[U-Boot] [PATCH 0/6] kbuild, kconfig: sync with Linux 3.18-rc1
Masahiro Yamada (5): kbuild: bug fixes and cleanups of Makefile.host kbuild: improve multi-objs dependency and cleanups kbuild: sync top Makefile with Linux 3.18-rc1 kconfig: sync kconfig files with Linux 3.18-rc1 kbuild: sync misc scripts with Linux 3.18-rc1
Michal Marek (1): kbuild: Make scripts executable
Makefile | 188 +++++++++++++++-------------- scripts/Kbuild.include | 18 +-- scripts/Makefile.autoconf | 7 +- scripts/Makefile.build | 14 +-- scripts/Makefile.clean | 6 +- scripts/Makefile.host | 63 ++-------- scripts/Makefile.lib | 9 ++ scripts/binutils-version.sh | 0 scripts/dtc-version.sh | 0 scripts/gcc-stack-usage.sh | 0 scripts/gcc-version.sh | 0 scripts/kconfig/Makefile | 57 ++++----- scripts/kconfig/lxdialog/check-lxdialog.sh | 0 scripts/kconfig/lxdialog/dialog.h | 2 +- scripts/kconfig/streamline_config.pl | 0 scripts/kernel-doc | 16 ++- scripts/mkmakefile | 0 scripts/multiconfig.sh | 0 tools/Makefile | 2 +- 19 files changed, 179 insertions(+), 203 deletions(-) mode change 100644 => 100755 scripts/binutils-version.sh mode change 100644 => 100755 scripts/dtc-version.sh mode change 100644 => 100755 scripts/gcc-stack-usage.sh mode change 100644 => 100755 scripts/gcc-version.sh mode change 100644 => 100755 scripts/kconfig/lxdialog/check-lxdialog.sh mode change 100644 => 100755 scripts/kconfig/streamline_config.pl mode change 100644 => 100755 scripts/mkmakefile mode change 100644 => 100755 scripts/multiconfig.sh
This commit imports updates of scripts/Makefile.host from Linux 3.18-rc1.
Imported commits are:
[1] commit d8d9efe22709 by Masahiro Yamada kbuild: fix a typo in scripts/Makefile.host
[2] commit edb950c17de0 by Masahiro Yamada kbuild: fix a bug of C++ host program handling
[3] commit 62e2210798ed by Masahiro Yamada kbuild: drop shared library support from Makefile.host
[4] commit 663935593915 by Masahiro Yamada kbuild: clean up scripts/Makefile.host
[5] commit 1791ff7179f6 by Masahiro Yamada kbuild: clean-up and bug fix of scripts/Makefile.host
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com ---
scripts/Makefile.host | 61 ++++++++------------------------------------------- 1 file changed, 9 insertions(+), 52 deletions(-)
diff --git a/scripts/Makefile.host b/scripts/Makefile.host index 6689364..ab5980f 100644 --- a/scripts/Makefile.host +++ b/scripts/Makefile.host @@ -20,21 +20,12 @@ # Will compile qconf as a C++ program, and menu as a C program. # They are linked as C++ code to the executable qconf
-# hostprogs-y := conf -# conf-objs := conf.o libkconfig.so -# libkconfig-objs := expr.o type.o -# Will create a shared library named libkconfig.so that consists of -# expr.o and type.o (they are both compiled as C code and the object files -# are made as position independent code). -# conf.c is compiled as a C program, and conf.o is linked together with -# libkconfig.so as the executable conf. -# Note: Shared libraries consisting of C++ files are not supported - __hostprogs := $(sort $(hostprogs-y) $(hostprogs-m))
# C code # Executables compiled from a single .c file -host-csingle := $(foreach m,$(__hostprogs),$(if $($(m)-objs),,$(m))) +host-csingle := $(foreach m,$(__hostprogs), \ + $(if $($(m)-objs)$($(m)-cxxobjs),,$(m)))
# C executables linked based on several .o files host-cmulti := $(foreach m,$(__hostprogs),\ @@ -44,33 +35,17 @@ host-cmulti := $(foreach m,$(__hostprogs),\ host-cobjs := $(sort $(foreach m,$(__hostprogs),$($(m)-objs)))
# C++ code -# C++ executables compiled from at least on .cc file +# C++ executables compiled from at least one .cc file # and zero or more .c files host-cxxmulti := $(foreach m,$(__hostprogs),$(if $($(m)-cxxobjs),$(m)))
# C++ Object (.o) files compiled from .cc files host-cxxobjs := $(sort $(foreach m,$(host-cxxmulti),$($(m)-cxxobjs)))
-# Shared libaries (only .c supported) -# Shared libraries (.so) - all .so files referenced in "xxx-objs" -host-cshlib := $(sort $(filter %.so, $(host-cobjs))) -# Remove .so files from "xxx-objs" -host-cobjs := $(filter-out %.so,$(host-cobjs)) - -#Object (.o) files used by the shared libaries -host-cshobjs := $(sort $(foreach m,$(host-cshlib),$($(m:.so=-objs)))) - # output directory for programs/.o files -# hostprogs-y := tools/build may have been specified. Retrieve directory -host-objdirs := $(foreach f,$(__hostprogs), $(if $(dir $(f)),$(dir $(f)))) -# directory of .o files from prog-objs notation -host-objdirs += $(foreach f,$(host-cmulti), \ - $(foreach m,$($(f)-objs), \ - $(if $(dir $(m)),$(dir $(m))))) -# directory of .o files from prog-cxxobjs notation -host-objdirs += $(foreach f,$(host-cxxmulti), \ - $(foreach m,$($(f)-cxxobjs), \ - $(if $(dir $(m)),$(dir $(m))))) +# hostprogs-y := tools/build may have been specified. +# Retrieve also directory of .o files from prog-objs or prog-cxxobjs notation +host-objdirs := $(dir $(__hostprogs) $(host-cobjs) $(host-cxxobjs))
