[U-Boot] [PATCH 1/2] MMC: add sdhci generic framework
Nowdays, there are plenty of mmc driver in uboot adopt the sd standard host design, aka as sdhci. It is better to centralize the common logic together to better maintenance.
Signed-off-by: Lei Wen leiwen@marvell.com --- drivers/mmc/Makefile | 1 + drivers/mmc/sdhci.c | 433 ++++++++++++++++++++++++++++++++++++++++++++++++++ include/sdhci.h | 325 +++++++++++++++++++++++++++++++++++++ 3 files changed, 759 insertions(+), 0 deletions(-) create mode 100644 drivers/mmc/sdhci.c create mode 100644 include/sdhci.h
diff --git a/drivers/mmc/Makefile b/drivers/mmc/Makefile index a8fe17a..50b5117 100644 --- a/drivers/mmc/Makefile +++ b/drivers/mmc/Makefile @@ -38,6 +38,7 @@ COBJS-$(CONFIG_OMAP3_MMC) += omap3_mmc.o COBJS-$(CONFIG_OMAP_HSMMC) += omap_hsmmc.o COBJS-$(CONFIG_PXA_MMC) += pxa_mmc.o COBJS-$(CONFIG_S5P_MMC) += s5p_mmc.o +COBJS-$(CONFIG_SDHCI) += sdhci.o
COBJS := $(COBJS-y) SRCS := $(COBJS:.o=.c) diff --git a/drivers/mmc/sdhci.c b/drivers/mmc/sdhci.c new file mode 100644 index 0000000..9ebd33d --- /dev/null +++ b/drivers/mmc/sdhci.c @@ -0,0 +1,433 @@ +/* + * Copyright 2011, Marvell Semiconductor Inc. + * Lei Wen leiwen@marvell.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + * + * Back ported to the 8xx platform (from the 8260 platform) by + * Murray.Jensen@cmst.csiro.au, 27-Jan-01. + */ + +#include <common.h> +#include <malloc.h> +#include <mmc.h> +#include <sdhci.h> + +void *aligned_buffer; + +static void sdhci_reset(struct sdhci_host *host, u8 mask) +{ + unsigned long timeout; + + /* Wait max 100 ms */ + timeout = 100; + sdhci_writeb(host, mask, SDHCI_SOFTWARE_RESET); + while (sdhci_readb(host, SDHCI_SOFTWARE_RESET) & mask) { + if (timeout == 0) { + printf("Reset 0x%x never completed.\n", (int)mask); + return; + } + timeout--; + udelay(1000); + } +} + +static void sdhci_cmd_done(struct sdhci_host *host, struct mmc_cmd *cmd) +{ + int i; + if (cmd->resp_type & MMC_RSP_136) { + /* CRC is stripped so we need to do some shifting. */ + for (i = 0; i < 4; i++) { + cmd->response[i] = sdhci_readl(host, + SDHCI_RESPONSE + (3-i)*4) << 8; + if (i != 3) + cmd->response[i] |= sdhci_readb(host, + SDHCI_RESPONSE + (3-i)*4-1); + } + } else { + cmd->response[0] = sdhci_readl(host, SDHCI_RESPONSE); + } +} + +static void sdhci_transfer_pio(struct sdhci_host *host, struct mmc_data *data) +{ + int i; + char *offs; + for (i = 0; i < data->blocksize; i += 4) { + offs = data->dest + i; + if (data->flags == MMC_DATA_READ) + *(u32 *)offs = sdhci_readl(host, SDHCI_BUFFER); + else + sdhci_writel(host, *(u32 *)offs, SDHCI_BUFFER); + } +} + +static int sdhci_transfer_data(struct sdhci_host *host, struct mmc_data *data, + unsigned int start_addr) +{ + unsigned int stat, rdy, mask, block = 0; + + rdy = SDHCI_INT_SPACE_AVAIL | SDHCI_INT_DATA_AVAIL; + mask = SDHCI_DATA_AVAILABLE | SDHCI_SPACE_AVAILABLE; + do { + stat = sdhci_readl(host, SDHCI_INT_STATUS); + if (stat & SDHCI_INT_ERROR) { + printf("Error detected in status(0x%X)!\n", stat); + return -1; + } + if (stat & rdy) { + if (!(sdhci_readl(host, SDHCI_PRESENT_STATE) & mask)) + continue; + sdhci_writel(host, rdy, SDHCI_INT_STATUS); + sdhci_transfer_pio(host, data); + data->dest += data->blocksize; + if (++block >= data->blocks) + break; + } +#ifdef CONFIG_MMC_SDMA + if (stat & SDHCI_INT_DMA_END) { + sdhci_writel(host, SDHCI_INT_DMA_END, SDHCI_INT_STATUS); + start_addr &= SDHCI_DEFAULT_BOUNDARY_SIZE - 1; + start_addr += SDHCI_DEFAULT_BOUNDARY_SIZE; + sdhci_writel(host, start_addr, SDHCI_DMA_ADDRESS); + } +#endif + } while (!(stat & SDHCI_INT_DATA_END)); + return 0; +} + +int sdhci_send_command(struct mmc *mmc, struct mmc_cmd *cmd, + struct mmc_data *data) +{ + struct sdhci_host *host = (struct sdhci_host *)mmc->priv; + unsigned int stat = 0; + int ret = 0; + int trans_bytes = 0, is_aligned = 1; + u32 mask, flags, mode; + unsigned int timeout, start_addr = 0; + + /* Wait max 10 ms */ + timeout = 10; + + sdhci_writel(host, SDHCI_INT_ALL_MASK, SDHCI_INT_STATUS); + mask = SDHCI_CMD_INHIBIT | SDHCI_DATA_INHIBIT; + + /* We shouldn't wait for data inihibit for stop commands, even + though they might use busy signaling */ + if (cmd->cmdidx == MMC_CMD_STOP_TRANSMISSION) + mask &= ~SDHCI_DATA_INHIBIT; + + while (sdhci_readl(host, SDHCI_PRESENT_STATE) & mask) { + if (timeout == 0) { + printf("Controller never released inhibit bit(s).\n"); + return COMM_ERR; + } + timeout--; + udelay(1000); + } + + mask = SDHCI_INT_RESPONSE; + if (!