[U-Boot] [PATCH] spi: xilinx: Remove unused variable
7 Aug
2012
7 Aug
'12
11:29 p.m.
Warning is:
xilinx_spi.c: In function 'spi_setup_slave': xilinx_spi.c:81: warning: unused variable 'regs'
Signed-off-by: Stephan Linz linz@li-pro.net CC: Michal Simek monstr@monstr.eu --- drivers/spi/xilinx_spi.c | 1 - 1 files changed, 0 insertions(+), 1 deletions(-)
diff --git a/drivers/spi/xilinx_spi.c b/drivers/spi/xilinx_spi.c index e563c19..52a4134 100644 --- a/drivers/spi/xilinx_spi.c +++ b/drivers/spi/xilinx_spi.c @@ -78,7 +78,6 @@ struct spi_slave *spi_setup_slave(unsigned int bus, unsigned int cs, unsigned int max_hz, unsigned int mode) { struct xilinx_spi_slave *xilspi; - struct xilinx_spi_reg *regs;
if (!spi_cs_is_valid(bus, cs)) { printf("XILSPI error: %s: unsupported bus %d / cs %d\n",
1.7.0.4
4657
Stephan Linz
