[U-Boot] [PATCH v2 1/3] phy: atheros: Use ar8035_config for AR8031
Commit 08ad9b068afb88 (" ar8031: modify the config func of ar8031 to ar8021_config") selected 'ar8021_config' as the configuration function for AR8031.
The correct would be to use 'ar8035_config' instead as AR8031/AR8035 have the same programming model and even share the same phy driver in the linux kernel: drivers/net/phy/at803x.c.
Tested on a mx6qsabresd and wandboard, which now can work without any PHY setup code in the board files.
Signed-off-by: Fabio Estevam fabio.estevam@nxp.com --- This is 2016.04 material.
Zhao Qiang, could you please test this on your platform?
Changes since v1: - None
drivers/net/phy/atheros.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/net/phy/atheros.c b/drivers/net/phy/atheros.c index d509e30..ba57b1a 100644 --- a/drivers/net/phy/atheros.c +++ b/drivers/net/phy/atheros.c @@ -51,7 +51,7 @@ static struct phy_driver AR8031_driver = { .uid = 0x4dd074, .mask = 0xffffffef, .features = PHY_GBIT_FEATURES, - .config = ar8021_config, + .config = ar8035_config, .startup = genphy_startup, .shutdown = genphy_shutdown, };
As per the AR8031 datasheet:
"For a reliable power on reset, suggest to keep asserting the reset low long enough (10ms) to ensure the clock is stable and clock-to-reset 1ms requirement is satisfied."
So do as suggested and also add a 100us delay after deasserting the reset line to guarantee that the PHY ID can be read correctly and the Atheros 8031 PHY driver can be loaded automatically.
This results in a simpler code.
board/freescale/mx6sabresd/mx6sabresd.c | 36 ++------------------------------- 1 file changed, 2 insertions(+), 34 deletions(-)
diff --git a/board/freescale/mx6sabresd/mx6sabresd.c b/board/freescale/mx6sabresd/mx6sabresd.c index 581c9d5..d20953d 100644 --- a/board/freescale/mx6sabresd/mx6sabresd.c +++ b/board/freescale/mx6sabresd/mx6sabresd.c @@ -94,8 +94,9 @@ static void setup_iomux_enet(void)
/* Reset AR8031 PHY */ gpio_direction_output(IMX_GPIO_NR(1, 25) , 0); - udelay(500); + mdelay(10); gpio_set_value(IMX_GPIO_NR(1, 25), 1); + udelay(100); }
static iomux_v3_cfg_t const usdhc2_pads[] = { @@ -340,39 +341,6 @@ int board_mmc_init(bd_t *bis) } #endif
-int mx6_rgmii_rework(struct phy_device *phydev) -{ - unsigned short val; - - /* To enable AR8031 ouput a 125MHz clk from CLK_25M */ - phy_write(phydev, MDIO_DEVAD_NONE, 0xd, 0x7); - phy_write(phydev, MDIO_DEVAD_NONE, 0xe, 0x8016); - phy_write(phydev, MDIO_DEVAD_NONE, 0xd, 0x4007); - - val = phy_read(phydev, MDIO_DEVAD_NONE, 0xe); - val &= 0xffe3; - val |= 0x18; - phy_write(phydev, MDIO_DEVAD_NONE, 0xe, val); - - /* introduce tx clock delay */ - phy_write(phydev, MDIO_DEVAD_NONE, 0x1d, 0x5); - val = phy_read(phydev, MDIO_DEVAD_NONE, 0x1e); - val |= 0x0100; - phy_write(phydev, MDIO_DEVAD_NONE, 0x1e, val); - - return 0; -} - -int board_phy_config(struct phy_device *phydev) -{ - mx6_rgmii_rework(phydev); - - if (phydev->drv->config) - phydev->drv->config(phydev); - - return 0; -} - #if defined(CONFIG_VIDEO_IPUV3) static void disable_lvds(struct display_info_t const *dev) {
Hi Fabio,
Changes since v1: - Use mdelay instead of udelay
board/wandboard/wandboard.c | 36 ++---------------------------------- 1 file changed, 2 insertions(+), 34 deletions(-)
diff --git a/board/wandboard/wandboard.c b/board/wandboard/wandboard.c index 0af63d2..5fb7117 100644 --- a/board/wandboard/wandboard.c +++ b/board/wandboard/wandboard.c @@ -121,8 +121,9 @@ static void setup_iomux_enet(void)
/* Reset AR8031 PHY */ gpio_direction_output(ETH_PHY_RESET, 0); - udelay(500); + mdelay(10); gpio_set_value(ETH_PHY_RESET, 1); + udelay(100); }
static struct fsl_esdhc_cfg usdhc_cfg[2] = { @@ -187,39 +188,6 @@ int board_mmc_init(bd_t *bis) return 0; }
-static int mx6_rgmii_rework(struct phy_device *phydev) -{ - unsigned short val; - - /* To enable AR8031 ouput a 125MHz clk from CLK_25M */ - phy_write(phydev, MDIO_DEVAD_NONE, 0xd, 0x7); - phy_write(phydev, MDIO_DEVAD_NONE, 0xe, 0x8016); - phy_write(phydev, MDIO_DEVAD_NONE, 0xd, 0x4007); - - val = phy_read(phydev, MDIO_DEVAD_NONE, 0xe); - val &= 0xffe3; - val |= 0x18; - phy_write(phydev, MDIO_DEVAD_NONE, 0xe, val); - - /* introduce tx clock delay */ - phy_write(phydev, MDIO_DEVAD_NONE, 0x1d, 0x5); - val = phy_read(phydev, MDIO_DEVAD_NONE, 0x1e); - val |= 0x0100; - phy_write(phydev, MDIO_DEVAD_NONE, 0x1e, val); - - return 0; -} - -int board_phy_config(struct phy_device *phydev) -{ - mx6_rgmii_rework(phydev); - - if (phydev->drv->config) - phydev->drv->config(phydev); - - return 0; -} - #if defined(CONFIG_VIDEO_IPUV3) struct i2c_pads_info mx6q_i2c2_pad_info = { .scl = {
Hi Fabio,
Applied (fix) to u-boot-imx, thanks !
Best regards, Stefano Babic
-----Original Message----- From: Fabio Estevam [mailto:festevam@gmail.com] Sent: Wednesday, January 06, 2016 3:03 AM To: sbabic@denx.de Cc: joe.hershberger@ni.com; B45475@freescale.com; yorksun@freescale.com; troy.kisky@boundarydevices.com; u-boot@lists.denx.de; Fabio Estevam fabio.estevam@nxp.com Subject: [PATCH v2 1/3] phy: atheros: Use ar8035_config for AR8031
Yes, have tested, it can work on my platform.
Changes since v1:
- None
- .config = ar8035_config, .startup = genphy_startup, .shutdown = genphy_shutdown,
1.9.1
Best Regards Zhao Qiang
Excellent, thanks for testing, Zhao.
Stefano,
With Zhao's test I think it is safe to add this for 2016.01. What do you think?
Hi Fabio,
Stefano,
Agree, I pick it up.
Regards, Stefano
Changes since v1:
- None
1.9.1
Changes since v1:
- None
1.9.1
Changes since v1:
- None
Fabio Estevam
Joe Hershberger
Qiang Zhao
Stefano Babic
