[U-Boot] [PATCH 0/3] Enable SECURE BOOT in SPL framework
The patch-set does the following:
1. Enable SECURE BOOT framework in SPL for powerpc/mpc85xx and arm/layerscape platform. 2. Add NAND SECURE BOOT support for powerpc/mpc85xx T104x platform.
Changes PATCH v5->PATCH v6: Added README for SECURE BOOT support in SPL framework. Also incorporated review comments regarding comment style. Also patch [1] has been accepted in upstream, so no dependency.
Changes PATCH v4->PATCH v5: Check for def CONFIG_SPL_DM and ndef CONFIG_SPL_FRAMEWORK instead of def CONFIG_DM macro to include call to dm_init_and_scan(). As dm_init_and_scan() is called as part of common SPL framework, so no need to call it again but in case of powerpc platforms which currently do not use common SPL framework, so need to include this function call here.
Changes PATCH v3->PATCH v4: Generic changes in lib, drivers, common Makefiles removed from this patchset. Rebased this patchset on top of patch [1], so this patchset is dependent on patch [1].
Changes PATCH v2->PATCH v3: Patches rebased
Changes PATCH->PATCH v2: Patches rebased
[1]https://patchwork.ozlabs.org/patch/627664/
Sumit Garg (3): powerpc/mpc85xx: SECURE BOOT- Enable chain of trust in SPL powerpc/mpc85xx: T104x: Add nand secure boot target doc: SPL: Add README for secure boot support
arch/powerpc/cpu/mpc85xx/cpu_init.c | 4 +- arch/powerpc/cpu/mpc85xx/start.S | 12 ++++-- arch/powerpc/cpu/mpc8xxx/fsl_pamu.c | 8 ++++ arch/powerpc/cpu/mpc8xxx/pamu_table.c | 8 ++++ arch/powerpc/include/asm/fsl_secure_boot.h | 41 ++++++++++++++++++- board/freescale/common/fsl_chain_of_trust.c | 56 ++++++++++++++++++++++++++ board/freescale/t104xrdb/t104x_pbi_sb.cfg | 38 +++++++++++++++++ board/freescale/t104xrdb/tlb.c | 15 ++++++- configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig | 30 ++++++++++++++ doc/SPL/README.spl-secure-boot | 18 +++++++++ drivers/crypto/fsl/jr.c | 17 ++++++++ drivers/mtd/nand/fsl_ifc_spl.c | 24 +++++++++++ include/configs/T104xRDB.h | 29 ++++++++++++- include/fsl_validate.h | 7 ++++ 14 files changed, 298 insertions(+), 9 deletions(-) create mode 100644 board/freescale/t104xrdb/t104x_pbi_sb.cfg create mode 100644 configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig create mode 100644 doc/SPL/README.spl-secure-boot
Dear Sumit,
-----Original Message----- From: Sumit Garg [mailto:sumit.garg@nxp.com] Sent: Thursday, July 14, 2016 9:58 PM To: u-boot@lists.denx.de Cc: york sun york.sun@nxp.com; Ruchika Gupta ruchika.gupta@nxp.com; Prabhakar Kushwaha prabhakar.kushwaha@nxp.com; sjg@google.com; teddy.reed@gmail.com; dannenberg@ti.com; trini@konsulko.com; Sumit Garg sumit.garg@nxp.com Subject: [PATCH 0/3] Enable SECURE BOOT in SPL framework
Patch version history is missing from patch header. If you get any comments then please incorporate in next patch-set.
--prabhakar
-----Original Message----- From: Prabhakar Kushwaha Sent: Thursday, July 14, 2016 5:00 PM To: Sumit Garg sumit.garg@nxp.com; u-boot@lists.denx.de Cc: york sun york.sun@nxp.com; Ruchika Gupta ruchika.gupta@nxp.com; sjg@google.com; teddy.reed@gmail.com; dannenberg@ti.com; trini@konsulko.com; Sumit Garg sumit.garg@nxp.com Subject: RE: [PATCH 0/3] Enable SECURE BOOT in SPL framework
Dear Sumit,
--prabhakar
Yes you are right, I missed it. Sure I will incorporate it in next patch set if I get any comments.
