[U-Boot] [PATCH 2/2] i2c: mxc_i2c: Remove i2c_idle_bus from probe
i2c_idle_bus is already used in i2c_init_transfer. So before each tranfer if the bus is not ready, the i2c_idle_bus will be used to force idle. It is unnecessary to call it again in probe.
We found a issue when enabling i2c mux with the mxc_i2c. The mxc_i2c is probed after mux probing. However, at this moment the mux is still in idle state not select any port. So if we call i2c_idle_bus in probe, it will fail and cause mxc_i2c probe failed.
Signed-off-by: Ye Li ye.li@nxp.com --- drivers/i2c/mxc_i2c.c | 7 ------- 1 file changed, 7 deletions(-)
diff --git a/drivers/i2c/mxc_i2c.c b/drivers/i2c/mxc_i2c.c index 23119cc..bd00bb5 100644 --- a/drivers/i2c/mxc_i2c.c +++ b/drivers/i2c/mxc_i2c.c @@ -916,13 +916,6 @@ static int mxc_i2c_probe(struct udevice *bus) } }
- ret = i2c_idle_bus(i2c_bus); - if (ret < 0) { - /* Disable clk */ - enable_i2c_clk(0, bus->seq); - return ret; - } - /* * Pinmux settings are in board file now, until pinmux is supported, * we can set pinmux here in probe function.
Hello Ye Li,
Am 10.07.2019 um 12:24 schrieb Ye Li:
Applied to u-boot-i2c master
Thanks!
bye, Heiko
Heiko Schocher
Ye Li
