[U-Boot] [PATCH v2 0/3] Add atmel ROM code image
This series add atmelimage support to mkimage.
An atmelimage is a quite dumb image type cause it has no real header. The file is mostly unmodified but the 6'th ARM vector gets replaced by the image size to load.
Heiko, I know your approach setting the vector in start.S but I think this solution is a bit smarter. We would need to patch at least 2 start.S files (arm926ejs and armv7), maybe also the arm920t one too. In fact is the conversion of executable BLOB to ROM detected executable BLOB something that should really be done afterwards as all other SoC vendors do.
In version 2 of this patchset the atmelimage mkimage target can also generate PMECC NAND header.
Changes in v2: * do not check filesize in atmelimage * add PMECC header generation and printout * add printout of 6'th vector * add -n switch to mkimage for PMECC type NAND and CONFIG_SYS_NANDFLASH
Andreas Bießmann (3): mkimage: add atmelimage arm:at91: enable ROM loadable atmel image sama5d3xek: enable PMECC header generation
arch/arm/cpu/armv7/at91/config.mk | 10 ++ common/image.c | 1 + doc/README.atmel_pmecc | 30 ++++ include/configs/sama5d3xek.h | 6 + include/image.h | 1 + spl/Makefile | 18 ++ tools/Makefile | 1 + tools/atmelimage.c | 345 +++++++++++++++++++++++++++++++++++++ tools/imagetool.c | 2 + tools/imagetool.h | 1 + 10 files changed, 415 insertions(+) create mode 100644 arch/arm/cpu/armv7/at91/config.mk create mode 100644 tools/atmelimage.c
The new atmelimage converts a machine code BLOB to bootable ROM image. Atmel ROM has no sophisticated image format, it only checks the first 7 ARM vectors. The vectors can contain valid B or LDR opcodes, the 6'th vector contains the image size to load.
Additionally the PMECC header can be written by the atmelimage target. The parameters must be given via the -n switch as a coma separated list. For example:
mkimage -T atmelimage \ -n usePmecc=1,sectorPerPage=4,sectorSize=512,spareSize=64,eccBits=4,eccOffset=36 \ -d spl/u-boot-spl.bin boot.bin
A provided image can be checked for correct header setup. It prints out the PMECC header parameters if it has one and the 6'th interrupt vector content.
---8<--- Image Type: ATMEL ROM-Boot Image with PMECC Header PMECC header ==================== eccOffset: 36 sectorSize: 512 eccBitReq: 4 spareSize: 64 nbSectorPerPage: 4 usePmecc: 1 ==================== 6'th vector has 17044 set --->8---
A SPL binary modified with the atmelimage mkimage target was succesfully booted on a sama5d34ek via MMC and NAND.
Signed-off-by: Andreas Bießmann andreas.devel@googlemail.com Cc: Bo Shen voice.shen@atmel.com Cc: Heiko Schocher hs@denx.de ---
common/image.c | 1 + include/image.h | 1 + tools/Makefile | 1 + tools/atmelimage.c | 345 ++++++++++++++++++++++++++++++++++++++++++++++++++++ tools/imagetool.c | 2 + tools/imagetool.h | 1 + 6 files changed, 351 insertions(+) create mode 100644 tools/atmelimage.c
diff --git a/common/image.c b/common/image.c index fcc5a9c..7cb0bd7 100644 --- a/common/image.c +++ b/common/image.c @@ -139,6 +139,7 @@ static const table_entry_t uimage_type[] = { { IH_TYPE_STANDALONE, "standalone", "Standalone Program", }, { IH_TYPE_UBLIMAGE, "ublimage", "Davinci UBL image",}, { IH_TYPE_MXSIMAGE, "mxsimage", "Freescale MXS Boot Image",}, + { IH_TYPE_ATMELIMAGE, "atmelimage", "ATMEL ROM-Boot Image",}, { -1, "", "", }, };