--Sumit
As part of Chain of Trust for Secure boot, the SPL U-Boot will validate the next level U-boot image. Add a new function spl_validate_uboot to perform the validation.
Enable hardware crypto operations in SPL using SEC block. In case of Secure Boot, PAMU is not bypassed. For allowing SEC block access to CPC configured as SRAM, configure PAMU.
Reviewed-by: Ruchika Gupta ruchika.gupta@nxp.com Signed-off-by: Aneesh Bansal aneesh.bansal@nxp.com Signed-off-by: Sumit Garg sumit.garg@nxp.com ---
Changes PATCH v5->PATCH v6: Incorporated review comments regarding comment style.
arch/powerpc/cpu/mpc8xxx/fsl_pamu.c | 8 +++++ arch/powerpc/cpu/mpc8xxx/pamu_table.c | 8 +++++ arch/powerpc/include/asm/fsl_secure_boot.h | 31 +++++++++++++++- board/freescale/common/fsl_chain_of_trust.c | 56 +++++++++++++++++++++++++++++ drivers/crypto/fsl/jr.c | 17 +++++++++ drivers/mtd/nand/fsl_ifc_spl.c | 24 +++++++++++++ include/fsl_validate.h | 7 ++++ 7 files changed, 150 insertions(+), 1 deletion(-)
diff --git a/arch/powerpc/cpu/mpc8xxx/fsl_pamu.c b/arch/powerpc/cpu/mpc8xxx/fsl_pamu.c index 9421f1e..ede8e66 100644 --- a/arch/powerpc/cpu/mpc8xxx/fsl_pamu.c +++ b/arch/powerpc/cpu/mpc8xxx/fsl_pamu.c @@ -239,15 +239,23 @@ int pamu_init(void) spaact_size = sizeof(struct paace) * NUM_SPAACT_ENTRIES;
/* Allocate space for Primary PAACT Table */ +#if (defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_PPAACT_ADDR)) + ppaact = (void *)CONFIG_SPL_PPAACT_ADDR; +#else ppaact = memalign(PAMU_TABLE_ALIGNMENT, ppaact_size); if (!ppaact) return -1; +#endif memset(ppaact, 0, ppaact_size);
/* Allocate space for Secondary PAACT Table */ +#if (defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_SPAACT_ADDR)) + sec = (void *)CONFIG_SPL_SPAACT_ADDR; +#else sec = memalign(PAMU_TABLE_ALIGNMENT, spaact_size); if (!sec) return -1; +#endif memset(sec, 0, spaact_size);
ppaact_phys = virt_to_phys((void *)ppaact); diff --git a/arch/powerpc/cpu/mpc8xxx/pamu_table.c b/arch/powerpc/cpu/mpc8xxx/pamu_table.c index 26c5ea4..a8e6f51 100644 --- a/arch/powerpc/cpu/mpc8xxx/pamu_table.c +++ b/arch/powerpc/cpu/mpc8xxx/pamu_table.c @@ -28,6 +28,14 @@ void construct_pamu_addr_table(struct pamu_addr_tbl *tbl, int *num_entries)
i++; #endif +#if (defined(CONFIG_SPL_BUILD) && (CONFIG_SYS_INIT_L3_VADDR)) + tbl->start_addr[i] = + (uint64_t)virt_to_phys((void *)CONFIG_SYS_INIT_L3_VADDR); + tbl->size[i] = 256 * 1024; /* 256K CPC flash */ + tbl->end_addr[i] = tbl->start_addr[i] + tbl->size[i] - 1; + + i++; +#endif debug("PAMU address\t\t\tsize\n"); for (j = 0; j < i ; j++) debug("%llx \t\t\t%llx\n", tbl->start_addr[j], tbl->size[j]); diff --git a/arch/powerpc/include/asm/fsl_secure_boot.h b/arch/powerpc/include/asm/fsl_secure_boot.h index 826f9c9..9420021 100644 --- a/arch/powerpc/include/asm/fsl_secure_boot.h +++ b/arch/powerpc/include/asm/fsl_secure_boot.h @@ -72,6 +72,32 @@
#ifdef CONFIG_CHAIN_OF_TRUST
