[PATCH] fs: ext4: Remove unused parameter from ext4_mount
The part_length parameter is not used. Remove it.
Signed-off-by: Sean Anderson seanga2@gmail.com ---
common/spl/spl_ext.c | 4 ++-- env/ext4.c | 4 ++-- fs/ext4/ext4_common.c | 2 +- fs/ext4/ext4fs.c | 2 +- include/ext4fs.h | 2 +- 5 files changed, 7 insertions(+), 7 deletions(-)
diff --git a/common/spl/spl_ext.c b/common/spl/spl_ext.c index af836ca15b8..2f960956c44 100644 --- a/common/spl/spl_ext.c +++ b/common/spl/spl_ext.c @@ -29,7 +29,7 @@ int spl_load_image_ext(struct spl_image_info *spl_image,
ext4fs_set_blk_dev(block_dev, &part_info);
- err = ext4fs_mount(part_info.size); + err = ext4fs_mount(); if (!err) { #ifdef CONFIG_SPL_LIBCOMMON_SUPPORT printf("%s: ext4fs mount err - %d\n", __func__, err); @@ -84,7 +84,7 @@ int spl_load_image_ext_os(struct spl_image_info *spl_image,
- err = ext4fs_mount(part_info.size); + err = ext4fs_mount(); if (!err) { #ifdef CONFIG_SPL_LIBCOMMON_SUPPORT printf("%s: ext4fs mount err - %d\n", __func__, err); diff --git a/env/ext4.c b/env/ext4.c index 47e05a48919..da26705b8da 100644 --- a/env/ext4.c +++ b/env/ext4.c @@ -77,7 +77,7 @@ static int env_ext4_save_buffer(env_t *env_new) dev = dev_desc->devnum; ext4fs_set_blk_dev(dev_desc, &info);
- if (!ext4fs_mount(info.size)) { + if (!ext4fs_mount()) { printf("\n** Unable to use %s %s for saveenv **\n", ifname, dev_and_part); return 1; @@ -160,7 +160,7 @@ static int env_ext4_load(void) dev = dev_desc->devnum; ext4fs_set_blk_dev(dev_desc, &info);
- if (!ext4fs_mount(info.size)) { + if (!ext4fs_mount()) { printf("\n** Unable to use %s %s for loading the env **\n", ifname, dev_and_part); goto err_env_relocate; diff --git a/fs/ext4/ext4_common.c b/fs/ext4/ext4_common.c index f50de7c089e..ea9b92298ba 100644 --- a/fs/ext4/ext4_common.c +++ b/fs/ext4/ext4_common.c @@ -2368,7 +2368,7 @@ fail: return -1; }
-int ext4fs_mount(unsigned part_length) +int ext4fs_mount(void) { struct ext2_data *data; int status; diff --git a/fs/ext4/ext4fs.c b/fs/ext4/ext4fs.c index 4c89152ce4a..3b12ec54fa2 100644 --- a/fs/ext4/ext4fs.c +++ b/fs/ext4/ext4fs.c @@ -233,7 +233,7 @@ int ext4fs_probe(struct blk_desc *fs_dev_desc, { ext4fs_set_blk_dev(fs_dev_desc, fs_partition);
- if (!ext4fs_mount(fs_partition->size)) { + if (!ext4fs_mount()) { ext4fs_close(); return -1; } diff --git a/include/ext4fs.h b/include/ext4fs.h index dd66d27f776..d96edfd0576 100644 --- a/include/ext4fs.h +++ b/include/ext4fs.h @@ -147,7 +147,7 @@ int ext4fs_create_link(const char *target, const char *fname); struct ext_filesystem *get_fs(void); int ext4fs_open(const char *filename, loff_t *len); int ext4fs_read(char *buf, loff_t offset, loff_t len, loff_t *actread); -int ext4fs_mount(unsigned part_length); +int ext4fs_mount(void); void ext4fs_close(void); void ext4fs_reinit_global(void); int ext4fs_ls(const char *dirname);
Sean Anderson
