is_saga() (machine_arch_type == MACH_TYPE_SAGA) -#else -# define machine_is_saga() (0) -#endif
-#ifdef CONFIG_MACH_NS_K330 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NS_K330 -# endif -# define machine_is_ns_k330() (machine_arch_type == MACH_TYPE_NS_K330) -#else -# define machine_is_ns_k330() (0) -#endif
-#ifdef CONFIG_MACH_TANNA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TANNA -# endif -# define machine_is_tanna() (machine_arch_type == MACH_TYPE_TANNA) -#else -# define machine_is_tanna() (0) -#endif
-#ifdef CONFIG_MACH_IMATE8502 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_IMATE8502 -# endif -# define machine_is_imate8502() (machine_arch_type == MACH_TYPE_IMATE8502) -#else -# define machine_is_imate8502() (0) -#endif
-#ifdef CONFIG_MACH_ASPEN -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ASPEN -# endif -# define machine_is_aspen() (machine_arch_type == MACH_TYPE_ASPEN) -#else -# define machine_is_aspen() (0) -#endif
-#ifdef CONFIG_MACH_DAINTREE_CWAC -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DAINTREE_CWAC -# endif -# define machine_is_daintree_cwac() (machine_arch_type == MACH_TYPE_DAINTREE_CWAC) -#else -# define machine_is_daintree_cwac() (0) -#endif
-#ifdef CONFIG_MACH_ZMX25 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ZMX25 -# endif -# define machine_is_zmx25() (machine_arch_type == MACH_TYPE_ZMX25) -#else -# define machine_is_zmx25() (0) -#endif
-#ifdef CONFIG_MACH_MAPLE1 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MAPLE1 -# endif -# define machine_is_maple1() (machine_arch_type == MACH_TYPE_MAPLE1) -#else -# define machine_is_maple1() (0) -#endif
-#ifdef CONFIG_MACH_QSD8X72_SURF -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_QSD8X72_SURF -# endif -# define machine_is_qsd8x72_surf() (machine_arch_type == MACH_TYPE_QSD8X72_SURF) -#else -# define machine_is_qsd8x72_surf() (0) -#endif
-#ifdef CONFIG_MACH_QSD8X72_FFA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_QSD8X72_FFA -# endif -# define machine_is_qsd8x72_ffa() (machine_arch_type == MACH_TYPE_QSD8X72_FFA) -#else -# define machine_is_qsd8x72_ffa() (0) -#endif
-#ifdef CONFIG_MACH_ABILENE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ABILENE -# endif -# define machine_is_abilene() (machine_arch_type == MACH_TYPE_ABILENE) -#else -# define machine_is_abilene() (0) -#endif
-#ifdef CONFIG_MACH_EIGEN_TTR -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_EIGEN_TTR -# endif -# define machine_is_eigen_ttr() (machine_arch_type == MACH_TYPE_EIGEN_TTR) -#else -# define machine_is_eigen_ttr() (0) -#endif
-#ifdef CONFIG_MACH_IOMEGA_IX2_200 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_IOMEGA_IX2_200 -# endif -# define machine_is_iomega_ix2_200() (machine_arch_type == MACH_TYPE_IOMEGA_IX2_200) -#else -# define machine_is_iomega_ix2_200() (0) -#endif
-#ifdef CONFIG_MACH_CORETEC_VCX7400 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CORETEC_VCX7400 -# endif -# define machine_is_coretec_vcx7400() (machine_arch_type == MACH_TYPE_CORETEC_VCX7400) -#else -# define machine_is_coretec_vcx7400() (0) -#endif
-#ifdef CONFIG_MACH_SANTIAGO -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SANTIAGO -# endif -# define machine_is_santiago() (machine_arch_type == MACH_TYPE_SANTIAGO) -#else -# define machine_is_santiago() (0) -#endif
-#ifdef CONFIG_MACH_MX257SOL -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MX257SOL -# endif -# define machine_is_mx257sol() (machine_arch_type == MACH_TYPE_MX257SOL) -#else -# define machine_is_mx257sol() (0) -#endif
-#ifdef CONFIG_MACH_STRASBOURG -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_STRASBOURG -# endif -# define machine_is_strasbourg() (machine_arch_type == MACH_TYPE_STRASBOURG) -#else -# define machine_is_strasbourg() (0) -#endif
-#ifdef CONFIG_MACH_MSM8X60_FLUID -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MSM8X60_FLUID -# endif -# define machine_is_msm8x60_fluid() (machine_arch_type == MACH_TYPE_MSM8X60_FLUID) -#else -# define machine_is_msm8x60_fluid() (0) -#endif
-#ifdef CONFIG_MACH_SMARTQV5 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SMARTQV5 -# endif -# define machine_is_smartqv5() (machine_arch_type == MACH_TYPE_SMARTQV5) -#else -# define machine_is_smartqv5() (0) -#endif
-#ifdef CONFIG_MACH_SMARTQV3 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SMARTQV3 -# endif -# define machine_is_smartqv3() (machine_arch_type == MACH_TYPE_SMARTQV3) -#else -# define machine_is_smartqv3() (0) -#endif
-#ifdef CONFIG_MACH_SMARTQV7 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SMARTQV7 -# endif -# define machine_is_smartqv7() (machine_arch_type == MACH_TYPE_SMARTQV7) -#else -# define machine_is_smartqv7() (0) -#endif
-#ifdef CONFIG_MACH_PAZ00 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_PAZ00 -# endif -# define machine_is_paz00() (machine_arch_type == MACH_TYPE_PAZ00) -#else -# define machine_is_paz00() (0) -#endif
-#ifdef CONFIG_MACH_ACMENETUSFOXG20 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ACMENETUSFOXG20 -# endif -# define machine_is_acmenetusfoxg20() (machine_arch_type == MACH_TYPE_ACMENETUSFOXG20) -#else -# define machine_is_acmenetusfoxg20() (0) -#endif
-#ifdef CONFIG_MACH_FWBD_0404 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_FWBD_0404 -# endif -# define machine_is_fwbd_0404() (machine_arch_type == MACH_TYPE_FWBD_0404) -#else -# define machine_is_fwbd_0404() (0) -#endif
-#ifdef CONFIG_MACH_HDGU -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_HDGU -# endif -# define machine_is_hdgu() (machine_arch_type == MACH_TYPE_HDGU) -#else -# define machine_is_hdgu() (0) -#endif
-#ifdef CONFIG_MACH_PYRAMID -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_PYRAMID -# endif -# define machine_is_pyramid() (machine_arch_type == MACH_TYPE_PYRAMID) -#else -# define machine_is_pyramid() (0) -#endif
-#ifdef CONFIG_MACH_EPIPHAN -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_EPIPHAN -# endif -# define machine_is_epiphan() (machine_arch_type == MACH_TYPE_EPIPHAN) -#else -# define machine_is_epiphan() (0) -#endif
-#ifdef CONFIG_MACH_OMAP_BENDER -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OMAP_BENDER -# endif -# define machine_is_omap_bender() (machine_arch_type == MACH_TYPE_OMAP_BENDER) -#else -# define machine_is_omap_bender() (0) -#endif
-#ifdef CONFIG_MACH_GURNARD -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_GURNARD -# endif -# define machine_is_gurnard() (machine_arch_type == MACH_TYPE_GURNARD) -#else -# define machine_is_gurnard() (0) -#endif
-#ifdef CONFIG_MACH_GTL_IT5100 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_GTL_IT5100 -# endif -# define machine_is_gtl_it5100() (machine_arch_type == MACH_TYPE_GTL_IT5100) -#else -# define machine_is_gtl_it5100() (0) -#endif
-#ifdef CONFIG_MACH_BCM2708 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_BCM2708 -# endif -# define machine_is_bcm2708() (machine_arch_type == MACH_TYPE_BCM2708) -#else -# define machine_is_bcm2708() (0) -#endif
-#ifdef CONFIG_MACH_MX51_GGC -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MX51_GGC -# endif -# define machine_is_mx51_ggc() (machine_arch_type == MACH_TYPE_MX51_GGC) -#else -# define machine_is_mx51_ggc() (0) -#endif
-#ifdef CONFIG_MACH_SHARESPACE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SHARESPACE -# endif -# define machine_is_sharespace() (machine_arch_type == MACH_TYPE_SHARESPACE) -#else -# define machine_is_sharespace() (0) -#endif
-#ifdef CONFIG_MACH_HABA_KNX_EXPLORER -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_HABA_KNX_EXPLORER -# endif -# define machine_is_haba_knx_explorer() (machine_arch_type == MACH_TYPE_HABA_KNX_EXPLORER) -#else -# define machine_is_haba_knx_explorer() (0) -#endif
-#ifdef CONFIG_MACH_SIMTEC_KIRKMOD -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SIMTEC_KIRKMOD -# endif -# define machine_is_simtec_kirkmod() (machine_arch_type == MACH_TYPE_SIMTEC_KIRKMOD) -#else -# define machine_is_simtec_kirkmod() (0) -#endif
-#ifdef CONFIG_MACH_CRUX -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CRUX -# endif -# define machine_is_crux() (machine_arch_type == MACH_TYPE_CRUX) -#else -# define machine_is_crux() (0) -#endif
-#ifdef CONFIG_MACH_MX51_BRAVO -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MX51_BRAVO -# endif -# define machine_is_mx51_bravo() (machine_arch_type == MACH_TYPE_MX51_BRAVO) -#else -# define machine_is_mx51_bravo() (0) -#endif
-#ifdef CONFIG_MACH_CHARON -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CHARON -# endif -# define machine_is_charon() (machine_arch_type == MACH_TYPE_CHARON) -#else -# define machine_is_charon() (0) -#endif
-#ifdef CONFIG_MACH_PICOCOM3 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_PICOCOM3 -# endif -# define machine_is_picocom3() (machine_arch_type == MACH_TYPE_PICOCOM3) -#else -# define machine_is_picocom3() (0) -#endif
-#ifdef CONFIG_MACH_PICOCOM4 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_PICOCOM4 -# endif -# define machine_is_picocom4() (machine_arch_type == MACH_TYPE_PICOCOM4) -#else -# define machine_is_picocom4() (0) -#endif
-#ifdef CONFIG_MACH_SERRANO -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SERRANO -# endif -# define machine_is_serrano() (machine_arch_type == MACH_TYPE_SERRANO) -#else -# define machine_is_serrano() (0) -#endif
-#ifdef CONFIG_MACH_DOUBLESHOT -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DOUBLESHOT -# endif -# define machine_is_doubleshot() (machine_arch_type == MACH_TYPE_DOUBLESHOT) -#else -# define machine_is_doubleshot() (0) -#endif
-#ifdef CONFIG_MACH_EVSY -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_EVSY -# endif -# define machine_is_evsy() (machine_arch_type == MACH_TYPE_EVSY) -#else -# define machine_is_evsy() (0) -#endif
-#ifdef CONFIG_MACH_HUASHAN -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_HUASHAN -# endif -# define machine_is_huashan() (machine_arch_type == MACH_TYPE_HUASHAN) -#else -# define machine_is_huashan() (0) -#endif
-#ifdef CONFIG_MACH_LAUSANNE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_LAUSANNE -# endif -# define machine_is_lausanne() (machine_arch_type == MACH_TYPE_LAUSANNE) -#else -# define machine_is_lausanne() (0) -#endif
-#ifdef CONFIG_MACH_EMERALD -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_EMERALD -# endif -# define machine_is_emerald() (machine_arch_type == MACH_TYPE_EMERALD) -#else -# define machine_is_emerald() (0) -#endif
-#ifdef CONFIG_MACH_TQMA35 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TQMA35 -# endif -# define machine_is_tqma35() (machine_arch_type == MACH_TYPE_TQMA35) -#else -# define machine_is_tqma35() (0) -#endif
-#ifdef CONFIG_MACH_MARVEL -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MARVEL -# endif -# define machine_is_marvel() (machine_arch_type == MACH_TYPE_MARVEL) -#else -# define machine_is_marvel() (0) -#endif
-#ifdef CONFIG_MACH_MANUAE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MANUAE -# endif -# define machine_is_manuae() (machine_arch_type == MACH_TYPE_MANUAE) -#else -# define machine_is_manuae() (0) -#endif
-#ifdef CONFIG_MACH_CHACHA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CHACHA -# endif -# define machine_is_chacha() (machine_arch_type == MACH_TYPE_CHACHA) -#else -# define machine_is_chacha() (0) -#endif
-#ifdef CONFIG_MACH_LEMON -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_LEMON -# endif -# define machine_is_lemon() (machine_arch_type == MACH_TYPE_LEMON) -#else -# define machine_is_lemon() (0) -#endif
-#ifdef CONFIG_MACH_CSC -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CSC -# endif -# define machine_is_csc() (machine_arch_type == MACH_TYPE_CSC) -#else -# define machine_is_csc() (0) -#endif
-#ifdef CONFIG_MACH_GIRA_KNXIP_ROUTER -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_GIRA_KNXIP_ROUTER -# endif -# define machine_is_gira_knxip_router() (machine_arch_type == MACH_TYPE_GIRA_KNXIP_ROUTER) -#else -# define machine_is_gira_knxip_router() (0) -#endif
-#ifdef CONFIG_MACH_T20 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_T20 -# endif -# define machine_is_t20() (machine_arch_type == MACH_TYPE_T20) -#else -# define machine_is_t20() (0) -#endif
-#ifdef CONFIG_MACH_HDMINI -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_HDMINI -# endif -# define machine_is_hdmini() (machine_arch_type == MACH_TYPE_HDMINI) -#else -# define machine_is_hdmini() (0) -#endif
-#ifdef CONFIG_MACH_SCIPHONE_G2 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SCIPHONE_G2 -# endif -# define machine_is_sciphone_g2() (machine_arch_type == MACH_TYPE_SCIPHONE_G2) -#else -# define machine_is_sciphone_g2() (0) -#endif
-#ifdef CONFIG_MACH_EXPRESS -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_EXPRESS -# endif -# define machine_is_express() (machine_arch_type == MACH_TYPE_EXPRESS) -#else -# define machine_is_express() (0) -#endif
-#ifdef CONFIG_MACH_EXPRESS_KT -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_EXPRESS_KT -# endif -# define machine_is_express_kt() (machine_arch_type == MACH_TYPE_EXPRESS_KT) -#else -# define machine_is_express_kt() (0) -#endif
-#ifdef CONFIG_MACH_MAXIMASP -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MAXIMASP -# endif -# define machine_is_maximasp() (machine_arch_type == MACH_TYPE_MAXIMASP) -#else -# define machine_is_maximasp() (0) -#endif
-#ifdef CONFIG_MACH_NITROGEN_IMX51 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NITROGEN_IMX51 -# endif -# define machine_is_nitrogen_imx51() (machine_arch_type == MACH_TYPE_NITROGEN_IMX51) -#else -# define machine_is_nitrogen_imx51() (0) -#endif
-#ifdef CONFIG_MACH_NITROGEN_IMX53 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NITROGEN_IMX53 -# endif -# define machine_is_nitrogen_imx53() (machine_arch_type == MACH_TYPE_NITROGEN_IMX53) -#else -# define machine_is_nitrogen_imx53() (0) -#endif
-#ifdef CONFIG_MACH_SUNFIRE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SUNFIRE -# endif -# define machine_is_sunfire() (machine_arch_type == MACH_TYPE_SUNFIRE) -#else -# define machine_is_sunfire() (0) -#endif
-#ifdef CONFIG_MACH_AROWANA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_AROWANA -# endif -# define machine_is_arowana() (machine_arch_type == MACH_TYPE_AROWANA) -#else -# define machine_is_arowana() (0) -#endif
-#ifdef CONFIG_MACH_TEGRA_DAYTONA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TEGRA_DAYTONA -# endif -# define machine_is_tegra_daytona() (machine_arch_type == MACH_TYPE_TEGRA_DAYTONA) -#else -# define machine_is_tegra_daytona() (0) -#endif
