[U-Boot] [PATCH] i.MX6: set drive strength for parallel RGB pads
Default drive strength is disabled and won't function.
Signed-off-by: Eric Nelson eric.nelson@boundarydevices.com --- arch/arm/include/asm/arch-mx6/mx6x_pins.h | 58 ++++++++++++++-------------- 1 files changed, 29 insertions(+), 29 deletions(-)
diff --git a/arch/arm/include/asm/arch-mx6/mx6x_pins.h b/arch/arm/include/asm/arch-mx6/mx6x_pins.h index 3d66d64..3ade8dc 100644 --- a/arch/arm/include/asm/arch-mx6/mx6x_pins.h +++ b/arch/arm/include/asm/arch-mx6/mx6x_pins.h @@ -530,20 +530,20 @@ enum { MX6Q_PAD_EIM_BCLK__IPU1_DI1_PIN16 = IOMUX_PAD(0x046C, 0x0158, 1, 0x0000, 0, 0), MX6Q_PAD_EIM_BCLK__GPIO_6_31 = IOMUX_PAD(0x046C, 0x0158, 5, 0x0000, 0, 0), MX6Q_PAD_EIM_BCLK__TPSMP_HDATA_31 = IOMUX_PAD(0x046C, 0x0158, 6, 0x0000, 0, 0), - MX6Q_PAD_DI0_DISP_CLK__IPU1_DI0_DISP_CLK = IOMUX_PAD(0x0470, 0x015C, 0, 0x0000, 0, 0), + MX6Q_PAD_DI0_DISP_CLK__IPU1_DI0_DISP_CLK = IOMUX_PAD(0x0470, 0x015C, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6Q_PAD_DI0_DISP_CLK__IPU2_DI0_DISP_CLK = IOMUX_PAD(0x0470, 0x015C, 1, 0x0000, 0, 0), MX6Q_PAD_DI0_DISP_CLK__MIPI_CR_DPY_OT28 = IOMUX_PAD(0x0470, 0x015C, 3, 0x0000, 0, 0), MX6Q_PAD_DI0_DISP_CLK__SDMA_DBG_CR_STA0 = IOMUX_PAD(0x0470, 0x015C, 4, 0x0000, 0, 0), MX6Q_PAD_DI0_DISP_CLK__GPIO_4_16 = IOMUX_PAD(0x0470, 0x015C, 5, 0x0000, 0, 0), MX6Q_PAD_DI0_DISP_CLK__MMDC_DEBUG_0 = IOMUX_PAD(0x0470, 0x015C, 6, 0x0000, 0, 0), - MX6Q_PAD_DI0_PIN15__IPU1_DI0_PIN15 = IOMUX_PAD(0x0474, 0x0160, 0, 0x0000, 0, 0), + MX6Q_PAD_DI0_PIN15__IPU1_DI0_PIN15 = IOMUX_PAD(0x0474, 0x0160, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6Q_PAD_DI0_PIN15__IPU2_DI0_PIN15 = IOMUX_PAD(0x0474, 0x0160, 1, 0x0000, 0, 0), MX6Q_PAD_DI0_PIN15__AUDMUX_AUD6_TXC = IOMUX_PAD(0x0474, 0x0160, 2, 0x0000, 0, 0), MX6Q_PAD_DI0_PIN15__MIPI_CR_DPHY_OUT_29 = IOMUX_PAD(0x0474, 0x0160, 3, 0x0000, 0, 0), MX6Q_PAD_DI0_PIN15__SDMA_DBG_CORE_STA_1 = IOMUX_PAD(0x0474, 0x0160, 4, 0x0000, 0, 0), MX6Q_PAD_DI0_PIN15__GPIO_4_17 = IOMUX_PAD(0x0474, 0x0160, 5, 0x0000, 0, 0), MX6Q_PAD_DI0_PIN15__MMDC_MMDC_DEBUG_1 = IOMUX_PAD(0x0474, 0x0160, 6, 0x0000, 0, 0), - MX6Q_PAD_DI0_PIN2__IPU1_DI0_PIN2 = IOMUX_PAD(0x0478, 0x0164, 0, 0x0000, 0, 0), + MX6Q_PAD_DI0_PIN2__IPU1_DI0_PIN2 = IOMUX_PAD(0x0478, 0x0164, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6Q_PAD_DI0_PIN2__IPU2_DI0_PIN2 = IOMUX_PAD(0x0478, 0x0164, 1, 0x0000, 0, 0), MX6Q_PAD_DI0_PIN2__AUDMUX_AUD6_TXD = IOMUX_PAD(0x0478, 0x0164, 2, 0x0000, 0, 0), MX6Q_PAD_DI0_PIN2__MIPI_CR_DPHY_OUT_30 = IOMUX_PAD(0x0478, 0x0164, 3, 0x0000, 0, 0), @@ -551,7 +551,7 @@ enum { MX6Q_PAD_DI0_PIN2__GPIO_4_18 = IOMUX_PAD(0x0478, 0x0164, 5, 0x0000, 0, 0), MX6Q_PAD_DI0_PIN2__MMDC_DEBUG_2 = IOMUX_PAD(0x0478, 0x0164, 6, 0x0000, 0, 0), MX6Q_PAD_DI0_PIN2__PL301_PER1_HADDR_9 = IOMUX_PAD(0x0478, 0x0164, 7, 0x0000, 0, 0), - MX6Q_PAD_DI0_PIN3__IPU1_DI0_PIN3 = IOMUX_PAD(0x047C, 0x0168, 0, 0x0000, 0, 0), + MX6Q_PAD_DI0_PIN3__IPU1_DI0_PIN3 = IOMUX_PAD(0x047C, 0x0168, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6Q_PAD_DI0_PIN3__IPU2_DI0_PIN3 = IOMUX_PAD(0x047C, 0x0168, 1, 0x0000, 0, 0), MX6Q_PAD_DI0_PIN3__AUDMUX_AUD6_TXFS = IOMUX_PAD(0x047C, 0x0168, 2, 0x0000, 0, 0), MX6Q_PAD_DI0_PIN3__MIPI_CORE_DPHY_OUT31 = IOMUX_PAD(0x047C, 0x0168, 3, 0x0000, 0, 0), @@ -564,17 +564,17 @@ enum { MX6Q_PAD_DI0_PIN4__AUDMUX_AUD6_RXD = IOMUX_PAD(0x0480, 0x016C, 2, 0x0000, 0, 0), MX6Q_PAD_DI0_PIN4__USDHC1_WP = IOMUX_PAD(0x0480, 0x016C, 3, 0x094C, 0, 0), MX6Q_PAD_DI0_PIN4__SDMA_DEBUG_YIELD = IOMUX_PAD(0x0480, 0x016C, 4, 0x0000, 0, 0), - MX6Q_PAD_DI0_PIN4__GPIO_4_20 = IOMUX_PAD(0x0480, 0x016C, 5, 0x0000, 0, 0), + MX6Q_PAD_DI0_PIN4__GPIO_4_20 = IOMUX_PAD(0x0480, 0x016C, 5, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6Q_PAD_DI0_PIN4__MMDC_MMDC_DEBUG_4 = IOMUX_PAD(0x0480, 0x016C, 6, 0x0000, 0, 0), MX6Q_PAD_DI0_PIN4__PL301_PER1_HADDR_11 = IOMUX_PAD(0x0480, 0x016C, 7, 0x0000, 0, 0), - MX6Q_PAD_DISP0_DAT0__IPU1_DISP0_DAT_0 = IOMUX_PAD(0x0484, 0x0170, 0, 0x0000, 0, 0), + MX6Q_PAD_DISP0_DAT0__IPU1_DISP0_DAT_0 = IOMUX_PAD(0x0484, 0x0170, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6Q_PAD_DISP0_DAT0__IPU2_DISP0_DAT_0 = IOMUX_PAD(0x0484, 0x0170, 1, 0x0000, 0, 0), MX6Q_PAD_DISP0_DAT0__ECSPI3_SCLK = IOMUX_PAD(0x0484, 0x0170, 2, 0x0000, 0, 0), MX6Q_PAD_DISP0_DAT0__USDHC1_USDHC_DBG_0 = IOMUX_PAD(0x0484, 0x0170, 3, 0x0000, 0, 0), MX6Q_PAD_DISP0_DAT0__SDMA_DBG_CORE_RUN = IOMUX_PAD(0x0484, 0x0170, 4, 0x0000, 0, 0), MX6Q_PAD_DISP0_DAT0__GPIO_4_21 = IOMUX_PAD(0x0484, 0x0170, 5, 0x0000, 0, 0), MX6Q_PAD_DISP0_DAT0__MMDC_MMDC_DEBUG_5 = IOMUX_PAD(0x0484, 0x0170, 6, 0x0000, 0, 0), - MX6Q_PAD_DISP0_DAT1__IPU1_DISP0_DAT_1 = IOMUX_PAD(0x0488, 0x0174, 0, 0x0000, 0, 0), + MX6Q_PAD_DISP0_DAT1__IPU1_DISP0_DAT_1 = IOMUX_PAD(0x0488, 0x0174, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6Q_PAD_DISP0_DAT1__IPU2_DISP0_DAT_1 = IOMUX_PAD(0x0488, 0x0174, 1, 0x0000, 0, 0), MX6Q_PAD_DISP0_DAT1__ECSPI3_MOSI = IOMUX_PAD(0x0488, 0x0174, 2, 0x0000, 0, 0), MX6Q_PAD_DISP0_DAT1__USDHC1_USDHC_DBG_1 = IOMUX_PAD(0x0488, 0x0174, 3, 0x0000, 0, 0), @@ -582,7 +582,7 @@ enum { MX6Q_PAD_DISP0_DAT1__GPIO_4_22 = IOMUX_PAD(0x0488, 0x0174, 5, 0x0000, 0, 0), MX6Q_PAD_DISP0_DAT1__MMDC_DEBUG_6 = IOMUX_PAD(0x0488, 0x0174, 6, 0x0000, 0, 0), MX6Q_PAD_DISP0_DAT1__PL301_PER1_HADR_12 = IOMUX_PAD(0x0488, 0x0174, 7, 0x0000, 0, 0), - MX6Q_PAD_DISP0_DAT2__IPU1_DISP0_DAT_2 = IOMUX_PAD(0x048C, 0x0178, 0, 0x0000, 0, 0), + MX6Q_PAD_DISP0_DAT2__IPU1_DISP0_DAT_2 = IOMUX_PAD(0x048C, 0x0178, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6Q_PAD_DISP0_DAT2__IPU2_DISP0_DAT_2 = IOMUX_PAD(0x048C, 0x0178, 1, 0x0000, 0, 0), MX6Q_PAD_DISP0_DAT2__ECSPI3_MISO = IOMUX_PAD(0x048C, 0x0178, 2, 0x0000, 0, 0), MX6Q_PAD_DISP0_DAT2__USDHC1_USDHC_DBG_2 = IOMUX_PAD(0x048C, 0x0178, 3, 0x0000, 0, 0), @@ -590,7 +590,7 @@ enum { MX6Q_PAD_DISP0_DAT2__GPIO_4_23 = IOMUX_PAD(0x048C, 0x0178, 5, 0x0000, 0, 0), MX6Q_PAD_DISP0_DAT2__MMDC_DEBUG_7 = IOMUX_PAD(0x048C, 0x0178, 6, 0x0000, 0, 0), MX6Q_PAD_DISP0_DAT2__PL301_PER1_HADR_13 = IOMUX_PAD(0x048C, 0x0178, 7, 0x0000, 0, 