+#ifdef CONFIG_SPL_BUILD +#define CONFIG_SPL_DM 1 +#define CONFIG_SPL_CRYPTO_SUPPORT +#define CONFIG_SPL_HASH_SUPPORT +#define CONFIG_SPL_RSA +#define CONFIG_SPL_DRIVERS_MISC_SUPPORT +/* + * PPAACT and SPAACT table for PAMU must be placed on DDR after DDR init + * due to space crunch on CPC and thus malloc will not work. + */ +#define CONFIG_SPL_PPAACT_ADDR 0x2e000000 +#define CONFIG_SPL_SPAACT_ADDR 0x2f000000 +#define CONFIG_SPL_JR0_LIODN_S 454 +#define CONFIG_SPL_JR0_LIODN_NS 458 +/* + * Define the key hash for U-Boot here if public/private key pair used to + * sign U-boot are different from the SRK hash put in the fuse + * Example of defining KEY_HASH is + * #define CONFIG_SPL_UBOOT_KEY_HASH \ + * "41066b564c6ffcef40ccbc1e0a5d0d519604000c785d97bbefd25e4d288d1c8b" + * else leave it defined as NULL + */ + +#define CONFIG_SPL_UBOOT_KEY_HASH NULL +#endif /* ifdef CONFIG_SPL_BUILD */ + #define CONFIG_CMD_ESBC_VALIDATE #define CONFIG_CMD_BLOB #define CONFIG_FSL_SEC_MON @@ -82,7 +108,9 @@ #define CONFIG_FSL_CAAM #endif
-/* fsl_setenv_chain_of_trust() must be called from +#ifndef CONFIG_SPL_BUILD +/* + * fsl_setenv_chain_of_trust() must be called from * board_late_init() */ #ifndef CONFIG_BOARD_LATE_INIT @@ -119,5 +147,6 @@ #endif /* #ifdef CONFIG_BOOTSCRIPT_COPY_RAM */
#include <config_fsl_chain_trust.h> +#endif /* #ifndef CONFIG_SPL_BUILD */ #endif /* #ifdef CONFIG_CHAIN_OF_TRUST */ #endif diff --git a/board/freescale/common/fsl_chain_of_trust.c b/board/freescale/common/fsl_chain_of_trust.c index ecfcc82..290536d 100644 --- a/board/freescale/common/fsl_chain_of_trust.c +++ b/board/freescale/common/fsl_chain_of_trust.c @@ -6,7 +6,17 @@
#include <common.h> #include <fsl_validate.h> +#include <fsl_secboot_err.h> #include <fsl_sfp.h> +#include <dm/root.h> + +#ifdef CONFIG_ADDR_MAP +#include <asm/mmu.h> +#endif + +#ifdef CONFIG_FSL_CORENET +#include <asm/fsl_pamu.h> +#endif
#ifdef CONFIG_LS102XA #include <asm/arch/immap_ls102xa.h> @@ -52,6 +62,7 @@ int fsl_check_boot_mode_secure(void) return 0; }
+#ifndef CONFIG_SPL_BUILD int fsl_setenv_chain_of_trust(void) { /* Check Boot Mode @@ -68,3 +79,48 @@ int fsl_setenv_chain_of_trust(void) setenv("bootcmd", CONFIG_CHAIN_BOOT_CMD); return 0; } +#endif + +#ifdef CONFIG_SPL_BUILD +void spl_validate_uboot(uint32_t hdr_addr, uintptr_t img_addr) +{ + int res; + + /* + * Check Boot Mode + * If Boot Mode is Non-Secure, skip validation + */ + if (fsl_check_boot_mode_secure() == 0) + return; + + printf("SPL: Validating U-Boot image\n"); + +#ifdef CONFIG_ADDR_MAP + init_addr_map(); +#endif + +#ifdef CONFIG_FSL_CORENET + if (pamu_init() < 0) + fsl_secboot_handle_error(ERROR_ESBC_PAMU_INIT); +#endif + +#ifdef CONFIG_FSL_CAAM + if (sec_init() < 0) + fsl_secboot_handle_error(ERROR_ESBC_SEC_INIT); +#endif + +/* + * dm_init_and_scan() is called as part of common SPL framework, so no + * need to call it again but in case of powerpc platforms which currently + * do not use common SPL framework, so need to call this function here. + */ +#if defined(CONFIG_SPL_DM) && (!defined(CONFIG_SPL_FRAMEWORK)) + dm_init_and_scan(false); +#endif + res = fsl_secboot_validate(hdr_addr, CONFIG_SPL_UBOOT_KEY_HASH, + &img_addr); + + if (res == 0) + printf("SPL: Validation of U-boot successful\n"); +} +#endif /* ifdef CONFIG_SPL_BUILD */ diff --git a/drivers/crypto/fsl/jr.c b/drivers/crypto/fsl/jr.c index 510fa4e..4a8cc32 100644 --- a/drivers/crypto/fsl/jr.c +++ b/drivers/crypto/fsl/jr.c @@ -599,10 +599,27 @@ int sec_init_idx(uint8_t sec_idx) sec_out32(&sec->mcfgr, mcr);
