[PATCH] Rname CONFIG_SPL_FIT_SHAxxx to CONFIG_SPL_SHAxxx
Rename these options to align the use in common/image-fit.c
else if (CONFIG_IS_ENABLED(SHA1) && strcmp(algo, "sha1") == 0) ... else if (CONFIG_IS_ENABLED(SHA256) && strcmp(algo, "sha256") == 0) ... else if (CONFIG_IS_ENABLED(SHA384) && strcmp(algo, "sha384") == 0) ... else if (CONFIG_IS_ENABLED(SHA512) && strcmp(algo, "sha512") == 0) ...
Signed-off-by: Chia-Wei Wang chiawei_wang@aspeedtech.com --- common/spl/Kconfig | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/common/spl/Kconfig b/common/spl/Kconfig index 9552ed4911..67e0345906 100644 --- a/common/spl/Kconfig +++ b/common/spl/Kconfig @@ -439,7 +439,7 @@ config SPL_MD5 applications where images may be changed maliciously, you should consider SHA256 or SHA384.
-config SPL_FIT_SHA1 +config SPL_SHA1 bool "Support SHA1" depends on SPL_FIT select SHA1 @@ -451,7 +451,7 @@ config SPL_FIT_SHA1 due to the expanding computing power available to brute-force attacks. For more security, consider SHA256 or SHA384.
-config SPL_FIT_SHA256 +config SPL_SHA256 bool "Support SHA256" depends on SPL_FIT select SHA256 @@ -460,7 +460,7 @@ config SPL_FIT_SHA256 checksum is a 256-bit (32-byte) hash value used to check that the image contents have not been corrupted.
-config SPL_FIT_SHA384 +config SPL_SHA384 bool "Support SHA384" depends on SPL_FIT select SHA384 @@ -471,7 +471,7 @@ config SPL_FIT_SHA384 image contents have not been corrupted. Use this for the highest security.
-config SPL_FIT_SHA512 +config SPL_SHA512 bool "Support SHA512" depends on SPL_FIT select SHA512
Chia-Wei Wang