(cmd->resp_type & MMC_RSP_PRESENT)) + flags = SDHCI_CMD_RESP_NONE; + else if (cmd->resp_type & MMC_RSP_136) + flags = SDHCI_CMD_RESP_LONG; + else if (cmd->resp_type & MMC_RSP_BUSY) { + flags = SDHCI_CMD_RESP_SHORT_BUSY; + mask |= SDHCI_INT_DATA_END; + } else + flags = SDHCI_CMD_RESP_SHORT; + + if (cmd->resp_type & MMC_RSP_CRC) + flags |= SDHCI_CMD_CRC; + if (cmd->resp_type & MMC_RSP_OPCODE) + flags |= SDHCI_CMD_INDEX; + if (data) + flags |= SDHCI_CMD_DATA; + + /*Set Transfer mode regarding to data flag*/ + if (data != 0) { + sdhci_writeb(host, 0xe, SDHCI_TIMEOUT_CONTROL); + mode = SDHCI_TRNS_BLK_CNT_EN; + trans_bytes = data->blocks * data->blocksize; + if (data->blocks > 1) + mode |= SDHCI_TRNS_MULTI; + + if (data->flags == MMC_DATA_READ) + mode |= SDHCI_TRNS_READ; + +#ifdef CONFIG_MMC_SDMA + if (data->flags == MMC_DATA_READ) + start_addr = (unsigned int)data->dest; + else + start_addr = (unsigned int)data->src; + if ((host->quirks & SDHCI_QUIRK_32BIT_DMA_ADDR) && + (start_addr & 0x7) != 0x0) { + is_aligned = 0; + start_addr = (unsigned int)aligned_buffer; + if (data->flags != MMC_DATA_READ) + memcpy(aligned_buffer, data->src, trans_bytes); + } + + sdhci_writel(host, start_addr, SDHCI_DMA_ADDRESS); + mode |= SDHCI_TRNS_DMA; +#endif + sdhci_writew(host, SDHCI_MAKE_BLKSZ(SDHCI_DEFAULT_BOUNDARY_ARG, + data->blocksize), + SDHCI_BLOCK_SIZE); + sdhci_writew(host, data->blocks, SDHCI_BLOCK_COUNT); + sdhci_writew(host, mode, SDHCI_TRANSFER_MODE); + } + + sdhci_writel(host, cmd->cmdarg, SDHCI_ARGUMENT); +#ifdef CONFIG_MMC_SDMA + flush_cache(0, ~0); +#endif + sdhci_writew(host, SDHCI_MAKE_CMD(cmd->cmdidx, flags), SDHCI_COMMAND); + do { + stat = sdhci_readl(host, SDHCI_INT_STATUS); + if (stat & SDHCI_INT_ERROR) + break; + } while ((stat & mask) != mask); + + if ((stat & (SDHCI_INT_ERROR | mask)) == mask) { + sdhci_cmd_done(host, cmd); + sdhci_writel(host, mask, SDHCI_INT_STATUS); + } else + ret = -1; + + if (!ret && data) + ret = sdhci_transfer_data(host, data, start_addr); + + stat = sdhci_readl(host, SDHCI_INT_STATUS); + sdhci_writel(host, SDHCI_INT_ALL_MASK, SDHCI_INT_STATUS); + if (!ret) { + if ((host->quirks & SDHCI_QUIRK_32BIT_DMA_ADDR) && + !is_aligned && (data->flags == MMC_DATA_READ)) + memcpy(data->dest, aligned_buffer, trans_bytes); + return 0; + } + + sdhci_reset(host, SDHCI_RESET_CMD); + sdhci_reset(host, SDHCI_RESET_DATA); + if (stat & SDHCI_INT_TIMEOUT) + return TIMEOUT; + else + return COMM_ERR; +} + +static int sdhci_set_clock(struct mmc *mmc, unsigned int clock) +{ + struct sdhci_host *host = (struct sdhci_host *)mmc->priv; + unsigned int div, clk, timeout; + + sdhci_writew(host, 0, SDHCI_CLOCK_CONTROL); + + if (clock == 0) + return 0; + + if (host->version >= SDHCI_SPEC_300) { + /* Version 3.00 divisors must be a multiple of 2. */ + if (mmc->f_max <= clock) + div = 1; + else { + for (div = 2; div < SDHCI_MAX_DIV_SPEC_300; div += 2) { + if ((mmc->f_max / div) <= clock) + break; + } + } + } else { + /* Version 2.00 divisors must be a power of 2. */ + for (div = 1; div < SDHCI_MAX_DIV_SPEC_200; div *= 2) { + if ((mmc->f_max / div) <= clock) + break; + } + } + div >>= 1; + + clk = (div & SDHCI_DIV_MASK) << SDHCI_DIVIDER_SHIFT; + clk |= ((div & SDHCI_DIV_HI_MASK) >> SDHCI_DIV_MASK_LEN) + << SDHCI_DIVIDER_HI_SHIFT; + clk |= SDHCI_CLOCK_INT_EN; + sdhci_writew(host, clk, SDHCI_CLOCK_CONTROL); + + /* Wait max 20 ms */ + timeout = 20; + while (!((clk = sdhci_readw(host, SDHCI_CLOCK_CONTROL)) + & SDHCI_CLOCK_INT_STABLE)) { + if (timeout == 0) { + printf("Internal clock never stabilised.\n"); + return -1; + } + timeout--; + udelay(1000); + } + + clk |= SDHCI_CLOCK_CARD_EN; + sdhci_writew(host, clk, SDHCI_CLOCK_CONTROL); + return 0; +} + +static void sdhci_set_power(struct sdhci_host *host, unsigned short power) +{ + u8 pwr = 0; + + if (power != (unsigned short)-1) { + switch (1 << power) { + case MMC_VDD_165_195: + pwr = SDHCI_POWER_180; + break; + case MMC_VDD_29_30: + case MMC_VDD_30_31: + pwr = SDHCI_POWER_300; + break; + case MMC_VDD_32_33: + case MMC_VDD_33_34: + pwr = SDHCI_POWER_330; + break; + } + } + + if (pwr == 0) { + sdhci_writeb(host, 0, SDHCI_POWER_CONTROL); + return; + } + + pwr |= SDHCI_POWER_ON; + + sdhci_writeb(host, pwr, SDHCI_POWER_CONTROL); +} + +void sdhci_set_ios(struct mmc *mmc) +{ + u32 ctrl; + struct sdhci_host *host = (struct sdhci_host *)mmc->priv; + + if (mmc->clock != host->clock) + sdhci_set_clock(mmc, mmc->clock); + + /* Set bus width */ + ctrl = sdhci_readb(host, SDHCI_HOST_CONTROL); + if (mmc->bus_width == 8) { + ctrl &= ~SDHCI_CTRL_4BITBUS; + if (host->version >= SDHCI_SPEC_300) + ctrl |= SDHCI_CTRL_8BITBUS; + } else { + if (host->version >= SDHCI_SPEC_300) + ctrl &= ~SDHCI_CTRL_8BITBUS; + if (mmc->bus_width == 4) + ctrl |= SDHCI_CTRL_4BITBUS; + else + ctrl &= ~SDHCI_CTRL_4BITBUS; + } + + if (mmc->clock > 26000000) + ctrl |= SDHCI_CTRL_HISPD; + else + ctrl &= ~SDHCI_CTRL_HISPD; + + sdhci_writeb(host, ctrl, SDHCI_HOST_CONTROL); +} + +int sdhci_init(struct mmc *mmc) +{ + struct sdhci_host *host = (struct sdhci_host *)mmc->priv; + + if ((host->quirks & SDHCI_QUIRK_32BIT_DMA_ADDR) && !aligned_buffer) { + aligned_buffer = memalign(8, 512*1024); + if (!aligned_buffer) { + printf("Aligned buffer alloc failed!!!"); + return -1; + } + } + + /* Eable all state */ + sdhci_writel(host, SDHCI_INT_ALL_MASK, SDHCI_INT_ENABLE); + sdhci_writel(host, SDHCI_INT_ALL_MASK, SDHCI_SIGNAL_ENABLE); + + sdhci_set_power(host, fls(mmc->voltages) - 1); + + return 0; +} + +int add_sdhci(struct sdhci_host *host, u32 max_clk, u32 min_clk) +{ + struct mmc *mmc; + unsigned int caps; + + mmc = malloc(sizeof(struct mmc)); + if (!mmc) { + printf("mmc malloc fail!