[PATCH] cpsw_mdio.c: Use correct reg in cpsw_mdio_get_alive
cpsw_mdio_get_alive reads the wrong register. See page 2316 in SPRUH73Q AM335x TRM
Signed-off-by: Ulf Samuelsson ulf@emagii.com Cc: Joe Hershberger joe.hershberger@ni.com Cc: Ramon Fried rfried.dev@gmail.com --- drivers/net/ti/cpsw_mdio.c | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/drivers/net/ti/cpsw_mdio.c b/drivers/net/ti/cpsw_mdio.c index a5ba73b739..ac791faa81 100644 --- a/drivers/net/ti/cpsw_mdio.c +++ b/drivers/net/ti/cpsw_mdio.c @@ -51,7 +51,7 @@ struct cpsw_mdio_regs { #define USERACCESS_PHY_REG_SHIFT (21) #define USERACCESS_PHY_ADDR_SHIFT (16) #define USERACCESS_DATA GENMASK(15, 0) - } user[0]; + } user[2]; };
#define CPSW_MDIO_DIV_DEF 0xff @@ -366,8 +366,8 @@ u32 cpsw_mdio_get_alive(struct mii_dev *bus) struct cpsw_mdio *mdio = bus->priv; u32 val;
- val = readl(&mdio->regs->control); - return val & GENMASK(15, 0); + val = readl(&mdio->regs->alive); + return val & GENMASK(7, 0); }
struct mii_dev *cpsw_mdio_init(const char *name, phys_addr_t mdio_base,
Hello Ulf,
- } user[0];
- } user[2];
- val = readl(&mdio->regs->alive);
- return val & GENMASK(7, 0);
Referring to the TRM for AM335x at [0], on page 2401, the MDIOALIVE register reports the presence of Ethernet PHYs up to ADDR 31. Also, the cpsw driver: drivers/net/ti/cpsw.c which uses the cpsw_mdio_get_alive() function, expects the return value to be a 16 bit value. Therefore, I believe that the GENMASK should retain the previous value of "GENMASK(15, 0)", while only the register being read needs to be changed from "control" to "alive". Please let me know if I misunderstood something regarding your implementation.
[0] https://www.ti.com/lit/ug/spruh73q/spruh73q.pdf
Regards, Siddharth.
Den 2023-02-09 kl. 08:29, skrev Siddharth Vadapalli:
Hello Ulf,
- } user[0];
} user[2]; };
We had an unusual H/W where the PHY (actually a switch) was connected to the second Ethernet port. All boards I have seen have the PHY connected to the first port or have both ports connected.
IIRC correctly (this patch is > 2 years old), we had bad data in the bits (15:8) and this is why only the 8 bits. Only bits [1:0] are used anyway.
Regards, Siddharth.
Best Regards Ulf Samuelsson
Hello Ulf,
diff --git a/drivers/net/ti/cpsw_mdio.c b/drivers/net/ti/cpsw_mdio.c index a5ba73b739..ac791faa81 100644 --- a/drivers/net/ti/cpsw_mdio.c +++ b/drivers/net/ti/cpsw_mdio.c @@ -51,7 +51,7 @@ struct cpsw_mdio_regs { #define USERACCESS_PHY_REG_SHIFT (21) #define USERACCESS_PHY_ADDR_SHIFT (16) #define USERACCESS_DATA GENMASK(15, 0) - } user[0]; + } user[2]; }; #define CPSW_MDIO_DIV_DEF 0xff @@ -366,8 +366,8 @@ u32 cpsw_mdio_get_alive(struct mii_dev *bus) struct cpsw_mdio *mdio = bus->priv; u32 val; - val = readl(&mdio->regs->control); - return val & GENMASK(15, 0); + val = readl(&mdio->regs->alive); + return val & GENMASK(7, 0);
Thank you for clarifying.
Reviewed-by: Siddharth Vadapalli s-vadapalli@ti.com
Regards, Siddharth.
Signed-off-by: Ulf Samuelsson ulf@emagii.com Cc: Joe Hershberger joe.hershberger@ni.com Cc: Ramon Fried rfried.dev@gmail.com Reviewed-by: Siddharth Vadapalli s-vadapalli@ti.com
Siddharth Vadapalli
Ulf Samuelsson
Ulf Samuelsson
