[U-Boot] [PATCH v1 0/9] ARM: Odroid XU3: Enable DM_MMC support which is necessary for CONFIG_BLK
This patch series provides following improvements to Odroid XU3: - Fix sdr_timing problem with DW_MMC running with DM - Clean up the defconfig file - Allow default booting via SD card - Fix potential memory leak when running under DM (DW_MMC) Travis-CI: https://travis-ci.org/lmajewski/u-boot-dfu/builds/408080614
Lukasz Majewski (9): ARM: dw_mmc: Exclude dwmci Exynos priv_data allocation from exynos_dwmci_get_config() ARM: Odroid XU3: config: Disable SDHCI support in the Odroid XU3 ARM: Odroid XU3: Enable driver model support for MMC (DM_MMC) ARM: Odroid XU3: Fix autoboot.cmd to use ${mmcbootdev} instead of hardcoded 0 ARM: Odroid XU3: Adjust BOOT_TARGET_DEVICES to allow booting from SD card (mmc2) ARM: Odroid XU3: MAINTAINERS: Add a co-maintainer for OdroidXU3 ARM: Odroid XU3: Fix the dwmci_exynos *priv data assignment for DM_MMC (sdr_timing) ARM: Odroid XU3: Modify exynos dw_mmc driver to support Odroid XU3 in DM MMC ARM: Odroid XU3: Modify Odroid XU3 config to boot by default from SD card
board/samsung/common/bootscripts/autoboot.cmd | 6 ++--- board/samsung/smdk5420/MAINTAINERS | 1 + configs/odroid-xu3_defconfig | 3 +-- drivers/mmc/exynos_dw_mmc.c | 37 +++++++++++++++------------ include/configs/exynos5-common.h | 1 + include/configs/odroid_xu3.h | 7 +++-- 6 files changed, 32 insertions(+), 23 deletions(-)
This commit prevents memory leak when this function is used with DM_MMC as the struct dwmci_exynos_priv_data is already allocated by DM.
It is necessary for NON DM aware devices to allocate this struct first.
Signed-off-by: Lukasz Majewski lukma@denx.de ---
drivers/mmc/exynos_dw_mmc.c | 30 +++++++++++++++--------------- 1 file changed, 15 insertions(+), 15 deletions(-)
diff --git a/drivers/mmc/exynos_dw_mmc.c b/drivers/mmc/exynos_dw_mmc.c index 865fdf4dbba0..49c4f7634830 100644 --- a/drivers/mmc/exynos_dw_mmc.c +++ b/drivers/mmc/exynos_dw_mmc.c @@ -146,17 +146,11 @@ static int do_dwmci_init(struct dwmci_host *host) }
static int exynos_dwmci_get_config(const void *blob, int node, - struct dwmci_host *host) + struct dwmci_host *host, + struct dwmci_exynos_priv_data *priv) { int err = 0; u32 base, timing[3]; - struct dwmci_exynos_priv_data *priv; - - priv = malloc(sizeof(struct dwmci_exynos_priv_data)); - if (!priv) { - pr_err("dwmci_exynos_priv_data malloc fail!\n"); - return -ENOMEM; - }
/* Extract device id for each mmc channel */ host->dev_id = pinmux_decode_periph_id(blob, node); @@ -167,7 +161,6 @@ static int exynos_dwmci_get_config(const void *blob, int node,
if (host->dev_index > 4) { printf("DWMMC%d: Can't get the dev index\n", host->dev_index); - free(priv); return -EINVAL; }
@@ -178,7 +171,6 @@ static int exynos_dwmci_get_config(const void *blob, int node, base = fdtdec_get_addr(blob, node, "reg"); if (!base) { printf("DWMMC%d: Can't get base address\n", host->dev_index); - free(priv); return -EINVAL; } host->ioaddr = (void *)base; @@ -188,7 +180,6 @@ static int exynos_dwmci_get_config(const void *blob, int node, if (err) { printf("DWMMC%d: Can't get sdr-timings for devider\n", host->dev_index); - free(priv); return -EINVAL; }
@@ -208,14 +199,13 @@ static int exynos_dwmci_get_config(const void *blob, int node, host->bus_hz = fdtdec_get_int(blob, node, "bus_hz", 0); host->div = fdtdec_get_int(blob, node, "div", 0);