host-objdirs := $(strip $(sort $(filter-out ./,$(host-objdirs))))
@@ -81,8 +56,6 @@ host-cmulti := $(addprefix $(obj)/,$(host-cmulti)) host-cobjs := $(addprefix $(obj)/,$(host-cobjs)) host-cxxmulti := $(addprefix $(obj)/,$(host-cxxmulti)) host-cxxobjs := $(addprefix $(obj)/,$(host-cxxobjs)) -host-cshlib := $(addprefix $(obj)/,$(host-cshlib)) -host-cshobjs := $(addprefix $(obj)/,$(host-cshobjs)) host-objdirs := $(addprefix $(obj)/,$(host-objdirs))
obj-dirs += $(host-objdirs) @@ -123,7 +96,7 @@ quiet_cmd_host-cmulti = HOSTLD $@ cmd_host-cmulti = $(HOSTCC) $(HOSTLDFLAGS) -o $@ \ $(addprefix $(obj)/,$($(@F)-objs)) \ $(HOST_LOADLIBES) $(HOSTLOADLIBES_$(@F)) -$(host-cmulti): $(obj)/%: $(host-cobjs) $(host-cshlib) FORCE +$(host-cmulti): $(obj)/%: $(host-cobjs) FORCE $(call if_changed,host-cmulti)
# Create .o file from a single .c file @@ -140,7 +113,7 @@ quiet_cmd_host-cxxmulti = HOSTLD $@ $(foreach o,objs cxxobjs,\ $(addprefix $(obj)/,$($(@F)-$(o)))) \ $(HOST_LOADLIBES) $(HOSTLOADLIBES_$(@F)) -$(host-cxxmulti): $(obj)/%: $(host-cobjs) $(host-cxxobjs) $(host-cshlib) FORCE +$(host-cxxmulti): $(obj)/%: $(host-cobjs) $(host-cxxobjs) FORCE $(call if_changed,host-cxxmulti)
# Create .o file from a single .cc (C++) file @@ -149,21 +122,5 @@ quiet_cmd_host-cxxobjs = HOSTCXX $@ $(host-cxxobjs): $(obj)/%.o: $(src)/%.cc FORCE $(call if_changed_dep,host-cxxobjs)
-# Compile .c file, create position independent .o file -# host-cshobjs -> .o -quiet_cmd_host-cshobjs = HOSTCC -fPIC $@ - cmd_host-cshobjs = $(HOSTCC) $(hostc_flags) -fPIC -c -o $@ $< -$(host-cshobjs): $(obj)/%.o: $(src)/%.c FORCE - $(call if_changed_dep,host-cshobjs) - -# Link a shared library, based on position independent .o files -# *.o -> .so shared library (host-cshlib) -quiet_cmd_host-cshlib = HOSTLLD -shared $@ - cmd_host-cshlib = $(HOSTCC) $(HOSTLDFLAGS) -shared -o $@ \ - $(addprefix $(obj)/,$($(@F:.so=-objs))) \ - $(HOST_LOADLIBES) $(HOSTLOADLIBES_$(@F)) -$(host-cshlib): $(obj)/%: $(host-cshobjs) FORCE - $(call if_changed,host-cshlib) - targets += $(host-csingle) $(host-cmulti) $(host-cobjs)\ - $(host-cxxmulti) $(host-cxxobjs) $(host-cshlib) $(host-cshobjs) + $(host-cxxmulti) $(host-cxxobjs)
Since Linux 3.18-rc1, Kbuild is able to handle multi-objs dependency correctly, which also allows us futher cleanups of some makefiles.
This commit imports those commits:
[1] commit c8589d1e9e01 by Masahiro Yamada kbuild: handle multi-objs dependency appropriately
[2] commit 97e3226e6e98 by Masahiro Yamada kbuild: handle the dependency of multi-objs hostprogs appropriately
[3] commit 022af62d0190 by Masahiro Yamada kbuild: refactor script/kconfig/Makefile
[4] commit 221ecca6cafe by Masahiro Yamada kbuild: remove redundant clean-files from scripts/kconfig/Makefile
scripts/Makefile.build | 10 ++++------ scripts/Makefile.host | 6 ++++-- scripts/Makefile.lib | 9 +++++++++ scripts/kconfig/Makefile | 35 +++-------------------------------- 4 files changed, 20 insertions(+), 40 deletions(-)
diff --git a/scripts/Makefile.build b/scripts/Makefile.build index 6742ddd..3e12b57 100644 --- a/scripts/Makefile.build +++ b/scripts/Makefile.build @@ -400,16 +400,14 @@ cmd_link_multi-y = $(LD) $(ld_flags) -r -o $@ $(link_multi_deps) $(cmd_secanalys quiet_cmd_link_multi-m = LD [M] $@ cmd_link_multi-m = $(cmd_link_multi-y)
-# We would rather have a list of rules like -# foo.o: $(foo-objs) -# but that's not so easy, so we rather make all composite objects depend -# on the set of all their parts -$(multi-used-y) : %.o: $(multi-objs-y) FORCE +$(multi-used-y): FORCE $(call if_changed,link_multi-y) +$(call multi_depend, $(multi-used-y), .o, -objs -y)
-$(multi-used-m) : %.o: $(multi-objs-m) FORCE +$(multi-used-m): FORCE $(call if_changed,link_multi-m) @{ echo $(@:.o=.ko); echo $(link_multi_deps); } > $(MODVERDIR)/$(@F:.o=.mod) +$(call multi_depend, $(multi-used-m), .o, -objs -y)
targets += $(multi-used-y) $(multi-used-m)