0), - MX6Q_PAD_DISP0_DAT3__IPU1_DISP0_DAT_3 = IOMUX_PAD(0x0490, 0x017C, 0, 0x0000, 0, 0), + MX6Q_PAD_DISP0_DAT3__IPU1_DISP0_DAT_3 = IOMUX_PAD(0x0490, 0x017C, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6Q_PAD_DISP0_DAT3__IPU2_DISP0_DAT_3 = IOMUX_PAD(0x0490, 0x017C, 1, 0x0000, 0, 0), MX6Q_PAD_DISP0_DAT3__ECSPI3_SS0 = IOMUX_PAD(0x0490, 0x017C, 2, 0x0000, 0, 0), MX6Q_PAD_DISP0_DAT3__USDHC1_USDHC_DBG_3 = IOMUX_PAD(0x0490, 0x017C, 3, 0x0000, 0, 0), @@ -598,7 +598,7 @@ enum { MX6Q_PAD_DISP0_DAT3__GPIO_4_24 = IOMUX_PAD(0x0490, 0x017C, 5, 0x0000, 0, 0), MX6Q_PAD_DISP0_DAT3__MMDC_MMDC_DBG_8 = IOMUX_PAD(0x0490, 0x017C, 6, 0x0000, 0, 0), MX6Q_PAD_DISP0_DAT3__PL301_PER1_HADR_14 = IOMUX_PAD(0x0490, 0x017C, 7, 0x0000, 0, 0), - MX6Q_PAD_DISP0_DAT4__IPU1_DISP0_DAT_4 = IOMUX_PAD(0x0494, 0x0180, 0, 0x0000, 0, 0), + MX6Q_PAD_DISP0_DAT4__IPU1_DISP0_DAT_4 = IOMUX_PAD(0x0494, 0x0180, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6Q_PAD_DISP0_DAT4__IPU2_DISP0_DAT_4 = IOMUX_PAD(0x0494, 0x0180, 1, 0x0000, 0, 0), MX6Q_PAD_DISP0_DAT4__ECSPI3_SS1 = IOMUX_PAD(0x0494, 0x0180, 2, 0x0000, 0, 0), MX6Q_PAD_DISP0_DAT4__USDHC1_USDHC_DBG_4 = IOMUX_PAD(0x0494, 0x0180, 3, 0x0000, 0, 0), @@ -606,7 +606,7 @@ enum { MX6Q_PAD_DISP0_DAT4__GPIO_4_25 = IOMUX_PAD(0x0494, 0x0180, 5, 0x0000, 0, 0), MX6Q_PAD_DISP0_DAT4__MMDC_MMDC_DEBUG_9 = IOMUX_PAD(0x0494, 0x0180, 6, 0x0000, 0, 0), MX6Q_PAD_DISP0_DAT4__PL301_PER1_HADR_15 = IOMUX_PAD(0x0494, 0x0180, 7, 0x0000, 0, 0), - MX6Q_PAD_DISP0_DAT5__IPU1_DISP0_DAT_5 = IOMUX_PAD(0x0498, 0x0184, 0, 0x0000, 0, 0), + MX6Q_PAD_DISP0_DAT5__IPU1_DISP0_DAT_5 = IOMUX_PAD(0x0498, 0x0184, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6Q_PAD_DISP0_DAT5__IPU2_DISP0_DAT_5 = IOMUX_PAD(0x0498, 0x0184, 1, 0x0000, 0, 0), MX6Q_PAD_DISP0_DAT5__ECSPI3_SS2 = IOMUX_PAD(0x0498, 0x0184, 2, 0x0000, 0, 0), MX6Q_PAD_DISP0_DAT5__AUDMUX_AUD6_RXFS = IOMUX_PAD(0x0498, 0x0184, 3, 0x0000, 0, 0), @@ -614,7 +614,7 @@ enum { MX6Q_PAD_DISP0_DAT5__GPIO_4_26 = IOMUX_PAD(0x0498, 0x0184, 5, 0x0000, 0, 0), MX6Q_PAD_DISP0_DAT5__MMDC_DEBUG_10 = IOMUX_PAD(0x0498, 0x0184, 6, 0x0000, 0, 0), MX6Q_PAD_DISP0_DAT5__PL301_PER1_HADR_16 = IOMUX_PAD(0x0498, 0x0184, 7, 0x0000, 0, 0), - MX6Q_PAD_DISP0_DAT6__IPU1_DISP0_DAT_6 = IOMUX_PAD(0x049C, 0x0188, 0, 0x0000, 0, 0), + MX6Q_PAD_DISP0_DAT6__IPU1_DISP0_DAT_6 = IOMUX_PAD(0x049C, 0x0188, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6Q_PAD_DISP0_DAT6__IPU2_DISP0_DAT_6 = IOMUX_PAD(0x049C, 0x0188, 1, 0x0000, 0, 0), MX6Q_PAD_DISP0_DAT6__ECSPI3_SS3 = IOMUX_PAD(0x049C, 0x0188, 2, 0x0000, 0, 0), MX6Q_PAD_DISP0_DAT6__AUDMUX_AUD6_RXC = IOMUX_PAD(0x049C, 0x0188, 3, 0x0000, 0, 0), @@ -622,7 +622,7 @@ enum { MX6Q_PAD_DISP0_DAT6__GPIO_4_27 = IOMUX_PAD(0x049C, 0x0188, 5, 0x0000, 0, 0), MX6Q_PAD_DISP0_DAT6__MMDC_DEBUG_11 = IOMUX_PAD(0x049C, 0x0188, 6, 0x0000, 0, 0), MX6Q_PAD_DISP0_DAT6__PL301_PER1_HADR_17 = IOMUX_PAD(0x049C, 0x0188, 7, 0x0000, 0, 0), - MX6Q_PAD_DISP0_DAT7__IPU1_DISP0_DAT_7 = IOMUX_PAD(0x04A0, 0x018C, 0, 0x0000, 0, 0), + MX6Q_PAD_DISP0_DAT7__IPU1_DISP0_DAT_7 = IOMUX_PAD(0x04A0, 