-#ifdef CONFIG_MACH_TEGRA_SWORDFISH -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TEGRA_SWORDFISH -# endif -# define machine_is_tegra_swordfish() (machine_arch_type == MACH_TYPE_TEGRA_SWORDFISH) -#else -# define machine_is_tegra_swordfish() (0) -#endif
-#ifdef CONFIG_MACH_EDISON -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_EDISON -# endif -# define machine_is_edison() (machine_arch_type == MACH_TYPE_EDISON) -#else -# define machine_is_edison() (0) -#endif
-#ifdef CONFIG_MACH_SVP8500V1 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SVP8500V1 -# endif -# define machine_is_svp8500v1() (machine_arch_type == MACH_TYPE_SVP8500V1) -#else -# define machine_is_svp8500v1() (0) -#endif
-#ifdef CONFIG_MACH_SVP8500V2 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SVP8500V2 -# endif -# define machine_is_svp8500v2() (machine_arch_type == MACH_TYPE_SVP8500V2) -#else -# define machine_is_svp8500v2() (0) -#endif
-#ifdef CONFIG_MACH_SVP5500 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SVP5500 -# endif -# define machine_is_svp5500() (machine_arch_type == MACH_TYPE_SVP5500) -#else -# define machine_is_svp5500() (0) -#endif
-#ifdef CONFIG_MACH_B5500 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_B5500 -# endif -# define machine_is_b5500() (machine_arch_type == MACH_TYPE_B5500) -#else -# define machine_is_b5500() (0) -#endif
-#ifdef CONFIG_MACH_S5500 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_S5500 -# endif -# define machine_is_s5500() (machine_arch_type == MACH_TYPE_S5500) -#else -# define machine_is_s5500() (0) -#endif
-#ifdef CONFIG_MACH_ICON -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ICON -# endif -# define machine_is_icon() (machine_arch_type == MACH_TYPE_ICON) -#else -# define machine_is_icon() (0) -#endif
-#ifdef CONFIG_MACH_ELEPHANT -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ELEPHANT -# endif -# define machine_is_elephant() (machine_arch_type == MACH_TYPE_ELEPHANT) -#else -# define machine_is_elephant() (0) -#endif
-#ifdef CONFIG_MACH_SHOOTER -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SHOOTER -# endif -# define machine_is_shooter() (machine_arch_type == MACH_TYPE_SHOOTER) -#else -# define machine_is_shooter() (0) -#endif
-#ifdef CONFIG_MACH_SPADE_LTE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SPADE_LTE -# endif -# define machine_is_spade_lte() (machine_arch_type == MACH_TYPE_SPADE_LTE) -#else -# define machine_is_spade_lte() (0) -#endif
-#ifdef CONFIG_MACH_PHILHWANI -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_PHILHWANI -# endif -# define machine_is_philhwani() (machine_arch_type == MACH_TYPE_PHILHWANI) -#else -# define machine_is_philhwani() (0) -#endif
-#ifdef CONFIG_MACH_GSNCOMM -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_GSNCOMM -# endif -# define machine_is_gsncomm() (machine_arch_type == MACH_TYPE_GSNCOMM) -#else -# define machine_is_gsncomm() (0) -#endif
-#ifdef CONFIG_MACH_STRASBOURG_A2 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_STRASBOURG_A2 -# endif -# define machine_is_strasbourg_a2() (machine_arch_type == MACH_TYPE_STRASBOURG_A2) -#else -# define machine_is_strasbourg_a2() (0) -#endif
-#ifdef CONFIG_MACH_MMM -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MMM -# endif -# define machine_is_mmm() (machine_arch_type == MACH_TYPE_MMM) -#else -# define machine_is_mmm() (0) -#endif
-#ifdef CONFIG_MACH_DAVINCI_DM365_BV -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DAVINCI_DM365_BV -# endif -# define machine_is_davinci_dm365_bv() (machine_arch_type == MACH_TYPE_DAVINCI_DM365_BV) -#else -# define machine_is_davinci_dm365_bv() (0) -#endif
-#ifdef CONFIG_MACH_AG5EVM -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_AG5EVM -# endif -# define machine_is_ag5evm() (machine_arch_type == MACH_TYPE_AG5EVM) -#else -# define machine_is_ag5evm() (0) -#endif
-#ifdef CONFIG_MACH_SC575PLC -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SC575PLC -# endif -# define machine_is_sc575plc() (machine_arch_type == MACH_TYPE_SC575PLC) -#else -# define machine_is_sc575plc() (0) -#endif
-#ifdef CONFIG_MACH_SC575IPC -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SC575IPC -# endif -# define machine_is_sc575hmi() (machine_arch_type == MACH_TYPE_SC575IPC) -#else -# define machine_is_sc575hmi() (0) -#endif
-#ifdef CONFIG_MACH_OMAP3_TDM3730 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OMAP3_TDM3730 -# endif -# define machine_is_omap3_tdm3730() (machine_arch_type == MACH_TYPE_OMAP3_TDM3730) -#else -# define machine_is_omap3_tdm3730() (0) -#endif
-#ifdef CONFIG_MACH_TOP9000_EVAL -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TOP9000_EVAL -# endif -# define machine_is_top9000_eval() (machine_arch_type == MACH_TYPE_TOP9000_EVAL) -#else -# define machine_is_top9000_eval() (0) -#endif
-#ifdef CONFIG_MACH_TOP9000_SU -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TOP9000_SU -# endif -# define machine_is_top9000_su() (machine_arch_type == MACH_TYPE_TOP9000_SU) -#else -# define machine_is_top9000_su() (0) -#endif
-#ifdef CONFIG_MACH_UTM300 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_UTM300 -# endif -# define machine_is_utm300() (machine_arch_type == MACH_TYPE_UTM300) -#else -# define machine_is_utm300() (0) -#endif
-#ifdef CONFIG_MACH_TSUNAGI -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TSUNAGI -# endif -# define machine_is_tsunagi() (machine_arch_type == MACH_TYPE_TSUNAGI) -#else -# define machine_is_tsunagi() (0) -#endif
-#ifdef CONFIG_MACH_TS75XX -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TS75XX -# endif -# define machine_is_ts75xx() (machine_arch_type == MACH_TYPE_TS75XX) -#else -# define machine_is_ts75xx() (0) -#endif
-#ifdef CONFIG_MACH_TS47XX -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TS47XX -# endif -# define machine_is_ts47xx() (machine_arch_type == MACH_TYPE_TS47XX) -#else -# define machine_is_ts47xx() (0) -#endif
-#ifdef CONFIG_MACH_DA850_K5 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DA850_K5 -# endif -# define machine_is_da850_k5() (machine_arch_type == MACH_TYPE_DA850_K5) -#else -# define machine_is_da850_k5() (0) -#endif
-#ifdef CONFIG_MACH_AX502 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_AX502 -# endif -# define machine_is_ax502() (machine_arch_type == MACH_TYPE_AX502) -#else -# define machine_is_ax502() (0) -#endif
-#ifdef CONFIG_MACH_IGEP0032 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_IGEP0032 -# endif -# define machine_is_igep0032() (machine_arch_type == MACH_TYPE_IGEP0032) -#else -# define machine_is_igep0032() (0) -#endif
-#ifdef CONFIG_MACH_ANTERO -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ANTERO -# endif -# define machine_is_antero() (machine_arch_type == MACH_TYPE_ANTERO) -#else -# define machine_is_antero() (0) -#endif
-#ifdef CONFIG_MACH_SYNERGY -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SYNERGY -# endif -# define machine_is_synergy() (machine_arch_type == MACH_TYPE_SYNERGY) -#else -# define machine_is_synergy() (0) -#endif
-#ifdef CONFIG_MACH_ICS_IF_VOIP -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ICS_IF_VOIP -# endif -# define machine_is_ics_if_voip() (machine_arch_type == MACH_TYPE_ICS_IF_VOIP) -#else -# define machine_is_ics_if_voip() (0) -#endif
-#ifdef CONFIG_MACH_WLF_CRAGG_6410 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_WLF_CRAGG_6410 -# endif -# define machine_is_wlf_cragg_6410() (machine_arch_type == MACH_TYPE_WLF_CRAGG_6410) -#else -# define machine_is_wlf_cragg_6410() (0) -#endif
-#ifdef CONFIG_MACH_PUNICA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_PUNICA -# endif -# define machine_is_punica() (machine_arch_type == MACH_TYPE_PUNICA) -#else -# define machine_is_punica() (0) -#endif
-#ifdef CONFIG_MACH_TRIMSLICE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TRIMSLICE -# endif -# define machine_is_trimslice() (machine_arch_type == MACH_TYPE_TRIMSLICE) -#else -# define machine_is_trimslice() (0) -#endif
-#ifdef CONFIG_MACH_MX27_WMULTRA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MX27_WMULTRA -# endif -# define machine_is_mx27_wmultra() (machine_arch_type == MACH_TYPE_MX27_WMULTRA) -#else -# define machine_is_mx27_wmultra() (0) -#endif
-#ifdef CONFIG_MACH_MACKEREL -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MACKEREL -# endif -# define machine_is_mackerel() (machine_arch_type == MACH_TYPE_MACKEREL) -#else -# define machine_is_mackerel() (0) -#endif
-#ifdef CONFIG_MACH_FA9X27 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_FA9X27 -# endif -# define machine_is_fa9x27() (machine_arch_type == MACH_TYPE_FA9X27) -#else -# define machine_is_fa9x27() (0) -#endif
-#ifdef CONFIG_MACH_NS2816TB -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NS2816TB -# endif -# define machine_is_ns2816tb() (machine_arch_type == MACH_TYPE_NS2816TB) -#else -# define machine_is_ns2816tb() (0) -#endif
-#ifdef CONFIG_MACH_NS2816_NTPAD -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NS2816_NTPAD -# endif -# define machine_is_ns2816_ntpad() (machine_arch_type == MACH_TYPE_NS2816_NTPAD) -#else -# define machine_is_ns2816_ntpad() (0) -#endif
-#ifdef CONFIG_MACH_NS2816_NTNB -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NS2816_NTNB -# endif -# define machine_is_ns2816_ntnb() (machine_arch_type == MACH_TYPE_NS2816_NTNB) -#else -# define machine_is_ns2816_ntnb() (0) -#endif
-#ifdef CONFIG_MACH_KAEN -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_KAEN -# endif -# define machine_is_kaen() (machine_arch_type == MACH_TYPE_KAEN) -#else -# define machine_is_kaen() (0) -#endif
-#ifdef CONFIG_MACH_NV1000 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NV1000 -# endif -# define machine_is_nv1000() (machine_arch_type == MACH_TYPE_NV1000) -#else -# define machine_is_nv1000() (0) -#endif
-#ifdef CONFIG_MACH_NUC950TS -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NUC950TS -# endif -# define machine_is_nuc950ts() (machine_arch_type == MACH_TYPE_NUC950TS) -#else -# define machine_is_nuc950ts() (0) -#endif
-#ifdef CONFIG_MACH_NOKIA_RM680 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NOKIA_RM680 -# endif -# define machine_is_nokia_rm680() (machine_arch_type == MACH_TYPE_NOKIA_RM680) -#else -# define machine_is_nokia_rm680() (0) -#endif
-#ifdef CONFIG_MACH_AST2200 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_AST2200 -# endif -# define machine_is_ast2200() (machine_arch_type == MACH_TYPE_AST2200) -#else -# define machine_is_ast2200() (0) -#endif
-#ifdef CONFIG_MACH_LEAD -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_LEAD -# endif -# define machine_is_lead() (machine_arch_type == MACH_TYPE_LEAD) -#else -# define machine_is_lead() (0) -#endif
-#ifdef CONFIG_MACH_UNINO1 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_UNINO1 -# endif -# define machine_is_unino1() (machine_arch_type == MACH_TYPE_UNINO1) -#else -# define machine_is_unino1() (0) -#endif
-#ifdef CONFIG_MACH_GREECO -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_GREECO -# endif -# define machine_is_greeco() (machine_arch_type == MACH_TYPE_GREECO) -#else -# define machine_is_greeco() (0) -#endif
-#ifdef CONFIG_MACH_VERDI -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_VERDI -# endif -# define machine_is_verdi() (machine_arch_type == MACH_TYPE_VERDI) -#else -# define machine_is_verdi() (0) -#endif
-#ifdef CONFIG_MACH_DM6446_ADBOX -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DM6446_ADBOX -# endif -# define machine_is_dm6446_adbox() (machine_arch_type == MACH_TYPE_DM6446_ADBOX) -#else -# define machine_is_dm6446_adbox() (0) -#endif
-#ifdef CONFIG_MACH_QUAD_SALSA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_QUAD_SALSA -# endif -# define machine_is_quad_salsa() (machine_arch_type == MACH_TYPE_QUAD_SALSA) -#else -# define machine_is_quad_salsa() (0) -#endif
-#ifdef CONFIG_MACH_ABB_GMA_1_1 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ABB_GMA_1_1 -# endif -# define machine_is_abb_gma_1_1() (machine_arch_type == MACH_TYPE_ABB_GMA_1_1) -#else -# define machine_is_abb_gma_1_1() (0) -#endif
-#ifdef CONFIG_MACH_SVCID -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SVCID -# endif -# define machine_is_svcid() (machine_arch_type == MACH_TYPE_SVCID) -#else -# define machine_is_svcid() (0) -#endif
-#ifdef CONFIG_MACH_MSM8960_SIM -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MSM8960_SIM -# endif -# define machine_is_msm8960_sim() (machine_arch_type == MACH_TYPE_MSM8960_SIM) -#else -# define machine_is_msm8960_sim() (0) -#endif
-#ifdef CONFIG_MACH_MSM8960_RUMI3 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MSM8960_RUMI3 -# endif -# define machine_is_msm8960_rumi3() (machine_arch_type == MACH_TYPE_MSM8960_RUMI3) -#else -# define machine_is_msm8960_rumi3() (0) -#endif
-#ifdef CONFIG_MACH_ICON_G -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ICON_G -# endif -# define machine_is_icon_g() (machine_arch_type == MACH_TYPE_ICON_G) -#else -# define machine_is_icon_g() (0) -#endif
-#ifdef CONFIG_MACH_MB3 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MB3 -# endif -# define machine_is_mb3() (machine_arch_type == MACH_TYPE_MB3) -#else -# define machine_is_mb3() (0) -#endif
-#ifdef CONFIG_MACH_GSIA18S -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_GSIA18S -# endif -# define machine_is_gsia18s() (machine_arch_type == MACH_TYPE_GSIA18S) -#else -# define machine_is_gsia18s() (0) -#endif
-#ifdef CONFIG_MACH_PIVICC -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_PIVICC -# endif -# define machine_is_pivicc() (machine_arch_type == MACH_TYPE_PIVICC) -#else -# define machine_is_pivicc() (0) -#endif
-#ifdef CONFIG_MACH_PCM048 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_PCM048 -# endif -# define machine_is_pcm048() (machine_arch_type == MACH_TYPE_PCM048) -#else -# define machine_is_pcm048() (0) -#endif
-#ifdef CONFIG_MACH_DDS -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DDS -# endif -# define machine_is_dds() (machine_arch_type == MACH_TYPE_DDS) -#else -# define machine_is_dds() (0) -#endif
-#ifdef CONFIG_MACH_CHALTEN_XA1 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CHALTEN_XA1 -# endif -# define machine_is_chalten_xa1() (machine_arch_type == MACH_TYPE_CHALTEN_XA1) -#else -# define machine_is_chalten_xa1() (0) -#endif
-#ifdef CONFIG_MACH_TS48XX -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TS48XX -# endif -# define machine_is_ts48xx() (machine_arch_type == MACH_TYPE_TS48XX) -#else -# define machine_is_ts48xx() (0) -#endif
-#ifdef CONFIG_MACH_TONGA2_TFTTIMER -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TONGA2_TFTTIMER -# endif -# define machine_is_tonga2_tfttimer() (machine_arch_type == MACH_TYPE_TONGA2_TFTTIMER) -#else -# define machine_is_tonga2_tfttimer() (0) -#endif
