[PATCH v3 0/3] bootcount: Replace I2C legacy implementation by driver model
The generic I2C bootcounter driver does not yet adhere to driver model. This patchset intends to replace the legacy implementation.
There are currently no upstream boards using the driver, so it should be safe to just remove it. For downstream users it should be straighforward to switch to the new implementation.
Changes in v3: - Remove common.h #include
Changes in v2: - Improved device tree handling by replacing address property with phandle - Addition of a generic i2c helper function
Philip Richard Oberfichtner (3): bootcount: Remove legacy I2C driver i2c: Implement i2c_get_chip_by_phandle() bootcount: Add driver model I2C driver
drivers/bootcount/Kconfig | 34 ++++----- drivers/bootcount/Makefile | 2 +- drivers/bootcount/bootcount_dm_i2c.c | 102 +++++++++++++++++++++++++++ drivers/bootcount/bootcount_i2c.c | 43 ----------- drivers/i2c/i2c-uclass.c | 75 ++++++++++++++++++++ include/i2c.h | 12 ++++ 6 files changed, 203 insertions(+), 65 deletions(-) create mode 100644 drivers/bootcount/bootcount_dm_i2c.c delete mode 100644 drivers/bootcount/bootcount_i2c.c
The legacy I2C bootcounter will hereby be removed and eventually be replaced by a driver model implementation in the follow-up commit.
The legacy driver has the following drawbacks: - It's not adhering to the driver model - Settings are grabbed from Kconfig rather than device tree - i2c_{read,write} are being used instead of dm_i2c_{read,write}
Signed-off-by: Philip Richard Oberfichtner pro@denx.de ---
Notes: Changes in v3: none Changes in v2: none
drivers/bootcount/Kconfig | 24 +++-------------- drivers/bootcount/Makefile | 1 - drivers/bootcount/bootcount_i2c.c | 43 ------------------------------- 3 files changed, 3 insertions(+), 65 deletions(-) delete mode 100644 drivers/bootcount/bootcount_i2c.c
diff --git a/drivers/bootcount/Kconfig b/drivers/bootcount/Kconfig index 570252d186..7a2548ace2 100644 --- a/drivers/bootcount/Kconfig +++ b/drivers/bootcount/Kconfig @@ -79,14 +79,6 @@ config BOOTCOUNT_RAM Store the bootcount in DRAM protected against bit errors due to short power loss or holding a system in RESET.
-config BOOTCOUNT_I2C - bool "Boot counter on I2C device" - help - Enable support for the bootcounter on an i2c (like RTC) device. - CFG_SYS_I2C_RTC_ADDR = i2c chip address - CONFIG_SYS_BOOTCOUNT_ADDR = i2c addr which is used for - the bootcounter. - config BOOTCOUNT_AT91 bool "Boot counter for Atmel AT91SAM9XE" depends on AT91SAM9XE @@ -175,14 +167,6 @@ config BOOTCOUNT_BOOTLIMIT counter being cleared. If set to 0, do not set a boot limit in the environment.
-config BOOTCOUNT_ALEN - int "I2C address length" - default 1 - depends on BOOTCOUNT_I2C - help - Length of the the I2C address at SYS_BOOTCOUNT_ADDR for storing - the boot counter. - config SYS_BOOTCOUNT_SINGLEWORD bool "Use single word to pack boot count and magic value" depends on BOOTCOUNT_GENERIC @@ -218,7 +202,7 @@ config SYS_BOOTCOUNT_ADDR default 0x44E3E000 if BOOTCOUNT_AM33XX || BOOTCOUNT_AM33XX_NVMEM default 0xE0115FF8 if ARCH_LS1043A || ARCH_LS1021A depends on BOOTCOUNT_AM33XX || BOOTCOUNT_GENERIC || BOOTCOUNT_EXT || \ - BOOTCOUNT_I2C || BOOTCOUNT_AM33XX_NVMEM + BOOTCOUNT_AM33XX_NVMEM help Set the address used for reading and writing the boot counter.