diff --git a/include/image.h b/include/image.h index b278778..9c3b9b8 100644 --- a/include/image.h +++ b/include/image.h @@ -225,6 +225,7 @@ struct lmb; #define IH_TYPE_PBLIMAGE 15 /* Freescale PBL Boot Image */ #define IH_TYPE_MXSIMAGE 16 /* Freescale MXSBoot Image */ #define IH_TYPE_GPIMAGE 17 /* TI Keystone GPHeader Image */ +#define IH_TYPE_ATMELIMAGE 18 /* ATMEL ROM bootable Image */
/* * Compression Types diff --git a/tools/Makefile b/tools/Makefile index 6e43a01..421ff50 100644 --- a/tools/Makefile +++ b/tools/Makefile @@ -69,6 +69,7 @@ RSA_OBJS-$(CONFIG_FIT_SIGNATURE) := rsa-sign.o rsa-verify.o rsa-checksum.o
# common objs for dumpimage and mkimage dumpimage-mkimage-objs := aisimage.o \ + atmelimage.o \ $(FIT_SIG_OBJS-y) \ crc32.o \ default_image.o \ diff --git a/tools/atmelimage.c b/tools/atmelimage.c new file mode 100644 index 0000000..099a326 --- /dev/null +++ b/tools/atmelimage.c @@ -0,0 +1,345 @@ +/* + * (C) Copyright 2014 + * Andreas Bießmann andreas.devel@googlemail.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include "imagetool.h" +#include "mkimage.h" + +#include <image.h> + +#define pr_err(fmt, args...) fprintf(stderr, "atmelimage Error: " fmt, ##args) + +static int atmel_check_image_type(uint8_t type) +{ + if (type == IH_TYPE_ATMELIMAGE) + return EXIT_SUCCESS; + else + return EXIT_FAILURE; +} + +static uint32_t nand_pmecc_header[52]; + +/* + * A helper struct for parsing the mkimage -n parameter + * + * Keep in same order as the configs array! + */ +static struct pmecc_config { + int use_pmecc; + int sector_per_page; + int spare_size; + int ecc_bits; + int sector_size; + int ecc_offset; +} pmecc; + +/* + * Strings used for configure the PMECC header via -n mkimage switch + * + * We estimate a coma separated list of key=value pairs. The mkimage -n + * parameter argument should not contain any whitespace. + * + * Keep in same order as struct pmecc_config! + */ +static const char * const configs[] = { + "usePmecc", + "sectorPerPage", + "spareSize", + "eccBits", + "sectorSize", + "eccOffset" +}; + +static int atmel_find_pmecc_parameter_in_token(const char *token) +{ + size_t pos; + char *param; + + debug("token: '%s'\n", token); + + for (pos = 0; pos < ARRAY_SIZE(configs); pos++) { + if (strncmp(token, configs[pos], strlen(configs[pos])) == 0) { + param = strstr(token, "="); + if (!param) + goto err; + + param++; + debug("\t%s parameter: '%s'\n", configs[pos], param); + + switch (pos) { + case 0: + if (*param == 'y' || *param == '1') + pmecc.use_pmecc = 1; + else + pmecc.use_pmecc = 0; + return EXIT_SUCCESS; + case 1: + pmecc.sector_per_page = strtol(param, NULL, 10); + return EXIT_SUCCESS; + case 2: + pmecc.spare_size = strtol(param, NULL, 10); + return EXIT_SUCCESS; + case 3: + pmecc.ecc_bits = strtol(param, NULL, 10); + return EXIT_SUCCESS; + case 4: + pmecc.sector_size = strtol(param, NULL, 10); + return EXIT_SUCCESS; + case 5: + pmecc.ecc_offset = strtol(param, NULL, 10); + return EXIT_SUCCESS; + } + } + } + +err: + pr_err("Could not find parameter in token '%s'\n", token); + return