-#ifdef CONFIG_MACH_WHISTLER -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_WHISTLER -# endif -# define machine_is_whistler() (machine_arch_type == MACH_TYPE_WHISTLER) -#else -# define machine_is_whistler() (0) -#endif
-#ifdef CONFIG_MACH_ASL_PHOENIX -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ASL_PHOENIX -# endif -# define machine_is_asl_phoenix() (machine_arch_type == MACH_TYPE_ASL_PHOENIX) -#else -# define machine_is_asl_phoenix() (0) -#endif
-#ifdef CONFIG_MACH_AT91SAM9263OTLITE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_AT91SAM9263OTLITE -# endif -# define machine_is_at91sam9263otlite() (machine_arch_type == MACH_TYPE_AT91SAM9263OTLITE) -#else -# define machine_is_at91sam9263otlite() (0) -#endif
-#ifdef CONFIG_MACH_DDPLUG -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DDPLUG -# endif -# define machine_is_ddplug() (machine_arch_type == MACH_TYPE_DDPLUG) -#else -# define machine_is_ddplug() (0) -#endif
-#ifdef CONFIG_MACH_D2PLUG -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_D2PLUG -# endif -# define machine_is_d2plug() (machine_arch_type == MACH_TYPE_D2PLUG) -#else -# define machine_is_d2plug() (0) -#endif
-#ifdef CONFIG_MACH_KZM9D -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_KZM9D -# endif -# define machine_is_kzm9d() (machine_arch_type == MACH_TYPE_KZM9D) -#else -# define machine_is_kzm9d() (0) -#endif
-#ifdef CONFIG_MACH_VERDI_LTE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_VERDI_LTE -# endif -# define machine_is_verdi_lte() (machine_arch_type == MACH_TYPE_VERDI_LTE) -#else -# define machine_is_verdi_lte() (0) -#endif
-#ifdef CONFIG_MACH_NANOZOOM -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NANOZOOM -# endif -# define machine_is_nanozoom() (machine_arch_type == MACH_TYPE_NANOZOOM) -#else -# define machine_is_nanozoom() (0) -#endif
-#ifdef CONFIG_MACH_DM3730_SOM_LV -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DM3730_SOM_LV -# endif -# define machine_is_dm3730_som_lv() (machine_arch_type == MACH_TYPE_DM3730_SOM_LV) -#else -# define machine_is_dm3730_som_lv() (0) -#endif
-#ifdef CONFIG_MACH_DM3730_TORPEDO -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DM3730_TORPEDO -# endif -# define machine_is_dm3730_torpedo() (machine_arch_type == MACH_TYPE_DM3730_TORPEDO) -#else -# define machine_is_dm3730_torpedo() (0) -#endif
-#ifdef CONFIG_MACH_ANCHOVY -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ANCHOVY -# endif -# define machine_is_anchovy() (machine_arch_type == MACH_TYPE_ANCHOVY) -#else -# define machine_is_anchovy() (0) -#endif
-#ifdef CONFIG_MACH_RE2REV20 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_RE2REV20 -# endif -# define machine_is_re2rev20() (machine_arch_type == MACH_TYPE_RE2REV20) -#else -# define machine_is_re2rev20() (0) -#endif
-#ifdef CONFIG_MACH_RE2REV21 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_RE2REV21 -# endif -# define machine_is_re2rev21() (machine_arch_type == MACH_TYPE_RE2REV21) -#else -# define machine_is_re2rev21() (0) -#endif
-#ifdef CONFIG_MACH_CNS21XX -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CNS21XX -# endif -# define machine_is_cns21xx() (machine_arch_type == MACH_TYPE_CNS21XX) -#else -# define machine_is_cns21xx() (0) -#endif
-#ifdef CONFIG_MACH_RIDER -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_RIDER -# endif -# define machine_is_rider() (machine_arch_type == MACH_TYPE_RIDER) -#else -# define machine_is_rider() (0) -#endif
-#ifdef CONFIG_MACH_NSK330 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NSK330 -# endif -# define machine_is_nsk330() (machine_arch_type == MACH_TYPE_NSK330) -#else -# define machine_is_nsk330() (0) -#endif
-#ifdef CONFIG_MACH_CNS2133EVB -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CNS2133EVB -# endif -# define machine_is_cns2133evb() (machine_arch_type == MACH_TYPE_CNS2133EVB) -#else -# define machine_is_cns2133evb() (0) -#endif
-#ifdef CONFIG_MACH_Z3_816X_MOD -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_Z3_816X_MOD -# endif -# define machine_is_z3_816x_mod() (machine_arch_type == MACH_TYPE_Z3_816X_MOD) -#else -# define machine_is_z3_816x_mod() (0) -#endif
-#ifdef CONFIG_MACH_Z3_814X_MOD -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_Z3_814X_MOD -# endif -# define machine_is_z3_814x_mod() (machine_arch_type == MACH_TYPE_Z3_814X_MOD) -#else -# define machine_is_z3_814x_mod() (0) -#endif
-#ifdef CONFIG_MACH_BEECT -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_BEECT -# endif -# define machine_is_beect() (machine_arch_type == MACH_TYPE_BEECT) -#else -# define machine_is_beect() (0) -#endif
-#ifdef CONFIG_MACH_DMA_THUNDERBUG -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DMA_THUNDERBUG -# endif -# define machine_is_dma_thunderbug() (machine_arch_type == MACH_TYPE_DMA_THUNDERBUG) -#else -# define machine_is_dma_thunderbug() (0) -#endif
-#ifdef CONFIG_MACH_OMN_AT91SAM9G20 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OMN_AT91SAM9G20 -# endif -# define machine_is_omn_at91sam9g20() (machine_arch_type == MACH_TYPE_OMN_AT91SAM9G20) -#else -# define machine_is_omn_at91sam9g20() (0) -#endif
-#ifdef CONFIG_MACH_MX25_E2S_UC -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MX25_E2S_UC -# endif -# define machine_is_mx25_e2s_uc() (machine_arch_type == MACH_TYPE_MX25_E2S_UC) -#else -# define machine_is_mx25_e2s_uc() (0) -#endif
-#ifdef CONFIG_MACH_MIONE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MIONE -# endif -# define machine_is_mione() (machine_arch_type == MACH_TYPE_MIONE) -#else -# define machine_is_mione() (0) -#endif
-#ifdef CONFIG_MACH_TOP9000_TCU -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TOP9000_TCU -# endif -# define machine_is_top9000_tcu() (machine_arch_type == MACH_TYPE_TOP9000_TCU) -#else -# define machine_is_top9000_tcu() (0) -#endif
-#ifdef CONFIG_MACH_TOP9000_BSL -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TOP9000_BSL -# endif -# define machine_is_top9000_bsl() (machine_arch_type == MACH_TYPE_TOP9000_BSL) -#else -# define machine_is_top9000_bsl() (0) -#endif
-#ifdef CONFIG_MACH_KINGDOM -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_KINGDOM -# endif -# define machine_is_kingdom() (machine_arch_type == MACH_TYPE_KINGDOM) -#else -# define machine_is_kingdom() (0) -#endif
-#ifdef CONFIG_MACH_ARMADILLO460 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ARMADILLO460 -# endif -# define machine_is_armadillo460() (machine_arch_type == MACH_TYPE_ARMADILLO460) -#else -# define machine_is_armadillo460() (0) -#endif
-#ifdef CONFIG_MACH_LQ2 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_LQ2 -# endif -# define machine_is_lq2() (machine_arch_type == MACH_TYPE_LQ2) -#else -# define machine_is_lq2() (0) -#endif
-#ifdef CONFIG_MACH_SWEDA_TMS2 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SWEDA_TMS2 -# endif -# define machine_is_sweda_tms2() (machine_arch_type == MACH_TYPE_SWEDA_TMS2) -#else -# define machine_is_sweda_tms2() (0) -#endif
-#ifdef CONFIG_MACH_MX53_LOCO -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MX53_LOCO -# endif -# define machine_is_mx53_loco() (machine_arch_type == MACH_TYPE_MX53_LOCO) -#else -# define machine_is_mx53_loco() (0) -#endif
-#ifdef CONFIG_MACH_ACER_A8 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ACER_A8 -# endif -# define machine_is_acer_a8() (machine_arch_type == MACH_TYPE_ACER_A8) -#else -# define machine_is_acer_a8() (0) -#endif
-#ifdef CONFIG_MACH_ACER_GAUGUIN -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ACER_GAUGUIN -# endif -# define machine_is_acer_gauguin() (machine_arch_type == MACH_TYPE_ACER_GAUGUIN) -#else -# define machine_is_acer_gauguin() (0) -#endif
-#ifdef CONFIG_MACH_GUPPY -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_GUPPY -# endif -# define machine_is_guppy() (machine_arch_type == MACH_TYPE_GUPPY) -#else -# define machine_is_guppy() (0) -#endif
-#ifdef CONFIG_MACH_MX61_ARD -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MX61_ARD -# endif -# define machine_is_mx61_ard() (machine_arch_type == MACH_TYPE_MX61_ARD) -#else -# define machine_is_mx61_ard() (0) -#endif
-#ifdef CONFIG_MACH_TX53 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TX53 -# endif -# define machine_is_tx53() (machine_arch_type == MACH_TYPE_TX53) -#else -# define machine_is_tx53() (0) -#endif
-#ifdef CONFIG_MACH_OMAPL138_CASE_A3 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OMAPL138_CASE_A3 -# endif -# define machine_is_omapl138_case_a3() (machine_arch_type == MACH_TYPE_OMAPL138_CASE_A3) -#else -# define machine_is_omapl138_case_a3() (0) -#endif
-#ifdef CONFIG_MACH_UEMD -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_UEMD -# endif -# define machine_is_uemd() (machine_arch_type == MACH_TYPE_UEMD) -#else -# define machine_is_uemd() (0) -#endif
-#ifdef CONFIG_MACH_CCWMX51MUT -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CCWMX51MUT -# endif -# define machine_is_ccwmx51mut() (machine_arch_type == MACH_TYPE_CCWMX51MUT) -#else -# define machine_is_ccwmx51mut() (0) -#endif
-#ifdef CONFIG_MACH_ROCKHOPPER -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ROCKHOPPER -# endif -# define machine_is_rockhopper() (machine_arch_type == MACH_TYPE_ROCKHOPPER) -#else -# define machine_is_rockhopper() (0) -#endif
-#ifdef CONFIG_MACH_ENCORE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ENCORE -# endif -# define machine_is_encore() (machine_arch_type == MACH_TYPE_ENCORE) -#else -# define machine_is_encore() (0) -#endif
-#ifdef CONFIG_MACH_HKDKC100 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_HKDKC100 -# endif -# define machine_is_hkdkc100() (machine_arch_type == MACH_TYPE_HKDKC100) -#else -# define machine_is_hkdkc100() (0) -#endif
-#ifdef CONFIG_MACH_TS42XX -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TS42XX -# endif -# define machine_is_ts42xx() (machine_arch_type == MACH_TYPE_TS42XX) -#else -# define machine_is_ts42xx() (0) -#endif
-#ifdef CONFIG_MACH_AEBL -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_AEBL -# endif -# define machine_is_aebl() (machine_arch_type == MACH_TYPE_AEBL) -#else -# define machine_is_aebl() (0) -#endif
-#ifdef CONFIG_MACH_WARIO -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_WARIO -# endif -# define machine_is_wario() (machine_arch_type == MACH_TYPE_WARIO) -#else -# define machine_is_wario() (0) -#endif
-#ifdef CONFIG_MACH_GFS_SPM -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_GFS_SPM -# endif -# define machine_is_gfs_spm() (machine_arch_type == MACH_TYPE_GFS_SPM) -#else -# define machine_is_gfs_spm() (0) -#endif
-#ifdef CONFIG_MACH_CM_T3730 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CM_T3730 -# endif -# define machine_is_cm_t3730() (machine_arch_type == MACH_TYPE_CM_T3730) -#else -# define machine_is_cm_t3730() (0) -#endif
-#ifdef CONFIG_MACH_ISC3 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ISC3 -# endif -# define machine_is_isc3() (machine_arch_type == MACH_TYPE_ISC3) -#else -# define machine_is_isc3() (0) -#endif
-#ifdef CONFIG_MACH_RASCAL -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_RASCAL -# endif -# define machine_is_rascal() (machine_arch_type == MACH_TYPE_RASCAL) -#else -# define machine_is_rascal() (0) -#endif
-#ifdef CONFIG_MACH_HREFV60 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_HREFV60 -# endif -# define machine_is_hrefv60() (machine_arch_type == MACH_TYPE_HREFV60) -#else -# define machine_is_hrefv60() (0) -#endif
-#ifdef CONFIG_MACH_TPT_2_0 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TPT_2_0 -# endif -# define machine_is_tpt_2_0() (machine_arch_type == MACH_TYPE_TPT_2_0) -#else -# define machine_is_tpt_2_0() (0) -#endif
-#ifdef CONFIG_MACH_SPLENDOR -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SPLENDOR -# endif -# define machine_is_splendor() (machine_arch_type == MACH_TYPE_SPLENDOR) -#else -# define machine_is_splendor() (0) -#endif
-#ifdef CONFIG_MACH_MSM8X60_QT -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MSM8X60_QT -# endif -# define machine_is_msm8x60_qt() (machine_arch_type == MACH_TYPE_MSM8X60_QT) -#else -# define machine_is_msm8x60_qt() (0) -#endif
-#ifdef CONFIG_MACH_HTC_HD_MINI -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_HTC_HD_MINI -# endif -# define machine_is_htc_hd_mini() (machine_arch_type == MACH_TYPE_HTC_HD_MINI) -#else -# define machine_is_htc_hd_mini() (0) -#endif
-#ifdef CONFIG_MACH_ATHENE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ATHENE -# endif -# define machine_is_athene() (machine_arch_type == MACH_TYPE_ATHENE) -#else -# define machine_is_athene() (0) -#endif
-#ifdef CONFIG_MACH_DEEP_R_EK_1 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DEEP_R_EK_1 -# endif -# define machine_is_deep_r_ek_1() (machine_arch_type == MACH_TYPE_DEEP_R_EK_1) -#else -# define machine_is_deep_r_ek_1() (0) -#endif
-#ifdef CONFIG_MACH_VIVOW_CT -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_VIVOW_CT -# endif -# define machine_is_vivow_ct() (machine_arch_type == MACH_TYPE_VIVOW_CT) -#else -# define machine_is_vivow_ct() (0) -#endif
-#ifdef CONFIG_MACH_NERY_1000 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NERY_1000 -# endif -# define machine_is_nery_1000() (machine_arch_type == MACH_TYPE_NERY_1000) -#else -# define machine_is_nery_1000() (0) -#endif
-#ifdef CONFIG_MACH_RFL109145_SSRV -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_RFL109145_SSRV -# endif -# define machine_is_rfl109145_ssrv() (machine_arch_type == MACH_TYPE_RFL109145_SSRV) -#else -# define machine_is_rfl109145_ssrv() (0) -#endif
-#ifdef CONFIG_MACH_NMH -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NMH -# endif -# define machine_is_nmh() (machine_arch_type == MACH_TYPE_NMH) -#else -# define machine_is_nmh() (0) -#endif
-#ifdef CONFIG_MACH_WN802T -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_WN802T -# endif -# define machine_is_wn802t() (machine_arch_type == MACH_TYPE_WN802T) -#else -# define machine_is_wn802t() (0) -#endif
-#ifdef CONFIG_MACH_DRAGONET -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DRAGONET -# endif -# define machine_is_dragonet() (machine_arch_type == MACH_TYPE_DRAGONET) -#else -# define machine_is_dragonet() (0) -#endif
-#ifdef CONFIG_MACH_AT91SAM9263DESK16L -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_AT91SAM9263DESK16L -# endif -# define machine_is_at91sam9263desk16l() (machine_arch_type == MACH_TYPE_AT91SAM9263DESK16L) -#else -# define machine_is_at91sam9263desk16l() (0) -#endif