#ifdef CONFIG_FSL_CORENET +#ifdef CONFIG_SPL_BUILD + /* + * For SPL Build, Set the Liodns in SEC JR0 for + * creating PAMU entries corresponding to these. + * For normal build, these are set in set_liodns(). + */ + liodn_ns = CONFIG_SPL_JR0_LIODN_NS & JRNSLIODN_MASK; + liodn_s = CONFIG_SPL_JR0_LIODN_S & JRSLIODN_MASK; + + liodnr = sec_in32(&sec->jrliodnr[0].ls) & + ~(JRNSLIODN_MASK | JRSLIODN_MASK); + liodnr = liodnr | + (liodn_ns << JRNSLIODN_SHIFT) | + (liodn_s << JRSLIODN_SHIFT); + sec_out32(&sec->jrliodnr[0].ls, liodnr); +#else liodnr = sec_in32(&sec->jrliodnr[0].ls); liodn_ns = (liodnr & JRNSLIODN_MASK) >> JRNSLIODN_SHIFT; liodn_s = (liodnr & JRSLIODN_MASK) >> JRSLIODN_SHIFT; #endif +#endif
ret = jr_init(sec_idx); if (ret < 0) { diff --git a/drivers/mtd/nand/fsl_ifc_spl.c b/drivers/mtd/nand/fsl_ifc_spl.c index cbeb74a..4e49a4e 100644 --- a/drivers/mtd/nand/fsl_ifc_spl.c +++ b/drivers/mtd/nand/fsl_ifc_spl.c @@ -11,6 +11,9 @@ #include <asm/io.h> #include <fsl_ifc.h> #include <linux/mtd/nand.h> +#ifdef CONFIG_CHAIN_OF_TRUST +#include <fsl_validate.h> +#endif
static inline int is_blank(uchar *addr, int page_size) { @@ -268,6 +271,27 @@ void nand_boot(void) */ flush_cache(CONFIG_SYS_NAND_U_BOOT_DST, CONFIG_SYS_NAND_U_BOOT_SIZE); #endif + +#ifdef CONFIG_CHAIN_OF_TRUST + /* + * U-Boot header is appended at end of U-boot image, so + * calculate U-boot header address using U-boot header size. + */ +#define CONFIG_U_BOOT_HDR_ADDR \ + ((CONFIG_SYS_NAND_U_BOOT_START + \ + CONFIG_SYS_NAND_U_BOOT_SIZE) - \ + CONFIG_U_BOOT_HDR_SIZE) + spl_validate_uboot(CONFIG_U_BOOT_HDR_ADDR, + CONFIG_SYS_NAND_U_BOOT_START); + /* + * In case of failure in validation, spl_validate_uboot would + * not return back in case of Production environment with ITS=1. + * Thus U-Boot will not start. + * In Development environment (ITS=0 and SB_EN=1), the function + * may return back in case of non-fatal failures. + */ +#endif + uboot = (void *)CONFIG_SYS_NAND_U_BOOT_START; uboot(); } diff --git a/include/fsl_validate.h b/include/fsl_validate.h index a71e1ce..c350938 100644 --- a/include/fsl_validate.h +++ b/include/fsl_validate.h @@ -254,4 +254,11 @@ int fsl_secboot_blob_decap(cmd_tbl_t *cmdtp, int flag, int argc,
int fsl_check_boot_mode_secure(void); int fsl_setenv_chain_of_trust(void); + +/* + * This function is used to validate the main U-boot binary from + * SPL just before passing control to it using QorIQ Trust + * Architecture header (appended to U-boot image). + */ +void spl_validate_uboot(uint32_t hdr_addr, uintptr_t img_addr); #endif
For mpc85xx SoCs, the core begins execution from address 0xFFFFFFFC. In non-secure boot scenario from NAND, this address will map to CPC configured as SRAM. But in case of secure boot, this default address always maps to IBR (Internal Boot ROM). The IBR code requires that the bootloader(U-boot) must lie in 0 to 3.5G address space i.e. 0x0 - 0xDFFFFFFF.