\n"); + return -1; + } + + mmc->priv = host; + + sprintf(mmc->name, "%s", host->name); + mmc->send_cmd = sdhci_send_command; + mmc->set_ios = sdhci_set_ios; + mmc->init = sdhci_init; + + caps = sdhci_readl(host, SDHCI_CAPABILITIES); +#ifdef CONFIG_MMC_SDMA + if (!(caps & SDHCI_CAN_DO_SDMA)) { + printf("Your controller don't support sdma!!\n"); + return -1; + } +#endif + + if (max_clk) + mmc->f_max = max_clk; + else { + if (host->version >= SDHCI_SPEC_300) + mmc->f_max = (caps & SDHCI_CLOCK_V3_BASE_MASK) + >> SDHCI_CLOCK_BASE_SHIFT; + else + mmc->f_max = (caps & SDHCI_CLOCK_BASE_MASK) + >> SDHCI_CLOCK_BASE_SHIFT; + mmc->f_max *= 1000000; + } + if (mmc->f_max == 0) { + printf("Hardware doesn't specify base clock frequency\n"); + return -1; + } + if (min_clk) + mmc->f_min = min_clk; + else { + if (host->version >= SDHCI_SPEC_300) + mmc->f_min = mmc->f_max / SDHCI_MAX_DIV_SPEC_300; + else + mmc->f_min = mmc->f_max / SDHCI_MAX_DIV_SPEC_200; + } + + mmc->voltages = 0; + if (caps & SDHCI_CAN_VDD_330) + mmc->voltages |= MMC_VDD_32_33 | MMC_VDD_33_34; + if (caps & SDHCI_CAN_VDD_300) + mmc->voltages |= MMC_VDD_29_30 | MMC_VDD_30_31; + if (caps & SDHCI_CAN_VDD_180) + mmc->voltages |= MMC_VDD_165_195; + mmc->host_caps = MMC_MODE_HS | MMC_MODE_HS_52MHz | MMC_MODE_4BIT; + if (caps & SDHCI_CAN_DO_8BIT) + mmc->host_caps |= MMC_MODE_8BIT; + + sdhci_reset(host, SDHCI_RESET_ALL); + mmc_register(mmc); + + return 0; +} diff --git a/include/sdhci.h b/include/sdhci.h new file mode 100644 index 0000000..6d52ce9 --- /dev/null +++ b/include/sdhci.h @@ -0,0 +1,325 @@ +/* + * Copyright 2011, Marvell Semiconductor Inc. + * Lei Wen leiwen@marvell.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + * + * Back ported to the 8xx platform (from the 8260 platform) by + * Murray.Jensen@cmst.csiro.au, 27-Jan-01. + */ +#ifndef __SDHCI_HW_H +#define __SDHCI_HW_H + +#include <asm/io.h> +/* + * Controller registers + */ + +#define SDHCI_DMA_ADDRESS 0x00 + +#define SDHCI_BLOCK_SIZE 0x04 +#define SDHCI_MAKE_BLKSZ(dma, blksz) (((dma & 0x7) << 12) | (blksz & 0xFFF)) + +#define SDHCI_BLOCK_COUNT 0x06 + +#define SDHCI_ARGUMENT 0x08 + +#define SDHCI_TRANSFER_MODE 0x0C +#define SDHCI_TRNS_DMA 0x01 +#define SDHCI_TRNS_BLK_CNT_EN 0x02 +#define SDHCI_TRNS_ACMD12 0x04 +#define SDHCI_TRNS_READ 0x10 +#define SDHCI_TRNS_MULTI 0x20 + +#define SDHCI_COMMAND 0x0E +#define SDHCI_CMD_RESP_MASK 0x03 +#define SDHCI_CMD_CRC 0x08 +#define SDHCI_CMD_INDEX 0x10 +#define SDHCI_CMD_DATA 0x20 +#define SDHCI_CMD_ABORTCMD 0xC0 + +#define SDHCI_CMD_RESP_NONE 0x00 +#define SDHCI_CMD_RESP_LONG 0x01 +#define SDHCI_CMD_RESP_SHORT 0x02 +#define SDHCI_CMD_RESP_SHORT_BUSY 0x03 + +#define SDHCI_MAKE_CMD(c, f) (((c & 0xff) << 8) | (f & 0xff)) +#define SDHCI_GET_CMD(c) ((c>>8) & 0x3f) + +#define SDHCI_RESPONSE 0x10 + +#define SDHCI_BUFFER 0x20 + +#define SDHCI_PRESENT_STATE 0x24 +#define SDHCI_CMD_INHIBIT 0x00000001 +#define SDHCI_DATA_INHIBIT 0x00000002 +#define SDHCI_DOING_WRITE 0x00000100 +#define SDHCI_DOING_READ 0x00000200 +#define SDHCI_SPACE_AVAILABLE 0x00000400 +#define SDHCI_DATA_AVAILABLE 0x00000800 +#define SDHCI_CARD_PRESENT 0x00010000 +#define SDHCI_WRITE_PROTECT 0x00080000 + +#define SDHCI_HOST_CONTROL 0x28 +#define SDHCI_CTRL_LED 0x01 +#define SDHCI_CTRL_4BITBUS 0x02 +#define SDHCI_CTRL_HISPD 0x04 +#define SDHCI_CTRL_DMA_MASK 0x18 +#define SDHCI_CTRL_SDMA 0x00 +#define SDHCI_CTRL_ADMA1 0x08 +#define SDHCI_CTRL_ADMA32 0x10 +#define SDHCI_CTRL_ADMA64 0x18 +#define SDHCI_CTRL_8BITBUS 0x20 + +#define SDHCI_POWER_CONTROL 0x29 +#define SDHCI_POWER_ON 0x01 +#define SDHCI_POWER_180 0x0A +#define SDHCI_POWER_300 0x0C +#define SDHCI_POWER_330 0x0E + +#define SDHCI_BLOCK_GAP_CONTROL 0x2A + +#define SDHCI_WAKE_UP_CONTROL 0x2B +#define SDHCI_WAKE_ON_INT 0x01 +#define SDHCI_WAKE_ON_INSERT 0x02 +#define SDHCI_WAKE_ON_REMOVE 0x04 + +#define SDHCI_CLOCK_CONTROL 0x2C +#define SDHCI_DIVIDER_SHIFT 8 +#define SDHCI_DIVIDER_HI_SHIFT 6 +#define SDHCI_DIV_MASK 0xFF +#define SDHCI_DIV_MASK_LEN 8 +#define SDHCI_DIV_HI_MASK 0x300 +#define SDHCI_CLOCK_CARD_EN 0x0004 +#define SDHCI_CLOCK_INT_STABLE 0x0002 +#define SDHCI_CLOCK_INT_EN 0x0001 + +#define SDHCI_TIMEOUT_CONTROL 0x2E + +#define SDHCI_SOFTWARE_RESET 0x2F +#define SDHCI_RESET_ALL 0x01 +#define SDHCI_RESET_CMD 0x02 +#define SDHCI_RESET_DATA 0x04 + +#define SDHCI_INT_STATUS 0x30 +#define SDHCI_INT_ENABLE 0x34 +#define SDHCI_SIGNAL_ENABLE 0x38 +#define SDHCI_INT_RESPONSE 0x00000001 +#define SDHCI_INT_DATA_END 0x00000002 +#define SDHCI_INT_DMA_END 0x00000008 +#define SDHCI_INT_SPACE_AVAIL 0x00000010 +#define SDHCI_INT_DATA_AVAIL 0x00000020 +#define SDHCI_INT_CARD_INSERT 0x00000040 +#define SDHCI_INT_CARD_REMOVE 0x00000080 +#define SDHCI_INT_CARD_INT 0x00000100 +#define SDHCI_INT_ERROR 0x00008000 +#define SDHCI_INT_TIMEOUT 0x00010000 +#define SDHCI_INT_CRC 0x00020000 +#define SDHCI_INT_END_BIT 0x00040000 +#define SDHCI_INT_INDEX 0x00080000 +#define SDHCI_INT_DATA_TIMEOUT 0x00100000 +#define SDHCI_INT_DATA_CRC 0x00200000 +#define SDHCI_INT_DATA_END_BIT 