@@ -226,13 +210,11 @@ config SYS_BOOTCOUNT_MAGIC hex "Magic value for the boot counter" default 0xB001C041 if BOOTCOUNT_GENERIC || BOOTCOUNT_EXT || \ BOOTCOUNT_AM33XX || BOOTCOUNT_ENV || \ - BOOTCOUNT_RAM || BOOTCOUNT_I2C || \ - BOOTCOUNT_AT91 || DM_BOOTCOUNT + BOOTCOUNT_RAM || BOOTCOUNT_AT91 || DM_BOOTCOUNT default 0xB0 if BOOTCOUNT_AM33XX_NVMEM depends on BOOTCOUNT_GENERIC || BOOTCOUNT_EXT || \ BOOTCOUNT_AM33XX || BOOTCOUNT_ENV || \ - BOOTCOUNT_RAM || BOOTCOUNT_I2C || \ - BOOTCOUNT_AT91 || DM_BOOTCOUNT || \ + BOOTCOUNT_RAM || BOOTCOUNT_AT91 || DM_BOOTCOUNT || \ BOOTCOUNT_AM33XX_NVMEM help Set the magic value used for the boot counter. diff --git a/drivers/bootcount/Makefile b/drivers/bootcount/Makefile index b65959a384..d6d2389c16 100644 --- a/drivers/bootcount/Makefile +++ b/drivers/bootcount/Makefile @@ -6,7 +6,6 @@ obj-$(CONFIG_BOOTCOUNT_AT91) += bootcount_at91.o obj-$(CONFIG_BOOTCOUNT_AM33XX) += bootcount_davinci.o obj-$(CONFIG_BOOTCOUNT_RAM) += bootcount_ram.o obj-$(CONFIG_BOOTCOUNT_ENV) += bootcount_env.o -obj-$(CONFIG_BOOTCOUNT_I2C) += bootcount_i2c.o obj-$(CONFIG_BOOTCOUNT_EXT) += bootcount_ext.o obj-$(CONFIG_BOOTCOUNT_AM33XX_NVMEM) += bootcount_nvmem.o
diff --git a/drivers/bootcount/bootcount_i2c.c b/drivers/bootcount/bootcount_i2c.c deleted file mode 100644 index b3ac67ea35..0000000000 --- a/drivers/bootcount/bootcount_i2c.c +++ /dev/null @@ -1,43 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * (C) Copyright 2013 - * Heiko Schocher, DENX Software Engineering, hs@denx.de. - */ - -#include <bootcount.h> -#include <linux/compiler.h> -#include <i2c.h> - -#define BC_MAGIC 0xbc - -void bootcount_store(ulong a) -{ - unsigned char buf[3]; - int ret; - - buf[0] = BC_MAGIC; - buf[1] = (a & 0xff); - ret = i2c_write(CFG_SYS_I2C_RTC_ADDR, CONFIG_SYS_BOOTCOUNT_ADDR, - CONFIG_BOOTCOUNT_ALEN, buf, 2); - if (ret != 0) - puts("Error writing bootcount\n"); -} - -ulong bootcount_load(void) -{ - unsigned char buf[3]; - int ret; - - ret = i2c_read(CFG_SYS_I2C_RTC_ADDR, CONFIG_SYS_BOOTCOUNT_ADDR, - CONFIG_BOOTCOUNT_ALEN, buf, 2); - if (ret != 0) { - puts("Error loading bootcount\n"); - return 0; - } - if (buf[0] == BC_MAGIC) - return buf[1]; - - bootcount_store(0); - - return 0; -}
Hello Philip,
Reviewed-by: Heiko Schocher hs@denx.de
bye, Heiko
Hello Philip,
Applied to u-boot-i2c.git master
Thanks!
bye, Heiko
This new function enhances the i2c_get_chip*() toolbox by implementing a variant that does not require a chip_addr. Instead, the desired device is pointed to by a phandle.