For secure boot target from NAND, the text base for SPL is kept same as non-secure boot target i.e. 0xFFFx_xxxx but the SPL U-boot binary will be copied to CPC configured as SRAM with address in 0-3.5G(0xBFFC_0000) As a the virtual and physical address of CPC would be different. The virtual address 0xFFFx_xxxx needs to be mapped to physical address 0xBFFx_xxxx.
Create a new PBI file to configure CPC as SRAM with address 0xBFFC0000 and update DCFG SCRTACH1 register with location of Header required for secure boot.
The changes are similar to commit 467a40dfe35f48d830f01a72617207d03ca85b4d powerpc/mpc85xx: SECURE BOOT- NAND secure boot target for P3041
While P3041 has a 1MB CPC and does not require SPL. On T104x, CPC is only 256K and thus SPL framework is used. The changes are only applicable for SPL U-Boot running out of CPC SRAM and not the next level U-Boot loaded on DDR.
Reviewed-by: Ruchika Gupta ruchika.gupta@nxp.com Reviewed-by: Simon Glass sjg@chromium.org Signed-off-by: Aneesh Bansal aneesh.bansal@nxp.com Signed-off-by: Sumit Garg sumit.garg@nxp.com ---
Changes PATCH v4->PATCH v5: No change.
Changes PATCH v3->PATCH v4: No change.
arch/powerpc/cpu/mpc85xx/cpu_init.c | 4 +-- arch/powerpc/cpu/mpc85xx/start.S | 12 ++++++-- arch/powerpc/include/asm/fsl_secure_boot.h | 10 ++++++- board/freescale/t104xrdb/t104x_pbi_sb.cfg | 38 ++++++++++++++++++++++++++ board/freescale/t104xrdb/tlb.c | 15 +++++++++- configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig | 30 ++++++++++++++++++++ include/configs/T104xRDB.h | 29 +++++++++++++++++++- 7 files changed, 130 insertions(+), 8 deletions(-) create mode 100644 board/freescale/t104xrdb/t104x_pbi_sb.cfg create mode 100644 configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig
diff --git a/arch/powerpc/cpu/mpc85xx/cpu_init.c b/arch/powerpc/cpu/mpc85xx/cpu_init.c index 61f5639..ace4279 100644 --- a/arch/powerpc/cpu/mpc85xx/cpu_init.c +++ b/arch/powerpc/cpu/mpc85xx/cpu_init.c @@ -439,7 +439,7 @@ ulong cpu_init_f(void) #ifdef CONFIG_SYS_DCSRBAR_PHYS ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); #endif -#if defined(CONFIG_SECURE_BOOT) +#if defined(CONFIG_SECURE_BOOT) && !defined(CONFIG_SYS_RAMBOOT) struct law_entry law; #endif #ifdef CONFIG_MPC8548 @@ -459,7 +459,7 @@ ulong cpu_init_f(void) disable_tlb(14); disable_tlb(15);
-#if defined(CONFIG_SECURE_BOOT) +#if defined(CONFIG_SECURE_BOOT) && !defined(CONFIG_SYS_RAMBOOT) /* Disable the LAW created for NOR flash by the PBI commands */ law = find_law(CONFIG_SYS_PBI_FLASH_BASE); if (law.index != -1) diff --git a/arch/powerpc/cpu/mpc85xx/start.S b/arch/powerpc/cpu/mpc85xx/start.S index 4c51225..c3e1234 100644 --- a/arch/powerpc/cpu/mpc85xx/start.S +++ b/arch/powerpc/cpu/mpc85xx/start.S @@ -1069,17 +1069,23 @@ create_init_ram_area: #elif !defined(CONFIG_SYS_RAMBOOT) && defined(CONFIG_SECURE_BOOT) /* create a temp mapping in AS = 1 for Flash mapping * created by PBL for ISBC code - */ + */ create_tlb1_entry 15, \ 1, BOOKE_PAGESZ_1M, \ CONFIG_SYS_MONITOR_BASE & 0xfff00000, MAS2_I|MAS2_G, \ CONFIG_SYS_PBI_FLASH_WINDOW & 0xfff00000, MAS3_SX|MAS3_SW|MAS3_SR, \ 0, r6
