[PATCH 1/2] ARM: dts: Drop unused RZ/G2L devicetrees
We are now using the dts/upstream subtree for the RZ/G2L SoC family.
Signed-off-by: Paul Barker paul.barker.ct@bp.renesas.com --- arch/arm/dts/Makefile | 3 - arch/arm/dts/r9a07g044.dtsi | 1273 --------------------- arch/arm/dts/r9a07g044l2-smarc.dts | 39 - arch/arm/dts/r9a07g044l2.dtsi | 13 - arch/arm/dts/rz-smarc-common.dtsi | 183 --- arch/arm/dts/rzg2l-smarc-pinfunction.dtsi | 157 --- arch/arm/dts/rzg2l-smarc-som.dtsi | 371 ------ arch/arm/dts/rzg2l-smarc.dtsi | 181 --- 8 files changed, 2220 deletions(-) delete mode 100644 arch/arm/dts/r9a07g044.dtsi delete mode 100644 arch/arm/dts/r9a07g044l2-smarc.dts delete mode 100644 arch/arm/dts/r9a07g044l2.dtsi delete mode 100644 arch/arm/dts/rz-smarc-common.dtsi delete mode 100644 arch/arm/dts/rzg2l-smarc-pinfunction.dtsi delete mode 100644 arch/arm/dts/rzg2l-smarc-som.dtsi delete mode 100644 arch/arm/dts/rzg2l-smarc.dtsi
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index aeccfa93fc53..e0cc9937acb4 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -979,9 +979,6 @@ dtb-$(CONFIG_ARCH_IMXRT) += imxrt1050-evk.dtb \ imxrt1020-evk.dtb \ imxrt1170-evk.dtb \
-dtb-$(CONFIG_TARGET_RZG2L) += \ - r9a07g044l2-smarc.dts - ifdef CONFIG_RCAR_64 DTC_FLAGS += -R 4 -p 0x1000 endif diff --git a/arch/arm/dts/r9a07g044.dtsi b/arch/arm/dts/r9a07g044.dtsi deleted file mode 100644 index 66f68fc2b241..000000000000 --- a/arch/arm/dts/r9a07g044.dtsi +++ /dev/null @@ -1,1273 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0-only OR BSD-2-Clause) -/* - * Device Tree Source for the RZ/G2L and RZ/G2LC common SoC parts - * - * Copyright (C) 2021 Renesas Electronics Corp. - */ - -#include <dt-bindings/interrupt-controller/arm-gic.h> -#include <dt-bindings/clock/r9a07g044-cpg.h> - -/ { - compatible = "renesas,r9a07g044"; - #address-cells = <2>; - #size-cells = <2>; - - audio_clk1: audio1-clk { - compatible = "fixed-clock"; - #clock-cells = <0>; - /* This value must be overridden by boards that provide it */ - clock-frequency = <0>; - }; - - audio_clk2: audio2-clk { - compatible = "fixed-clock"; - #clock-cells = <0>; - /* This value must be overridden by boards that provide it */ - clock-frequency = <0>; - }; - - /* External CAN clock - to be overridden by boards that provide it */ - can_clk: can-clk { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <0>; - }; - - /* clock can be either from exclk or crystal oscillator (XIN/XOUT) */ - extal_clk: extal-clk { - compatible = "fixed-clock"; - #clock-cells = <0>; - /* This value must be overridden by the board */ - clock-frequency = <0>; - }; - - cluster0_opp: opp-table-0 { - compatible = "operating-points-v2"; - opp-shared; - - opp-150000000 { - opp-hz = /bits/ 64 <150000000>; - opp-microvolt = <1100000>; - clock-latency-ns = <300000>; - }; - opp-300000000 { - opp-hz = /bits/ 64 <300000000>; - opp-microvolt = <1100000>; - clock-latency-ns = <300000>; - }; - opp-600000000 { - opp-hz = /bits/ 64 <600000000>; - opp-microvolt = <1100000>; - clock-latency-ns = <300000>; - }; - opp-1200000000 { - opp-hz = /bits/ 64 <1200000000>; - opp-microvolt = <1100000>; - clock-latency-ns = <300000>; - opp-suspend; - }; - }; - - cpus { - #address-cells = <1>; - #size-cells = <0>; - - cpu-map { - cluster0 { - core0 { - cpu = <&cpu0>; - }; - core1 { - cpu = <&cpu1>; - }; - }; - }; - - cpu0: cpu@0 { - compatible = "arm,cortex-a55"; - reg = <0>; - device_type = "cpu"; - #cooling-cells = <2>; - next-level-cache = <&L3_CA55>; - enable-method = "psci"; - clocks = <&cpg CPG_CORE R9A07G044_CLK_I>; - operating-points-v2 = <&cluster0_opp>; - }; - - cpu1: cpu@100 { - compatible = "arm,cortex-a55"; - reg = <0x100>; - device_type = "cpu"; - next-level-cache = <&L3_CA55>; - enable-method = "psci"; - clocks = <&cpg CPG_CORE R9A07G044_CLK_I>; - operating-points-v2 = <&cluster0_opp>; - }; - - L3_CA55: cache-controller-0 { - compatible = "cache"; - cache-unified; - cache-size = <0x40000>; - cache-level = <3>; - }; - }; - - gpu_opp_table: opp-table-1 { - compatible = "operating-points-v2"; - - opp-500000000 { - opp-hz = /bits/ 64 <500000000>; - opp-microvolt = <1100000>; - }; - - opp-400000000 { - opp-hz = /bits/ 64 <400000000>; - opp-microvolt = <1100000>; - }; - - opp-250000000 { - opp-hz = /bits/ 64 <250000000>; - opp-microvolt = <1100000>; - }; - - opp-200000000 { - opp-hz = /bits/ 64 <200000000>; - opp-microvolt = <1100000>; - }; - - opp-125000000 { - opp-hz = /bits/ 64 <125000000>; - opp-microvolt = <1100000>; - }; - - opp-100000000 { - opp-hz = /bits/ 64 <100000000>; - opp-microvolt = <1100000>; - }; - - opp-62500000 { - opp-hz = /bits/ 64 <62500000>; - opp-microvolt = <1100000>; - }; - - opp-50000000 { - opp-hz = /bits/ 64 <50000000>; - opp-microvolt = <1100000>; - }; - }; - - pmu { - compatible = "arm,cortex-a55-pmu"; - interrupts-extended = <&gic GIC_PPI 7 IRQ_TYPE_LEVEL_LOW>; - }; - - psci { - compatible = "arm,psci-1.0", "arm,psci-0.2"; - method = "smc"; - }; - - soc: soc { - compatible = "simple-bus"; - interrupt-parent = <&gic>; - #address-cells = <2>; - #size-cells = <2>; - ranges; - - mtu3: timer@10001200 { - compatible = "renesas,r9a07g044-mtu3", - "renesas,rz-mtu3"; - reg = <0 0x10001200 0 0xb00>; - interrupts = <GIC_SPI 170 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 171 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 172 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 173 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 174 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 175 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 176 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 177 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 178 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 179 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 180 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 181 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 182 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 183 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 184 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 185 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 186 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 187 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 188 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 189 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 190 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 191 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 192 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 193 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 194 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 195 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 196 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 197 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 198 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 199 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 200 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 201 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 202 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 203 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 204 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 205 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 206 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 207 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 208 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 209 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 210 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 211 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 212 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 213 IRQ_TYPE_EDGE_RISING>; - interrupt-names = "tgia0", "tgib0", "tgic0", "tgid0", - "tciv0", "tgie0", "tgif0", - "tgia1", "tgib1", "tciv1", "tciu1", - "tgia2", "tgib2", "tciv2", "tciu2", - "tgia3", "tgib3", "tgic3", "tgid3", - "tciv3", - "tgia4", "tgib4", "tgic4", "tgid4", - "tciv4", - "tgiu5", "tgiv5", "tgiw5", - "tgia6", "tgib6", "tgic6", "tgid6", - "tciv6", - "tgia7", "tgib7", "tgic7", "tgid7", - "tciv7", - "tgia8", "tgib8", "tgic8", "tgid8", - "tciv8", "tciu8"; - clocks = <&cpg CPG_MOD R9A07G044_MTU_X_MCK_MTU3>; - power-domains = <&cpg>; - resets = <&cpg R9A07G044_MTU_X_PRESET_MTU3>; - #pwm-cells = <2>; - status = "disabled"; - }; - - ssi0: ssi@10049c00 { - compatible = "renesas,r9a07g044-ssi", - "renesas,rz-ssi"; - reg = <0 0x10049c00 0 0x400>; - interrupts = <GIC_SPI 326 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 327 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 328 IRQ_TYPE_EDGE_RISING>; - interrupt-names = "int_req", "dma_rx", "dma_tx"; - clocks = <&cpg CPG_MOD R9A07G044_SSI0_PCLK2>, - <&cpg CPG_MOD R9A07G044_SSI0_PCLK_SFR>, - <&audio_clk1>, <&audio_clk2>; - clock-names = "ssi", "ssi_sfr", "audio_clk1", "audio_clk2"; - resets = <&cpg R9A07G044_SSI0_RST_M2_REG>; - dmas = <&dmac 0x2655>, <&dmac 0x2656>; - dma-names = "tx", "rx"; - power-domains = <&cpg>; - #sound-dai-cells = <0>; - status = "disabled"; - }; - - ssi1: ssi@1004a000 { - compatible = "renesas,r9a07g044-ssi", - "renesas,rz-ssi"; - reg = <0 0x1004a000 0 0x400>; - interrupts = <GIC_SPI 330 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 331 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 332 IRQ_TYPE_EDGE_RISING>; - interrupt-names = "int_req", "dma_rx", "dma_tx"; - clocks = <&cpg CPG_MOD R9A07G044_SSI1_PCLK2>, - <&cpg CPG_MOD R9A07G044_SSI1_PCLK_SFR>, - <&audio_clk1>, <&audio_clk2>; - clock-names = "ssi", "ssi_sfr", "audio_clk1", "audio_clk2"; - resets = <&cpg R9A07G044_SSI1_RST_M2_REG>; - dmas = <&dmac 0x2659>, <&dmac 0x265a>; - dma-names = "tx", "rx"; - power-domains = <&cpg>; - #sound-dai-cells = <0>; - status = "disabled"; - }; - - ssi2: ssi@1004a400 { - compatible = "renesas,r9a07g044-ssi", - "renesas,rz-ssi"; - reg = <0 0x1004a400 0 0x400>; - interrupts = <GIC_SPI 334 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 337 IRQ_TYPE_EDGE_RISING>; - interrupt-names = "int_req", "dma_rt"; - clocks = <&cpg CPG_MOD R9A07G044_SSI2_PCLK2>, - <&cpg CPG_MOD R9A07G044_SSI2_PCLK_SFR>, - <&audio_clk1>, <&audio_clk2>; - clock-names = "ssi", "ssi_sfr", "audio_clk1", "audio_clk2"; - resets = <&cpg R9A07G044_SSI2_RST_M2_REG>; - dmas = <&dmac 0x265f>; - dma-names = "rt"; - power-domains = <&cpg>; - #sound-dai-cells = <0>; - status = "disabled"; - }; - - ssi3: ssi@1004a800 { - compatible = "renesas,r9a07g044-ssi", - "renesas,rz-ssi"; - reg = <0 0x1004a800 0 0x400>; - interrupts = <GIC_SPI 338 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 339 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 340 IRQ_TYPE_EDGE_RISING>; - interrupt-names = "int_req", "dma_rx", "dma_tx"; - clocks = <&cpg CPG_MOD R9A07G044_SSI3_PCLK2>, - <&cpg CPG_MOD R9A07G044_SSI3_PCLK_SFR>, - <&audio_clk1>, <&audio_clk2>; - clock-names = "ssi", "ssi_sfr", "audio_clk1", "audio_clk2"; - resets = <&cpg R9A07G044_SSI3_RST_M2_REG>; - dmas = <&dmac 0x2661>, <&dmac 0x2662>; - dma-names = "tx", "rx"; - power-domains = <&cpg>; - #sound-dai-cells = <0>; - status = "disabled"; - }; - - spi0: spi@1004ac00 { - compatible = "renesas,r9a07g044-rspi", "renesas,rspi-rz"; - reg = <0 0x1004ac00 0 0x400>; - interrupts = <GIC_SPI 415 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 413 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 414 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "error", "rx", "tx"; - clocks = <&cpg CPG_MOD R9A07G044_RSPI0_CLKB>; - resets = <&cpg R9A07G044_RSPI0_RST>; - dmas = <&dmac 0x2e95>, <&dmac 0x2e96>; - dma-names = "tx", "rx"; - power-domains = <&cpg>; - num-cs = <1>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - spi1: spi@1004b000 { - compatible = "renesas,r9a07g044-rspi", "renesas,rspi-rz"; - reg = <0 0x1004b000 0 0x400>; - interrupts = <GIC_SPI 418 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 416 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 417 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "error", "rx", "tx"; - clocks = <&cpg CPG_MOD R9A07G044_RSPI1_CLKB>; - resets = <&cpg R9A07G044_RSPI1_RST>; - dmas = <&dmac 0x2e99>, <&dmac 0x2e9a>; - dma-names = "tx", "rx"; - power-domains = <&cpg>; - num-cs = <1>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - spi2: spi@1004b400 { - compatible = "renesas,r9a07g044-rspi", "renesas,rspi-rz"; - reg = <0 0x1004b400 0 0x400>; - interrupts = <GIC_SPI 421 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 419 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 420 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "error", "rx", "tx"; - clocks = <&cpg CPG_MOD R9A07G044_RSPI2_CLKB>; - resets = <&cpg R9A07G044_RSPI2_RST>; - dmas = <&dmac 0x2e9d>, <&dmac 0x2e9e>; - dma-names = "tx", "rx"; - power-domains = <&cpg>; - num-cs = <1>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - scif0: serial@1004b800 { - compatible = "renesas,scif-r9a07g044"; - reg = <0 0x1004b800 0 0x400>; - interrupts = <GIC_SPI 380 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 382 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 383 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 381 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 384 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 384 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "eri", "rxi", "txi", - "bri", "dri", "tei"; - clocks = <&cpg CPG_MOD R9A07G044_SCIF0_CLK_PCK>; - clock-names = "fck"; - power-domains = <&cpg>; - resets = <&cpg R9A07G044_SCIF0_RST_SYSTEM_N>; - status = "disabled"; - }; - - scif1: serial@1004bc00 { - compatible = "renesas,scif-r9a07g044"; - reg = <0 0x1004bc00 0 0x400>; - interrupts = <GIC_SPI 385 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 387 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 388 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 386 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 389 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 389 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "eri", "rxi", "txi", - "bri", "dri", "tei"; - clocks = <&cpg CPG_MOD R9A07G044_SCIF1_CLK_PCK>; - clock-names = "fck"; - power-domains = <&cpg>; - resets = <&cpg R9A07G044_SCIF1_RST_SYSTEM_N>; - status = "disabled"; - }; - - scif2: serial@1004c000 { - compatible = "renesas,scif-r9a07g044"; - reg = <0 0x1004c000 0 0x400>; - interrupts = <GIC_SPI 390 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 392 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 393 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 391 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 394 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 394 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "eri", "rxi", "txi", - "bri", "dri", "tei"; - clocks = <&cpg CPG_MOD R9A07G044_SCIF2_CLK_PCK>; - clock-names = "fck"; - power-domains = <&cpg>; - resets = <&cpg R9A07G044_SCIF2_RST_SYSTEM_N>; - status = "disabled"; - }; - - scif3: serial@1004c400 { - compatible = "renesas,scif-r9a07g044"; - reg = <0 0x1004c400 0 0x400>; - interrupts = <GIC_SPI 395 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 397 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 398 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 396 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 399 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 399 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "eri", "rxi", "txi", - "bri", "dri", "tei"; - clocks = <&cpg CPG_MOD R9A07G044_SCIF3_CLK_PCK>; - clock-names = "fck"; - power-domains = <&cpg>; - resets = <&cpg R9A07G044_SCIF3_RST_SYSTEM_N>; - status = "disabled"; - }; - - scif4: serial@1004c800 { - compatible = "renesas,scif-r9a07g044"; - reg = <0 0x1004c800 0 0x400>; - interrupts = <GIC_SPI 400 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 402 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 403 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 401 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 404 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 404 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "eri", "rxi", "txi", - "bri", "dri", "tei"; - clocks = <&cpg CPG_MOD R9A07G044_SCIF4_CLK_PCK>; - clock-names = "fck"; - power-domains = <&cpg>; - resets = <&cpg R9A07G044_SCIF4_RST_SYSTEM_N>; - status = "disabled"; - }; - - sci0: serial@1004d000 { - compatible = "renesas,r9a07g044-sci", "renesas,sci"; - reg = <0 0x1004d000 0 0x400>; - interrupts = <GIC_SPI 405 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 406 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 407 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 408 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "eri", "rxi", "txi", "tei"; - clocks = <&cpg CPG_MOD R9A07G044_SCI0_CLKP>; - clock-names = "fck"; - power-domains = <&cpg>; - resets = <&cpg R9A07G044_SCI0_RST>; - status = "disabled"; - }; - - sci1: serial@1004d400 { - compatible = "renesas,r9a07g044-sci", "renesas,sci"; - reg = <0 0x1004d400 0 0x400>; - interrupts = <GIC_SPI 409 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 410 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 411 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 412 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "eri", "rxi", "txi", "tei"; - clocks = <&cpg CPG_MOD R9A07G044_SCI1_CLKP>; - clock-names = "fck"; - power-domains = <&cpg>; - resets = <&cpg R9A07G044_SCI1_RST>; - status = "disabled"; - }; - - canfd: can@10050000 { - compatible = "renesas,r9a07g044-canfd", "renesas,rzg2l-canfd"; - reg = <0 0x10050000 0 0x8000>; - interrupts = <GIC_SPI 426 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 427 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 422 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 424 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 428 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 423 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 425 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 429 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "g_err", "g_recc", - "ch0_err", "ch0_rec", "ch0_trx", - "ch1_err", "ch1_rec", "ch1_trx"; - clocks = <&cpg CPG_MOD R9A07G044_CANFD_PCLK>, - <&cpg CPG_CORE R9A07G044_CLK_P0_DIV2>, - <&can_clk>; - clock-names = "fck", "canfd", "can_clk"; - assigned-clocks = <&cpg CPG_CORE R9A07G044_CLK_P0_DIV2>; - assigned-clock-rates = <50000000>; - resets = <&cpg R9A07G044_CANFD_RSTP_N>, - <&cpg R9A07G044_CANFD_RSTC_N>; - reset-names = "rstp_n", "rstc_n"; - power-domains = <&cpg>; - status = "disabled"; - - channel0 { - status = "disabled"; - }; - channel1 { - status = "disabled"; - }; - }; - - i2c0: i2c@10058000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,riic-r9a07g044", "renesas,riic-rz"; - reg = <0 0x10058000 0 0x400>; - interrupts = <GIC_SPI 350 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 348 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 349 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 352 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 353 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 351 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 354 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 355 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "tei", "ri", "ti", "spi", "sti", - "naki", "ali", "tmoi"; - clocks = <&cpg CPG_MOD R9A07G044_I2C0_PCLK>; - clock-frequency = <100000>; - resets = <&cpg R9A07G044_I2C0_MRST>; - power-domains = <&cpg>; - status = "disabled"; - }; - - i2c1: i2c@10058400 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,riic-r9a07g044", "renesas,riic-rz"; - reg = <0 0x10058400 0 0x400>; - interrupts = <GIC_SPI 358 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 356 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 357 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 360 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 361 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 359 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 362 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 363 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "tei", "ri", "ti", "spi", "sti", - "naki", "ali", "tmoi"; - clocks = <&cpg CPG_MOD R9A07G044_I2C1_PCLK>; - clock-frequency = <100000>; - resets = <&cpg R9A07G044_I2C1_MRST>; - power-domains = <&cpg>; - status = "disabled"; - }; - - i2c2: i2c@10058800 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,riic-r9a07g044", "renesas,riic-rz"; - reg = <0 0x10058800 0 0x400>; - interrupts = <GIC_SPI 366 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 364 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 365 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 368 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 369 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 367 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 370 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 371 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "tei", "ri", "ti", "spi", "sti", - "naki", "ali", "tmoi"; - clocks = <&cpg CPG_MOD R9A07G044_I2C2_PCLK>; - clock-frequency = <100000>; - resets = <&cpg R9A07G044_I2C2_MRST>; - power-domains = <&cpg>; - status = "disabled"; - }; - - i2c3: i2c@10058c00 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "renesas,riic-r9a07g044", "renesas,riic-rz"; - reg = <0 0x10058c00 0 0x400>; - interrupts = <GIC_SPI 374 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 372 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 373 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 376 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 377 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 375 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 378 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 379 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "tei", "ri", "ti", "spi", "sti", - "naki", "ali", "tmoi"; - clocks = <&cpg CPG_MOD R9A07G044_I2C3_PCLK>; - clock-frequency = <100000>; - resets = <&cpg R9A07G044_I2C3_MRST>; - power-domains = <&cpg>; - status = "disabled"; - }; - - adc: adc@10059000 { - compatible = "renesas,r9a07g044-adc", "renesas,rzg2l-adc"; - reg = <0 0x10059000 0 0x400>; - interrupts = <GIC_SPI 347 IRQ_TYPE_EDGE_RISING>; - clocks = <&cpg CPG_MOD R9A07G044_ADC_ADCLK>, - <&cpg CPG_MOD R9A07G044_ADC_PCLK>; - clock-names = "adclk", "pclk"; - resets = <&cpg R9A07G044_ADC_PRESETN>, - <&cpg R9A07G044_ADC_ADRST_N>; - reset-names = "presetn", "adrst-n"; - power-domains = <&cpg>; - status = "disabled"; - - #address-cells = <1>; - #size-cells = <0>; - - channel@0 { - reg = <0>; - }; - channel@1 { - reg = <1>; - }; - channel@2 { - reg = <2>; - }; - channel@3 { - reg = <3>; - }; - channel@4 { - reg = <4>; - }; - channel@5 { - reg = <5>; - }; - channel@6 { - reg = <6>; - }; - channel@7 { - reg = <7>; - }; - }; - - tsu: thermal@10059400 { - compatible = "renesas,r9a07g044-tsu", - "renesas,rzg2l-tsu"; - reg = <0 0x10059400 0 0x400>; - clocks = <&cpg CPG_MOD R9A07G044_TSU_PCLK>; - resets = <&cpg R9A07G044_TSU_PRESETN>; - power-domains = <&cpg>; - #thermal-sensor-cells = <1>; - }; - - sbc: spi@10060000 { - compatible = "renesas,r9a07g044-rpc-if", - "renesas,rzg2l-rpc-if"; - reg = <0 0x10060000 0 0x10000>, - <0 0x20000000 0 0x10000000>, - <0 0x10070000 0 0x10000>; - reg-names = "regs", "dirmap", "wbuf"; - interrupts = <GIC_SPI 41 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD R9A07G044_SPI_CLK2>, - <&cpg CPG_MOD R9A07G044_SPI_CLK>; - resets = <&cpg R9A07G044_SPI_RST>; - power-domains = <&cpg>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - cru: video@10830000 { - compatible = "renesas,r9a07g044-cru", "renesas,rzg2l-cru"; - reg = <0 0x10830000 0 0x400>; - clocks = <&cpg CPG_MOD R9A07G044_CRU_VCLK>, - <&cpg CPG_MOD R9A07G044_CRU_PCLK>, - <&cpg CPG_MOD R9A07G044_CRU_ACLK>; - clock-names = "video", "apb", "axi"; - interrupts = <GIC_SPI 167 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 168 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 169 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "image_conv", "image_conv_err", "axi_mst_err"; - resets = <&cpg R9A07G044_CRU_PRESETN>, - <&cpg R9A07G044_CRU_ARESETN>; - reset-names = "presetn", "aresetn"; - power-domains = <&cpg>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <0>; - cruparallel: endpoint@0 { - reg = <0>; - }; - }; - - port@1 { - #address-cells = <1>; - #size-cells = <0>; - - reg = <1>; - crucsi2: endpoint@0 { - reg = <0>; - remote-endpoint = <&csi2cru>; - }; - }; - }; - }; - - csi2: csi2@10830400 { - compatible = "renesas,r9a07g044-csi2", "renesas,rzg2l-csi2"; - reg = <0 0x10830400 0 0xfc00>; - interrupts = <GIC_SPI 166 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD R9A07G044_CRU_SYSCLK>, - <&cpg CPG_MOD R9A07G044_CRU_VCLK>, - <&cpg CPG_MOD R9A07G044_CRU_PCLK>; - clock-names = "system", "video", "apb"; - resets = <&cpg R9A07G044_CRU_PRESETN>, - <&cpg R9A07G044_CRU_CMN_RSTB>; - reset-names = "presetn", "cmn-rstb"; - power-domains = <&cpg>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - }; - - port@1 { - #address-cells = <1>; - #size-cells = <0>; - reg = <1>; - - csi2cru: endpoint@0 { - reg = <0>; - remote-endpoint = <&crucsi2>; - }; - }; - }; - }; - - dsi: dsi@10850000 { - compatible = "renesas,r9a07g044-mipi-dsi", - "renesas,rzg2l-mipi-dsi"; - reg = <0 0x10850000 0 0x20000>; - interrupts = <GIC_SPI 142 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 143 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 144 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 145 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 146 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 147 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 148 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "seq0", "seq1", "vin1", "rcv", - "ferr", "ppi", "debug"; - clocks = <&cpg CPG_MOD R9A07G044_MIPI_DSI_PLLCLK>, - <&cpg CPG_MOD R9A07G044_MIPI_DSI_SYSCLK>, - <&cpg CPG_MOD R9A07G044_MIPI_DSI_ACLK>, - <&cpg CPG_MOD R9A07G044_MIPI_DSI_PCLK>, - <&cpg CPG_MOD R9A07G044_MIPI_DSI_VCLK>, - <&cpg CPG_MOD R9A07G044_MIPI_DSI_LPCLK>; - clock-names = "pllclk", "sysclk", "aclk", "pclk", "vclk", "lpclk"; - resets = <&cpg R9A07G044_MIPI_DSI_CMN_RSTB>, - <&cpg R9A07G044_MIPI_DSI_ARESET_N>, - <&cpg R9A07G044_MIPI_DSI_PRESET_N>; - reset-names = "rst", "arst", "prst"; - power-domains = <&cpg>; - status = "disabled"; - }; - - vspd: vsp@10870000 { - compatible = "renesas,r9a07g044-vsp2"; - reg = <0 0x10870000 0 0x10000>; - interrupts = <GIC_SPI 149 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD R9A07G044_LCDC_CLK_A>, - <&cpg CPG_MOD R9A07G044_LCDC_CLK_P>, - <&cpg CPG_MOD R9A07G044_LCDC_CLK_D>; - clock-names = "aclk", "pclk", "vclk"; - power-domains = <&cpg>; - resets = <&cpg R9A07G044_LCDC_RESET_N>; - renesas,fcp = <&fcpvd>; - }; - - fcpvd: fcp@10880000 { - compatible = "renesas,r9a07g044-fcpvd", - "renesas,fcpv"; - reg = <0 0x10880000 0 0x10000>; - clocks = <&cpg CPG_MOD R9A07G044_LCDC_CLK_A>, - <&cpg CPG_MOD R9A07G044_LCDC_CLK_P>, - <&cpg CPG_MOD R9A07G044_LCDC_CLK_D>; - clock-names = "aclk", "pclk", "vclk"; - power-domains = <&cpg>; - resets = <&cpg R9A07G044_LCDC_RESET_N>; - }; - - cpg: clock-controller@11010000 { - compatible = "renesas,r9a07g044-cpg"; - reg = <0 0x11010000 0 0x10000>; - clocks = <&extal_clk>; - clock-names = "extal"; - #clock-cells = <2>; - #reset-cells = <1>; - #power-domain-cells = <0>; - }; - - sysc: system-controller@11020000 { - compatible = "renesas,r9a07g044-sysc"; - reg = <0 0x11020000 0 0x10000>; - interrupts = <GIC_SPI 42 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 43 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 44 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 45 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "lpm_int", "ca55stbydone_int", - "cm33stbyr_int", "ca55_deny"; - status = "disabled"; - }; - - pinctrl: pinctrl@11030000 { - compatible = "renesas,r9a07g044-pinctrl"; - reg = <0 0x11030000 0 0x10000>; - gpio-controller; - #gpio-cells = <2>; - #interrupt-cells = <2>; - interrupt-parent = <&irqc>; - interrupt-controller; - gpio-ranges = <&pinctrl 0 0 392>; - clocks = <&cpg CPG_MOD R9A07G044_GPIO_HCLK>; - power-domains = <&cpg>; - resets = <&cpg R9A07G044_GPIO_RSTN>, - <&cpg R9A07G044_GPIO_PORT_RESETN>, - <&cpg R9A07G044_GPIO_SPARE_RESETN>; - }; - - irqc: interrupt-controller@110a0000 { - compatible = "renesas,r9a07g044-irqc", - "renesas,rzg2l-irqc"; - #interrupt-cells = <2>; - #address-cells = <0>; - interrupt-controller; - reg = <0 0x110a0000 0 0x10000>; - interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 1 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 2 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 3 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 4 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 5 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 6 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 444 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 445 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 446 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 447 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 448 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 449 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 450 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 451 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 452 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 453 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 454 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 455 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 456 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 457 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 458 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 459 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 460 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 461 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 462 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 463 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 464 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 465 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 466 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 467 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 468 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 469 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 470 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 471 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 472 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 473 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 474 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 475 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD R9A07G044_IA55_CLK>, - <&cpg CPG_MOD R9A07G044_IA55_PCLK>; - clock-names = "clk", "pclk"; - power-domains = <&cpg>; - resets = <&cpg R9A07G044_IA55_RESETN>; - }; - - dmac: dma-controller@11820000 { - compatible = "renesas,r9a07g044-dmac", - "renesas,rz-dmac"; - reg = <0 0x11820000 0 0x10000>, - <0 0x11830000 0 0x10000>; - interrupts = <GIC_SPI 141 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 125 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 126 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 127 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 128 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 129 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 130 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 131 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 132 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 133 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 134 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 135 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 136 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 137 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 138 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 139 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 140 IRQ_TYPE_EDGE_RISING>; - interrupt-names = "error", - "ch0", "ch1", "ch2", "ch3", - "ch4", "ch5", "ch6", "ch7", - "ch8", "ch9", "ch10", "ch11", - "ch12", "ch13", "ch14", "ch15"; - clocks = <&cpg CPG_MOD R9A07G044_DMAC_ACLK>, - <&cpg CPG_MOD R9A07G044_DMAC_PCLK>; - clock-names = "main", "register"; - power-domains = <&cpg>; - resets = <&cpg R9A07G044_DMAC_ARESETN>, - <&cpg R9A07G044_DMAC_RST_ASYNC>; - reset-names = "arst", "rst_async"; - #dma-cells = <1>; - dma-channels = <16>; - }; - - gpu: gpu@11840000 { - compatible = "renesas,r9a07g044-mali", - "arm,mali-bifrost"; - reg = <0x0 0x11840000 0x0 0x10000>; - interrupts = <GIC_SPI 154 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 155 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 153 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 156 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "job", "mmu", "gpu", "event"; - clocks = <&cpg CPG_MOD R9A07G044_GPU_CLK>, - <&cpg CPG_MOD R9A07G044_GPU_AXI_CLK>, - <&cpg CPG_MOD R9A07G044_GPU_ACE_CLK>; - clock-names = "gpu", "bus", "bus_ace"; - power-domains = <&cpg>; - resets = <&cpg R9A07G044_GPU_RESETN>, - <&cpg R9A07G044_GPU_AXI_RESETN>, - <&cpg R9A07G044_GPU_ACE_RESETN>; - reset-names = "rst", "axi_rst", "ace_rst"; - operating-points-v2 = <&gpu_opp_table>; - }; - - gic: interrupt-controller@11900000 { - compatible = "arm,gic-v3"; - #interrupt-cells = <3>; - #address-cells = <0>; - interrupt-controller; - reg = <0x0 0x11900000 0 0x40000>, - <0x0 0x11940000 0 0x60000>; - interrupts = <GIC_PPI 9 IRQ_TYPE_LEVEL_LOW>; - }; - - sdhi0: mmc@11c00000 { - compatible = "renesas,sdhi-r9a07g044", - "renesas,rcar-gen3-sdhi"; - reg = <0x0 0x11c00000 0 0x10000>; - interrupts = <GIC_SPI 104 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 105 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD R9A07G044_SDHI0_IMCLK>, - <&cpg CPG_MOD R9A07G044_SDHI0_CLK_HS>, - <&cpg CPG_MOD R9A07G044_SDHI0_IMCLK2>, - <&cpg CPG_MOD R9A07G044_SDHI0_ACLK>; - clock-names = "core", "clkh", "cd", "aclk"; - resets = <&cpg R9A07G044_SDHI0_IXRST>; - power-domains = <&cpg>; - status = "disabled"; - }; - - sdhi1: mmc@11c10000 { - compatible = "renesas,sdhi-r9a07g044", - "renesas,rcar-gen3-sdhi"; - reg = <0x0 0x11c10000 0 0x10000>; - interrupts = <GIC_SPI 106 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 107 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD R9A07G044_SDHI1_IMCLK>, - <&cpg CPG_MOD R9A07G044_SDHI1_CLK_HS>, - <&cpg CPG_MOD R9A07G044_SDHI1_IMCLK2>, - <&cpg CPG_MOD R9A07G044_SDHI1_ACLK>; - clock-names = "core", "clkh", "cd", "aclk"; - resets = <&cpg R9A07G044_SDHI1_IXRST>; - power-domains = <&cpg>; - status = "disabled"; - }; - - eth0: ethernet@11c20000 { - compatible = "renesas,r9a07g044-gbeth", - "renesas,rzg2l-gbeth"; - reg = <0 0x11c20000 0 0x10000>; - interrupts = <GIC_SPI 84 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 85 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 86 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "mux", "fil", "arp_ns"; - phy-mode = "rgmii"; - clocks = <&cpg CPG_MOD R9A07G044_ETH0_CLK_AXI>, - <&cpg CPG_MOD R9A07G044_ETH0_CLK_CHI>, - <&cpg CPG_CORE R9A07G044_CLK_HP>; - clock-names = "axi", "chi", "refclk"; - resets = <&cpg R9A07G044_ETH0_RST_HW_N>; - power-domains = <&cpg>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - eth1: ethernet@11c30000 { - compatible = "renesas,r9a07g044-gbeth", - "renesas,rzg2l-gbeth"; - reg = <0 0x11c30000 0 0x10000>; - interrupts = <GIC_SPI 87 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 88 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 89 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "mux", "fil", "arp_ns"; - phy-mode = "rgmii"; - clocks = <&cpg CPG_MOD R9A07G044_ETH1_CLK_AXI>, - <&cpg CPG_MOD R9A07G044_ETH1_CLK_CHI>, - <&cpg CPG_CORE R9A07G044_CLK_HP>; - clock-names = "axi", "chi", "refclk"; - resets = <&cpg R9A07G044_ETH1_RST_HW_N>; - power-domains = <&cpg>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - phyrst: usbphy-ctrl@11c40000 { - compatible = "renesas,r9a07g044-usbphy-ctrl", - "renesas,rzg2l-usbphy-ctrl"; - reg = <0 0x11c40000 0 0x10000>; - clocks = <&cpg CPG_MOD R9A07G044_USB_PCLK>; - resets = <&cpg R9A07G044_USB_PRESETN>; - power-domains = <&cpg>; - #reset-cells = <1>; - status = "disabled"; - }; - - ohci0: usb@11c50000 { - compatible = "generic-ohci"; - reg = <0 0x11c50000 0 0x100>; - interrupts = <GIC_SPI 91 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD R9A07G044_USB_PCLK>, - <&cpg CPG_MOD R9A07G044_USB_U2H0_HCLK>; - resets = <&phyrst 0>, - <&cpg R9A07G044_USB_U2H0_HRESETN>; - phys = <&usb2_phy0 1>; - phy-names = "usb"; - power-domains = <&cpg>; - status = "disabled"; - }; - - ohci1: usb@11c70000 { - compatible = "generic-ohci"; - reg = <0 0x11c70000 0 0x100>; - interrupts = <GIC_SPI 96 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD R9A07G044_USB_PCLK>, - <&cpg CPG_MOD R9A07G044_USB_U2H1_HCLK>; - resets = <&phyrst 1>, - <&cpg R9A07G044_USB_U2H1_HRESETN>; - phys = <&usb2_phy1 1>; - phy-names = "usb"; - power-domains = <&cpg>; - status = "disabled"; - }; - - ehci0: usb@11c50100 { - compatible = "generic-ehci"; - reg = <0 0x11c50100 0 0x100>; - interrupts = <GIC_SPI 92 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD R9A07G044_USB_PCLK>, - <&cpg CPG_MOD R9A07G044_USB_U2H0_HCLK>; - resets = <&phyrst 0>, - <&cpg R9A07G044_USB_U2H0_HRESETN>; - phys = <&usb2_phy0 2>; - phy-names = "usb"; - companion = <&ohci0>; - power-domains = <&cpg>; - status = "disabled"; - }; - - ehci1: usb@11c70100 { - compatible = "generic-ehci"; - reg = <0 0x11c70100 0 0x100>; - interrupts = <GIC_SPI 97 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD R9A07G044_USB_PCLK>, - <&cpg CPG_MOD R9A07G044_USB_U2H1_HCLK>; - resets = <&phyrst 1>, - <&cpg R9A07G044_USB_U2H1_HRESETN>; - phys = <&usb2_phy1 2>; - phy-names = "usb"; - companion = <&ohci1>; - power-domains = <&cpg>; - status = "disabled"; - }; - - usb2_phy0: usb-phy@11c50200 { - compatible = "renesas,usb2-phy-r9a07g044", - "renesas,rzg2l-usb2-phy"; - reg = <0 0x11c50200 0 0x700>; - interrupts = <GIC_SPI 94 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD R9A07G044_USB_PCLK>, - <&cpg CPG_MOD R9A07G044_USB_U2H0_HCLK>; - resets = <&phyrst 0>; - #phy-cells = <1>; - power-domains = <&cpg>; - status = "disabled"; - }; - - usb2_phy1: usb-phy@11c70200 { - compatible = "renesas,usb2-phy-r9a07g044", - "renesas,rzg2l-usb2-phy"; - reg = <0 0x11c70200 0 0x700>; - interrupts = <GIC_SPI 99 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD R9A07G044_USB_PCLK>, - <&cpg CPG_MOD R9A07G044_USB_U2H1_HCLK>; - resets = <&phyrst 1>; - #phy-cells = <1>; - power-domains = <&cpg>; - status = "disabled"; - }; - - hsusb: usb@11c60000 { - compatible = "renesas,usbhs-r9a07g044", - "renesas,rza2-usbhs"; - reg = <0 0x11c60000 0 0x10000>; - interrupts = <GIC_SPI 100 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 101 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 102 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 103 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cpg CPG_MOD R9A07G044_USB_PCLK>, - <&cpg CPG_MOD R9A07G044_USB_U2P_EXR_CPUCLK>; - resets = <&phyrst 0>, - <&cpg R9A07G044_USB_U2P_EXL_SYSRST>; - renesas,buswait = <7>; - phys = <&usb2_phy0 3>; - phy-names = "usb"; - power-domains = <&cpg>; - status = "disabled"; - }; - - wdt0: watchdog@12800800 { - compatible = "renesas,r9a07g044-wdt", - "renesas,rzg2l-wdt"; - reg = <0 0x12800800 0 0x400>; - clocks = <&cpg CPG_MOD R9A07G044_WDT0_PCLK>, - <&cpg CPG_MOD R9A07G044_WDT0_CLK>; - clock-names = "pclk", "oscclk"; - interrupts = <GIC_SPI 49 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 50 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "wdt", "perrout"; - resets = <&cpg R9A07G044_WDT0_PRESETN>; - power-domains = <&cpg>; - status = "disabled"; - }; - - wdt1: watchdog@12800c00 { - compatible = "renesas,r9a07g044-wdt", - "renesas,rzg2l-wdt"; - reg = <0 0x12800C00 0 0x400>; - clocks = <&cpg CPG_MOD R9A07G044_WDT1_PCLK>, - <&cpg CPG_MOD R9A07G044_WDT1_CLK>; - clock-names = "pclk", "oscclk"; - interrupts = <GIC_SPI 51 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 52 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "wdt", "perrout"; - resets = <&cpg R9A07G044_WDT1_PRESETN>; - power-domains = <&cpg>; - status = "disabled"; - }; - - ostm0: timer@12801000 { - compatible = "renesas,r9a07g044-ostm", - "renesas,ostm"; - reg = <0x0 0x12801000 0x0 0x400>; - interrupts = <GIC_SPI 46 IRQ_TYPE_EDGE_RISING>; - clocks = <&cpg CPG_MOD R9A07G044_OSTM0_PCLK>; - resets = <&cpg R9A07G044_OSTM0_PRESETZ>; - power-domains = <&cpg>; - status = "disabled"; - }; - - ostm1: timer@12801400 { - compatible = "renesas,r9a07g044-ostm", - "renesas,ostm"; - reg = <0x0 0x12801400 0x0 0x400>; - interrupts = <GIC_SPI 47 IRQ_TYPE_EDGE_RISING>; - clocks = <&cpg CPG_MOD R9A07G044_OSTM1_PCLK>; - resets = <&cpg R9A07G044_OSTM1_PRESETZ>; - power-domains = <&cpg>; - status = "disabled"; - }; - - ostm2: timer@12801800 { - compatible = "renesas,r9a07g044-ostm", - "renesas,ostm"; - reg = <0x0 0x12801800 0x0 0x400>; - interrupts = <GIC_SPI 48 IRQ_TYPE_EDGE_RISING>; - clocks = <&cpg CPG_MOD R9A07G044_OSTM2_PCLK>; - resets = <&cpg R9A07G044_OSTM2_PRESETZ>; - power-domains = <&cpg>; - status = "disabled"; - }; - }; - - thermal-zones { - cpu-thermal { - polling-delay-passive = <250>; - polling-delay = <1000>; - thermal-sensors = <&tsu 0>; - sustainable-power = <717>; - - cooling-maps { - map0 { - trip = <&target>; - cooling-device = <&cpu0 0 2>; - contribution = <1024>; - }; - }; - - trips { - sensor_crit: sensor-crit { - temperature = <125000>; - hysteresis = <1000>; - type = "critical"; - }; - - target: trip-point { - temperature = <100000>; - hysteresis = <1000>; - type = "passive"; - }; - }; - }; - }; - - timer { - compatible = "arm,armv8-timer"; - interrupts-extended = <&gic GIC_PPI 13 IRQ_TYPE_LEVEL_LOW>, - <&gic GIC_PPI 14 IRQ_TYPE_LEVEL_LOW>, - <&gic GIC_PPI 11 IRQ_TYPE_LEVEL_LOW>, - <&gic GIC_PPI 10 IRQ_TYPE_LEVEL_LOW>; - }; -}; diff --git a/arch/arm/dts/r9a07g044l2-smarc.dts b/arch/arm/dts/r9a07g044l2-smarc.dts deleted file mode 100644 index 568d49cfe44a..000000000000 --- a/arch/arm/dts/r9a07g044l2-smarc.dts +++ /dev/null @@ -1,39 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0-only OR BSD-2-Clause) -/* - * Device Tree Source for the RZ/G2L SMARC EVK board - * - * Copyright (C) 2021 Renesas Electronics Corp. - */ - -/dts-v1/; - -/* Enable SCIF2 (SER0) on PMOD1 (CN7) */ -#define PMOD1_SER0 1 - -/* - * To enable MTU3a PWM on PMOD0, - * Disable PMOD1_SER0 by setting "#define PMOD1_SER0 0" above and - * enable PMOD_MTU3 by setting "#define PMOD_MTU3 1" below. - */ -#define PMOD_MTU3 0 - -#if (PMOD_MTU3 && PMOD1_SER0) -#error "Cannot set as PMOD_MTU3 and PMOD1_SER0 are mutually exclusive " -#endif - -#define MTU3_COUNTER_Z_PHASE_SIGNAL 0 - -#if (!PMOD_MTU3 && MTU3_COUNTER_Z_PHASE_SIGNAL) -#error "Cannot set 1 to MTU3_COUNTER_Z_PHASE_SIGNAL as PMOD_MTU3=0" -#endif - -#include "r9a07g044l2.dtsi" -#include "rzg2l-smarc-som.dtsi" -#include "rzg2l-smarc-pinfunction.dtsi" -#include "rz-smarc-common.dtsi" -#include "rzg2l-smarc.dtsi" - -/ { - model = "Renesas SMARC EVK based on r9a07g044l2"; - compatible = "renesas,smarc-evk", "renesas,r9a07g044l2", "renesas,r9a07g044"; -}; diff --git a/arch/arm/dts/r9a07g044l2.dtsi b/arch/arm/dts/r9a07g044l2.dtsi deleted file mode 100644 index 91dc10b2cdbb..000000000000 --- a/arch/arm/dts/r9a07g044l2.dtsi +++ /dev/null @@ -1,13 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0-only OR BSD-2-Clause) -/* - * Device Tree Source for the RZ/G2L R9A07G044L2 SoC specific parts - * - * Copyright (C) 2021 Renesas Electronics Corp. - */ - -/dts-v1/; -#include "r9a07g044.dtsi" - -/ { - compatible = "renesas,r9a07g044l2", "renesas,r9a07g044"; -}; diff --git a/arch/arm/dts/rz-smarc-common.dtsi b/arch/arm/dts/rz-smarc-common.dtsi deleted file mode 100644 index b7a3e6caa386..000000000000 --- a/arch/arm/dts/rz-smarc-common.dtsi +++ /dev/null @@ -1,183 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0-only OR BSD-2-Clause) -/* - * Device Tree Source for the RZ/{G2L,G2LC,V2L} SMARC EVK common parts - * - * Copyright (C) 2022 Renesas Electronics Corp. - */ - -#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/pinctrl/rzg2l-pinctrl.h> - -/* - * SSI-WM8978 - * - * This command is required when Playback/Capture - * - * amixer cset name='Left Input Mixer L2 Switch' on - * amixer cset name='Right Input Mixer R2 Switch' on - * amixer cset name='Headphone Playback Volume' 100 - * amixer cset name='PCM Volume' 100% - * amixer cset name='Input PGA Volume' 25 - * - */ - -/ { - aliases { - serial0 = &scif0; - i2c0 = &i2c0; - i2c1 = &i2c1; - }; - - chosen { - stdout-path = "serial0:115200n8"; - }; - - snd_rzg2l: sound { - compatible = "simple-audio-card"; - simple-audio-card,format = "i2s"; - simple-audio-card,bitclock-master = <&cpu_dai>; - simple-audio-card,frame-master = <&cpu_dai>; - simple-audio-card,mclk-fs = <256>; - - simple-audio-card,widgets = "Microphone", "Microphone Jack"; - simple-audio-card,routing = - "L2", "Mic Bias", - "R2", "Mic Bias", - "Mic Bias", "Microphone Jack"; - - cpu_dai: simple-audio-card,cpu { - }; - - codec_dai: simple-audio-card,codec { - clocks = <&versa3 2>; - sound-dai = <&wm8978>; - }; - }; - - usb0_vbus_otg: regulator-usb0-vbus-otg { - compatible = "regulator-fixed"; - - regulator-name = "USB0_VBUS_OTG"; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - }; - - vccq_sdhi1: regulator-vccq-sdhi1 { - compatible = "regulator-gpio"; - regulator-name = "SDHI1 