0x00400000 +#define SDHCI_INT_BUS_POWER 0x00800000 +#define SDHCI_INT_ACMD12ERR 0x01000000 +#define SDHCI_INT_ADMA_ERROR 0x02000000 + +#define SDHCI_INT_NORMAL_MASK 0x00007FFF +#define SDHCI_INT_ERROR_MASK 0xFFFF8000 + +#define SDHCI_INT_CMD_MASK (SDHCI_INT_RESPONSE | SDHCI_INT_TIMEOUT | \ + SDHCI_INT_CRC | SDHCI_INT_END_BIT | SDHCI_INT_INDEX) +#define SDHCI_INT_DATA_MASK (SDHCI_INT_DATA_END | SDHCI_INT_DMA_END | \ + SDHCI_INT_DATA_AVAIL | SDHCI_INT_SPACE_AVAIL | \ + SDHCI_INT_DATA_TIMEOUT | SDHCI_INT_DATA_CRC | \ + SDHCI_INT_DATA_END_BIT | SDHCI_INT_ADMA_ERROR) +#define SDHCI_INT_ALL_MASK ((unsigned int)-1) + +#define SDHCI_ACMD12_ERR 0x3C + +/* 3E-3F reserved */ + +#define SDHCI_CAPABILITIES 0x40 +#define SDHCI_TIMEOUT_CLK_MASK 0x0000003F +#define SDHCI_TIMEOUT_CLK_SHIFT 0 +#define SDHCI_TIMEOUT_CLK_UNIT 0x00000080 +#define SDHCI_CLOCK_BASE_MASK 0x00003F00 +#define SDHCI_CLOCK_V3_BASE_MASK 0x0000FF00 +#define SDHCI_CLOCK_BASE_SHIFT 8 +#define SDHCI_MAX_BLOCK_MASK 0x00030000 +#define SDHCI_MAX_BLOCK_SHIFT 16 +#define SDHCI_CAN_DO_8BIT 0x00040000 +#define SDHCI_CAN_DO_ADMA2 0x00080000 +#define SDHCI_CAN_DO_ADMA1 0x00100000 +#define SDHCI_CAN_DO_HISPD 0x00200000 +#define SDHCI_CAN_DO_SDMA 0x00400000 +#define SDHCI_CAN_VDD_330 0x01000000 +#define SDHCI_CAN_VDD_300 0x02000000 +#define SDHCI_CAN_VDD_180 0x04000000 +#define SDHCI_CAN_64BIT 0x10000000 + +#define SDHCI_CAPABILITIES_1 0x44 + +#define SDHCI_MAX_CURRENT 0x48 + +/* 4C-4F reserved for more max current */ + +#define SDHCI_SET_ACMD12_ERROR 0x50 +#define SDHCI_SET_INT_ERROR 0x52 + +#define SDHCI_ADMA_ERROR 0x54 + +/* 55-57 reserved */ + +#define SDHCI_ADMA_ADDRESS 0x58 + +/* 60-FB reserved */ + +#define SDHCI_SLOT_INT_STATUS 0xFC + +#define SDHCI_HOST_VERSION 0xFE +#define SDHCI_VENDOR_VER_MASK 0xFF00 +#define SDHCI_VENDOR_VER_SHIFT 8 +#define SDHCI_SPEC_VER_MASK 0x00FF +#define SDHCI_SPEC_VER_SHIFT 0 +#define SDHCI_SPEC_100 0 +#define SDHCI_SPEC_200 1 +#define SDHCI_SPEC_300 2 + +/* + * End of controller registers. + */ + +#define SDHCI_MAX_DIV_SPEC_200 256 +#define SDHCI_MAX_DIV_SPEC_300 2046 + +/* + * quirks + */ +#define SDHCI_QUIRK_32BIT_DMA_ADDR (1 << 0) + +/* + * Host SDMA buffer boundary. Valid values from 4K to 512K in powers of 2. + */ +#define SDHCI_DEFAULT_BOUNDARY_SIZE (512 * 1024) +#define SDHCI_DEFAULT_BOUNDARY_ARG (7) +struct sdhci_ops { +#ifdef CONFIG_MMC_SDHCI_IO_ACCESSORS + u32 (*read_l)(struct sdhci_host *host, int reg); + u16 (*read_w)(struct sdhci_host *host, int reg); + u8 (*read_b)(struct sdhci_host *host, int reg); + void (*write_l)(struct sdhci_host *host, u32 val, int reg); + void (*write_w)(struct sdhci_host *host, u16 val, int reg); + void (*write_b)(struct sdhci_host *host, u8 val, int reg); +#endif +}; + +struct sdhci_host { + char *name; + void *ioaddr; + unsigned int quirks; + unsigned int version; + unsigned int clock; + const struct sdhci_ops *ops; +}; + +#ifdef CONFIG_MMC_SDHCI_IO_ACCESSORS + +static inline void sdhci_writel(struct sdhci_host *host, u32 val, int reg) +{ + if (unlikely(host->ops->write_l)) + host->ops->write_l(host, val, reg); + else + writel(val, host->ioaddr + reg); +} + +static inline void sdhci_writew(struct sdhci_host *host, u16 val, int reg) +{ + if (unlikely(host->ops->write_w)) + host->ops->write_w(host, val, reg); + else + writew(val, host->ioaddr + reg); +} + +static inline void sdhci_writeb(struct sdhci_host *host, u8 val, int reg) +{ + if (unlikely(host->ops->write_b)) + host->ops->write_b(host, val, reg); + else + writeb(val, host->ioaddr + reg); +} + +static inline u32 sdhci_readl(struct sdhci_host *host, int reg) +{ + if (unlikely(host->ops->read_l)) + return host->ops->read_l(host, reg); + else + return readl(host->ioaddr + reg); +} + +static inline u16 sdhci_readw(struct sdhci_host *host, int reg) +{ + if (unlikely(host->ops->read_w)) + return host->ops->read_w(host, reg); + else + return readw(host->ioaddr + reg); +} + +static inline u8 sdhci_readb(struct sdhci_host *host, int reg) +{ + if (unlikely(host->ops->read_b)) + return host->ops->read_b(host, reg); + else + return readb(host->ioaddr + reg); +} + +#else + +static inline void sdhci_writel(struct sdhci_host *host, u32 val, int reg) +{ + writel(val, host->ioaddr + reg); +} + +static inline void sdhci_writew(struct sdhci_host *host, u16 val, int reg) +{ + writew(val, host->ioaddr + reg); +} + +static inline void sdhci_writeb(struct sdhci_host *host, u8 val, int reg) +{ + writeb(val, host->ioaddr + reg); +} +static inline u32 sdhci_readl(struct sdhci_host *host, int reg) +{ + return readl(host->ioaddr + reg); +} + +static inline u16 sdhci_readw(struct sdhci_host *host, int reg) +{ + return readw(host->ioaddr + reg); +} + +static inline u8 sdhci_readb(struct sdhci_host *host, int reg) +{ + return readb(host->ioaddr + reg); +} +#endif + +int add_sdhci(struct sdhci_host *host, u32 max_clk, u32 min_clk); +#endif /* __SDHCI_HW_H */
This could support both armada100 and pantheon serial in the mainline, while this driver also be tested to support upcoming mg, mmp2 and mmp3 hardware.
