[U-Boot] [PATCH 0/2] fix flash_get_info function
These series patch correct the behaviour of flash_get_info() function defined in drivers/mtd/cfi_flash.c
I separated a cosmetic change in the first patch.
Masahiro Yamada (2): cosmetic: cfi_flash: delete a space after an unary operator cfi_flash: return NULL for invalid base address input
drivers/mtd/cfi_flash.c | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
Linux Kernel Documentation/CodingStyle says: Do not add a space after unary operators such as &, *, ...
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com --- drivers/mtd/cfi_flash.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/mtd/cfi_flash.c b/drivers/mtd/cfi_flash.c index 22d8440..6dd47b4 100644 --- a/drivers/mtd/cfi_flash.c +++ b/drivers/mtd/cfi_flash.c @@ -186,7 +186,7 @@ flash_info_t *flash_get_info(ulong base) flash_info_t *info = NULL;
for (i = 0; i < CONFIG_SYS_MAX_FLASH_BANKS; i++) { - info = & flash_info[i]; + info = &flash_info[i]; if (info->size && info->start[0] <= base && base <= info->start[0] + info->size - 1) break;
Applied to u-boot-cfi-flash/master.
Thanks, Stefan
When base address given was out of valid flash address ranges, flash_get_info() function returned the pointer to the last element of flash_info[i] array.
This patch changes this function to return NULL pointer in such a case, which is more correct behaviour.
The function flash_protect_default() calls flash_protect() immediately after flash_get_info() invocation. With this correction, flash_protect() function would be able to return soon, for NULL flash_info.
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com --- drivers/mtd/cfi_flash.c | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/drivers/mtd/cfi_flash.c b/drivers/mtd/cfi_flash.c index 6dd47b4..ac8318a 100644 --- a/drivers/mtd/cfi_flash.c +++ b/drivers/mtd/cfi_flash.c @@ -183,16 +183,16 @@ u64 flash_read64(void *addr)__attribute__((weak, alias("__flash_read64"))); flash_info_t *flash_get_info(ulong base) { int i; - flash_info_t *info = NULL; + flash_info_t *info;
for (i = 0; i < CONFIG_SYS_MAX_FLASH_BANKS; i++) { info = &flash_info[i]; if (info->size && info->start[0] <= base && base <= info->start[0] + info->size - 1) - break; + return info; }
- return info; + return NULL; } #endif
Thanks, Stefan
Masahiro Yamada
Stefan Roese
