[U-Boot-Users] [PATCH: cmdcfg: 13/19] cpu/ non-mpc*: Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).
This is a compatibility step that allows both the older form and the new form to co-exist for a while until the older can be removed entirely.
All transformations are of the form: Before: #if (CONFIG_COMMANDS & CFG_CMD_AUTOSCRIPT) After: #if (CONFIG_COMMANDS & CFG_CMD_AUTOSCRIPT) || defined(CONFIG_CMD_AUTOSCRIPT)
Signed-off-by: Jon Loeliger jdl@freescale.com --- cpu/74xx_7xx/kgdb.S | 2 +- cpu/74xx_7xx/traps.c | 12 ++++++------ cpu/arm920t/at91rm9200/bcm5221.c | 2 +- cpu/arm920t/at91rm9200/dm9161.c | 2 +- cpu/arm920t/at91rm9200/ether.c | 6 +++--- cpu/arm920t/at91rm9200/lxt972.c | 2 +- cpu/i386/serial.c | 2 +- cpu/ixp/cpu.c | 2 +- cpu/ixp/npe/npe.c | 2 +- cpu/mcf52x2/fec.c | 10 +++++----- cpu/microblaze/cache.c | 2 +- cpu/microblaze/interrupts.c | 2 +- cpu/mips/au1x00_eth.c | 6 +++--- cpu/nios/interrupts.c | 2 +- cpu/nios2/interrupts.c | 2 +- cpu/ppc4xx/4xx_enet.c | 8 ++++---- cpu/ppc4xx/bedbug_405.c | 2 +- cpu/ppc4xx/interrupts.c | 2 +- cpu/ppc4xx/kgdb.S | 2 +- cpu/ppc4xx/ndfc.c | 2 +- cpu/ppc4xx/serial.c | 2 +- cpu/ppc4xx/traps.c | 14 +++++++------- cpu/ppc4xx/usbdev.c | 2 +- 23 files changed, 45 insertions(+), 45 deletions(-)
diff --git a/cpu/74xx_7xx/kgdb.S b/cpu/74xx_7xx/kgdb.S index e838513..5d2ce85 100644 --- a/cpu/74xx_7xx/kgdb.S +++ b/cpu/74xx_7xx/kgdb.S @@ -31,7 +31,7 @@ #include <asm/cache.h> #include <asm/mmu.h>
-#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if (CONFIG_COMMANDS & CFG_CMD_KGDB) || defined(CONFIG_CMD_KGDB)
/* * cache flushing routines for kgdb diff --git a/cpu/74xx_7xx/traps.c b/cpu/74xx_7xx/traps.c index 50c5eeb..e7658bb 100644 --- a/cpu/74xx_7xx/traps.c +++ b/cpu/74xx_7xx/traps.c @@ -40,7 +40,7 @@ DECLARE_GLOBAL_DATA_PTR; #endif
-#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if (CONFIG_COMMANDS & CFG_CMD_KGDB) || defined(CONFIG_CMD_KGDB) int (*debugger_exception_handler)(struct pt_regs *) = 0; #endif
@@ -133,7 +133,7 @@ MachineCheckException(struct pt_regs *regs) return; }
-#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if (CONFIG_COMMANDS & CFG_CMD_KGDB) || defined(CONFIG_CMD_KGDB) if (debugger_exception_handler && (*debugger_exception_handler)(regs)) return; #endif @@ -166,7 +166,7 @@ MachineCheckException(struct pt_regs *regs) void AlignmentException(struct pt_regs *regs) { -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if (CONFIG_COMMANDS & CFG_CMD_KGDB) || defined(CONFIG_CMD_KGDB) if (debugger_exception_handler && (*debugger_exception_handler)(regs)) return; #endif @@ -181,7 +181,7 @@ ProgramCheckException(struct pt_regs *regs) unsigned char *p = regs ? (unsigned char *)(regs->nip) : NULL; int i, j;