- host->priv = priv; - return 0; }
static int exynos_dwmci_process_node(const void *blob, int node_list[], int count) { + struct dwmci_exynos_priv_data *priv; struct dwmci_host *host; int i, node, err;
@@ -224,11 +214,20 @@ static int exynos_dwmci_process_node(const void *blob, if (node <= 0) continue; host = &dwmci_host[i]; - err = exynos_dwmci_get_config(blob, node, host); + + priv = malloc(sizeof(struct dwmci_exynos_priv_data)); + if (!priv) { + pr_err("dwmci_exynos_priv_data malloc fail!\n"); + return -ENOMEM; + } + + err = exynos_dwmci_get_config(blob, node, host, priv); if (err) { printf("%s: failed to decode dev %d\n", __func__, i); + free(priv); return err; } + host->priv = priv;
do_dwmci_init(host); } @@ -266,7 +265,8 @@ static int exynos_dwmmc_probe(struct udevice *dev) struct dwmci_host *host = &priv->host; int err;
- err = exynos_dwmci_get_config(gd->fdt_blob, dev_of_offset(dev), host); + err = exynos_dwmci_get_config(gd->fdt_blob, dev_of_offset(dev), host, + priv); if (err) return err; err = do_dwmci_init(host);
Hi Lukasz
if (!priv) {
return -ENOMEM;
} /* Extract device id for each mmc channel */ host->dev_id = pinmux_decode_periph_id(blob, node);
host->priv = priv;
if (!priv) {
return -ENOMEM;
host->priv = priv; do_dwmci_init(host); }
-- 2.11.0
Please add my. Tested-by: Anand Moon linux.amoon@gmail.com
Best Regards -Anand
The Exynos5422 is solely using DW MMC IP block to support eMMC/SD devices, hence the SDHCI code doesn't need to be compiled it.
configs/odroid-xu3_defconfig | 2 -- 1 file changed, 2 deletions(-)
diff --git a/configs/odroid-xu3_defconfig b/configs/odroid-xu3_defconfig index 5943c19cf9b3..6398c2cd0d6a 100644 --- a/configs/odroid-xu3_defconfig +++ b/configs/odroid-xu3_defconfig @@ -30,8 +30,6 @@ CONFIG_ADC=y CONFIG_ADC_EXYNOS=y CONFIG_DFU_MMC=y CONFIG_MMC_DW=y -CONFIG_MMC_SDHCI=y -CONFIG_MMC_SDHCI_S5P=y CONFIG_NETDEVICES=y CONFIG_SMC911X=y CONFIG_SMC911X_BASE=0x5000000
Hi Lukasz
diff --git a/configs/odroid-xu3_defconfig b/configs/odroid-xu3_defconfig index 5943c19cf9b3..6398c2cd0d6a 100644 --- a/configs/odroid-xu3_defconfig +++ b/configs/odroid-xu3_defconfig @@ -30,8 +30,6 @@ CONFIG_ADC=y CONFIG_ADC_EXYNOS=y CONFIG_DFU_MMC=y CONFIG_MMC_DW=y -CONFIG_MMC_SDHCI=y -CONFIG_MMC_SDHCI_S5P=y CONFIG_NETDEVICES=y CONFIG_SMC911X=y CONFIG_SMC911X_BASE=0x5000000 -- 2.11.0
Best Regards -Anand
This commit enables support for DW_MMC running with driver model.
configs/odroid-xu3_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/odroid-xu3_defconfig b/configs/odroid-xu3_defconfig index 6398c2cd0d6a..632542d98420 100644 --- a/configs/odroid-xu3_defconfig +++ b/configs/odroid-xu3_defconfig @@ -29,6 +29,7 @@ CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_ADC=y CONFIG_ADC_EXYNOS=y CONFIG_DFU_MMC=y +CONFIG_DM_MMC=y CONFIG_MMC_DW=y CONFIG_NETDEVICES=y CONFIG_SMC911X=y
Hi Lukasz
diff --git a/configs/odroid-xu3_defconfig b/configs/odroid-xu3_defconfig index 6398c2cd0d6a..632542d98420 100644 --- a/configs/odroid-xu3_defconfig +++ b/configs/odroid-xu3_defconfig @@ -29,6 +29,7 @@ CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_ADC=y CONFIG_ADC_EXYNOS=y CONFIG_DFU_MMC=y +CONFIG_DM_MMC=y CONFIG_MMC_DW=y CONFIG_NETDEVICES=y CONFIG_SMC911X=y -- 2.11.0
Best Regards -Anand
This commit adjusts the autoboot.cmd file to use ${mmcbootdev} instead of hardcoded value 0.