-#ifdef CONFIG_MACH_BCMHANA_SV -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_BCMHANA_SV -# endif -# define machine_is_bcmhana_sv() (machine_arch_type == MACH_TYPE_BCMHANA_SV) -#else -# define machine_is_bcmhana_sv() (0) -#endif
-#ifdef CONFIG_MACH_BCMHANA_TABLET -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_BCMHANA_TABLET -# endif -# define machine_is_bcmhana_tablet() (machine_arch_type == MACH_TYPE_BCMHANA_TABLET) -#else -# define machine_is_bcmhana_tablet() (0) -#endif
-#ifdef CONFIG_MACH_KOI -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_KOI -# endif -# define machine_is_koi() (machine_arch_type == MACH_TYPE_KOI) -#else -# define machine_is_koi() (0) -#endif
-#ifdef CONFIG_MACH_TS4800 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TS4800 -# endif -# define machine_is_ts4800() (machine_arch_type == MACH_TYPE_TS4800) -#else -# define machine_is_ts4800() (0) -#endif
-#ifdef CONFIG_MACH_TQMA9263 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TQMA9263 -# endif -# define machine_is_tqma9263() (machine_arch_type == MACH_TYPE_TQMA9263) -#else -# define machine_is_tqma9263() (0) -#endif
-#ifdef CONFIG_MACH_HOLIDAY -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_HOLIDAY -# endif -# define machine_is_holiday() (machine_arch_type == MACH_TYPE_HOLIDAY) -#else -# define machine_is_holiday() (0) -#endif
-#ifdef CONFIG_MACH_DMA6410 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DMA6410 -# endif -# define machine_is_dma_6410() (machine_arch_type == MACH_TYPE_DMA6410) -#else -# define machine_is_dma_6410() (0) -#endif
-#ifdef CONFIG_MACH_PCATS_OVERLAY -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_PCATS_OVERLAY -# endif -# define machine_is_pcats_overlay() (machine_arch_type == MACH_TYPE_PCATS_OVERLAY) -#else -# define machine_is_pcats_overlay() (0) -#endif
-#ifdef CONFIG_MACH_HWGW6410 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_HWGW6410 -# endif -# define machine_is_hwgw6410() (machine_arch_type == MACH_TYPE_HWGW6410) -#else -# define machine_is_hwgw6410() (0) -#endif
-#ifdef CONFIG_MACH_SHENZHOU -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SHENZHOU -# endif -# define machine_is_shenzhou() (machine_arch_type == MACH_TYPE_SHENZHOU) -#else -# define machine_is_shenzhou() (0) -#endif
-#ifdef CONFIG_MACH_CWME9210 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CWME9210 -# endif -# define machine_is_cwme9210() (machine_arch_type == MACH_TYPE_CWME9210) -#else -# define machine_is_cwme9210() (0) -#endif
-#ifdef CONFIG_MACH_CWME9210JS -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CWME9210JS -# endif -# define machine_is_cwme9210js() (machine_arch_type == MACH_TYPE_CWME9210JS) -#else -# define machine_is_cwme9210js() (0) -#endif
-#ifdef CONFIG_MACH_PGS_SITARA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_PGS_SITARA -# endif -# define machine_is_pgs_v1() (machine_arch_type == MACH_TYPE_PGS_SITARA) -#else -# define machine_is_pgs_v1() (0) -#endif
-#ifdef CONFIG_MACH_COLIBRI_T20 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_COLIBRI_T20 -# endif -# define machine_is_colibri_t20() (machine_arch_type == MACH_TYPE_COLIBRI_T20) -#else -# define machine_is_colibri_t20() (0) -#endif
-#ifdef CONFIG_MACH_W21 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_W21 -# endif -# define machine_is_w21() (machine_arch_type == MACH_TYPE_W21) -#else -# define machine_is_w21() (0) -#endif
-#ifdef CONFIG_MACH_POLYSAT1 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_POLYSAT1 -# endif -# define machine_is_polysat1() (machine_arch_type == MACH_TYPE_POLYSAT1) -#else -# define machine_is_polysat1() (0) -#endif
-#ifdef CONFIG_MACH_DATAWAY -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DATAWAY -# endif -# define machine_is_dataway() (machine_arch_type == MACH_TYPE_DATAWAY) -#else -# define machine_is_dataway() (0) -#endif
-#ifdef CONFIG_MACH_COBRAL138 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_COBRAL138 -# endif -# define machine_is_cobral138() (machine_arch_type == MACH_TYPE_COBRAL138) -#else -# define machine_is_cobral138() (0) -#endif
-#ifdef CONFIG_MACH_ROVERPCS8 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ROVERPCS8 -# endif -# define machine_is_roverpcs8() (machine_arch_type == MACH_TYPE_ROVERPCS8) -#else -# define machine_is_roverpcs8() (0) -#endif
-#ifdef CONFIG_MACH_MARVELC -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MARVELC -# endif -# define machine_is_marvelc() (machine_arch_type == MACH_TYPE_MARVELC) -#else -# define machine_is_marvelc() (0) -#endif
-#ifdef CONFIG_MACH_NAVEFIHID -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NAVEFIHID -# endif -# define machine_is_navefihid() (machine_arch_type == MACH_TYPE_NAVEFIHID) -#else -# define machine_is_navefihid() (0) -#endif
-#ifdef CONFIG_MACH_DM365_CV100 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DM365_CV100 -# endif -# define machine_is_dm365_cv100() (machine_arch_type == MACH_TYPE_DM365_CV100) -#else -# define machine_is_dm365_cv100() (0) -#endif
-#ifdef CONFIG_MACH_ABLE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ABLE -# endif -# define machine_is_able() (machine_arch_type == MACH_TYPE_ABLE) -#else -# define machine_is_able() (0) -#endif
-#ifdef CONFIG_MACH_LEGACY -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_LEGACY -# endif -# define machine_is_legacy() (machine_arch_type == MACH_TYPE_LEGACY) -#else -# define machine_is_legacy() (0) -#endif
-#ifdef CONFIG_MACH_ICONG -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ICONG -# endif -# define machine_is_icong() (machine_arch_type == MACH_TYPE_ICONG) -#else -# define machine_is_icong() (0) -#endif
-#ifdef CONFIG_MACH_ROVER_G8 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ROVER_G8 -# endif -# define machine_is_rover_g8() (machine_arch_type == MACH_TYPE_ROVER_G8) -#else -# define machine_is_rover_g8() (0) -#endif
-#ifdef CONFIG_MACH_T5388P -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_T5388P -# endif -# define machine_is_t5388p() (machine_arch_type == MACH_TYPE_T5388P) -#else -# define machine_is_t5388p() (0) -#endif
-#ifdef CONFIG_MACH_DINGO -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DINGO -# endif -# define machine_is_dingo() (machine_arch_type == MACH_TYPE_DINGO) -#else -# define machine_is_dingo() (0) -#endif
-#ifdef CONFIG_MACH_GOFLEXHOME -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_GOFLEXHOME -# endif -# define machine_is_goflexhome() (machine_arch_type == MACH_TYPE_GOFLEXHOME) -#else -# define machine_is_goflexhome() (0) -#endif
-#ifdef CONFIG_MACH_LANREADYFN511 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_LANREADYFN511 -# endif -# define machine_is_lanreadyfn511() (machine_arch_type == MACH_TYPE_LANREADYFN511) -#else -# define machine_is_lanreadyfn511() (0) -#endif
-#ifdef CONFIG_MACH_OMAP3_BAIA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OMAP3_BAIA -# endif -# define machine_is_omap3_baia() (machine_arch_type == MACH_TYPE_OMAP3_BAIA) -#else -# define machine_is_omap3_baia() (0) -#endif
-#ifdef CONFIG_MACH_OMAP3SMARTDISPLAY -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OMAP3SMARTDISPLAY -# endif -# define machine_is_omap3smartdisplay() (machine_arch_type == MACH_TYPE_OMAP3SMARTDISPLAY) -#else -# define machine_is_omap3smartdisplay() (0) -#endif
-#ifdef CONFIG_MACH_XILINX -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_XILINX -# endif -# define machine_is_xilinx() (machine_arch_type == MACH_TYPE_XILINX) -#else -# define machine_is_xilinx() (0) -#endif
-#ifdef CONFIG_MACH_A2F -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_A2F -# endif -# define machine_is_a2f() (machine_arch_type == MACH_TYPE_A2F) -#else -# define machine_is_a2f() (0) -#endif
-#ifdef CONFIG_MACH_SKY25 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SKY25 -# endif -# define machine_is_sky25() (machine_arch_type == MACH_TYPE_SKY25) -#else -# define machine_is_sky25() (0) -#endif
-#ifdef CONFIG_MACH_CCMX53 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CCMX53 -# endif -# define machine_is_ccmx53() (machine_arch_type == MACH_TYPE_CCMX53) -#else -# define machine_is_ccmx53() (0) -#endif
-#ifdef CONFIG_MACH_CCMX53JS -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CCMX53JS -# endif -# define machine_is_ccmx53js() (machine_arch_type == MACH_TYPE_CCMX53JS) -#else -# define machine_is_ccmx53js() (0) -#endif
-#ifdef CONFIG_MACH_CCWMX53 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CCWMX53 -# endif -# define machine_is_ccwmx53() (machine_arch_type == MACH_TYPE_CCWMX53) -#else -# define machine_is_ccwmx53() (0) -#endif
-#ifdef CONFIG_MACH_CCWMX53JS -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CCWMX53JS -# endif -# define machine_is_ccwmx53js() (machine_arch_type == MACH_TYPE_CCWMX53JS) -#else -# define machine_is_ccwmx53js() (0) -#endif
-#ifdef CONFIG_MACH_FRISMS -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_FRISMS -# endif -# define machine_is_frisms() (machine_arch_type == MACH_TYPE_FRISMS) -#else -# define machine_is_frisms() (0) -#endif
-#ifdef CONFIG_MACH_MSM7X27A_FFA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MSM7X27A_FFA -# endif -# define machine_is_msm7x27a_ffa() (machine_arch_type == MACH_TYPE_MSM7X27A_FFA) -#else -# define machine_is_msm7x27a_ffa() (0) -#endif
-#ifdef CONFIG_MACH_MSM7X27A_SURF -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MSM7X27A_SURF -# endif -# define machine_is_msm7x27a_surf() (machine_arch_type == MACH_TYPE_MSM7X27A_SURF) -#else -# define machine_is_msm7x27a_surf() (0) -#endif
-#ifdef CONFIG_MACH_MSM7X27A_RUMI3 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MSM7X27A_RUMI3 -# endif -# define machine_is_msm7x27a_rumi3() (machine_arch_type == MACH_TYPE_MSM7X27A_RUMI3) -#else -# define machine_is_msm7x27a_rumi3() (0) -#endif
-#ifdef CONFIG_MACH_DIMMSAM9G20 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DIMMSAM9G20 -# endif -# define machine_is_dimmsam9g20() (machine_arch_type == MACH_TYPE_DIMMSAM9G20) -#else -# define machine_is_dimmsam9g20() (0) -#endif
-#ifdef CONFIG_MACH_DIMM_IMX28 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DIMM_IMX28 -# endif -# define machine_is_dimm_imx28() (machine_arch_type == MACH_TYPE_DIMM_IMX28) -#else -# define machine_is_dimm_imx28() (0) -#endif
-#ifdef CONFIG_MACH_AMK_A4 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_AMK_A4 -# endif -# define machine_is_amk_a4() (machine_arch_type == MACH_TYPE_AMK_A4) -#else -# define machine_is_amk_a4() (0) -#endif
-#ifdef CONFIG_MACH_GNET_SGME -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_GNET_SGME -# endif -# define machine_is_gnet_sgme() (machine_arch_type == MACH_TYPE_GNET_SGME) -#else -# define machine_is_gnet_sgme() (0) -#endif
-#ifdef CONFIG_MACH_SHOOTER_U -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SHOOTER_U -# endif -# define machine_is_shooter_u() (machine_arch_type == MACH_TYPE_SHOOTER_U) -#else -# define machine_is_shooter_u() (0) -#endif
-#ifdef CONFIG_MACH_VMX53 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_VMX53 -# endif -# define machine_is_vmx53() (machine_arch_type == MACH_TYPE_VMX53) -#else -# define machine_is_vmx53() (0) -#endif
-#ifdef CONFIG_MACH_RHINO -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_RHINO -# endif -# define machine_is_rhino() (machine_arch_type == MACH_TYPE_RHINO) -#else -# define machine_is_rhino() (0) -#endif
-#ifdef CONFIG_MACH_ARMLEX4210 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ARMLEX4210 -# endif -# define machine_is_armlex4210() (machine_arch_type == MACH_TYPE_ARMLEX4210) -#else -# define machine_is_armlex4210() (0) -#endif
-#ifdef CONFIG_MACH_SWARCOEXTMODEM -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SWARCOEXTMODEM -# endif -# define machine_is_swarcoextmodem() (machine_arch_type == MACH_TYPE_SWARCOEXTMODEM) -#else -# define machine_is_swarcoextmodem() (0) -#endif
-#ifdef CONFIG_MACH_PCM049 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_PCM049 -# endif -# define machine_is_pcm049() (machine_arch_type == MACH_TYPE_PCM049) -#else -# define machine_is_pcm049() (0) -#endif
-#ifdef CONFIG_MACH_VIGOR -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_VIGOR -# endif -# define machine_is_vigor() (machine_arch_type == MACH_TYPE_VIGOR) -#else -# define machine_is_vigor() (0) -#endif
-#ifdef CONFIG_MACH_OSLO_AMUNDSEN -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OSLO_AMUNDSEN -# endif -# define machine_is_oslo_amundsen() (machine_arch_type == MACH_TYPE_OSLO_AMUNDSEN) -#else -# define machine_is_oslo_amundsen() (0) -#endif
-#ifdef CONFIG_MACH_GSL_DIAMOND -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_GSL_DIAMOND -# endif -# define machine_is_gsl_diamond() (machine_arch_type == MACH_TYPE_GSL_DIAMOND) -#else -# define machine_is_gsl_diamond() (0) -#endif
-#ifdef CONFIG_MACH_CV2201 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CV2201 -# endif -# define machine_is_cv2201() (machine_arch_type == MACH_TYPE_CV2201) -#else -# define machine_is_cv2201() (0) -#endif
-#ifdef CONFIG_MACH_CV2202 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CV2202 -# endif -# define machine_is_cv2202() (machine_arch_type == MACH_TYPE_CV2202) -#else -# define machine_is_cv2202() (0) -#endif
-#ifdef CONFIG_MACH_CV2203 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CV2203 -# endif -# define machine_is_cv2203() (machine_arch_type == MACH_TYPE_CV2203) -#else -# define machine_is_cv2203() (0) -#endif
-#ifdef CONFIG_MACH_VIT_IBOX -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_VIT_IBOX -# endif -# define machine_is_vit_ibox() (machine_arch_type == MACH_TYPE_VIT_IBOX) -#else -# define machine_is_vit_ibox() (0) -#endif
-#ifdef CONFIG_MACH_DM6441_ESP -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DM6441_ESP -# endif -# define machine_is_dm6441_esp() (machine_arch_type == MACH_TYPE_DM6441_ESP) -#else -# define machine_is_dm6441_esp() (0) -#endif
-#ifdef CONFIG_MACH_AT91SAM9X5EK -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_AT91SAM9X5EK -# endif -# define machine_is_at91sam9x5ek() (machine_arch_type == MACH_TYPE_AT91SAM9X5EK) -#else -# define machine_is_at91sam9x5ek() (0) -#endif
-#ifdef CONFIG_MACH_LIBRA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_LIBRA -# endif -# define machine_is_libra() (machine_arch_type == MACH_TYPE_LIBRA) -#else -# define machine_is_libra() (0) -#endif
-#ifdef CONFIG_MACH_EASYCRRH -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_EASYCRRH -# endif -# define machine_is_easycrrh() (machine_arch_type == MACH_TYPE_EASYCRRH) -#else -# define machine_is_easycrrh() (0) -#endif
