root access and u-boot-test-hooks scripts
Hey all,
I'm looking for some feedback and ideas. Today, in our u-boot-test-hooks repository we have 2 cases that use sudo, imx_usb and L4T-based flashing. Other places that may require root access, such as mounting a filesystem instead assume an /etc/fstab entry exists and has "user" as one of the attributes.
Locally, I've extended using "sudo" instead for further access, and so far have updated the rpi3_mount script to be like the flashair one and support all of the platforms (by naming u-boot.bin correctly for the platform) and I've got an easily re-usable ti-omap writer as well (ti-k3 is harder since you need to build two distinct U-Boots).
Would people rather see more sudo use, or more /etc/fstab setup required? I'm happy to adjust what I've done to not use sudo and post that.
Hi Tom
On Fri, Apr 29, 2022 at 3:04 PM Tom Rini trini@konsulko.com wrote:
Hey all,
I'm not a super expert but is it sufficient to use udev and insert the right on a group for a particular vendor and product id?
If you have a docker container --previlege should not be possible to mount but stay in a different name space?
Michael
-- Tom
On Fri, Apr 29, 2022 at 03:19:00PM +0200, Michael Nazzareno Trimarchi wrote:
Hi Tom
Hey all,
You can do some mount-based rules there as well, but that gets trickier still to document / make portable.
I honestly don't know how well all of the tooling would work containerized, especially since we're talking about dynamically appearing/disappearing devices (ie we run sd-mux-ctrl to tell the sd-mux board via USB to present the SD card to us as a mass storage device, mount it via UUID, copy things, unmount, tell the sd-mux board to present it to the device under test now instead).
