[U-Boot] [PATCH] ARM: davinci: fixes for cam_enc_4xx board
- change CONFIG_ENV_RANGE to contain 2 nand erase blocks, one for bad block reserve. - remove from the envvariable "img_writeramdisk" the ubifsmount command, as it is not needed. - erase the hole mtd partition containing u-boot - save environment variable "dvn_app_vers" and "dvn_boot_vers" only after installing the new image. changes requested from Marek Vasut: - arm, davinci: fix eldk-4.2 warnings for cam_enc_4xx board - get rid of run_command2 usage needed since patch: commit 009dde1955583e306cf904c864068f3acb0db499 Author: Simon Glass sjg@chromium.org Date: Tue Feb 14 19:59:20 2012 +0000
Rename run_command2() to run_command() is now in mainline. - add CONFIG_SPL_LIBGENERIC_SUPPORT support - remove CONFIG_CMD_PXE support - fix warning: cam_enc_4xx.c: In function 'menu_handle': cam_enc_4xx.c:609: warning: dereferencing type-punned pointer will break strict-aliasing rules - fix error: arm-linux-ld: u-boot-spl: Not enough room for program headers, try linking with -N
Signed-off-by: Heiko Schocher hs@denx.de Cc: Marek Vasut marex@denx.de Cc: Tom Rini tom.rini@gmail.com Cc: Fletzer Martin Martin.Fletzer@ait.ac.at Cc: Wolfgang Denk wd@denx.de --- board/ait/cam_enc_4xx/cam_enc_4xx.c | 55 ++++++++++++++++++++++++---------- board/ait/cam_enc_4xx/config.mk | 7 ++++ board/ait/cam_enc_4xx/u-boot-spl.lds | 2 +- include/configs/cam_enc_4xx.h | 13 ++++---- 4 files changed, 54 insertions(+), 23 deletions(-)
diff --git a/board/ait/cam_enc_4xx/cam_enc_4xx.c b/board/ait/cam_enc_4xx/cam_enc_4xx.c index bb29cf3..32b28f9 100644 --- a/board/ait/cam_enc_4xx/cam_enc_4xx.c +++ b/board/ait/cam_enc_4xx/cam_enc_4xx.c @@ -21,6 +21,7 @@
#include <common.h> #include <errno.h> +#include <hush.h> #include <linux/mtd/nand.h> #include <nand.h> #include <miiphy.h> @@ -554,7 +555,7 @@ static char *menu_handle(struct menu_display *display) { struct menu *m; int i; - char *choice = NULL; + void *choice = NULL; char key[2]; int ret; char *s; @@ -606,7 +607,7 @@ static char *menu_handle(struct menu_display *display) sprintf(key, "%d", 1); menu_default_set(m, key);
- if (menu_get_choice(m, (void **)&choice) != 1) + if (menu_get_choice(m, &choice) != 1) debug("Problem picking a choice!\n");
menu_destroy(m); @@ -653,7 +654,7 @@ static int ait_writeublheader(void) sprintf(s, "%lx", i); ret = setenv("header_addr", s); if (ret == 0) - ret = run_command2("run img_writeheader", 0); + ret = run_command("run img_writeheader", 0); if (ret != 0) break; } @@ -697,7 +698,7 @@ static int ait_menu_install_images(void) setenv("filesize", s); switch (imgs[count].subtype) { case FIT_SUBTYPE_DF_ENV_IMAGE: - ret = run_command2("run img_writedfenv", 0); + ret = run_command("run img_writedfenv", 0); break; case FIT_SUBTYPE_RAMDISK_IMAGE: t = getenv("img_volume"); @@ -713,16 +714,16 @@ static int ait_menu_install_images(void) if (ret != 0) break;