Signed-off-by: Lei Wen leiwen@marvell.com --- drivers/mmc/Makefile | 1 + drivers/mmc/sdhci-mv.c | 21 +++++++++++++++++++++ 2 files changed, 22 insertions(+), 0 deletions(-) create mode 100644 drivers/mmc/sdhci-mv.c
diff --git a/drivers/mmc/Makefile b/drivers/mmc/Makefile index 50b5117..fd84389 100644 --- a/drivers/mmc/Makefile +++ b/drivers/mmc/Makefile @@ -39,6 +39,7 @@ COBJS-$(CONFIG_OMAP_HSMMC) += omap_hsmmc.o COBJS-$(CONFIG_PXA_MMC) += pxa_mmc.o COBJS-$(CONFIG_S5P_MMC) += s5p_mmc.o COBJS-$(CONFIG_SDHCI) += sdhci.o +COBJS-$(CONFIG_SDHCI_MV) += sdhci-mv.o
COBJS := $(COBJS-y) SRCS := $(COBJS:.o=.c) diff --git a/drivers/mmc/sdhci-mv.c b/drivers/mmc/sdhci-mv.c new file mode 100644 index 0000000..97d79ee --- /dev/null +++ b/drivers/mmc/sdhci-mv.c @@ -0,0 +1,21 @@ +#include <common.h> +#include <malloc.h> +#include <sdhci.h> + +static char *MVSDH_NAME = "sdh-mv"; +int mv_sdh_init(u32 regbase, u32 max_clk, u32 min_clk, u32 quirks) +{ + struct sdhci_host *host = NULL; + host = (struct sdhci_host *)malloc(sizeof(struct sdhci_host)); + if (!host) { + printf("sdh_host malloc fail!\n"); + return 1; + } + + host->name = MVSDH_NAME; + host->ioaddr = (void *)regbase; + host->quirks = quirks; + host->version = sdhci_readw(host, SDHCI_HOST_VERSION); + add_sdhci(host, max_clk, min_clk); + return 0; +}
-----Original Message----- From: Lei Wen [mailto:leiwen@marvell.com] Sent: Thursday, June 16, 2011 8:48 PM To: Andy Fleming; Rob Herring; u-boot@lists.denx.de; Prafulla Wadaskar; Yu Tang; Prabhanjan Sarnaik; Ashish Karkare Subject: [PATCH 2/2] MMC: add marvell sdhci driver
The file name should be mv_sdhci.c
Same here CONFIG_MV_SDHCI
"mv_sdhci" sounds better.
Regards.. Prafulla . .
- struct sdhci_host *host = NULL;
- host = (struct sdhci_host *)malloc(sizeof(struct sdhci_host));
- if (!host) {
return 1;
- host->name = MVSDH_NAME;
- host->ioaddr = (void *)regbase;
- host->quirks = quirks;
- host->version = sdhci_readw(host, SDHCI_HOST_VERSION);
- add_sdhci(host, max_clk, min_clk);
1.7.0.4
Hi Prafulla,
On Fri, Jun 17, 2011 at 3:33 PM, Prafulla Wadaskar prafulla@marvell.com wrote:
I have no concern with the name change, this would be included in next patch set.
Best regards, Lei
Hi All,
Any comment to this patch set, could it be merged in this open window?
Thanks, Lei
- Copyright 2011, Marvell Semiconductor Inc.
- Lei Wen leiwen@marvell.com
- project.
- MA 02111-1307 USA
- Back ported to the 8xx platform (from the 8260 platform) by
- Murray.Jensen@cmst.csiro.au, 27-Jan-01.
- unsigned long timeout;
- /* Wait max 100 ms */
- timeout = 100;
- sdhci_writeb(host, mask, SDHCI_SOFTWARE_RESET);
- while (sdhci_readb(host, SDHCI_SOFTWARE_RESET) & mask) {
- if (timeout == 0) {
- printf("Reset 0x%x never completed.\n", (int)mask);
- return;
- timeout--;
- udelay(1000);
- int i;
- if (cmd->resp_type & MMC_RSP_136) {
- /* CRC is stripped so we need to do some shifting. */
- for (i = 0; i < 4; i++) {
- cmd->response[i] = sdhci_readl(host,
- SDHCI_RESPONSE + (3-i)*4) << 8;
- if (i != 3)
- cmd->response[i] |= sdhci_readb(host,
- SDHCI_RESPONSE + (3-i)*4-1);
- } else {
- cmd->response[0] = sdhci_readl(host, SDHCI_RESPONSE);
- int i;
- char *offs;
- for (i = 0; i < data->blocksize; i += 4) {
- offs = data->dest + i;
- if (data->flags == MMC_DATA_READ)
- *(u32 *)offs = sdhci_readl(host, SDHCI_BUFFER);
- else
- sdhci_writel(host, *(u32 *)offs, SDHCI_BUFFER);
- unsigned int start_addr)
- unsigned int stat, rdy, mask, block = 0;
- rdy = SDHCI_INT_SPACE_AVAIL | SDHCI_INT_DATA_AVAIL;
- mask = SDHCI_DATA_AVAILABLE | SDHCI_SPACE_AVAILABLE;
- do {
- stat = sdhci_readl(host, SDHCI_INT_STATUS);
- if (stat & SDHCI_INT_ERROR) {
- printf("Error detected in status(0x%X)!\n", stat);
- return -1;
- if (stat & rdy) {
- if (!(sdhci_readl(host, SDHCI_PRESENT_STATE) & mask))
- continue;
- sdhci_writel(host, rdy, SDHCI_INT_STATUS);
- sdhci_transfer_pio(host, data);
- data->dest += data->blocksize;
- if (++block >= data->blocks)
- break;
- if (stat & SDHCI_INT_DMA_END) {
- sdhci_writel(host, SDHCI_INT_DMA_END, SDHCI_INT_STATUS);
- start_addr &= SDHCI_DEFAULT_BOUNDARY_SIZE - 1;
- start_addr += SDHCI_DEFAULT_BOUNDARY_SIZE;
- sdhci_writel(host, start_addr, SDHCI_DMA_ADDRESS);
- } while (!(stat & SDHCI_INT_DATA_END));
- struct mmc_data *data)
- struct sdhci_host *host = (struct sdhci_host *)mmc->priv;
- unsigned int stat = 0;
- int ret = 0;
- int trans_bytes = 0, is_aligned = 1;
- u32 mask, flags, mode;
- unsigned int timeout, start_addr = 0;
- /* Wait max 10 ms */
- timeout = 10;
- sdhci_writel(host, SDHCI_INT_ALL_MASK, SDHCI_INT_STATUS);
- mask = SDHCI_CMD_INHIBIT | SDHCI_DATA_INHIBIT;
- /* We shouldn't wait for data inihibit for stop commands, even
- though they might use busy signaling */
