[PATCH] powerpc: Fix incorrect SYS_IMMR migration values
When migrating SYS_IMMR, I didn't allow for boards to provide non-default values here. This lead to an incorrect migration on the platforms where CONFIG_SYS_IMMR is set to CONFIG_SYS_CCSRBAR and CONFIG_SYS_CSSRBAR is NOT the same as CONFIG_SYS_CCSRBAR_DEFAULT. Add text to the prompt so that non-default values can be used and re-migrate the platforms that have CONFIG_SYS_IMMR=CONFIG_SYS_CSSRBAR where CONFIG_SYS_CSSRBAR != CONFIG_SYS_CCSRBAR_DEFAULT.
Fixes: be7dbb60c5bf ("Convert CONFIG_SYS_IMMR to Kconfig") Reported-by: Pali Rohár pali@kernel.org Signed-off-by: Tom Rini trini@konsulko.com --- arch/Kconfig | 2 +- configs/MPC8548CDS_36BIT_defconfig | 1 + configs/MPC8548CDS_defconfig | 1 + configs/MPC8548CDS_legacy_defconfig | 1 + configs/P1010RDB-PA_36BIT_NAND_defconfig | 1 + configs/P1010RDB-PA_36BIT_NOR_defconfig | 1 + configs/P1010RDB-PA_36BIT_SDCARD_defconfig | 1 + configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig | 1 + configs/P1010RDB-PA_NAND_defconfig | 1 + configs/P1010RDB-PA_NOR_defconfig | 1 + configs/P1010RDB-PA_SDCARD_defconfig | 1 + configs/P1010RDB-PA_SPIFLASH_defconfig | 1 + configs/P1010RDB-PB_36BIT_NAND_defconfig | 1 + configs/P1010RDB-PB_36BIT_NOR_defconfig | 1 + configs/P1010RDB-PB_36BIT_SDCARD_defconfig | 1 + configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig | 1 + configs/P1010RDB-PB_NAND_defconfig | 1 + configs/P1010RDB-PB_NOR_defconfig | 1 + configs/P1010RDB-PB_SDCARD_defconfig | 1 + configs/P1010RDB-PB_SPIFLASH_defconfig | 1 + configs/P1020RDB-PC_36BIT_NAND_defconfig | 1 + configs/P1020RDB-PC_36BIT_SDCARD_defconfig | 1 + configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig | 1 + configs/P1020RDB-PC_36BIT_defconfig | 1 + configs/P1020RDB-PC_NAND_defconfig | 1 + configs/P1020RDB-PC_SDCARD_defconfig | 1 + configs/P1020RDB-PC_SPIFLASH_defconfig | 1 + configs/P1020RDB-PC_defconfig | 1 + configs/P1020RDB-PD_NAND_defconfig | 1 + configs/P1020RDB-PD_SDCARD_defconfig | 1 + configs/P1020RDB-PD_SPIFLASH_defconfig | 1 + configs/P1020RDB-PD_defconfig | 1 + configs/P2020RDB-PC_36BIT_NAND_defconfig | 1 + configs/P2020RDB-PC_36BIT_SDCARD_defconfig | 1 + configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig | 1 + configs/P2020RDB-PC_36BIT_defconfig | 1 + configs/P2020RDB-PC_NAND_defconfig | 1 + configs/P2020RDB-PC_SDCARD_defconfig | 1 + configs/P2020RDB-PC_SPIFLASH_defconfig | 1 + configs/P2020RDB-PC_defconfig | 1 + configs/socrates_defconfig | 1 + 41 files changed, 41 insertions(+), 1 deletion(-)
diff --git a/arch/Kconfig b/arch/Kconfig index e6191446a357..7ecb375b6b5a 100644 --- a/arch/Kconfig +++ b/arch/Kconfig @@ -363,7 +363,7 @@ config SYS_DISABLE_DCACHE_OPS this functionality.
config SYS_IMMR - hex + hex "Address for the Internal Memory-Mapped Registers (IMMR) window" depends on PPC || FSL_LSCH2 || FSL_LSCH3 || ARCH_LS1021A default 0xFF000000 if MPC8xx default 0xF0000000 if ARCH_MPC8313 diff --git a/configs/MPC8548CDS_36BIT_defconfig b/configs/MPC8548CDS_36BIT_defconfig index d6351d5b11b9..240c6bec3758 100644 --- a/configs/MPC8548CDS_36BIT_defconfig +++ b/configs/MPC8548CDS_36BIT_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_SYS_IMMR=0xE0000000 CONFIG_SYS_TEXT_BASE=0xFFF80000 CONFIG_SYS_MALLOC_LEN=0x100000 CONFIG_ENV_SIZE=0x2000 diff --git a/configs/MPC8548CDS_defconfig b/configs/MPC8548CDS_defconfig index da0b80b09d7b..434ab0939b0b 100644 --- a/configs/MPC8548CDS_defconfig +++ b/configs/MPC8548CDS_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_SYS_IMMR=0xE0000000 CONFIG_SYS_TEXT_BASE=0xFFF80000 CONFIG_SYS_MALLOC_LEN=0x100000 CONFIG_ENV_SIZE=0x2000 diff --git a/configs/MPC8548CDS_legacy_defconfig b/configs/MPC8548CDS_legacy_defconfig index 87d1fd716c95..eb8233dfd67e 100644 --- a/configs/MPC8548CDS_legacy_defconfig +++ b/configs/MPC8548CDS_legacy_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_SYS_IMMR=0xE0000000 CONFIG_SYS_TEXT_BASE=0xFFF80000 CONFIG_SYS_MALLOC_LEN=0x100000 CONFIG_ENV_SIZE=0x2000 diff --git a/configs/P1010RDB-PA_36BIT_NAND_defconfig b/configs/P1010RDB-PA_36BIT_NAND_defconfig index 61fd2a78a4e3..314d73a8ae1e 100644 --- a/configs/P1010RDB-PA_36BIT_NAND_defconfig +++ b/configs/P1010RDB-PA_36BIT_NAND_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_SYS_IMMR=0xFFE00000 CONFIG_SYS_TEXT_BASE=0x11001000 CONFIG_SYS_MALLOC_LEN=0x100000 CONFIG_ENV_SIZE=0x4000 diff --git a/configs/P1010RDB-PA_36BIT_NOR_defconfig b/configs/P1010RDB-PA_36BIT_NOR_defconfig index 0e537ebb5213..ebfb9c43f7ae 100644 --- a/configs/P1010RDB-PA_36BIT_NOR_defconfig +++ b/configs/P1010RDB-PA_36BIT_NOR_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_SYS_IMMR=0xFFE00000 CONFIG_SYS_TEXT_BASE=0xEFF40000 CONFIG_SYS_MALLOC_LEN=0x100000 CONFIG_ENV_SIZE=0x2000 diff --git a/configs/P1010RDB-PA_36BIT_SDCARD_defconfig b/configs/P1010RDB-PA_36BIT_SDCARD_defconfig index dc113be28d90..ca149b0b26d4 100644 --- a/configs/P1010RDB-PA_36BIT_SDCARD_defconfig +++ b/configs/P1010RDB-PA_36BIT_SDCARD_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_SYS_IMMR=0xFFE00000 CONFIG_SYS_TEXT_BASE=0x11001000 CONFIG_SYS_MALLOC_LEN=0x100000 CONFIG_SPL_LIBCOMMON_SUPPORT=y diff --git a/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig b/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig index cd5c80c6346c..0d1f1568e2d6 100644 --- a/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig +++ b/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_SYS_IMMR=0xFFE00000 CONFIG_SYS_TEXT_BASE=0x11001000 CONFIG_SYS_MALLOC_LEN=0x100000 CONFIG_SPL_LIBCOMMON_SUPPORT=y diff --git a/configs/P1010RDB-PA_NAND_defconfig b/configs/P1010RDB-PA_NAND_defconfig index f80a0d929c13..fde12ea861b6 100644 --- a/configs/P1010RDB-PA_NAND_defconfig +++ b/configs/P1010RDB-PA_NAND_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_SYS_IMMR=0xFFE00000 CONFIG_SYS_TEXT_BASE=0x11001000 CONFIG_SYS_MALLOC_LEN=0x100000 CONFIG_ENV_SIZE=0x4000 diff --git a/configs/P1010RDB-PA_NOR_defconfig b/configs/P1010RDB-PA_NOR_defconfig index 035aac226bb5..eeda2dd4cd50 100644 --- a/configs/P1010RDB-PA_NOR_defconfig +++ b/configs/P1010RDB-PA_NOR_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_SYS_IMMR=0xFFE00000 CONFIG_SYS_TEXT_BASE=0xEFF40000 CONFIG_SYS_MALLOC_LEN=0x100000 CONFIG_ENV_SIZE=0x2000 diff --git a/configs/P1010RDB-PA_SDCARD_defconfig b/configs/P1010RDB-PA_SDCARD_defconfig index cd031d218c38..0032f2779099 100644 --- a/configs/P1010RDB-PA_SDCARD_defconfig +++ b/configs/P1010RDB-PA_SDCARD_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_SYS_IMMR=0xFFE00000 CONFIG_SYS_TEXT_BASE=0x11001000 CONFIG_SYS_MALLOC_LEN=0x100000 CONFIG_SPL_LIBCOMMON_SUPPORT=y diff --git a/configs/P1010RDB-PA_SPIFLASH_defconfig b/configs/P1010RDB-PA_SPIFLASH_defconfig index f339502637b7..e40cd4f93d01 100644 --- a/configs/P1010RDB-PA_SPIFLASH_defconfig +++ b/configs/P1010RDB-PA_SPIFLASH_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_SYS_IMMR=0xFFE00000 CONFIG_SYS_TEXT_BASE=0x11001000 CONFIG_SYS_MALLOC_LEN=0x100000 CONFIG_SPL_LIBCOMMON_SUPPORT=y diff --git a/configs/P1010RDB-PB_36BIT_NAND_defconfig b/configs/P1010RDB-PB_36BIT_NAND_defconfig index ba64f8818fb8..f6dfc16edef3 100644 --- a/configs/P1010RDB-PB_36BIT_NAND_defconfig +++ b/configs/P1010RDB-PB_36BIT_NAND_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_SYS_IMMR=0xFFE00000 CONFIG_SYS_TEXT_BASE=0x11001000 CONFIG_SYS_MALLOC_LEN=0x100000 CONFIG_ENV_SIZE=0x4000 diff --git a/configs/P1010RDB-PB_36BIT_NOR_defconfig b/configs/P1010RDB-PB_36BIT_NOR_defconfig index a8e95568714d..acaba8539b77 100644 --- a/configs/P1010RDB-PB_36BIT_NOR_defconfig +++ b/configs/P1010RDB-PB_36BIT_NOR_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_SYS_IMMR=0xFFE00000 CONFIG_SYS_TEXT_BASE=0xEFF40000 CONFIG_SYS_MALLOC_LEN=0x100000 CONFIG_ENV_SIZE=0x2000 diff --git a/configs/P1010RDB-PB_36BIT_SDCARD_defconfig b/configs/P1010RDB-PB_36BIT_SDCARD_defconfig index 871996711db3..6a346fba2ac2 100644 --- a/configs/P1010RDB-PB_36BIT_SDCARD_defconfig +++ b/configs/P1010RDB-PB_36BIT_SDCARD_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_SYS_IMMR=0xFFE00000 CONFIG_SYS_TEXT_BASE=0x11001000 CONFIG_SYS_MALLOC_LEN=0x100000 CONFIG_SPL_LIBCOMMON_SUPPORT=y diff --git a/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig b/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig index 2d646f9f54d9..5e31d18a5f8f 100644 --- a/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig +++ b/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_SYS_IMMR=0xFFE00000 CONFIG_SYS_TEXT_BASE=0x11001000 CONFIG_SYS_MALLOC_LEN=0x100000 CONFIG_SPL_LIBCOMMON_SUPPORT=y diff --git a/configs/P1010RDB-PB_NAND_defconfig b/configs/P1010RDB-PB_NAND_defconfig index f8437ff032f9..be614b85b725 100644 --- a/configs/P1010RDB-PB_NAND_defconfig +++ b/configs/P1010RDB-PB_NAND_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_SYS_IMMR=0xFFE00000 CONFIG_SYS_TEXT_BASE=0x11001000 CONFIG_SYS_MALLOC_LEN=0x100000 CONFIG_ENV_SIZE=0x4000 diff --git a/configs/P1010RDB-PB_NOR_defconfig b/configs/P1010RDB-PB_NOR_defconfig index b99531c4cd90..261ca79c7aea 100644 --- a/configs/P1010RDB-PB_NOR_defconfig +++ b/configs/P1010RDB-PB_NOR_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_SYS_IMMR=0xFFE00000 CONFIG_SYS_TEXT_BASE=0xEFF40000 CONFIG_SYS_MALLOC_LEN=0x100000 CONFIG_ENV_SIZE=0x2000 diff --git a/configs/P1010RDB-PB_SDCARD_defconfig b/configs/P1010RDB-PB_SDCARD_defconfig index ebe2af6f4a1d..e102207afff3 100644 --- a/configs/P1010RDB-PB_SDCARD_defconfig +++ b/configs/P1010RDB-PB_SDCARD_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_SYS_IMMR=0xFFE00000 CONFIG_SYS_TEXT_BASE=0x11001000 CONFIG_SYS_MALLOC_LEN=0x100000 CONFIG_SPL_LIBCOMMON_SUPPORT=y diff --git a/configs/P1010RDB-PB_SPIFLASH_defconfig b/configs/P1010RDB-PB_SPIFLASH_defconfig index 7893782fa445..52dfbbaae3ac 100644 --- a/configs/P1010RDB-PB_SPIFLASH_defconfig +++ b/configs/P1010RDB-PB_SPIFLASH_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_SYS_IMMR=0xFFE00000 CONFIG_SYS_TEXT_BASE=0x11001000 CONFIG_SYS_MALLOC_LEN=0x100000 CONFIG_SPL_LIBCOMMON_SUPPORT=y diff --git a/configs/P1020RDB-PC_36BIT_NAND_defconfig b/configs/P1020RDB-PC_36BIT_NAND_defconfig index 30b841d691bd..a8bc420f638e 100644 --- a/configs/P1020RDB-PC_36BIT_NAND_defconfig +++ b/configs/P1020RDB-PC_36BIT_NAND_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_SYS_IMMR=0xFFE00000 CONFIG_SYS_TEXT_BASE=0x11001000 CONFIG_SYS_MALLOC_LEN=0x100000 CONFIG_ENV_SIZE=0x4000 diff --git a/configs/P1020RDB-PC_36BIT_SDCARD_defconfig b/configs/P1020RDB-PC_36BIT_SDCARD_defconfig index 79edbf388d49..e9ee3cfdb110 100644 --- a/configs/P1020RDB-PC_36BIT_SDCARD_defconfig +++ b/configs/P1020RDB-PC_36BIT_SDCARD_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_SYS_IMMR=0xFFE00000 CONFIG_SYS_TEXT_BASE=0x11001000 CONFIG_SYS_MALLOC_LEN=0x100000 CONFIG_SPL_LIBCOMMON_SUPPORT=y diff --git a/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig b/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig index c5a64de98e08..3f5a7cee0e22 100644 --- a/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig +++ b/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_SYS_IMMR=0xFFE00000 CONFIG_SYS_TEXT_BASE=0x11001000 CONFIG_SYS_MALLOC_LEN=0x100000 CONFIG_SPL_LIBCOMMON_SUPPORT=y diff --git a/configs/P1020RDB-PC_36BIT_defconfig b/configs/P1020RDB-PC_36BIT_defconfig index 9671a6d33008..6b3685bc365c 100644 --- a/configs/P1020RDB-PC_36BIT_defconfig +++ b/configs/P1020RDB-PC_36BIT_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_SYS_IMMR=0xFFE00000 CONFIG_SYS_TEXT_BASE=0xEFF40000 CONFIG_SYS_MALLOC_LEN=0x100000 CONFIG_ENV_SIZE=0x2000 diff --git a/configs/P1020RDB-PC_NAND_defconfig b/configs/P1020RDB-PC_NAND_defconfig index 0201c51a5d0d..3a41738eede4 100644 --- a/configs/P1020RDB-PC_NAND_defconfig +++ b/configs/P1020RDB-PC_NAND_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_SYS_IMMR=0xFFE00000 CONFIG_SYS_TEXT_BASE=0x11001000 CONFIG_SYS_MALLOC_LEN=0x100000 CONFIG_ENV_SIZE=0x4000 diff --git a/configs/P1020RDB-PC_SDCARD_defconfig b/configs/P1020RDB-PC_SDCARD_defconfig index 371a8b5f8b84..395f0b2d8914 100644 --- a/configs/P1020RDB-PC_SDCARD_defconfig +++ b/configs/P1020RDB-PC_SDCARD_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_SYS_IMMR=0xFFE00000 CONFIG_SYS_TEXT_BASE=0x11001000 CONFIG_SYS_MALLOC_LEN=0x100000 CONFIG_SPL_LIBCOMMON_SUPPORT=y diff --git a/configs/P1020RDB-PC_SPIFLASH_defconfig b/configs/P1020RDB-PC_SPIFLASH_defconfig index 