diff --git a/scripts/Makefile.host b/scripts/Makefile.host index ab5980f..133edfa 100644 --- a/scripts/Makefile.host +++ b/scripts/Makefile.host @@ -96,8 +96,9 @@ quiet_cmd_host-cmulti = HOSTLD $@ cmd_host-cmulti = $(HOSTCC) $(HOSTLDFLAGS) -o $@ \ $(addprefix $(obj)/,$($(@F)-objs)) \ $(HOST_LOADLIBES) $(HOSTLOADLIBES_$(@F)) -$(host-cmulti): $(obj)/%: $(host-cobjs) FORCE +$(host-cmulti): FORCE $(call if_changed,host-cmulti) +$(call multi_depend, $(host-cmulti), , -objs)
# Create .o file from a single .c file # host-cobjs -> .o @@ -113,8 +114,9 @@ quiet_cmd_host-cxxmulti = HOSTLD $@ $(foreach o,objs cxxobjs,\ $(addprefix $(obj)/,$($(@F)-$(o)))) \ $(HOST_LOADLIBES) $(HOSTLOADLIBES_$(@F)) -$(host-cxxmulti): $(obj)/%: $(host-cobjs) $(host-cxxobjs) FORCE +$(host-cxxmulti): FORCE $(call if_changed,host-cxxmulti) +$(call multi_depend, $(host-cxxmulti), , -objs -cxxobjs)
# Create .o file from a single .cc (C++) file quiet_cmd_host-cxxobjs = HOSTCXX $@ diff --git a/scripts/Makefile.lib b/scripts/Makefile.lib index 072abaa..9d1383a 100644 --- a/scripts/Makefile.lib +++ b/scripts/Makefile.lib @@ -160,6 +160,15 @@ dtc_cpp_flags = -Wp,-MD,$(depfile).pre.tmp -nostdinc \ modname-multi = $(sort $(foreach m,$(multi-used),\ $(if $(filter $(subst $(obj)/,,$*.o), $($(m:.o=-objs)) $($(m:.o=-y))),$(m:.o=))))
+# Useful for describing the dependency of composite objects +# Usage: +# $(call multi_depend, multi_used_targets, suffix_to_remove, suffix_to_add) +define multi_depend +$(foreach m, $(notdir $1), \ + $(eval $(obj)/$m: \ + $(addprefix $(obj)/, $(foreach s, $3, $($(m:%$(strip $2)=%$(s))))))) +endef + ifdef REGENERATE_PARSERS
# GPERF diff --git a/scripts/kconfig/Makefile b/scripts/kconfig/Makefile index 9c4d241..e7bf38e 100644 --- a/scripts/kconfig/Makefile +++ b/scripts/kconfig/Makefile @@ -157,39 +157,10 @@ qconf-cxxobjs := qconf.o qconf-objs := zconf.tab.o gconf-objs := gconf.o zconf.tab.o
-hostprogs-y := conf - -ifeq ($(MAKECMDGOALS),nconfig) - hostprogs-y += nconf -endif - -ifeq ($(MAKECMDGOALS),menuconfig) - hostprogs-y += mconf -endif - -ifeq ($(MAKECMDGOALS),update-po-config) - hostprogs-y += kxgettext -endif - -ifeq ($(MAKECMDGOALS),xconfig) - qconf-target := 1 -endif -ifeq ($(MAKECMDGOALS),gconfig) - gconf-target := 1 -endif - - -ifeq ($(qconf-target),1) - hostprogs-y += qconf -endif - -ifeq ($(gconf-target),1) - hostprogs-y += gconf -endif +hostprogs-y := conf nconf mconf kxgettext qconf gconf
clean-files := qconf.moc .tmp_qtcheck .tmp_gtkcheck clean-files += zconf.tab.c zconf.lex.c zconf.hash.c gconf.glade.h -clean-files += mconf qconf gconf nconf clean-files += config.pot linux.pot
# Check that we have the required ncurses stuff installed for lxdialog (menuconfig) @@ -224,7 +195,7 @@ HOSTLOADLIBES_nconf = $(shell \ || echo "-lmenu -lpanel -lncurses" ) $(obj)/qconf.o: $(obj)/.tmp_qtcheck
-ifeq ($(qconf-target),1) +ifeq ($(MAKECMDGOALS),xconfig) $(obj)/.tmp_qtcheck: $(src)/Makefile -include $(obj)/.tmp_qtcheck
@@ -281,7 +252,7 @@ endif
$(obj)/gconf.o: $(obj)/.tmp_gtkcheck
-ifeq ($(gconf-target),1) +ifeq ($(MAKECMDGOALS),gconfig) -include $(obj)/.tmp_gtkcheck
# GTK needs some extra effort, too...
Since Linux 3.15, relative path feature and related fixes, cleanups have been merged to the top Makefile.
The relative path feature looks stable enough, so let's import it to U-Boot along with various cleanups.
Commits imported from Linux (some need adjustment) are:
[1] commit 7e1c04779efd by Michal Marek kbuild: Use relative path for $(objtree)
[2] commit 890676c65d69 by Michal Marek kbuild: Use relative path when building in the source tree
[3] commit 9da0763bdd82 by Michal Marek kbuild: Use relative path when building in a subdir of the source tree
[4] commit c2e28dc975ea by Michal Marek kbuild: Print the name of the build directory
[5] commit 066b7ed95580 by Michal Marek kbuild: Do not print the build directory with make -s
[6] commit 3f1d9a6cec01 by Michal Marek kbuild: make -s should be used with kernelrelease/kernelversion/image_name
[7] commit 7ff525712acf by Masahiro Yamada kbuild: fake the "Entering directory ..." message more simply
[8] commit 745a254322c8 by Masahiro Yamada kbuild: use $(Q) for sub-make target
[9] commit aa55c8e2f7a3 by Masahiro Yamada kbuild: handle C=... and M=... after entering into build directory
[10] commit ab7474ea5361 by Borislav Petkov Kbuild: Ignore GREP_OPTIONS env variable
To use relative path feature, tools/Makefile and scripts/Makefile.autoconf must be tweaked.
