[U-Boot] [PATCH V2] dm: core: device: set pinctrl state for pinctrl device
We may have pinmux settings for pinctrl device, like the following example: " &iomuxc { pinctrl-names = "default"; pinctrl-0 = <&pinctrl_hog_1>; imx6ul-evk { pinctrl_hog_1: hoggrp-1 { fsl,pins = < MX6UL_PAD_UART1_RTS_B__GPIO1_IO19 0x17059 /* SD1 CD */ MX6UL_PAD_GPIO1_IO05__USDHC1_VSELECT 0x17059 /* SD1 VSELECT */ MX6UL_PAD_GPIO1_IO09__GPIO1_IO09 0x17059 /* SD1 RESET */ MX6UL_PAD_SNVS_TAMPER0__GPIO5_IO00 0x80000000 >; }; [......] }; "
We should not only select pinctrl state for non pinctrl devices, we need also to handle pin mux settings such as pinctrl_log for pinctrl devices.
So at the end of probing process of pinctrl device, select the default state of pinctrl device.
Signed-off-by: Peng Fan van.freenix@gmail.com Reviewed-by: Simon Glass sjg@chromium.org Reviewed-by: Masahiro Yamada yamada.masahiro@socionext.com ---
V2: To pinctrl node, it is not root node. No need to check dev->parent.
drivers/core/device.c | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/drivers/core/device.c b/drivers/core/device.c index cb24a61..636a895 100644 --- a/drivers/core/device.c +++ b/drivers/core/device.c @@ -332,6 +332,9 @@ int device_probe(struct udevice *dev) if (ret) goto fail_uclass;
+ if (device_get_uclass_id(dev) == UCLASS_PINCTRL) + pinctrl_select_state(dev, "default"); + return 0; fail_uclass: if (device_remove(dev)) {
Applied to u-boot-dm, thanks!
Peng Fan