-#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if (CONFIG_COMMANDS & CFG_CMD_KGDB) || defined(CONFIG_CMD_KGDB) if (debugger_exception_handler && (*debugger_exception_handler)(regs)) return; #endif @@ -204,7 +204,7 @@ ProgramCheckException(struct pt_regs *regs) void SoftEmuException(struct pt_regs *regs) { -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if (CONFIG_COMMANDS & CFG_CMD_KGDB) || defined(CONFIG_CMD_KGDB) if (debugger_exception_handler && (*debugger_exception_handler)(regs)) return; #endif @@ -217,7 +217,7 @@ SoftEmuException(struct pt_regs *regs) void UnknownException(struct pt_regs *regs) { -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if (CONFIG_COMMANDS & CFG_CMD_KGDB) || defined(CONFIG_CMD_KGDB) if (debugger_exception_handler && (*debugger_exception_handler)(regs)) return; #endif diff --git a/cpu/arm920t/at91rm9200/bcm5221.c b/cpu/arm920t/at91rm9200/bcm5221.c index 6db1435..b0d8795 100644 --- a/cpu/arm920t/at91rm9200/bcm5221.c +++ b/cpu/arm920t/at91rm9200/bcm5221.c @@ -32,7 +32,7 @@
#ifdef CONFIG_DRIVER_ETHER
-#if (CONFIG_COMMANDS & CFG_CMD_NET) +#if (CONFIG_COMMANDS & CFG_CMD_NET) || defined(CONFIG_CMD_NET)
/* * Name: diff --git a/cpu/arm920t/at91rm9200/dm9161.c b/cpu/arm920t/at91rm9200/dm9161.c index 4b13c23..eaa6ccb 100644 --- a/cpu/arm920t/at91rm9200/dm9161.c +++ b/cpu/arm920t/at91rm9200/dm9161.c @@ -27,7 +27,7 @@
/* * Name: diff --git a/cpu/arm920t/at91rm9200/ether.c b/cpu/arm920t/at91rm9200/ether.c index 67008d0..f0ec831 100644 --- a/cpu/arm920t/at91rm9200/ether.c +++ b/cpu/arm920t/at91rm9200/ether.c @@ -50,7 +50,7 @@ typedef struct {
/* alignment as per Errata #11 (64 bytes) is insufficient! */ rbf_t rbfdt[RBF_FRAMEMAX] __attribute((aligned(512))); @@ -265,7 +265,7 @@ void eth_halt (void) { };
-#if defined(CONFIG_MII) || (CONFIG_COMMANDS & CFG_CMD_MII) +#if defined(CONFIG_MII) || (CONFIG_COMMANDS & CFG_CMD_MII) || defined(CONFIG_CMD_MII) int at91rm9200_miiphy_read(char *devname, unsigned char addr, unsigned char reg, unsigned short * value) { @@ -288,7 +288,7 @@ int at91rm9200_miiphy_write(char *devname, unsigned char addr,
int at91rm9200_miiphy_initialize(bd_t *bis) { -#if defined(CONFIG_MII) || (CONFIG_COMMANDS & CFG_CMD_MII) +#if defined(CONFIG_MII) || (CONFIG_COMMANDS & CFG_CMD_MII) || defined(CONFIG_CMD_MII) miiphy_register("at91rm9200phy", at91rm9200_miiphy_read, at91rm9200_miiphy_write); #endif return 0; diff --git a/cpu/arm920t/at91rm9200/lxt972.c b/cpu/arm920t/at91rm9200/lxt972.c index f12c59c..c3ddb6d 100644 --- a/cpu/arm920t/at91rm9200/lxt972.c +++ b/cpu/arm920t/at91rm9200/lxt972.c @@ -33,7 +33,7 @@