-#ifdef CONFIG_MACH_TRIPEL -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TRIPEL -# endif -# define machine_is_tripel() (machine_arch_type == MACH_TYPE_TRIPEL) -#else -# define machine_is_tripel() (0) -#endif
-#ifdef CONFIG_MACH_ENDIAN_MINI -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ENDIAN_MINI -# endif -# define machine_is_endian_mini() (machine_arch_type == MACH_TYPE_ENDIAN_MINI) -#else -# define machine_is_endian_mini() (0) -#endif
-#ifdef CONFIG_MACH_XILINX_EP107 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_XILINX_EP107 -# endif -# define machine_is_xilinx_ep107() (machine_arch_type == MACH_TYPE_XILINX_EP107) -#else -# define machine_is_xilinx_ep107() (0) -#endif
-#ifdef CONFIG_MACH_NURI -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NURI -# endif -# define machine_is_nuri() (machine_arch_type == MACH_TYPE_NURI) -#else -# define machine_is_nuri() (0) -#endif
-#ifdef CONFIG_MACH_JANUS -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_JANUS -# endif -# define machine_is_janus() (machine_arch_type == MACH_TYPE_JANUS) -#else -# define machine_is_janus() (0) -#endif
-#ifdef CONFIG_MACH_DDNAS -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DDNAS -# endif -# define machine_is_ddnas() (machine_arch_type == MACH_TYPE_DDNAS) -#else -# define machine_is_ddnas() (0) -#endif
-#ifdef CONFIG_MACH_TAG -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TAG -# endif -# define machine_is_tag() (machine_arch_type == MACH_TYPE_TAG) -#else -# define machine_is_tag() (0) -#endif
-#ifdef CONFIG_MACH_TAGW -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TAGW -# endif -# define machine_is_tagw() (machine_arch_type == MACH_TYPE_TAGW) -#else -# define machine_is_tagw() (0) -#endif
-#ifdef CONFIG_MACH_NITROGEN_VM_IMX51 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NITROGEN_VM_IMX51 -# endif -# define machine_is_nitrogen_vm_imx51() (machine_arch_type == MACH_TYPE_NITROGEN_VM_IMX51) -#else -# define machine_is_nitrogen_vm_imx51() (0) -#endif
-#ifdef CONFIG_MACH_VIPRINET -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_VIPRINET -# endif -# define machine_is_viprinet() (machine_arch_type == MACH_TYPE_VIPRINET) -#else -# define machine_is_viprinet() (0) -#endif
-#ifdef CONFIG_MACH_BOCKW -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_BOCKW -# endif -# define machine_is_bockw() (machine_arch_type == MACH_TYPE_BOCKW) -#else -# define machine_is_bockw() (0) -#endif
-#ifdef CONFIG_MACH_EVA2000 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_EVA2000 -# endif -# define machine_is_eva2000() (machine_arch_type == MACH_TYPE_EVA2000) -#else -# define machine_is_eva2000() (0) -#endif
-#ifdef CONFIG_MACH_STEELYARD -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_STEELYARD -# endif -# define machine_is_steelyard() (machine_arch_type == MACH_TYPE_STEELYARD) -#else -# define machine_is_steelyard() (0) -#endif
-#ifdef CONFIG_MACH_MACH_SDH001 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MACH_SDH001 -# endif -# define machine_is_sdh001() (machine_arch_type == MACH_TYPE_MACH_SDH001) -#else -# define machine_is_sdh001() (0) -#endif
-#ifdef CONFIG_MACH_NSSLSBOARD -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NSSLSBOARD -# endif -# define machine_is_nsslsboard() (machine_arch_type == MACH_TYPE_NSSLSBOARD) -#else -# define machine_is_nsslsboard() (0) -#endif
-#ifdef CONFIG_MACH_GENEVA_B5 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_GENEVA_B5 -# endif -# define machine_is_geneva_b5() (machine_arch_type == MACH_TYPE_GENEVA_B5) -#else -# define machine_is_geneva_b5() (0) -#endif
-#ifdef CONFIG_MACH_SPEAR1340 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SPEAR1340 -# endif -# define machine_is_spear1340() (machine_arch_type == MACH_TYPE_SPEAR1340) -#else -# define machine_is_spear1340() (0) -#endif
-#ifdef CONFIG_MACH_REXMAS -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_REXMAS -# endif -# define machine_is_rexmas() (machine_arch_type == MACH_TYPE_REXMAS) -#else -# define machine_is_rexmas() (0) -#endif
-#ifdef CONFIG_MACH_MSM8960_CDP -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MSM8960_CDP -# endif -# define machine_is_msm8960_cdp() (machine_arch_type == MACH_TYPE_MSM8960_CDP) -#else -# define machine_is_msm8960_cdp() (0) -#endif
-#ifdef CONFIG_MACH_MSM8960_MDP -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MSM8960_MDP -# endif -# define machine_is_msm8960_mdp() (machine_arch_type == MACH_TYPE_MSM8960_MDP) -#else -# define machine_is_msm8960_mdp() (0) -#endif
-#ifdef CONFIG_MACH_MSM8960_FLUID -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MSM8960_FLUID -# endif -# define machine_is_msm8960_fluid() (machine_arch_type == MACH_TYPE_MSM8960_FLUID) -#else -# define machine_is_msm8960_fluid() (0) -#endif
-#ifdef CONFIG_MACH_MSM8960_APQ -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MSM8960_APQ -# endif -# define machine_is_msm8960_apq() (machine_arch_type == MACH_TYPE_MSM8960_APQ) -#else -# define machine_is_msm8960_apq() (0) -#endif
-#ifdef CONFIG_MACH_HELIOS_V2 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_HELIOS_V2 -# endif -# define machine_is_helios_v2() (machine_arch_type == MACH_TYPE_HELIOS_V2) -#else -# define machine_is_helios_v2() (0) -#endif
-#ifdef CONFIG_MACH_MIF10P -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MIF10P -# endif -# define machine_is_mif10p() (machine_arch_type == MACH_TYPE_MIF10P) -#else -# define machine_is_mif10p() (0) -#endif
-#ifdef CONFIG_MACH_IAM28 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_IAM28 -# endif -# define machine_is_iam28() (machine_arch_type == MACH_TYPE_IAM28) -#else -# define machine_is_iam28() (0) -#endif
-#ifdef CONFIG_MACH_PICASSO -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_PICASSO -# endif -# define machine_is_picasso() (machine_arch_type == MACH_TYPE_PICASSO) -#else -# define machine_is_picasso() (0) -#endif
-#ifdef CONFIG_MACH_MR301A -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MR301A -# endif -# define machine_is_mr301a() (machine_arch_type == MACH_TYPE_MR301A) -#else -# define machine_is_mr301a() (0) -#endif
-#ifdef CONFIG_MACH_NOTLE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NOTLE -# endif -# define machine_is_notle() (machine_arch_type == MACH_TYPE_NOTLE) -#else -# define machine_is_notle() (0) -#endif
-#ifdef CONFIG_MACH_EELX2 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_EELX2 -# endif -# define machine_is_eelx2() (machine_arch_type == MACH_TYPE_EELX2) -#else -# define machine_is_eelx2() (0) -#endif
-#ifdef CONFIG_MACH_MOON -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MOON -# endif -# define machine_is_moon() (machine_arch_type == MACH_TYPE_MOON) -#else -# define machine_is_moon() (0) -#endif
-#ifdef CONFIG_MACH_RUBY -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_RUBY -# endif -# define machine_is_ruby() (machine_arch_type == MACH_TYPE_RUBY) -#else -# define machine_is_ruby() (0) -#endif
-#ifdef CONFIG_MACH_GOLDENGATE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_GOLDENGATE -# endif -# define machine_is_goldengate() (machine_arch_type == MACH_TYPE_GOLDENGATE) -#else -# define machine_is_goldengate() (0) -#endif
-#ifdef CONFIG_MACH_CTBU_GEN2 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CTBU_GEN2 -# endif -# define machine_is_ctbu_gen2() (machine_arch_type == MACH_TYPE_CTBU_GEN2) -#else -# define machine_is_ctbu_gen2() (0) -#endif
-#ifdef CONFIG_MACH_KMP_AM17_01 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_KMP_AM17_01 -# endif -# define machine_is_kmp_am17_01() (machine_arch_type == MACH_TYPE_KMP_AM17_01) -#else -# define machine_is_kmp_am17_01() (0) -#endif
-#ifdef CONFIG_MACH_WTPLUG -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_WTPLUG -# endif -# define machine_is_wtplug() (machine_arch_type == MACH_TYPE_WTPLUG) -#else -# define machine_is_wtplug() (0) -#endif
-#ifdef CONFIG_MACH_MX27SU2 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MX27SU2 -# endif -# define machine_is_mx27su2() (machine_arch_type == MACH_TYPE_MX27SU2) -#else -# define machine_is_mx27su2() (0) -#endif
-#ifdef CONFIG_MACH_NB31 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NB31 -# endif -# define machine_is_nb31() (machine_arch_type == MACH_TYPE_NB31) -#else -# define machine_is_nb31() (0) -#endif
-#ifdef CONFIG_MACH_HJSDU -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_HJSDU -# endif -# define machine_is_hjsdu() (machine_arch_type == MACH_TYPE_HJSDU) -#else -# define machine_is_hjsdu() (0) -#endif
-#ifdef CONFIG_MACH_TD3_REV1 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TD3_REV1 -# endif -# define machine_is_td3_rev1() (machine_arch_type == MACH_TYPE_TD3_REV1) -#else -# define machine_is_td3_rev1() (0) -#endif
-#ifdef CONFIG_MACH_EAG_CI4000 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_EAG_CI4000 -# endif -# define machine_is_eag_ci4000() (machine_arch_type == MACH_TYPE_EAG_CI4000) -#else -# define machine_is_eag_ci4000() (0) -#endif
-#ifdef CONFIG_MACH_NET5BIG_NAND_V2 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NET5BIG_NAND_V2 -# endif -# define machine_is_net5big_nand_v2() (machine_arch_type == MACH_TYPE_NET5BIG_NAND_V2) -#else -# define machine_is_net5big_nand_v2() (0) -#endif
-#ifdef CONFIG_MACH_CPX2 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CPX2 -# endif -# define machine_is_cpx2() (machine_arch_type == MACH_TYPE_CPX2) -#else -# define machine_is_cpx2() (0) -#endif
-#ifdef CONFIG_MACH_NET2BIG_NAND_V2 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NET2BIG_NAND_V2 -# endif -# define machine_is_net2big_nand_v2() (machine_arch_type == MACH_TYPE_NET2BIG_NAND_V2) -#else -# define machine_is_net2big_nand_v2() (0) -#endif
-#ifdef CONFIG_MACH_ECUV5 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ECUV5 -# endif -# define machine_is_ecuv5() (machine_arch_type == MACH_TYPE_ECUV5) -#else -# define machine_is_ecuv5() (0) -#endif
-#ifdef CONFIG_MACH_HSGX6D -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_HSGX6D -# endif -# define machine_is_hsgx6d() (machine_arch_type == MACH_TYPE_HSGX6D) -#else -# define machine_is_hsgx6d() (0) -#endif
-#ifdef CONFIG_MACH_DAWAD7 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DAWAD7 -# endif -# define machine_is_dawad7() (machine_arch_type == MACH_TYPE_DAWAD7) -#else -# define machine_is_dawad7() (0) -#endif
-#ifdef CONFIG_MACH_SAM9REPEATER -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SAM9REPEATER -# endif -# define machine_is_sam9repeater() (machine_arch_type == MACH_TYPE_SAM9REPEATER) -#else -# define machine_is_sam9repeater() (0) -#endif
-#ifdef CONFIG_MACH_GT_I5700 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_GT_I5700 -# endif -# define machine_is_gt_i5700() (machine_arch_type == MACH_TYPE_GT_I5700) -#else -# define machine_is_gt_i5700() (0) -#endif
-#ifdef CONFIG_MACH_CTERA_PLUG_C2 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CTERA_PLUG_C2 -# endif -# define machine_is_ctera_plug_c2() (machine_arch_type == MACH_TYPE_CTERA_PLUG_C2) -#else -# define machine_is_ctera_plug_c2() (0) -#endif
-#ifdef CONFIG_MACH_MARVELCT -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MARVELCT -# endif -# define machine_is_marvelct() (machine_arch_type == MACH_TYPE_MARVELCT) -#else -# define machine_is_marvelct() (0) -#endif
-#ifdef CONFIG_MACH_AG11005 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_AG11005 -# endif -# define machine_is_ag11005() (machine_arch_type == MACH_TYPE_AG11005) -#else -# define machine_is_ag11005() (0) -#endif
-#ifdef CONFIG_MACH_VANGOGH -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_VANGOGH -# endif -# define machine_is_vangogh() (machine_arch_type == MACH_TYPE_VANGOGH) -#else -# define machine_is_vangogh() (0) -#endif
-#ifdef CONFIG_MACH_MATRIX505 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MATRIX505 -# endif -# define machine_is_matrix505() (machine_arch_type == MACH_TYPE_MATRIX505) -#else -# define machine_is_matrix505() (0) -#endif
-#ifdef CONFIG_MACH_OCE_NIGMA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OCE_NIGMA -# endif -# define machine_is_oce_nigma() (machine_arch_type == MACH_TYPE_OCE_NIGMA) -#else -# define machine_is_oce_nigma() (0) -#endif
-#ifdef CONFIG_MACH_T55 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_T55 -# endif -# define machine_is_t55() (machine_arch_type == MACH_TYPE_T55) -#else -# define machine_is_t55() (0) -#endif
-#ifdef CONFIG_MACH_BIO3K -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_BIO3K -# endif -# define machine_is_bio3k() (machine_arch_type == MACH_TYPE_BIO3K) -#else -# define machine_is_bio3k() (0) -#endif
-#ifdef CONFIG_MACH_EXPRESSCT -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_EXPRESSCT -# endif -# define machine_is_expressct() (machine_arch_type == MACH_TYPE_EXPRESSCT) -#else -# define machine_is_expressct() (0) -#endif
-#ifdef CONFIG_MACH_CARDHU -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CARDHU -# endif -# define machine_is_cardhu() (machine_arch_type == MACH_TYPE_CARDHU) -#else -# define machine_is_cardhu() (0) -#endif
-#ifdef CONFIG_MACH_ARUBA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ARUBA -# endif -# define machine_is_aruba() (machine_arch_type == MACH_TYPE_ARUBA) -#else -# define machine_is_aruba() (0) -#endif
-#ifdef CONFIG_MACH_BONAIRE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_BONAIRE -# endif -# define machine_is_bonaire() (machine_arch_type == MACH_TYPE_BONAIRE) -#else -# define machine_is_bonaire() (0) -#endif
-#ifdef CONFIG_MACH_NUC700EVB -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NUC700EVB -# endif -# define machine_is_nuc700evb() (machine_arch_type == MACH_TYPE_NUC700EVB) -#else -# define machine_is_nuc700evb() (0) -#endif
-#ifdef CONFIG_MACH_NUC710EVB -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NUC710EVB -# endif -# define machine_is_nuc710evb() (machine_arch_type == MACH_TYPE_NUC710EVB) -#else -# define machine_is_nuc710evb() (0) -#endif
-#ifdef CONFIG_MACH_NUC740EVB -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NUC740EVB -# endif -# define machine_is_nuc740evb() (machine_arch_type == MACH_TYPE_NUC740EVB) -#else -# define machine_is_nuc740evb() (0) -#endif
-#ifdef CONFIG_MACH_NUC745EVB -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NUC745EVB -# endif -# define machine_is_nuc745evb() (machine_arch_type == MACH_TYPE_NUC745EVB) -#else -# define machine_is_nuc745evb() (0) -#endif
-#ifdef CONFIG_MACH_TRANSCEDE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TRANSCEDE -# endif -# define machine_is_transcede() (machine_arch_type == MACH_TYPE_TRANSCEDE) -#else -# define machine_is_transcede() (0) -#endif