Signed-off-by: Michal Marek mmarek@suse.cz Signed-off-by: Borislav Petkov bp@suse.de Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com ---
Makefile | 186 ++++++++++++++++++++++++---------------------- scripts/Makefile.autoconf | 7 +- tools/Makefile | 2 +- 3 files changed, 102 insertions(+), 93 deletions(-)
diff --git a/Makefile b/Makefile index 26dacee..7f25cb5 100644 --- a/Makefile +++ b/Makefile @@ -1,10 +1,3 @@ -# -# (C) Copyright 2000-2013 -# Wolfgang Denk, DENX Software Engineering, wd@denx.de. -# -# SPDX-License-Identifier: GPL-2.0+ -# - VERSION = 2014 PATCHLEVEL = 10 SUBLEVEL = @@ -17,11 +10,9 @@ NAME = # Comments in this file are targeted only to the developer, do not # expect to learn how to build the kernel reading this file.
-# Do not: -# o use make's built-in rules and variables -# (this increases performance and avoids hard-to-debug behaviour); -# o print "Entering directory ..."; -MAKEFLAGS += -rR --no-print-directory +# Do not use make's built-in rules and variables +# (this increases performance and avoids hard-to-debug behaviour); +MAKEFLAGS += -rR
# Avoid funny character set dependencies unexport LC_ALL @@ -29,6 +20,9 @@ LC_COLLATE=C LC_NUMERIC=C export LC_COLLATE LC_NUMERIC
+# Avoid interference with shell env settings +unexport GREP_OPTIONS + # We are using a recursive build, so we need to do a little thinking # to get the ordering right. # @@ -45,6 +39,29 @@ export LC_COLLATE LC_NUMERIC # descending is started. They are now explicitly listed as the # prepare rule.
+# Beautify output +# --------------------------------------------------------------------------- +# +# Normally, we echo the whole command before executing it. By making +# that echo $($(quiet)$(cmd)), we now have the possibility to set +# $(quiet) to choose other forms of output instead, e.g. +# +# quiet_cmd_cc_o_c = Compiling $(RELDIR)/$@ +# cmd_cc_o_c = $(CC) $(c_flags) -c -o $@ $< +# +# If $(quiet) is empty, the whole command will be printed. +# If it is set to "quiet_", only the short version will be printed. +# If it is set to "silent_", nothing will be printed at all, since +# the variable $(silent_cmd_cc_o_c) doesn't exist. +# +# A simple variant is to prefix commands with $(Q) - that's useful +# for commands that shall be hidden in non-verbose mode. +# +# $(Q)ln $@ :< +# +# If KBUILD_VERBOSE equals 0 then the above command will be hidden. +# If KBUILD_VERBOSE equals 1 then the above command is displayed. +# # To put more focus on warnings, be less verbose as default # Use 'make V=1' to see the full commands
@@ -55,33 +72,28 @@ ifndef KBUILD_VERBOSE KBUILD_VERBOSE = 0 endif
-# Call a source code checker (by default, "sparse") as part of the -# C compilation. -# -# Use 'make C=1' to enable checking of only re-compiled files. -# Use 'make C=2' to enable checking of *all* source files, regardless -# of whether they are re-compiled or not. -# -# See the file "Documentation/sparse.txt" for more details, including -# where to get the "sparse" utility. +ifeq ($(KBUILD_VERBOSE),1) + quiet = + Q = +else + quiet=quiet_ + Q = @ +endif
-ifeq ("$(origin C)", "command line") - KBUILD_CHECKSRC = $(C) +# If the user is running make -s (silent mode), suppress echoing of +# commands + +ifneq ($(filter 4.%,$(MAKE_VERSION)),) # make-4 +ifneq ($(filter %s ,$(firstword x$(MAKEFLAGS))),) + quiet=silent_ endif -ifndef KBUILD_CHECKSRC - KBUILD_CHECKSRC = 0 +else # make-3.8x +ifneq ($(filter s% -s%,$(MAKEFLAGS)),) + quiet=silent_ endif - -# Use make M=dir to specify directory of external module to build -# Old syntax make ... SUBDIRS=$PWD is still supported -# Setting the environment variable KBUILD_EXTMOD take precedence -ifdef SUBDIRS - KBUILD_EXTMOD ?= $(SUBDIRS) endif
-ifeq ("$(origin M)", "command line") - KBUILD_EXTMOD := $(M) -endif +export quiet Q KBUILD_VERBOSE
# kbuild supports saving output files in a separate directory. # To locate output files in a separate directory two syntaxes are supported. @@ -98,7 +110,6 @@ endif # The O= assignment takes precedence over the KBUILD_OUTPUT environment # variable.