/* * Name: diff --git a/cpu/i386/serial.c b/cpu/i386/serial.c index e7299a7..a5725b9 100644 --- a/cpu/i386/serial.c +++ b/cpu/i386/serial.c @@ -394,7 +394,7 @@ int serial_buffered_tstc(void) #endif /* CONFIG_SERIAL_SOFTWARE_FIFO */
-#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if (CONFIG_COMMANDS & CFG_CMD_KGDB) || defined(CONFIG_CMD_KGDB) /* AS HARNOIS : according to CONFIG_KGDB_SER_INDEX kgdb uses serial port number 0 or number 1 diff --git a/cpu/ixp/cpu.c b/cpu/ixp/cpu.c index 7f9f334..ef6c552 100644 --- a/cpu/ixp/cpu.c +++ b/cpu/ixp/cpu.c @@ -85,7 +85,7 @@ int cpu_init (void) FIQ_STACK_START = IRQ_STACK_START - CONFIG_STACKSIZE_IRQ; #endif
-#if (CONFIG_COMMANDS & CFG_CMD_PCI) || defined (CONFIG_PCI) +#if (CONFIG_COMMANDS & CFG_CMD_PCI) || defined(CONFIG_CMD_PCI) || defined (CONFIG_PCI) pci_init(); #endif return 0; diff --git a/cpu/ixp/npe/npe.c b/cpu/ixp/npe/npe.c index ab7ca8b..57a707b 100644 --- a/cpu/ixp/npe/npe.c +++ b/cpu/ixp/npe/npe.c @@ -682,7 +682,7 @@ int npe_initialize(bd_t * bis)
eth_register(dev);
-#if defined(CONFIG_MII) || (CONFIG_COMMANDS & CFG_CMD_MII) +#if defined(CONFIG_MII) || (CONFIG_COMMANDS & CFG_CMD_MII) || defined(CONFIG_CMD_MII) miiphy_register(dev->name, npe_miiphy_read, npe_miiphy_write); #endif
diff --git a/cpu/mcf52x2/fec.c b/cpu/mcf52x2/fec.c index b6540b5..3627071 100644 --- a/cpu/mcf52x2/fec.c +++ b/cpu/mcf52x2/fec.c @@ -53,7 +53,7 @@ #undef ET_DEBUG #undef MII_DEBUG
-#if (CONFIG_COMMANDS & CFG_CMD_NET) && defined(FEC_ENET) +#if ((CONFIG_COMMANDS & CFG_CMD_NET) || defined(CONFIG_CMD_NET)) && defined(FEC_ENET)
#ifdef CFG_DISCOVER_PHY #include <miiphy.h> @@ -363,7 +363,7 @@ void eth_halt (void) }
-#if defined(CFG_DISCOVER_PHY) || (CONFIG_COMMANDS & CFG_CMD_MII) +#if defined(CFG_DISCOVER_PHY) || (CONFIG_COMMANDS & CFG_CMD_MII) || defined(CONFIG_CMD_MII)
static int phyaddr = -1; /* didn't find a PHY yet */ static uint phytype; @@ -485,7 +485,7 @@ static void mii_discover_phy (void) } #endif /* CFG_DISCOVER_PHY */
-#if (CONFIG_COMMANDS & CFG_CMD_MII) && !defined(CONFIG_BITBANGMII) +#if ((CONFIG_COMMANDS & CFG_CMD_MII) || defined(CONFIG_CMD_MII)) && !defined(CONFIG_BITBANGMII)
static int mii_init_done = 0;
@@ -596,8 +596,8 @@ int mcf52x2_miiphy_write (char *devname, unsigned char addr,
int mcf52x2_miiphy_initialize(bd_t *bis) { -#if (CONFIG_COMMANDS & CFG_CMD_NET) && defined(FEC_ENET) -#if (CONFIG_COMMANDS & CFG_CMD_MII) && !defined(CONFIG_BITBANGMII) +#if ((CONFIG_COMMANDS & CFG_CMD_NET) || defined(CONFIG_CMD_NET)) && defined(FEC_ENET) +#if ((CONFIG_COMMANDS & CFG_CMD_MII) || defined(CONFIG_CMD_MII)) && !defined(CONFIG_BITBANGMII) miiphy_register("mcf52x2phy", mcf52x2_miiphy_read, mcf52x2_miiphy_write); #endif #endif diff --git a/cpu/microblaze/cache.c b/cpu/microblaze/cache.c index 4f36a84..2921551 100755 --- a/cpu/microblaze/cache.c +++ b/cpu/microblaze/cache.c @@ -25,7 +25,7 @@ #include <common.h> #include <asm/asm.h>
