[U-Boot] [U-Boot PATCH V2 0/8] introduce Rockchip rockusb
rockusb is a protocol run between host pc and device. it help people get device info, flash image to device. this patch implement rockusb on device side
Eddie Cai (8): usb: ums: split macro and data struct in f_mass_storage.c usb: ums: merge storage_common.c into f_mass_storage.c usb: ums: remove static declaration of some ums functions usb: ums: add functions to set and get usb interface descriptor usb: ums: add do_extra_command cmd: add rockusb command rockchip: config: enable rockusb support on rk3288 based board rockusb: add a simple readme
cmd/Kconfig | 5 + cmd/Makefile | 1 + cmd/rockusb.c | 383 ++++++++++++++++++++++++++++++++++++ configs/evb-rk3288_defconfig | 2 + configs/fennec-rk3288_defconfig | 1 + configs/firefly-rk3288_defconfig | 1 + configs/miqi-rk3288_defconfig | 1 + configs/popmetal-rk3288_defconfig | 1 + configs/rock2_defconfig | 2 + configs/sandbox_defconfig | 1 + configs/tinker-rk3288_defconfig | 1 + doc/README.rockusb | 35 ++++ drivers/usb/gadget/f_mass_storage.c | 356 ++++++++++++++++++++++----------- drivers/usb/gadget/storage_common.c | 238 ---------------------- include/f_mass_storage.h | 117 +++++++++++ 15 files changed, 797 insertions(+), 348 deletions(-) create mode 100644 cmd/rockusb.c create mode 100644 doc/README.rockusb delete mode 100644 drivers/usb/gadget/storage_common.c
split the macro and data struct in f_mass_storage.c to f_mass_storage.h
Signed-off-by: Eddie Cai eddie.cai.linux@gmail.com --- drivers/usb/gadget/f_mass_storage.c | 108 --------------------------------- include/f_mass_storage.h | 116 ++++++++++++++++++++++++++++++++++++ 2 files changed, 116 insertions(+), 108 deletions(-)
diff --git a/drivers/usb/gadget/f_mass_storage.c b/drivers/usb/gadget/f_mass_storage.c index 1ecb92a..7164655 100644 --- a/drivers/usb/gadget/f_mass_storage.c +++ b/drivers/usb/gadget/f_mass_storage.c @@ -274,15 +274,6 @@ static const char fsg_string_interface[] = "Mass Storage";
-#define GFP_ATOMIC ((gfp_t) 0) -#define PAGE_CACHE_SHIFT 12 -#define PAGE_CACHE_SIZE (1 << PAGE_CACHE_SHIFT) -#define kthread_create(...) __builtin_return_address(0) -#define wait_for_completion(...) do {} while (0) - -struct kref {int x; }; -struct completion {int x; }; - inline void set_bit(int nr, volatile void *addr) { int mask; @@ -303,105 +294,6 @@ inline void clear_bit(int nr, volatile void *addr) *a &= ~mask; }
-struct fsg_dev; -struct fsg_common; - -/* Data shared by all the FSG instances. */ -struct fsg_common { - struct usb_gadget *gadget; - struct fsg_dev *fsg, *new_fsg; - - struct usb_ep *ep0; /* Copy of gadget->ep0 */ - struct usb_request *ep0req; /* Copy of cdev->req */ - unsigned int ep0_req_tag; - - struct fsg_buffhd *next_buffhd_to_fill; - struct fsg_buffhd *next_buffhd_to_drain; - struct fsg_buffhd buffhds[FSG_NUM_BUFFERS]; - - int cmnd_size; - u8 cmnd[MAX_COMMAND_SIZE]; - - unsigned int nluns; - unsigned int lun; - struct fsg_lun luns[FSG_MAX_LUNS]; - - unsigned int bulk_out_maxpacket; - enum fsg_state state; /* For exception handling */ - unsigned int exception_req_tag; - - enum data_direction data_dir; - u32 data_size; - u32 data_size_from_cmnd; - u32 tag; - u32 residue; - u32 usb_amount_left; - - unsigned int can_stall:1; - unsigned int free_storage_on_release:1; - unsigned int phase_error:1; - unsigned int short_packet_received:1; - unsigned int bad_lun_okay:1; - unsigned int running:1; - - int thread_wakeup_needed; - struct completion thread_notifier; - struct task_struct *thread_task; - - /* Callback functions. */ - const struct fsg_operations *ops; - /* Gadget's private data. */ - void *private_data; - - const char *vendor_name; /* 8 characters or less */ - const char *product_name; /* 16 characters or less */ - u16 release; - - /* Vendor (8 chars), product (16 chars), release (4 - * hexadecimal digits) and NUL byte */ - char inquiry_string[8 + 16 + 4 + 1]; - - struct kref ref; -}; - -struct fsg_config { - unsigned nluns; - struct fsg_lun_config { - const char *filename; - char ro; - char removable; - char cdrom; - char nofua; - } luns[FSG_MAX_LUNS]; - - /* Callback functions. */ - const struct fsg_operations *ops; - /* Gadget's private data. */ - void *private_data; - - const char *vendor_name; /* 8 characters or less */ - const char *product_name; /* 16 characters or less */ - - char can_stall; -}; - -struct fsg_dev { - struct usb_function function; - struct usb_gadget *gadget; /* Copy of cdev->gadget */ - struct fsg_common *common; - - u16 interface_number; - - unsigned int bulk_in_enabled:1; - unsigned int bulk_out_enabled:1; - - unsigned long atomic_bitflags; -#define IGNORE_BULK_OUT 0 - - struct usb_ep *bulk_in; - struct usb_ep *bulk_out; -}; -
static inline int __fsg_is_set(struct fsg_common *common, const char *func, unsigned line) diff --git a/include/f_mass_storage.h b/include/f_mass_storage.h index 679f242..620af06 100644 --- a/include/f_mass_storage.h +++ b/include/f_mass_storage.h @@ -390,4 +390,120 @@ fsg_otg_desc = { }; #endif