-#ifdef CONFIG_MACH_MORA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MORA -# endif -# define machine_is_mora() (machine_arch_type == MACH_TYPE_MORA) -#else -# define machine_is_mora() (0) -#endif
-#ifdef CONFIG_MACH_NDA_EVM -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_NDA_EVM -# endif -# define machine_is_nda_evm() (machine_arch_type == MACH_TYPE_NDA_EVM) -#else -# define machine_is_nda_evm() (0) -#endif
-#ifdef CONFIG_MACH_TIMU -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TIMU -# endif -# define machine_is_timu() (machine_arch_type == MACH_TYPE_TIMU) -#else -# define machine_is_timu() (0) -#endif
-#ifdef CONFIG_MACH_EXPRESSH -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_EXPRESSH -# endif -# define machine_is_expressh() (machine_arch_type == MACH_TYPE_EXPRESSH) -#else -# define machine_is_expressh() (0) -#endif
-#ifdef CONFIG_MACH_VERIDIS_A300 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_VERIDIS_A300 -# endif -# define machine_is_veridis_a300() (machine_arch_type == MACH_TYPE_VERIDIS_A300) -#else -# define machine_is_veridis_a300() (0) -#endif
-#ifdef CONFIG_MACH_DM368_LEOPARD -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DM368_LEOPARD -# endif -# define machine_is_dm368_leopard() (machine_arch_type == MACH_TYPE_DM368_LEOPARD) -#else -# define machine_is_dm368_leopard() (0) -#endif
-#ifdef CONFIG_MACH_OMAP_MCOP -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OMAP_MCOP -# endif -# define machine_is_omap_mcop() (machine_arch_type == MACH_TYPE_OMAP_MCOP) -#else -# define machine_is_omap_mcop() (0) -#endif
-#ifdef CONFIG_MACH_TRITIP -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TRITIP -# endif -# define machine_is_tritip() (machine_arch_type == MACH_TYPE_TRITIP) -#else -# define machine_is_tritip() (0) -#endif
-#ifdef CONFIG_MACH_SM1K -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SM1K -# endif -# define machine_is_sm1k() (machine_arch_type == MACH_TYPE_SM1K) -#else -# define machine_is_sm1k() (0) -#endif
-#ifdef CONFIG_MACH_MONCH -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MONCH -# endif -# define machine_is_monch() (machine_arch_type == MACH_TYPE_MONCH) -#else -# define machine_is_monch() (0) -#endif
-#ifdef CONFIG_MACH_CURACAO -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CURACAO -# endif -# define machine_is_curacao() (machine_arch_type == MACH_TYPE_CURACAO) -#else -# define machine_is_curacao() (0) -#endif
-#ifdef CONFIG_MACH_ORIGEN -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ORIGEN -# endif -# define machine_is_origen() (machine_arch_type == MACH_TYPE_ORIGEN) -#else -# define machine_is_origen() (0) -#endif
-#ifdef CONFIG_MACH_EPC10 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_EPC10 -# endif -# define machine_is_epc10() (machine_arch_type == MACH_TYPE_EPC10) -#else -# define machine_is_epc10() (0) -#endif
-#ifdef CONFIG_MACH_SGH_I740 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SGH_I740 -# endif -# define machine_is_sgh_i740() (machine_arch_type == MACH_TYPE_SGH_I740) -#else -# define machine_is_sgh_i740() (0) -#endif
-#ifdef CONFIG_MACH_TUNA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TUNA -# endif -# define machine_is_tuna() (machine_arch_type == MACH_TYPE_TUNA) -#else -# define machine_is_tuna() (0) -#endif
-#ifdef CONFIG_MACH_MX51_TULIP -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MX51_TULIP -# endif -# define machine_is_mx51_tulip() (machine_arch_type == MACH_TYPE_MX51_TULIP) -#else -# define machine_is_mx51_tulip() (0) -#endif
-#ifdef CONFIG_MACH_MX51_ASTER7 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MX51_ASTER7 -# endif -# define machine_is_mx51_aster7() (machine_arch_type == MACH_TYPE_MX51_ASTER7) -#else -# define machine_is_mx51_aster7() (0) -#endif
-#ifdef CONFIG_MACH_ACRO37XBRD -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ACRO37XBRD -# endif -# define machine_is_acro37xbrd() (machine_arch_type == MACH_TYPE_ACRO37XBRD) -#else -# define machine_is_acro37xbrd() (0) -#endif
-#ifdef CONFIG_MACH_ELKE -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ELKE -# endif -# define machine_is_elke() (machine_arch_type == MACH_TYPE_ELKE) -#else -# define machine_is_elke() (0) -#endif
-#ifdef CONFIG_MACH_SBC6000X -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SBC6000X -# endif -# define machine_is_sbc6000x() (machine_arch_type == MACH_TYPE_SBC6000X) -#else -# define machine_is_sbc6000x() (0) -#endif
-#ifdef CONFIG_MACH_R1801E -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_R1801E -# endif -# define machine_is_r1801e() (machine_arch_type == MACH_TYPE_R1801E) -#else -# define machine_is_r1801e() (0) -#endif
-#ifdef CONFIG_MACH_H1600 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_H1600 -# endif -# define machine_is_h1600() (machine_arch_type == MACH_TYPE_H1600) -#else -# define machine_is_h1600() (0) -#endif
-#ifdef CONFIG_MACH_MINI210 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MINI210 -# endif -# define machine_is_mini210() (machine_arch_type == MACH_TYPE_MINI210) -#else -# define machine_is_mini210() (0) -#endif
-#ifdef CONFIG_MACH_MINI8168 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MINI8168 -# endif -# define machine_is_mini8168() (machine_arch_type == MACH_TYPE_MINI8168) -#else -# define machine_is_mini8168() (0) -#endif
-#ifdef CONFIG_MACH_PC7308 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_PC7308 -# endif -# define machine_is_pc7308() (machine_arch_type == MACH_TYPE_PC7308) -#else -# define machine_is_pc7308() (0) -#endif
-#ifdef CONFIG_MACH_KMM2M01 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_KMM2M01 -# endif -# define machine_is_kmm2m01() (machine_arch_type == MACH_TYPE_KMM2M01) -#else -# define machine_is_kmm2m01() (0) -#endif
-#ifdef CONFIG_MACH_MX51EREBUS -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MX51EREBUS -# endif -# define machine_is_mx51erebus() (machine_arch_type == MACH_TYPE_MX51EREBUS) -#else -# define machine_is_mx51erebus() (0) -#endif
-#ifdef CONFIG_MACH_WM8650REFBOARD -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_WM8650REFBOARD -# endif -# define machine_is_wm8650refboard() (machine_arch_type == MACH_TYPE_WM8650REFBOARD) -#else -# define machine_is_wm8650refboard() (0) -#endif
-#ifdef CONFIG_MACH_TUXRAIL -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_TUXRAIL -# endif -# define machine_is_tuxrail() (machine_arch_type == MACH_TYPE_TUXRAIL) -#else -# define machine_is_tuxrail() (0) -#endif
-#ifdef CONFIG_MACH_ARTHUR -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ARTHUR -# endif -# define machine_is_arthur() (machine_arch_type == MACH_TYPE_ARTHUR) -#else -# define machine_is_arthur() (0) -#endif
-#ifdef CONFIG_MACH_DOORBOY -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DOORBOY -# endif -# define machine_is_doorboy() (machine_arch_type == MACH_TYPE_DOORBOY) -#else -# define machine_is_doorboy() (0) -#endif
-#ifdef CONFIG_MACH_XARINA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_XARINA -# endif -# define machine_is_xarina() (machine_arch_type == MACH_TYPE_XARINA) -#else -# define machine_is_xarina() (0) -#endif
-#ifdef CONFIG_MACH_ROVERX7 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ROVERX7 -# endif -# define machine_is_roverx7() (machine_arch_type == MACH_TYPE_ROVERX7) -#else -# define machine_is_roverx7() (0) -#endif
-#ifdef CONFIG_MACH_SDVR -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SDVR -# endif -# define machine_is_sdvr() (machine_arch_type == MACH_TYPE_SDVR) -#else -# define machine_is_sdvr() (0) -#endif
-#ifdef CONFIG_MACH_ACER_MAYA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ACER_MAYA -# endif -# define machine_is_acer_maya() (machine_arch_type == MACH_TYPE_ACER_MAYA) -#else -# define machine_is_acer_maya() (0) -#endif
-#ifdef CONFIG_MACH_PICO -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_PICO -# endif -# define machine_is_pico() (machine_arch_type == MACH_TYPE_PICO) -#else -# define machine_is_pico() (0) -#endif
-#ifdef CONFIG_MACH_CWMX233 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CWMX233 -# endif -# define machine_is_cwmx233() (machine_arch_type == MACH_TYPE_CWMX233) -#else -# define machine_is_cwmx233() (0) -#endif
-#ifdef CONFIG_MACH_CWAM1808 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CWAM1808 -# endif -# define machine_is_cwam1808() (machine_arch_type == MACH_TYPE_CWAM1808) -#else -# define machine_is_cwam1808() (0) -#endif
-#ifdef CONFIG_MACH_CWDM365 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_CWDM365 -# endif -# define machine_is_cwdm365() (machine_arch_type == MACH_TYPE_CWDM365) -#else -# define machine_is_cwdm365() (0) -#endif
-#ifdef CONFIG_MACH_MX51_MORAY -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_MX51_MORAY -# endif -# define machine_is_mx51_moray() (machine_arch_type == MACH_TYPE_MX51_MORAY) -#else -# define machine_is_mx51_moray() (0) -#endif
-#ifdef CONFIG_MACH_THALES_CBC -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_THALES_CBC -# endif -# define machine_is_thales_cbc() (machine_arch_type == MACH_TYPE_THALES_CBC) -#else -# define machine_is_thales_cbc() (0) -#endif
-#ifdef CONFIG_MACH_BLUEPOINT -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_BLUEPOINT -# endif -# define machine_is_bluepoint() (machine_arch_type == MACH_TYPE_BLUEPOINT) -#else -# define machine_is_bluepoint() (0) -#endif
-#ifdef CONFIG_MACH_DIR665 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_DIR665 -# endif -# define machine_is_dir665() (machine_arch_type == MACH_TYPE_DIR665) -#else -# define machine_is_dir665() (0) -#endif
-#ifdef CONFIG_MACH_ACMEROVER1 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ACMEROVER1 -# endif -# define machine_is_acmerover1() (machine_arch_type == MACH_TYPE_ACMEROVER1) -#else -# define machine_is_acmerover1() (0) -#endif
-#ifdef CONFIG_MACH_SHOOTER_CT -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SHOOTER_CT -# endif -# define machine_is_shooter_ct() (machine_arch_type == MACH_TYPE_SHOOTER_CT) -#else -# define machine_is_shooter_ct() (0) -#endif
-#ifdef CONFIG_MACH_BLISS -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_BLISS -# endif -# define machine_is_bliss() (machine_arch_type == MACH_TYPE_BLISS) -#else -# define machine_is_bliss() (0) -#endif
-#ifdef CONFIG_MACH_BLISSC -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_BLISSC -# endif -# define machine_is_blissc() (machine_arch_type == MACH_TYPE_BLISSC) -#else -# define machine_is_blissc() (0) -#endif
-#ifdef CONFIG_MACH_THALES_ADC -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_THALES_ADC -# endif -# define machine_is_thales_adc() (machine_arch_type == MACH_TYPE_THALES_ADC) -#else -# define machine_is_thales_adc() (0) -#endif
-#ifdef CONFIG_MACH_UBISYS_P9D_EVP -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_UBISYS_P9D_EVP -# endif -# define machine_is_ubisys_p9d_evp() (machine_arch_type == MACH_TYPE_UBISYS_P9D_EVP) -#else -# define machine_is_ubisys_p9d_evp() (0) -#endif
-#ifdef CONFIG_MACH_ATDGP318 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ATDGP318 -# endif -# define machine_is_atdgp318() (machine_arch_type == MACH_TYPE_ATDGP318) -#else -# define machine_is_atdgp318() (0) -#endif
-#ifdef CONFIG_MACH_OMAP5_SEVM -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_OMAP5_SEVM -# endif -# define machine_is_omap5_sevm() (machine_arch_type == MACH_TYPE_OMAP5_SEVM) -#else -# define machine_is_omap5_sevm() (0) -#endif
-#ifdef CONFIG_MACH_ARMADILLO800EVA -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_ARMADILLO800EVA -# endif -# define machine_is_armadillo800eva() (machine_arch_type == MACH_TYPE_ARMADILLO800EVA) -#else -# define machine_is_armadillo800eva() (0) -#endif
-#ifdef CONFIG_MACH_KZM9G -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_KZM9G -# endif -# define machine_is_kzm9g() (machine_arch_type == MACH_TYPE_KZM9G) -#else -# define machine_is_kzm9g() (0) -#endif
-#ifdef CONFIG_MACH_COLIBRI_T30 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_COLIBRI_T30 -# endif -# define machine_is_colibri_t30() (machine_arch_type == MACH_TYPE_COLIBRI_T30) -#else -# define machine_is_colibri_t30() (0) -#endif
-#ifdef CONFIG_MACH_APALIS_T30 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_APALIS_T30 -# endif -# define machine_is_apalis_t30() (machine_arch_type == MACH_TYPE_APALIS_T30) -#else -# define machine_is_apalis_t30() (0) -#endif
- These have not yet been registered
-#ifndef machine_arch_type -#define machine_arch_type __machine_arch_type -#endif +#define MACH_TYPE_ARMSTONEA9 4515 +#define MACH_TYPE_OMAP_BLAZETABLET 4516 +#define MACH_TYPE_AR6MXQ 4517 +#define MACH_TYPE_AR6MXS 4518 +#define MACH_TYPE_GWVENTANA 4520 +#define MACH_TYPE_IGEP0033 4521 +#define MACH_TYPE_H52C1_CONCERTO 4524 +#define MACH_TYPE_FCMBRD 4525 +#define MACH_TYPE_PCAAXS1 4526 +#define MACH_TYPE_LS_ORCA 4527 +#define MACH_TYPE_PCM051LB 4528 +#define MACH_TYPE_MX6S_LP507_GVCI 4529 +#define MACH_TYPE_DIDO 4530 +#define MACH_TYPE_SWARCO_ITC3_9G20 4531 +#define MACH_TYPE_ROBO_ROADY 4532 +#define MACH_TYPE_RSKRZA1 4533 +#define MACH_TYPE_SWARCO_SID 4534 +#define MACH_TYPE_MX6_IWG15S_SBC 4535 +#define MACH_TYPE_MX6Q_CAMARO 4536 +#define MACH_TYPE_HB6MXS 4537 +#define MACH_TYPE_LAGER 4538 +#define MACH_TYPE_LP8X4X 4539 +#define MACH_TYPE_TEGRATAB7 4540 +#define MACH_TYPE_ANDROMEDA 4541 +#define MACH_TYPE_BOOTES 4542 +#define MACH_TYPE_NETHMI 4543 +#define MACH_TYPE_TEGRATAB 4544 +#define MACH_TYPE_SOM5_EVB 4545 +#define MACH_TYPE_VENATICORUM 4546 +#define MACH_TYPE_STM_B2110 4547 +#define MACH_TYPE_ELUX_HATHOR 4548 +#define MACH_TYPE_HELIOS_V7 4549 +#define MACH_TYPE_XC10V1 4550 +#define MACH_TYPE_CP2U 4551 +#define MACH_TYPE_IAP_F 4552 +#define MACH_TYPE_IAP_G 4553 +#define MACH_TYPE_AAE 4554 +#define MACH_TYPE_PEGASUS 4555 +#define MACH_TYPE_CYGNUS 4556 +#define MACH_TYPE_CENTAURUS 4557 +#define MACH_TYPE_MSM8930_QRD8930 4558 +#define MACH_TYPE_QUBY_TIM 4559 +#define MACH_TYPE_ZEDI3250A 4560 +#define MACH_TYPE_GRUS 4561 +#define MACH_TYPE_APOLLO3 4562 +#define MACH_TYPE_COWON_R7 4563 +#define MACH_TYPE_TONGA3 4564 +#define MACH_TYPE_P535 4565 +#define MACH_TYPE_SA3874I 4566 +#define MACH_TYPE_MX6_NAVICO_COM 4567 +#define MACH_TYPE_PROXMOBIL2 4568 +#define MACH_TYPE_UBINUX1 4569 +#define MACH_TYPE_ISTOS 4570 +#define MACH_TYPE_BENVOLIO4 4571 +#define MACH_TYPE_ECO5_BX2 4572 +#define MACH_TYPE_EUKREA_CPUIMX28SD 4573 +#define MACH_TYPE_DOMOTAB 4574 +#define MACH_TYPE_PFLA03 4575