0x018C, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6Q_PAD_DISP0_DAT7__IPU2_DISP0_DAT_7 = IOMUX_PAD(0x04A0, 0x018C, 1, 0x0000, 0, 0), MX6Q_PAD_DISP0_DAT7__ECSPI3_RDY = IOMUX_PAD(0x04A0, 0x018C, 2, 0x0000, 0, 0), MX6Q_PAD_DISP0_DAT7__USDHC1_USDHC_DBG_5 = IOMUX_PAD(0x04A0, 0x018C, 3, 0x0000, 0, 0), @@ -630,7 +630,7 @@ enum { MX6Q_PAD_DISP0_DAT7__GPIO_4_28 = IOMUX_PAD(0x04A0, 0x018C, 5, 0x0000, 0, 0), MX6Q_PAD_DISP0_DAT7__MMDC_DEBUG_12 = IOMUX_PAD(0x04A0, 0x018C, 6, 0x0000, 0, 0), MX6Q_PAD_DISP0_DAT7__PL301_PER1_HADR_18 = IOMUX_PAD(0x04A0, 0x018C, 7, 0x0000, 0, 0), - MX6Q_PAD_DISP0_DAT8__IPU1_DISP0_DAT_8 = IOMUX_PAD(0x04A4, 0x0190, 0, 0x0000, 0, 0), + MX6Q_PAD_DISP0_DAT8__IPU1_DISP0_DAT_8 = IOMUX_PAD(0x04A4, 0x0190, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6Q_PAD_DISP0_DAT8__IPU2_DISP0_DAT_8 = IOMUX_PAD(0x04A4, 0x0190, 1, 0x0000, 0, 0), MX6Q_PAD_DISP0_DAT8__PWM1_PWMO = IOMUX_PAD(0x04A4, 0x0190, 2, 0x0000, 0, 0), MX6Q_PAD_DISP0_DAT8__WDOG1_WDOG_B = IOMUX_PAD(0x04A4, 0x0190, 3, 0x0000, 0, 0), @@ -638,7 +638,7 @@ enum { MX6Q_PAD_DISP0_DAT8__GPIO_4_29 = IOMUX_PAD(0x04A4, 0x0190, 5, 0x0000, 0, 0), MX6Q_PAD_DISP0_DAT8__MMDC_DEBUG_13 = IOMUX_PAD(0x04A4, 0x0190, 6, 0x0000, 0, 0), MX6Q_PAD_DISP0_DAT8__PL301_PER1_HADR_19 = IOMUX_PAD(0x04A4, 0x0190, 7, 0x0000, 0, 0), - MX6Q_PAD_DISP0_DAT9__IPU1_DISP0_DAT_9 = IOMUX_PAD(0x04A8, 0x0194, 0, 0x0000, 0, 0), + MX6Q_PAD_DISP0_DAT9__IPU1_DISP0_DAT_9 = IOMUX_PAD(0x04A8, 0x0194, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6Q_PAD_DISP0_DAT9__IPU2_DISP0_DAT_9 = IOMUX_PAD(0x04A8, 0x0194, 1, 0x0000, 0, 0), MX6Q_PAD_DISP0_DAT9__PWM2_PWMO = IOMUX_PAD(0x04A8, 0x0194, 2, 0x0000, 0, 0), MX6Q_PAD_DISP0_DAT9__WDOG2_WDOG_B = IOMUX_PAD(0x04A8, 0x0194, 3, 0x0000, 0, 0), @@ -646,41 +646,41 @@ enum { MX6Q_PAD_DISP0_DAT9__GPIO_4_30 = IOMUX_PAD(0x04A8, 0x0194, 5, 0x0000, 0, 0), MX6Q_PAD_DISP0_DAT9__MMDC_DEBUG_14 = IOMUX_PAD(0x04A8, 0x0194, 6, 0x0000, 0, 0), MX6Q_PAD_DISP0_DAT9__PL301_PER1_HADR_20 = IOMUX_PAD(0x04A8, 0x0194, 7, 0x0000, 0, 0), - MX6Q_PAD_DISP0_DAT10__IPU1_DISP0_DAT_10 = IOMUX_PAD(0x04AC, 0x0198, 0, 0x0000, 0, 0), + MX6Q_PAD_DISP0_DAT10__IPU1_DISP0_DAT_10 = IOMUX_PAD(0x04AC, 0x0198, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6Q_PAD_DISP0_DAT10__IPU2_DISP0_DAT_10 = IOMUX_PAD(0x04AC, 0x0198, 1, 0x0000, 0, 0), MX6Q_PAD_DISP0_DAT10__USDHC1_DBG_6 = IOMUX_PAD(0x04AC, 0x0198, 3, 0x0000, 0, 0), MX6Q_PAD_DISP0_DAT10__SDMA_DBG_EVT_CHN3 = IOMUX_PAD(0x04AC, 0x0198, 4, 0x0000, 0, 0), MX6Q_PAD_DISP0_DAT10__GPIO_4_31 = IOMUX_PAD(0x04AC, 0x0198, 5, 0x0000, 0, 0), MX6Q_PAD_DISP0_DAT10__MMDC_DEBUG_15 = IOMUX_PAD(0x04AC, 0x0198, 6, 0x0000, 0, 0), MX6Q_PAD_DISP0_DAT10__PL301_PER1_HADR21 = IOMUX_PAD(0x04AC, 0x0198, 7, 0x0000, 0, 0), - MX6Q_PAD_DISP0_DAT11__IPU1_DISP0_DAT_11 = IOMUX_PAD(0x04B0, 0x019C, 0, 0x0000, 0, 0), + MX6Q_PAD_DISP0_DAT11__IPU1_DISP0_DAT_11 = IOMUX_PAD(0x04B0, 0x019C, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6Q_PAD_DISP0_DAT11__IPU2_DISP0_DAT_11 = IOMUX_PAD(0x04B0, 0x019C, 1, 0x0000, 0, 