Notes: Changes in v3: none Changes in v2: new
drivers/i2c/i2c-uclass.c | 75 ++++++++++++++++++++++++++++++++++++++++ include/i2c.h | 12 +++++++ 2 files changed, 87 insertions(+)
diff --git a/drivers/i2c/i2c-uclass.c b/drivers/i2c/i2c-uclass.c index 8867a560bd..5405067861 100644 --- a/drivers/i2c/i2c-uclass.c +++ b/drivers/i2c/i2c-uclass.c @@ -388,6 +388,81 @@ int i2c_get_chip_for_busnum(int busnum, int chip_addr, uint offset_len, return 0; }
+/* Find and probe I2C bus based on a chip attached to it */ +static int i2c_get_parent_bus(ofnode chip, struct udevice **devp) +{ + ofnode node; + struct udevice *dev; + int ret; + + node = ofnode_get_parent(chip); + if (!ofnode_valid(node)) + return -ENODEV; + + ret = uclass_get_device_by_ofnode(UCLASS_I2C, node, &dev); + if (ret) { + *devp = NULL; + return ret; + } + + *devp = dev; + return 0; +} + +int i2c_get_chip_by_phandle(const struct udevice *parent, const char *prop_name, + struct udevice **devp) +{ + ofnode node; + uint phandle; + struct udevice *bus, *chip; + char *dev_name; + int ret; + + debug("%s: Searching I2C chip for phandle "%s"\n", + __func__, prop_name); + + dev_name = strdup(prop_name); + if (!dev_name) { + ret = -ENOMEM; + goto err_exit; + } + + ret = dev_read_u32(parent, "i2cbcdev", &phandle); + if (ret) + goto err_exit; + + node = ofnode_get_by_phandle(phandle); + if (!ofnode_valid(node)) { + ret = -ENODEV; + goto err_exit; + } + + ret = i2c_get_parent_bus(node, &bus); + if (ret) + goto err_exit; + + ret = device_bind_driver_to_node(bus, "i2c_generic_chip_drv", + dev_name, node, &chip); + if (ret) + goto err_exit; + + ret = device_probe(chip); + if (ret) { + device_unbind(chip); + goto err_exit; + } + + debug("%s succeeded\n", __func__); + *devp = chip; + return 0; + +err_exit: + free(dev_name); + debug("%s failed, ret = %d\n", __func__, ret); + *devp = NULL; + return ret; +} + int dm_i2c_probe(struct udevice *bus, uint chip_addr, uint chip_flags, struct udevice **devp) { diff --git a/include/i2c.h b/include/i2c.h index ef3820eaba..4e59009cd9 100644 --- a/include/i2c.h +++ b/include/i2c.h @@ -537,6 +537,18 @@ int i2c_get_chip(struct udevice *bus, uint chip_addr, uint offset_len, int i2c_get_chip_for_busnum(int busnum, int chip_addr, uint offset_len, struct udevice **devp);
+/** + * i2c_get_chip_by_phandle() - get a device to use to access a chip + * based on a phandle property pointing to it + * + * @parent: Parent device containing the phandle pointer + * @name: Name of phandle property in the parent device node + * @devp: Returns pointer to new device or NULL if not found + * Return: 0 on success, -ve on failure + */ +int i2c_get_chip_by_phandle(const struct udevice *parent, const char *prop_name, + struct udevice **devp); + /** * i2c_chip_of_to_plat() - Decode standard I2C platform data *
Hello Philip,
bye, Heiko
Hello Philip,
Thanks!
bye, Heiko
This adds a generic I2C bootcounter adhering to driver model to replace the previously removed legacy implementation.
There is no change in functionality, it can be used on any I2C device. The device tree configuration may look like this for example:
bootcount { compatible = "u-boot,bootcount-i2c"; i2cbcdev = <&i2c_rtc>; offset = <0x11>; };
Notes: Changes in v3: - Remove common.h #include
Changes in v2: - Adaption of Kconfig help message - Rename chip to bcdev - Adapt probe to use i2c_get_chip_by_phandle()
drivers/bootcount/Kconfig | 10 +++ drivers/bootcount/Makefile | 1 + drivers/bootcount/bootcount_dm_i2c.c | 102 +++++++++++++++++++++++++++ 3 files changed, 113 insertions(+) create mode 100644 drivers/bootcount/bootcount_dm_i2c.c
diff --git a/drivers/bootcount/Kconfig b/drivers/bootcount/Kconfig index 7a2548ace2..3c56253b1e 100644 --- a/drivers/bootcount/Kconfig +++ b/drivers/bootcount/Kconfig @@ -109,6 +109,16 @@ config DM_BOOTCOUNT_RTC Accesses to the backing store are performed using the write16 and read16 ops of DM RTC devices.