- if (cmd->cmdidx == MMC_CMD_STOP_TRANSMISSION)
- mask &= ~SDHCI_DATA_INHIBIT;
- while (sdhci_readl(host, SDHCI_PRESENT_STATE) & mask) {
- printf("Controller never released inhibit bit(s).\n");
- return COMM_ERR;
- timeout--;
- udelay(1000);
- mask = SDHCI_INT_RESPONSE;
- if (!(cmd->resp_type & MMC_RSP_PRESENT))
- flags = SDHCI_CMD_RESP_NONE;
- else if (cmd->resp_type & MMC_RSP_136)
- flags = SDHCI_CMD_RESP_LONG;
- else if (cmd->resp_type & MMC_RSP_BUSY) {
- flags = SDHCI_CMD_RESP_SHORT_BUSY;
- mask |= SDHCI_INT_DATA_END;
- } else
- flags = SDHCI_CMD_RESP_SHORT;
- if (cmd->resp_type & MMC_RSP_CRC)
- flags |= SDHCI_CMD_CRC;
- if (cmd->resp_type & MMC_RSP_OPCODE)
- flags |= SDHCI_CMD_INDEX;
- if (data)
- flags |= SDHCI_CMD_DATA;
- /*Set Transfer mode regarding to data flag*/
- if (data != 0) {
- sdhci_writeb(host, 0xe, SDHCI_TIMEOUT_CONTROL);
- mode = SDHCI_TRNS_BLK_CNT_EN;
- trans_bytes = data->blocks * data->blocksize;
- if (data->blocks > 1)
- mode |= SDHCI_TRNS_MULTI;
- mode |= SDHCI_TRNS_READ;
- start_addr = (unsigned int)data->dest;
- else
- start_addr = (unsigned int)data->src;
- if ((host->quirks & SDHCI_QUIRK_32BIT_DMA_ADDR) &&
- (start_addr & 0x7) != 0x0) {
- is_aligned = 0;
- start_addr = (unsigned int)aligned_buffer;
- if (data->flags != MMC_DATA_READ)
- memcpy(aligned_buffer, data->src, trans_bytes);
- mode |= SDHCI_TRNS_DMA;
- sdhci_writew(host, SDHCI_MAKE_BLKSZ(SDHCI_DEFAULT_BOUNDARY_ARG,
- data->blocksize),
- SDHCI_BLOCK_SIZE);
- sdhci_writew(host, data->blocks, SDHCI_BLOCK_COUNT);
- sdhci_writew(host, mode, SDHCI_TRANSFER_MODE);
- sdhci_writel(host, cmd->cmdarg, SDHCI_ARGUMENT);
- flush_cache(0, ~0);
- sdhci_writew(host, SDHCI_MAKE_CMD(cmd->cmdidx, flags), SDHCI_COMMAND);
- do {
- break;
- } while ((stat & mask) != mask);
- if ((stat & (SDHCI_INT_ERROR | mask)) == mask) {
- sdhci_cmd_done(host, cmd);
- sdhci_writel(host, mask, SDHCI_INT_STATUS);
- } else
- ret = -1;
- if (!ret && data)
- ret = sdhci_transfer_data(host, data, start_addr);
- if (!ret) {
- !is_aligned && (data->flags == MMC_DATA_READ))
- memcpy(data->dest, aligned_buffer, trans_bytes);
- sdhci_reset(host, SDHCI_RESET_CMD);
- sdhci_reset(host, SDHCI_RESET_DATA);
- if (stat & SDHCI_INT_TIMEOUT)
- return TIMEOUT;
- else
- return COMM_ERR;
- unsigned int div, clk, timeout;
- sdhci_writew(host, 0, SDHCI_CLOCK_CONTROL);
- if (clock == 0)
- if (host->version >= SDHCI_SPEC_300) {
- /* Version 3.00 divisors must be a multiple of 2. */
- if (mmc->f_max <= clock)
- div = 1;
- else {
- for (div = 2; div < SDHCI_MAX_DIV_SPEC_300; div += 2) {
- if ((mmc->f_max / div) <= clock)
- break;
- } else {
- /* Version 2.00 divisors must be a power of 2. */
- for (div = 1; div < SDHCI_MAX_DIV_SPEC_200; div *= 2) {
- break;
- div >>= 1;
- clk = (div & SDHCI_DIV_MASK) << SDHCI_DIVIDER_SHIFT;
- clk |= ((div & SDHCI_DIV_HI_MASK) >> SDHCI_DIV_MASK_LEN)
- << SDHCI_DIVIDER_HI_SHIFT;
- clk |= SDHCI_CLOCK_INT_EN;
- sdhci_writew(host, clk, SDHCI_CLOCK_CONTROL);
- /* Wait max 20 ms */
- timeout = 20;
- while (!((clk = sdhci_readw(host, SDHCI_CLOCK_CONTROL))
- & SDHCI_CLOCK_INT_STABLE)) {
- printf("Internal clock never stabilised.\n");
- return -1;
- timeout--;
- udelay(1000);
- clk |= SDHCI_CLOCK_CARD_EN;
- u8 pwr = 0;
- if (power != (unsigned short)-1) {
- switch (1 << power) {
- case MMC_VDD_165_195:
- pwr = SDHCI_POWER_180;
- break;
- case MMC_VDD_29_30:
- case MMC_VDD_30_31:
- pwr = SDHCI_POWER_300;
- break;
- case MMC_VDD_32_33:
- case MMC_VDD_33_34:
- pwr = SDHCI_POWER_330;
- break;
- if (pwr == 0) {
- sdhci_writeb(host, 0, SDHCI_POWER_CONTROL);
- return;
- pwr |= SDHCI_POWER_ON;
- sdhci_writeb(host, pwr, SDHCI_POWER_CONTROL);
- u32 ctrl;
- if (mmc->clock != host->clock)
- sdhci_set_clock(mmc, mmc->clock);
- /* Set bus width */
- ctrl = sdhci_readb(host, SDHCI_HOST_CONTROL);
- if (mmc->bus_width == 8) {
- ctrl &= ~SDHCI_CTRL_4BITBUS;
- ctrl |= SDHCI_CTRL_8BITBUS;
- } else {
- ctrl &= ~SDHCI_CTRL_8BITBUS;
- if (mmc->bus_width == 4)
- ctrl |= SDHCI_CTRL_4BITBUS;
- else
- if (mmc->clock > 26000000)
- ctrl |= SDHCI_CTRL_HISPD;
- else
- ctrl &= ~SDHCI_CTRL_HISPD;
- sdhci_writeb(host, ctrl, SDHCI_HOST_CONTROL);
- if ((host->quirks & SDHCI_QUIRK_32BIT_DMA_ADDR) && !aligned_buffer) {
- aligned_buffer = memalign(8, 512*1024);
- if (!aligned_buffer) {
- printf("Aligned buffer alloc failed!!!");
- return -1;
- /* Eable all state */
- sdhci_writel(host, SDHCI_INT_ALL_MASK, SDHCI_INT_ENABLE);
- sdhci_writel(host, SDHCI_INT_ALL_MASK, SDHCI_SIGNAL_ENABLE);
- sdhci_set_power(host, fls(mmc->voltages) - 1);
- struct mmc *mmc;
- unsigned int caps;
- mmc = malloc(sizeof(struct mmc));
- if (!mmc) {
- printf("mmc malloc fail!\n");
- return -1;
- mmc->priv = host;