- # KBUILD_SRC is set on invocation of make in OBJ directory # KBUILD_SRC is not intended to be used by the regular user (for now) ifeq ($(KBUILD_SRC),) @@ -131,10 +142,8 @@ $(filter-out _all sub-make $(CURDIR)/Makefile, $(MAKECMDGOALS)) _all: sub-make @:
sub-make: FORCE - $(if $(KBUILD_VERBOSE:1=),@)$(MAKE) -C $(KBUILD_OUTPUT) \ - KBUILD_SRC=$(CURDIR) \ - KBUILD_EXTMOD="$(KBUILD_EXTMOD)" -f $(CURDIR)/Makefile \ - $(filter-out _all sub-make,$(MAKECMDGOALS)) + $(Q)$(MAKE) -C $(KBUILD_OUTPUT) KBUILD_SRC=$(CURDIR) \ + -f $(CURDIR)/Makefile $(filter-out _all sub-make,$(MAKECMDGOALS))
# Leave processing to above invocation of make skip-makefile := 1 @@ -144,6 +153,39 @@ endif # ifeq ($(KBUILD_SRC),) # We process the rest of the Makefile if this is the final invocation of make ifeq ($(skip-makefile),)
+# Do not print "Entering directory ...", +# but we want to display it when entering to the output directory +# so that IDEs/editors are able to understand relative filenames. +MAKEFLAGS += --no-print-directory + +# Call a source code checker (by default, "sparse") as part of the +# C compilation. +# +# Use 'make C=1' to enable checking of only re-compiled files. +# Use 'make C=2' to enable checking of *all* source files, regardless +# of whether they are re-compiled or not. +# +# See the file "Documentation/sparse.txt" for more details, including +# where to get the "sparse" utility. + +ifeq ("$(origin C)", "command line") + KBUILD_CHECKSRC = $(C) +endif +ifndef KBUILD_CHECKSRC + KBUILD_CHECKSRC = 0 +endif + +# Use make M=dir to specify directory of external module to build +# Old syntax make ... SUBDIRS=$PWD is still supported +# Setting the environment variable KBUILD_EXTMOD take precedence +ifdef SUBDIRS + KBUILD_EXTMOD ?= $(SUBDIRS) +endif + +ifeq ("$(origin M)", "command line") + KBUILD_EXTMOD := $(M) +endif + # If building an external module we do not care about the all: rule # but instead _all depend on modules PHONY += all @@ -153,8 +195,18 @@ else _all: modules endif
-srctree := $(if $(KBUILD_SRC),$(KBUILD_SRC),$(CURDIR)) -objtree := $(CURDIR) +ifeq ($(KBUILD_SRC),) + # building in the source tree + srctree := . +else + ifeq ($(KBUILD_SRC)/,$(dir $(CURDIR))) + # building in a subdirectory of the source tree + srctree := .. + else + srctree := $(KBUILD_SRC) + endif +endif +objtree := . src := $(srctree) obj := $(objtree)
@@ -262,52 +314,6 @@ endif export KBUILD_MODULES KBUILD_BUILTIN export KBUILD_CHECKSRC KBUILD_SRC KBUILD_EXTMOD
-# Beautify output -# --------------------------------------------------------------------------- -# -# Normally, we echo the whole command before executing it. By making -# that echo $($(quiet)$(cmd)), we now have the possibility to set -# $(quiet) to choose other forms of output instead, e.g. -# -# quiet_cmd_cc_o_c = Compiling $(RELDIR)/$@ -# cmd_cc_o_c = $(CC) $(c_flags) -c -o $@ $< -# -# If $(quiet) is empty, the whole command will be printed. -# If it is set to "quiet_", only the short version will be printed. -# If it is set to "silent_", nothing will be printed at all, since -# the variable $(silent_cmd_cc_o_c) doesn't exist. -# -# A simple variant is to prefix commands with $(Q) - that's useful -# for commands that shall be hidden in non-verbose mode. -# -# $(Q)ln $@ :< -# -# If KBUILD_VERBOSE equals 0 then the above command will be hidden. -# If KBUILD_VERBOSE equals 1 then the above command is displayed. - -ifeq ($(KBUILD_VERBOSE),1) - quiet = - Q = -else - quiet=quiet_ - Q = @ -endif - -# If the user is running make -s (silent mode), suppress echoing of -# commands - -ifneq ($(filter 4.%,$(MAKE_VERSION)),) # make-4 -ifneq ($(filter %s ,$(firstword x$(MAKEFLAGS))),) - quiet=silent_ -endif -else # make-3.8x -ifneq ($(filter s% -s%,$(MAKEFLAGS)),) - quiet=silent_ -endif -endif - -export quiet Q KBUILD_VERBOSE - # Look for make include files relative to root of kernel src MAKEFLAGS += --include-dir=$(srctree)
@@ -1314,7 +1320,7 @@ help: @echo '' @echo 'Other generic targets:' @echo ' all - Build all necessary images depending on configuration' - @echo ' u-boot - Build the bare u-boot' + @echo '* u-boot - Build the bare u-boot' @echo ' dir/ - Build all files in dir and below' @echo ' dir/file.[oisS] - Build specified target only' @echo ' dir/file.lst - Build specified mixed source/assembly target only' @@ -1322,8 +1328,8 @@ help: @echo ' tags/ctags - Generate ctags file for editors' @echo ' etags - Generate etags file for editors' @echo ' cscope - Generate cscope index' - @echo ' ubootrelease - Output the release version string' - @echo ' ubootversion - Output the version stored in Makefile' + @echo ' ubootrelease - Output the release version string (use with make -s)' + @echo ' ubootversion - Output the version stored in Makefile (use with make -s)' @echo '' @echo 'Static analysers' @echo ' checkstack - Generate a list of stack hogs' diff --git a/scripts/Makefile.autoconf b/scripts/Makefile.autoconf index ced2b9a..8e9d71f 100644 --- a/scripts/Makefile.autoconf +++ b/scripts/Makefile.autoconf @@ -89,9 +89,12 @@ PHONY += create_symlink create_symlink: ifneq ($(KBUILD_SRC),) $(Q)mkdir -p include/asm + $(Q)ln -fsn $(KBUILD_SRC)/arch/$(ARCH)/include/asm/arch-$(if $(SOC),$(SOC),$(CPU)) \ + include/asm/arch +else + $(Q)ln -fsn arch-$(if $(SOC),$(SOC),$(CPU)) \ + arch/$(ARCH)/include/asm/arch endif - $(Q)ln -fsn $(srctree)/arch/$(ARCH)/include/asm/arch-$(if $(SOC),$(SOC),$(CPU)) \ - $(if $(KBUILD_SRC),,arch/$(ARCH)/)include/asm/arch
PHONY += FORCE FORCE: diff --git a/tools/Makefile b/tools/Makefile index 3b95964..c422b76 100644 --- a/tools/Makefile +++ b/tools/Makefile @@ -157,7 +157,7 @@ HOSTCFLAGS_sha256.o := -pedantic #HOSTCFLAGS_mpc86x_clk.o := -pedantic
quiet_cmd_wrap = WRAP $@ -cmd_wrap = echo "#include <$(srctree)/$(patsubst $(obj)/%,%,$@)>" >$@ +cmd_wrap = echo "#include <../$(patsubst $(obj)/%,%,$@)>" >$@
$(obj)/lib/%.c $(obj)/common/%.c: $(call cmd,wrap)
This commit imports Kconfig updates from Linux 3.18-rc1.