This is necessary to allow booting this board from the SD card.
board/samsung/common/bootscripts/autoboot.cmd | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/board/samsung/common/bootscripts/autoboot.cmd b/board/samsung/common/bootscripts/autoboot.cmd index 1faed8ba0c1a..11c724c4e095 100644 --- a/board/samsung/common/bootscripts/autoboot.cmd +++ b/board/samsung/common/bootscripts/autoboot.cmd @@ -74,15 +74,15 @@ setenv boot_img "
#### Routine: autoboot - choose proper boot path setenv autoboot " -if test -e mmc 0:${mmcbootpart} Image.itb; then +if test -e mmc ${mmcbootdev}:${mmcbootpart} Image.itb; then echo Found kernel image: Image.itb; run setboot_fit; run boot_img; -elif test -e mmc 0:${mmcbootpart} zImage; then +elif test -e mmc ${mmcbootdev}:${mmcbootpart} zImage; then echo Found kernel image: zImage; run setboot_zimg; run boot_img; -elif test -e mmc 0:${mmcbootpart} uImage; then +elif test -e mmc ${mmcbootdev}:${mmcbootpart} uImage; then echo Found kernel image: uImage; run setboot_uimg; run boot_img;
Hi Lukasz
#### Routine: autoboot - choose proper boot path setenv autoboot " -if test -e mmc 0:${mmcbootpart} Image.itb; then +if test -e mmc ${mmcbootdev}:${mmcbootpart} Image.itb; then echo Found kernel image: Image.itb; run setboot_fit; run boot_img; -elif test -e mmc 0:${mmcbootpart} zImage; then +elif test -e mmc ${mmcbootdev}:${mmcbootpart} zImage; then echo Found kernel image: zImage; run setboot_zimg; run boot_img; -elif test -e mmc 0:${mmcbootpart} uImage; then +elif test -e mmc ${mmcbootdev}:${mmcbootpart} uImage; then echo Found kernel image: uImage; run setboot_uimg; run boot_img; -- 2.11.0
Best Regards -Anand
This change is necessary to allow booting the Odroid XU3 from SD card after enabling the DM_MMC support.
After this change the SD card mmc IP block is correctly enumerated as mmc2 (and not as mmc1 as in the legacy code).
include/configs/exynos5-common.h | 1 + 1 file changed, 1 insertion(+)
diff --git a/include/configs/exynos5-common.h b/include/configs/exynos5-common.h index a7621fc701b2..cd2a9046afec 100644 --- a/include/configs/exynos5-common.h +++ b/include/configs/exynos5-common.h @@ -138,6 +138,7 @@ #define BOOT_TARGET_DEVICES(func) \ func(MMC, mmc, 1) \ func(MMC, mmc, 0) \ + func(MMC, mmc, 2) \ func(PXE, pxe, na) \ func(DHCP, dhcp, na)
Hi Lukasz,
-- 2.11.0
Best Regards -Anand
board/samsung/smdk5420/MAINTAINERS | 1 + 1 file changed, 1 insertion(+)
diff --git a/board/samsung/smdk5420/MAINTAINERS b/board/samsung/smdk5420/MAINTAINERS index 590a1140b07e..31c00360f287 100644 --- a/board/samsung/smdk5420/MAINTAINERS +++ b/board/samsung/smdk5420/MAINTAINERS @@ -11,6 +11,7 @@ F: configs/peach-pi_defconfig
ODROID-XU3 BOARD M: Jaehoon Chung jh80.chung@samsung.com +M: Lukasz Majewski lukma@denx.de S: Maintained F: board/samsung/smdk5420/ F: include/configs/odroid_xu3.h
By convention for DM_MMC the host->priv is used to store struct udevice *dev pointer.
