[PATCH 0/2] v2: rr3188: change APP to 600MHz and enable bwadj for DPLL
Hello! Here are two patches I found usefull for rk3188.
Changes in v2: Add u-boot@lists.denx.de as addressee.
Alexander Kochetkov (2): rockchip: clk: rk3188: change APLL to safe 600MHz rockchip: clk: rk3188: enable bwadj for rk3188 DPLL
drivers/clk/rockchip/clk_rk3188.c | 11 ++++++----- 1 file changed, 6 insertions(+), 5 deletions(-)
The commit 84a6a27ae3ff ("rockchip: rk3188: init CPU freq in clock driver") changed ARM clock from 600MHz to 1600MHz. It made boot unstable due to the fact that PMIC at the start generates insufficient voltage for operation. See also: commit f4f57c58b589 ("rockchip: rk3188: Setup the armclk in spl").
Fixes commit 84a6a27ae3ff ("rockchip: rk3188: init CPU freq in clock driver").
Signed-off-by: Alexander Kochetkov al.kochet@gmail.com --- drivers/clk/rockchip/clk_rk3188.c | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/drivers/clk/rockchip/clk_rk3188.c b/drivers/clk/rockchip/clk_rk3188.c index b193ac913e..4fc5c78563 100644 --- a/drivers/clk/rockchip/clk_rk3188.c +++ b/drivers/clk/rockchip/clk_rk3188.c @@ -564,7 +564,8 @@ static int rk3188_clk_probe(struct udevice *dev) rkclk_init(priv->cru, priv->grf, priv->has_bwadj);
/* Init CPU frequency */ - rkclk_configure_cpu(priv->cru, priv->grf, APLL_HZ, priv->has_bwadj); + rkclk_configure_cpu(priv->cru, priv->grf, APLL_SAFE_HZ, + priv->has_bwadj); #endif
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
priv->has_bwadj);
#endif
Empirically, I found that DPLL on rk3188 has bwadj registers. Configuring DPLL with bwadj increase DPLL stability. Because of DPLL provide clock for ethernet, enabling bwaj reduces the number of errors on the ethernet.
Signed-off-by: Alexander Kochetkov al.kochet@gmail.com --- drivers/clk/rockchip/clk_rk3188.c | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/drivers/clk/rockchip/clk_rk3188.c b/drivers/clk/rockchip/clk_rk3188.c index 4fc5c78563..ee5782d25d 100644 --- a/drivers/clk/rockchip/clk_rk3188.c +++ b/drivers/clk/rockchip/clk_rk3188.c @@ -117,7 +117,7 @@ static int rkclk_set_pll(struct rk3188_cru *cru, enum rk_clk_id clk_id, }
static int rkclk_configure_ddr(struct rk3188_cru *cru, struct rk3188_grf *grf, - unsigned int hz, bool has_bwadj) + unsigned int hz) { static const struct pll_div dpll_cfg[] = { {.nf = 75, .nr = 1, .no = 6}, @@ -149,7 +149,8 @@ static int rkclk_configure_ddr(struct rk3188_cru *cru, struct rk3188_grf *grf, rk_clrsetreg(&cru->cru_mode_con, DPLL_MODE_MASK << DPLL_MODE_SHIFT, DPLL_MODE_SLOW << DPLL_MODE_SHIFT);
- rkclk_set_pll(cru, CLK_DDR, &dpll_cfg[cfg], has_bwadj); + /* rk3188 and rk3188a DPLL has bwadj */ + rkclk_set_pll(cru, CLK_DDR, &dpll_cfg[cfg], 1);
/* wait for pll lock */ while (!(readl(&grf->soc_status0) & SOCSTS_DPLL_LOCK)) @@ -504,8 +505,7 @@ static ulong rk3188_clk_set_rate(struct clk *clk, ulong rate) priv->has_bwadj); break; case CLK_DDR: - new_rate = rkclk_configure_ddr(priv->cru, priv->grf, rate, - priv->has_bwadj); + new_rate = rkclk_configure_ddr(priv->cru, priv->grf, rate); break; case HCLK_EMMC: case HCLK_SDMMC:
Hi Alex,
I think it will be better to update the rk3188_clk_probe() function instead of
what you have modified if the RK3188 and RK3188A has the same PLL(I'm not sure
about it now).