'kvmconfig' and 'tinyconfig' help message have been commented out since they are unavailable at least now; in the future perhaps we can implement 'tinyconfig' to disable most of CONFIG_CMD_* to create a very small U-Boot image.
[1] commit 3aaefce10351 by Josh Triplett x86, platform, kconfig: move kvmconfig functionality to a helper
[2] commit 0da1d4a0b951 by Josh Triplett x86: Add "make tinyconfig" to configure the tiniest possible kernel
[3] commit c40724d3f381 by Brian Norris kconfig: lxdialog: fix spelling
[4] commit 7285996aa000 by Brian Norris kconfig: nconfig: fix multi-byte UTF handling
Signed-off-by: Josh Triplett josh@joshtriplett.org Signed-off-by: Brian Norris computersforpeace@gmail.com Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com ---
scripts/kconfig/Makefile | 22 +++++++++++++++++++++- scripts/kconfig/lxdialog/dialog.h | 2 +- 2 files changed, 22 insertions(+), 2 deletions(-)
diff --git a/scripts/kconfig/Makefile b/scripts/kconfig/Makefile index e7bf38e..349f770 100644 --- a/scripts/kconfig/Makefile +++ b/scripts/kconfig/Makefile @@ -104,6 +104,23 @@ endif %_defconfig: $(obj)/conf $(Q)$< --defconfig=arch/$(SRCARCH)/configs/$@ $(Kconfig)
+configfiles=$(wildcard $(srctree)/kernel/configs/$(1).config $(srctree)/arch/$(SRCARCH)/configs/$(1).config) + +define mergeconfig +$(if $(wildcard $(objtree)/.config),, $(error You need an existing .config for this target)) +$(if $(call configfiles,$(1)),, $(error No configuration exists for this target on this architecture)) +$(Q)$(CONFIG_SHELL) $(srctree)/scripts/kconfig/merge_config.sh -m -O $(objtree) $(objtree)/.config $(call configfiles,$(1)) +$(Q)yes "" | $(MAKE) -f $(srctree)/Makefile oldconfig +endef + +PHONY += kvmconfig +kvmconfig: + $(call mergeconfig,kvm_guest) + +PHONY += tinyconfig +tinyconfig: allnoconfig + $(call mergeconfig,tiny) + # Help text used by make help help: @echo ' config - Update current config utilising a line-oriented program' @@ -124,6 +141,8 @@ help: @echo ' randconfig - New config with random answer to all options' @echo ' listnewconfig - List new options' @echo ' olddefconfig - Same as silentoldconfig but sets new symbols to their default value' +# @echo ' kvmconfig - Enable additional options for guest kernel support' +# @echo ' tinyconfig - Configure the tiniest possible kernel'
# lxdialog stuff check-lxdialog := $(srctree)/$(src)/lxdialog/check-lxdialog.sh @@ -191,7 +210,8 @@ HOSTCFLAGS_gconf.o = `pkg-config --cflags gtk+-2.0 gmodule-2.0 libglade-2.0` \ HOSTLOADLIBES_mconf = $(shell $(CONFIG_SHELL) $(check-lxdialog) -ldflags $(HOSTCC))
HOSTLOADLIBES_nconf = $(shell \ - pkg-config --libs menu panel ncurses 2>/dev/null \ + pkg-config --libs menuw panelw ncursesw 2>/dev/null \ + || pkg-config --libs menu panel ncurses 2>/dev/null \ || echo "-lmenu -lpanel -lncurses" ) $(obj)/qconf.o: $(obj)/.tmp_qtcheck
diff --git a/scripts/kconfig/lxdialog/dialog.h b/scripts/kconfig/lxdialog/dialog.h index b4343d3..fcffd5b 100644 --- a/scripts/kconfig/lxdialog/dialog.h +++ b/scripts/kconfig/lxdialog/dialog.h @@ -170,7 +170,7 @@ char item_tag(void); /* item list manipulation for lxdialog use */ #define MAXITEMSTR 200 struct dialog_item { - char str[MAXITEMSTR]; /* promtp displayed */ + char str[MAXITEMSTR]; /* prompt displayed */ char tag; void *data; /* pointer to menu item - used by menubox+checklist */ int selected; /* Set to 1 by dialog_*() function if selected. */
This commit imports some updates in misc scripts from Linux 3.18-rc1.