EXIT_FAILURE; +} + +static int atmel_parse_pmecc_params(char *txt) +{ + char *token; + + token = strtok(txt, ","); + while (token != NULL) { + if (atmel_find_pmecc_parameter_in_token(token)) + return EXIT_FAILURE; + + token = strtok(NULL, ","); + } + + return EXIT_SUCCESS; +} + +static int atmel_verify_header(unsigned char *ptr, int image_size, + struct image_tool_params *params) +{ + uint32_t *ints = (uint32_t *)ptr; + size_t pos; + size_t size = image_size; + + /* check if we have an PMECC header attached */ + for (pos = 0; pos < ARRAY_SIZE(nand_pmecc_header); pos++) + if (ints[pos] >> 28 != 0xC) + break; + + if (pos == ARRAY_SIZE(nand_pmecc_header)) { + ints += ARRAY_SIZE(nand_pmecc_header); + size -= sizeof(nand_pmecc_header); + } + + /* check the seven interrupt vectors of binary */ + for (pos = 0; pos < 7; pos++) { + debug("atmelimage: interrupt vector #%d is 0x%08X\n", pos+1, + ints[pos]); + /* + * all vectors except the 6'th one must contain valid + * LDR or B Opcode + */ + if (pos == 5) + /* 6'th vector has image size set, check later */ + continue; + if ((ints[pos] & 0xff000000) == 0xea000000) + /* valid B Opcode */ + continue; + if ((ints[pos] & 0xfffff000) == 0xe59ff000) + /* valid LDR (I=0, P=1, U=1, B=0, W=0, L=1) */ + continue; + /* ouch, one of the checks has missed ... */ + return 1; + } + + return ints[5] != cpu_to_le32(size); +} + +static void atmel_print_pmecc_header(const uint32_t word) +{ + int val; + + printf("\t\tPMECC header\n"); + + printf("\t\t====================\n"); + + val = (word >> 18) & 0x1ff; + printf("\t\teccOffset: %9i\n", val); + + val = (((word >> 16) & 0x3) == 0) ? 512 : 1024; + printf("\t\tsectorSize: %8i\n", val); + + if (((word >> 13) & 0x7) <= 2) + val = (2 << ((word >> 13) & 0x7)); + else + val = (12 << (((word >> 13) & 0x7) - 3)); + printf("\t\teccBitReq: %9i\n", val); + + val = (word >> 4) & 0x1ff; + printf("\t\tspareSize: %9i\n", val); + + val = (1 << ((word >> 1) & 0x3)); + printf("\t\tnbSectorPerPage: %3i\n", val); + + printf("\t\tusePmecc: %10i\n", word & 0x1); + printf("\t\t====================\n"); +} + +static void atmel_print_header(const void *ptr) +{ + uint32_t *ints = (uint32_t *)ptr; + size_t pos; + + /* check if we have an PMECC header attached */ + for (pos = 0; pos < ARRAY_SIZE(nand_pmecc_header); pos++) + if (ints[pos] >> 28 != 0xC) + break; + + if (pos == ARRAY_SIZE(nand_pmecc_header)) { + printf("Image Type:\tATMEL ROM-Boot Image with PMECC Header\n"); + atmel_print_pmecc_header(ints[0]); + pos += 5; + } else { + printf("Image Type:\tATMEL ROM-Boot Image without PMECC Header\n"); + pos = 5; + } + printf("\t\t6'th vector has %u set\n", le32_to_cpu(ints[pos])); +} + +static void atmel_set_header(void *ptr, struct stat *sbuf, int ifd, + struct image_tool_params *params) +{ + /* just save the image size into 6'th interrupt vector */ + uint32_t *ints = (uint32_t *)ptr; + size_t cnt; + size_t pos = 5; + size_t size = sbuf->st_size; + + for (cnt = 0; cnt < ARRAY_SIZE(nand_pmecc_header); cnt++) + if (ints[cnt] >> 28 != 0xC) + break; + + if (cnt == ARRAY_SIZE(nand_pmecc_header)) { + pos += ARRAY_SIZE(nand_pmecc_header); + size -= sizeof(nand_pmecc_header); + } + + ints[pos] = cpu_to_le32(size); +} + +static int atmel_check_params(struct image_tool_params *params) +{ + if (strlen(params->imagename) > 0) + if (atmel_parse_pmecc_params(params->imagename)) + return EXIT_FAILURE; + + return !