-#elif defined(CONFIG_RAMBOOT_PBL) && defined(CONFIG_SECURE_BOOT) +/* + * For Targets without CONFIG_SPL like P3, P5 + * and for targets with CONFIG_SPL like T1, T2, T4, only for + * u-boot-spl i.e. CONFIG_SPL_BUILD + */ +#elif defined(CONFIG_RAMBOOT_PBL) && defined(CONFIG_SECURE_BOOT) && \ + (!defined(CONFIG_SPL) || defined(CONFIG_SPL_BUILD)) /* create a temp mapping in AS = 1 for mapping CONFIG_SYS_MONITOR_BASE * to L3 Address configured by PBL for ISBC code - */ + */ create_tlb1_entry 15, \ 1, BOOKE_PAGESZ_1M, \ CONFIG_SYS_MONITOR_BASE & 0xfff00000, MAS2_I|MAS2_G, \ diff --git a/arch/powerpc/include/asm/fsl_secure_boot.h b/arch/powerpc/include/asm/fsl_secure_boot.h index 9420021..2e2d565 100644 --- a/arch/powerpc/include/asm/fsl_secure_boot.h +++ b/arch/powerpc/include/asm/fsl_secure_boot.h @@ -35,7 +35,9 @@ defined(CONFIG_T104xD4RDB) || \ defined(CONFIG_PPC_T1023) || \ defined(CONFIG_PPC_T1024) +#ifndef CONFIG_SYS_RAMBOOT #define CONFIG_SYS_CPC_REINIT_F +#endif #define CONFIG_KEY_REVOCATION #undef CONFIG_SYS_INIT_L3_ADDR #define CONFIG_SYS_INIT_L3_ADDR 0xbff00000 @@ -43,7 +45,13 @@
#if defined(CONFIG_RAMBOOT_PBL) #undef CONFIG_SYS_INIT_L3_ADDR -#define CONFIG_SYS_INIT_L3_ADDR 0xbff00000 +#ifdef CONFIG_SYS_INIT_L3_VADDR +#define CONFIG_SYS_INIT_L3_ADDR \ + (CONFIG_SYS_INIT_L3_VADDR & ~0xFFF00000) | \ + 0xbff00000 +#else +#define CONFIG_SYS_INIT_L3_ADDR 0xbff00000 +#endif #endif
#if defined(CONFIG_C29XPCIE) diff --git a/board/freescale/t104xrdb/t104x_pbi_sb.cfg b/board/freescale/t104xrdb/t104x_pbi_sb.cfg new file mode 100644 index 0000000..98dc8e4 --- /dev/null +++ b/board/freescale/t104xrdb/t104x_pbi_sb.cfg @@ -0,0 +1,38 @@ +#PBI commands +#Software Workaround for errata A-007662 to train PCIe2 controller in Gen2 speed +09250100 00000400 +09250108 00002000 +#Software Workaround for errata A-008007 to reset PVR register +09000010 0000000b +09000014 c0000000 +09000018 81d00017 +89020400 a1000000 +091380c0 000f0000 +89020400 00000000 +#Initialize CPC1 +09010000 00200400 +09138000 00000000 +091380c0 00000100 +#Configure CPC1 as 256KB SRAM +09010100 00000000 +09010104 bffc0007 +09010f00 081e000d +09010000 80000000 +#Configure LAW for CPC1 +09000cd0 00000000 +09000cd4 bffc0000 +09000cd8 81000011 +#Configure alternate space +09000010 00000000 +09000014 bf000000 +09000018 81000000 +#Configure SPI controller +09110000 80000403 +09110020 2d170008 +09110024 00100008 +09110028 00100008 +0911002c 00100008 +#Flush PBL data +091380c0 000FFFFF +090e0200 bffd0000 +091380c0 000FFFFF diff --git a/board/freescale/t104xrdb/tlb.c b/board/freescale/t104xrdb/tlb.c index 95c15aa..7c0511e 100644 --- a/board/freescale/t104xrdb/tlb.c +++ b/board/freescale/t104xrdb/tlb.c @@ -28,7 +28,8 @@ struct fsl_e_tlb_entry tlb_table[] = {