Unfortunately, the legacy Exynos DW MMC code uses this field to store pointer to dwmci_exynos_priv_data struct Hence, we do need to get data in other way - namely by using container_of when host pointer is present. In this way the sdr_timing data is properly accessed.
drivers/mmc/exynos_dw_mmc.c | 6 +++++- 1 file changed, 5 insertions(+), 1 deletion(-)
diff --git a/drivers/mmc/exynos_dw_mmc.c b/drivers/mmc/exynos_dw_mmc.c index 49c4f7634830..cd0fa4c6341b 100644 --- a/drivers/mmc/exynos_dw_mmc.c +++ b/drivers/mmc/exynos_dw_mmc.c @@ -46,8 +46,12 @@ struct dwmci_exynos_priv_data { */ static void exynos_dwmci_clksel(struct dwmci_host *host) { +#ifdef CONFIG_DM_MMC + struct dwmci_exynos_priv_data *priv = + container_of(host, struct dwmci_exynos_priv_data, host); +#else struct dwmci_exynos_priv_data *priv = host->priv; - +#endif dwmci_writel(host, DWMCI_CLKSEL, priv->sdr_timing); }
Hi Lukasz,
-- 2.11.0
Best Regards -Anand
This commit enables support for Exynos Designware MMC driver based on DM.
drivers/mmc/exynos_dw_mmc.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/mmc/exynos_dw_mmc.c b/drivers/mmc/exynos_dw_mmc.c index cd0fa4c6341b..435ccac59421 100644 --- a/drivers/mmc/exynos_dw_mmc.c +++ b/drivers/mmc/exynos_dw_mmc.c @@ -295,6 +295,7 @@ static int exynos_dwmmc_bind(struct udevice *dev)
static const struct udevice_id exynos_dwmmc_ids[] = { { .compatible = "samsung,exynos4412-dw-mshc" }, + { .compatible = "samsung,exynos-dwmmc" }, { } };
Hi Lukasz,
-- 2.11.0
Best Regards -Anand
This commit allows by default booting Odroid XU3 from the SD card (when e.g. eMMC module is not present).
include/configs/odroid_xu3.h | 7 +++++-- 1 file changed, 5 insertions(+), 2 deletions(-)
diff --git a/include/configs/odroid_xu3.h b/include/configs/odroid_xu3.h index f495f6219ba9..818a06515cb2 100644 --- a/include/configs/odroid_xu3.h +++ b/include/configs/odroid_xu3.h @@ -94,6 +94,9 @@ #undef CONFIG_SYS_BOARD #define CONFIG_SYS_BOARD "odroid"
+#undef CONFIG_SYS_MMC_ENV_DEV +#define CONFIG_SYS_MMC_ENV_DEV 2 + /* Define new extra env settings, including DFU settings */ #undef CONFIG_EXTRA_ENV_SETTINGS #define CONFIG_EXTRA_ENV_SETTINGS \ @@ -105,8 +108,8 @@ "console=" CONFIG_DEFAULT_CONSOLE "\0"\ "fdtfile=exynos5422-odroidxu3.dtb\0" \ "boardname=odroidxu3\0" \ - "mmcbootdev=0\0" \ - "mmcrootdev=0\0" \ + "mmcbootdev=2\0" \ + "mmcrootdev=1\0" \ "mmcbootpart=1\0" \ "mmcrootpart=2\0" \ "dfu_alt_system="CONFIG_DFU_ALT_SYSTEM \
Hi Lukasz,
"mmcbootdev=0\0" \
"mmcrootdev=0\0" \
"mmcbootdev=2\0" \
-- 2.11.0
This changes probably breaks the booting from eMMC on Odroid-XU4
U-Boot 2018.07-00377-g80df37b417 (Jul 26 2018 - 10:50:16 +0000) for ODROID-XU3/XU4/HC1
CPU: Exynos5422 @ 800 MHz Model: Odroid XU3 based on EXYNOS5422 Board: Odroid XU3 based on EXYNOS5422 Type: xu4 DRAM: 2 GiB MMC: EXYNOS DWMMC: 0, EXYNOS DWMMC: 2 Loading Environment from MMC... Card did not respond to voltage select! *** Warning - No block device, using default environment
