[PATCH v2 0/1] hwrng: meson - add support for S4
Hello!
This patch adds support for Meson S4 series hardware number generator using new algo.
V2:
- Sync with Linux version.
Alexey Romanov (1): drivers: rng: add support for Meson S4
drivers/rng/meson-rng.c | 72 ++++++++++++++++++++++++++++++++++++++++- 1 file changed, 71 insertions(+), 1 deletion(-)
For some Amlogic SOC's, mechanism to obtain random number has been changed. For example, S4 now uses status bit waiting algo.
Signed-off-by: Alexey Romanov avromanov@salutedevices.com --- drivers/rng/meson-rng.c | 72 ++++++++++++++++++++++++++++++++++++++++- 1 file changed, 71 insertions(+), 1 deletion(-)
diff --git a/drivers/rng/meson-rng.c b/drivers/rng/meson-rng.c index e0a1e8c7e0..ba60325b94 100644 --- a/drivers/rng/meson-rng.c +++ b/drivers/rng/meson-rng.c @@ -10,10 +10,23 @@ #include <dm.h> #include <rng.h> #include <asm/io.h> +#include <linux/iopoll.h> + +#define RNG_DATA 0x00 +#define RNG_S4_DATA 0x08 +#define RNG_S4_CFG 0x00 + +#define RUN_BIT BIT(0) +#define SEED_READY_STS_BIT BIT(31) + +struct meson_rng_priv { + u32 (*read)(fdt_addr_t base); +};
struct meson_rng_plat { fdt_addr_t base; struct clk clk; + struct meson_rng_priv *priv; };
/** @@ -27,10 +40,11 @@ struct meson_rng_plat { static int meson_rng_read(struct udevice *dev, void *data, size_t len) { struct meson_rng_plat *pdata = dev_get_plat(dev); + struct meson_rng_priv *priv = pdata->priv; char *buffer = (char *)data;
while (len) { - u32 rand = readl(pdata->base); + u32 rand = priv->read(pdata->base); size_t step;
if (len >= 4) @@ -44,6 +58,47 @@ static int meson_rng_read(struct udevice *dev, void *data, size_t len) return 0; }
+static int meson_rng_wait_status(void __iomem *cfg_addr, int bit) +{ + u32 status = 0; + int ret; + + ret = readl_relaxed_poll_timeout(cfg_addr, + status, !(status & bit), + 10000); + if (ret) + return -EBUSY; + + return 0; +} + +static u32 meson_common_rng_read(fdt_addr_t base) +{ + return readl(base); +} + +static u32 meson_s4_rng_read(fdt_addr_t base) +{ + void __iomem *cfg_addr = (void *)base + RNG_S4_CFG; + int err; + + writel_relaxed(readl_relaxed(cfg_addr) | SEED_READY_STS_BIT, cfg_addr); + + err = meson_rng_wait_status(cfg_addr, SEED_READY_STS_BIT); + if (err) { + pr_err("Seed isn't ready, try again\n"); + return err; + } + + err = meson_rng_wait_status(cfg_addr, RUN_BIT); + if (err) { + pr_err("Can't get random number, try again\n"); + return err; + } + + return readl_relaxed(base + RNG_S4_DATA); +} + /** * meson_rng_probe() - probe rng device * @@ -59,6 +114,8 @@ static int meson_rng_probe(struct udevice *dev) if (err) return err;
+ pdata->priv = dev_get_driver_data(dev); + return 0; }
@@ -102,9 +159,22 @@ static const struct dm_rng_ops meson_rng_ops = { .read = meson_rng_read, };
+static const struct meson_rng_priv meson_rng_priv = { + .read = meson_common_rng_read, +}; + +static const struct meson_rng_priv meson_rng_priv_s4 = { + .read = meson_s4_rng_read, +}; + static const struct udevice_id meson_rng_match[] = { { .compatible = "amlogic,meson-rng", + .data = (ulong)&meson_rng_priv, + }, + { + .compatible = "amlogic,meson-s4-rng", + .data = (ulong)&meson_rng_priv_s4, }, {}, };
- u32 (*read)(fdt_addr_t base);
while (len) {
size_t step;
if (len >= 4)
- u32 status = 0;
- int ret;
- ret = readl_relaxed_poll_timeout(cfg_addr,
10000);
- if (ret)
return -EBUSY;
- return readl(base);
- void __iomem *cfg_addr = (void *)base + RNG_S4_CFG;
- int err;
- writel_relaxed(readl_relaxed(cfg_addr) | SEED_READY_STS_BIT, cfg_addr);
- err = meson_rng_wait_status(cfg_addr, SEED_READY_STS_BIT);
- if (err) {
return err;
- err = meson_rng_wait_status(cfg_addr, RUN_BIT);
- if (err) {
return err;
- return readl_relaxed(base + RNG_S4_DATA);
- meson_rng_probe() - probe rng device
- pdata->priv = dev_get_driver_data(dev);
- return 0; }
- .read = meson_common_rng_read,
- .read = meson_s4_rng_read,
- static const struct udevice_id meson_rng_match[] = { { .compatible = "amlogic,meson-rng",
}, {}, };.data = (ulong)&meson_rng_priv_s4,
I get: +drivers/rng/meson-rng.c: In function 'meson_rng_probe': +drivers/rng/meson-rng.c:117:21: error: assignment to 'struct meson_rng_priv *' from 'ulong' {aka 'long unsigned int'} makes pointer from integer without a cast [-Werror=int-conversion] + 117 | pdata->priv = dev_get_driver_data(dev);
while building in CI.
Thanks, Neil
Alexey Romanov
neil.armstrong@linaro.org