Thanks,
- Kever
{ static const struct pll_div dpll_cfg[] = { {.nf = 75, .nr = 1, .no = 6},unsigned int hz)
priv->has_bwadj);
break; case HCLK_EMMC: case HCLK_SDMMC:new_rate = rkclk_configure_ddr(priv->cru, priv->grf, rate);
Hi Kever,
Strange… Then I tested a year ago I saw, that writing into bwadj registers had no effect for some PLLs. But now I did another test. See patch and output. Looks like rk3188 allow writing into bwadj fields.
So I do something like 'priv->has_bwadj = 1' in the rk3188_clk_probe() and send try 2.
-------------------------------------- --- a/drivers/clk/rockchip/clk_rk3188.c +++ b/drivers/clk/rockchip/clk_rk3188.c @@ -91,7 +91,7 @@ static int rkclk_set_pll(struct rk3188_cru *cru, enum rk_clk_id clk_id, uint vco_hz = OSC_HZ / 1000 * div->nf / div->nr * 1000; uint output_hz = vco_hz / div->no;
- debug("PLL at %x: nf=%d, nr=%d, no=%d, vco=%u Hz, output=%u Hz\n", + printf("PLL at %x: nf=%d, nr=%d, no=%d, vco=%u Hz, output=%u Hz\n", (uint)pll, div->nf, div->nr, div->no, vco_hz, output_hz); assert(vco_hz >= VCO_MIN_HZ && vco_hz <= VCO_MAX_HZ && output_hz >= OUTPUT_MIN_HZ && output_hz <= OUTPUT_MAX_HZ && @@ -105,8 +105,12 @@ static int rkclk_set_pll(struct rk3188_cru *cru, enum rk_clk_id clk_id, ((div->nr - 1) << CLKR_SHIFT) | (div->no - 1)); rk_clrsetreg(&pll->con1, CLKF_MASK, div->nf - 1);
- if (has_bwadj) + if (has_bwadj) { + printf("before: %p: con2=%x, clr=%x, set=%x\n", + &pll->con2, readl(&pll->con2), PLL_BWADJ_MASK, (div->nf >> 1) - 1); rk_clrsetreg(&pll->con2, PLL_BWADJ_MASK, (div->nf >> 1) - 1); + printf("after: %p: con2=%x\n", &pll->con2, readl(&pll->con2)); + }
udelay(10);
@@ -552,7 +556,9 @@ static int rk3188_clk_probe(struct udevice *dev) priv->grf = syscon_get_first_range(ROCKCHIP_SYSCON_GRF); if (IS_ERR(priv->grf)) return PTR_ERR(priv->grf); - priv->has_bwadj = (type == RK3188A_CRU) ? 1 : 0; + printf("type %d\n", type); + //priv->has_bwadj = (type == RK3188A_CRU) ? 1 : 0; + priv->has_bwadj = 1; ————————————————————— type 0 PLL at 20000030: nf=64, nr=1, no=2, vco=1536000000 Hz, output=768000000 Hz before: 20000038: con2=94, clr=fff, set=1f after: 20000038: con2=1f PLL at 20000020: nf=32, nr=1, no=2, vco=768000000 Hz, output=384000000 Hz before: 20000028: con2=63, clr=fff, set=f after: 20000028: con2=f PLL at 20000000: nf=50, nr=1, no=2, vco=1200000000 Hz, output=600000000 Hz before: 20000008: con2=18, clr=fff, set=18 after: 20000008: con2=18 PLL at 20000010: nf=75, nr=1, no=4, vco=1800000000 Hz, output=450000000 Hz before: 20000018: con2=10b, clr=fff, set=24 after: 20000018: con2=24
27 июня 2020 г., в 18:17, Kever Yang kever.yang@rock-chips.com написал(а):
Hi Alex,
about it now).
Thanks,
- Kever
diff --git a/drivers/clk/rockchip/clk_rk3188.c b/drivers/clk/rockchip/clk_rk3188.c index 4fc5c78563..ee5782d25d 100644 --- a/drivers/clk/rockchip/clk_rk3188.c +++ b/drivers/clk/rockchip/clk_rk3188.c @@ -117,7 +117,7 @@ static int rkclk_set_pll(struct rk3188_cru *cru, enum rk_clk_id clk_id, } static int rkclk_configure_ddr(struct rk3188_cru *cru, struct rk3188_grf *grf,
unsigned int hz)
- /* rk3188 and rk3188a DPLL has bwadj */
- rkclk_set_pll(cru, CLK_DDR, &dpll_cfg[cfg], 1); /* wait for pll lock */ while (!(readl(&grf->soc_status0) & SOCSTS_DPLL_LOCK))
priv->has_bwadj);
Alexander Kochetkov
Kever Yang