+ + + + +#define GFP_ATOMIC ((gfp_t) 0) +#define PAGE_CACHE_SHIFT 12 +#define PAGE_CACHE_SIZE (1 << PAGE_CACHE_SHIFT) +#define kthread_create(...) __builtin_return_address(0) +#define wait_for_completion(...) do {} while (0) + +struct kref {int x; }; +struct completion {int x; }; + + +struct fsg_dev; +struct fsg_common; + +/* Data shared by all the FSG instances. */ +struct fsg_common { + struct usb_gadget *gadget; + struct fsg_dev *fsg, *new_fsg; + + struct usb_ep *ep0; /* Copy of gadget->ep0 */ + struct usb_request *ep0req; /* Copy of cdev->req */ + unsigned int ep0_req_tag; + + struct fsg_buffhd *next_buffhd_to_fill; + struct fsg_buffhd *next_buffhd_to_drain; + struct fsg_buffhd buffhds[FSG_NUM_BUFFERS]; + + int cmnd_size; + u8 cmnd[MAX_COMMAND_SIZE]; + + unsigned int nluns; + unsigned int lun; + struct fsg_lun luns[FSG_MAX_LUNS]; + + unsigned int bulk_out_maxpacket; + enum fsg_state state; /* For exception handling */ + unsigned int exception_req_tag; + + enum data_direction data_dir; + u32 data_size; + u32 data_size_from_cmnd; + u32 tag; + u32 residue; + u32 usb_amount_left; + + unsigned int can_stall:1; + unsigned int free_storage_on_release:1; + unsigned int phase_error:1; + unsigned int short_packet_received:1; + unsigned int bad_lun_okay:1; + unsigned int running:1; + + int thread_wakeup_needed; + struct completion thread_notifier; + struct task_struct *thread_task; + + /* Callback functions. */ + const struct fsg_operations *ops; + /* Gadget's private data. */ + void *private_data; + + const char *vendor_name; /* 8 characters or less */ + const char *product_name; /* 16 characters or less */ + u16 release; + + /* Vendor (8 chars), product (16 chars), release (4 + * hexadecimal digits) and NUL byte */ + char inquiry_string[8 + 16 + 4 + 1]; + + struct kref ref; +}; + +struct fsg_config { + unsigned nluns; + struct fsg_lun_config { + const char *filename; + char ro; + char removable; + char cdrom; + char nofua; + } luns[FSG_MAX_LUNS]; + + /* Callback functions. */ + const struct fsg_operations *ops; + /* Gadget's private data. */ + void *private_data; + + const char *vendor_name; /* 8 characters or less */ + const char *product_name; /* 16 characters or less */ + + char can_stall; +}; + +struct fsg_dev { + struct usb_function function; + struct usb_gadget *gadget; /* Copy of cdev->gadget */ + struct fsg_common *common; + + u16 interface_number; + + unsigned int bulk_in_enabled:1; + unsigned int bulk_out_enabled:1; + + unsigned long atomic_bitflags; +#define IGNORE_BULK_OUT 0 + + struct usb_ep *bulk_in; + struct usb_ep *bulk_out; +}; + #endif /* __F_MASS_STORAGE_H_ */ + + +
Hi Eddie
Please add a cover letter that describe your changes. Comments follow
int cmnd_size;
unsigned int nluns;
unsigned int lun;
u32 data_size;
u32 tag;
u32 residue;
void *private_data;
u16 release;
struct kref ref;
unsigned nluns;
char ro;
char removable;
char cdrom;
char nofua;
void *private_data;
char can_stall;
-struct fsg_dev {
Remove empty lines
ditto
int cmnd_size;
unsigned int nluns;
unsigned int lun;
u32 data_size;
u32 tag;
u32 residue;
void *private_data;
u16 release;
struct kref ref;
unsigned nluns;
char ro;
char removable;
char cdrom;
char nofua;
void *private_data;
char can_stall;
+struct fsg_dev {
ditto
Michael
-- 2.10.2
storage_common.c is only used by f_mass_storage. so merge it.
Signed-off-by: Eddie Cai eddie.cai.linux@gmail.com --- drivers/usb/gadget/f_mass_storage.c | 222 ++++++++++++++++++++++++++++++++- drivers/usb/gadget/storage_common.c | 238 ------------------------------------ 2 files changed, 221 insertions(+), 239 deletions(-) delete mode 100644 drivers/usb/gadget/storage_common.c
diff --git a/drivers/usb/gadget/f_mass_storage.c b/drivers/usb/gadget/f_mass_storage.c index 7164655..eb2ff82 100644 --- a/drivers/usb/gadget/f_mass_storage.c +++ b/drivers/usb/gadget/f_mass_storage.c @@ -270,7 +270,227 @@ static const char fsg_string_interface[] = "Mass Storage"; #define FSG_NO_OTG 1 #define FSG_NO_INTR_EP 1
-#include "storage_common.c" +#include <f_mass_storage.h> + +/* There is only one interface. */ + +static struct usb_interface_descriptor +fsg_intf_desc = { + .bLength = sizeof(fsg_intf_desc), + .bDescriptorType = USB_DT_INTERFACE, + + .bNumEndpoints = 2, /* Adjusted during fsg_bind() */ + .bInterfaceClass = USB_CLASS_MASS_STORAGE, + .bInterfaceSubClass = USB_SC_SCSI, /* Adjusted during fsg_bind() */ + .bInterfaceProtocol = USB_PR_BULK, /* Adjusted during fsg_bind() */ + .iInterface = FSG_STRING_INTERFACE, +}; + +/* + * Three full-speed endpoint descriptors: bulk-in, bulk-out, and + * interrupt-in. + */ + +static struct usb_endpoint_descriptor +fsg_fs_bulk_in_desc = { + .bLength = USB_DT_ENDPOINT_SIZE, + .bDescriptorType = USB_DT_ENDPOINT, + + .bEndpointAddress = USB_DIR_IN, + .bmAttributes = USB_ENDPOINT_XFER_BULK, + /* wMaxPacketSize set by autoconfiguration */ +}; + +static struct usb_endpoint_descriptor +fsg_fs_bulk_out_desc = { + .bLength = USB_DT_ENDPOINT_SIZE, + .bDescriptorType = USB_DT_ENDPOINT, + + .bEndpointAddress = USB_DIR_OUT, + .bmAttributes = USB_ENDPOINT_XFER_BULK, + /* wMaxPacketSize set by autoconfiguration */ +}; + +#ifndef FSG_NO_INTR_EP + +static struct usb_endpoint_descriptor +fsg_fs_intr_in_desc = { + .bLength = USB_DT_ENDPOINT_SIZE, + .bDescriptorType = USB_DT_ENDPOINT, + + .bEndpointAddress = USB_DIR_IN, + .bmAttributes = USB_ENDPOINT_XFER_INT, + .wMaxPacketSize = cpu_to_le16(2), + .bInterval = 32, /* frames -> 32 ms */ +}; + +#ifndef FSG_NO_OTG +# define FSG_FS_FUNCTION_PRE_EP_ENTRIES 2 +#else +# define FSG_FS_FUNCTION_PRE_EP_ENTRIES 1 +#endif + +#endif + +static struct