[U-Boot] [PATCH 2/2] mx6sxsabresd: Add Ethernet support
mx6sxsabresd board has 2 FEC ports, each one connected to a AR8031.
Add support for one FEC port initially.
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- FEC is not functional after this series.
There is still another patch for FEC that I will submit later that makes FEC functional on mx6solox, but it is orthogonal to this series.
arch/arm/include/asm/arch-mx6/crm_regs.h | 1 + arch/arm/include/asm/arch-mx6/iomux.h | 10 +++ board/freescale/mx6sxsabresd/mx6sxsabresd.c | 116 ++++++++++++++++++++++++++++ include/configs/mx6sxsabresd.h | 17 ++++ 4 files changed, 144 insertions(+)
diff --git a/arch/arm/include/asm/arch-mx6/crm_regs.h b/arch/arm/include/asm/arch-mx6/crm_regs.h index 9a7fb34..e67b5b9 100644 --- a/arch/arm/include/asm/arch-mx6/crm_regs.h +++ b/arch/arm/include/asm/arch-mx6/crm_regs.h @@ -981,6 +981,7 @@ struct mxc_ccm_reg { #define BM_ANADIG_PLL_ENET_RSVD1 0x7FE00000 #define BF_ANADIG_PLL_ENET_RSVD1(v) \ (((v) << 21) & BM_ANADIG_PLL_ENET_RSVD1) +#define BM_ANADIG_PLL_ENET_REF_25M_ENABLE 0x00200000 #define BM_ANADIG_PLL_ENET_ENABLE_SATA 0x00100000 #define BM_ANADIG_PLL_ENET_ENABLE_PCIE 0x00080000 #define BM_ANADIG_PLL_ENET_PFD_OFFSET_EN 0x00040000 diff --git a/arch/arm/include/asm/arch-mx6/iomux.h b/arch/arm/include/asm/arch-mx6/iomux.h index 6a4a632..f54db69 100644 --- a/arch/arm/include/asm/arch-mx6/iomux.h +++ b/arch/arm/include/asm/arch-mx6/iomux.h @@ -65,6 +65,16 @@ #define IOMUX_GPR1_FEC_MASK (IOMUX_GPR1_FEC_CLOCK_MUX1_SEL_MASK \ | IOMUX_GPR1_FEC_CLOCK_MUX2_SEL_MASK)
+#define IOMUX_GPR1_FEC1_CLOCK_MUX1_SEL_MASK (0x1 << 17) +#define IOMUX_GPR1_FEC1_CLOCK_MUX2_SEL_MASK (0x1 << 13) +#define IOMUX_GPR1_FEC1_MASK (IOMUX_GPR1_FEC1_CLOCK_MUX1_SEL_MASK \ + | IOMUX_GPR1_FEC1_CLOCK_MUX2_SEL_MASK) + +#define IOMUX_GPR1_FEC2_CLOCK_MUX1_SEL_MASK (0x1 << 18) +#define IOMUX_GPR1_FEC2_CLOCK_MUX2_SEL_MASK (0x1 << 14) +#define IOMUX_GPR1_FEC2_MASK (IOMUX_GPR1_FEC2_CLOCK_MUX1_SEL_MASK \ + | IOMUX_GPR1_FEC2_CLOCK_MUX2_SEL_MASK) + #define IOMUXC_GPR13_SATA_PHY_8_RXEQ_0P5DB (0<<24) #define IOMUXC_GPR13_SATA_PHY_8_RXEQ_1P0DB (1<<24) #define IOMUXC_GPR13_SATA_PHY_8_RXEQ_1P5DB (2<<24) diff --git a/board/freescale/mx6sxsabresd/mx6sxsabresd.c b/board/freescale/mx6sxsabresd/mx6sxsabresd.c index 6cd2b4a..5eaec1b 100644 --- a/board/freescale/mx6sxsabresd/mx6sxsabresd.c +++ b/board/freescale/mx6sxsabresd/mx6sxsabresd.c @@ -7,6 +7,7 @@ */
#include <asm/arch/clock.h> +#include <asm/arch/crm_regs.h> #include <asm/arch/iomux.h> #include <asm/arch/imx-regs.h> #include <asm/arch/mx6-pins.h> @@ -20,6 +21,8 @@ #include <fsl_esdhc.h> #include <mmc.h> #include <i2c.h> +#include <miiphy.h> +#include <netdev.h> #include <power/pmic.h> #include <power/pfuze100_pmic.h>
@@ -38,6 +41,21 @@ DECLARE_GLOBAL_DATA_PTR; PAD_CTL_DSE_40ohm | PAD_CTL_HYS | \ PAD_CTL_ODE)
+#define ENET_PAD_CTRL (PAD_CTL_PUS_100K_UP | PAD_CTL_PUE | \ + PAD_CTL_SPEED_HIGH | \ + PAD_CTL_DSE_48ohm | PAD_CTL_SRE_FAST) + +#define ENET_CLK_PAD_CTRL (PAD_CTL_SPEED_MED | \ + PAD_CTL_DSE_120ohm | PAD_CTL_SRE_FAST) + +#define ENET_RX_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \ + PAD_CTL_SPEED_HIGH | PAD_CTL_SRE_FAST) + +#define I2C_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \ + PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_MED | \ + PAD_CTL_DSE_40ohm | PAD_CTL_HYS | \ + PAD_CTL_ODE) + int dram_init(void) { gd->ram_size = PHYS_SDRAM_SIZE; @@ -60,11 +78,83 @@ static iomux_v3_cfg_t const usdhc4_pads[] = { MX6_PAD_SD4_DATA7__GPIO6_IO_21 | MUX_PAD_CTRL(NO_PAD_CTRL), };
