[U-Boot] [PATCH] cmd: efidebug: fix a build error in show_efi_boot_opt()
I detected the following error in sandbox with Clang on Travis CI: +cmd/efidebug.c:703:15: error: result of comparison of constant 9223372036854775822 with expression of type 'int' is always false [-Werror,-Wtautological-constant-out-of-range-compare] + else if (ret == EFI_NOT_FOUND) + ~~~ ^ ~~~~~~~~~~~~~
Simply changing a type of 'ret' to efi_status_t will fix this error.
Signed-off-by: AKASHI Takahiro takahiro.akashi@linaro.org --- cmd/efidebug.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/cmd/efidebug.c b/cmd/efidebug.c index ef97e19d0735..09ac84e5ef0a 100644 --- a/cmd/efidebug.c +++ b/cmd/efidebug.c @@ -684,7 +684,7 @@ static void show_efi_boot_opt(int id) efi_guid_t guid; void *data = NULL; efi_uintn_t size; - int ret; + efi_status_t ret;
sprintf(var_name, "Boot%04X", id); p = var_name16;
- int ret;
efi_status_t ret;
Thanks for reporting this issue.
Please, adjust this line too:
if (ret == (int)EFI_BUFFER_TOO_SMALL) {
Best regards
Heinrich
- int ret;
efi_status_t ret;
Sure. -Takahiro Akashi
Best regards
Heinrich
AKASHI Takahiro