usb_descriptor_header *fsg_fs_function[] = { +#ifndef FSG_NO_OTG + (struct usb_descriptor_header *)&fsg_otg_desc, +#endif + (struct usb_descriptor_header *)&fsg_intf_desc, + (struct usb_descriptor_header *)&fsg_fs_bulk_in_desc, + (struct usb_descriptor_header *)&fsg_fs_bulk_out_desc, +#ifndef FSG_NO_INTR_EP + (struct usb_descriptor_header *)&fsg_fs_intr_in_desc, +#endif + NULL, +}; + +/* + * USB 2.0 devices need to expose both high speed and full speed + * descriptors, unless they only run at full speed. + * + * That means alternate endpoint descriptors (bigger packets) + * and a "device qualifier" ... plus more construction options + * for the configuration descriptor. + */ +static struct usb_endpoint_descriptor +fsg_hs_bulk_in_desc = { + .bLength = USB_DT_ENDPOINT_SIZE, + .bDescriptorType = USB_DT_ENDPOINT, + + /* bEndpointAddress copied from fs_bulk_in_desc during fsg_bind() */ + .bmAttributes = USB_ENDPOINT_XFER_BULK, + .wMaxPacketSize = cpu_to_le16(512), +}; + +static struct usb_endpoint_descriptor +fsg_hs_bulk_out_desc = { + .bLength = USB_DT_ENDPOINT_SIZE, + .bDescriptorType = USB_DT_ENDPOINT, + + /* bEndpointAddress copied from fs_bulk_out_desc during fsg_bind() */ + .bmAttributes = USB_ENDPOINT_XFER_BULK, + .wMaxPacketSize = cpu_to_le16(512), + .bInterval = 1, /* NAK every 1 uframe */ +}; + +#ifndef FSG_NO_INTR_EP + +static struct usb_endpoint_descriptor +fsg_hs_intr_in_desc = { + .bLength = USB_DT_ENDPOINT_SIZE, + .bDescriptorType = USB_DT_ENDPOINT, + + /* bEndpointAddress copied from fs_intr_in_desc during fsg_bind() */ + .bmAttributes = USB_ENDPOINT_XFER_INT, + .wMaxPacketSize = cpu_to_le16(2), + .bInterval = 9, /* 2**(9-1) = 256 uframes -> 32 ms */ +}; + +#ifndef FSG_NO_OTG +# define FSG_HS_FUNCTION_PRE_EP_ENTRIES 2 +#else +# define FSG_HS_FUNCTION_PRE_EP_ENTRIES 1 +#endif + +#endif + +static struct usb_descriptor_header *fsg_hs_function[] = { +#ifndef FSG_NO_OTG + (struct usb_descriptor_header *)&fsg_otg_desc, +#endif + (struct usb_descriptor_header *)&fsg_intf_desc, + (struct usb_descriptor_header *)&fsg_hs_bulk_in_desc, + (struct usb_descriptor_header *)&fsg_hs_bulk_out_desc, +#ifndef FSG_NO_INTR_EP + (struct usb_descriptor_header *)&fsg_hs_intr_in_desc, +#endif + NULL, +}; + +/* Maxpacket and other transfer characteristics vary by speed. */ +static struct usb_endpoint_descriptor *fsg_ep_desc( + struct usb_gadget *g, + struct usb_endpoint_descriptor *fs, + struct usb_endpoint_descriptor *hs) +{ + if (gadget_is_dualspeed(g) && g->speed == USB_SPEED_HIGH) + return hs; + return fs; +} + +/* Static strings, in UTF-8 (for simplicity we use only ASCII characters) */ +static struct usb_string fsg_strings[] = { +#ifndef FSG_NO_DEVICE_STRINGS + {FSG_STRING_MANUFACTURER, fsg_string_manufacturer}, + {FSG_STRING_PRODUCT, fsg_string_product}, + {FSG_STRING_SERIAL, fsg_string_serial}, + {FSG_STRING_CONFIG, fsg_string_config}, +#endif + {FSG_STRING_INTERFACE, fsg_string_interface}, + {} +}; + +static struct usb_gadget_strings fsg_stringtab = { + .language = 0x0409, /* en-us */ + .strings = fsg_strings, +}; + +/*-------------------------------------------------------------------------*/ + +/* + * If the next two routines are called while the gadget is registered, + * the caller must own fsg->filesem for writing. + */ + +static int fsg_lun_open(struct fsg_lun *curlun, unsigned int num_sectors, + const char *filename) +{ + int ro; + + /* R/W if we can, R/O if we must */ + ro = curlun->initially_ro; + + curlun->ro = ro; + curlun->file_length = num_sectors << 9; + curlun->num_sectors = num_sectors; + debug("open backing file: %s\n", filename); + + return 0; +} + +static void fsg_lun_close(struct fsg_lun *curlun) +{ +} + +/*-------------------------------------------------------------------------*/ + +/* + * Sync the file data, don't bother with the metadata. + * This code was copied from fs/buffer.c:sys_fdatasync(). + */ +static int fsg_lun_fsync_sub(struct fsg_lun *curlun) +{ + return 0; +} + +static void store_cdrom_address(u8 *dest, int msf, u32 addr) +{ + if (msf) { + /* Convert to Minutes-Seconds-Frames */ + addr >>= 2; /* Convert to 2048-byte frames */ + addr += 2*75; /* Lead-in occupies 2 seconds */ + dest[3] = addr % 75; /* Frames */ + addr /= 75; + dest[2] = addr % 60; /* Seconds */ + addr /= 60; + dest[1] = addr; /* Minutes */ + dest[0] = 0; /* Reserved */ + } else { + /* Absolute sector */ + put_unaligned_be32(addr, dest); + } +}
diff --git a/drivers/usb/gadget/storage_common.c b/drivers/usb/gadget/storage_common.c deleted file mode 100644 index bea7607..0000000 --- a/drivers/usb/gadget/storage_common.c +++ /dev/null @@ -1,238 +0,0 @@ -/* - * storage_common.c -- Common definitions for mass storage functionality - * - * Copyright (C) 2003-2008 Alan Stern - * Copyeight (C) 2009 Samsung Electronics - * Author: Michal Nazarewicz (m.nazarewicz@samsung.com) - * - * Ported to u-boot: - * Andrzej Pietrasiewicz andrzej.p@samsung.com - * - * Code refactoring & cleanup: - * Ćukasz Majewski l.majewski@samsung.