0), MX6Q_PAD_DISP0_DAT11__USDHC1_USDHC_DBG7 = IOMUX_PAD(0x04B0, 0x019C, 3, 0x0000, 0, 0), MX6Q_PAD_DISP0_DAT11__SDMA_DBG_EVT_CHN4 = IOMUX_PAD(0x04B0, 0x019C, 4, 0x0000, 0, 0), MX6Q_PAD_DISP0_DAT11__GPIO_5_5 = IOMUX_PAD(0x04B0, 0x019C, 5, 0x0000, 0, 0), MX6Q_PAD_DISP0_DAT11__MMDC_DEBUG_16 = IOMUX_PAD(0x04B0, 0x019C, 6, 0x0000, 0, 0), MX6Q_PAD_DISP0_DAT11__PL301_PER1_HADR22 = IOMUX_PAD(0x04B0, 0x019C, 7, 0x0000, 0, 0), - MX6Q_PAD_DISP0_DAT12__IPU1_DISP0_DAT_12 = IOMUX_PAD(0x04B4, 0x01A0, 0, 0x0000, 0, 0), + MX6Q_PAD_DISP0_DAT12__IPU1_DISP0_DAT_12 = IOMUX_PAD(0x04B4, 0x01A0, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6Q_PAD_DISP0_DAT12__IPU2_DISP0_DAT_12 = IOMUX_PAD(0x04B4, 0x01A0, 1, 0x0000, 0, 0), MX6Q_PAD_DISP0_DAT12__RESERVED_RESERVED = IOMUX_PAD(0x04B4, 0x01A0, 3, 0x0000, 0, 0), MX6Q_PAD_DISP0_DAT12__SDMA_DBG_EVT_CHN5 = IOMUX_PAD(0x04B4, 0x01A0, 4, 0x0000, 0, 0), MX6Q_PAD_DISP0_DAT12__GPIO_5_6 = IOMUX_PAD(0x04B4, 0x01A0, 5, 0x0000, 0, 0), MX6Q_PAD_DISP0_DAT12__MMDC_DEBUG_17 = IOMUX_PAD(0x04B4, 0x01A0, 6, 0x0000, 0, 0), MX6Q_PAD_DISP0_DAT12__PL301_PER1_HADR23 = IOMUX_PAD(0x04B4, 0x01A0, 7, 0x0000, 0, 0), - MX6Q_PAD_DISP0_DAT13__IPU1_DISP0_DAT_13 = IOMUX_PAD(0x04B8, 0x01A4, 0, 0x0000, 0, 0), + MX6Q_PAD_DISP0_DAT13__IPU1_DISP0_DAT_13 = IOMUX_PAD(0x04B8, 0x01A4, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6Q_PAD_DISP0_DAT13__IPU2_DISP0_DAT_13 = IOMUX_PAD(0x04B8, 0x01A4, 1, 0x0000, 0, 0), MX6Q_PAD_DISP0_DAT13__AUDMUX_AUD5_RXFS = IOMUX_PAD(0x04B8, 0x01A4, 3, 0x07D8, 1, 0), MX6Q_PAD_DISP0_DAT13__SDMA_DBG_EVT_CHN0 = IOMUX_PAD(0x04B8, 0x01A4, 4, 0x0000, 0, 0), MX6Q_PAD_DISP0_DAT13__GPIO_5_7 = IOMUX_PAD(0x04B8, 0x01A4, 5, 0x0000, 0, 0), MX6Q_PAD_DISP0_DAT13__MMDC_DEBUG_18 = IOMUX_PAD(0x04B8, 0x01A4, 6, 0x0000, 0, 0), MX6Q_PAD_DISP0_DAT13__PL301_PER1_HADR24 = IOMUX_PAD(0x04B8, 0x01A4, 7, 0x0000, 0, 0), - MX6Q_PAD_DISP0_DAT14__IPU1_DISP0_DAT_14 = IOMUX_PAD(0x04BC, 0x01A8, 0, 0x0000, 0, 0), + MX6Q_PAD_DISP0_DAT14__IPU1_DISP0_DAT_14 = IOMUX_PAD(0x04BC, 0x01A8, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6Q_PAD_DISP0_DAT14__IPU2_DISP0_DAT_14 = IOMUX_PAD(0x04BC, 0x01A8, 1, 0x0000, 0, 0), MX6Q_PAD_DISP0_DAT14__AUDMUX_AUD5_RXC = IOMUX_PAD(0x04BC, 0x01A8, 3, 0x07D4, 1, 0), MX6Q_PAD_DISP0_DAT14__SDMA_DBG_EVT_CHN1 = IOMUX_PAD(0x04BC, 0x01A8, 4, 0x0000, 0, 0), MX6Q_PAD_DISP0_DAT14__GPIO_5_8 = IOMUX_PAD(0x04BC, 0x01A8, 5, 0x0000, 0, 0), MX6Q_PAD_DISP0_DAT14__MMDC_DEBUG_19 = IOMUX_PAD(0x04BC, 0x01A8, 6, 0x0000, 0, 0), - MX6Q_PAD_DISP0_DAT15__IPU1_DISP0_DAT_15 = IOMUX_PAD(0x04C0, 0x01AC, 0, 0x0000, 0, 0), + MX6Q_PAD_DISP0_DAT15__IPU1_DISP0_DAT_15 = IOMUX_PAD(0x04C0, 0x01AC, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6Q_PAD_DISP0_DAT15__IPU2_DISP0_DAT_15 = IOMUX_PAD(0x04C0, 0x01AC, 1, 0x0000, 0, 0), MX6Q_PAD_DISP0_DAT15__ECSPI1_SS1 = IOMUX_PAD(0x04C0, 0x01AC, 2, 0x0804, 1, 0), MX6Q_PAD_DISP0_DAT15__ECSPI2_SS1 = IOMUX_PAD(0x04C0, 0x01AC, 3, 0x0820, 1, 0), @@ -688,7 +688,7 @@ enum { MX6Q_PAD_DISP0_DAT15__GPIO_5_9 = IOMUX_PAD(0x04C0, 0x01AC, 5, 0x0000, 0, 0), MX6Q_PAD_DISP0_DAT15__MMDC_DEBUG_20 = IOMUX_PAD(0x04C0, 0x01AC, 6, 0x0000, 0, 0), MX6Q_PAD_DISP0_DAT15__PL301_PER1_HADR25 = IOMUX_PAD(0x04C0, 0x01AC, 7, 0x0000, 0, 0), - MX6Q_PAD_DISP0_DAT16__IPU1_DISP0_DAT_16 = IOMUX_PAD(0x04C4, 0x01B0, 0, 0x0000, 0, 0), + MX6Q_PAD_DISP0_DAT16__IPU1_DISP0_DAT_16 = IOMUX_PAD(0x04C4, 0x01B0, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6Q_PAD_DISP0_DAT16__IPU2_DISP0_DAT_16 = IOMUX_PAD(0x04C4, 0x01B0, 1, 0x0000, 0, 0), MX6Q_PAD_DISP0_DAT16__ECSPI2_MOSI = IOMUX_PAD(0x04C4, 0x01B0, 2, 0x0818, 1, 0), MX6Q_PAD_DISP0_DAT16__AUDMUX_AUD5_TXC = IOMUX_PAD(0x04C4, 0x01B0, 3, 0x07DC, 0, 0), @@ -696,7 +696,7 @@ enum { MX6Q_PAD_DISP0_DAT16__GPIO_5_10 = IOMUX_PAD(0x04C4, 0x01B0, 5, 0x0000, 0, 0), MX6Q_PAD_DISP0_DAT16__MMDC_DEBUG_21 = IOMUX_PAD(0x04C4, 0x01B0, 6, 0x0000, 0, 0), MX6Q_PAD_DISP0_DAT16__PL301_PER1_HADR26 = IOMUX_PAD(0x04C4, 0x01B0, 7, 0x0000, 0, 0), - MX6Q_PAD_DISP0_DAT17__IPU1_DISP0_DAT_17 = IOMUX_PAD(0x04C8, 0x01B4, 0, 0x0000, 0, 0), + MX6Q_PAD_DISP0_DAT17__IPU1_DISP0_DAT_17 = IOMUX_PAD(0x04C8, 0x01B4, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6Q_PAD_DISP0_DAT17__IPU2_DISP0_DAT_17 = IOMUX_PAD(0x04C8, 0x01B4, 1, 0x0000, 0, 0), MX6Q_PAD_DISP0_DAT17__ECSPI2_MISO = IOMUX_PAD(0x04C8, 0x01B4, 2, 0x0814, 1, 0), MX6Q_PAD_DISP0_DAT17__AUDMUX_AUD5_TXD = IOMUX_PAD(0x04C8, 0x01B4, 3, 0x07D0, 0, 0), @@ -704,7 +704,7 @@ enum { MX6Q_PAD_DISP0_DAT17__GPIO_5_11 = IOMUX_PAD(0x04C8, 0x01B4, 5, 0x0000, 0, 0), MX6Q_PAD_DISP0_DAT17__MMDC_DEBUG_22 = IOMUX_PAD(0x04C8, 0x01B4, 6, 0x0000, 0, 0), MX6Q_PAD_DISP0_DAT17__PL301_PER1_HADR27 = IOMUX_PAD(0x04C8, 0x01B4, 7, 0x0000, 0, 0), - MX6Q_PAD_DISP0_DAT18__IPU1_DISP0_DAT_18 = IOMUX_PAD(0x04CC, 0x01B8, 0, 0x0000, 0, 0), + MX6Q_PAD_DISP0_DAT18__IPU1_DISP0_DAT_18 = IOMUX_PAD(0x04CC, 0x01B8, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6Q_PAD_DISP0_DAT18__IPU2_DISP0_DAT_18 = IOMUX_PAD(0x04CC, 0x01B8, 1, 0x0000, 0, 0), MX6Q_PAD_DISP0_DAT18__ECSPI2_SS0 = IOMUX_PAD(0x04CC, 0x01B8, 2, 0x081C, 1, 0), MX6Q_PAD_DISP0_DAT18__AUDMUX_AUD5_TXFS = IOMUX_PAD(0x04CC, 0x01B8, 3, 0x07E0, 0, 0), @@ -712,7 +712,7 @@ enum { MX6Q_PAD_DISP0_DAT18__GPIO_5_12 = IOMUX_PAD(0x04CC, 0x01B8, 5, 0x0000, 0, 0), MX6Q_PAD_DISP0_DAT18__MMDC_DEBUG_23 = IOMUX_PAD(0x04CC, 0x01B8, 6, 0x0000, 0, 0), MX6Q_PAD_DISP0_DAT18__WEIM_WEIM_CS_2 = IOMUX_PAD(0x04CC, 0x01B8, 7, 0x0000, 0, 0), - MX6Q_PAD_DISP0_DAT19__IPU1_DISP0_DAT_19 = IOMUX_PAD(0x04D0, 0x01BC, 0, 0x0000, 0, 0), + MX6Q_PAD_DISP0_DAT19__IPU1_DISP0_DAT_19 = IOMUX_PAD(0x04D0, 0x01BC, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6Q_PAD_DISP0_DAT19__IPU2_DISP0_DAT_19 = IOMUX_PAD(0x04D0, 0x01BC, 1, 0x0000, 0, 0), MX6Q_PAD_DISP0_DAT19__ECSPI2_SCLK = IOMUX_PAD(0x04D0, 0x01BC, 2, 0x0810, 1, 0), MX6Q_PAD_DISP0_DAT19__AUDMUX_AUD5_RXD = IOMUX_PAD(0x04D0, 0x01BC, 3, 0x07CC, 0, 0), @@ -720,7 +720,7 @@ enum { MX6Q_PAD_DISP0_DAT19__GPIO_5_13 = IOMUX_PAD(0x04D0, 0x01BC, 5, 0x0000, 0, 0), MX6Q_PAD_DISP0_DAT19__MMDC_DEBUG_24 = IOMUX_PAD(0x04D0, 0x01BC, 6, 0x0000, 0, 0), MX6Q_PAD_DISP0_DAT19__WEIM_WEIM_CS_3 = IOMUX_PAD(0x04D0, 