(!params->eflag && + !params->fflag && + !params->xflag && + ((params->dflag && !params->lflag) || + (params->lflag && !params->dflag))); +} + +static int atmel_vrec_header(struct image_tool_params *params, + struct image_type_params *tparams) +{ + uint32_t tmp; + size_t pos; + + if (strlen(params->imagename) == 0) + return EXIT_SUCCESS; + + tmp = 0xC << 28; + + tmp |= (pmecc.ecc_offset & 0x1ff) << 18; + + switch (pmecc.sector_size) { + case 512: + tmp |= 0 << 16; + break; + case 1024: + tmp |= 1 << 16; + break; + + default: + pr_err("Wrong sectorSize (%i) for PMECC header\n", + pmecc.sector_size); + return EXIT_FAILURE; + } + + switch (pmecc.ecc_bits) { + case 2: + tmp |= 0 << 13; + break; + case 4: + tmp |= 1 << 13; + break; + case 8: + tmp |= 2 << 13; + break; + case 12: + tmp |= 3 << 13; + break; + case 24: + tmp |= 4 << 13; + break; + + default: + pr_err("Wrong eccBits (%i) for PMECC header\n", + pmecc.ecc_bits); + return EXIT_FAILURE; + } + + tmp |= (pmecc.spare_size & 0x1ff) << 4; + + switch (pmecc.sector_per_page) { + case 1: + tmp |= 0 << 1; + break; + case 2: + tmp |= 1 << 1; + break; + case 4: + tmp |= 2 << 1; + break; + case 8: + tmp |= 3 << 1; + break; + + default: + pr_err("Wrong sectorPerPage (%i) for PMECC header\n", + pmecc.sector_per_page); + return EXIT_FAILURE; + } + + if (pmecc.use_pmecc) + tmp |= 1; + + for (pos = 0; pos < ARRAY_SIZE(nand_pmecc_header); pos++) + nand_pmecc_header[pos] = tmp; + + debug("PMECC header filled 52 times with 0x%08X\n", tmp); + + tparams->header_size = sizeof(nand_pmecc_header); + tparams->hdr = nand_pmecc_header; + + return EXIT_SUCCESS; +} + +static struct image_type_params atmelimage_params = { + .name = "ATMEL ROM-Boot Image support", + .header_size = 0, + .hdr = NULL, + .check_image_type = atmel_check_image_type, + .verify_header = atmel_verify_header, + .print_header = atmel_print_header, + .set_header = atmel_set_header, + .check_params = atmel_check_params, + .vrec_header = atmel_vrec_header, +}; + +void init_atmel_image_type(void) +{ + register_image_type(&atmelimage_params); +} diff --git a/tools/imagetool.c b/tools/imagetool.c index da72115..32d6278 100644 --- a/tools/imagetool.c +++ b/tools/imagetool.c @@ -27,6 +27,8 @@ void register_image_tool(imagetool_register_t image_register) */ register_func = image_register;
+ /* Init ATMEL ROM Boot Image generation/list support */ + init_atmel_image_type(); /* Init Freescale PBL Boot image generation/list support */ init_pbl_image_type(); /* Init Kirkwood Boot image generation/list support */ diff --git a/tools/imagetool.h b/tools/imagetool.h index a3e9d30..c480687 100644 --- a/tools/imagetool.h +++ b/tools/imagetool.h @@ -159,6 +159,7 @@ void register_image_type(struct image_type_params *tparams); * Supported image types init functions */ void init_default_image_type(void); +void init_atmel_image_type(void); void init_pbl_image_type(void); void init_ais_image_type(void); void init_kwb_image_type(void);
For sama5d3xek we need to modify the SPL image for correct detection by ROM code.
