Pull request for efi-2022-04-rc6
Dear Tom,
The following changes since commit 64b78f5721e65e96ea5a3d100d46b2e6fda722df:
Merge branch '2022-03-31-critical-fixes' (2022-03-31 08:28:43 -0400)
https://source.denx.de/u-boot/custodians/u-boot-efi.git tags/efi-2022-04-rc6
for you to fetch changes up to b6370aca3709ef23a9e8fe556beaa2e4b4e089c3:
efi_loader: initrddump: Actually use the custom CFLAGS (2022-03-31 19:06:17 +0200)
No problems were reported by Gitlab CI:
https://source.denx.de/u-boot/custodians/u-boot-efi/-/pipelines/11531
---------------------------------------------------------------- Pull request for efi-2022-04-rc6
Documentation:
* Move VxWorks and Plan 9 to HTML documentation * Move all command man-pages to a separate directory
Test:
* Fix pylint errors
UEFI
* Fix build flags for initrddump.efi
QEMU
* Remove unused function to get RNG device
---------------------------------------------------------------- Andy Shevchenko (1): efi_loader: initrddump: Actually use the custom CFLAGS
Bin Meng (5): doc: usage: Group all shell command docs into cmd/ sub-directory doc: usage: Update the extension command title doc: usage: Convert README.vxworks to reST doc: usage: Update vxworks doc to mention RISC-V support doc: usage: Convert README.plan9 to reST
Heinrich Schuchardt (2): test: fix pylint warnings for test_efi_fit.py test: fix pylint warnings in test_efi_bootmgr
Patrick Delaunay (1): doc: mmc dev
Sughosh Ganu (1): qemu: arm: Remove platform specific function to get RNG device
board/emulation/qemu-arm/qemu-arm.c | 42 ------------ doc/usage/{ => cmd}/acpi.rst | 0 doc/usage/{ => cmd}/addrmap.rst | 0 doc/usage/{ => cmd}/askenv.rst | 0 doc/usage/{ => cmd}/base.rst | 0 doc/usage/{ => cmd}/bootefi.rst | 0 doc/usage/{ => cmd}/booti.rst | 0 doc/usage/{ => cmd}/bootmenu.rst | 0 doc/usage/{ => cmd}/button.rst | 0 doc/usage/{x86 => cmd}/cbsysinfo.rst | 0 doc/usage/{ => cmd}/conitrace.rst | 0 doc/usage/{ => cmd}/echo.rst | 0 doc/usage/{ => cmd}/exception.rst | 0 doc/usage/{ => cmd}/exit.rst | 0 doc/usage/{ => cmd}/extension.rst | 4 +- doc/usage/{ => cmd}/false.rst | 0 doc/usage/{ => cmd}/fatinfo.rst | 0 doc/usage/{ => cmd}/fatload.rst | 0 doc/usage/{ => cmd}/for.rst | 0 doc/usage/{ => cmd}/load.rst | 0 doc/usage/{ => cmd}/loady.rst | 0 doc/usage/{ => cmd}/mbr.rst | 0 doc/usage/{ => cmd}/md.rst | 2 - doc/usage/{ => cmd}/mmc.rst | 36 +++++----- doc/usage/{ => cmd}/pinmux.rst | 0 doc/usage/{ => cmd}/pstore.rst | 0 doc/usage/{ => cmd}/qfw.rst | 0 doc/usage/{ => cmd}/reset.rst | 0 doc/usage/{ => cmd}/sbi.rst | 0 doc/usage/{ => cmd}/scp03.rst | 0 doc/usage/{ => cmd}/setexpr.rst | 0 doc/usage/{ => cmd}/sf.rst | 0 doc/usage/{ => cmd}/size.rst | 0 doc/usage/{ => cmd}/true.rst | 0 doc/usage/{ => cmd}/ums.rst | 0 doc/usage/{ => cmd}/wdt.rst | 0 doc/usage/index.rst | 79 ++++++++++++---------- doc/{README.plan9 => usage/os/plan9.rst} | 12 ++-- doc/{README.vxworks => usage/os/vxworks.rst} | 31 ++++++--- lib/efi_loader/Makefile | 2 +- test/py/tests/test_efi_bootmgr/conftest.py | 14 ++-- test/py/tests/test_efi_bootmgr/test_efi_bootmgr.py | 13 +++- test/py/tests/test_efi_fit.py | 31 +++++---- 43 files changed, 129 insertions(+), 137 deletions(-) rename doc/usage/{ => cmd}/acpi.rst (100%) rename doc/usage/{ => cmd}/addrmap.rst (100%) rename doc/usage/{ => cmd}/askenv.rst (100%) rename doc/usage/{ => cmd}/base.rst (100%) rename doc/usage/{ => cmd}/bootefi.rst (100%) rename doc/usage/{ => cmd}/booti.rst (100%) rename doc/usage/{ => cmd}/bootmenu.rst (100%) rename doc/usage/{ => cmd}/button.rst (100%) rename doc/usage/{x86 => cmd}/cbsysinfo.rst (100%) rename doc/usage/{ => cmd}/conitrace.rst (100%) rename doc/usage/{ => cmd}/echo.rst (100%) rename doc/usage/{ => cmd}/exception.rst (100%) rename doc/usage/{ => cmd}/exit.rst (100%) rename doc/usage/{ => cmd}/extension.rst (96%) rename doc/usage/{ => cmd}/false.rst (100%) rename doc/usage/{ => cmd}/fatinfo.rst (100%) rename doc/usage/{ => cmd}/fatload.rst (100%) rename doc/usage/{ => cmd}/for.rst (100%) rename doc/usage/{ => cmd}/load.rst (100%) rename doc/usage/{ => cmd}/loady.rst (100%) rename doc/usage/{ => cmd}/mbr.rst (100%) rename doc/usage/{ => cmd}/md.rst (99%) rename doc/usage/{ => cmd}/mmc.rst (90%) rename doc/usage/{ => cmd}/pinmux.rst (100%) rename doc/usage/{ => cmd}/pstore.rst (100%) rename doc/usage/{ => cmd}/qfw.rst (100%) rename doc/usage/{ => cmd}/reset.rst (100%) rename doc/usage/{ => cmd}/sbi.rst (100%) rename doc/usage/{ => cmd}/scp03.rst (100%) rename doc/usage/{ => cmd}/setexpr.rst (100%) rename doc/usage/{ => cmd}/sf.rst (100%) rename doc/usage/{ => cmd}/size.rst (100%) rename doc/usage/{ => cmd}/true.rst (100%) rename doc/usage/{ => cmd}/ums.rst (100%) rename doc/usage/{ => cmd}/wdt.rst (100%) rename doc/{README.plan9 => usage/os/plan9.rst} (89%) rename doc/{README.vxworks => usage/os/vxworks.rst} (89%)
On Fri, Apr 01, 2022 at 03:21:14AM +0200, Heinrich Schuchardt wrote:
Dear Tom,
