[PATCH 0/1] imx8mm-cl-iot-gate-optee: add CONFIG_SPL_MMC and CONFIG_SPL_SERIAL
From: "Ying-Chun Liu (PaulLiu)" paul.liu@linaro.org
Previously these two options are called CONFIG_SPL_MMC_SUPPORT and CONFIG_SPL_SERIAL_SUPPORT. During the transition they are removed by accident. Thus adding them back.
This patch is a re-work of previously posted on mailing list. [PATCH] imx8mm-cl-iot-gate-optee: remove _SUPPORT from CONFIG_SPL_{MMC, SERIAL}
Ying-Chun Liu (PaulLiu) (1): imx8mm-cl-iot-gate-optee: add CONFIG_SPL_MMC and CONFIG_SPL_SERIAL
configs/imx8mm-cl-iot-gate-optee_defconfig | 2 ++ 1 file changed, 2 insertions(+)
Signed-off-by: Ying-Chun Liu (PaulLiu) paul.liu@linaro.org Cc: uboot-imx uboot-imx@nxp.com --- configs/imx8mm-cl-iot-gate-optee_defconfig | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/configs/imx8mm-cl-iot-gate-optee_defconfig b/configs/imx8mm-cl-iot-gate-optee_defconfig index 29d060166b..0fb4da6582 100644 --- a/configs/imx8mm-cl-iot-gate-optee_defconfig +++ b/configs/imx8mm-cl-iot-gate-optee_defconfig @@ -13,6 +13,8 @@ CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="imx8mm-cl-iot-gate-optee" CONFIG_SPL_TEXT_BASE=0x7E1000 CONFIG_TARGET_IMX8MM_CL_IOT_GATE_OPTEE=y +CONFIG_SPL_MMC=y +CONFIG_SPL_SERIAL=y CONFIG_SPL_DRIVERS_MISC=y CONFIG_SPL=y CONFIG_DISTRO_DEFAULTS=y
Reviewed-by: Fabio Estevam festevam@gmail.com
From: "Ying-Chun Liu (PaulLiu)" paul.liu@linaro.org Previously these two options are called CONFIG_SPL_MMC_SUPPORT and CONFIG_SPL_SERIAL_SUPPORT. During the transition they are removed by accident. Thus adding them back. Signed-off-by: Ying-Chun Liu (PaulLiu) paul.liu@linaro.org Cc: uboot-imx uboot-imx@nxp.com Reviewed-by: Fabio Estevam festevam@gmail.com
Best regards, Stefano Babic
Fabio Estevam
sbabic@denx.de
Ying-Chun Liu