Signed-off-by: Andreas Bießmann andreas.devel@googlemail.com ---
Changes in v2: * add -n switch to mkimage for PMECC type NAND and CONFIG_SYS_NANDFLASH
arch/arm/cpu/armv7/at91/config.mk | 10 ++++++++++ doc/README.atmel_pmecc | 30 ++++++++++++++++++++++++++++++ spl/Makefile | 18 ++++++++++++++++++ 3 files changed, 58 insertions(+) create mode 100644 arch/arm/cpu/armv7/at91/config.mk
diff --git a/arch/arm/cpu/armv7/at91/config.mk b/arch/arm/cpu/armv7/at91/config.mk new file mode 100644 index 0000000..09eab70 --- /dev/null +++ b/arch/arm/cpu/armv7/at91/config.mk @@ -0,0 +1,10 @@ +# +# Copyright (C) 2014, Andreas Bießmann andreas.devel@googlemail.com +# +# SPDX-License-Identifier: GPL-2.0+ +# +ifdef CONFIG_SPL_BUILD +ALL-y += boot.bin +else +ALL-y += u-boot.img +endif diff --git a/doc/README.atmel_pmecc b/doc/README.atmel_pmecc index cf8373b..5a93123 100644 --- a/doc/README.atmel_pmecc +++ b/doc/README.atmel_pmecc @@ -27,3 +27,33 @@ Take AT91SAM9X5EK as an example, the board definition file likes: #define CONFIG_ATMEL_NAND_HW_PMECC 1 #define CONFIG_PMECC_CAP 2 #define CONFIG_PMECC_SECTOR_SIZE 512 + +How to enable PMECC header for direct programmable boot.bin +----------------------------------------------------------- +2014-05-15 Andreas Bießmann andreas.devel@googlemail.com + +The usual way to program SPL into NAND flash is to use the SAM-BA Atmel tool. +This however is often not usable when doing field updates. To be able to +program a SPL binary into NAND flash we need to add the PMECC header to the +binary before. Chapter '12.4.4.1 NAND Flash Boot: NAND Flash Detection' in +sama5d3 SoC spec (as of 03. April 2014). We have a new image type added to +mkimage to generate this PMECC header and integrated into the build process of +SPL. +The required parameters in board configuration header are as follows: + +This example is working for sama5d3xek: + +#define CONFIG_SPL_AT91_HEADER_USE_PMECC 1 +#define CONFIG_SPL_AT91_HEADER_SECTOR_PER_PAGE 4 +#define CONFIG_SPL_AT91_HEADER_SECTOR_SIZE CONFIG_PMECC_SECTOR_SIZE +#define CONFIG_SPL_AT91_HEADER_SPARE_SIZE 64 +#define CONFIG_SPL_AT91_HEADER_ECC_BITS CONFIG_PMECC_CAP +#define CONFIG_SPL_AT91_HEADER_ECC_OFFSET 36 + +It enables the PMECC hardware and set the relevant parameters as known from +the SAM-BA tool. We are able to use other defined values here cause we check +these values in the buildsystem. Therefore the CONFIG_PMECC_SECTOR_SIZE is +expanded to the correct value set some lines above. + +The mkimage image type atmelimage also set the 6'th interrupt vector to the +correct value. This feature can also be used to setup a boot.bin for MMC boot. diff --git a/spl/Makefile b/spl/Makefile index 55500fd..8c6397e 100644 --- a/spl/Makefile +++ b/spl/Makefile @@ -183,6 +183,24 @@ MKIMAGEFLAGS_MLO.byteswap = -T omapimage -n byteswap -a $(CONFIG_SPL_TEXT_BASE) MLO MLO.byteswap: $(obj)/u-boot-spl.bin $(call if_changed,mkimage)
+ATMEL_NAND_HEADER = usePmecc=$(CONFIG_SPL_AT91_HEADER_USE_PMECC), \ + sectorPerPage=$(CONFIG_SPL_AT91_HEADER_SECTOR_PER_PAGE), \ + sectorSize=$(CONFIG_SPL_AT91_HEADER_SECTOR_SIZE), \ + spareSize=$(CONFIG_SPL_AT91_HEADER_SPARE_SIZE), \ + eccBits=$(CONFIG_SPL_AT91_HEADER_ECC_BITS), \ + eccOffset=$(CONFIG_SPL_AT91_HEADER_ECC_OFFSET) + +MKIMAGEFLAGS_boot.bin = -T atmelimage + +ifdef CONFIG_ATMEL_NAND_HW_PMECC +ifeq ($(CONFIG_SYS_USE_NANDFLASH),y) +MKIMAGEFLAGS_boot.bin += -n $(subst $(space),,$(ATMEL_NAND_HEADER)) +endif +endif + +boot.bin: $(obj)/u-boot-spl.bin + $(call if_changed,mkimage) + ALL-y += $(obj)/$(SPL_BIN).bin
ifdef CONFIG_SAMSUNG
Hi Andreas,
Changes in v2:
Just a nitpick here:
Can we take this parameter from the existing definition while not use new definition? Or else, if the header using different parameter with what u-boot nand driver use, then if flash through u-boot, it won't boot.
