[U-Boot] [PATCH v1 0/2] sun8i_emac: set MDC divider for MDIO read/write
To ensure compatibility with all PHYs, we need to keep the MDIO clock (MDC) below 2.5MHz (the guaranteed operating limit from IEEE 802.3), even if some PHYs will tolerate higher speeds.
This changeset also cleans up the MDIO read/write functions by removing pointless bit-masking in a variable initialised to 0.
Philipp Tomsich (2): sun8i_emac: Set MDC divider for MDIO read/write sun8i_emac: remove unnecessary bit-masking for mdio_read/write
drivers/net/sun8i_emac.c | 22 ++++++++++++++-------- 1 file changed, 14 insertions(+), 8 deletions(-)
The IEEE 802.3 standard guarantees operation of the MDIO signals at up to 2.5MHz (anything above this is a vendor-specific feature, although most PHYs work at higher frequencies). With the EMAC being fed by a (typically) 300MHz clock (e.g. on the A64 this is AHB2, which should be kept at 300MHz according to the CCU documentation), we need to use the divide-by-128 setting to get us below 2.5MHz.
The ~2.34MHz clock signal (i.e. assuring that the MDC clock is indeed derived from the AHB2 clock) has been verified using a A64-uQ7.
Signed-off-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com --- drivers/net/sun8i_emac.c | 14 ++++++++++++++ 1 file changed, 14 insertions(+)
diff --git a/drivers/net/sun8i_emac.c b/drivers/net/sun8i_emac.c index b87210b..5ae17b7 100644 --- a/drivers/net/sun8i_emac.c +++ b/drivers/net/sun8i_emac.c @@ -1,92 +1,98 @@ /* * (C) Copyright 2016 * Author: Amit Singh Tomar, amittomer25@gmail.com * * SPDX-License-Identifier: GPL-2.0+ * * Ethernet driver for H3/A64/A83T based SoC's * * It is derived from the work done by * LABBE Corentin & Chen-Yu Tsai for Linux, THANKS! * */
#include <asm/io.h> #include <asm/arch/clock.h> #include <asm/arch/gpio.h> #include <common.h> #include <dm.h> #include <fdt_support.h> #include <linux/err.h> #include <malloc.h> #include <miiphy.h> #include <net.h>
#define MDIO_CMD_MII_BUSY BIT(0) #define MDIO_CMD_MII_WRITE BIT(1)
#define MDIO_CMD_MII_PHY_REG_ADDR_MASK 0x000001f0 #define MDIO_CMD_MII_PHY_REG_ADDR_SHIFT 4 #define MDIO_CMD_MII_PHY_ADDR_MASK 0x0001f000 #define MDIO_CMD_MII_PHY_ADDR_SHIFT 12
+#define MDIO_CMD_MDC_DIV_RATIO_M_SHIFT 20 +#define MDIO_CMD_MDC_DIV_16 (0 << MDIO_CMD_MDC_DIV_RATIO_M_SHIFT) +#define MDIO_CMD_MDC_DIV_32 (1 << MDIO_CMD_MDC_DIV_RATIO_M_SHIFT) +#define MDIO_CMD_MDC_DIV_64 (2 << MDIO_CMD_MDC_DIV_RATIO_M_SHIFT) +#define MDIO_CMD_MDC_DIV_128 (3 << MDIO_CMD_MDC_DIV_RATIO_M_SHIFT) + #define CONFIG_TX_DESCR_NUM 32 #define CONFIG_RX_DESCR_NUM 32 #define CONFIG_ETH_BUFSIZE 2048 /* Note must be dma aligned */