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <f_mass_storage.h> - -/* There is only one interface. */ - -static struct usb_interface_descriptor -fsg_intf_desc = { - .bLength = sizeof fsg_intf_desc, - .bDescriptorType = USB_DT_INTERFACE, - - .bNumEndpoints = 2, /* Adjusted during fsg_bind() */ - .bInterfaceClass = USB_CLASS_MASS_STORAGE, - .bInterfaceSubClass = USB_SC_SCSI, /* Adjusted during fsg_bind() */ - .bInterfaceProtocol = USB_PR_BULK, /* Adjusted during fsg_bind() */ - .iInterface = FSG_STRING_INTERFACE, -}; - -/* - * Three full-speed endpoint descriptors: bulk-in, bulk-out, and - * interrupt-in. - */ - -static struct usb_endpoint_descriptor -fsg_fs_bulk_in_desc = { - .bLength = USB_DT_ENDPOINT_SIZE, - .bDescriptorType = USB_DT_ENDPOINT, - - .bEndpointAddress = USB_DIR_IN, - .bmAttributes = USB_ENDPOINT_XFER_BULK, - /* wMaxPacketSize set by autoconfiguration */ -}; - -static struct usb_endpoint_descriptor -fsg_fs_bulk_out_desc = { - .bLength = USB_DT_ENDPOINT_SIZE, - .bDescriptorType = USB_DT_ENDPOINT, - - .bEndpointAddress = USB_DIR_OUT, - .bmAttributes = USB_ENDPOINT_XFER_BULK, - /* wMaxPacketSize set by autoconfiguration */ -}; - -#ifndef FSG_NO_INTR_EP - -static struct usb_endpoint_descriptor -fsg_fs_intr_in_desc = { - .bLength = USB_DT_ENDPOINT_SIZE, - .bDescriptorType = USB_DT_ENDPOINT, - - .bEndpointAddress = USB_DIR_IN, - .bmAttributes = USB_ENDPOINT_XFER_INT, - .wMaxPacketSize = cpu_to_le16(2), - .bInterval = 32, /* frames -> 32 ms */ -}; - -#ifndef FSG_NO_OTG -# define FSG_FS_FUNCTION_PRE_EP_ENTRIES 2 -#else -# define FSG_FS_FUNCTION_PRE_EP_ENTRIES 1 -#endif - -#endif - -static struct usb_descriptor_header *fsg_fs_function[] = { -#ifndef FSG_NO_OTG - (struct usb_descriptor_header *) &fsg_otg_desc, -#endif - (struct usb_descriptor_header *) &fsg_intf_desc, - (struct usb_descriptor_header *) &fsg_fs_bulk_in_desc, - (struct usb_descriptor_header *) &fsg_fs_bulk_out_desc, -#ifndef FSG_NO_INTR_EP - (struct usb_descriptor_header *) &fsg_fs_intr_in_desc, -#endif - NULL, -}; - -/* - * USB 2.0 devices need to expose both high speed and full speed - * descriptors, unless they only run at full speed. - * - * That means alternate endpoint descriptors (bigger packets) - * and a "device qualifier" ... plus more construction options - * for the configuration descriptor. - */ -static struct usb_endpoint_descriptor -fsg_hs_bulk_in_desc = { - .bLength = USB_DT_ENDPOINT_SIZE, - .bDescriptorType = USB_DT_ENDPOINT, - - /* bEndpointAddress copied from fs_bulk_in_desc during fsg_bind() */ - .bmAttributes = USB_ENDPOINT_XFER_BULK, - .wMaxPacketSize = cpu_to_le16(512), -}; - -static struct usb_endpoint_descriptor -fsg_hs_bulk_out_desc = { - .bLength = USB_DT_ENDPOINT_SIZE, - .bDescriptorType = USB_DT_ENDPOINT, - - /* bEndpointAddress copied from fs_bulk_out_desc during fsg_bind() */ - .bmAttributes = USB_ENDPOINT_XFER_BULK, - .wMaxPacketSize = cpu_to_le16(512), - .bInterval = 1, /* NAK every 1 uframe */ -}; - -#ifndef FSG_NO_INTR_EP - -static struct usb_endpoint_descriptor -fsg_hs_intr_in_desc = { - .bLength = USB_DT_ENDPOINT_SIZE, - .bDescriptorType = USB_DT_ENDPOINT, - - /* bEndpointAddress copied from fs_intr_in_desc during fsg_bind() */ - .bmAttributes = USB_ENDPOINT_XFER_INT, - .wMaxPacketSize = cpu_to_le16(2), - .bInterval = 9, /* 2**(9-1) = 256 uframes -> 32 ms */ -}; - -#ifndef FSG_NO_OTG -# define FSG_HS_FUNCTION_PRE_EP_ENTRIES 2 -#else -# define FSG_HS_FUNCTION_PRE_EP_ENTRIES 1 -#endif - -#endif - -static struct usb_descriptor_header *fsg_hs_function[] = { -#ifndef FSG_NO_OTG - (struct usb_descriptor_header *) &fsg_otg_desc, -#endif - (struct usb_descriptor_header *) &fsg_intf_desc, - (struct usb_descriptor_header *) &fsg_hs_bulk_in_desc, - (struct usb_descriptor_header *) &fsg_hs_bulk_out_desc, -#ifndef FSG_NO_INTR_EP - (struct usb_descriptor_header *) &fsg_hs_intr_in_desc, -#endif - NULL, -}; - -/* Maxpacket and other transfer characteristics vary by speed. */ -static struct usb_endpoint_descriptor * -fsg_ep_desc(struct usb_gadget *g, struct usb_endpoint_descriptor *fs, - struct usb_endpoint_descriptor *hs) -{ - if (gadget_is_dualspeed(g) && g->speed == USB_SPEED_HIGH) - return hs; - return fs; -} - -/* Static strings, in UTF-8 (for simplicity we use only ASCII characters) */ -static struct usb_string fsg_strings[] = { -#ifndef FSG_NO_DEVICE_STRINGS - {FSG_STRING_MANUFACTURER, fsg_string_manufacturer}, - {FSG_STRING_PRODUCT, fsg_string_product}, - {FSG_STRING_SERIAL, fsg_string_serial}, - {FSG_STRING_CONFIG, fsg_string_config}, -#endif - {FSG_STRING_INTERFACE, fsg_string_interface}, - {} -}; - -static struct usb_gadget_strings fsg_stringtab = { - .language = 0x0409, /* en-us */ - .strings = fsg_strings, -}; - -/*-------------------------------------------------------------------------*/ - -/* - * If the next two routines are called while the gadget is registered, - * the caller must own fsg->filesem for writing. - */ - -static int fsg_lun_open(struct fsg_lun *curlun, unsigned int num_sectors, - const char *filename) -{ - int ro; - - /* R/W if we can, R/O if we must */ - ro = curlun->initially_ro; - - curlun->ro = ro; - curlun->file_length = num_sectors << 9; - curlun->num_sectors = num_sectors; - debug("open backing file: %s\n", filename); - - return 0; -} - -static void fsg_lun_close(struct fsg_lun *curlun) -{ -} - -/*-------------------------------------------------------------------------*/ - -/* - * Sync the file data, don't bother with the metadata. - * This code was copied from fs/buffer.c:sys_fdatasync(). - */ -static int fsg_lun_fsync_sub(struct fsg_lun *curlun) -{ - return 0; -} - -static void store_cdrom_address(u8 *dest, int msf, u32 addr) -{ - if (msf) { - /* Convert to Minutes-Seconds-Frames */ - addr >>= 2; /* Convert to 2048-byte frames */ - addr += 2*75; /* Lead-in occupies 2 seconds */ - dest[3] = addr % 75; /* Frames */ - addr /= 75; - dest[2] = addr % 60; /* Seconds */ - addr /= 60; - dest[1] = addr; /* Minutes */ - dest[0] = 0; /* Reserved */ - } else { - /* Absolute sector */ - put_unaligned_be32(addr, dest); - } -} - -/*-------------------------------------------------------------------------*/