Failed (-5) In: serial Out: serial Err: serial Net: No ethernet found. Hit any key to stop autoboot: 0 MMC Device 1 not found no mmc device at slot 1 switch to partitions #0, OK mmc0(part 0) is current device Scanning mmc 0:1... Found U-Boot script /boot.scr 3069 bytes read in 6 ms (499 KiB/s) ## Executing script at 50000000 Card did not respond to voltage select! ** Bad device mmc 2 ** Card did not respond to voltage select! ** Bad device mmc 2 ** Card did not respond to voltage select! ** Bad device mmc 2 ** SCRIPT FAILED: continuing... 63776 bytes read in 7 ms (8.7 MiB/s) Card did not respond to voltage select! starting USB... USB0: USB EHCI 1.00 USB1: Register 2000140 NbrPorts 2 Starting the controller USB XHCI 1.00 USB2: Register 2000140 NbrPorts 2 Starting the controller USB XHCI 1.00 scanning bus 0 for devices... 1 USB Device(s) found scanning bus 1 for devices... 3 USB Device(s) found scanning bus 2 for devices... 2 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found scanning usb for ethernet devices... 1 Ethernet Device(s) found Waiting for Ethernet connection... done. BOOTP broadcast 1 BOOTP broadcast 2 DHCP client bound to address 10.0.0.144 (1021 ms) *** Warning: no boot file name; using '0A000090.img' Using r8152#0 device TFTP from server 0.0.0.0; our IP address is 10.0.0.144; sending through gateway 10.0.0.1 Filename '0A000090.img'. Load address: 0x43e00000 Loading: T
Best Regards -Anand
Hi Anand,
Hi Lukasz,
"mmcbootdev=0\0" \
"mmcrootdev=0\0" \
"mmcbootdev=2\0" \
-- 2.11.0
I suppose, that XU4 is also equipped with SD card slot as XU3.
Nonetheless, as I don't have eMMC card for mine XU3, the only way to boot my device is SD card.
If you believe that this may be a problem, then I can drop this patch.
Have you checked patches from 1-8? Does it work for you? If yes, please send tested-by tag.
Best Regards -Anand
Lukasz Majewski
DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de
Hi Lukasz,
On 26 July 2018 at 21:23, Lukasz Majewski lukma@denx.de wrote:
Hi Anand,
Hi Lukasz,
"mmcbootdev=0\0" \
"mmcrootdev=0\0" \
"mmcbootdev=2\0" \
-- 2.11.0
Yes you probably need to drop this patch, I had some tough time recovering my eMMC back to flash new u-boot.
I have tested my eMMC with default boot.scr its boot good. Need to modify the boot.scr to boot into SD card.
Best Regards -Anand
On Fri, 27 Jul 2018 08:34:15 +0530 Anand Moon linux.amoon@gmail.com wrote:
Hi Lukasz,
Hi Anand,
Hi Lukasz,
"mmcbootdev=0\0" \
"mmcrootdev=0\0" \
"mmcbootdev=2\0" \
-- 2.11.0
SD card has different layout than eMMC.
Despite above - you just shall need to apply patch 9/9 to get the board running from SD card.
Best Regards -Anand
Lukasz Majewski
Hi Lukasz,
Hi Lukasz,
Hi Anand,
Hi Lukasz,
"mmcbootdev=0\0" \
"mmcrootdev=0\0" \
"mmcbootdev=2\0" \
-- 2.11.0
Actually SD card are easy to modify and tune with just adding setenv mmcrootdev "1" to autoboot.cmd from sdcard.
but with eMMC module it's bit difficult to make this work, even if we modify the autoboot.cmd and with new boot.scr changes do not work out.
I have hard time to recover my eMMC module to boot again. well I have to boot from SD card with eMMC attach and then flash the new bootloader to eMMC to make this work.
best regards -Anand
On Fri, 27 Jul 2018 14:42:32 +0530 Anand Moon linux.amoon@gmail.com wrote:
Hi Lukasz,
Hi Lukasz,
Hi Anand,
Hi Lukasz,
"mmcbootdev=0\0" \
"mmcrootdev=0\0" \
"mmcbootdev=2\0" \
-- 2.11.0
Ach.... Ok, I see
The problem is when you have both attached - the eMMC and SD card.
In that case I always thought that one shall boot from eMMC and the SD card shall be used as an extra storage space.