VccQ"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <3300000>; - gpios-states = <1>; - states = <3300000 1>, <1800000 0>; - }; - - x1: x1-clock { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <24000000>; - }; -}; - -&audio_clk1 { - clock-frequency = <11289600>; -}; - -&audio_clk2 { - clock-frequency = <12288000>; -}; - -&canfd { - pinctrl-0 = <&can0_pins &can1_pins>; - pinctrl-names = "default"; - status = "okay"; - - channel0 { - status = "okay"; - }; - - channel1 { - status = "okay"; - }; -}; - -&ehci0 { - dr_mode = "otg"; - status = "okay"; -}; - -&ehci1 { - status = "okay"; -}; - -&hsusb { - dr_mode = "otg"; - status = "okay"; -}; - -&i2c0 { - pinctrl-0 = <&i2c0_pins>; - pinctrl-names = "default"; - - status = "okay"; -}; - -&i2c1 { - pinctrl-0 = <&i2c1_pins>; - pinctrl-names = "default"; - - status = "okay"; -}; - -&ohci0 { - dr_mode = "otg"; - status = "okay"; -}; - -&ohci1 { - status = "okay"; -}; - -&phyrst { - status = "okay"; -}; - -&scif0 { - pinctrl-0 = <&scif0_pins>; - pinctrl-names = "default"; - status = "okay"; -}; - -&sdhi1 { - pinctrl-0 = <&sdhi1_pins>; - pinctrl-1 = <&sdhi1_pins_uhs>; - pinctrl-names = "default", "state_uhs"; - - vmmc-supply = <®_3p3v>; - vqmmc-supply = <&vccq_sdhi1>; - bus-width = <4>; - sd-uhs-sdr50; - sd-uhs-sdr104; - status = "okay"; -}; - -&spi1 { - pinctrl-0 = <&spi1_pins>; - pinctrl-names = "default"; - - status = "okay"; -}; - -&usb2_phy0 { - pinctrl-0 = <&usb0_pins>; - pinctrl-names = "default"; - - vbus-supply = <&usb0_vbus_otg>; - status = "okay"; -}; - -&usb2_phy1 { - pinctrl-0 = <&usb1_pins>; - pinctrl-names = "default"; - - status = "okay"; -}; diff --git a/arch/arm/dts/rzg2l-smarc-pinfunction.dtsi b/arch/arm/dts/rzg2l-smarc-pinfunction.dtsi deleted file mode 100644 index 18c526c7a4cf..000000000000 --- a/arch/arm/dts/rzg2l-smarc-pinfunction.dtsi +++ /dev/null @@ -1,157 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0-only OR BSD-2-Clause) -/* - * Device Tree Source for the RZ/{G2L,V2L} SMARC pincontrol parts - * - * Copyright (C) 2021 Renesas Electronics Corp. - */ - -#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/pinctrl/rzg2l-pinctrl.h> - -&pinctrl { - pinctrl-0 = <&sound_clk_pins>; - pinctrl-names = "default"; - - can0_pins: can0 { - pinmux = <RZG2L_PORT_PINMUX(10, 1, 2)>, /* TX */ - <RZG2L_PORT_PINMUX(11, 0, 2)>; /* RX */ - }; - - /* SW7 should be at position 2->3 so that GPIO8_CAN0_STB line is activated */ - can0-stb-hog { - gpio-hog; - gpios = <RZG2L_GPIO(42, 2) GPIO_ACTIVE_HIGH>; - output-low; - line-name = "can0_stb"; - }; - - can1_pins: can1 { - pinmux = <RZG2L_PORT_PINMUX(12, 1, 2)>, /* TX */ - <RZG2L_PORT_PINMUX(13, 0, 2)>; /* RX */ - }; - - /* SW8 should be at position 2->3 so that GPIO9_CAN1_STB line is activated */ - can1-stb-hog { - gpio-hog; - gpios = <RZG2L_GPIO(42, 3) GPIO_ACTIVE_HIGH>; - output-low; - line-name = "can1_stb"; - }; - - i2c0_pins: i2c0 { - pins = "RIIC0_SDA", "RIIC0_SCL"; - input-enable; - }; - - i2c1_pins: i2c1 { - pins = "RIIC1_SDA", "RIIC1_SCL"; - input-enable; - }; - - i2c3_pins: i2c3 { - pinmux = <RZG2L_PORT_PINMUX(18, 0, 3)>, /* SDA */ - <RZG2L_PORT_PINMUX(18, 1, 3)>; /* SCL */ - }; - - mtu3_pins: mtu3 { - mtu3-ext-clk-input-pin { - pinmux = <RZG2L_PORT_PINMUX(48, 0, 4)>, /* MTCLKA */ - <RZG2L_PORT_PINMUX(48, 1, 4)>; /* MTCLKB */ - }; - - mtu3-pwm { - pinmux = <RZG2L_PORT_PINMUX(44, 0, 4)>, /* MTIOC3A */ - <RZG2L_PORT_PINMUX(44, 1, 4)>, /* MTIOC3B */ - <RZG2L_PORT_PINMUX(44, 2, 4)>, /* MTIOC3C */ - <RZG2L_PORT_PINMUX(44, 3, 4)>; /* MTIOC3D */ - }; - -#if MTU3_COUNTER_Z_PHASE_SIGNAL - mtu3-zphase-clk { - pinmux = <RZG2L_PORT_PINMUX(19, 0, 3)>; /* MTIOC1A */ - }; -#endif /* MTU3_COUNTER_Z_PHASE_SIGNAL */ - }; - - scif0_pins: scif0 { - pinmux = <RZG2L_PORT_PINMUX(38, 0, 1)>, /* TxD */ - <RZG2L_PORT_PINMUX(38, 1, 1)>; /* RxD */ - }; - - scif2_pins: scif2 { - pinmux = <RZG2L_PORT_PINMUX(48, 0, 1)>, /* TxD */ - <RZG2L_PORT_PINMUX(48, 1, 1)>, /* RxD */ - <RZG2L_PORT_PINMUX(48, 3, 1)>, /* CTS# */ - <RZG2L_PORT_PINMUX(48, 4, 1)>; /* RTS# */ - }; - - sd1-pwr-en-hog { - gpio-hog; - gpios = <RZG2L_GPIO(39, 2) GPIO_ACTIVE_HIGH>; - output-high; - line-name = "sd1_pwr_en"; - }; - - sdhi1_pins: sd1 { - sd1_data { - pins = "SD1_DATA0", "SD1_DATA1", "SD1_DATA2", "SD1_DATA3"; - power-source = <3300>; - }; - - sd1_ctrl { - pins = "SD1_CLK", "SD1_CMD"; - power-source = <3300>; - }; - - sd1_mux { - pinmux = <RZG2L_PORT_PINMUX(19, 0, 1)>; /* SD1_CD */ - }; - }; - - sdhi1_pins_uhs: sd1_uhs { - sd1_data_uhs { - pins = "SD1_DATA0", "SD1_DATA1", "SD1_DATA2", "SD1_DATA3"; - power-source = <1800>; - }; - - sd1_ctrl_uhs { - pins = "SD1_CLK", "SD1_CMD"; - power-source = <1800>; - }; - - sd1_mux_uhs { - pinmux = <RZG2L_PORT_PINMUX(19, 0, 1)>; /* SD1_CD */ - }; - }; - - sound_clk_pins: sound_clk { - pins = "AUDIO_CLK1", "AUDIO_CLK2"; - input-enable; - }; - - spi1_pins: spi1 { - pinmux = <RZG2L_PORT_PINMUX(44, 0, 1)>, /* CK */ - <RZG2L_PORT_PINMUX(44, 1, 1)>, /* MOSI */ - <RZG2L_PORT_PINMUX(44, 2, 1)>, /* MISO */ - <RZG2L_PORT_PINMUX(44, 3, 1)>; /* SSL */ - }; - - ssi0_pins: ssi0 { - pinmux = <RZG2L_PORT_PINMUX(45, 0, 1)>, /* BCK */ - <RZG2L_PORT_PINMUX(45, 1, 1)>, /* RCK */ - <RZG2L_PORT_PINMUX(45, 2, 1)>, /* TXD */ - <RZG2L_PORT_PINMUX(45, 3, 1)>; /* RXD */ - }; - - usb0_pins: usb0 { - pinmux = <RZG2L_PORT_PINMUX(4, 0, 1)>, /* VBUS */ - <RZG2L_PORT_PINMUX(5, 0, 1)>, /* OVC */ - <RZG2L_PORT_PINMUX(5, 1, 1)>; /* OTG_ID */ - }; - - usb1_pins: usb1 { - pinmux = <RZG2L_PORT_PINMUX(42, 0, 1)>, /* VBUS */ - <RZG2L_PORT_PINMUX(42, 1, 1)>; /* OVC */ - }; -}; - diff --git a/arch/arm/dts/rzg2l-smarc-som.dtsi b/arch/arm/dts/rzg2l-smarc-som.dtsi deleted file mode 100644 index 547859c388ce..000000000000 --- a/arch/arm/dts/rzg2l-smarc-som.dtsi +++ /dev/null @@ -1,371 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0-only OR BSD-2-Clause) -/* - * Device Tree Source for the RZ/{G2L,V2L} SMARC SOM common parts - * - * Copyright (C) 2021 Renesas Electronics Corp. - */ - -#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/interrupt-controller/irqc-rzg2l.h> -#include <dt-bindings/pinctrl/rzg2l-pinctrl.h> - -/* SW1[2] should be at position 2/OFF to enable 64 GB eMMC */ -#define EMMC 1 - -/* - * To enable uSD card on CN3, - * SW1[2] should be at position 3/ON. - * Disable eMMC by setting "#define EMMC 0" above. - */ -#define SDHI (!EMMC) - -/ { - aliases { - ethernet0 = ð0; - ethernet1 = ð1; - }; - - chosen { - bootargs = "ignore_loglevel rw root=/dev/nfs ip=on"; - }; - - memory@48000000 { - device_type = "memory"; - /* first 128MB is reserved for secure area. */ - reg = <0x0 0x48000000 0x0 0x78000000>; - }; - - reg_1p8v: regulator-1p8v { - compatible = "regulator-fixed"; - regulator-name = "fixed-1.8V"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-boot-on; - regulator-always-on; - }; - - reg_3p3v: regulator-3p3v { - compatible = "regulator-fixed"; - regulator-name = "fixed-3.3V"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-boot-on; - regulator-always-on; - }; - - reg_1p1v: regulator-vdd-core { - compatible = "regulator-fixed"; - regulator-name = "fixed-1.1V"; - regulator-min-microvolt = <1100000>; - regulator-max-microvolt = <1100000>; - regulator-boot-on; - regulator-always-on; - }; - - vccq_sdhi0: regulator-vccq-sdhi0 { - compatible = "regulator-gpio"; - - regulator-name = "SDHI0 VccQ"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <3300000>; - states = <3300000 1>, <1800000 0>; - regulator-boot-on; - gpios = <&pinctrl RZG2L_GPIO(39, 0) GPIO_ACTIVE_HIGH>; - regulator-always-on; - }; - - /* 32.768kHz crystal */ - x2: x2-clock { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <32768>; - }; -}; - -&adc { - pinctrl-0 = <&adc_pins>; - pinctrl-names = "default"; - status = "okay"; - - /delete-node/ channel@6; - /delete-node/ channel@7; -}; - -ð0 { - pinctrl-0 = <ð0_pins>; - pinctrl-names = "default"; - phy-handle = <&phy0>; - phy-mode = "rgmii-id"; - status = "okay"; - - phy0: ethernet-phy@7 { - compatible = "ethernet-phy-id0022.1640", - "ethernet-phy-ieee802.3-c22"; - reg = <7>; - interrupt-parent = <&irqc>; - interrupts = <RZG2L_IRQ2 IRQ_TYPE_LEVEL_LOW>; - rxc-skew-psec = <2400>; - txc-skew-psec = <2400>; - rxdv-skew-psec = <0>; - txen-skew-psec = <0>; - rxd0-skew-psec = <0>; - rxd1-skew-psec = <0>; - rxd2-skew-psec = <0>; - rxd3-skew-psec = <0>; - txd0-skew-psec = <0>; - txd1-skew-psec = <0>; - txd2-skew-psec = <0>; - txd3-skew-psec = <0>; - }; -}; - -ð1 { - pinctrl-0 = <ð1_pins>; - pinctrl-names = "default"; - phy-handle = <&phy1>; - phy-mode = "rgmii-id"; - status = "okay"; - - phy1: ethernet-phy@7 { - compatible = "ethernet-phy-id0022.1640", - "ethernet-phy-ieee802.3-c22"; - reg = <7>; - interrupt-parent = <&irqc>; - interrupts = <RZG2L_IRQ3 IRQ_TYPE_LEVEL_LOW>; - rxc-skew-psec = <2400>; - txc-skew-psec = <2400>; - rxdv-skew-psec = <0>; - txen-skew-psec = <0>; - rxd0-skew-psec = <0>; - rxd1-skew-psec = <0>; - rxd2-skew-psec = <0>; - rxd3-skew-psec = <0>; - txd0-skew-psec = <0>; - txd1-skew-psec = <0>; - txd2-skew-psec = <0>; - txd3-skew-psec = <0>; - }; -}; - -&extal_clk { - clock-frequency = <24000000>; -}; - -&gpu { - mali-supply = <®_1p1v>; -}; - -&i2c3 { - raa215300: pmic@12 { - compatible = "renesas,raa215300"; - reg = <0x12>, <0x6f>; - reg-names = "main", "rtc"; - - clocks = <&x2>; - clock-names = "xin"; - }; -}; - -&ostm1 { - status = "okay"; -}; - -&ostm2 { - status = "okay"; -}; - -&pinctrl { - adc_pins: adc { - pinmux = <RZG2L_PORT_PINMUX(9, 0, 2)>; /* ADC_TRG */ - }; - - eth0_pins: eth0 { - pinmux = <RZG2L_PORT_PINMUX(28, 1, 1)>, /* ET0_LINKSTA */ - <RZG2L_PORT_PINMUX(27, 1, 1)>, /* ET0_MDC */ - <RZG2L_PORT_PINMUX(28, 0, 1)>, /* ET0_MDIO */ - <RZG2L_PORT_PINMUX(20, 0, 1)>, /* ET0_TXC */ - <RZG2L_PORT_PINMUX(20, 1, 1)>, /* ET0_TX_CTL */ - <RZG2L_PORT_PINMUX(20, 2, 1)>, /* ET0_TXD0 */ - <RZG2L_PORT_PINMUX(21, 0, 1)>, /* ET0_TXD1 */ - <RZG2L_PORT_PINMUX(21, 1, 1)>, /* ET0_TXD2 */ - <RZG2L_PORT_PINMUX(22, 0, 1)>, /* ET0_TXD3 */ - <RZG2L_PORT_PINMUX(24, 0, 1)>, /* ET0_RXC */ - <RZG2L_PORT_PINMUX(24, 1, 1)>, /* ET0_RX_CTL */ - <RZG2L_PORT_PINMUX(25, 0, 1)>, /* ET0_RXD0 */ - <RZG2L_PORT_PINMUX(25, 1, 1)>, /* ET0_RXD1 */ - <RZG2L_PORT_PINMUX(26, 0, 1)>, /* ET0_RXD2 */ - <RZG2L_PORT_PINMUX(26, 1, 1)>, /* ET0_RXD3 */ - <RZG2L_PORT_PINMUX(1, 0, 1)>; /* IRQ2 */ - }; - - eth1_pins: eth1 { - pinmux = <RZG2L_PORT_PINMUX(37, 2, 1)>, /* ET1_LINKSTA */ - <RZG2L_PORT_PINMUX(37, 0, 1)>, /* ET1_MDC */ - <RZG2L_PORT_PINMUX(37, 1, 1)>, /* ET1_MDIO */ - <RZG2L_PORT_PINMUX(29, 0, 1)>, /* ET1_TXC */ - <RZG2L_PORT_PINMUX(29, 1, 1)>, /* ET1_TX_CTL */ - <RZG2L_PORT_PINMUX(30, 0, 1)>, /* ET1_TXD0 */ - <RZG2L_PORT_PINMUX(30, 1, 1)>, /* ET1_TXD1 */ - <RZG2L_PORT_PINMUX(31, 0, 1)>, /* ET1_TXD2 */ - <RZG2L_PORT_PINMUX(31, 1, 1)>, /* ET1_TXD3 */ - <RZG2L_PORT_PINMUX(33, 1, 1)>, /* ET1_RXC */ - <RZG2L_PORT_PINMUX(34, 0, 1)>, /* ET1_RX_CTL */ - <RZG2L_PORT_PINMUX(34, 1, 1)>, /* ET1_RXD0 */ - <RZG2L_PORT_PINMUX(35, 0, 1)>, /* ET1_RXD1 */ - <RZG2L_PORT_PINMUX(35, 1, 1)>, /* ET1_RXD2 */ - <RZG2L_PORT_PINMUX(36, 0, 1)>, /* ET1_RXD3 */ - <RZG2L_PORT_PINMUX(1, 1, 1)>; /* IRQ3 */ - }; - - gpio-sd0-pwr-en-hog { - gpio-hog; - gpios = <RZG2L_GPIO(4, 1) GPIO_ACTIVE_HIGH>; - output-high; - line-name = "gpio_sd0_pwr_en"; - }; - - qspi0_pins: qspi0 { - qspi0-data { - pins = "QSPI0_IO0", "QSPI0_IO1", "QSPI0_IO2", "QSPI0_IO3"; - power-source = <1800>; - }; - - qspi0-ctrl { - pins = "QSPI0_SPCLK", "QSPI0_SSL", "QSPI_RESET#"; - power-source = <1800>; - }; - }; - - /* - * SD0 device selection is XOR between GPIO_SD0_DEV_SEL and SW1[2] - * The below switch logic can be used to select the device between - * eMMC and microSD, after setting GPIO_SD0_DEV_SEL to high in DT. - * SW1[2] should be at position 2/OFF to enable 64 GB eMMC - * SW1[2] should be at position 3/ON to enable uSD card CN3 - */ - sd0-dev-sel-hog { - gpio-hog; - gpios = <RZG2L_GPIO(41, 1) GPIO_ACTIVE_HIGH>; - output-high; - line-name = "sd0_dev_sel"; - }; - - sdhi0_emmc_pins: sd0emmc { - sd0_emmc_data { - pins = "SD0_DATA0", "SD0_DATA1", "SD0_DATA2", "SD0_DATA3", - "SD0_DATA4", "SD0_DATA5", "SD0_DATA6", "SD0_DATA7"; - power-source = <1800>; - }; - - sd0_emmc_ctrl { - pins = "SD0_CLK", "SD0_CMD"; - power-source = <1800>; - }; - - sd0_emmc_rst { - pins = "SD0_RST#"; - power-source = <1800>; - }; - }; - - sdhi0_pins: sd0 { - sd0_data { - pins = "SD0_DATA0", "SD0_DATA1", "SD0_DATA2", "SD0_DATA3"; - power-source = <3300>; - }; - - sd0_ctrl { - pins = "SD0_CLK", "SD0_CMD"; - power-source = <3300>; - }; - - sd0_mux { - pinmux = <RZG2L_PORT_PINMUX(47, 0, 2)>; /* SD0_CD */ - }; - }; - - sdhi0_pins_uhs: sd0_uhs { - sd0_data_uhs { - pins = "SD0_DATA0", "SD0_DATA1", "SD0_DATA2", "SD0_DATA3"; - power-source = <1800>; - }; - - sd0_ctrl_uhs { - pins = "SD0_CLK", "SD0_CMD"; - power-source = <1800>; - }; - - sd0_mux_uhs { - pinmux = <RZG2L_PORT_PINMUX(47, 0, 2)>; /* SD0_CD */ - }; - }; -}; - -&sbc { - pinctrl-0 = <&qspi0_pins>; - pinctrl-names = "default"; - status = "okay"; - - flash@0 { - compatible = "micron,mt25qu512a", "jedec,spi-nor"; - reg = <0>; - m25p,fast-read; - spi-max-frequency = <50000000>; - spi-rx-bus-width = <4>; - - partitions { - compatible = "fixed-partitions"; - #address-cells = <1>; - #size-cells = <1>; - - boot@0 { - reg = <0x00000000 0x2000000>; - read-only; - }; - user@2000000 { - reg = <0x2000000 0x2000000>; - }; - }; - }; -}; - -#if SDHI -&sdhi0 { - pinctrl-0 = <&sdhi0_pins>; - pinctrl-1 = <&sdhi0_pins_uhs>; - pinctrl-names = "default", "state_uhs"; - - vmmc-supply = <®_3p3v>; - vqmmc-supply = <&vccq_sdhi0>; - bus-width = <4>; - sd-uhs-sdr50; - sd-uhs-sdr104; - status = "okay"; -}; -#endif - -#if EMMC -&sdhi0 { - pinctrl-0 = <&sdhi0_emmc_pins>; - pinctrl-1 = <&sdhi0_emmc_pins>; - pinctrl-names = "default", "state_uhs"; - - vmmc-supply = <®_3p3v>; - vqmmc-supply = <®_1p8v>; - bus-width = <8>; - mmc-hs200-1_8v; - non-removable; - fixed-emmc-driver-type = <1>; - status = "okay"; -}; -#endif - -&wdt0 { - status = "okay"; - timeout-sec = <60>; -}; - -&wdt1 { - status = "okay"; - timeout-sec = <60>; -}; diff --git a/arch/arm/dts/rzg2l-smarc.dtsi b/arch/arm/dts/rzg2l-smarc.dtsi deleted file mode 100644 index 37807f1bda4d..000000000000 --- a/arch/arm/dts/rzg2l-smarc.dtsi +++ /dev/null @@ -1,181 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0-only OR BSD-2-Clause) -/* - * Device Tree Source for the RZ/{G2L,V2L} SMARC EVK common parts - * - * Copyright (C) 2021 Renesas Electronics Corp. - */ - -#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/pinctrl/rzg2l-pinctrl.h> - -/ { - aliases { - serial1 = &scif2; - i2c3 = &i2c3; - }; - - osc1: cec-clock { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <12000000>; - }; - - hdmi-out { - compatible = "hdmi-connector"; - type = "d"; - - port { - hdmi_con_out: endpoint { - remote-endpoint = <&adv7535_out>; - }; - }; - }; -}; - -&cpu_dai { - sound-dai = <&ssi0>; -}; - -&dsi { - status = "okay"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - dsi0_in: endpoint { - }; - }; - - port@1 { - reg = <1>; - dsi0_out: endpoint { - data-lanes = <1 2 3 4>; - remote-endpoint = <&adv7535_in>; - }; - }; - }; -}; - -&i2c1 { - adv7535: hdmi@3d { - compatible = "adi,adv7535"; - reg = <0x3d>; - - interrupt-parent = <&pinctrl>; - interrupts = <RZG2L_GPIO(2, 1) IRQ_TYPE_EDGE_FALLING>; - clocks = <&osc1>; - clock-names = "cec"; - avdd-supply = <®_1p8v>; - dvdd-supply = <®_1p8v>; - pvdd-supply = <®_1p8v>; - a2vdd-supply = <®_1p8v>; - v3p3-supply = <®_3p3v>; - v1p2-supply = <®_1p8v>; - - adi,dsi-lanes = <4>; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - adv7535_in: endpoint { - remote-endpoint = <&dsi0_out>; - }; - }; - - port@1 { - reg = <1>; - adv7535_out: endpoint { - remote-endpoint = <&hdmi_con_out>; - }; - }; - }; - }; -}; - -&i2c3 { - pinctrl-0 = <&i2c3_pins>; - pinctrl-names = "default"; - clock-frequency = <400000>; - - status = "okay"; - - wm8978: codec@1a { - compatible = "wlf,wm8978"; - #sound-dai-cells = <0>; - reg = <0x1a>; - }; - - versa3: clock-generator@68 { - compatible = "renesas,5p35023"; - reg = <0x68>; - #clock-cells = <1>; - clocks = <&x1>; - - renesas,settings = [ - 80 00 11 19 4c 02 23 7f 83 19 08 a9 5f 25 24 bf - 00 14 7a e1 00 00 00 00 01 55 59 bb 3f 30 90 b6 - 80 b0 45 c4 95 - ]; - - assigned-clocks = <&versa3 0>, <&versa3 1>, - <&versa3 2>, <&versa3 3>, - <&versa3 4>, <&versa3 5>; - assigned-clock-rates = <24000000>, <11289600>, - <11289600>, <12000000>, - <25000000>, <12288000>; - }; -}; - -#if PMOD_MTU3 -&mtu3 { - pinctrl-0 = <&mtu3_pins>; - pinctrl-names = "default"; - - status = "okay"; -}; - -#if MTU3_COUNTER_Z_PHASE_SIGNAL -/* SDHI cd pin is muxed with counter Z phase signal */ -&sdhi1 { - status = "disabled"; -}; -#endif /* MTU3_COUNTER_Z_PHASE_SIGNAL */ - -&spi1 { - status = "disabled"; -}; -#endif /* PMOD_MTU3 */ - -/* - * To enable SCIF2 (SER0) on PMOD1 (CN7) - * SW1 should be at position 2->3 so that SER0_CTS# line is activated - * SW2 should be at position 2->3 so that SER0_TX line is activated - * SW3 should be at position 2->3 so that SER0_RX line is activated - * SW4 should be at position 2->3 so that SER0_RTS# line is activated - */ -#if PMOD1_SER0 -&scif2 { - pinctrl-0 = <&scif2_pins>; - pinctrl-names = "default"; - - uart-has-rtscts; - status = "okay"; -}; -#endif - -&ssi0 { - pinctrl-0 = <&ssi0_pins>; - pinctrl-names = "default"; - - status = "okay"; -}; - -&vccq_sdhi1 { - gpios = <&pinctrl RZG2L_GPIO(39, 1) GPIO_ACTIVE_HIGH>; -};
Signed-off-by: Paul Barker paul.barker.ct@bp.renesas.com --- include/dt-bindings/clock/r9a07g044-cpg.h | 220 ------------------ .../interrupt-controller/irqc-rzg2l.h | 25 -- include/dt-bindings/pinctrl/rzg2l-pinctrl.h | 23 -- 3 files changed, 268 deletions(-) delete mode 100644 include/dt-bindings/clock/r9a07g044-cpg.h delete mode 100644 include/dt-bindings/interrupt-controller/irqc-rzg2l.h delete mode 100644 include/dt-bindings/pinctrl/rzg2l-pinctrl.h