0x01BC, 7, 0x0000, 0, 0), - MX6Q_PAD_DISP0_DAT20__IPU1_DISP0_DAT_20 = IOMUX_PAD(0x04D4, 0x01C0, 0, 0x0000, 0, 0), + MX6Q_PAD_DISP0_DAT20__IPU1_DISP0_DAT_20 = IOMUX_PAD(0x04D4, 0x01C0, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6Q_PAD_DISP0_DAT20__IPU2_DISP0_DAT_20 = IOMUX_PAD(0x04D4, 0x01C0, 1, 0x0000, 0, 0), MX6Q_PAD_DISP0_DAT20__ECSPI1_SCLK = IOMUX_PAD(0x04D4, 0x01C0, 2, 0x07F4, 1, 0), MX6Q_PAD_DISP0_DAT20__AUDMUX_AUD4_TXC = IOMUX_PAD(0x04D4, 0x01C0, 3, 0x07C4, 0, 0), @@ -728,7 +728,7 @@ enum { MX6Q_PAD_DISP0_DAT20__GPIO_5_14 = IOMUX_PAD(0x04D4, 0x01C0, 5, 0x0000, 0, 0), MX6Q_PAD_DISP0_DAT20__MMDC_DEBUG_25 = IOMUX_PAD(0x04D4, 0x01C0, 6, 0x0000, 0, 0), MX6Q_PAD_DISP0_DAT20__PL301_PER1_HADR28 = IOMUX_PAD(0x04D4, 0x01C0, 7, 0x0000, 0, 0), - MX6Q_PAD_DISP0_DAT21__IPU1_DISP0_DAT_21 = IOMUX_PAD(0x04D8, 0x01C4, 0, 0x0000, 0, 0), + MX6Q_PAD_DISP0_DAT21__IPU1_DISP0_DAT_21 = IOMUX_PAD(0x04D8, 0x01C4, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6Q_PAD_DISP0_DAT21__IPU2_DISP0_DAT_21 = IOMUX_PAD(0x04D8, 0x01C4, 1, 0x0000, 0, 0), MX6Q_PAD_DISP0_DAT21__ECSPI1_MOSI = IOMUX_PAD(0x04D8, 0x01C4, 2, 0x07FC, 1, 0), MX6Q_PAD_DISP0_DAT21__AUDMUX_AUD4_TXD = IOMUX_PAD(0x04D8, 0x01C4, 3, 0x07B8, 1, 0), @@ -736,7 +736,7 @@ enum { MX6Q_PAD_DISP0_DAT21__GPIO_5_15 = IOMUX_PAD(0x04D8, 0x01C4, 5, 0x0000, 0, 0), MX6Q_PAD_DISP0_DAT21__MMDC_DEBUG_26 = IOMUX_PAD(0x04D8, 0x01C4, 6, 0x0000, 0, 0), MX6Q_PAD_DISP0_DAT21__PL301_PER1_HADR29 = IOMUX_PAD(0x04D8, 0x01C4, 7, 0x0000, 0, 0), - MX6Q_PAD_DISP0_DAT22__IPU1_DISP0_DAT_22 = IOMUX_PAD(0x04DC, 0x01C8, 0, 0x0000, 0, 0), + MX6Q_PAD_DISP0_DAT22__IPU1_DISP0_DAT_22 = IOMUX_PAD(0x04DC, 0x01C8, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6Q_PAD_DISP0_DAT22__IPU2_DISP0_DAT_22 = IOMUX_PAD(0x04DC, 0x01C8, 1, 0x0000, 0, 0), MX6Q_PAD_DISP0_DAT22__ECSPI1_MISO = IOMUX_PAD(0x04DC, 0x01C8, 2, 0x07F8, 1, 0), MX6Q_PAD_DISP0_DAT22__AUDMUX_AUD4_TXFS = IOMUX_PAD(0x04DC, 0x01C8, 3, 0x07C8, 1, 0), @@ -744,7 +744,7 @@ enum { MX6Q_PAD_DISP0_DAT22__GPIO_5_16 = IOMUX_PAD(0x04DC, 0x01C8, 5, 0x0000, 0, 0), MX6Q_PAD_DISP0_DAT22__MMDC_DEBUG_27 = IOMUX_PAD(0x04DC, 0x01C8, 6, 0x0000, 0, 0), MX6Q_PAD_DISP0_DAT22__PL301_PER1_HADR30 = IOMUX_PAD(0x04DC, 0x01C8, 7, 0x0000, 0, 0), - MX6Q_PAD_DISP0_DAT23__IPU1_DISP0_DAT_23 = IOMUX_PAD(0x04E0, 0x01CC, 0, 0x0000, 0, 0), + MX6Q_PAD_DISP0_DAT23__IPU1_DISP0_DAT_23 = IOMUX_PAD(0x04E0, 0x01CC, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), MX6Q_PAD_DISP0_DAT23__IPU2_DISP0_DAT_23 = IOMUX_PAD(0x04E0, 0x01CC, 1, 0x0000, 0, 0), MX6Q_PAD_DISP0_DAT23__ECSPI1_SS0 = IOMUX_PAD(0x04E0, 0x01CC, 2, 0x0800, 1, 0), MX6Q_PAD_DISP0_DAT23__AUDMUX_AUD4_RXD = IOMUX_PAD(0x04E0, 0x01CC, 3, 0x07B4, 1, 0),
Signed-off-by: Eric Nelson eric.nelson@boundarydevices.com --- drivers/video/mxc_ipuv3_fb.c | 20 ++++++++++++++++++++ include/ipu_pixfmt.h | 1 + 2 files changed, 21 insertions(+), 0 deletions(-)
diff --git a/drivers/video/mxc_ipuv3_fb.c b/drivers/video/mxc_ipuv3_fb.c index c38e22d..47b336e 100644 --- a/drivers/video/mxc_ipuv3_fb.c +++ b/drivers/video/mxc_ipuv3_fb.c @@ -38,6 +38,7 @@ #include "videomodes.h" #include "ipu.h" #include "mxcfb.h" +#include "ipu_regs.h"