7c8b3c826cd0..5269c39ce98f 100644 --- a/configs/P1020RDB-PC_SPIFLASH_defconfig +++ b/configs/P1020RDB-PC_SPIFLASH_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_SYS_IMMR=0xFFE00000 CONFIG_SYS_TEXT_BASE=0x11001000 CONFIG_SYS_MALLOC_LEN=0x100000 CONFIG_SPL_LIBCOMMON_SUPPORT=y diff --git a/configs/P1020RDB-PC_defconfig b/configs/P1020RDB-PC_defconfig index 01b4fd363c40..dbe90e785be7 100644 --- a/configs/P1020RDB-PC_defconfig +++ b/configs/P1020RDB-PC_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_SYS_IMMR=0xFFE00000 CONFIG_SYS_TEXT_BASE=0xEFF40000 CONFIG_SYS_MALLOC_LEN=0x100000 CONFIG_ENV_SIZE=0x2000 diff --git a/configs/P1020RDB-PD_NAND_defconfig b/configs/P1020RDB-PD_NAND_defconfig index e70c1a7cbae6..bc277c600d01 100644 --- a/configs/P1020RDB-PD_NAND_defconfig +++ b/configs/P1020RDB-PD_NAND_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_SYS_IMMR=0xFFE00000 CONFIG_SYS_TEXT_BASE=0x11001000 CONFIG_SYS_MALLOC_LEN=0x100000 CONFIG_ENV_SIZE=0x20000 diff --git a/configs/P1020RDB-PD_SDCARD_defconfig b/configs/P1020RDB-PD_SDCARD_defconfig index 2596b5255d35..ed6b3393c27a 100644 --- a/configs/P1020RDB-PD_SDCARD_defconfig +++ b/configs/P1020RDB-PD_SDCARD_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_SYS_IMMR=0xFFE00000 CONFIG_SYS_TEXT_BASE=0x11001000 CONFIG_SYS_MALLOC_LEN=0x100000 CONFIG_SPL_LIBCOMMON_SUPPORT=y diff --git a/configs/P1020RDB-PD_SPIFLASH_defconfig b/configs/P1020RDB-PD_SPIFLASH_defconfig index f6f8888c82a7..7cad6ce45240 100644 --- a/configs/P1020RDB-PD_SPIFLASH_defconfig +++ b/configs/P1020RDB-PD_SPIFLASH_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_SYS_IMMR=0xFFE00000 CONFIG_SYS_TEXT_BASE=0x11001000 CONFIG_SYS_MALLOC_LEN=0x100000 CONFIG_SPL_LIBCOMMON_SUPPORT=y diff --git a/configs/P1020RDB-PD_defconfig b/configs/P1020RDB-PD_defconfig index e1a4965caae5..ccf251478f7d 100644 --- a/configs/P1020RDB-PD_defconfig +++ b/configs/P1020RDB-PD_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_SYS_IMMR=0xFFE00000 CONFIG_SYS_TEXT_BASE=0xEFF40000 CONFIG_SYS_MALLOC_LEN=0x100000 CONFIG_ENV_SIZE=0x2000 diff --git a/configs/P2020RDB-PC_36BIT_NAND_defconfig b/configs/P2020RDB-PC_36BIT_NAND_defconfig index 2c302b682168..3f3d30f2f132 100644 --- a/configs/P2020RDB-PC_36BIT_NAND_defconfig +++ b/configs/P2020RDB-PC_36BIT_NAND_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_SYS_IMMR=0xFFE00000 CONFIG_SYS_TEXT_BASE=0x11001000 CONFIG_SYS_MALLOC_LEN=0x100000 CONFIG_ENV_SIZE=0x4000 diff --git a/configs/P2020RDB-PC_36BIT_SDCARD_defconfig b/configs/P2020RDB-PC_36BIT_SDCARD_defconfig index 2d080713e7a2..3acb251e1e0d 100644 --- a/configs/P2020RDB-PC_36BIT_SDCARD_defconfig +++ b/configs/P2020RDB-PC_36BIT_SDCARD_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_SYS_IMMR=0xFFE00000 CONFIG_SYS_TEXT_BASE=0x11001000 CONFIG_SYS_MALLOC_LEN=0x100000 CONFIG_SPL_LIBCOMMON_SUPPORT=y diff --git a/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig b/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig index 7b53b0251711..e545c294e09a 100644 --- a/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig +++ b/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_SYS_IMMR=0xFFE00000 CONFIG_SYS_TEXT_BASE=0x11001000 CONFIG_SYS_MALLOC_LEN=0x100000 CONFIG_SPL_LIBCOMMON_SUPPORT=y diff --git a/configs/P2020RDB-PC_36BIT_defconfig b/configs/P2020RDB-PC_36BIT_defconfig index 5e8a474c905a..4c120e5722b6 100644 --- a/configs/P2020RDB-PC_36BIT_defconfig +++ b/configs/P2020RDB-PC_36BIT_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_SYS_IMMR=0xFFE00000 CONFIG_SYS_TEXT_BASE=0xEFF40000 CONFIG_SYS_MALLOC_LEN=0x100000 CONFIG_ENV_SIZE=0x2000 diff --git a/configs/P2020RDB-PC_NAND_defconfig b/configs/P2020RDB-PC_NAND_defconfig index 74165dc60aa7..73e8a5c5714c 100644 --- a/configs/P2020RDB-PC_NAND_defconfig +++ b/configs/P2020RDB-PC_NAND_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_SYS_IMMR=0xFFE00000 CONFIG_SYS_TEXT_BASE=0x11001000 CONFIG_SYS_MALLOC_LEN=0x100000 CONFIG_ENV_SIZE=0x4000 diff --git a/configs/P2020RDB-PC_SDCARD_defconfig b/configs/P2020RDB-PC_SDCARD_defconfig index 0505f40a8148..614ff521b90e 100644 --- a/configs/P2020RDB-PC_SDCARD_defconfig +++ b/configs/P2020RDB-PC_SDCARD_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_SYS_IMMR=0xFFE00000 CONFIG_SYS_TEXT_BASE=0x11001000 CONFIG_SYS_MALLOC_LEN=0x100000 CONFIG_SPL_LIBCOMMON_SUPPORT=y diff --git a/configs/P2020RDB-PC_SPIFLASH_defconfig b/configs/P2020RDB-PC_SPIFLASH_defconfig index f1085fde4702..325a238fbfab 100644 --- a/configs/P2020RDB-PC_SPIFLASH_defconfig +++ b/configs/P2020RDB-PC_SPIFLASH_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_SYS_IMMR=0xFFE00000 CONFIG_SYS_TEXT_BASE=0x11001000 CONFIG_SYS_MALLOC_LEN=0x100000 CONFIG_SPL_LIBCOMMON_SUPPORT=y diff --git a/configs/P2020RDB-PC_defconfig b/configs/P2020RDB-PC_defconfig index f933ed42fced..15f2a97df2d1 100644 --- a/configs/P2020RDB-PC_defconfig +++ b/configs/P2020RDB-PC_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_SYS_IMMR=0xFFE00000 CONFIG_SYS_TEXT_BASE=0xEFF40000 CONFIG_SYS_MALLOC_LEN=0x100000 CONFIG_ENV_SIZE=0x2000 diff --git a/configs/socrates_defconfig b/configs/socrates_defconfig index bad08e79c9f4..f9815ca581f1 100644 --- a/configs/socrates_defconfig +++ b/configs/socrates_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_SYS_IMMR=0xE0000000 CONFIG_SYS_TEXT_BASE=0xfff80000 CONFIG_ENV_SIZE=0x4000 CONFIG_ENV_SECT_SIZE=0x20000
For P2020RDB-PC_SDCARD_defconfig: Tested-by: Pali Rohár pali@kernel.org
config SYS_IMMR
- hex
- hex "Address for the Internal Memory-Mapped Registers (IMMR) window" depends on PPC || FSL_LSCH2 || FSL_LSCH3 || ARCH_LS1021A default 0xFF000000 if MPC8xx default 0xF0000000 if ARCH_MPC8313
diff --git a/configs/MPC8548CDS_36BIT_defconfig b/configs/MPC8548CDS_36BIT_defconfig index d6351d5b11b9..240c6bec3758 100644 --- a/configs/MPC8548CDS_36BIT_defconfig +++ b/configs/MPC8548CDS_36BIT_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_SYS_IMMR=0xE0000000 CONFIG_SYS_TEXT_BASE=0xFFF80000 CONFIG_SYS_MALLOC_LEN=0x100000 CONFIG_ENV_SIZE=0x2000 diff --git a/configs/MPC8548CDS_defconfig b/configs/MPC8548CDS_defconfig index da0b80b09d7b..434ab0939b0b 100644 --- a/configs/MPC8548CDS_defconfig +++ b/configs/MPC8548CDS_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_SYS_IMMR=0xE0000000 CONFIG_SYS_TEXT_BASE=0xFFF80000 CONFIG_SYS_MALLOC_LEN=0x100000 CONFIG_ENV_SIZE=0x2000 diff --git a/configs/MPC8548CDS_legacy_defconfig b/configs/MPC8548CDS_legacy_defconfig index 87d1fd716c95..eb8233dfd67e 100644 --- a/configs/MPC8548CDS_legacy_defconfig +++ b/configs/MPC8548CDS_legacy_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_SYS_IMMR=0xE0000000 CONFIG_SYS_TEXT_BASE=0xFFF80000 CONFIG_SYS_MALLOC_LEN=0x100000 CONFIG_ENV_SIZE=0x2000 diff --git a/configs/P1010RDB-PA_36BIT_NAND_defconfig b/configs/P1010RDB-PA_36BIT_NAND_defconfig index 61fd2a78a4e3..314d73a8ae1e 100644 --- a/configs/P1010RDB-PA_36BIT_NAND_defconfig +++ b/configs/P1010RDB-PA_36BIT_NAND_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_SYS_IMMR=0xFFE00000 CONFIG_SYS_TEXT_BASE=0x11001000 CONFIG_SYS_MALLOC_LEN=0x100000 CONFIG_ENV_SIZE=0x4000 diff --git a/configs/P1010RDB-PA_36BIT_NOR_defconfig b/configs/P1010RDB-PA_36BIT_NOR_defconfig index 0e537ebb5213..ebfb9c43f7ae 100644 --- a/configs/P1010RDB-PA_36BIT_NOR_defconfig +++ b/configs/P1010RDB-PA_36BIT_NOR_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_SYS_IMMR=0xFFE00000 CONFIG_SYS_TEXT_BASE=0xEFF40000 CONFIG_SYS_MALLOC_LEN=0x100000 CONFIG_ENV_SIZE=0x2000 diff --git a/configs/P1010RDB-PA_36BIT_SDCARD_defconfig b/configs/P1010RDB-PA_36BIT_SDCARD_defconfig index dc113be28d90..ca149b0b26d4 100644 --- a/configs/P1010RDB-PA_36BIT_SDCARD_defconfig +++ b/configs/P1010RDB-PA_36BIT_SDCARD_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_SYS_IMMR=0xFFE00000 CONFIG_SYS_TEXT_BASE=0x11001000 CONFIG_SYS_MALLOC_LEN=0x100000 CONFIG_SPL_LIBCOMMON_SUPPORT=y diff --git a/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig b/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig index cd5c80c6346c..0d1f1568e2d6 100644 --- a/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig +++ b/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_SYS_IMMR=0xFFE00000 CONFIG_SYS_TEXT_BASE=0x11001000 CONFIG_SYS_MALLOC_LEN=0x100000 CONFIG_SPL_LIBCOMMON_SUPPORT=y diff --git