diff --git a/include/dt-bindings/clock/r9a07g044-cpg.h b/include/dt-bindings/clock/r9a07g044-cpg.h deleted file mode 100644 index 0bb17ff1a01a..000000000000 --- a/include/dt-bindings/clock/r9a07g044-cpg.h +++ /dev/null @@ -1,220 +0,0 @@ -/* SPDX-License-Identifier: (GPL-2.0-only OR BSD-2-Clause) - * - * Copyright (C) 2021 Renesas Electronics Corp. - */ -#ifndef __DT_BINDINGS_CLOCK_R9A07G044_CPG_H__ -#define __DT_BINDINGS_CLOCK_R9A07G044_CPG_H__ - -#include <dt-bindings/clock/renesas-cpg-mssr.h> - -/* R9A07G044 CPG Core Clocks */ -#define R9A07G044_CLK_I 0 -#define R9A07G044_CLK_I2 1 -#define R9A07G044_CLK_G 2 -#define R9A07G044_CLK_S0 3 -#define R9A07G044_CLK_S1 4 -#define R9A07G044_CLK_SPI0 5 -#define R9A07G044_CLK_SPI1 6 -#define R9A07G044_CLK_SD0 7 -#define R9A07G044_CLK_SD1 8 -#define R9A07G044_CLK_M0 9 -#define R9A07G044_CLK_M1 10 -#define R9A07G044_CLK_M2 11 -#define R9A07G044_CLK_M3 12 -#define R9A07G044_CLK_M4 13 -#define R9A07G044_CLK_HP 14 -#define R9A07G044_CLK_TSU 15 -#define R9A07G044_CLK_ZT 16 -#define R9A07G044_CLK_P0 17 -#define R9A07G044_CLK_P1 18 -#define R9A07G044_CLK_P2 19 -#define R9A07G044_CLK_AT 20 -#define R9A07G044_OSCCLK 21 -#define R9A07G044_CLK_P0_DIV2 22 - -/* R9A07G044 Module Clocks */ -#define R9A07G044_CA55_SCLK 0 -#define R9A07G044_CA55_PCLK 1 -#define R9A07G044_CA55_ATCLK 2 -#define R9A07G044_CA55_GICCLK 3 -#define R9A07G044_CA55_PERICLK 4 -#define R9A07G044_CA55_ACLK 5 -#define R9A07G044_CA55_TSCLK 6 -#define R9A07G044_GIC600_GICCLK 7 -#define R9A07G044_IA55_CLK 8 -#define R9A07G044_IA55_PCLK 9 -#define R9A07G044_MHU_PCLK 10 -#define R9A07G044_SYC_CNT_CLK 11 -#define R9A07G044_DMAC_ACLK 12 -#define R9A07G044_DMAC_PCLK 13 -#define R9A07G044_OSTM0_PCLK 14 -#define R9A07G044_OSTM1_PCLK 15 -#define R9A07G044_OSTM2_PCLK 16 -#define R9A07G044_MTU_X_MCK_MTU3 17 -#define R9A07G044_POE3_CLKM_POE 18 -#define R9A07G044_GPT_PCLK 19 -#define R9A07G044_POEG_A_CLKP 20 -#define R9A07G044_POEG_B_CLKP 21 -#define R9A07G044_POEG_C_CLKP 22 -#define R9A07G044_POEG_D_CLKP 23 -#define R9A07G044_WDT0_PCLK 24 -#define R9A07G044_WDT0_CLK 25 -#define R9A07G044_WDT1_PCLK 26 -#define R9A07G044_WDT1_CLK 27 -#define R9A07G044_WDT2_PCLK 28 -#define R9A07G044_WDT2_CLK 29 -#define R9A07G044_SPI_CLK2 30 -#define R9A07G044_SPI_CLK 31 -#define R9A07G044_SDHI0_IMCLK 32 -#define R9A07G044_SDHI0_IMCLK2 33 -#define R9A07G044_SDHI0_CLK_HS 34 -#define R9A07G044_SDHI0_ACLK 35 -#define R9A07G044_SDHI1_IMCLK 36 -#define R9A07G044_SDHI1_IMCLK2 37 -#define R9A07G044_SDHI1_CLK_HS 38 -#define R9A07G044_SDHI1_ACLK 39 -#define R9A07G044_GPU_CLK 40 -#define R9A07G044_GPU_AXI_CLK 41 -#define R9A07G044_GPU_ACE_CLK 42 -#define R9A07G044_ISU_ACLK 43 -#define R9A07G044_ISU_PCLK 44 -#define R9A07G044_H264_CLK_A 45 -#define R9A07G044_H264_CLK_P 46 -#define R9A07G044_CRU_SYSCLK 47 -#define R9A07G044_CRU_VCLK 48 -#define R9A07G044_CRU_PCLK 49 -#define R9A07G044_CRU_ACLK 50 -#define R9A07G044_MIPI_DSI_PLLCLK 51 -#define R9A07G044_MIPI_DSI_SYSCLK 52 -#define R9A07G044_MIPI_DSI_ACLK 53 -#define R9A07G044_MIPI_DSI_PCLK 54 -#define R9A07G044_MIPI_DSI_VCLK 55 -#define R9A07G044_MIPI_DSI_LPCLK 56 -#define R9A07G044_LCDC_CLK_A 57 -#define R9A07G044_LCDC_CLK_P 58 -#define R9A07G044_LCDC_CLK_D 59 -#define R9A07G044_SSI0_PCLK2 60 -#define R9A07G044_SSI0_PCLK_SFR 61 -#define R9A07G044_SSI1_PCLK2 62 -#define R9A07G044_SSI1_PCLK_SFR 63 -#define R9A07G044_SSI2_PCLK2 64 -#define R9A07G044_SSI2_PCLK_SFR 65 -#define R9A07G044_SSI3_PCLK2 66 -#define R9A07G044_SSI3_PCLK_SFR 67 -#define R9A07G044_SRC_CLKP 68 -#define R9A07G044_USB_U2H0_HCLK 69 -#define R9A07G044_USB_U2H1_HCLK 70 -#define R9A07G044_USB_U2P_EXR_CPUCLK 71 -#define R9A07G044_USB_PCLK 72 -#define R9A07G044_ETH0_CLK_AXI 73 -#define R9A07G044_ETH0_CLK_CHI 74 -#define R9A07G044_ETH1_CLK_AXI 75 -#define R9A07G044_ETH1_CLK_CHI 76 -#define R9A07G044_I2C0_PCLK 77 -#define R9A07G044_I2C1_PCLK 78 -#define R9A07G044_I2C2_PCLK 79 -#define R9A07G044_I2C3_PCLK 80 -#define R9A07G044_SCIF0_CLK_PCK 81 -#define R9A07G044_SCIF1_CLK_PCK 82 -#define R9A07G044_SCIF2_CLK_PCK 83 -#define R9A07G044_SCIF3_CLK_PCK 84 -#define R9A07G044_SCIF4_CLK_PCK 85 -#define R9A07G044_SCI0_CLKP 86 -#define R9A07G044_SCI1_CLKP 87 -#define R9A07G044_IRDA_CLKP 88 -#define R9A07G044_RSPI0_CLKB 89 -#define R9A07G044_RSPI1_CLKB 90 -#define R9A07G044_RSPI2_CLKB 91 -#define R9A07G044_CANFD_PCLK 92 -#define R9A07G044_GPIO_HCLK 93 -#define R9A07G044_ADC_ADCLK 94 -#define R9A07G044_ADC_PCLK 95 -#define R9A07G044_TSU_PCLK 96 - -/* R9A07G044 Resets */ -#define R9A07G044_CA55_RST_1_0 0 -#define R9A07G044_CA55_RST_1_1 1 -#define R9A07G044_CA55_RST_3_0 2 -#define R9A07G044_CA55_RST_3_1 3 -#define R9A07G044_CA55_RST_4 4 -#define R9A07G044_CA55_RST_5 5 -#define R9A07G044_CA55_RST_6 6 -#define R9A07G044_CA55_RST_7 7 -#define R9A07G044_CA55_RST_8 8 -#define R9A07G044_CA55_RST_9 9 -#define R9A07G044_CA55_RST_10 10 -#define R9A07G044_CA55_RST_11 11 -#define R9A07G044_CA55_RST_12 12 -#define R9A07G044_GIC600_GICRESET_N 13 -#define R9A07G044_GIC600_DBG_GICRESET_N 14 -#define R9A07G044_IA55_RESETN 15 -#define R9A07G044_MHU_RESETN 16 -#define R9A07G044_DMAC_ARESETN 17 -#define R9A07G044_DMAC_RST_ASYNC 18 -#define R9A07G044_SYC_RESETN 19 -#define R9A07G044_OSTM0_PRESETZ 20 -#define R9A07G044_OSTM1_PRESETZ 21 -#define R9A07G044_OSTM2_PRESETZ 22 -#define R9A07G044_MTU_X_PRESET_MTU3 23 -#define R9A07G044_POE3_RST_M_REG 24 -#define R9A07G044_GPT_RST_C 25 -#define R9A07G044_POEG_A_RST 26 -#define R9A07G044_POEG_B_RST 27 -#define R9A07G044_POEG_C_RST 28 -#define R9A07G044_POEG_D_RST 29 -#define R9A07G044_WDT0_PRESETN 30 -#define R9A07G044_WDT1_PRESETN 31 -#define R9A07G044_WDT2_PRESETN 32 -#define R9A07G044_SPI_RST 33 -#define R9A07G044_SDHI0_IXRST 34 -#define R9A07G044_SDHI1_IXRST 35 -#define R9A07G044_GPU_RESETN 36 -#define R9A07G044_GPU_AXI_RESETN 37 -#define R9A07G044_GPU_ACE_RESETN 38 -#define R9A07G044_ISU_ARESETN 39 -#define R9A07G044_ISU_PRESETN 40 -#define R9A07G044_H264_X_RESET_VCP 41 -#define R9A07G044_H264_CP_PRESET_P 42 -#define R9A07G044_CRU_CMN_RSTB 43 -#define R9A07G044_CRU_PRESETN 44 -#define R9A07G044_CRU_ARESETN 45 -#define R9A07G044_MIPI_DSI_CMN_RSTB 46 -#define R9A07G044_MIPI_DSI_ARESET_N 47 -#define R9A07G044_MIPI_DSI_PRESET_N 48 -#define R9A07G044_LCDC_RESET_N 49 -#define R9A07G044_SSI0_RST_M2_REG 50 -#define R9A07G044_SSI1_RST_M2_REG 51 -#define R9A07G044_SSI2_RST_M2_REG 52 -#define R9A07G044_SSI3_RST_M2_REG 53 -#define R9A07G044_SRC_RST 54 -#define R9A07G044_USB_U2H0_HRESETN 55 -#define R9A07G044_USB_U2H1_HRESETN 56 -#define R9A07G044_USB_U2P_EXL_SYSRST 57 -#define R9A07G044_USB_PRESETN 58 -#define R9A07G044_ETH0_RST_HW_N 59 -#define R9A07G044_ETH1_RST_HW_N 60 -#define R9A07G044_I2C0_MRST 61 -#define R9A07G044_I2C1_MRST 62 -#define R9A07G044_I2C2_MRST 63 -#define R9A07G044_I2C3_MRST 64 -#define R9A07G044_SCIF0_RST_SYSTEM_N 65 -#define R9A07G044_SCIF1_RST_SYSTEM_N 66 -#define R9A07G044_SCIF2_RST_SYSTEM_N 67 -#define R9A07G044_SCIF3_RST_SYSTEM_N 68 -#define R9A07G044_SCIF4_RST_SYSTEM_N 69 -#define R9A07G044_SCI0_RST 70 -#define R9A07G044_SCI1_RST 71 -#define R9A07G044_IRDA_RST 72 -#define R9A07G044_RSPI0_RST 73 -#define R9A07G044_RSPI1_RST 74 -#define R9A07G044_RSPI2_RST 75 -#define R9A07G044_CANFD_RSTP_N 76 -#define R9A07G044_CANFD_RSTC_N 77 -#define R9A07G044_GPIO_RSTN 78 -#define R9A07G044_GPIO_PORT_RESETN 79 -#define R9A07G044_GPIO_SPARE_RESETN 80 -#define R9A07G044_ADC_PRESETN 81 -#define R9A07G044_ADC_ADRST_N 82 -#define R9A07G044_TSU_PRESETN 83 - -#endif /* __DT_BINDINGS_CLOCK_R9A07G044_CPG_H__ */ diff --git a/include/dt-bindings/interrupt-controller/irqc-rzg2l.h b/include/dt-bindings/interrupt-controller/irqc-rzg2l.h deleted file mode 100644 index 34ce778885a1..000000000000 --- a/include/dt-bindings/interrupt-controller/irqc-rzg2l.h +++ /dev/null @@ -1,25 +0,0 @@ -/* SPDX-License-Identifier: (GPL-2.0-only OR BSD-2-Clause) */ -/* - * This header provides constants for Renesas RZ/G2L family IRQC bindings. - * - * Copyright (C) 2022 Renesas Electronics Corp. - * - */ - -#ifndef __DT_BINDINGS_IRQC_RZG2L_H -#define __DT_BINDINGS_IRQC_RZG2L_H - -/* NMI maps to SPI0 */ -#define RZG2L_NMI 0 - -/* IRQ0-7 map to SPI1-8 */ -#define RZG2L_IRQ0 1 -#define RZG2L_IRQ1 2 -#define RZG2L_IRQ2 3 -#define RZG2L_IRQ3 4 -#define RZG2L_IRQ4 5 -#define RZG2L_IRQ5 6 -#define RZG2L_IRQ6 7 -#define RZG2L_IRQ7 8 - -#endif /* __DT_BINDINGS_IRQC_RZG2L_H */ diff --git a/include/dt-bindings/pinctrl/rzg2l-pinctrl.h b/include/dt-bindings/pinctrl/rzg2l-pinctrl.h deleted file mode 100644 index c78ed5e5efb7..000000000000 --- a/include/dt-bindings/pinctrl/rzg2l-pinctrl.h +++ /dev/null @@ -1,23 +0,0 @@ -/* SPDX-License-Identifier: (GPL-2.0-only OR BSD-2-Clause) */ -/* - * This header provides constants for Renesas RZ/G2L family pinctrl bindings. - * - * Copyright (C) 2021 Renesas Electronics Corp. - * - */ - -#ifndef __DT_BINDINGS_RZG2L_PINCTRL_H -#define __DT_BINDINGS_RZG2L_PINCTRL_H - -#define RZG2L_PINS_PER_PORT 8 - -/* - * Create the pin index from its bank and position numbers and store in - * the upper 16 bits the alternate function identifier - */ -#define RZG2L_PORT_PINMUX(b, p, f) ((b) * RZG2L_PINS_PER_PORT + (p) | ((f) << 16)) - -/* Convert a port and pin label to its global pin index */ -#define RZG2L_GPIO(port, pin) ((port) * RZG2L_PINS_PER_PORT + (pin)) - -#endif /* __DT_BINDINGS_RZG2L_PINCTRL_H */
On 10/30/24 11:32 AM, Paul Barker wrote:
We are now using the dts/upstream subtree for the RZ/G2L SoC family.
That's great news, but ... what does this commit do ?
It would be good to at least include "Drop unused headers" in the commit message.
Paul Barker
