[U-Boot] [PATCH v1 0/3] Let U-Boot generate MAC address for db410
This patchset gives U-boot ownership on generating WLAN/BT mac addresses for WCNSS chip on Dragonboard410. Previously, this was done by LK and U-boot only read the results from the patched DTB LK fixed-up.
This is is part of my ongoing effort to get rid of LK once and for all for Snapdragon ARCH.
Ramon Fried (3): snapdragon: added msm_board_serial() func snapdragon: added MAC generation functions db410: alter WLAN/BT MAC address fixup
arch/arm/mach-snapdragon/Makefile | 1 + arch/arm/mach-snapdragon/include/mach/misc.h | 13 +++++ arch/arm/mach-snapdragon/misc.c | 53 ++++++++++++++++++ .../dragonboard410c/dragonboard410c.c | 54 +++++++++---------- 4 files changed, 94 insertions(+), 27 deletions(-) create mode 100644 arch/arm/mach-snapdragon/include/mach/misc.h create mode 100644 arch/arm/mach-snapdragon/misc.c
This commit adds a function to get the board serial number. In snapdragon it's actually the eMMC serial number.
Function added in a new file misc.c that will include further snapdragon miscellaneous functions.
Signed-off-by: Ramon Fried ramon.fried@gmail.com
arch/arm/mach-snapdragon/Makefile | 1 + arch/arm/mach-snapdragon/include/mach/misc.h | 12 +++++++ arch/arm/mach-snapdragon/misc.c | 37 ++++++++++++++++++++ 3 files changed, 50 insertions(+) create mode 100644 arch/arm/mach-snapdragon/include/mach/misc.h create mode 100644 arch/arm/mach-snapdragon/misc.c
diff --git a/arch/arm/mach-snapdragon/Makefile b/arch/arm/mach-snapdragon/Makefile index f375d07d03..2d94083600 100644 --- a/arch/arm/mach-snapdragon/Makefile +++ b/arch/arm/mach-snapdragon/Makefile @@ -8,5 +8,6 @@ obj-$(CONFIG_TARGET_DRAGONBOARD410C) += clock-apq8016.o obj-$(CONFIG_TARGET_DRAGONBOARD410C) += sysmap-apq8016.o obj-$(CONFIG_TARGET_DRAGONBOARD410C) += pinctrl-apq8016.o obj-$(CONFIG_TARGET_DRAGONBOARD410C) += pinctrl-snapdragon.o +obj-y += misc.o obj-y += clock-snapdragon.o obj-y += dram.o diff --git a/arch/arm/mach-snapdragon/include/mach/misc.h b/arch/arm/mach-snapdragon/include/mach/misc.h new file mode 100644 index 0000000000..5af6ae8da4 --- /dev/null +++ b/arch/arm/mach-snapdragon/include/mach/misc.h @@ -0,0 +1,12 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Snapdragon DRAM + * Copyright (C) 2018 Ramon Fried ramon.fried@gmail.com + */ + +#ifndef MISC_H +#define MISC_H + +u32 msm_board_serial(void); + +#endif diff --git a/arch/arm/mach-snapdragon/misc.c b/arch/arm/mach-snapdragon/misc.c new file mode 100644 index 0000000000..678bd69f83 --- /dev/null +++ b/arch/arm/mach-snapdragon/misc.c @@ -0,0 +1,37 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Miscellaneous Snapdragon functionality + * + * (C) Copyright 2018 Ramon Fried ramon.fried@gmail.com + * + */ + +#include <common.h> +#include <mmc.h> +#include <asm/arch/misc.h> + +/* UNSTUFF_BITS macro taken from Linux Kernel: drivers/mmc/core/sd.c */ +#define UNSTUFF_BITS(resp, start, size) \ + ({ \ + const int __size = size; \ + const u32 __mask = (__size < 32 ? 1 << __size : 0) - 1; \ + const int __off = 3 - ((start) / 32); \ + const int __shft = (start) & 31; \ + u32 __res; \ + \ + __res = resp[__off] >> __shft; \ + if (__size + __shft > 32) \ + __res |= resp[__off - 1] << ((32 - __shft) % 32); \ + __res & __mask; \ + }) + +u32 msm_board_serial(void) +{ + struct mmc *mmc_dev; + + mmc_dev = find_mmc_device(0); + if (!mmc_dev) + return 0; + + return UNSTUFF_BITS(mmc_dev->cid, 16, 32); +}
Add support for generation of unique MAC address that is derived from board serial. Algorithm for generation of MAC taken from LK.