a/configs/P1010RDB-PA_NAND_defconfig b/configs/P1010RDB-PA_NAND_defconfig index f80a0d929c13..fde12ea861b6 100644 --- a/configs/P1010RDB-PA_NAND_defconfig +++ b/configs/P1010RDB-PA_NAND_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_SYS_IMMR=0xFFE00000 CONFIG_SYS_TEXT_BASE=0x11001000 CONFIG_SYS_MALLOC_LEN=0x100000 CONFIG_ENV_SIZE=0x4000 diff --git a/configs/P1010RDB-PA_NOR_defconfig b/configs/P1010RDB-PA_NOR_defconfig index 035aac226bb5..eeda2dd4cd50 100644 --- a/configs/P1010RDB-PA_NOR_defconfig +++ b/configs/P1010RDB-PA_NOR_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_SYS_IMMR=0xFFE00000 CONFIG_SYS_TEXT_BASE=0xEFF40000 CONFIG_SYS_MALLOC_LEN=0x100000 CONFIG_ENV_SIZE=0x2000 diff --git a/configs/P1010RDB-PA_SDCARD_defconfig b/configs/P1010RDB-PA_SDCARD_defconfig index cd031d218c38..0032f2779099 100644 --- a/configs/P1010RDB-PA_SDCARD_defconfig +++ b/configs/P1010RDB-PA_SDCARD_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_SYS_IMMR=0xFFE00000 CONFIG_SYS_TEXT_BASE=0x11001000 CONFIG_SYS_MALLOC_LEN=0x100000 CONFIG_SPL_LIBCOMMON_SUPPORT=y diff --git a/configs/P1010RDB-PA_SPIFLASH_defconfig b/configs/P1010RDB-PA_SPIFLASH_defconfig index f339502637b7..e40cd4f93d01 100644 --- a/configs/P1010RDB-PA_SPIFLASH_defconfig +++ b/configs/P1010RDB-PA_SPIFLASH_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_SYS_IMMR=0xFFE00000 CONFIG_SYS_TEXT_BASE=0x11001000 CONFIG_SYS_MALLOC_LEN=0x100000 CONFIG_SPL_LIBCOMMON_SUPPORT=y diff --git a/configs/P1010RDB-PB_36BIT_NAND_defconfig b/configs/P1010RDB-PB_36BIT_NAND_defconfig index ba64f8818fb8..f6dfc16edef3 100644 --- a/configs/P1010RDB-PB_36BIT_NAND_defconfig +++ b/configs/P1010RDB-PB_36BIT_NAND_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_SYS_IMMR=0xFFE00000 CONFIG_SYS_TEXT_BASE=0x11001000 CONFIG_SYS_MALLOC_LEN=0x100000 CONFIG_ENV_SIZE=0x4000 diff --git a/configs/P1010RDB-PB_36BIT_NOR_defconfig b/configs/P1010RDB-PB_36BIT_NOR_defconfig index a8e95568714d..acaba8539b77 100644 --- a/configs/P1010RDB-PB_36BIT_NOR_defconfig +++ b/configs/P1010RDB-PB_36BIT_NOR_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_SYS_IMMR=0xFFE00000 CONFIG_SYS_TEXT_BASE=0xEFF40000 CONFIG_SYS_MALLOC_LEN=0x100000 CONFIG_ENV_SIZE=0x2000 diff --git a/configs/P1010RDB-PB_36BIT_SDCARD_defconfig b/configs/P1010RDB-PB_36BIT_SDCARD_defconfig index 871996711db3..6a346fba2ac2 100644 --- a/configs/P1010RDB-PB_36BIT_SDCARD_defconfig +++ b/configs/P1010RDB-PB_36BIT_SDCARD_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_SYS_IMMR=0xFFE00000 CONFIG_SYS_TEXT_BASE=0x11001000 CONFIG_SYS_MALLOC_LEN=0x100000 CONFIG_SPL_LIBCOMMON_SUPPORT=y diff --git a/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig b/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig index 2d646f9f54d9..5e31d18a5f8f 100644 --- a/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig +++ b/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_SYS_IMMR=0xFFE00000 CONFIG_SYS_TEXT_BASE=0x11001000 CONFIG_SYS_MALLOC_LEN=0x100000 CONFIG_SPL_LIBCOMMON_SUPPORT=y diff --git a/configs/P1010RDB-PB_NAND_defconfig b/configs/P1010RDB-PB_NAND_defconfig index f8437ff032f9..be614b85b725 100644 --- a/configs/P1010RDB-PB_NAND_defconfig +++ b/configs/P1010RDB-PB_NAND_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_SYS_IMMR=0xFFE00000 CONFIG_SYS_TEXT_BASE=0x11001000 CONFIG_SYS_MALLOC_LEN=0x100000 CONFIG_ENV_SIZE=0x4000 diff --git a/configs/P1010RDB-PB_NOR_defconfig b/configs/P1010RDB-PB_NOR_defconfig index b99531c4cd90..261ca79c7aea 100644 --- a/configs/P1010RDB-PB_NOR_defconfig +++ b/configs/P1010RDB-PB_NOR_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_SYS_IMMR=0xFFE00000 CONFIG_SYS_TEXT_BASE=0xEFF40000 CONFIG_SYS_MALLOC_LEN=0x100000 CONFIG_ENV_SIZE=0x2000 diff --git a/configs/P1010RDB-PB_SDCARD_defconfig b/configs/P1010RDB-PB_SDCARD_defconfig index ebe2af6f4a1d..e102207afff3 100644 --- a/configs/P1010RDB-PB_SDCARD_defconfig +++ b/configs/P1010RDB-PB_SDCARD_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_SYS_IMMR=0xFFE00000 CONFIG_SYS_TEXT_BASE=0x11001000 CONFIG_SYS_MALLOC_LEN=0x100000 CONFIG_SPL_LIBCOMMON_SUPPORT=y diff --git a/configs/P1010RDB-PB_SPIFLASH_defconfig