/* * The datasheet says that each descriptor can transfers up to 4096 bytes * But later, the register documentation reduces that value to 2048, * using 2048 cause strange behaviours and even BSP driver use 2047 */ #define CONFIG_ETH_RXSIZE 2044 /* Note must fit in ETH_BUFSIZE */
#define TX_TOTAL_BUFSIZE (CONFIG_ETH_BUFSIZE * CONFIG_TX_DESCR_NUM) #define RX_TOTAL_BUFSIZE (CONFIG_ETH_BUFSIZE * CONFIG_RX_DESCR_NUM)
#define H3_EPHY_DEFAULT_VALUE 0x58000 #define H3_EPHY_DEFAULT_MASK GENMASK(31, 15) #define H3_EPHY_ADDR_SHIFT 20 #define REG_PHY_ADDR_MASK GENMASK(4, 0) #define H3_EPHY_LED_POL BIT(17) /* 1: active low, 0: active high */ #define H3_EPHY_SHUTDOWN BIT(16) /* 1: shutdown, 0: power up */ #define H3_EPHY_SELECT BIT(15) /* 1: internal PHY, 0: external PHY */
#define SC_RMII_EN BIT(13) #define SC_EPIT BIT(2) /* 1: RGMII, 0: MII */ #define SC_ETCS_MASK GENMASK(1, 0) #define SC_ETCS_EXT_GMII 0x1 #define SC_ETCS_INT_GMII 0x2
#define CONFIG_MDIO_TIMEOUT (3 * CONFIG_SYS_HZ)
#define AHB_GATE_OFFSET_EPHY 0
#if defined(CONFIG_MACH_SUN8I_H3) #define SUN8I_GPD8_GMAC 2 #else #define SUN8I_GPD8_GMAC 4 #endif
/* H3/A64 EMAC Register's offset */ #define EMAC_CTL0 0x00 #define EMAC_CTL1 0x04 #define EMAC_INT_STA 0x08 #define EMAC_INT_EN 0x0c #define EMAC_TX_CTL0 0x10 #define EMAC_TX_CTL1 0x14 #define EMAC_TX_FLOW_CTL 0x1c #define EMAC_TX_DMA_DESC 0x20 #define EMAC_RX_CTL0 0x24 #define EMAC_RX_CTL1 0x28 #define EMAC_RX_DMA_DESC 0x34 #define EMAC_MII_CMD 0x48 #define EMAC_MII_DATA 0x4c #define EMAC_ADDR0_HIGH 0x50 #define EMAC_ADDR0_LOW 0x54 #define EMAC_TX_DMA_STA 0xb0 #define EMAC_TX_CUR_DESC 0xb4 #define EMAC_TX_CUR_BUF 0xb8 #define EMAC_RX_DMA_STA 0xc0 #define EMAC_RX_CUR_DESC 0xc4
@@ -133,66 +139,74 @@ struct emac_eth_dev { static int sun8i_mdio_read(struct mii_dev *bus, int addr, int devad, int reg) { struct emac_eth_dev *priv = bus->priv; ulong start; u32 miiaddr = 0; int timeout = CONFIG_MDIO_TIMEOUT;
miiaddr &= ~MDIO_CMD_MII_WRITE; miiaddr &= ~MDIO_CMD_MII_PHY_REG_ADDR_MASK; miiaddr |= (reg << MDIO_CMD_MII_PHY_REG_ADDR_SHIFT) & MDIO_CMD_MII_PHY_REG_ADDR_MASK;
miiaddr &= ~MDIO_CMD_MII_PHY_ADDR_MASK;
miiaddr |= (addr << MDIO_CMD_MII_PHY_ADDR_SHIFT) & MDIO_CMD_MII_PHY_ADDR_MASK;
+ /* The MAC block is fed by a 300MHz clock, so we need to divide by 128 + to bring the MDC into the range permissible by the IEEE standard. */ + miiaddr |= MDIO_CMD_MDC_DIV_128; + miiaddr |= MDIO_CMD_MII_BUSY;
writel(miiaddr, priv->mac_reg + EMAC_MII_CMD);
start = get_timer(0); while (get_timer(start) < timeout) { if (!(readl(priv->mac_reg + EMAC_MII_CMD) & MDIO_CMD_MII_BUSY)) return readl(priv->mac_reg + EMAC_MII_DATA); udelay(10); };
return -1; }