- sprintf(mmc->name, "%s", host->name);
- mmc->send_cmd = sdhci_send_command;
- mmc->set_ios = sdhci_set_ios;
- mmc->init = sdhci_init;
- caps = sdhci_readl(host, SDHCI_CAPABILITIES);
- if (!(caps & SDHCI_CAN_DO_SDMA)) {
- printf("Your controller don't support sdma!!\n");
- return -1;
- if (max_clk)
- mmc->f_max = max_clk;
- else {
- mmc->f_max = (caps & SDHCI_CLOCK_V3_BASE_MASK)
- >> SDHCI_CLOCK_BASE_SHIFT;
- else
- mmc->f_max = (caps & SDHCI_CLOCK_BASE_MASK)
- mmc->f_max *= 1000000;
- if (mmc->f_max == 0) {
- printf("Hardware doesn't specify base clock frequency\n");
- return -1;
- if (min_clk)
- mmc->f_min = min_clk;
- else {
- mmc->f_min = mmc->f_max / SDHCI_MAX_DIV_SPEC_300;
- else
- mmc->f_min = mmc->f_max / SDHCI_MAX_DIV_SPEC_200;
- mmc->voltages = 0;
- if (caps & SDHCI_CAN_VDD_330)
- mmc->voltages |= MMC_VDD_32_33 | MMC_VDD_33_34;
- if (caps & SDHCI_CAN_VDD_300)
- mmc->voltages |= MMC_VDD_29_30 | MMC_VDD_30_31;
- if (caps & SDHCI_CAN_VDD_180)
- mmc->voltages |= MMC_VDD_165_195;
- mmc->host_caps = MMC_MODE_HS | MMC_MODE_HS_52MHz | MMC_MODE_4BIT;
- if (caps & SDHCI_CAN_DO_8BIT)
- mmc->host_caps |= MMC_MODE_8BIT;
- sdhci_reset(host, SDHCI_RESET_ALL);
- mmc_register(mmc);
- project.
- MA 02111-1307 USA
- Controller registers
- SDHCI_INT_CRC | SDHCI_INT_END_BIT | SDHCI_INT_INDEX)
- SDHCI_INT_DATA_AVAIL | SDHCI_INT_SPACE_AVAIL | \
- SDHCI_INT_DATA_TIMEOUT | SDHCI_INT_DATA_CRC | \
- SDHCI_INT_DATA_END_BIT | SDHCI_INT_ADMA_ERROR)
- End of controller registers.
- quirks
- Host SDMA buffer boundary. Valid values from 4K to 512K in powers of 2.
- u32 (*read_l)(struct sdhci_host *host, int reg);
- u16 (*read_w)(struct sdhci_host *host, int reg);
- u8 (*read_b)(struct sdhci_host *host, int reg);
- void (*write_l)(struct sdhci_host *host, u32 val, int reg);
- void (*write_w)(struct sdhci_host *host, u16 val, int reg);
- void (*write_b)(struct sdhci_host *host, u8 val, int reg);
+#endif +};
- char *name;
- void *ioaddr;
- unsigned int quirks;
- unsigned int version;
- unsigned int clock;
- const struct sdhci_ops *ops;
- if (unlikely(host->ops->write_l))
- host->ops->write_l(host, val, reg);
- else
- writel(val, host->ioaddr + reg);
- if (unlikely(host->ops->write_w))
- host->ops->write_w(host, val, reg);
- else
- writew(val, host->ioaddr + reg);
- if (unlikely(host->ops->write_b))
- host->ops->write_b(host, val, reg);
- else
- writeb(val, host->ioaddr + reg);
- if (unlikely(host->ops->read_l))
- return host->ops->read_l(host, reg);
- else
- return readl(host->ioaddr + reg);
- if (unlikely(host->ops->read_w))
- return host->ops->read_w(host, reg);
- else
- return readw(host->ioaddr + reg);
- if (unlikely(host->ops->read_b))
- return host->ops->read_b(host, reg);
- else
- return readb(host->ioaddr + reg);
+#else
+} +#endif
1.7.0.4
Hello,
Is this driver adaptable for sheevaplug ?
Le 29/06/2011 05:46, Lei Wen a écrit :
Hi All,
Thanks, Lei
- project.
- MA 02111-1307 USA
timeout = 100;
if (timeout == 0) {
return;
timeout--;
udelay(1000);
int i;
if (i != 3)
} else {
int i;
char *offs;
else
do {
return -1;
if (stat & rdy) {
continue;
break;
int ret = 0;
timeout = 10;
if (timeout == 0) {
return COMM_ERR;
timeout--;
udelay(1000);
} else
if (data)
if (data != 0) {
else
is_aligned = 0;
data->blocksize),
SDHCI_BLOCK_SIZE);
flush_cache(0, ~0);
do {
break;
} else
ret = -1;
if (!ret && data)
if (!ret) {
return TIMEOUT;
else
return COMM_ERR;
if (clock == 0)
div = 1;
else {
break;
} else {
break;
div >>= 1;
timeout = 20;
if (timeout == 0) {
return -1;
timeout--;
udelay(1000);
u8 pwr = 0;
break;
case MMC_VDD_29_30:
case MMC_VDD_30_31:
break;
case MMC_VDD_32_33:
case MMC_VDD_33_34:
break;
if (pwr == 0) {
return;
u32 ctrl;
/* Set bus width */
} else {
else
else
return -1;
struct mmc *mmc;
unsigned int caps;
if (!mmc) {
return -1;
mmc->priv = host;
return -1;
if (max_clk)
else {
else
return -1;
if (min_clk)
else {
else
mmc->voltages = 0;
mmc_register(mmc);
- project.
- MA 02111-1307 USA
- quirks
+#endif +};
char *name;
void *ioaddr;
unsigned int clock;
else
else
else
else
else
else
+#else
+} +#endif
1.7.0.4
Hi Gérald,
On Wed, Jun 29, 2011 at 1:53 PM, Gérald Kerma geraker@gmail.com wrote:
Hello,
Sheevaplug use kirkwood series, which is different from the platform current develop on. But since this is a generic framework, any controller follow sdhci host spec certainly could be supported.
In the Linux kernel, the sdhci-dove.c does the similar way to support the kirkwood.
Best regards, Lei
Hello Lei,
Le 29/06/2011 07:58, Lei Wen a écrit :
Hi Gérald,
Hello,
The linux kernel use mvsdio driver for kirkwood.
MMC_MVSDIO Marvell MMC/SD/SDIO host driver This selects the Marvell SDIO host driver. SDIO may currently be found on the Kirkwood 88F6281 and 88F6192 SoC controllers.