b/configs/P1010RDB-PB_SPIFLASH_defconfig index 7893782fa445..52dfbbaae3ac 100644 --- a/configs/P1010RDB-PB_SPIFLASH_defconfig +++ b/configs/P1010RDB-PB_SPIFLASH_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_SYS_IMMR=0xFFE00000 CONFIG_SYS_TEXT_BASE=0x11001000 CONFIG_SYS_MALLOC_LEN=0x100000 CONFIG_SPL_LIBCOMMON_SUPPORT=y diff --git a/configs/P1020RDB-PC_36BIT_NAND_defconfig b/configs/P1020RDB-PC_36BIT_NAND_defconfig index 30b841d691bd..a8bc420f638e 100644 --- a/configs/P1020RDB-PC_36BIT_NAND_defconfig +++ b/configs/P1020RDB-PC_36BIT_NAND_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_SYS_IMMR=0xFFE00000 CONFIG_SYS_TEXT_BASE=0x11001000 CONFIG_SYS_MALLOC_LEN=0x100000 CONFIG_ENV_SIZE=0x4000 diff --git a/configs/P1020RDB-PC_36BIT_SDCARD_defconfig b/configs/P1020RDB-PC_36BIT_SDCARD_defconfig index 79edbf388d49..e9ee3cfdb110 100644 --- a/configs/P1020RDB-PC_36BIT_SDCARD_defconfig +++ b/configs/P1020RDB-PC_36BIT_SDCARD_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_SYS_IMMR=0xFFE00000 CONFIG_SYS_TEXT_BASE=0x11001000 CONFIG_SYS_MALLOC_LEN=0x100000 CONFIG_SPL_LIBCOMMON_SUPPORT=y diff --git a/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig b/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig index c5a64de98e08..3f5a7cee0e22 100644 --- a/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig +++ b/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_SYS_IMMR=0xFFE00000 CONFIG_SYS_TEXT_BASE=0x11001000 CONFIG_SYS_MALLOC_LEN=0x100000 CONFIG_SPL_LIBCOMMON_SUPPORT=y diff --git a/configs/P1020RDB-PC_36BIT_defconfig b/configs/P1020RDB-PC_36BIT_defconfig index 9671a6d33008..6b3685bc365c 100644 --- a/configs/P1020RDB-PC_36BIT_defconfig +++ b/configs/P1020RDB-PC_36BIT_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_SYS_IMMR=0xFFE00000 CONFIG_SYS_TEXT_BASE=0xEFF40000 CONFIG_SYS_MALLOC_LEN=0x100000 CONFIG_ENV_SIZE=0x2000 diff --git a/configs/P1020RDB-PC_NAND_defconfig b/configs/P1020RDB-PC_NAND_defconfig index 0201c51a5d0d..3a41738eede4 100644 --- a/configs/P1020RDB-PC_NAND_defconfig +++ b/configs/P1020RDB-PC_NAND_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_SYS_IMMR=0xFFE00000 CONFIG_SYS_TEXT_BASE=0x11001000 CONFIG_SYS_MALLOC_LEN=0x100000 CONFIG_ENV_SIZE=0x4000 diff --git a/configs/P1020RDB-PC_SDCARD_defconfig b/configs/P1020RDB-PC_SDCARD_defconfig index 371a8b5f8b84..395f0b2d8914 100644 --- a/configs/P1020RDB-PC_SDCARD_defconfig +++ b/configs/P1020RDB-PC_SDCARD_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_SYS_IMMR=0xFFE00000 CONFIG_SYS_TEXT_BASE=0x11001000 CONFIG_SYS_MALLOC_LEN=0x100000 CONFIG_SPL_LIBCOMMON_SUPPORT=y diff --git a/configs/P1020RDB-PC_SPIFLASH_defconfig b/configs/P1020RDB-PC_SPIFLASH_defconfig index 7c8b3c826cd0..5269c39ce98f 100644 --- a/configs/P1020RDB-PC_SPIFLASH_defconfig +++ b/configs/P1020RDB-PC_SPIFLASH_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_SYS_IMMR=0xFFE00000 CONFIG_SYS_TEXT_BASE=0x11001000 CONFIG_SYS_MALLOC_LEN=0x100000 CONFIG_SPL_LIBCOMMON_SUPPORT=y diff --git a/configs/P1020RDB-PC_defconfig b/configs/P1020RDB-PC_defconfig index 01b4fd363c40..dbe90e785be7 100644 --- a/configs/P1020RDB-PC_defconfig +++ b/configs/P1020RDB-PC_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_SYS_IMMR=0xFFE00000 CONFIG_SYS_TEXT_BASE=0xEFF40000 CONFIG_SYS_MALLOC_LEN=0x100000 CONFIG_ENV_SIZE=0x2000 diff --git a/configs/P1020RDB-PD_NAND_defconfig b/configs/P1020RDB-PD_NAND_defconfig index e70c1a7cbae6..bc277c600d01 100644 --- a/configs/P1020RDB-PD_NAND_defconfig +++ b/configs/P1020RDB-PD_NAND_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_SYS_IMMR=0xFFE00000 CONFIG_SYS_TEXT_BASE=0x11001000 CONFIG_SYS_MALLOC_LEN=0x100000 CONFIG_ENV_SIZE=0x20000 diff --git a/configs/P1020RDB-PD_SDCARD_defconfig b/configs/P1020RDB-PD_SDCARD_defconfig index 2596b5255d35..ed6b3393c27a 100644 --- a/configs/P1020RDB-PD_SDCARD_defconfig +++ b/configs/P1020RDB-PD_SDCARD_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_SYS_IMMR=0xFFE00000 CONFIG_SYS_TEXT_BASE=0x11001000 CONFIG_SYS_MALLOC_LEN=0x100000 CONFIG_SPL_LIBCOMMON_SUPPORT=y diff --git a/configs/P1020RDB-PD_SPIFLASH_defconfig b/configs/P1020RDB-PD_SPIFLASH_defconfig