[1] commit cbb4d3e6510b99522719c5ef0 by Horia Geanta scripts/kernel-doc: handle object-like macros
[2] commit 164f0d2efaaef83 by Michal Marek kbuild: Fix handling of backslashes in *.cmd files
[3] commit 270a00963cd367214e by Randy Dunlap scripts/kernel-doc: recognize __meminit
[4] commit a4954fd7724c0f55361eb5 by Masahiro Yamada kbuild: remove obj-n and lib-n handling
[5] commit 5b2389b45d1a9c12b9f by Masahiro Yamada kbuild: simplify build, clean, modbuiltin shorthands
Signed-off-by: Horia Geanta horia.geanta@freescale.com Signed-off-by: Michal Marek mmarek@suse.cz Signed-off-by: Randy Dunlap rdunlap@infradead.org Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com ---
Makefile | 2 +- scripts/Kbuild.include | 18 ++++++++++-------- scripts/Makefile.build | 4 ++-- scripts/Makefile.clean | 6 ++---- scripts/kernel-doc | 16 +++++++++++++--- 5 files changed, 28 insertions(+), 18 deletions(-)
diff --git a/Makefile b/Makefile index 7f25cb5..603b6b7 100644 --- a/Makefile +++ b/Makefile @@ -1450,7 +1450,7 @@ endif # Shorthand for $(Q)$(MAKE) -f scripts/Makefile.clean obj=dir # Usage: # $(Q)$(MAKE) $(clean)=dir -clean := -f $(if $(KBUILD_SRC),$(srctree)/)scripts/Makefile.clean obj +clean := -f $(srctree)/scripts/Makefile.clean obj
endif # skip-makefile
diff --git a/scripts/Kbuild.include b/scripts/Kbuild.include index 4c33359..d20f20a 100644 --- a/scripts/Kbuild.include +++ b/scripts/Kbuild.include @@ -177,13 +177,13 @@ ld-ifversion = $(shell [ $(call ld-version) $(1) $(2) ] && echo $(3)) # Shorthand for $(Q)$(MAKE) -f scripts/Makefile.build obj= # Usage: # $(Q)$(MAKE) $(build)=dir -build := -f $(if $(KBUILD_SRC),$(srctree)/)scripts/Makefile.build obj +build := -f $(srctree)/scripts/Makefile.build obj
### # Shorthand for $(Q)$(MAKE) -f scripts/Makefile.modbuiltin obj= # Usage: # $(Q)$(MAKE) $(modbuiltin)=dir -modbuiltin := -f $(if $(KBUILD_SRC),$(srctree)/)scripts/Makefile.modbuiltin obj +modbuiltin := -f $(srctree)/scripts/Makefile.modbuiltin obj
# Prefix -I with $(srctree) if it is not an absolute path. # skip if -I has no parameter @@ -221,11 +221,13 @@ else arg-check = $(if $(strip $(cmd_$@)),,1) endif
-# >'< substitution is for echo to work, -# >$< substitution to preserve $ when reloading .cmd file -# note: when using inline perl scripts [perl -e '...$$t=1;...'] -# in $(cmd_xxx) double $$ your perl vars -make-cmd = $(subst \,\\,$(subst #,\#,$(subst $$,$$$$,$(call escsq,$(cmd_$(1)))))) +# Replace >$< with >$$< to preserve $ when reloading the .cmd file +# (needed for make) +# Replace >#< with >#< to avoid starting a comment in the .cmd file +# (needed for make) +# Replace >'< with >'''< to be able to enclose the whole string in '...' +# (needed for the shell) +make-cmd = $(call escsq,$(subst #,\#,$(subst $$,$$$$,$(cmd_$(1)))))
# Find any prerequisites that is newer than target or that does not exist. # PHONY targets skipped in both cases. @@ -236,7 +238,7 @@ any-prereq = $(filter-out $(PHONY),$?) $(filter-out $(PHONY) $(wildcard $^),$^) if_changed = $(if $(strip $(any-prereq) $(arg-check)), \ @set -e; \ $(echo-cmd) $(cmd_$(1)); \ - echo 'cmd_$@ := $(make-cmd)' > $(dot-target).cmd) + printf '%s\n' 'cmd_$@ := $(make-cmd)' > $(dot-target).cmd)
# Execute the command and also postprocess generated .d dependencies file. if_changed_dep = $(if $(strip $(any-prereq) $(arg-check) ), \ diff --git a/scripts/Makefile.build b/scripts/Makefile.build index 3e12b57..14cf092 100644 --- a/scripts/Makefile.build +++ b/scripts/Makefile.build @@ -97,11 +97,11 @@ endif
-ifneq ($(strip $(lib-y) $(lib-m) $(lib-n) $(lib-)),) +ifneq ($(strip $(lib-y) $(lib-m) $(lib-)),) lib-target := $(obj)/lib.a endif
-ifneq ($(strip $(obj-y) $(obj-m) $(obj-n) $(obj-) $(subdir-m) $(lib-target)),) +ifneq ($(strip $(obj-y) $(obj-m) $(obj-) $(subdir-m) $(lib-target)),) builtin-target := $(obj)/built-in.o endif
diff --git a/scripts/Makefile.clean b/scripts/Makefile.clean index 88f14e2..21e1f21 100644 --- a/scripts/Makefile.clean +++ b/scripts/Makefile.clean @@ -10,7 +10,7 @@ __clean: # Shorthand for $(Q)$(MAKE) scripts/Makefile.clean obj=dir # Usage: # $(Q)$(MAKE) $(clean)=dir -clean := -f $(if $(KBUILD_SRC),$(srctree)/)scripts/Makefile.clean obj +clean := -f $(srctree)/scripts/Makefile.clean obj
# The filename Kbuild has precedence over Makefile kbuild-dir := $(if $(filter /%,$(src)),$(src),$(srctree)/$(src)) @@ -23,15 +23,13 @@ __subdir-y := $(patsubst %/,%,$(filter %/, $(obj-y))) subdir-y += $(__subdir-y) __subdir-m := $(patsubst %/,%,$(filter %/, $(obj-m))) subdir-m += $(__subdir-m) -__subdir-n := $(patsubst %/,%,$(filter %/, $(obj-n))) -subdir-n += $(__subdir-n) __subdir- := $(patsubst %/,%,$(filter %/, $(obj-))) subdir- += $(__subdir-)
# Subdirectories we need to descend into
subdir-ym := $(sort $(subdir-y) $(subdir-m)) -subdir-ymn := $(sort $(subdir-ym) $(subdir-n) $(subdir-)) +subdir-ymn := $(sort $(subdir-ym) $(subdir-))
