[U-Boot] [PATCH 1/2] spi: omap3: pre-initialize bus-speed with max. slave-speed
Otherwise the frequency is zero and the clock divider cannot be setup by 'omap3_spi_set_speed' function.
Signed-off-by: Hannes Schmelzer oe5hpm@oevsv.at ---
drivers/spi/omap3_spi.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/drivers/spi/omap3_spi.c b/drivers/spi/omap3_spi.c index 4169abd..a149abe 100644 --- a/drivers/spi/omap3_spi.c +++ b/drivers/spi/omap3_spi.c @@ -590,6 +590,8 @@ static int omap3_spi_claim_bus(struct udevice *dev) struct dm_spi_slave_platdata *slave_plat = dev_get_parent_platdata(dev);
priv->cs = slave_plat->cs; + priv->freq = slave_plat->max_hz; + _omap3_spi_claim_bus(priv);
commit 84807922874e03895bbf15c4472a2dcee8fbbd03 ("spi: omap3: Skip set_mode, set_speed from claim") did break SPI support on my AM335x board.
The named commit:
- ignored the responsible arguments (speed, mode) The set speed/mode function must use the supplied function arguments to work properly. With this commit we take those arguments and transfer them to the priv-data.
- used wrong udevice pointer for getting priv data the udevice-pointer within function argument is already the spi-bus device, so it is wrong looking here for some parent (ocp-bus in this case) and getting priv-pointer from there.
drivers/spi/omap3_spi.c | 16 ++++++---------- 1 file changed, 6 insertions(+), 10 deletions(-)
diff --git a/drivers/spi/omap3_spi.c b/drivers/spi/omap3_spi.c index a149abe..766436e 100644 --- a/drivers/spi/omap3_spi.c +++ b/drivers/spi/omap3_spi.c @@ -650,12 +650,10 @@ static int omap3_spi_xfer(struct udevice *dev, unsigned int bitlen,
static int omap3_spi_set_speed(struct udevice *dev, unsigned int speed) { - struct udevice *bus = dev->parent; - struct omap3_spi_priv *priv = dev_get_priv(bus); - struct dm_spi_slave_platdata *slave_plat = dev_get_parent_platdata(dev);
- priv->cs = slave_plat->cs; - priv->freq = slave_plat->max_hz; + struct omap3_spi_priv *priv = dev_get_priv(dev); + + priv->freq = speed; _omap3_spi_set_speed(priv);
return 0; @@ -663,12 +661,10 @@ static int omap3_spi_set_speed(struct udevice *dev, unsigned int speed)
static int omap3_spi_set_mode(struct udevice *dev, uint mode) { - struct udevice *bus = dev->parent; - struct omap3_spi_priv *priv = dev_get_priv(bus); - struct dm_spi_slave_platdata *slave_plat = dev_get_parent_platdata(dev); + struct omap3_spi_priv *priv = dev_get_priv(dev); + + priv->mode = mode;
- priv->cs = slave_plat->cs; - priv->mode = slave_plat->mode; _omap3_spi_set_mode(priv);
Hannes Schmelzer
