[PATCH] sunxi: Remove dead ifdefs in sunxi-common.h
As variables were moved to Kconfig, some of the surrounding ifdefs were left around, even though they were empty. Clean them up.
Signed-off-by: Samuel Holland samuel@sholland.org --- include/configs/sunxi-common.h | 15 --------------- 1 file changed, 15 deletions(-)
diff --git a/include/configs/sunxi-common.h b/include/configs/sunxi-common.h index 000f3864702..64a70f9375c 100644 --- a/include/configs/sunxi-common.h +++ b/include/configs/sunxi-common.h @@ -134,11 +134,6 @@ #define CONFIG_BOARD_SIZE_LIMIT 0x7e000 #endif
-#if CONFIG_MMC_SUNXI_SLOT_EXTRA != -1 -/* If we have two devices (most likely eMMC + MMC), favour the eMMC */ -#else -/* Otherwise, use the only device we have */ -#endif #define CONFIG_SYS_MMC_MAX_DEVICE 4 #endif
@@ -199,10 +194,6 @@
/* I2C */ -#if defined CONFIG_AXP152_POWER || defined CONFIG_AXP209_POWER || \ - defined CONFIG_SY8106A_POWER -#endif - #if defined CONFIG_I2C0_ENABLE || defined CONFIG_I2C1_ENABLE || \ defined CONFIG_I2C2_ENABLE || defined CONFIG_I2C3_ENABLE || \ defined CONFIG_I2C4_ENABLE || defined CONFIG_R_I2C_ENABLE @@ -232,12 +223,6 @@ extern int soft_i2c_gpio_scl; #define CONFIG_VIDEO_LCD_I2C_BUS -1 /* NA, but necessary to compile */ #endif
-/* PMU */ -#if defined CONFIG_AXP152_POWER || defined CONFIG_AXP209_POWER || \ - defined CONFIG_AXP221_POWER || defined CONFIG_AXP818_POWER || \ - defined CONFIG_SY8106A_POWER -#endif - #ifdef CONFIG_REQUIRE_SERIAL_CONSOLE #if CONFIG_CONS_INDEX == 1 #ifdef CONFIG_MACH_SUN9I
Indeed, thanks for the cleanup!
Reviewed-by: Andre Przywara andre.przywara@arm.com
Cheers, Andre
-#endif
-#endif
Andre Przywara
Samuel Holland