static int sun8i_mdio_write(struct mii_dev *bus, int addr, int devad, int reg, u16 val) { struct emac_eth_dev *priv = bus->priv; ulong start; u32 miiaddr = 0; int ret = -1, timeout = CONFIG_MDIO_TIMEOUT;
miiaddr &= ~MDIO_CMD_MII_PHY_ADDR_MASK; miiaddr |= (addr << MDIO_CMD_MII_PHY_ADDR_SHIFT) & MDIO_CMD_MII_PHY_ADDR_MASK;
miiaddr |= MDIO_CMD_MII_WRITE; miiaddr |= MDIO_CMD_MII_BUSY;
+ /* The MAC block is fed by a 300MHz clock, so we need to divide by 128 + to bring the MDC into the range permissible by the IEEE standard. */ + miiaddr |= MDIO_CMD_MDC_DIV_128; + writel(val, priv->mac_reg + EMAC_MII_DATA); writel(miiaddr, priv->mac_reg + EMAC_MII_CMD);
start = get_timer(0); while (get_timer(start) < timeout) { if (!(readl(priv->mac_reg + EMAC_MII_CMD) & MDIO_CMD_MII_BUSY)) { ret = 0; break; } udelay(10); };
return ret; }
The MDIO read/write builds up the MII_CMD register from scratch (starting with a value of 0). No need to mask out any fields before writing the new values.
Signed-off-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com --- drivers/net/sun8i_emac.c | 8 -------- 1 file changed, 8 deletions(-)
diff --git a/drivers/net/sun8i_emac.c b/drivers/net/sun8i_emac.c index 5ae17b7..5094dd8 100644 --- a/drivers/net/sun8i_emac.c +++ b/drivers/net/sun8i_emac.c @@ -139,74 +139,66 @@ struct emac_eth_dev { static int sun8i_mdio_read(struct mii_dev *bus, int addr, int devad, int reg) { struct emac_eth_dev *priv = bus->priv; ulong start; u32 miiaddr = 0; int timeout = CONFIG_MDIO_TIMEOUT;
- miiaddr &= ~MDIO_CMD_MII_WRITE; - miiaddr &= ~MDIO_CMD_MII_PHY_REG_ADDR_MASK; miiaddr |= (reg << MDIO_CMD_MII_PHY_REG_ADDR_SHIFT) & MDIO_CMD_MII_PHY_REG_ADDR_MASK; - - miiaddr &= ~MDIO_CMD_MII_PHY_ADDR_MASK; - miiaddr |= (addr << MDIO_CMD_MII_PHY_ADDR_SHIFT) & MDIO_CMD_MII_PHY_ADDR_MASK;
/* The MAC block is fed by a 300MHz clock, so we need to divide by 128 to bring the MDC into the range permissible by the IEEE standard. */ miiaddr |= MDIO_CMD_MDC_DIV_128;
return -1; }
- miiaddr &= ~MDIO_CMD_MII_PHY_REG_ADDR_MASK; miiaddr |= (reg << MDIO_CMD_MII_PHY_REG_ADDR_SHIFT) & MDIO_CMD_MII_PHY_REG_ADDR_MASK; - - miiaddr &= ~MDIO_CMD_MII_PHY_ADDR_MASK; miiaddr |= (addr << MDIO_CMD_MII_PHY_ADDR_SHIFT) & MDIO_CMD_MII_PHY_ADDR_MASK;
return ret; }
Reviewed-by: Andre Przywara andre.przywara@arm.com
As a general comment: Can you configure your setup to use the standard three lines of context? Reading over those big gaps is rather confusing and may lead to changes being missed. Thanks!
Cheers, Andre.
return -1;
return ret;
Acked-by: Maxime Ripard maxime.ripard@free-electrons.com
For both.
Thanks! Maxime
André Przywara
Maxime Ripard
Philipp Tomsich