index f6f8888c82a7..7cad6ce45240 100644 --- a/configs/P1020RDB-PD_SPIFLASH_defconfig +++ b/configs/P1020RDB-PD_SPIFLASH_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_SYS_IMMR=0xFFE00000 CONFIG_SYS_TEXT_BASE=0x11001000 CONFIG_SYS_MALLOC_LEN=0x100000 CONFIG_SPL_LIBCOMMON_SUPPORT=y diff --git a/configs/P1020RDB-PD_defconfig b/configs/P1020RDB-PD_defconfig index e1a4965caae5..ccf251478f7d 100644 --- a/configs/P1020RDB-PD_defconfig +++ b/configs/P1020RDB-PD_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_SYS_IMMR=0xFFE00000 CONFIG_SYS_TEXT_BASE=0xEFF40000 CONFIG_SYS_MALLOC_LEN=0x100000 CONFIG_ENV_SIZE=0x2000 diff --git a/configs/P2020RDB-PC_36BIT_NAND_defconfig b/configs/P2020RDB-PC_36BIT_NAND_defconfig index 2c302b682168..3f3d30f2f132 100644 --- a/configs/P2020RDB-PC_36BIT_NAND_defconfig +++ b/configs/P2020RDB-PC_36BIT_NAND_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_SYS_IMMR=0xFFE00000 CONFIG_SYS_TEXT_BASE=0x11001000 CONFIG_SYS_MALLOC_LEN=0x100000 CONFIG_ENV_SIZE=0x4000 diff --git a/configs/P2020RDB-PC_36BIT_SDCARD_defconfig b/configs/P2020RDB-PC_36BIT_SDCARD_defconfig index 2d080713e7a2..3acb251e1e0d 100644 --- a/configs/P2020RDB-PC_36BIT_SDCARD_defconfig +++ b/configs/P2020RDB-PC_36BIT_SDCARD_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_SYS_IMMR=0xFFE00000 CONFIG_SYS_TEXT_BASE=0x11001000 CONFIG_SYS_MALLOC_LEN=0x100000 CONFIG_SPL_LIBCOMMON_SUPPORT=y diff --git a/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig b/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig index 7b53b0251711..e545c294e09a 100644 --- a/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig +++ b/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_SYS_IMMR=0xFFE00000 CONFIG_SYS_TEXT_BASE=0x11001000 CONFIG_SYS_MALLOC_LEN=0x100000 CONFIG_SPL_LIBCOMMON_SUPPORT=y diff --git a/configs/P2020RDB-PC_36BIT_defconfig b/configs/P2020RDB-PC_36BIT_defconfig index 5e8a474c905a..4c120e5722b6 100644 --- a/configs/P2020RDB-PC_36BIT_defconfig +++ b/configs/P2020RDB-PC_36BIT_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_SYS_IMMR=0xFFE00000 CONFIG_SYS_TEXT_BASE=0xEFF40000 CONFIG_SYS_MALLOC_LEN=0x100000 CONFIG_ENV_SIZE=0x2000 diff --git a/configs/P2020RDB-PC_NAND_defconfig b/configs/P2020RDB-PC_NAND_defconfig index 74165dc60aa7..73e8a5c5714c 100644 --- a/configs/P2020RDB-PC_NAND_defconfig +++ b/configs/P2020RDB-PC_NAND_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_SYS_IMMR=0xFFE00000 CONFIG_SYS_TEXT_BASE=0x11001000 CONFIG_SYS_MALLOC_LEN=0x100000 CONFIG_ENV_SIZE=0x4000 diff --git a/configs/P2020RDB-PC_SDCARD_defconfig b/configs/P2020RDB-PC_SDCARD_defconfig index 0505f40a8148..614ff521b90e 100644 --- a/configs/P2020RDB-PC_SDCARD_defconfig +++ b/configs/P2020RDB-PC_SDCARD_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_SYS_IMMR=0xFFE00000 CONFIG_SYS_TEXT_BASE=0x11001000 CONFIG_SYS_MALLOC_LEN=0x100000 CONFIG_SPL_LIBCOMMON_SUPPORT=y diff --git a/configs/P2020RDB-PC_SPIFLASH_defconfig b/configs/P2020RDB-PC_SPIFLASH_defconfig index f1085fde4702..325a238fbfab 100644 --- a/configs/P2020RDB-PC_SPIFLASH_defconfig +++ b/configs/P2020RDB-PC_SPIFLASH_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_SYS_IMMR=0xFFE00000 CONFIG_SYS_TEXT_BASE=0x11001000 CONFIG_SYS_MALLOC_LEN=0x100000 CONFIG_SPL_LIBCOMMON_SUPPORT=y diff --git a/configs/P2020RDB-PC_defconfig b/configs/P2020RDB-PC_defconfig index f933ed42fced..15f2a97df2d1 100644 --- a/configs/P2020RDB-PC_defconfig +++ b/configs/P2020RDB-PC_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_SYS_IMMR=0xFFE00000 CONFIG_SYS_TEXT_BASE=0xEFF40000 CONFIG_SYS_MALLOC_LEN=0x100000 CONFIG_ENV_SIZE=0x2000 diff --git a/configs/socrates_defconfig b/configs/socrates_defconfig index bad08e79c9f4..f9815ca581f1 100644 --- a/configs/socrates_defconfig +++ b/configs/socrates_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_SYS_IMMR=0xE0000000 CONFIG_SYS_TEXT_BASE=0xfff80000 CONFIG_ENV_SIZE=0x4000 CONFIG_ENV_SECT_SIZE=0x20000 -- 2.25.1
Fixes: be7dbb60c5bf ("Convert CONFIG_SYS_IMMR to Kconfig") Reported-by: Pali Rohár pali@kernel.org Signed-off-by: Tom Rini trini@konsulko.com Tested-by: Pali Rohár pali@kernel.org
Pali Rohár