remove static declaration of some functions. so these functions can be called by other module
Signed-off-by: Eddie Cai eddie.cai.linux@gmail.com --- drivers/usb/gadget/f_mass_storage.c | 4 ++-- include/f_mass_storage.h | 7 +++---- 2 files changed, 5 insertions(+), 6 deletions(-)
diff --git a/drivers/usb/gadget/f_mass_storage.c b/drivers/usb/gadget/f_mass_storage.c index eb2ff82..faf875e 100644 --- a/drivers/usb/gadget/f_mass_storage.c +++ b/drivers/usb/gadget/f_mass_storage.c @@ -775,7 +775,7 @@ static void busy_indicator(void) state = 0; }
-static int sleep_thread(struct fsg_common *common) +int sleep_thread(struct fsg_common *common) { int rc = 0; int i = 0, k = 0; @@ -1899,7 +1899,7 @@ static int check_command(struct fsg_common *common, int cmnd_size, }
-static int do_scsi_command(struct fsg_common *common) +int do_scsi_command(struct fsg_common *common) { struct fsg_buffhd *bh; int rc; diff --git a/include/f_mass_storage.h b/include/f_mass_storage.h index 620af06..df6ea33 100644 --- a/include/f_mass_storage.h +++ b/include/f_mass_storage.h @@ -391,9 +391,6 @@ fsg_otg_desc = { #endif
- - - #define GFP_ATOMIC ((gfp_t) 0) #define PAGE_CACHE_SHIFT 12 #define PAGE_CACHE_SIZE (1 << PAGE_CACHE_SHIFT) @@ -503,7 +500,9 @@ struct fsg_dev { struct usb_ep *bulk_out; };
-#endif /* __F_MASS_STORAGE_H_ */ +int sleep_thread(struct fsg_common *common); +int do_scsi_command(struct fsg_common *common);
+#endif /* __F_MASS_STORAGE_H_ */
add functions to set and get usb interface descriptor, so people can customize usb interface descriptor
Signed-off-by: Eddie Cai eddie.cai.linux@gmail.com --- drivers/usb/gadget/f_mass_storage.c | 18 ++++++++++++++++++ include/f_mass_storage.h | 2 ++ 2 files changed, 20 insertions(+)
diff --git a/drivers/usb/gadget/f_mass_storage.c b/drivers/usb/gadget/f_mass_storage.c index faf875e..333f069 100644 --- a/drivers/usb/gadget/f_mass_storage.c +++ b/drivers/usb/gadget/f_mass_storage.c @@ -2870,6 +2870,24 @@ static int fsg_bind_config(struct usb_composite_dev *cdev, return rc; }
+struct usb_interface_descriptor *fsg_get_usb_interface_descriptor(void) +{ + return &fsg_intf_desc; +} + +void fsg_set_usb_interface_descriptor(struct usb_interface_descriptor *desc) +{ + if (desc) { + fsg_intf_desc.bLength = desc->bLength; + fsg_intf_desc.bDescriptorType = desc->bDescriptorType; + fsg_intf_desc.bNumEndpoints = desc->bNumEndpoints; + fsg_intf_desc.bInterfaceClass = desc->bInterfaceClass; + fsg_intf_desc.bInterfaceSubClass = desc->bInterfaceSubClass; + fsg_intf_desc.bInterfaceProtocol = desc->bInterfaceProtocol; + fsg_intf_desc.iInterface = desc->iInterface; + } +} + int fsg_add(struct usb_configuration *c) { struct fsg_common *fsg_common; diff --git a/include/f_mass_storage.h b/include/f_mass_storage.h index df6ea33..0cf29df 100644 --- a/include/f_mass_storage.h +++ b/include/f_mass_storage.h @@ -500,6 +500,8 @@ struct fsg_dev { struct usb_ep *bulk_out; };
+struct usb_interface_descriptor *fsg_get_usb_interface_descriptor(void); +void fsg_set_usb_interface_descriptor(struct usb_interface_descriptor *desc); int sleep_thread(struct fsg_common *common); int do_scsi_command(struct fsg_common *common);
add do_extra_command to let people deal with customized command
Signed-off-by: Eddie Cai eddie.cai.linux@gmail.com --- drivers/usb/gadget/f_mass_storage.c | 8 +++++++- 1 file changed, 7 insertions(+), 1 deletion(-)
diff --git a/drivers/usb/gadget/f_mass_storage.c b/drivers/usb/gadget/f_mass_storage.c index 333f069..d431e53 100644 --- a/drivers/usb/gadget/f_mass_storage.c +++ b/drivers/usb/gadget/f_mass_storage.c @@ -2168,6 +2168,10 @@ unknown_cmnd: return 0; }
+int __weak do_extra_command(struct fsg_common *common) +{ + return -EINVAL; +} /*-------------------------------------------------------------------------*/
static int received_cbw(struct fsg_dev *fsg, struct fsg_buffhd *bh) @@ -2540,8 +2544,10 @@ int fsg_main_thread(void *common_) if (!exception_in_progress(common)) common->state = FSG_STATE_DATA_PHASE;
- if (do_scsi_command(common) || finish_reply(common)) + if ((do_extra_command(common) && do_scsi_command(common)) || + finish_reply(common)) { continue; + }
if (!exception_in_progress(common)) common->state = FSG_STATE_STATUS_PHASE;
this patch add rockusb command. the usage is rockusb <USB_controller> [<devtype>] <devnum> e.g. rockusb 0 mmc 0
Signed-off-by: Eddie Cai eddie.cai.linux@gmail.com --- cmd/Kconfig | 5 + cmd/Makefile | 1 + cmd/rockusb.c | 383 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 389 insertions(+) create mode 100644 cmd/rockusb.c
diff --git a/cmd/Kconfig b/cmd/Kconfig index 661ae7a..c94f509 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -509,6 +509,11 @@ config CMD_DFU Enables the command "dfu" which is used to have U-Boot create a DFU class device via USB.