#endif diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 00ee3f10cdae..1ad9f7e9e7ab 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -106,66 +106,27 @@ CONFIG_APER_SIZE CONFIG_API CONFIG_APUS_FAST_EXCEPT CONFIG_AP_SH4A_4A -CONFIG_ARCH_AAED2000 -CONFIG_ARCH_ADI_COYOTE CONFIG_ARCH_ADPAG101P -CONFIG_ARCH_AT91RM9200DK -CONFIG_ARCH_AUTCPU12 -CONFIG_ARCH_BAST -CONFIG_ARCH_CATS -CONFIG_ARCH_CDB89712 -CONFIG_ARCH_CEIVA -CONFIG_ARCH_CLEP7212 CONFIG_ARCH_CPU_INIT CONFIG_ARCH_CSB226 CONFIG_ARCH_DMA_PIO_WORDS CONFIG_ARCH_EARLY_INIT_R -CONFIG_ARCH_EBSA110 -CONFIG_ARCH_EBSA285 -CONFIG_ARCH_EDB7211 -CONFIG_ARCH_ENP2611 -CONFIG_ARCH_FORTUNET -CONFIG_ARCH_GUMSTIX -CONFIG_ARCH_H1940 -CONFIG_ARCH_H5400 -CONFIG_ARCH_H7201 -CONFIG_ARCH_H7202 CONFIG_ARCH_HAS_ILOG2_U32 CONFIG_ARCH_HAS_ILOG2_U64 CONFIG_ARCH_INNOKOM -CONFIG_ARCH_IQ31244 -CONFIG_ARCH_IQ80321 -CONFIG_ARCH_IQ80331 -CONFIG_ARCH_IXCDP1100 -CONFIG_ARCH_IXDP2400 -CONFIG_ARCH_IXDP2401 -CONFIG_ARCH_IXDP2800 -CONFIG_ARCH_IXDP2801 -CONFIG_ARCH_IXDP425 CONFIG_ARCH_KIRKWOOD -CONFIG_ARCH_KS8695 -CONFIG_ARCH_L7200 CONFIG_ARCH_LUBBOCK CONFIG_ARCH_MAP_SYSMEM CONFIG_ARCH_MISC_INIT -CONFIG_ARCH_MX1ADS -CONFIG_ARCH_NETWINDER CONFIG_ARCH_OMAP4 CONFIG_ARCH_ORION5X -CONFIG_ARCH_P720T -CONFIG_ARCH_PERSONAL_SERVER CONFIG_ARCH_PLEB CONFIG_ARCH_PXA_CERF CONFIG_ARCH_PXA_IDP CONFIG_ARCH_RMOBILE_BOARD_STRING CONFIG_ARCH_RMOBILE_EXTRAM_BOOT -CONFIG_ARCH_RPC -CONFIG_ARCH_S3C2440 -CONFIG_ARCH_SHARK CONFIG_ARCH_TEGRA CONFIG_ARCH_USE_BUILTIN_BSWAP -CONFIG_ARCH_VERSATILE_PB -CONFIG_ARCH_VIPER CONFIG_ARC_MMU_VER CONFIG_ARC_SERIAL CONFIG_ARC_UART_BASE @@ -1931,1037 +1892,21 @@ CONFIG_MACB1_PHY CONFIG_MACB2_PHY CONFIG_MACB3_PHY CONFIG_MACB_SEARCH_PHY -CONFIG_MACH_A0 -CONFIG_MACH_A2F -CONFIG_MACH_ABACUS -CONFIG_MACH_ABB_GMA_1_1 -CONFIG_MACH_ABILENE -CONFIG_MACH_ABLE -CONFIG_MACH_ACER_A5 -CONFIG_MACH_ACER_A8 -CONFIG_MACH_ACER_GAUGUIN -CONFIG_MACH_ACER_MAYA -CONFIG_MACH_ACMENETUSFOXG20 -CONFIG_MACH_ACMEROVER1 -CONFIG_MACH_ACRO37XBRD -CONFIG_MACH_ACS5K -CONFIG_MACH_ACSX106 -CONFIG_MACH_ADSSPHERE -CONFIG_MACH_AEBL -CONFIG_MACH_AF4000 -CONFIG_MACH_AFEB9260 -CONFIG_MACH_AG11005 -CONFIG_MACH_AG5EVM -CONFIG_MACH_AKITA -CONFIG_MACH_AMK_A4 -CONFIG_MACH_AML_M5900 -CONFIG_MACH_AMS_DELTA -CONFIG_MACH_ANCHOVY -CONFIG_MACH_ANTARES -CONFIG_MACH_ANTERO -CONFIG_MACH_ANUBIS -CONFIG_MACH_ANW6410 -CONFIG_MACH_AP4EVB -CONFIG_MACH_APALIS_T30 -CONFIG_MACH_APP3K_ROBIN -CONFIG_MACH_AQUARIUS -CONFIG_MACH_AQUILA -CONFIG_MACH_ARCOM_VULCAN -CONFIG_MACH_ARCOM_ZEUS -CONFIG_MACH_ARK9431 -CONFIG_MACH_ARMADA_XP_DB -CONFIG_MACH_ARMADILLO460 -CONFIG_MACH_ARMADILLO5X0 -CONFIG_MACH_ARMADILLO800EVA -CONFIG_MACH_ARMCORE -CONFIG_MACH_ARMLEX4210 -CONFIG_MACH_ARMLGUEST -CONFIG_MACH_AROWANA -CONFIG_MACH_ARTHUR -CONFIG_MACH_ARUBA -CONFIG_MACH_AS1167 -CONFIG_MACH_ASL_PHOENIX -CONFIG_MACH_ASPEN CONFIG_MACH_ASPENITE -CONFIG_MACH_AST2200 -CONFIG_MACH_AT2440EVB -CONFIG_MACH_AT572D940HFEB -CONFIG_MACH_AT91CAP7STK -CONFIG_MACH_AT91CAP7XDK -CONFIG_MACH_AT91CAP9ADK -CONFIG_MACH_AT91EB01 -CONFIG_MACH_AT91RM9200EK -CONFIG_MACH_AT91SAM9260EK -CONFIG_MACH_AT91SAM9261EK -CONFIG_MACH_AT91SAM9263DESK16L -CONFIG_MACH_AT91SAM9263EK -CONFIG_MACH_AT91SAM9263OTLITE -CONFIG_MACH_AT91SAM9G10EK -CONFIG_MACH_AT91SAM9G20EK -CONFIG_MACH_AT91SAM9G20EK_2MMC -CONFIG_MACH_AT91SAM9G45EKES -CONFIG_MACH_AT91SAM9M10G45EK -CONFIG_MACH_AT91SAM9RLEK -CONFIG_MACH_AT91SAM9X5EK -CONFIG_MACH_ATDGP318 -CONFIG_MACH_ATEB9200 -CONFIG_MACH_ATHENE -CONFIG_MACH_ATLAS5_C1 -CONFIG_MACH_AUTOBOT -CONFIG_MACH_AVENGERS_LITE -CONFIG_MACH_AVILA -CONFIG_MACH_AWM2 -CONFIG_MACH_AX502 -CONFIG_MACH_AX8008 -CONFIG_MACH_B5500 -CONFIG_MACH_BASI -CONFIG_MACH_BCM2708 -CONFIG_MACH_BCM589X -CONFIG_MACH_BCMHANA_SV -CONFIG_MACH_BCMHANA_TABLET -CONFIG_MACH_BCMRING -CONFIG_MACH_BEECT -CONFIG_MACH_BIGDISK -CONFIG_MACH_BIO3K -CONFIG_MACH_BIPNET -CONFIG_MACH_BLISS -CONFIG_MACH_BLISSC -CONFIG_MACH_BLUECHEESE -CONFIG_MACH_BLUEPOINT -CONFIG_MACH_BLUESHARK -CONFIG_MACH_BOCKW -CONFIG_MACH_BONAIRE -CONFIG_MACH_BORABORA -CONFIG_MACH_BORZOI -CONFIG_MACH_BROWNSTONE -CONFIG_MACH_BSTBRD -CONFIG_MACH_BTMAVB101 -CONFIG_MACH_BTMAWB101 -CONFIG_MACH_BUBBA3 -CONFIG_MACH_BUG -CONFIG_MACH_BUG20 -CONFIG_MACH_BURY_BL7582 -CONFIG_MACH_BURY_BPS5270 -CONFIG_MACH_BV07 -CONFIG_MACH_C2MMI -CONFIG_MACH_CALLISTO -CONFIG_MACH_CAM60 -CONFIG_MACH_CAPC7117 -CONFIG_MACH_CARDHU -CONFIG_MACH_CARMEVA -CONFIG_MACH_CAYENNE -CONFIG_MACH_CC9P9360DEV -CONFIG_MACH_CC9P9360JS -CONFIG_MACH_CCMX53 -CONFIG_MACH_CCMX53JS -CONFIG_MACH_CCWMX51MUT -CONFIG_MACH_CCWMX53 -CONFIG_MACH_CCWMX53JS -CONFIG_MACH_CENTRO -CONFIG_MACH_CETUS9263 -CONFIG_MACH_CHACHA -CONFIG_MACH_CHALTEN_XA1 -CONFIG_MACH_CHARON -CONFIG_MACH_CLOD -CONFIG_MACH_CM4745 -CONFIG_MACH_CM_A510 -CONFIG_MACH_CM_T35 -CONFIG_MACH_CM_T3517 -CONFIG_MACH_CM_T3730 -CONFIG_MACH_CM_X300 -CONFIG_MACH_CNS2133EVB -CONFIG_MACH_CNS21XX -CONFIG_MACH_CNS3420VB -CONFIG_MACH_COBRAL138 -CONFIG_MACH_COCONUT -CONFIG_MACH_COLIBRI -CONFIG_MACH_COLIBRI300 -CONFIG_MACH_COLIBRI320 -CONFIG_MACH_COLIBRI_T20 -CONFIG_MACH_COLIBRI_T30 -CONFIG_MACH_CONTROLTEK9G20 -CONFIG_MACH_CORETEC_VCX7400 -CONFIG_MACH_CORGI -CONFIG_MACH_CPUAT9G20 -CONFIG_MACH_CPX2 -CONFIG_MACH_CRANEBOARD -CONFIG_MACH_CRUX -CONFIG_MACH_CSB337 -CONFIG_MACH_CSB637 -CONFIG_MACH_CSB726 -CONFIG_MACH_CSC -CONFIG_MACH_CTBU_GEN2 -CONFIG_MACH_CTERA_PLUG_C2 -CONFIG_MACH_CURACAO -CONFIG_MACH_CV2201 -CONFIG_MACH_CV2202 -CONFIG_MACH_CV2203 -CONFIG_MACH_CWAM1808 -CONFIG_MACH_CWDM365 -CONFIG_MACH_CWME9210 -CONFIG_MACH_CWME9210JS -CONFIG_MACH_CWMX233 -CONFIG_MACH_D2NET -CONFIG_MACH_D2NET_V2 -CONFIG_MACH_D2PLUG -CONFIG_MACH_DA850_K5 -CONFIG_MACH_DAINTREE_CWAC -CONFIG_MACH_DATAWAY CONFIG_MACH_DAVINCI_CALIMAIN -CONFIG_MACH_DAVINCI_DA830_EVM CONFIG_MACH_DAVINCI_DA850_EVM -CONFIG_MACH_DAVINCI_DM355_EVM -CONFIG_MACH_DAVINCI_DM355_MMM -CONFIG_MACH_DAVINCI_DM365_BV -CONFIG_MACH_DAVINCI_DM365_DVR -CONFIG_MACH_DAVINCI_DM365_EVM -CONFIG_MACH_DAVINCI_DM6467TEVM -CONFIG_MACH_DAVINCI_DM6467_EVM -CONFIG_MACH_DAVINCI_EVM -CONFIG_MACH_DAVINCI_PICTO -CONFIG_MACH_DAWAD7 -CONFIG_MACH_DB78X00_BP -CONFIG_MACH_DB88F5281 -CONFIG_MACH_DB88F6281_BP -CONFIG_MACH_DDNAS -CONFIG_MACH_DDPLUG -CONFIG_MACH_DDS -CONFIG_MACH_DEEP_R_EK_1 -CONFIG_MACH_DEVIXP -CONFIG_MACH_DEVKIT8000 -CONFIG_MACH_DGM3240 -CONFIG_MACH_DIMMSAM9G20 -CONFIG_MACH_DIMM_IMX28 -CONFIG_MACH_DIMM_MX257 -CONFIG_MACH_DINGO -CONFIG_MACH_DIR665 -CONFIG_MACH_DM355_LEOPARD -CONFIG_MACH_DM365_CV100 -CONFIG_MACH_DM368_LEOPARD -CONFIG_MACH_DM3730_SOM_LV -CONFIG_MACH_DM3730_TORPEDO -CONFIG_MACH_DM6441_ESP -CONFIG_MACH_DM6446_ADBOX -CONFIG_MACH_DMA6410 -CONFIG_MACH_DMA_THUNDERBUG -CONFIG_MACH_DMW96 -CONFIG_MACH_DNS323 CONFIG_MACH_DOCKSTAR -CONFIG_MACH_DOORBOY -CONFIG_MACH_DOUBLESHOT -CONFIG_MACH_DOVE_AVNG_V3 -CONFIG_MACH_DOVE_DB -CONFIG_MACH_DP6XX -CONFIG_MACH_DRAGONET -CONFIG_MACH_DSM320 -CONFIG_MACH_DSMG600 -CONFIG_MACH_DURIAN -CONFIG_MACH_DYNASTY -CONFIG_MACH_E10 -CONFIG_MACH_E330 -CONFIG_MACH_E350 -CONFIG_MACH_E400 -CONFIG_MACH_E740 -CONFIG_MACH_E750 -CONFIG_MACH_E800 -CONFIG_MACH_EA20 -CONFIG_MACH_EA2478DEVKIT -CONFIG_MACH_EAG_CI4000 -CONFIG_MACH_EASYCRRH -CONFIG_MACH_EC4350SDB -CONFIG_MACH_EC4350TBM -CONFIG_MACH_ECBAT91 -CONFIG_MACH_ECO920 -CONFIG_MACH_ECUV5 -CONFIG_MACH_EDB9301 -CONFIG_MACH_EDB9302 -CONFIG_MACH_EDB9302A -CONFIG_MACH_EDB9307 -CONFIG_MACH_EDB9307A -CONFIG_MACH_EDB9312 -CONFIG_MACH_EDB9315 -CONFIG_MACH_EDB9315A -CONFIG_MACH_EDISON CONFIG_MACH_EDMINIV2 -CONFIG_MACH_EDMINI_V2 -CONFIG_MACH_EELX2 -CONFIG_MACH_EIGEN_TTR -CONFIG_MACH_ELEPHANT -CONFIG_MACH_ELKE -CONFIG_MACH_ELOG -CONFIG_MACH_EM1SY -CONFIG_MACH_EM7210 -CONFIG_MACH_EMERALD -CONFIG_MACH_EM_X270 -CONFIG_MACH_ENCORE -CONFIG_MACH_ENDIAN_MINI -CONFIG_MACH_EP80219 -CONFIG_MACH_EPC10 -CONFIG_MACH_EPIPHAN -CONFIG_MACH_ES2440 -CONFIG_MACH_ESATA_SHEEVAPLUG -CONFIG_MACH_ESL_MOBILIS_A -CONFIG_MACH_ESL_MOBILIS_B -CONFIG_MACH_ESL_WAVE_A -CONFIG_MACH_ESL_WAVE_B -CONFIG_MACH_ESPRESSO -CONFIG_MACH_ETHERPRO_ISP -CONFIG_MACH_ETNA -CONFIG_MACH_EUKREA_CPUIMX25SD -CONFIG_MACH_EUKREA_CPUIMX35SD -CONFIG_MACH_EUKREA_CPUIMX51 -CONFIG_MACH_EUKREA_CPUIMX51SD -CONFIG_MACH_EVA2000 -CONFIG_MACH_EVSY -CONFIG_MACH_EXEDA -CONFIG_MACH_EXPRESS -CONFIG_MACH_EXPRESSCT -CONFIG_MACH_EXPRESSH -CONFIG_MACH_EXPRESS_KT -CONFIG_MACH_EZX_A1200 -CONFIG_MACH_EZX_A780 -CONFIG_MACH_EZX_A910 -CONFIG_MACH_EZX_E2 -CONFIG_MACH_EZX_E6 -CONFIG_MACH_EZX_E680 -CONFIG_MACH_FA9X27 -CONFIG_MACH_FFCORE -CONFIG_MACH_FLEXIBITY -CONFIG_MACH_FLINT -CONFIG_MACH_FLYER -CONFIG_MACH_FRISMS -CONFIG_MACH_FRRHWCDMA60W -CONFIG_MACH_FSG -CONFIG_MACH_FSM9XXX_FFA -CONFIG_MACH_FSM9XXX_SURF -CONFIG_MACH_FS_S5PC100 -CONFIG_MACH_FUJI -CONFIG_MACH_FWBD_0404 -CONFIG_MACH_G3EVM -CONFIG_MACH_G4EVM -CONFIG_MACH_GATEWAY7001 -CONFIG_MACH_GENEVA_B5 -CONFIG_MACH_GESBC9312 -CONFIG_MACH_GFS_SPM -CONFIG_MACH_GINGER -CONFIG_MACH_GIRA_KNXIP_ROUTER -CONFIG_MACH_GLANTANK -CONFIG_MACH_GNET_SGCE -CONFIG_MACH_GNET_SGME -CONFIG_MACH_GNET_SLC CONFIG_MACH_GOFLEXHOME -CONFIG_MACH_GOFLEXNET -CONFIG_MACH_GOLDENGATE CONFIG_MACH_GONI -CONFIG_MACH_GORAMO_MLR -CONFIG_MACH_GPSDISPLAY -CONFIG_MACH_GREECO -CONFIG_MACH_GSIA18S -CONFIG_MACH_GSL_DIAMOND -CONFIG_MACH_GSNCOMM -CONFIG_MACH_GTA04 -CONFIG_MACH_GTIB -CONFIG_MACH_GTL_IT5100 -CONFIG_MACH_GTWX5715 -CONFIG_MACH_GT_I5700 -CONFIG_MACH_GUPPY -CONFIG_MACH_GURNARD CONFIG_MACH_GURUPLUG -CONFIG_MACH_GW2361 -CONFIG_MACH_H1600 -CONFIG_MACH_H4700 -CONFIG_MACH_HABA_KNX_EXPLORER -CONFIG_MACH_HALIBUT -CONFIG_MACH_HAMMERHEAD -CONFIG_MACH_HARMONY -CONFIG_MACH_HARVEST_DESOTO -CONFIG_MACH_HAWKS -CONFIG_MACH_HDGU -CONFIG_MACH_HDMINI -CONFIG_MACH_HDNVP -CONFIG_MACH_HELIOS_V1 -CONFIG_MACH_HELIOS_V2 -CONFIG_MACH_HERALD -CONFIG_MACH_HERRING -CONFIG_MACH_HIMALAYA -CONFIG_MACH_HJSDU -CONFIG_MACH_HKDKC100 -CONFIG_MACH_HMT -CONFIG_MACH_HOLIDAY -CONFIG_MACH_HREFV60 -CONFIG_MACH_HSGX6D -CONFIG_MACH_HTCMEGA -CONFIG_MACH_HTCTORNADO -CONFIG_MACH_HTC_HD_MINI -CONFIG_MACH_HTC_SPV_M700 -CONFIG_MACH_HUASHAN -CONFIG_MACH_HUSKY -CONFIG_MACH_HWGW6410 -CONFIG_MACH_IAM28 -CONFIG_MACH_ICON -CONFIG_MACH_ICONG -CONFIG_MACH_ICONNECT -CONFIG_MACH_ICONTROL -CONFIG_MACH_ICON_G -CONFIG_MACH_ICS_IF_VOIP -CONFIG_MACH_IDEA6410 -CONFIG_MACH_IGEP0020 -CONFIG_MACH_IGEP0030 -CONFIG_MACH_IGEP0032 -CONFIG_MACH_IJ3K_2440 -CONFIG_MACH_IMATE8502 -CONFIG_MACH_IMX27IPCAM -CONFIG_MACH_IMX27LITE -CONFIG_MACH_IMX27_VISSTRIM_M10 -CONFIG_MACH_INCOME -CONFIG_MACH_INETSPACE_V2 -CONFIG_MACH_INHAND_APEIRON -CONFIG_MACH_INHAND_FURY -CONFIG_MACH_INHAND_SIREN -CONFIG_MACH_INTELMOTE2 -CONFIG_MACH_IOMEGA_IX2_200 -CONFIG_MACH_IQ80332 -CONFIG_MACH_IQ81340MC -CONFIG_MACH_IQ81340SC -CONFIG_MACH_ISC3 -CONFIG_MACH_IXDP2351 -CONFIG_MACH_IXDP28X5 -CONFIG_MACH_IXDP465 -CONFIG_MACH_IXDPG425 -CONFIG_MACH_JANUS -CONFIG_MACH_JIGEN -CONFIG_MACH_JIVE -CONFIG_MACH_JOCPU550 -CONFIG_MACH_KAEN -CONFIG_MACH_KAFA -CONFIG_MACH_KB9200 -CONFIG_MACH_KEV7A400 -CONFIG_MACH_KINGDOM -CONFIG_MACH_KIXRP435 -CONFIG_MACH_KMM2M01 -CONFIG_MACH_KMP_AM17_01 CONFIG_MACH_KM_KIRKWOOD -CONFIG_MACH_KOI -CONFIG_MACH_KRONOS -CONFIG_MACH_KT_SBC_SAM9_1 -CONFIG_MACH_KUROBOX_PRO -CONFIG_MACH_KX33XX -CONFIG_MACH_KZM9D -CONFIG_MACH_KZM9G -CONFIG_MACH_KZM_ARM11_01 -CONFIG_MACH_LANREADYFN511 -CONFIG_MACH_LAUSANNE -CONFIG_MACH_LB88RC8480 -CONFIG_MACH_LEAD -CONFIG_MACH_LEGACY -CONFIG_MACH_LEMON -CONFIG_MACH_LIBRA -CONFIG_MACH_LIGHTNING -CONFIG_MACH_LILLY1131 -CONFIG_MACH_LINKSTATION_CHLV2 -CONFIG_MACH_LINKSTATION_LSCHL -CONFIG_MACH_LINKSTATION_LS_HGL -CONFIG_MACH_LINKSTATION_MINI -CONFIG_MACH_LINKSTATION_PRO -CONFIG_MACH_LITTLETON -CONFIG_MACH_LOFT -CONFIG_MACH_LOGICPD_PXA270 -CONFIG_MACH_LPC24XX -CONFIG_MACH_LPD7A400 -CONFIG_MACH_LPD7A404 -CONFIG_MACH_LQ2 -CONFIG_MACH_LS9G20 -CONFIG_MACH_LSWXL -CONFIG_MACH_M502 -CONFIG_MACH_MACH_SDH001 -CONFIG_MACH_MACKEREL -CONFIG_MACH_MAGICIAN -CONFIG_MACH_MAGX_ZN5 -CONFIG_MACH_MAHIMAHI -CONFIG_MACH_MAINSTONE -CONFIG_MACH_MANUAE -CONFIG_MACH_MAPLE1 -CONFIG_MACH_MARVEL -CONFIG_MACH_MARVELC -CONFIG_MACH_MARVELCT -CONFIG_MACH_MARVELL_JASPER -CONFIG_MACH_MATRIX505 -CONFIG_MACH_MATRIX518 -CONFIG_MACH_MAXIMASP -CONFIG_MACH_MB3 -CONFIG_MACH_MECHA -CONFIG_MACH_MENO_QNG -CONFIG_MACH_MESON -CONFIG_MACH_MESON_6236M -CONFIG_MACH_MESON_8626M -CONFIG_MACH_MESSINA -CONFIG_MACH_MIC256 -CONFIG_MACH_MICCPT -CONFIG_MACH_MICRO9 -CONFIG_MACH_MICRO9L -CONFIG_MACH_MICRO9M -CONFIG_MACH_MICRO9S -CONFIG_MACH_MIF10P -CONFIG_MACH_MIMAS -CONFIG_MACH_MINI210 -CONFIG_MACH_MINI2440 -CONFIG_MACH_MINI6410 -CONFIG_MACH_MINI8168 -CONFIG_MACH_MIOA502 -CONFIG_MACH_MIOA701 -CONFIG_MACH_MIONE -CONFIG_MACH_MIOS_V1 -CONFIG_MACH_MITYOMAPL138 -CONFIG_MACH_MMM -CONFIG_MACH_MONCH -CONFIG_MACH_MONE -CONFIG_MACH_MOON -CONFIG_MACH_MORA -CONFIG_MACH_MR301A -CONFIG_MACH_MSM7X25_FFA -CONFIG_MACH_MSM7X25_SURF -CONFIG_MACH_MSM7X27A_FFA -CONFIG_MACH_MSM7X27A_RUMI3 -CONFIG_MACH_MSM7X27A_SURF -CONFIG_MACH_MSM7X27_FFA -CONFIG_MACH_MSM7X27_SURF -CONFIG_MACH_MSM7X30_FFA -CONFIG_MACH_MSM7X30_FLUID -CONFIG_MACH_MSM7X30_SURF -CONFIG_MACH_MSM8960_APQ -CONFIG_MACH_MSM8960_CDP -CONFIG_MACH_MSM8960_FLUID -CONFIG_MACH_MSM8960_MDP -CONFIG_MACH_MSM8960_RUMI3 -CONFIG_MACH_MSM8960_SIM -CONFIG_MACH_MSM8X55_SVLTE_FFA -CONFIG_MACH_MSM8X55_SVLTE_SURF -CONFIG_MACH_MSM8X60_FFA -CONFIG_MACH_MSM8X60_FLUID -CONFIG_MACH_MSM8X60_QRDC -CONFIG_MACH_MSM8X60_QT -CONFIG_MACH_MSM8X60_RUMI3 -CONFIG_MACH_MSM8X60_SIM -CONFIG_MACH_MSM8X60_SURF -CONFIG_MACH_MSS2 -CONFIG_MACH_MULTHSU -CONFIG_MACH_MV2120 -CONFIG_MACH_MV88F6281GTW_GE -CONFIG_MACH_MVBLX -CONFIG_MACH_MX21ADS -CONFIG_MACH_MX23EVK -CONFIG_MACH_MX257SOL -CONFIG_MACH_MX257SX -CONFIG_MACH_MX25_3DS -CONFIG_MACH_MX25_E2S_UC -CONFIG_MACH_MX27ADS -CONFIG_MACH_MX27SU2 -CONFIG_MACH_MX27_3DS -CONFIG_MACH_MX27_WMULTRA -CONFIG_MACH_MX28EVK -CONFIG_MACH_MX31ADS -CONFIG_MACH_MX31LITE -CONFIG_MACH_MX31MOBOARD -CONFIG_MACH_MX31_3DS -CONFIG_MACH_MX35_3DS -CONFIG_MACH_MX50_ARM2 -CONFIG_MACH_MX50_RDP -CONFIG_MACH_MX51EREBUS -CONFIG_MACH_MX51_3DS -CONFIG_MACH_MX51_ASTER7 -CONFIG_MACH_MX51_BABBAGE -CONFIG_MACH_MX51_BRAVO -CONFIG_MACH_MX51_EFIKAMX -CONFIG_MACH_MX51_EFIKASB -CONFIG_MACH_MX51_GGC -CONFIG_MACH_MX51_MORAY -CONFIG_MACH_MX51_TULIP -CONFIG_MACH_MX53_ARD -CONFIG_MACH_MX53_EVK -CONFIG_MACH_MX53_LOCO -CONFIG_MACH_MX53_SMD -CONFIG_MACH_MX61_ARD -CONFIG_MACH_MXC25_TOPAZ -CONFIG_MACH_MXLADS -CONFIG_MACH_MXT_TD60 -CONFIG_MACH_MXT_TD61 -CONFIG_MACH_N2100 -CONFIG_MACH_N30 -CONFIG_MACH_N35 -CONFIG_MACH_NAJAY_A9263 -CONFIG_MACH_NANOS -CONFIG_MACH_NANOZOOM -CONFIG_MACH_NAS100D -CONFIG_MACH_NAS4220B -CONFIG_MACH_NAS6210 -CONFIG_MACH_NAVEFIHID -CONFIG_MACH_NAXY1200 -CONFIG_MACH_NAXY400 -CONFIG_MACH_NB31 -CONFIG_MACH_NCP -CONFIG_MACH_NDA_EVM -CONFIG_MACH_NEC_MP900 -CONFIG_MACH_NEO1973_GTA02 -CONFIG_MACH_NEOCORE926 -CONFIG_MACH_NERY_1000 -CONFIG_MACH_NET2BIG -CONFIG_MACH_NET2BIG_NAND_V2 -CONFIG_MACH_NET2BIG_V2 -CONFIG_MACH_NET5BIG_NAND_V2 -CONFIG_MACH_NET5BIG_V2 -CONFIG_MACH_NETSPACE_LITE_V2 -CONFIG_MACH_NETSPACE_MAX_V2 -CONFIG_MACH_NETSPACE_V2 -CONFIG_MACH_NETVIZ -CONFIG_MACH_NETWALKER -CONFIG_MACH_NEUROS_OSD2 -CONFIG_MACH_NEXCODER_2440 -CONFIG_MACH_NITROGEN_IMX51 -CONFIG_MACH_NITROGEN_IMX53 -CONFIG_MACH_NITROGEN_VM_IMX51 -CONFIG_MACH_NMH -CONFIG_MACH_NOKIA770 -CONFIG_MACH_NOKIA_N800 -CONFIG_MACH_NOKIA_N810 -CONFIG_MACH_NOKIA_N810_WIMAX -CONFIG_MACH_NOKIA_RM680 -CONFIG_MACH_NOKIA_RX51 -CONFIG_MACH_NOMADIK -CONFIG_MACH_NOTLE -CONFIG_MACH_NS2416 -CONFIG_MACH_NS2816TB -CONFIG_MACH_NS2816_NTNB -CONFIG_MACH_NS2816_NTPAD -CONFIG_MACH_NSB3AST -CONFIG_MACH_NSK330 -CONFIG_MACH_NSLU2 -CONFIG_MACH_NSSLSBOARD -CONFIG_MACH_NS_K330 -CONFIG_MACH_NUC700EVB -CONFIG_MACH_NUC710EVB -CONFIG_MACH_NUC740EVB -CONFIG_MACH_NUC745EVB -CONFIG_MACH_NUC932EVB -CONFIG_MACH_NUC950TS -CONFIG_MACH_NURI -CONFIG_MACH_NV1000 -CONFIG_MACH_NXDB500 -CONFIG_MACH_NXDKN -CONFIG_MACH_NXEB500HMI -CONFIG_MACH_OCE_NIGMA -CONFIG_MACH_OMAP2EVM -CONFIG_MACH_OMAP3505NOVA8 -CONFIG_MACH_OMAP3517EVM -CONFIG_MACH_OMAP3530_LV_SOM -CONFIG_MACH_OMAP3621_EDP1 -CONFIG_MACH_OMAP3EVM -CONFIG_MACH_OMAP3SMARTDISPLAY -CONFIG_MACH_OMAP3_BAIA -CONFIG_MACH_OMAP3_BC10 -CONFIG_MACH_OMAP3_BEAGLE -CONFIG_MACH_OMAP3_BRAILLO -CONFIG_MACH_OMAP3_IBIZA -CONFIG_MACH_OMAP3_PANDORA -CONFIG_MACH_OMAP3_RFS200 -CONFIG_MACH_OMAP3_TDM3730 -CONFIG_MACH_OMAP3_TORPEDO -CONFIG_MACH_OMAP3_WALDO1 -CONFIG_MACH_OMAP4_PANDA -CONFIG_MACH_OMAP5_SEVM -CONFIG_MACH_OMAPL138_CASE_A3 -CONFIG_MACH_OMAPL138_EUROPALC -CONFIG_MACH_OMAPL138_HAWKBOARD CONFIG_MACH_OMAPL138_LCDK -CONFIG_MACH_OMAP_2430SDP -CONFIG_MACH_OMAP_3430SDP -CONFIG_MACH_OMAP_3630SDP -CONFIG_MACH_OMAP_4430SDP -CONFIG_MACH_OMAP_APOLLON -CONFIG_MACH_OMAP_BENDER -CONFIG_MACH_OMAP_FSAMPLE -CONFIG_MACH_OMAP_GENERIC -CONFIG_MACH_OMAP_H2 -CONFIG_MACH_OMAP_H3 -CONFIG_MACH_OMAP_H4 -CONFIG_MACH_OMAP_INNOVATOR -CONFIG_MACH_OMAP_LDP -CONFIG_MACH_OMAP_MCOP -CONFIG_MACH_OMAP_OSK -CONFIG_MACH_OMAP_PALMTE -CONFIG_MACH_OMAP_PALMTT -CONFIG_MACH_OMAP_PALMZ71 -CONFIG_MACH_OMAP_PERSEUS2 -CONFIG_MACH_OMAP_ZOOM2 -CONFIG_MACH_OMAP_ZOOM3 -CONFIG_MACH_OMN_AT91SAM9G20 -CONFIG_MACH_ONEARM CONFIG_MACH_OPENRD_BASE -CONFIG_MACH_OPENRD_CLIENT -CONFIG_MACH_OPENRD_ULTIMATE -CONFIG_MACH_ORATISAES -CONFIG_MACH_ORATISLINK -CONFIG_MACH_ORIGEN -CONFIG_MACH_OSIRIS -CONFIG_MACH_OSLO_AMUNDSEN -CONFIG_MACH_OTOM -CONFIG_MACH_OVERO -CONFIG_MACH_OVERO_CTU_INERTIAL -CONFIG_MACH_P87_SMARTSIM -CONFIG_MACH_PALMLD -CONFIG_MACH_PALMT5 -CONFIG_MACH_PALMTC -CONFIG_MACH_PALMTE2 -CONFIG_MACH_PALMTX -CONFIG_MACH_PALMZ72 -CONFIG_MACH_PAZ00 -CONFIG_MACH_PC7302 -CONFIG_MACH_PC7308 -CONFIG_MACH_PC9260_V2 -CONFIG_MACH_PCA100 -CONFIG_MACH_PCA102 -CONFIG_MACH_PCATS_OVERLAY -CONFIG_MACH_PCM027 -CONFIG_MACH_PCM037 -CONFIG_MACH_PCM038 -CONFIG_MACH_PCM043 -CONFIG_MACH_PCM048 -CONFIG_MACH_PCM049 -CONFIG_MACH_PCONTROL_G20 -CONFIG_MACH_PEC_HC2 -CONFIG_MACH_PEC_TC -CONFIG_MACH_PEMP_OMAP3_APOLLO -CONFIG_MACH_PGS_SITARA -CONFIG_MACH_PHILHWANI -CONFIG_MACH_PHY3250 -CONFIG_MACH_PICASSO -CONFIG_MACH_PICO -CONFIG_MACH_PICOCOM3 -CONFIG_MACH_PICOCOM4 -CONFIG_MACH_PICOTUX2XX -CONFIG_MACH_PIVICC -CONFIG_MACH_PNX4008 -CONFIG_MACH_POLYSAT1 -CONFIG_MACH_POODLE -CONFIG_MACH_PORTUXG20 -CONFIG_MACH_POV15HD -CONFIG_MACH_PREMIERWAVE_EN -CONFIG_MACH_PRIMA2_EVB -CONFIG_MACH_PTX7510 -CONFIG_MACH_PTX7545 -CONFIG_MACH_PUNICA -CONFIG_MACH_PUPITRE -CONFIG_MACH_PVM2030 -CONFIG_MACH_PWB3090 -CONFIG_MACH_PXWNAS_500_1000 -CONFIG_MACH_PYRAMID -CONFIG_MACH_QBC9263 -CONFIG_MACH_QIL_A9260 -CONFIG_MACH_QONG -CONFIG_MACH_QSD8X50A_ST1_5 -CONFIG_MACH_QSD8X50_SURF -CONFIG_MACH_QSD8X72_FFA -CONFIG_MACH_QSD8X72_SURF -CONFIG_MACH_QT2410 -CONFIG_MACH_QUAD_SALSA -CONFIG_MACH_QUICKSTEP -CONFIG_MACH_R1801E -CONFIG_MACH_RASCAL -CONFIG_MACH_RAUMFELD_CONNECTOR -CONFIG_MACH_RAUMFELD_RC -CONFIG_MACH_RAUMFELD_SPEAKER -CONFIG_MACH_RD78X00_MASA -CONFIG_MACH_RD88F5181L_FXO -CONFIG_MACH_RD88F5181L_GE -CONFIG_MACH_RD88F5182 -CONFIG_MACH_RD88F6183AP_GE -CONFIG_MACH_RD88F6192_NAS -CONFIG_MACH_RD88F6281 -CONFIG_MACH_RDSTOR -CONFIG_MACH_RE2REV20 -CONFIG_MACH_RE2REV21 -CONFIG_MACH_REAL6410 -CONFIG_MACH_REALVIEW_EB -CONFIG_MACH_REALVIEW_PB1176 -CONFIG_MACH_REALVIEW_PB11MP -CONFIG_MACH_REALVIEW_PBA8 -CONFIG_MACH_REALVIEW_PBX -CONFIG_MACH_REMUS -CONFIG_MACH_REXMAS -CONFIG_MACH_RFL109145_SSRV -CONFIG_MACH_RHINO -CONFIG_MACH_RIB -CONFIG_MACH_RIDER -CONFIG_MACH_RIOT_BEI2 -CONFIG_MACH_RIOT_X37 -CONFIG_MACH_ROADRUNNER -CONFIG_MACH_ROCKHOPPER -CONFIG_MACH_ROVERPCS8 -CONFIG_MACH_ROVERX7 -CONFIG_MACH_ROVER_G8 -CONFIG_MACH_RPC353 -CONFIG_MACH_RUBY -CONFIG_MACH_RUBYS -CONFIG_MACH_RUMP -CONFIG_MACH_RUT100 -CONFIG_MACH_RV082 -CONFIG_MACH_RX1950 -CONFIG_MACH_RX3715 -CONFIG_MACH_S3C2413 -CONFIG_MACH_S5500 -CONFIG_MACH_S5PC110_CRESPO -CONFIG_MACH_SAAR -CONFIG_MACH_SAARB -CONFIG_MACH_SAARB_MG1 -CONFIG_MACH_SAGA -CONFIG_MACH_SALUDA -CONFIG_MACH_SAM9REPEATER -CONFIG_MACH_SAM9_L9260 -CONFIG_MACH_SANTIAGO -CONFIG_MACH_SAPPHIRE -CONFIG_MACH_SBC3530 -CONFIG_MACH_SBC6000X -CONFIG_MACH_SBCA11 -CONFIG_MACH_SC575IPC -CONFIG_MACH_SC575PLC -CONFIG_MACH_SCB9328 -CONFIG_MACH_SCIPHONE_G2 -CONFIG_MACH_SDI_ESS_9263 -CONFIG_MACH_SDVR -CONFIG_MACH_SEABOARD -CONFIG_MACH_SERRANO -CONFIG_MACH_SFFSDR -CONFIG_MACH_SGH_I740 -CONFIG_MACH_SHARESPACE CONFIG_MACH_SHEEVAPLUG -CONFIG_MACH_SHENZHOU -CONFIG_MACH_SHEPHERD -CONFIG_MACH_SHOOTER -CONFIG_MACH_SHOOTER_CT -CONFIG_MACH_SHOOTER_U -CONFIG_MACH_SHORTLOIN -CONFIG_MACH_SIEMENS_L0 -CONFIG_MACH_SIMPLENET -CONFIG_MACH_SIMTEC_KIRKMOD -CONFIG_MACH_SIM_ONE -CONFIG_MACH_SKY25 -CONFIG_MACH_SKY6410 -CONFIG_MACH_SM1K -CONFIG_MACH_SMARTQ5 -CONFIG_MACH_SMARTQ7 -CONFIG_MACH_SMARTQV3 -CONFIG_MACH_SMARTQV5 -CONFIG_MACH_SMARTQV7 -CONFIG_MACH_SMDK2412 -CONFIG_MACH_SMDK2413 -CONFIG_MACH_SMDK2416 -CONFIG_MACH_SMDK2443 -CONFIG_MACH_SMDK6410 -CONFIG_MACH_SMDK6440 -CONFIG_MACH_SMDK6442 -CONFIG_MACH_SMDK6450 -CONFIG_MACH_SMDKC100 -CONFIG_MACH_SMDKC110 -CONFIG_MACH_SMDKC210 -CONFIG_MACH_SMDKV210 -CONFIG_MACH_SMDKV310 -CONFIG_MACH_SNAPPER_9260 -CONFIG_MACH_SNAPPER_CL15 -CONFIG_MACH_SOFTWINNER -CONFIG_MACH_SOLI_01 -CONFIG_MACH_SPADE -CONFIG_MACH_SPADE_LTE -CONFIG_MACH_SPDM -CONFIG_MACH_SPEAR1310 -CONFIG_MACH_SPEAR1340 -CONFIG_MACH_SPEAR300 -CONFIG_MACH_SPEAR310 -CONFIG_MACH_SPEAR320 -CONFIG_MACH_SPEAR600 -CONFIG_MACH_SPEAR900 CONFIG_MACH_SPECIFIC -CONFIG_MACH_SPICA -CONFIG_MACH_SPITZ -CONFIG_MACH_SPLENDOR -CONFIG_MACH_SPX_SAKURA -CONFIG_MACH_SPYPLUG -CONFIG_MACH_SSC -CONFIG_MACH_STAMP9G20 -CONFIG_MACH_STAMP9G45 -CONFIG_MACH_STARGATE2 -CONFIG_MACH_STEELYARD -CONFIG_MACH_STELLA -CONFIG_MACH_STMP378X -CONFIG_MACH_STMP37XX -CONFIG_MACH_STRASBOURG -CONFIG_MACH_STRASBOURG_A2 -CONFIG_MACH_STRETCHS7000 -CONFIG_MACH_SUNFIRE -CONFIG_MACH_SUNFLOWER -CONFIG_MACH_SVCID -CONFIG_MACH_SVP5500 -CONFIG_MACH_SVP8500V1 -CONFIG_MACH_SVP8500V2 -CONFIG_MACH_SWARCOEXTMODEM -CONFIG_MACH_SWEDA_TMS2 -CONFIG_MACH_SX1 -CONFIG_MACH_SYNERGY -CONFIG_MACH_SYNOLOGY_6282 -CONFIG_MACH_T20 -CONFIG_MACH_T5325 -CONFIG_MACH_T5388P -CONFIG_MACH_T55 -CONFIG_MACH_TAG -CONFIG_MACH_TAGW -CONFIG_MACH_TANNA -CONFIG_MACH_TAVOREVB -CONFIG_MACH_TAVOREVB3 -CONFIG_MACH_TCC8000_SDK -CONFIG_MACH_TCT_HAMMER -CONFIG_MACH_TD3_REV1 -CONFIG_MACH_TEENOTE -CONFIG_MACH_TEGRA_DAYTONA -CONFIG_MACH_TEGRA_E1165 -CONFIG_MACH_TEGRA_SWORDFISH -CONFIG_MACH_TEGRA_VOGUE -CONFIG_MACH_TEM3X30 -CONFIG_MACH_TENDERLOIN -CONFIG_MACH_TERASTATION_PRO2 -CONFIG_MACH_TERASTATION_WXL -CONFIG_MACH_TERA_PRO2_RACK -CONFIG_MACH_TETON_BGA -CONFIG_MACH_THALES_ADC -CONFIG_MACH_THALES_CBC -CONFIG_MACH_THEBE -CONFIG_MACH_TI8148EVM -CONFIG_MACH_TI8168EVM -CONFIG_MACH_TIMU -CONFIG_MACH_TIN307 -CONFIG_MACH_TIN510 -CONFIG_MACH_TINY_GURNARD -CONFIG_MACH_TITAN -CONFIG_MACH_TJINC1000 -CONFIG_MACH_TM_EFDC -CONFIG_MACH_TN200 -CONFIG_MACH_TNETV107X -CONFIG_MACH_TNY_T3530 -CONFIG_MACH_TONGA2_TFTTIMER -CONFIG_MACH_TOP9000 -CONFIG_MACH_TOP9000_BSL -CONFIG_MACH_TOP9000_EVAL -CONFIG_MACH_TOP9000_SU -CONFIG_MACH_TOP9000_TCU -CONFIG_MACH_TORBRECK -CONFIG_MACH_TORNADO3240 -CONFIG_MACH_TOSA -CONFIG_MACH_TOUCHBOOK -CONFIG_MACH_TPT_2_0 -CONFIG_MACH_TQ6410 -CONFIG_MACH_TQMA35 -CONFIG_MACH_TQMA9263 -CONFIG_MACH_TRANSCEDE -CONFIG_MACH_TREO680 -CONFIG_MACH_TRICORDER -CONFIG_MACH_TRIDENT -CONFIG_MACH_TRIMSLICE -CONFIG_MACH_TRIPEL -CONFIG_MACH_TRITIP -CONFIG_MACH_TRIZEPS4 -CONFIG_MACH_TRIZEPS4WL -CONFIG_MACH_TROUT -CONFIG_MACH_TS209 -CONFIG_MACH_TS219 -CONFIG_MACH_TS3 -CONFIG_MACH_TS409 -CONFIG_MACH_TS41X -CONFIG_MACH_TS42XX -CONFIG_MACH_TS47XX -CONFIG_MACH_TS4800 -CONFIG_MACH_TS48XX -CONFIG_MACH_TS72XX -CONFIG_MACH_TS75XX -CONFIG_MACH_TS78XX -CONFIG_MACH_TSOPLOADER -CONFIG_MACH_TSUNAGI -CONFIG_MACH_TTC_DKB -CONFIG_MACH_TUBE -CONFIG_MACH_TULIP -CONFIG_MACH_TUNA -CONFIG_MACH_TUXRAIL -CONFIG_MACH_TX28 -CONFIG_MACH_TX53 CONFIG_MACH_TYPE CONFIG_MACH_TYPE_COMPAT_REV -CONFIG_MACH_U300 -CONFIG_MACH_U5500 -CONFIG_MACH_UBISYS_P9D_EVP -CONFIG_MACH_UEMD -CONFIG_MACH_UNINO1 -CONFIG_MACH_UNISDEV -CONFIG_MACH_UNISENSE_MMM -CONFIG_MACH_UNIT2S -CONFIG_MACH_UNIVERSAL_C210 -CONFIG_MACH_USB_A9260 -CONFIG_MACH_USB_A9263 -CONFIG_MACH_USDLOADER -CONFIG_MACH_UTM300 -CONFIG_MACH_VALDEZ -CONFIG_MACH_VANGOGH -CONFIG_MACH_VC0718 -CONFIG_MACH_VENTANA -CONFIG_MACH_VERDI -CONFIG_MACH_VERDI_LTE -CONFIG_MACH_VERIDIS_A300 -CONFIG_MACH_VERSATILE_AB -CONFIG_MACH_VEXPRESS -CONFIG_MACH_VIGOR -CONFIG_MACH_VIPRINET -CONFIG_MACH_VIT_IBOX -CONFIG_MACH_VIVO -CONFIG_MACH_VIVOW_CT -CONFIG_MACH_VMX25 -CONFIG_MACH_VMX51 -CONFIG_MACH_VMX53 -CONFIG_MACH_VOICEBLUE -CONFIG_MACH_VPAC270 -CONFIG_MACH_VPR200 -CONFIG_MACH_VR1000 -CONFIG_MACH_VSTMS -CONFIG_MACH_VVBOX_SDLITE2 -CONFIG_MACH_VVBOX_SDORIG2 -CONFIG_MACH_VVBOX_SDPRO4 -CONFIG_MACH_W21 -CONFIG_MACH_W90N960EVB -CONFIG_MACH_W90P910EVB -CONFIG_MACH_W90P950EVB -CONFIG_MACH_WARIO -CONFIG_MACH_WASABI -CONFIG_MACH_WATSON_EFM_PLUGIN -CONFIG_MACH_WB40N -CONFIG_MACH_WBD111 -CONFIG_MACH_WBD222 -CONFIG_MACH_WG302V2 -CONFIG_MACH_WHISTLER -CONFIG_MACH_WLAN_COMPUTER -CONFIG_MACH_WLF_CRAGG_6410 -CONFIG_MACH_WM8505_7IN_NETBOOK -CONFIG_MACH_WM8650REFBOARD -CONFIG_MACH_WN802T -CONFIG_MACH_WNR854T -CONFIG_MACH_WRT350N_V2 -CONFIG_MACH_WTPLUG -CONFIG_MACH_XARINA -CONFIG_MACH_XCEP -CONFIG_MACH_XILINX -CONFIG_MACH_XILINX_EP107 -CONFIG_MACH_XSBASE255 -CONFIG_MACH_YANOMAMI -CONFIG_MACH_YL9200 -CONFIG_MACH_Z3_814X_MOD -CONFIG_MACH_Z3_816X_MOD -CONFIG_MACH_ZIPIT2 -CONFIG_MACH_ZMX25 -CONFIG_MACH_ZYLONITE -CONFIG_MACH_ZYLONITE2 CONFIG_MACPWR CONFIG_MACRESET_TIMEOUT CONFIG_MAC_ADDR_IN_EEPROM @@ -3751,28 +2696,6 @@ CONFIG_S5PC110 CONFIG_S5P_PA_SYSRAM CONFIG_S6E63D6 CONFIG_S6E8AX0 -CONFIG_SA1100_ADSBITSY -CONFIG_SA1100_ASSABET -CONFIG_SA1100_BADGE4 -CONFIG_SA1100_BRUTUS -CONFIG_SA1100_CERF -CONFIG_SA1100_COLLIE -CONFIG_SA1100_CONSUS -CONFIG_SA1100_FLEXANET -CONFIG_SA1100_GRAPHICSCLIENT -CONFIG_SA1100_GRAPHICSMASTER -CONFIG_SA1100_H3100 -CONFIG_SA1100_H3600 -CONFIG_SA1100_HACKKIT -CONFIG_SA1100_JORNADA720 -CONFIG_SA1100_LART -CONFIG_SA1100_NANOENGINE -CONFIG_SA1100_PFS168 -CONFIG_SA1100_PLEB -CONFIG_SA1100_PT_SYSTEM3 -CONFIG_SA1100_SHANNON -CONFIG_SA1100_SIMPAD -CONFIG_SA1100_XP860 CONFIG_SABRELITE CONFIG_SAMA5D2 CONFIG_SAMA5D3 -- 1.9.1
On Tue, Jan 10, 2017 at 05:22:08PM -0500, Tom Rini wrote:
This re-syncs the MACH_TYPE_xxx values from the Linux Kernel v4.9 release. In addition this removes all of the machine_arch_type and machine_is_xxx logic that is unused in U-Boot. This removal removes a large number of otherwise unused CONFIG values from the list to be converted.
Cc: Masahiro Yamada yamada.masahiro@socionext.com Signed-off-by: Tom Rini trini@konsulko.com Tested-by: Adam Ford aford173@gmail.com
On Tue, Jan 10, 2017 at 4:22 PM, Tom Rini trini@konsulko.com wrote:
The MACH_TYPE values for the omap37xx based platforms are no longer officially valid, so we must not set and pass them. In order to not reference them but still be able to set the default fdtfile based on the board detection logic we need to combine the two steps into one.
Look good.
Acked-by: Adam Ford aford173@gmail.com
Cc: Adam Ford aford173@gmail.com Signed-off-by: Tom Rini trini@konsulko.com
board/logicpd/omap3som/omap3logic.c | 54 ++++++++++++++----------------------- 1 file changed, 20 insertions(+), 34 deletions(-)
diff --git a/board/logicpd/omap3som/omap3logic.c b/board/logicpd/omap3som/omap3logic.c index de6a06021c2c..21b3fdcf49cf 100644 --- a/board/logicpd/omap3som/omap3logic.c +++ b/board/logicpd/omap3som/omap3logic.c @@ -60,25 +60,28 @@ U_BOOT_DEVICE(omap3logic_uart) = { static struct board_id { char *name; int machine_id;
char *fdtfile;
} boards[2][2] = { { { .name = "OMAP35xx SOM LV", .machine_id = MACH_TYPE_OMAP3530_LV_SOM,
.fdtfile = "logicpd-som-lv-35xx-devkit.dtb", }, { .name = "OMAP35xx Torpedo", .machine_id = MACH_TYPE_OMAP3_TORPEDO,
.fdtfile = "logicpd-torpedo-35xx-devkit.dtb", }, }, { { .name = "DM37xx SOM LV",
.machine_id = MACH_TYPE_DM3730_SOM_LV,
.fdtfile = "logicpd-som-lv-37xx-devkit.dtb", }, { .name = "DM37xx Torpedo",
.machine_id = MACH_TYPE_DM3730_TORPEDO,
.fdtfile = "logicpd-torpedo-37xx-devkit.dtb", }, },
}; @@ -165,14 +168,20 @@ int misc_init_r(void) */ int board_init(void) {
struct board_id *board;
unsigned int val;
gpmc_init(); /* in SRAM or SDRAM, finish GPMC */ /* boot param addr */ gd->bd->bi_boot_params = (OMAP34XX_SDRC_CS0 + 0x100);
+#ifdef CONFIG_BOARD_LATE_INIT +int board_late_init(void) +{
unsigned int val;
/* * To identify between a SOM LV and Torpedo module, * a pulldown resistor is on hsusb0_data5 for the SOM LV module.
@@ -207,39 +216,16 @@ int board_init(void) printf("Board: %s\n", board->name);
/* Set the machine_id passed to Linux */
gd->bd->bi_arch_number = board->machine_id;
if (board->machine_id)
/* If the user has not set fdtimage, set the default */
if (!getenv("fdtimage"))
setenv("fdtimage", board->fdtfile); } /* restore hsusb0_data5 pin as hsusb0_data5 */ MUX_VAL(CP(HSUSB0_DATA5), (IEN | PTD | DIS | M0));
-#ifdef CONFIG_BOARD_LATE_INIT -int board_late_init(void) -{
/* If we do not have an fdtimage, let's autodetect it*/
if (getenv("fdtimage"))
switch (gd->bd->bi_arch_number) {
case MACH_TYPE_DM3730_TORPEDO:
setenv("fdtimage", "logicpd-torpedo-37xx-devkit.dtb");
break;
case MACH_TYPE_DM3730_SOM_LV:
setenv("fdtimage", "logicpd-som-lv-37xx-devkit.dtb");
break;
case MACH_TYPE_OMAP3_TORPEDO:
setenv("fdtimage", "logicpd-torpedo-35xx-devkit.dtb");
break;
case MACH_TYPE_OMAP3530_LV_SOM:
setenv("fdtimage", "logicpd-som-lv-35xx-devkit.dtb");
break;
default:
/* unknown machine type */
break;
} return 0;
#endif
1.9.1
Cc: Adam Ford aford173@gmail.com Signed-off-by: Tom Rini trini@konsulko.com Acked-by: Adam Ford aford173@gmail.com
Adam Ford
Enric Balletbo Serra
Stephen Warren