MMC_SDHCI_DOVE SDHCI support on Marvell's Dove SoC This selects the Secure Digital Host Controller Interface in Marvell's Dove SoC.
a driver patch which use the old generic driver was adapted from Marvell UBoot (mvsdio).
It's not included in the Denx uboot mainline but is available in the Debian Uboot.
Hi Gérald,
On Sun, Jul 17, 2011 at 3:20 PM, Gérald Kerma geraker@gmail.com wrote:
Hello Lei,
Hi Gérald,
Hello,
I just don't object kirkwood to resue the old way. But since sdhci could be a generic framework, it is nice that denx mainline could also use sdhci for kirkwood which is actively maintained like in the linux kernel.
Best regards, Lei
-----Original Message----- From: u-boot-bounces@lists.denx.de [mailto:u-boot-bounces@lists.denx.de] On Behalf Of Lei Wen Sent: Sunday, July 17, 2011 12:54 PM To: Gérald Kerma Cc: Lei Wen; Yu Tang; Rob Herring; u-boot@lists.denx.de; Andy Fleming; Ashish Karkare; Prabhanjan Sarnaik Subject: Re: [U-Boot] [PATCH 1/2] MMC: add sdhci generic framework
Hi Gérald,
Hello Lei,
Hi Gérald,
wrote:
Hello,
Marvell
UBoot (mvsdio).
I don't see an issue here, if sdhci is more generic, it will support few more SoCs then it should go for mainlining.
Regards.. Prafulla . . .
Best regards, Lei _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
-----Original Message----- From: Lei Wen [mailto:adrian.wenl@gmail.com] Sent: Wednesday, June 29, 2011 9:17 AM To: Lei Wen Cc: Andy Fleming; Rob Herring; u-boot@lists.denx.de; Prafulla Wadaskar; Yu Tang; Prabhanjan Sarnaik; Ashish Karkare Subject: Re: [U-Boot] [PATCH 1/2] MMC: add sdhci generic framework
Hi All,
Hi Lei, I ack for the driver. Can you re-submit v2 patches as per review comments for v1?
Copying Andy Fleming on his alternate email id.
Hi Prafulla,
On Wed, Jun 29, 2011 at 2:56 PM, Prafulla Wadaskar prafulla@marvell.com wrote:
Hi All,
Ok, I would push the v2 patch later.
Thanks, Lei
V1: add sdhci generic framework and with marvell sdhci implementation
V2: rename the previous file name from sdhci-mv to mv_sdhci
Lei Wen (2): MMC: add sdhci generic framework MMC: add marvell sdhci driver
drivers/mmc/Makefile | 2 + drivers/mmc/mv_sdhci.c | 21 +++ drivers/mmc/sdhci.c | 433 ++++++++++++++++++++++++++++++++++++++++++++++++ include/sdhci.h | 325 ++++++++++++++++++++++++++++++++++++ 4 files changed, 781 insertions(+), 0 deletions(-) create mode 100644 drivers/mmc/mv_sdhci.c create mode 100644 drivers/mmc/sdhci.c create mode 100644 include/sdhci.h
Hi Andy,
Could this version be accepted to be merged?
Thanks, Lei
On Jul 12, 2011, at 22:54, "Lei Wen" adrian.wenl@gmail.com wrote:
Hi Andy,
I'm working on merging these (and other) patches this weekend.
Andy
Hi Wolfgang,
How about merge this for the next release?
Thanks, Lei
Hello Lei,
I am looking into adding eMMC support for some intel SDHCI controllers based on this common SDHCI driver submission.
One thing which is not quite clear is the quirks - can you (or somebody else on this list) please shed some light on what the quirks are. Is there some kind of formal description/definition of various defined quirks and their processing.
Thank you in advance,
--vb
Hi Vadim,
The quirk is standing for some workaround for those host that has some limitation that it cannot directly be applied with standard sdhci.c code, so that we add one quirk for it, which let it could use the sdhci.c.
Like the quirk as SDHCI_QUIRK_32BIT_DMA_ADDR, it indicate that some host has dma engine limitation that it must start from address with alignement. So if sdhci find caller set this quirk, it would follow corresponding workaround for it.
There is no formal description for it as I could see.
Thanks, Lei
-----Original Message----- From: vbendeb@gmail.com [mailto:vbendeb@gmail.com] On Behalf Of Vadim Bendebury Sent: Tuesday, October 15, 2013 10:09 AM To: Lei Wen Cc: Prafulla Wadaskar; afleming@gmail.com; Rob Herring; u- boot@lists.denx.de; Yu Tang; Prabhanjan Sarnaik; Ashish Karkare; Andy Fleming Subject: Re: [U-Boot] [PATCH V2 0/2] add sdhci generic framework
Hello Lei,
--vb
On Mon, Oct 14, 2013 at 7:16 PM, Lei Wen leiwen@marvell.com wrote:
Hi Vadim,
All right, that's what I figured :). Thank you for the explanation,
--vb
Thanks, Lei
Hello Lei,
--vb
Signed-off-by: Lei Wen leiwen@marvell.com --- V1: add sdhci generic framework
V2: No Change
Signed-off-by: Lei Wen leiwen@marvell.com --- V1: add marvell sdhci driver implementation
drivers/mmc/Makefile | 1 + drivers/mmc/mv_sdhci.c | 21 +++++++++++++++++++++ 2 files changed, 22 insertions(+), 0 deletions(-) create mode 100644 drivers/mmc/mv_sdhci.c
diff --git a/drivers/mmc/Makefile b/drivers/mmc/Makefile index 50b5117..bf6534a 100644 --- a/drivers/mmc/Makefile +++ b/drivers/mmc/Makefile @@ -39,6 +39,7 @@ COBJS-$(CONFIG_OMAP_HSMMC) += omap_hsmmc.o COBJS-$(CONFIG_PXA_MMC) += pxa_mmc.o COBJS-$(CONFIG_S5P_MMC) += s5p_mmc.o COBJS-$(CONFIG_SDHCI) += sdhci.o +COBJS-$(CONFIG_MV_SDHCI) += mv_sdhci.o
COBJS := $(COBJS-y) SRCS := $(COBJS:.o=.c) diff --git a/drivers/mmc/mv_sdhci.c b/drivers/mmc/mv_sdhci.c new file mode 100644 index 0000000..af0d486 --- /dev/null +++ b/drivers/mmc/mv_sdhci.c @@ -0,0 +1,21 @@ +#include <common.h> +#include <malloc.h> +#include <sdhci.h> + +static char *MVSDH_NAME = "mv_sdh"; +int mv_sdh_init(u32 regbase, u32 max_clk, u32 min_clk, u32 quirks) +{ + struct sdhci_host *host = NULL; + host = (struct sdhci_host *)malloc(sizeof(struct sdhci_host)); + if (!host) { + printf("sdh_host malloc fail!\n"); + return 1; + } + + host->name = MVSDH_NAME; + host->ioaddr = (void *)regbase; + host->quirks = quirks; + host->version = sdhci_readw(host, SDHCI_HOST_VERSION); + add_sdhci(host, max_clk, min_clk); + return 0; +}
participants (6)
Fleming Andy-AFLEMING
Gérald Kerma
Lei Wen
Lei Wen
Prafulla Wadaskar
Vadim Bendebury