Also, please keep in mind that IIRC the ROM first tries to boot from eMMC, so you need BL1, u-boot placed there if it is present.
best regards -Anand
Lukasz Majewski
Hi Lukasz,
Hi Lukasz,
Hi Lukasz,
Hi Anand,
Hi Lukasz,
On 26 July 2018 at 03:55, Lukasz Majewski lukma@denx.de wrote: > This commit allows by default booting Odroid XU3 from the SD > card (when e.g. eMMC module is not present). > > Signed-off-by: Lukasz Majewski lukma@denx.de > > --- > > include/configs/odroid_xu3.h | 7 +++++-- > 1 file changed, 5 insertions(+), 2 deletions(-) > > diff --git a/include/configs/odroid_xu3.h > b/include/configs/odroid_xu3.h index > f495f6219ba9..818a06515cb2 100644 --- > a/include/configs/odroid_xu3.h +++ > b/include/configs/odroid_xu3.h @@ -94,6 +94,9 @@ > #undef CONFIG_SYS_BOARD > #define CONFIG_SYS_BOARD "odroid" > > +#undef CONFIG_SYS_MMC_ENV_DEV > +#define CONFIG_SYS_MMC_ENV_DEV 2 > + > /* Define new extra env settings, including DFU settings */ > #undef CONFIG_EXTRA_ENV_SETTINGS > #define CONFIG_EXTRA_ENV_SETTINGS \ > @@ -105,8 +108,8 @@ > "console=" CONFIG_DEFAULT_CONSOLE "\0"\ > "fdtfile=exynos5422-odroidxu3.dtb\0" \ > "boardname=odroidxu3\0" \ > - "mmcbootdev=0\0" \ > - "mmcrootdev=0\0" \ > + "mmcbootdev=2\0" \ > + "mmcrootdev=1\0" \ > "mmcbootpart=1\0" \ > "mmcrootpart=2\0" \ > "dfu_alt_system="CONFIG_DFU_ALT_SYSTEM \ > -- > 2.11.0 >
Ach.... Ok, I see
Can we create a different board initialization file to fine tune the odroid xu3 platform. for example Odroid U3 has # board/samsung/odroid/odroid.c
where we can initialize for Odroid XU3 platform boards with following features. board_clock_init board_gpio_init exynos_power_init board_usb_init board_leds
Best Regards -Anand
On Tue, 31 Jul 2018 23:40:10 +0530 Anand Moon linux.amoon@gmail.com wrote:
Hi Lukasz,
Hi Lukasz,
Hi Lukasz,
Hi Anand,
> Hi Lukasz, > > On 26 July 2018 at 03:55, Lukasz Majewski lukma@denx.de > wrote: > > This commit allows by default booting Odroid XU3 from the > > SD card (when e.g. eMMC module is not present). > > > > Signed-off-by: Lukasz Majewski lukma@denx.de > > > > --- > > > > include/configs/odroid_xu3.h | 7 +++++-- > > 1 file changed, 5 insertions(+), 2 deletions(-) > > > > diff --git a/include/configs/odroid_xu3.h > > b/include/configs/odroid_xu3.h index > > f495f6219ba9..818a06515cb2 100644 --- > > a/include/configs/odroid_xu3.h +++ > > b/include/configs/odroid_xu3.h @@ -94,6 +94,9 @@ > > #undef CONFIG_SYS_BOARD > > #define CONFIG_SYS_BOARD "odroid" > > > > +#undef CONFIG_SYS_MMC_ENV_DEV > > +#define CONFIG_SYS_MMC_ENV_DEV 2 > > + > > /* Define new extra env settings, including DFU settings > > */ #undef CONFIG_EXTRA_ENV_SETTINGS > > #define CONFIG_EXTRA_ENV_SETTINGS \ > > @@ -105,8 +108,8 @@ > > "console=" CONFIG_DEFAULT_CONSOLE "\0"\ > > "fdtfile=exynos5422-odroidxu3.dtb\0" \ > > "boardname=odroidxu3\0" \ > > - "mmcbootdev=0\0" \ > > - "mmcrootdev=0\0" \ > > + "mmcbootdev=2\0" \ > > + "mmcrootdev=1\0" \ > > "mmcbootpart=1\0" \ > > "mmcrootpart=2\0" \ > > "dfu_alt_system="CONFIG_DFU_ALT_SYSTEM \ > > -- > > 2.11.0 > > > > This changes probably breaks the booting from eMMC on > Odroid-XU4
Ach.... Ok, I see
The idea was to use common board file (./board/samsung/common/board.c) for all Exynos5 based boards.
The potential differences were supposed to be added via device tree.
Above two can be achieved with driver model. Providing such functions would be a step back from full XU3/XU4 conversion to DM.
board_leds
Best Regards -Anand
Lukasz Majewski
Anand Moon
Lukasz Majewski