-#if (CONFIG_COMMANDS & CFG_CMD_CACHE) +#if (CONFIG_COMMANDS & CFG_CMD_CACHE) || defined(CONFIG_CMD_CACHE)
int dcache_status (void) { diff --git a/cpu/microblaze/interrupts.c b/cpu/microblaze/interrupts.c index b61153f..b97465a 100755 --- a/cpu/microblaze/interrupts.c +++ b/cpu/microblaze/interrupts.c @@ -190,7 +190,7 @@ void interrupt_handler (void) } #endif
-#if (CONFIG_COMMANDS & CFG_CMD_IRQ) +#if (CONFIG_COMMANDS & CFG_CMD_IRQ) || defined(CONFIG_CMD_IRQ) #ifdef CFG_INTC_0 int do_irqinfo (cmd_tbl_t * cmdtp, int flag, int argc, char *argv[]) { diff --git a/cpu/mips/au1x00_eth.c b/cpu/mips/au1x00_eth.c index 078e832..de13b05 100644 --- a/cpu/mips/au1x00_eth.c +++ b/cpu/mips/au1x00_eth.c @@ -63,7 +63,7 @@ #include <asm/io.h> #include <asm/au1x00.h>
-#if (CONFIG_COMMANDS & CFG_CMD_MII) +#if (CONFIG_COMMANDS & CFG_CMD_MII) || defined(CONFIG_CMD_MII) #include <miiphy.h> #endif
@@ -241,7 +241,7 @@ int au1x00_enet_initialize(bd_t *bis){
eth_register(dev);
-#if (CONFIG_COMMANDS & CFG_CMD_MII) +#if (CONFIG_COMMANDS & CFG_CMD_MII) || defined(CONFIG_CMD_MII) miiphy_register(dev->name, au1x00_miiphy_read, au1x00_miiphy_write); #endif @@ -249,7 +249,7 @@ int au1x00_enet_initialize(bd_t *bis){ return 1; }
-#if (CONFIG_COMMANDS & CFG_CMD_MII) +#if (CONFIG_COMMANDS & CFG_CMD_MII) || defined(CONFIG_CMD_MII) int au1x00_miiphy_read(char *devname, unsigned char addr, unsigned char reg, unsigned short * value) { diff --git a/cpu/nios/interrupts.c b/cpu/nios/interrupts.c index 48fc81e..cb60799 100644 --- a/cpu/nios/interrupts.c +++ b/cpu/nios/interrupts.c @@ -173,7 +173,7 @@ void irq_install_handler (int vec, interrupt_handler_t *handler, void *arg) }
/*************************************************************************/ -#if (CONFIG_COMMANDS & CFG_CMD_IRQ) +#if (CONFIG_COMMANDS & CFG_CMD_IRQ) || defined(CONFIG_CMD_IRQ) int do_irqinfo (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) { int vec; diff --git a/cpu/nios2/interrupts.c b/cpu/nios2/interrupts.c index 4685161..d085550 100644 --- a/cpu/nios2/interrupts.c +++ b/cpu/nios2/interrupts.c @@ -204,7 +204,7 @@ int interrupt_init (void)
/*************************************************************************/ -#if (CONFIG_COMMANDS & CFG_CMD_IRQ) +#if (CONFIG_COMMANDS & CFG_CMD_IRQ) || defined(CONFIG_CMD_IRQ) int do_irqinfo (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) { int i; diff --git a/cpu/ppc4xx/4xx_enet.c b/cpu/ppc4xx/4xx_enet.c index 1200d02..5a8f790 100644 --- a/cpu/ppc4xx/4xx_enet.c +++ b/cpu/ppc4xx/4xx_enet.c @@ -94,9 +94,9 @@ * network support enabled. * Remark: CONFIG_405 describes Xilinx PPC405 FPGA without EMAC controller! */ -#if (CONFIG_COMMANDS & CFG_CMD_NET) && !defined(CONFIG_405) && !defined(CONFIG_IOP480) +#if ((CONFIG_COMMANDS & CFG_CMD_NET) || defined(CONFIG_CMD_NET)) && !defined(CONFIG_405) && !defined(CONFIG_IOP480)