- ret = run_command2("run img_writeramdisk", 0); + ret = run_command("run img_writeramdisk", 0); break; case FIT_SUBTYPE_SPL_IMAGE: - ret = run_command2("run img_writespl", 0); + ret = run_command("run img_writespl", 0); break; case FIT_SUBTYPE_UBL_HEADER: ret = ait_writeublheader(); break; case FIT_SUBTYPE_UBOOT_IMAGE: - ret = run_command2("run img_writeuboot", 0); + ret = run_command("run img_writeuboot", 0); break; default: /* not supported type */ @@ -731,8 +732,19 @@ static int ait_menu_install_images(void) count++; } /* now save dvn_* and img_volume env vars to new values */ - if (ret == 0) - ret = run_command2("run savenewvers", 0); + if (ret == 0) { + t = getenv("x_dvn_boot_vers"); + if (t) + setenv("dvn_boot_vers", t); + + t = getenv("x_dvn_app_vers"); + if (t) + setenv("dvn_boot_vers", t); + + setenv("x_dvn_boot_vers", NULL); + setenv("x_dvn_app_vers", NULL); + ret = run_command("run savenewvers", 0); + }
return ret; } @@ -749,6 +761,8 @@ static int ait_menu_evaluate_load(char *choice) break; case '2': /* cancel, back to main */ + setenv("x_dvn_boot_vers", NULL); + setenv("x_dvn_app_vers", NULL); break; }
@@ -961,7 +975,7 @@ static int ait_menu_check_image(void) if (s) { ret = strcmp(s, imgs[found_uboot].desc); if (ret != 0) { - setenv("dvn_boot_vers", + setenv("x_dvn_boot_vers", imgs[found_uboot].desc); } else { found_uboot = -1; @@ -976,7 +990,7 @@ static int ait_menu_check_image(void) if (s) { ret = strcmp(s, imgs[found_ramdisk].desc); if (ret != 0) { - setenv("dvn_app_vers", + setenv("x_dvn_app_vers", imgs[found_ramdisk].desc); } else { found_ramdisk = -1; @@ -1005,7 +1019,7 @@ static int ait_menu_evaluate_update(char *choice) break; case '2': /* load image */ - ret = run_command2("run load_img", 0); + ret = run_command("run load_img", 0); printf("ret: %d\n", ret); if (ret) return MENU_UPDATE; @@ -1073,9 +1087,9 @@ int menu_show(int bootdelay) { int ret;
- run_command2("run saveparms", 0); + run_command("run saveparms", 0); ret = ait_menu_show(&ait_main, bootdelay); - run_command2("run restoreparms", 0); + run_command("run restoreparms", 0);
if (ret == MENU_EXIT_BOOTCMD) return 0; @@ -1085,8 +1099,17 @@ int menu_show(int bootdelay)
void menu_display_statusline(struct menu *m) { - printf("State: dvn_boot_vers: %s dvn_app_vers: %s\n", - getenv("dvn_boot_vers"), getenv("dvn_app_vers")); + char *s1, *s2; + + s1 = getenv("x_dvn_boot_vers"); + if (!s1) + s1 = getenv("dvn_boot_vers"); + + s2 = getenv("x_dvn_app_vers"); + if (!s2) + s2 = getenv("dvn_app_vers"); + + printf("State: dvn_boot_vers: %s dvn_app_vers: %s\n", s1, s2); return; } #endif diff --git a/board/ait/cam_enc_4xx/config.mk b/board/ait/cam_enc_4xx/config.mk index b1f9b6c..744b927 100644 --- a/board/ait/cam_enc_4xx/config.mk +++ b/board/ait/cam_enc_4xx/config.mk @@ -12,4 +12,11 @@ PAD_TO := 12320 UBL_CONFIG = $(SRCTREE)/board/$(BOARDDIR)/ublimage.cfg ifndef CONFIG_SPL_BUILD ALL-y += $(obj)u-boot.ubl +else +# as SPL_TEXT_BASE is not page-aligned, we need for some +# linkers the -n