# Add subdir path
diff --git a/scripts/kernel-doc b/scripts/kernel-doc index c881b8c..08a6c76 100755 --- a/scripts/kernel-doc +++ b/scripts/kernel-doc @@ -2073,6 +2073,7 @@ sub check_return_section { sub dump_function($$) { my $prototype = shift; my $file = shift; + my $noret = 0;
$prototype =~ s/^static +//; $prototype =~ s/^extern +//; @@ -2084,9 +2085,10 @@ sub dump_function($$) { $prototype =~ s/^noinline +//; $prototype =~ s/__init +//; $prototype =~ s/__init_or_module +//; + $prototype =~ s/__meminit +//; $prototype =~ s/__must_check +//; $prototype =~ s/__weak +//; - $prototype =~ s/^#\s*define\s+//; #ak added + my $define = $prototype =~ s/^#\s*define\s+//; #ak added $prototype =~ s/__attribute__\s*(([a-z,]*))//;
# Yes, this truly is vile. We are looking for: @@ -2105,7 +2107,15 @@ sub dump_function($$) { # - atomic_set (macro) # - pci_match_device, __copy_to_user (long return type)
- if ($prototype =~ m/^()([a-zA-Z0-9_~:]+)\s*(([^(]*))/ || + if ($define && $prototype =~ m/^()([a-zA-Z0-9_~:]+)\s+/) { + # This is an object-like macro, it has no return type and no parameter + # list. + # Function-like macros are not allowed to have spaces between + # declaration_name and opening parenthesis (notice the \s+). + $return_type = $1; + $declaration_name = $2; + $noret = 1; + } elsif ($prototype =~ m/^()([a-zA-Z0-9_~:]+)\s*(([^(]*))/ || $prototype =~ m/^(\w+)\s+([a-zA-Z0-9_~:]+)\s*(([^(]*))/ || $prototype =~ m/^(\w+\s**)\s*([a-zA-Z0-9_~:]+)\s*(([^(]*))/ || $prototype =~ m/^(\w+\s+\w+)\s+([a-zA-Z0-9_~:]+)\s*(([^(]*))/ || @@ -2140,7 +2150,7 @@ sub dump_function($$) { # of warnings goes sufficiently down, the check is only performed in # verbose mode. # TODO: always perform the check. - if ($verbose) { + if ($verbose && !$noret) { check_return_section($file, $declaration_name, $return_type); }
The Makefiles call the respective interpreter explicitly, but this makes it easier to use the scripts manually.
(This commit follows commit 06ed5c2bfaca of Linux Kernel)
Signed-off-by: Michal Marek mmarek@suse.cz Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com ---
scripts/binutils-version.sh | 0 scripts/dtc-version.sh | 0 scripts/gcc-stack-usage.sh | 0 scripts/gcc-version.sh | 0 scripts/kconfig/lxdialog/check-lxdialog.sh | 0 scripts/kconfig/streamline_config.pl | 0 scripts/mkmakefile | 0 scripts/multiconfig.sh | 0 8 files changed, 0 insertions(+), 0 deletions(-) mode change 100644 => 100755 scripts/binutils-version.sh mode change 100644 => 100755 scripts/dtc-version.sh mode change 100644 => 100755 scripts/gcc-stack-usage.sh mode change 100644 => 100755 scripts/gcc-version.sh mode change 100644 => 100755 scripts/kconfig/lxdialog/check-lxdialog.sh mode change 100644 => 100755 scripts/kconfig/streamline_config.pl mode change 100644 => 100755 scripts/mkmakefile mode change 100644 => 100755 scripts/multiconfig.sh
diff --git a/scripts/binutils-version.sh b/scripts/binutils-version.sh old mode 100644 new mode 100755 diff --git a/scripts/dtc-version.sh b/scripts/dtc-version.sh old mode 100644 new mode 100755 diff --git a/scripts/gcc-stack-usage.sh b/scripts/gcc-stack-usage.sh old mode 100644 new mode 100755 diff --git a/scripts/gcc-version.sh b/scripts/gcc-version.sh old mode 100644 new mode 100755 diff --git a/scripts/kconfig/lxdialog/check-lxdialog.sh b/scripts/kconfig/lxdialog/check-lxdialog.sh old mode 100644 new mode 100755 diff --git a/scripts/kconfig/streamline_config.pl b/scripts/kconfig/streamline_config.pl old mode 100644 new mode 100755 diff --git a/scripts/mkmakefile b/scripts/mkmakefile old mode 100644 new mode 100755 diff --git a/scripts/multiconfig.sh b/scripts/multiconfig.sh old mode 100644 new mode 100755
So, I kinda sorta thought that we had talked about lagging behind a kernel release on these things, to make sure bugs get sorted out uptsream. On the other hand, the kernel is up to -rc3 now, so perhaps we should sync to that for now and play it by ear for future syncs for this release?
Hi Tom,
I find no kbuild-related update since v3.18-rc1 so far.
Although there is no code diff, I can replace rc1 with rc3 in git-log and repost this series.
Best Regards Masahiro Yamada
On Wed, Nov 05, 2014 at 01:06:07PM +0900, Masahiro Yamada wrote:
Hi Tom,
If there's no changes, no need, thanks!
Masahiro Yamada
