[U-Boot] [PATCH 1/2] hush: Pull out U-Boot prompt display and read functionality
Pull the code which displays U-Boot prompt and reads the command line into a separate function. No functional change.
Signed-off-by: Marek Vasut marex@denx.de --- common/cli_hush.c | 21 ++++++++++++++++----- 1 file changed, 16 insertions(+), 5 deletions(-)
diff --git a/common/cli_hush.c b/common/cli_hush.c index 2fbfdbe..cbaf22e 100644 --- a/common/cli_hush.c +++ b/common/cli_hush.c @@ -974,6 +974,20 @@ static inline void setup_prompt_string(int promptmode, char **prompt_str) } #endif
+#ifdef __U_BOOT__ +static int uboot_cli_readline(struct in_str *i) +{ + char *prompt; + + if (i->promptmode == 1) + prompt = CONFIG_SYS_PROMPT; + else + prompt = CONFIG_SYS_PROMPT_HUSH_PS2; + + return cli_readline(prompt); +} +#endif + static void get_user_input(struct in_str *i) { #ifndef __U_BOOT__ @@ -1003,11 +1017,8 @@ static void get_user_input(struct in_str *i)
bootretry_reset_cmd_timeout(); i->__promptme = 1; - if (i->promptmode == 1) { - n = cli_readline(CONFIG_SYS_PROMPT); - } else { - n = cli_readline(CONFIG_SYS_PROMPT_HUSH_PS2); - } + n = uboot_cli_readline(i); + #ifdef CONFIG_BOOT_RETRY_TIME if (n == -2) { puts("\nTimeout waiting for command\n");
Add trivial support for changing the U-Boot command prompt string by setting PS1 and PS2 environment variables. Only static variables are supported.
Signed-off-by: Marek Vasut marex@denx.de --- README | 8 ++++++++ common/cli_hush.c | 10 ++++++++++ 2 files changed, 18 insertions(+)
diff --git a/README b/README index ece4793..8fb25c6 100644 --- a/README +++ b/README @@ -2894,6 +2894,14 @@ CBFS (Coreboot Filesystem) support Enable editing and History functions for interactive command line input operations
+- Command Line PS1/PS2 support: + CONFIG_CMDLINE_PS_SUPPORT + + Enable support for changing the command prompt string + at run-time. Only static string is supported so far. + The string is obtained from environment variables PS1 + and PS2. + - Default Environment: CONFIG_EXTRA_ENV_SETTINGS
diff --git a/common/cli_hush.c b/common/cli_hush.c index cbaf22e..00861e2 100644 --- a/common/cli_hush.c +++ b/common/cli_hush.c @@ -978,12 +978,22 @@ static inline void setup_prompt_string(int promptmode, char **prompt_str) static int uboot_cli_readline(struct in_str *i) { char *prompt; + char __maybe_unused *ps_prompt = NULL;
if (i->promptmode == 1) prompt = CONFIG_SYS_PROMPT; else prompt = CONFIG_SYS_PROMPT_HUSH_PS2;
+#ifdef CONFIG_CMDLINE_PS_SUPPORT + if (i->promptmode == 1) + ps_prompt = getenv("PS1"); + else + ps_prompt = getenv("PS2"); + if (ps_prompt) + prompt = ps_prompt; +#endif + return cli_readline(prompt); } #endif
Hello Marek,
Am 27.01.2016 um 04:47 schrieb Marek Vasut:
Nice!
Reviewed-by: Heiko Schocher hs@denx.de
bye, Heiko
and PS2.
- else
- if (ps_prompt)
prompt = ps_prompt;
- return cli_readline(prompt); } #endif
Signed-off-by: Marek Vasut marex@denx.de Reviewed-by: Heiko Schocher hs@denx.de Reviewed-by: Simon Glass sjg@chromium.org
Hello Marek,
bye, Heiko
- char *prompt;
- else
+} +#endif
- static void get_user_input(struct in_str *i) { #ifndef __U_BOOT__
- } else {
- n = uboot_cli_readline(i);
- #ifdef CONFIG_BOOT_RETRY_TIME if (n == -2) { puts("\nTimeout waiting for command\n");
Heiko Schocher