+config CMD_ROCKUSB + bool "rockusb" + help + enables the rockusb command. + config CMD_USB_MASS_STORAGE bool "UMS usb mass storage" help diff --git a/cmd/Makefile b/cmd/Makefile index ef1406b..9111ba3 100644 --- a/cmd/Makefile +++ b/cmd/Makefile @@ -112,6 +112,7 @@ obj-$(CONFIG_CMD_READ) += read.o obj-$(CONFIG_CMD_REGINFO) += reginfo.o obj-$(CONFIG_CMD_REISER) += reiser.o obj-$(CONFIG_CMD_REMOTEPROC) += remoteproc.o +obj-$(CONFIG_CMD_ROCKUSB) += rockusb.o obj-$(CONFIG_SANDBOX) += host.o obj-$(CONFIG_CMD_SATA) += sata.o obj-$(CONFIG_CMD_SF) += sf.o diff --git a/cmd/rockusb.c b/cmd/rockusb.c new file mode 100644 index 0000000..883db09 --- /dev/null +++ b/cmd/rockusb.c @@ -0,0 +1,383 @@ +/* + * Copyright (C) 2017 Eddie Cai eddie.cai.linux@gmail.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <command.h> +#include <console.h> +#include <f_mass_storage.h> +#include <g_dnl.h> +#include <usb.h> +#include <usb_mass_storage.h> + +#define K_FW_TEST_UNIT_READY 0x00 +#define K_FW_READ_FLASH_ID 0x01 +#define K_FW_SET_DEVICE_ID 0x02 +#define K_FW_TEST_BAD_BLOCK 0x03 +#define K_FW_READ_10 0x04 +#define K_FW_WRITE_10 0x05 +#define K_FW_ERASE_10 0x06 +#define K_FW_WRITE_SPARE 0x07 +#define K_FW_READ_SPARE 0x08 + +#define K_FW_ERASE_10_FORCE 0x0b +#define K_FW_GET_VERSION 0x0c + +#define K_FW_LBA_READ_10 0x14 +#define K_FW_LBA_WRITE_10 0x15 +#define K_FW_ERASE_SYS_DISK 0x16 +#define K_FW_SDRAM_READ_10 0x17 +#define K_FW_SDRAM_WRITE_10 0x18 +#define K_FW_SDRAM_EXECUTE 0x19 +#define K_FW_READ_FLASH_INFO 0x1A +#define K_FW_GET_CHIP_VER 0x1B +#define K_FW_LOW_FORMAT 0x1C +#define K_FW_SET_RESET_FLAG 0x1E +#define K_FW_SPI_READ_10 0x21 +#define K_FW_SPI_WRITE_10 0x22 + +#define K_FW_SESSION 0X30 +#define K_FW_RESET 0xff + +#define ROCKUSB_INTERFACE_CLASS 0xff +#define ROCKUSB_INTERFACE_SUB_CLASS 0x06 +#define ROCKUSB_INTERFACE_PROTOCOL 0x05 + +static struct usb_interface_descriptor rockusb_desc = { + .bLength = USB_DT_INTERFACE_SIZE, + .bDescriptorType = USB_DT_INTERFACE, + .bNumEndpoints = 0x02, + .bInterfaceClass = ROCKUSB_INTERFACE_CLASS, + .bInterfaceSubClass = ROCKUSB_INTERFACE_SUB_CLASS, + .bInterfaceProtocol = ROCKUSB_INTERFACE_PROTOCOL, + .iInterface = FSG_STRING_INTERFACE, +}; + +int __weak rkusb_set_reboot_flag(int flag) +{ + printf("rkusb_set_reboot_flag: %d\n", flag); + return -ENOSYS; +} + +static void rkusb_do_reset(struct usb_ep *ep, struct usb_request *req) +{ + do_reset(NULL, 0, 0, NULL); +} + +#ifdef DEBUG +static void printcbw(struct fsg_bulk_cb_wrap *cbw) +{ + debug("cbw: Signature:%x\n", cbw->Signature); + debug("cbw: Tag=%x\n", cbw->Tag); + debug("cbw: DataTransferLength=%d\n", cbw->DataTransferLength); + debug("cbw: Flags=%x\n", cbw->Flags); + debug("cbw: Lun=%d\n", cbw->Lun); + debug("cbw: Length=%d\n", cbw->Length); + debug("cbw: ucOperCode=%x\n", cbw->CDB[0]); + debug("cbw: ucReserved=%x\n", cbw->CDB[1]); + debug( + "cbw: dwAddress:%x %x %x %x\n", + cbw->CDB[5], cbw->CDB[4], cbw->CDB[3], cbw->CDB[2]); + debug("cbw: ucReserved2=%x\n", cbw->CDB[6]); + debug("cbw: usLength:%x %x\n", cbw->CDB[8], cbw->CDB[7]); +} + +static void printcsw(struct bulk_cs_wrap *csw) +{ + debug("csw: Signature:%x\n", csw->Signature); + debug("csw: Tag:%x\n", csw->Tag); + debug("csw: Residue:%x\n", csw->Residue); + debug("csw: Status:%x\n", csw->Status); +} +#endif + +int do_extra_command(struct fsg_common *common) +{ + struct fsg_buffhd *bh; + int rc, reply = -EINVAL; + struct usb_interface_descriptor *desc; + + desc = fsg_get_usb_interface_descriptor(); + /* make sure we are dealing with rockusb protocol */ + if (desc->bInterfaceClass != ROCKUSB_INTERFACE_CLASS || + desc->bInterfaceSubClass != ROCKUSB_INTERFACE_SUB_CLASS || + desc->bInterfaceProtocol != ROCKUSB_INTERFACE_PROTOCOL){ + return reply; + } + + /* Wait for the next buffer to become available for data or status */ + bh = common->next_buffhd_to_fill; + common->next_buffhd_to_drain = bh; +#ifdef DEBUG + struct usb_request *req; + struct fsg_bulk_cb_wrap *cbw; + req = bh->outreq; + cbw = req->buf; + printcbw(cbw); +#endif + debug("%s: cmd=%d\n", __func__, common->cmnd[0]); + while (bh->state != BUF_STATE_EMPTY) { + rc = sleep_thread(common); + if (rc) + return rc; + } + common->phase_error = 0; + common->short_packet_received = 0; + + switch (common->cmnd[0]) { + case K_FW_RESET: + common->data_size_from_cmnd = common->cmnd[4]; + rkusb_set_reboot_flag(common->cmnd[1]); + bh->inreq->complete = rkusb_do_reset; + bh->state = BUF_STATE_EMPTY; + bh->inreq->length = USB_BULK_CS_WRAP_LEN; + common->residue -= USB_BULK_CS_WRAP_LEN; + return 0; + case K_FW_LBA_WRITE_10: + common->cmnd[0] = SC_WRITE_10; + common->data_dir = DATA_DIR_FROM_HOST; + common->data_size_from_cmnd = + get_unaligned_be16(&common->cmnd[7]) << 9; + common->data_size = common->data_size_from_cmnd; + do_scsi_command(common); + return 0; + default: + return reply; + } + return reply; +} + +static int rkusb_read_sector(struct ums *rkusb_dev, + ulong start, lbaint_t blkcnt, void *buf) +{ + struct blk_desc *block_dev = &rkusb_dev->block_dev; + lbaint_t blkstart = start + rkusb_dev->start_sector; + + return blk_dread(block_dev, blkstart, blkcnt, buf); +} + +static int rkusb_write_sector(struct ums *rkusb_dev, + ulong start, lbaint_t blkcnt, const void *buf) +{ + struct blk_desc *block_dev = &rkusb_dev->block_dev; + lbaint_t blkstart = start + rkusb_dev->start_sector; + + return blk_dwrite(block_dev, blkstart, blkcnt, buf); +} + +static struct ums *rkusb; +static int rkusb_count; + +static void rkusb_fini(void) +{ + int i; + + for (i = 0; i < rkusb_count; i++) + free((void *)rkusb[i].name); + free(rkusb); + rkusb = 0; + rkusb_count = 0; +} + +#define ROCKUSB_NAME_LEN 16 + +static int rkusb_init(const char *devtype, const char *devnrkusb_part_str) +{ + char *s, *t, *devnum_part_str, *name; + struct blk_desc *block_dev; + disk_partition_t info; + int partnum; + int ret = -1; + struct ums *rkusb_new; + + s = strdup(devnrkusb_part_str); + if (!s) + return -1; + + t = s; + rkusb_count = 0; + + for (;;) { + devnum_part_str = strsep(&t, ","); + if (!devnum_part_str) + break; + + partnum = blk_get_device_part_str(devtype, devnum_part_str, + &block_dev, &info, 1); + + if (partnum < 0) + goto cleanup; + + /* Check if the argument is in legacy format. If yes, + * expose all partitions by setting the partnum = 0 + * e.g. rkusb 0 mmc 0 + */ + if (!strchr(devnum_part_str, ':')) + partnum = 0; + + /* f_mass_storage.c assumes SECTOR_SIZE sectors */ + if (block_dev->blksz != SECTOR_SIZE) + goto cleanup; + + rkusb_new = realloc(rkusb, (rkusb_count + 1) * sizeof(*rkusb)); + if (!rkusb_new) + goto cleanup; + rkusb = rkusb_new; + + /* if partnum = 0, expose all partitions */ + if (partnum == 0) { + rkusb[rkusb_count].start_sector = 0; + rkusb[rkusb_count].num_sectors = block_dev->lba; + } else { + rkusb[rkusb_count].start_sector = info.start; + rkusb[rkusb_count].num_sectors = info.size; + } + + rkusb[rkusb_count].read_sector = rkusb_read_sector; + rkusb[rkusb_count].write_sector = rkusb_write_sector; + + name = malloc(ROCKUSB_NAME_LEN); + if (!name) + goto cleanup; + snprintf(name, ROCKUSB_NAME_LEN, "rkusb disk %d", rkusb_count); + rkusb[rkusb_count].name = name; + rkusb[rkusb_count].block_dev = *block_dev; + + printf("ROCKUSB: LUN %d, dev %d, hwpart %d, sector %#x, count %#x\n", + rkusb_count, rkusb[rkusb_count].block_dev.devnum, + rkusb[rkusb_count].block_dev.hwpart, + rkusb[rkusb_count].start_sector, + rkusb[rkusb_count].num_sectors); + + rkusb_count++; + } + + if (rkusb_count) + ret = 0; + +cleanup: + free(s); + + if (ret < 0) + rkusb_fini(); + + return ret; +} + +static int do_rockusb(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[]) +{ + const char *usb_controller; + const char *devtype; + const char *devnum; + unsigned int controller_index; + int rc; + int cable_ready_timeout __maybe_unused; + struct usb_interface_descriptor desc; + + if (argc < 3) + return CMD_RET_USAGE; + + usb_controller = argv[1]; + if (argc >= 4) { + devtype = argv[2]; + devnum = argv[3]; + } else { + devtype = "mmc"; + devnum = argv[2]; + } + + rc = rkusb_init(devtype, devnum); + if (rc < 0) + return CMD_RET_FAILURE; + + controller_index = (unsigned int)(simple_strtoul( + usb_controller, NULL, 0)); + if (board_usb_init(controller_index, USB_INIT_DEVICE)) { + error("Couldn't init USB controller."); + rc = CMD_RET_FAILURE; + goto cleanup_rkusb_init; + } + + rc = fsg_init(rkusb, rkusb_count); + if (rc) { + error("fsg_init failed"); + rc = CMD_RET_FAILURE; + goto cleanup_board; + } + + memcpy(&desc, fsg_get_usb_interface_descriptor(), + sizeof(struct usb_interface_descriptor)); + fsg_set_usb_interface_descriptor(&rockusb_desc); + rc = g_dnl_register("usb_dnl_ums"); + if (rc) { + error("g_dnl_register failed"); + rc = CMD_RET_FAILURE; + goto cleanup_board; + } + + /* Timeout unit: seconds */ + cable_ready_timeout = UMS_CABLE_READY_TIMEOUT; + + if (!g_dnl_board_usb_cable_connected()) { + /* + * Won't execute if we don't know whether the cable is + * connected. + */ + puts("Please connect USB cable.\n"); + + while (!g_dnl_board_usb_cable_connected()) { + if (ctrlc()) { + puts("\rCTRL+C - Operation aborted.\n"); + rc = CMD_RET_SUCCESS; + goto cleanup_register; + } + if (!cable_ready_timeout) { + puts("\rUSB cable not detected.Command exit.\n"); + rc = CMD_RET_SUCCESS; + goto cleanup_register; + } + + printf("\rAuto exit in: %.2d s.", cable_ready_timeout); + mdelay(1000); + cable_ready_timeout--; + } + puts("\r\n"); + } + + while (1) { + usb_gadget_handle_interrupts(controller_index); + + rc = fsg_main_thread(NULL); + if (rc) { + /* Check I/O error */ + if (rc == -EIO) + printf("\rCheck USB cable connection\n"); + + /* Check CTRL+C */ + if (rc == -EPIPE) + printf("\rCTRL+C - Operation aborted\n"); + + rc = CMD_RET_SUCCESS; + goto cleanup_register; + } + } + +cleanup_register: + g_dnl_unregister(); +cleanup_board: + board_usb_cleanup(controller_index, USB_INIT_DEVICE); + fsg_set_usb_interface_descriptor(&desc); +cleanup_rkusb_init: + rkusb_fini(); + + return rc; +} + +U_BOOT_CMD( + rockusb, 4, 1, do_rockusb, + "use the ROCKUSB protocol", + "rockusb <USB_controller> [<devtype>] <devnum> e.g. rockusb 0 mmc 0\n" + " devtype defaults to mmc" +);