-#if !(defined(CONFIG_MII) || (CONFIG_COMMANDS & CFG_CMD_MII)) +#if !(defined(CONFIG_MII) || (CONFIG_COMMANDS & CFG_CMD_MII) || defined(CONFIG_CMD_MII)) #error "CONFIG_MII has to be defined!" #endif
@@ -1683,7 +1683,7 @@ int ppc_4xx_eth_initialize (bd_t * bis) #endif
#if defined(CONFIG_NET_MULTI) -#if defined(CONFIG_MII) || (CONFIG_COMMANDS & CFG_CMD_MII) +#if defined(CONFIG_MII) || (CONFIG_COMMANDS & CFG_CMD_MII) || defined(CONFIG_CMD_MII) miiphy_register (dev->name, emac4xx_miiphy_read, emac4xx_miiphy_write); #endif @@ -1724,7 +1724,7 @@ int eth_rx(void)
int emac4xx_miiphy_initialize (bd_t * bis) { -#if defined(CONFIG_MII) || (CONFIG_COMMANDS & CFG_CMD_MII) +#if defined(CONFIG_MII) || (CONFIG_COMMANDS & CFG_CMD_MII) || defined(CONFIG_CMD_MII) miiphy_register ("ppc_4xx_eth0", emac4xx_miiphy_read, emac4xx_miiphy_write); #endif diff --git a/cpu/ppc4xx/bedbug_405.c b/cpu/ppc4xx/bedbug_405.c index a3c2119..f646ea6 100644 --- a/cpu/ppc4xx/bedbug_405.c +++ b/cpu/ppc4xx/bedbug_405.c @@ -10,7 +10,7 @@ #include <bedbug/regs.h> #include <bedbug/ppc.h>
-#if (CONFIG_COMMANDS & CFG_CMD_BEDBUG) && defined(CONFIG_4xx) +#if ((CONFIG_COMMANDS & CFG_CMD_BEDBUG) || defined(CONFIG_CMD_BEDBUG)) && defined(CONFIG_4xx)
#define MAX_BREAK_POINTS 4
diff --git a/cpu/ppc4xx/interrupts.c b/cpu/ppc4xx/interrupts.c index c5a9f02..b39aad8 100644 --- a/cpu/ppc4xx/interrupts.c +++ b/cpu/ppc4xx/interrupts.c @@ -628,7 +628,7 @@ void timer_interrupt_cpu (struct pt_regs *regs)
/******************************************************************************* * diff --git a/cpu/ppc4xx/kgdb.S b/cpu/ppc4xx/kgdb.S index be28340..339a0cd 100644 --- a/cpu/ppc4xx/kgdb.S +++ b/cpu/ppc4xx/kgdb.S @@ -34,7 +34,7 @@ #include <asm/cache.h> #include <asm/mmu.h>
-#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if (CONFIG_COMMANDS & CFG_CMD_KGDB) || defined(CONFIG_CMD_KGDB) /* * cache flushing routines for kgdb */ diff --git a/cpu/ppc4xx/ndfc.c b/cpu/ppc4xx/ndfc.c index f63fc79..4debe53 100644 --- a/cpu/ppc4xx/ndfc.c +++ b/cpu/ppc4xx/ndfc.c @@ -31,7 +31,7 @@
#include <common.h>
-#if (CONFIG_COMMANDS & CFG_CMD_NAND) && !defined(CFG_NAND_LEGACY) && \ +#if ((CONFIG_COMMANDS & CFG_CMD_NAND) || defined(CONFIG_CMD_NAND)) && !defined(CFG_NAND_LEGACY) && \ (defined(CONFIG_440EP) || defined(CONFIG_440GR) || \ defined(CONFIG_440EPX) || defined(CONFIG_440GRX) || \ defined(CONFIG_405EZ)) diff --git a/cpu/ppc4xx/serial.c b/cpu/ppc4xx/serial.c index e62dd9d..67c8a8b 100644 --- a/cpu/ppc4xx/serial.c +++ b/cpu/ppc4xx/serial.c @@ -843,7 +843,7 @@ int serial_buffered_tstc (void)