- sectorPerPage=$(CONFIG_SPL_AT91_HEADER_SECTOR_PER_PAGE), \
- sectorSize=$(CONFIG_SPL_AT91_HEADER_SECTOR_SIZE), \
- spareSize=$(CONFIG_SPL_AT91_HEADER_SPARE_SIZE), \
- eccBits=$(CONFIG_SPL_AT91_HEADER_ECC_BITS), \
- eccOffset=$(CONFIG_SPL_AT91_HEADER_ECC_OFFSET)
Best Regards, Bo Shen
Hi Bo,
Changes in v2:
I used the two parameters I found, sorry the rest isn't defiend anywhere (or I can't find). Can you give me pointers to the other parameters?
Best regards
Andreas Bießmann
Hi Andreas,
On 05/19/2014 03:48 PM, Andreas Bießmann wrote:
Hi Bo,
Changes in v2:
Can we use the following information?
CONFIG_SPL_AT91_HEADER_USE_PMECC: CONFIG_ATMEL_NAND_HW_PMECC
CONFIG_SPL_AT91_HEADER_SECTOR_PER_PAGE: CONFIG_SYS_NAND_PAGE_SIZE / CONFIG_PMECC_SECTOR_SIZE
CONFIG_SPL_AT91_HEADER_SPARE_SIZE: CONFIG_SYS_NAND_OOBSIZE
CONFIG_SPL_AT91_HEADER_ECC_OFFSET: this need a little bit more calculation. take 4 bits (caps = 4) as an example:
ecc_offset = oob_size - ((12 + sector_size / 512) * caps + 7) /8 = 64 - ((12 + 512 / 512) * 4 + 7) / 8 = 36. I am not sure this is worthwhile.
<snip>
Unfortunately we cant do calculations within the Makefile. These parameters will be given to command line and end up in '-n usePmecc=y,sectorPerPage="0x800/512",..' This will make the atmelimage cmdline parsing way more difficult.
Does anybody know some way to solve this in Makefile?
Best regards
Andreas Bießmann
Signed-off-by: Andreas Bießmann andreas.devel@googlemail.com Cc: Bo Shen voice.shen@atmel.com ---
Changes in v2: None
include/configs/sama5d3xek.h | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/include/configs/sama5d3xek.h b/include/configs/sama5d3xek.h index 516be85..bddd7e4 100644 --- a/include/configs/sama5d3xek.h +++ b/include/configs/sama5d3xek.h @@ -201,6 +201,12 @@ #define CONFIG_BOOTCOMMAND "nand read 0x21000000 0x180000 0x80000;" \ "nand read 0x22000000 0x200000 0x600000;" \ "bootm 0x22000000 - 0x21000000" +#define CONFIG_SPL_AT91_HEADER_USE_PMECC 1 +#define CONFIG_SPL_AT91_HEADER_SECTOR_PER_PAGE 4 +#define CONFIG_SPL_AT91_HEADER_SECTOR_SIZE CONFIG_PMECC_SECTOR_SIZE +#define CONFIG_SPL_AT91_HEADER_SPARE_SIZE 64 +#define CONFIG_SPL_AT91_HEADER_ECC_BITS CONFIG_PMECC_CAP +#define CONFIG_SPL_AT91_HEADER_ECC_OFFSET 36 #elif CONFIG_SYS_USE_MMC /* bootstrap + u-boot + env in sd card */ #define CONFIG_ENV_IS_IN_MMC
Andreas Bießmann
Bo Shen