all rk3288 based boards support rockusb, so enable it
Signed-off-by: Eddie Cai eddie.cai.linux@gmail.com --- configs/evb-rk3288_defconfig | 2 ++ configs/fennec-rk3288_defconfig | 1 + configs/firefly-rk3288_defconfig | 1 + configs/miqi-rk3288_defconfig | 1 + configs/popmetal-rk3288_defconfig | 1 + configs/rock2_defconfig | 2 ++ configs/sandbox_defconfig | 1 + configs/tinker-rk3288_defconfig | 1 + 8 files changed, 10 insertions(+)
diff --git a/configs/evb-rk3288_defconfig b/configs/evb-rk3288_defconfig index aad2533..6be46fb 100644 --- a/configs/evb-rk3288_defconfig +++ b/configs/evb-rk3288_defconfig @@ -17,6 +17,8 @@ CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_ROCKUSB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_CACHE=y diff --git a/configs/fennec-rk3288_defconfig b/configs/fennec-rk3288_defconfig index d1b0ffc..ba8a356 100644 --- a/configs/fennec-rk3288_defconfig +++ b/configs/fennec-rk3288_defconfig @@ -18,6 +18,7 @@ CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_ROCKUSB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_CACHE=y diff --git a/configs/firefly-rk3288_defconfig b/configs/firefly-rk3288_defconfig index b0741d7..c860c06 100644 --- a/configs/firefly-rk3288_defconfig +++ b/configs/firefly-rk3288_defconfig @@ -17,6 +17,7 @@ CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_ROCKUSB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_CACHE=y diff --git a/configs/miqi-rk3288_defconfig b/configs/miqi-rk3288_defconfig index 203824b..3c42d99 100644 --- a/configs/miqi-rk3288_defconfig +++ b/configs/miqi-rk3288_defconfig @@ -17,6 +17,7 @@ CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_ROCKUSB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_CACHE=y diff --git a/configs/popmetal-rk3288_defconfig b/configs/popmetal-rk3288_defconfig index dfc84b9..ddf6062 100644 --- a/configs/popmetal-rk3288_defconfig +++ b/configs/popmetal-rk3288_defconfig @@ -18,6 +18,7 @@ CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_ROCKUSB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_CACHE=y diff --git a/configs/rock2_defconfig b/configs/rock2_defconfig index e9a32a9..365bc90 100644 --- a/configs/rock2_defconfig +++ b/configs/rock2_defconfig @@ -16,6 +16,8 @@ CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_ROCKUSB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_CACHE=y diff --git a/configs/sandbox_defconfig b/configs/sandbox_defconfig index 7f3f5ac..9350d51 100644 --- a/configs/sandbox_defconfig +++ b/configs/sandbox_defconfig @@ -33,6 +33,7 @@ CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_ROCKUSB=y CONFIG_CMD_REMOTEPROC=y CONFIG_CMD_GPIO=y CONFIG_CMD_TFTPPUT=y diff --git a/configs/tinker-rk3288_defconfig b/configs/tinker-rk3288_defconfig index cec3938..d96d7d3 100644 --- a/configs/tinker-rk3288_defconfig +++ b/configs/tinker-rk3288_defconfig @@ -18,6 +18,7 @@ CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y +CONFIG_CMD_ROCKUSB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_CACHE=y
add a simple readme to introduce rockusb and tell people how to use it
Signed-off-by: Eddie Cai eddie.cai.linux@gmail.com --- doc/README.rockusb | 35 +++++++++++++++++++++++++++++++++++ 1 file changed, 35 insertions(+) create mode 100644 doc/README.rockusb
diff --git a/doc/README.rockusb b/doc/README.rockusb new file mode 100644 index 0000000..13893d9 --- /dev/null +++ b/doc/README.rockusb @@ -0,0 +1,35 @@ +Rockusb (Rockchip USB protocol) +===================================================== + +Overview +-------- + +Rockusb protocol is widely used with Rockchip devices. +It can read/write info, image to/from devices. This +document briefly describes how to use Rockusb for upgrading +firmware (e.g. kernel, u-boot, rootfs, etc.). + +Tools +-------- +There are many tools can support Rockusb protocol. rkdeveloptool +is open source, It is maintained by Rockchip. + +Usage +-------- +The Usage of Rockusb command is +rockusb <USB_controller> [<devtype>] <devnum> +e.g. rockusb 0 mmc 0 +rockusb 0 usb 0 +On your U-Boot console, type this command to enter rockusb mode. +On your host PC. use lsusb command. you should see a usb device +using 0x2207 as its USB verdor id. Then use rkdeveloptool +sudo rkdeveloptool wl <BeginSec> <File> +to flash U-Boot image use command +sudo rkdeveloptool wl 64 <U-Boot binary> +There are plenty of Rockusb command. but wl(write lba) and +rd(reboot) command. These two command can let people flash +image to device. + +To do +----- +* Fully support Rockusb protocol
Hi
Sorry cover email arrive now ;)
Michael
-- 2.10.2
What's the difference between these two series? [U-Boot PATCH V2 0/9] introduce Rockchip rockusb [U-Boot PATCH V2 0/8] introduce Rockchip rockusb
Eddie Cai
Michael Nazzareno Trimarchi