+static iomux_v3_cfg_t const fec1_pads[] = { + MX6_PAD_ENET1_MDC__ENET1_MDC | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_ENET1_MDIO__ENET1_MDIO | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII1_RX_CTL__ENET1_RX_EN | MUX_PAD_CTRL(ENET_RX_PAD_CTRL), + MX6_PAD_RGMII1_RD0__ENET1_RX_DATA_0 | MUX_PAD_CTRL(ENET_RX_PAD_CTRL), + MX6_PAD_RGMII1_RD1__ENET1_RX_DATA_1 | MUX_PAD_CTRL(ENET_RX_PAD_CTRL), + MX6_PAD_RGMII1_RD2__ENET1_RX_DATA_2 | MUX_PAD_CTRL(ENET_RX_PAD_CTRL), + MX6_PAD_RGMII1_RD3__ENET1_RX_DATA_3 | MUX_PAD_CTRL(ENET_RX_PAD_CTRL), + MX6_PAD_RGMII1_RXC__ENET1_RX_CLK | MUX_PAD_CTRL(ENET_RX_PAD_CTRL), + MX6_PAD_RGMII1_TX_CTL__ENET1_TX_EN | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII1_TD0__ENET1_TX_DATA_0 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII1_TD1__ENET1_TX_DATA_1 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII1_TD2__ENET1_TX_DATA_2 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII1_TD3__ENET1_TX_DATA_3 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII1_TXC__ENET1_RGMII_TXC | MUX_PAD_CTRL(ENET_PAD_CTRL), +}; + +static iomux_v3_cfg_t const peri_3v3_pads[] = { + MX6_PAD_QSPI1A_DATA0__GPIO4_IO_16 | MUX_PAD_CTRL(NO_PAD_CTRL), +}; + +static iomux_v3_cfg_t const phy_control_pads[] = { + /* 25MHz Ethernet PHY Clock */ + MX6_PAD_ENET2_RX_CLK__ENET2_REF_CLK_25M | MUX_PAD_CTRL(ENET_CLK_PAD_CTRL), + + /* ENET PHY Power */ + MX6_PAD_ENET2_COL__GPIO2_IO_6 | MUX_PAD_CTRL(NO_PAD_CTRL), + + /* AR8031 PHY Reset */ + MX6_PAD_ENET2_CRS__GPIO2_IO_7 | MUX_PAD_CTRL(NO_PAD_CTRL), +}; + static void setup_iomux_uart(void) { imx_iomux_v3_setup_multiple_pads(uart1_pads, ARRAY_SIZE(uart1_pads)); }
+static int setup_fec(void) +{ + struct iomuxc *iomuxc_regs = (struct iomuxc *)IOMUXC_BASE_ADDR; + struct anatop_regs *anatop = (struct anatop_regs *)ANATOP_BASE_ADDR; + int ret; + int reg; + + /* Use 125MHz anatop loopback REF_CLK1 for ENET1 */ + clrsetbits_le32(&iomuxc_regs->gpr[1], IOMUX_GPR1_FEC1_MASK, 0); + + imx_iomux_v3_setup_multiple_pads(phy_control_pads, + ARRAY_SIZE(phy_control_pads)); + + /* Enable the ENET power, active low */ + gpio_direction_output(IMX_GPIO_NR(2, 6) , 0); + + /* Reset AR8031 PHY */ + gpio_direction_output(IMX_GPIO_NR(2, 7) , 0); + udelay(500); + gpio_set_value(IMX_GPIO_NR(2, 7), 1); + + reg = readl(&anatop->pll_enet); + reg |= BM_ANADIG_PLL_ENET_REF_25M_ENABLE; + writel(reg, &anatop->pll_enet); + + ret = enable_fec_anatop_clock(ENET_125MHz); + if (ret) + return ret; + + return 0; +} + +int board_eth_init(bd_t *bis) +{ + imx_iomux_v3_setup_multiple_pads(fec1_pads, ARRAY_SIZE(fec1_pads)); + setup_fec(); + + return cpu_eth_init(bis); +} + #define PC MUX_PAD_CTRL(I2C_PAD_CTRL) /* I2C1 for PMIC */ struct i2c_pads_info i2c_pad_info1 = { @@ -131,11 +221,37 @@ static int pfuze_init(void) return 0; }