+config DM_BOOTCOUNT_I2C + bool "Driver Model boot counter on I2C device" + depends on DM_I2C + help + Enable support for the bootcounter on a generic i2c device, like a RTC + or PMIC. The bootcounter is configured in the device tree using the + "u-boot,bootcount-i2c" compatible string. It requires a phandle + 'i2cbcdev' for the i2c device and an 'offset' property used within the + device. + config DM_BOOTCOUNT_I2C_EEPROM bool "Support i2c eeprom devices as a backing store for bootcount" depends on I2C_EEPROM diff --git a/drivers/bootcount/Makefile b/drivers/bootcount/Makefile index d6d2389c16..e7771f5b36 100644 --- a/drivers/bootcount/Makefile +++ b/drivers/bootcount/Makefile @@ -13,5 +13,6 @@ obj-$(CONFIG_DM_BOOTCOUNT) += bootcount-uclass.o obj-$(CONFIG_DM_BOOTCOUNT_PMIC_PFUZE100) += pmic_pfuze100.o obj-$(CONFIG_DM_BOOTCOUNT_RTC) += rtc.o obj-$(CONFIG_DM_BOOTCOUNT_I2C_EEPROM) += i2c-eeprom.o +obj-$(CONFIG_DM_BOOTCOUNT_I2C) += bootcount_dm_i2c.o obj-$(CONFIG_DM_BOOTCOUNT_SPI_FLASH) += spi-flash.o obj-$(CONFIG_DM_BOOTCOUNT_SYSCON) += bootcount_syscon.o diff --git a/drivers/bootcount/bootcount_dm_i2c.c b/drivers/bootcount/bootcount_dm_i2c.c new file mode 100644 index 0000000000..e27034cbeb --- /dev/null +++ b/drivers/bootcount/bootcount_dm_i2c.c @@ -0,0 +1,102 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2023 + * Philip Richard Oberfichtner pro@denx.de + * + * Based on previous work from Heiko Schocher (legacy bootcount_i2c.c driver) + */ + +#include <bootcount.h> +#include <dm.h> +#include <i2c.h> + +#define BC_MAGIC 0x55 + +struct bootcount_i2c_priv { + struct udevice *bcdev; + unsigned int offset; +}; + +static int bootcount_i2c_set(struct udevice *dev, const u32 val) +{ + int ret; + struct bootcount_i2c_priv *priv = dev_get_priv(dev); + + ret = dm_i2c_reg_write(priv->bcdev, priv->offset, BC_MAGIC); + if (ret < 0) + goto err_exit; + + ret = dm_i2c_reg_write(priv->bcdev, priv->offset + 1, val & 0xff); + if (ret < 0) + goto err_exit; + + return 0; + +err_exit: + log_debug("%s: Error writing to I2C device (%d)\n", __func__, ret); + return ret; +} + +static int bootcount_i2c_get(struct udevice *dev, u32 *val) +{ + int ret; + struct bootcount_i2c_priv *priv = dev_get_priv(dev); + + ret = dm_i2c_reg_read(priv->bcdev, priv->offset); + if (ret < 0) + goto err_exit; + + if ((ret & 0xff) != BC_MAGIC) { + log_debug("%s: Invalid Magic, reset bootcounter.\n", __func__); + *val = 0; + return bootcount_i2c_set(dev, 0); + } + + ret = dm_i2c_reg_read(priv->bcdev, priv->offset + 1); + if (ret < 0) + goto err_exit; + + *val = ret; + return 0; + +err_exit: + log_debug("%s: Error reading from I2C device (%d)\n", __func__, ret); + return ret; +} + +static int bootcount_i2c_probe(struct udevice *dev) +{ + struct bootcount_i2c_priv *priv = dev_get_priv(dev); + int ret; + + ret = dev_read_u32(dev, "offset", &priv->offset); + if (ret) + goto exit; + + ret = i2c_get_chip_by_phandle(dev, "i2cbcdev", &priv->bcdev); + +exit: + if (ret) + log_debug("%s failed, ret = %d\n", __func__, ret); + + return ret; +} + +static const struct bootcount_ops bootcount_i2c_ops = { + .get = bootcount_i2c_get, + .set = bootcount_i2c_set, +}; + +static const struct udevice_id bootcount_i2c_ids[] = { + { .compatible = "u-boot,bootcount-i2c" }, + { } +}; + +U_BOOT_DRIVER(bootcount_i2c) = { + .name = "bootcount-i2c", + .id = UCLASS_BOOTCOUNT, + .priv_auto = sizeof(struct bootcount_i2c_priv), + .probe = bootcount_i2c_probe, + .of_match = bootcount_i2c_ids, + .ops = &bootcount_i2c_ops, +};
Hello Philip,
bye, Heiko
Hello Philip,
Thanks!
bye, Heiko
Heiko Schocher