static int mxcfb_map_video_memory(struct fb_info *fbi); static int mxcfb_unmap_video_memory(struct fb_info *fbi); @@ -576,6 +577,25 @@ err0: return ret; }
+void ipuv3_fb_shutdown(void) +{ + int i; + struct ipu_stat *stat = (struct ipu_stat *)IPU_STAT; + + for (i = 0; i < ARRAY_SIZE(mxcfb_info); i++) { + struct fb_info *fbi = mxcfb_info[i]; + if (fbi) { + struct mxcfb_info *mxc_fbi = fbi->par; + ipu_disable_channel(mxc_fbi->ipu_ch); + ipu_uninit_channel(mxc_fbi->ipu_ch); + } + } + for (i = 0; i < ARRAY_SIZE(stat->int_stat); i++) { + __raw_writel(__raw_readl(&stat->int_stat[i]), + &stat->int_stat[i]); + } +} + void *video_hw_init(void) { int ret; diff --git a/include/ipu_pixfmt.h b/include/ipu_pixfmt.h index 0019898..4baa711 100644 --- a/include/ipu_pixfmt.h +++ b/include/ipu_pixfmt.h @@ -77,5 +77,6 @@ #define IPU_PIX_FMT_YUV422P fourcc('4', '2', '2', 'P') /*< 16 YUV 4:2:2 */
int ipuv3_fb_init(struct fb_videomode *mode, uint8_t disp, uint32_t pixfmt); +void ipuv3_fb_shutdown(void);
#endif
On 09/21/2012 01:56 PM, Eric Nelson wrote:
Signed-off-by: Eric Nelsoneric.nelson@boundarydevices.com
- int i;
- struct ipu_stat *stat = (struct ipu_stat *)IPU_STAT;
- for (i = 0; i< ARRAY_SIZE(mxcfb_info); i++) {
if (fbi) {
- for (i = 0; i< ARRAY_SIZE(stat->int_stat); i++) {
- void *video_hw_init(void) { int ret;
#endif
Sorry. This is a duplicate of a prior e-mail.
Signed-off-by: Eric Nelson eric.nelson@boundarydevices.com --- arch/arm/imx-common/Makefile | 1 + arch/arm/imx-common/preboot_os.c | 34 ++++++++++++++++++++++++++++++++++ 2 files changed, 35 insertions(+), 0 deletions(-) create mode 100644 arch/arm/imx-common/preboot_os.c
diff --git a/arch/arm/imx-common/Makefile b/arch/arm/imx-common/Makefile index b3e608e..31dc52e 100644 --- a/arch/arm/imx-common/Makefile +++ b/arch/arm/imx-common/Makefile @@ -32,6 +32,7 @@ COBJS-y = iomux-v3.o timer.o cpu.o speed.o COBJS-$(CONFIG_I2C_MXC) += i2c-mxv7.o endif COBJS-$(CONFIG_CMD_BMODE) += cmd_bmode.o +COBJS-y += preboot_os.o COBJS := $(sort $(COBJS-y))
SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) diff --git a/arch/arm/imx-common/preboot_os.c b/arch/arm/imx-common/preboot_os.c new file mode 100644 index 0000000..ed7a9e0 --- /dev/null +++ b/arch/arm/imx-common/preboot_os.c @@ -0,0 +1,34 @@ +/* + * Copyright (C) 2012 Boundary Devices Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#include <common.h> + +#if defined(CONFIG_VIDEO_IPUV3) +#include <ipu_pixfmt.h> +#endif + +void arch_preboot_os(void) +{ +#if defined(CONFIG_VIDEO_IPUV3) + /* disable video before launching O/S */ + ipuv3_fb_shutdown(); +#endif +}
- Copyright (C) 2012 Boundary Devices Inc.
- project.
- MA 02111-1307 USA
+#include<common.h>
+#if defined(CONFIG_VIDEO_IPUV3) +#include<ipu_pixfmt.h> +#endif
- /* disable video before launching O/S */
- ipuv3_fb_shutdown();
+#endif +}
Sorry. This is also a duplicate of a prior e-mail.
Eric Nelson
