Re: question about uboot mt7620 RAM_VERSION
25 Oct
2022
25 Oct
'22
6:46 a.m.
Hi Kang-sen,
On 24.10.22 19:58, Kang-sen Lu wrote:
I am wondering if you have read my reply on 10/18. It is very strange to find that unless I had uboot to do a saveenv, the RAM_VERSION uboot.bin would not run properly in DRAM.
Frankly, I don't really understand this message. It's not clear to me, what you are doing and what is working and what is failing.
I thought you were trying to boot the current mainline U-Boot RAM version u-boot.bin. If yes, which build target did you use? What does it show on the serial console?
Thanks, Stefan
Thanks.
Kang-sen
On Tue, Oct 18, 2022 at 10:05 AM Kang-sen Lu <klu@waav.com mailto:klu@waav.com> wrote:
Hi, Stefan: Thanks for your reply. The uboot in the zbtlink mt7620 router has the signatures follows: U-Boot 1.1.3 (Nov 9 2016 - 15:34:50) SoC:MediaTek MT7620 DRAM: Memory Testing..131072K OK. is 128 MB relocate_code Pointer at: 87fb0000 enable ephy clock...done. rf reg 29 = 5 SSC disabled. spi_wait_nsec: 29 spi device id: ef 40 18 0 0 (40180000) Flash: W25Q128BV I would like to share my strange experience about RAM version uboot for mt7620. By pure luck, I found that when I tried to load a newly built uboot with startup menu option 8, unless I change the filename, say, from uboot.bin to uboot1.bin, the newly loaded uboot would not startup properly in RAM. I don't have the knowledge to find out why this variable "modifies" to be none-zero is so important to the execution of uboot in RAM. Maybe some expert in this group can easily figure that out. Thanks. Kang-sen On Tue, Oct 18, 2022 at 7:53 AM Stefan Roese <sr@denx.de <mailto:sr@denx.de>> wrote: Hi Kang-sen, (added Weijie Gao to Cc) On 17.10.22 14:11, Kang-sen Lu wrote: > I am building uboot.bin for mt7620 router. > > I used start menu option 8, a hidden one choice, to load uboot.bin through > tftp. > > The tftp transfer is OK. But when the new uboot starts, it hang. So which mainline U-Boot build target did you use? Don't you see any output on the serial console at all? > I am wondering if the RAM_VERSION for mt7620 still works. In mainline U-Boot this is usually handled this way. The SPL U-Boot version is responsible for the low-level HW init, like DRAM/DDR init etc. It's hard to impossible to chainload this SPL part from a running U-Boot version. The "RAM_VERSION" is usually the main U-Boot proper image "u-boot.bin". So in general you are using the correct file here. Even though I have not idea, if the build target is correct for your "mt7620 router". Thanks, Stefan
Viele Grüße, Stefan Roese
DENX Software Engineering GmbH, Managing Director: Wolfgang Denk
HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany
Phone: (+49)-8142-66989-51 Fax: (+49)-8142-66989-80 Email: sr@denx.de
928
Stefan Roese