/* TLB 1 */ /* *I*** - Covers boot page */ -#if defined(CONFIG_SYS_RAMBOOT) && defined(CONFIG_SYS_INIT_L3_ADDR) +#if defined(CONFIG_SYS_RAMBOOT) && defined(CONFIG_SYS_INIT_L3_ADDR) && \ + !defined(CONFIG_SECURE_BOOT) /* * *I*G - L3SRAM. When L3 is used as 256K SRAM, the address of the * SRAM is at 0xfffc0000, it covered the 0xfffff000. @@ -36,6 +37,18 @@ struct fsl_e_tlb_entry tlb_table[] = { SET_TLB_ENTRY(1, CONFIG_SYS_INIT_L3_ADDR, CONFIG_SYS_INIT_L3_ADDR, MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, 0, 0, BOOKE_PAGESZ_256K, 1), + +#elif defined(CONFIG_SECURE_BOOT) && defined(CONFIG_SPL_BUILD) + /* + * *I*G - L3SRAM. When L3 is used as 256K SRAM, in case of Secure Boot + * the physical address of the SRAM is at 0xbffc0000, + * and virtual address is 0xfffc0000 + */ + + SET_TLB_ENTRY(1, CONFIG_SYS_INIT_L3_VADDR, + CONFIG_SYS_INIT_L3_ADDR, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 0, BOOKE_PAGESZ_256K, 1), #else SET_TLB_ENTRY(1, 0xfffff000, 0xfffff000, MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, diff --git a/configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig b/configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig new file mode 100644 index 0000000..2e16255 --- /dev/null +++ b/configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig @@ -0,0 +1,30 @@ +CONFIG_PPC=y +CONFIG_MPC85xx=y +CONFIG_TARGET_T104XRDB=y +CONFIG_SPL=y +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_OF_BOARD_SETUP=y +CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_SYS_EXTRA_OPTIONS="PPC_T1042,T1042RDB_PI,RAMBOOT_PBL,SPL_FSL_PBL,NAND,SECURE_BOOT" +CONFIG_BOOTDELAY=0 +CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MMC=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_NETDEVICES=y +CONFIG_E1000=y +CONFIG_SYS_NS16550=y +CONFIG_FSL_ESPI=y +CONFIG_OF_LIBFDT=y +CONFIG_RSA=y +CONFIG_DM=y diff --git a/include/configs/T104xRDB.h b/include/configs/T104xRDB.h index a8f4f74..2ec1962 100644 --- a/include/configs/T104xRDB.h +++ b/include/configs/T104xRDB.h @@ -18,7 +18,14 @@ #include <asm/config_mpc85xx.h>
#ifdef CONFIG_RAMBOOT_PBL + +#ifndef CONFIG_SECURE_BOOT #define CONFIG_SYS_FSL_PBL_PBI $(SRCTREE)/board/freescale/t104xrdb/t104x_pbi.cfg +#else +#define CONFIG_SYS_FSL_PBL_PBI \ + $(SRCTREE)/board/freescale/t104xrdb/t104x_pbi_sb.cfg +#endif + #ifdef CONFIG_T1040RDB #define CONFIG_SYS_FSL_PBL_RCW $(SRCTREE)/board/freescale/t104xrdb/t1040_rcw.cfg #endif @@ -62,7 +69,17 @@ $(SRCTREE)/board/freescale/t104xrdb/t1042d4_rcw.cfg