+int board_phy_config(struct phy_device *phydev) +{ + /* + * Enable 1.8V(SEL_1P5_1P8_POS_REG) on + * Phy control debug reg 0 + */ + phy_write(phydev, MDIO_DEVAD_NONE, 0x1d, 0x1f); + phy_write(phydev, MDIO_DEVAD_NONE, 0x1e, 0x8); + + /* rgmii tx clock delay enable */ + phy_write(phydev, MDIO_DEVAD_NONE, 0x1d, 0x05); + phy_write(phydev, MDIO_DEVAD_NONE, 0x1e, 0x100); + + if (phydev->drv->config) + phydev->drv->config(phydev); + + return 0; +} + int board_early_init_f(void) { setup_iomux_uart(); setup_i2c(1, CONFIG_SYS_I2C_SPEED, 0x7f, &i2c_pad_info1);
+ /* Enable PERI_3V3, which is used by SD2, ENET, LVDS, BT */ + imx_iomux_v3_setup_multiple_pads(peri_3v3_pads, + ARRAY_SIZE(peri_3v3_pads)); + + /* Active high for ncp692 */ + gpio_direction_output(IMX_GPIO_NR(4, 16) , 1); + return 0; }
diff --git a/include/configs/mx6sxsabresd.h b/include/configs/mx6sxsabresd.h index 7967b5d..1eda65e 100644 --- a/include/configs/mx6sxsabresd.h +++ b/include/configs/mx6sxsabresd.h @@ -181,6 +181,23 @@ #define CONFIG_POWER_PFUZE100 #define CONFIG_POWER_PFUZE100_I2C_ADDR 0x08
+/* Network */ +#define CONFIG_CMD_PING +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_MII +#define CONFIG_CMD_NET +#define CONFIG_FEC_MXC +#define CONFIG_MII + +#define IMX_FEC_BASE ENET_BASE_ADDR +#define CONFIG_FEC_MXC_PHYADDR 0x1 + +#define CONFIG_FEC_XCV_TYPE RGMII +#define CONFIG_ETHPRIME "FEC" + +#define CONFIG_PHYLIB +#define CONFIG_PHY_ATHEROS + /* FLASH and environment organization */ #define CONFIG_SYS_NO_FLASH
Configure and enable the ethernet clock for mx6solox.
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- arch/arm/cpu/armv7/mx6/clock.c | 21 +++++++++++++++++++++ 1 file changed, 21 insertions(+)
diff --git a/arch/arm/cpu/armv7/mx6/clock.c b/arch/arm/cpu/armv7/mx6/clock.c index abd9d61..820b8d5 100644 --- a/arch/arm/cpu/armv7/mx6/clock.c +++ b/arch/arm/cpu/armv7/mx6/clock.c @@ -373,6 +373,27 @@ int enable_fec_anatop_clock(enum enet_freq freq) reg &= ~BM_ANADIG_PLL_ENET_BYPASS; writel(reg, &anatop->pll_enet);
+#ifdef CONFIG_MX6SX + /* + * Set enet ahb clock to 200MHz + * pll2_pfd2_396m-> ENET_PODF-> ENET_AHB + */ + reg = readl(&imx_ccm->chsccdr); + reg &= ~(MXC_CCM_CHSCCDR_ENET_PRE_CLK_SEL_MASK + | MXC_CCM_CHSCCDR_ENET_PODF_MASK + | MXC_CCM_CHSCCDR_ENET_CLK_SEL_MASK); + /* PLL2 PFD2 */ + reg |= (4 << MXC_CCM_CHSCCDR_ENET_PRE_CLK_SEL_OFFSET); + /* Div = 2*/ + reg |= (1 << MXC_CCM_CHSCCDR_ENET_PODF_OFFSET); + reg |= (0 << MXC_CCM_CHSCCDR_ENET_CLK_SEL_OFFSET); + writel(reg, &imx_ccm->chsccdr); + + /* Enable enet system clock */ + reg = readl(&imx_ccm->CCGR3); + reg |= MXC_CCM_CCGR3_ENET_MASK; + writel(reg, &imx_ccm->CCGR3); +#endif return 0; } #endif
Hi Fabio,
- reg = readl(&imx_ccm->chsccdr);
- reg &= ~(MXC_CCM_CHSCCDR_ENET_PRE_CLK_SEL_MASK
- /* PLL2 PFD2 */
- reg |= (4 << MXC_CCM_CHSCCDR_ENET_PRE_CLK_SEL_OFFSET);
- /* Div = 2*/
- reg |= (1 << MXC_CCM_CHSCCDR_ENET_PODF_OFFSET);
- reg |= (0 << MXC_CCM_CHSCCDR_ENET_CLK_SEL_OFFSET);
- writel(reg, &imx_ccm->chsccdr);
- /* Enable enet system clock */
- reg = readl(&imx_ccm->CCGR3);
- reg |= MXC_CCM_CCGR3_ENET_MASK;
- writel(reg, &imx_ccm->CCGR3);
Best regards, Stefano Babic
Hi Fabio,
This is ok for me. Please feel free to send the additional patch fixing FEC behavior.
Fabio Estevam
Stefano Babic