-#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if (CONFIG_COMMANDS & CFG_CMD_KGDB) || defined(CONFIG_CMD_KGDB) /* AS HARNOIS : according to CONFIG_KGDB_SER_INDEX kgdb uses serial port number 0 or number 1 diff --git a/cpu/ppc4xx/traps.c b/cpu/ppc4xx/traps.c index 6aecca2..a19110d 100644 --- a/cpu/ppc4xx/traps.c +++ b/cpu/ppc4xx/traps.c @@ -36,7 +36,7 @@ #include <command.h> #include <asm/processor.h>
@@ -77,7 +77,7 @@ static __inline__ unsigned long get_esr(void) #define ESR_DIZ 0x00400000 #define ESR_U0F 0x00008000
-#if (CONFIG_COMMANDS & CFG_CMD_BEDBUG) +#if (CONFIG_COMMANDS & CFG_CMD_BEDBUG) || defined(CONFIG_CMD_BEDBUG) extern void do_bedbug_breakpoint(struct pt_regs *); #endif
@@ -156,7 +156,7 @@ MachineCheckException(struct pt_regs *regs) return; }
-#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if (CONFIG_COMMANDS & CFG_CMD_KGDB) || defined(CONFIG_CMD_KGDB) if (debugger_exception_handler && (*debugger_exception_handler)(regs)) return; #endif @@ -189,7 +189,7 @@ MachineCheckException(struct pt_regs *regs) void AlignmentException(struct pt_regs *regs) { -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if (CONFIG_COMMANDS & CFG_CMD_KGDB) || defined(CONFIG_CMD_KGDB) if (debugger_exception_handler && (*debugger_exception_handler)(regs)) return; #endif @@ -204,7 +204,7 @@ ProgramCheckException(struct pt_regs *regs) { long esr_val;
-#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if (CONFIG_COMMANDS & CFG_CMD_KGDB) || defined(CONFIG_CMD_KGDB) if (debugger_exception_handler && (*debugger_exception_handler)(regs)) return; #endif @@ -241,7 +241,7 @@ PITException(struct pt_regs *regs) void UnknownException(struct pt_regs *regs) { -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if (CONFIG_COMMANDS & CFG_CMD_KGDB) || defined(CONFIG_CMD_KGDB) if (debugger_exception_handler && (*debugger_exception_handler)(regs)) return; #endif @@ -256,7 +256,7 @@ DebugException(struct pt_regs *regs) { printf("Debugger trap at @ %lx\n", regs->nip ); show_regs(regs); -#if (CONFIG_COMMANDS & CFG_CMD_BEDBUG) +#if (CONFIG_COMMANDS & CFG_CMD_BEDBUG) || defined(CONFIG_CMD_BEDBUG) do_bedbug_breakpoint( regs ); #endif } diff --git a/cpu/ppc4xx/usbdev.c b/cpu/ppc4xx/usbdev.c index 6140d2a..edaafbf 100644 --- a/cpu/ppc4xx/usbdev.c +++ b/cpu/ppc4xx/usbdev.c @@ -3,7 +3,7 @@ #include <common.h> #include <asm/processor.h>
-#if (defined(CONFIG_440EP) || defined(CONFIG_440EPX)) && (CONFIG_COMMANDS & CFG_CMD_USB) +#if (defined(CONFIG_440EP) || defined(CONFIG_440EPX)) && ((CONFIG_COMMANDS & CFG_CMD_USB) || defined(CONFIG_CMD_USB))
#include <usb.h> #include "usbdev.h"
Jon Loeliger