#ifdef CONFIG_NAND #define CONFIG_SPL_NAND_SUPPORT +#ifdef CONFIG_SECURE_BOOT +#define CONFIG_U_BOOT_HDR_SIZE (16 << 10) +/* + * HDR would be appended at end of image and copied to DDR along + * with U-Boot image. + */ +#define CONFIG_SYS_NAND_U_BOOT_SIZE ((768 << 10) + \ + CONFIG_U_BOOT_HDR_SIZE) +#else #define CONFIG_SYS_NAND_U_BOOT_SIZE (768 << 10) +#endif #define CONFIG_SYS_NAND_U_BOOT_DST 0x30000000 #define CONFIG_SYS_NAND_U_BOOT_START 0x30000000 #define CONFIG_SYS_NAND_U_BOOT_OFFS (256 << 10) @@ -161,6 +178,10 @@ $(SRCTREE)/board/freescale/t104xrdb/t1042d4_rcw.cfg #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_ENV_OFFSET (512 * 0x800) #elif defined(CONFIG_NAND) +#ifdef CONFIG_SECURE_BOOT +#define CONFIG_RAMBOOT_NAND +#define CONFIG_BOOTSCRIPT_COPY_RAM +#endif #define CONFIG_SYS_EXTRA_ENV_RELOC #define CONFIG_ENV_IS_IN_NAND #define CONFIG_ENV_SIZE 0x2000 @@ -202,8 +223,14 @@ $(SRCTREE)/board/freescale/t104xrdb/t1042d4_rcw.cfg * Config the L3 Cache as L3 SRAM */ #define CONFIG_SYS_INIT_L3_ADDR 0xFFFC0000 +/* + * For Secure Boot CONFIG_SYS_INIT_L3_ADDR will be redefined and hence + * Physical address (CONFIG_SYS_INIT_L3_ADDR) and virtual address + * (CONFIG_SYS_INIT_L3_VADDR) will be different. + */ +#define CONFIG_SYS_INIT_L3_VADDR 0xFFFC0000 #define CONFIG_SYS_L3_SIZE 256 << 10 -#define CONFIG_SPL_GD_ADDR (CONFIG_SYS_INIT_L3_ADDR + 32 * 1024) +#define CONFIG_SPL_GD_ADDR (CONFIG_SYS_INIT_L3_VADDR + 32 * 1024) #ifdef CONFIG_RAMBOOT_PBL #define CONFIG_ENV_ADDR (CONFIG_SPL_GD_ADDR + 4 * 1024) #endif
Adds information regarding SPL handling validation process of main u-boot image on power/mpc85xx and arm/layerscape platforms.
doc/SPL/README.spl-secure-boot | 18 ++++++++++++++++++ 1 file changed, 18 insertions(+) create mode 100644 doc/SPL/README.spl-secure-boot
diff --git a/doc/SPL/README.spl-secure-boot b/doc/SPL/README.spl-secure-boot new file mode 100644 index 0000000..f2f8d78 --- /dev/null +++ b/doc/SPL/README.spl-secure-boot @@ -0,0 +1,18 @@ +Overview of SPL verified boot on powerpc/mpc85xx & arm/layerscape platforms +=========================================================================== + +Introduction +------------ + +This document provides an overview of how SPL verified boot works on powerpc/ +mpc85xx & arm/layerscape platforms. + +Methodology +----------- + +The SPL image is responsible for loading the next stage boot loader, which is +the main u-boot image. For secure boot process on these platforms ROM verifies +SPL image, so to continue chain of trust SPL image verifies U-boot image using +spl_validate_uboot(). This function uses QorIQ Trust Architecture header +(appended to U-boot image) to validate the U-boot binary just before passing +control to it.
Please use "U-Boot"
This seems a bit brief. Are there instructions on how to actually set it up?
Prabhakar Kushwaha
Sumit Garg
