[U-Boot] Pull request: nand flash
The following changes since commit f12af1f38dc59a6dfe0fed1359e1a05e700a435b: Wolfgang Denk (1): Merge branch 'master' of git://git.denx.de/u-boot-video
git://git.denx.de/u-boot-nand-flash.git master
David Müller (ELSOFT AG) (1): fix s3c2410_nand timing default values
Lei Wen (1): onenand: fix oob print out issue
Scott Wood (1): 83xx NAND boot: fix boards.cfg
Steve Sakoman (1): env_nand: Use nand_read_skip_bad instead of nand_read
boards.cfg | 6 +++--- common/cmd_onenand.c | 4 +++- common/env_nand.c | 2 +- drivers/mtd/nand/s3c2410_nand.c | 12 +++++++++--- 4 files changed, 16 insertions(+), 8 deletions(-)
Dear Scott Wood,
In message 20101207220511.GA31720@udp111988uds.am.freescale.net you wrote:
The following changes since commit f12af1f38dc59a6dfe0fed1359e1a05e700a43= 5b: Wolfgang Denk (1): Merge branch 'master' of git://git.denx.de/u-boot-video
David M=FCller (ELSOFT AG) (1): fix s3c2410_nand timing default values
Applied, thanks.
Scott Wood