Signed-off-by: Ramon Fried ramon.fried@gmail.com ---
arch/arm/mach-snapdragon/include/mach/misc.h | 1 + arch/arm/mach-snapdragon/misc.c | 16 ++++++++++++++++ 2 files changed, 17 insertions(+)
diff --git a/arch/arm/mach-snapdragon/include/mach/misc.h b/arch/arm/mach-snapdragon/include/mach/misc.h index 5af6ae8da4..c60e3e4724 100644 --- a/arch/arm/mach-snapdragon/include/mach/misc.h +++ b/arch/arm/mach-snapdragon/include/mach/misc.h @@ -8,5 +8,6 @@ #define MISC_H
u32 msm_board_serial(void); +void msm_generate_mac_addr(u8 *mac);
#endif diff --git a/arch/arm/mach-snapdragon/misc.c b/arch/arm/mach-snapdragon/misc.c index 678bd69f83..f6c87866c0 100644 --- a/arch/arm/mach-snapdragon/misc.c +++ b/arch/arm/mach-snapdragon/misc.c @@ -35,3 +35,19 @@ u32 msm_board_serial(void)
return UNSTUFF_BITS(mmc_dev->cid, 16, 32); } + +void msm_generate_mac_addr(u8 *mac) +{ + int i; + char sn[9]; + + snprintf(sn, 8, "%08x", msm_board_serial()); + + /* fill in the mac with serialno, use locally adminstrated pool */ + mac[0] = 0x02; + mac[1] = 00; + for (i = 3; i >= 0; i--) { + mac[i + 2] = simple_strtoul(&sn[2 * i], NULL, 16); + sn[2 * i] = 0; + } +}
Change the way MAC address fixup is done: 1. Stop using LK handed device-tree and calculate the MAC address our own. 2. Allow overriding the generated MACS with environment variables: "wlanaddr" and "btaddr".
.../dragonboard410c/dragonboard410c.c | 54 +++++++++---------- 1 file changed, 27 insertions(+), 27 deletions(-)
diff --git a/board/qualcomm/dragonboard410c/dragonboard410c.c b/board/qualcomm/dragonboard410c/dragonboard410c.c index 4f0b999e50..53e231e55a 100644 --- a/board/qualcomm/dragonboard410c/dragonboard410c.c +++ b/board/qualcomm/dragonboard410c/dragonboard410c.c @@ -10,7 +10,9 @@ #include <usb.h> #include <asm/gpio.h> #include <fdt_support.h> +#include <environment.h> #include <asm/arch/dram.h> +#include <asm/arch/misc.h>
DECLARE_GLOBAL_DATA_PTR;
@@ -149,40 +151,38 @@ int board_init(void) return 0; }
+/* Fixup of DTB for Linux Kernel + * 1. Fixup installed DRAM. + * 2. Fixup WLAN/BT Mac address: + * First, check if MAC addresses for WLAN/BT exists as environemnt + * variables wlanaddr,btaddr. if not, generate a unique address. + */ + int ft_board_setup(void *blob, bd_t *bd) { - int offset, len, i; - const char *mac; - struct { - const char *compatible; - const char *property; - } fix[] = { - [0] = { - /* update the kernel's dtb with wlan mac */ - .compatible = "qcom,wcnss-wlan", - .property = "local-mac-address", - }, - [1] = { - /* update the kernel's dtb with bt mac */ - .compatible = "qcom,wcnss-bt", - .property = "local-bd-address", - }, + u8 mac[ARP_HLEN]; + + msm_fixup_memory(blob); + + if (!eth_env_get_enetaddr("wlanaddr", mac)) { + msm_generate_mac_addr(mac); };
- for (i = 0; i < sizeof(fix) / sizeof(fix[0]); i++) { - offset = fdt_node_offset_by_compatible(gd->fdt_blob, -1, - fix[i].compatible); - if (offset < 0) - continue; + do_fixup_by_compat(blob, "qcom,wcnss-wlan", + "local-mac-address", mac, ARP_HLEN, 1);
- mac = fdt_getprop(gd->fdt_blob, offset, fix[i].property, &len); - if (mac) - do_fixup_by_compat(blob, fix[i].compatible, - fix[i].property, mac, ARP_HLEN, 1); - }
- msm_fixup_memory(blob); + if (!eth_env_get_enetaddr("btaddr", mac)) { + msm_generate_mac_addr(mac); + +/* The BD address is same as WLAN MAC address but with + * least significant bit flipped. + */ + mac[0] ^= 0x01; + };
+ do_fixup_by_compat(blob, "qcom,wcnss-bt", + "local-bd-address", mac, ARP_HLEN, 1); return 0; }
- Stop using LK handed device-tree and calculate the MAC address our own.
- Allow overriding the generated MACS with environment variables: "wlanaddr" and "btaddr".
Ramon Fried