flag (Do not page align data), to prevent +# the following error message: +# arm-linux-ld: u-boot-spl: Not enough room for program headers, try linking +# with -N +LDFLAGS_u-boot-spl += -n endif diff --git a/board/ait/cam_enc_4xx/u-boot-spl.lds b/board/ait/cam_enc_4xx/u-boot-spl.lds index 6f6e065..52c986e 100644 --- a/board/ait/cam_enc_4xx/u-boot-spl.lds +++ b/board/ait/cam_enc_4xx/u-boot-spl.lds @@ -32,7 +32,7 @@ OUTPUT_ARCH(arm) ENTRY(_start) SECTIONS { - . = 0x00000000; + . = CONFIG_SPL_TEXT_BASE;
. = ALIGN(4); .text : diff --git a/include/configs/cam_enc_4xx.h b/include/configs/cam_enc_4xx.h index 0fee53f..99856eb 100644 --- a/include/configs/cam_enc_4xx.h +++ b/include/configs/cam_enc_4xx.h @@ -161,15 +161,14 @@ #define CONFIG_MENU #define CONFIG_MENU_SHOW #define CONFIG_FIT -#define CONFIG_CMD_PXE #define CONFIG_BOARD_IMG_ADDR_R 0x80000000
#ifdef CONFIG_NAND_DAVINCI #define CONFIG_ENV_SIZE (16 << 10) #define CONFIG_ENV_IS_IN_NAND #define CONFIG_ENV_OFFSET 0x180000 +#define CONFIG_ENV_RANGE 0x040000 #define CONFIG_ENV_OFFSET_REDUND 0x1c0000 -#define CONFIG_ENV_RANGE 0x020000 #undef CONFIG_ENV_IS_IN_FLASH #endif
@@ -220,6 +219,7 @@
/* Defines for SPL */ #define CONFIG_SPL +#define CONFIG_SPL_LIBGENERIC_SUPPORT #define CONFIG_SPL_NAND_SUPPORT #define CONFIG_SPL_NAND_SIMPLE #define CONFIG_SPL_NAND_LOAD @@ -229,7 +229,7 @@ #define CONFIG_SPL_LDSCRIPT "$(BOARDDIR)/u-boot-spl.lds" #define CONFIG_SPL_STACK (0x00010000 + 0x7f00)
-#define CONFIG_SPL_TEXT_BASE 0x0000020 /*CONFIG_SYS_SRAM_START*/ +#define CONFIG_SPL_TEXT_BASE 0x00000020 /*CONFIG_SYS_SRAM_START*/ #define CONFIG_SPL_MAX_SIZE 12320
#ifndef CONFIG_SPL_BUILD @@ -274,6 +274,7 @@
#define CONFIG_SYS_NAND_U_BOOT_OFFS 0x80000 #define CONFIG_SYS_NAND_U_BOOT_SIZE 0xa0000 +#define CONFIG_SYS_NAND_U_BOOT_ERA_SIZE 0x100000
/* for UBL header */ #define CONFIG_SYS_UBL_BLOCK (CONFIG_SYS_NAND_PAGE_SIZE) @@ -429,7 +430,7 @@ " 0 3000;nandrbl uboot\0" \ "writeuboot=nandrbl uboot;" \ "nand erase " xstr(CONFIG_SYS_NAND_U_BOOT_OFFS) " " \ - xstr(CONFIG_SYS_NAND_U_BOOT_SIZE) \ + xstr(CONFIG_SYS_NAND_U_BOOT_ERA_SIZE) \ ";nand write " xstr(DVN4XX_UBOOT_ADDR_R_UBOOT) \ " " xstr(CONFIG_SYS_NAND_U_BOOT_OFFS) " " \ xstr(CONFIG_SYS_NAND_U_BOOT_SIZE) "\0" \ @@ -466,14 +467,14 @@ "nand write ${img_addr_r} 0 3000;nandrbl uboot\0" \ "img_writeuboot=nandrbl uboot;" \ "nand erase " xstr(CONFIG_SYS_NAND_U_BOOT_OFFS) " " \ - xstr(CONFIG_SYS_NAND_U_BOOT_SIZE) \ + xstr(CONFIG_SYS_NAND_U_BOOT_ERA_SIZE) \ ";nand write ${img_addr_r} " \ xstr(CONFIG_SYS_NAND_U_BOOT_OFFS) " " \ xstr(CONFIG_SYS_NAND_U_BOOT_SIZE) "\0" \ "img_writedfenv=ubi part ubi 2048;" \ "ubi write ${img_addr_r} default ${filesize}\0" \ "img_volume=rootfs1\0" \ - "img_writeramdisk=ubi part ubi 2048;ubifsmount ${img_volume};" \ + "img_writeramdisk=ubi part ubi 2048;" \ "ubi write ${img_addr_r} ${img_volume} ${filesize}\0" \ "load_img=tftp ${fit_addr_r} ${img_file}\0" \ "net_nfs=run load_kernel; " \
Heiko Schocher
