[U-Boot] [PATCH] imx: mx6sxsabresd: Add MCIMX28LCD display support
The i.MX6SX SABRESD board supports MCIMX28LCD (800x480x24) at LCDIF1 port, enable this display feature by adding relevant BSP codes and configurations.
Signed-off-by: Ye Li ye.li@nxp.com --- board/freescale/mx6sxsabresd/mx6sxsabresd.c | 61 +++++++++++++++++++++++++++ include/configs/mx6sxsabresd.h | 20 +++++++++ 2 files changed, 81 insertions(+), 0 deletions(-)
diff --git a/board/freescale/mx6sxsabresd/mx6sxsabresd.c b/board/freescale/mx6sxsabresd/mx6sxsabresd.c index 56dc020..886c883 100644 --- a/board/freescale/mx6sxsabresd/mx6sxsabresd.c +++ b/board/freescale/mx6sxsabresd/mx6sxsabresd.c @@ -59,6 +59,9 @@ DECLARE_GLOBAL_DATA_PTR; PAD_CTL_DSE_40ohm | PAD_CTL_HYS | \ PAD_CTL_ODE)
+#define LCD_PAD_CTRL (PAD_CTL_HYS | PAD_CTL_PUS_100K_UP | PAD_CTL_PUE | \ + PAD_CTL_PKE | PAD_CTL_SPEED_MED | PAD_CTL_DSE_40ohm) + int dram_init(void) { gd->ram_size = PHYS_SDRAM_SIZE; @@ -458,6 +461,60 @@ int board_qspi_init(void) } #endif
+#ifdef CONFIG_VIDEO_MXS +static iomux_v3_cfg_t const lcd_pads[] = { + MX6_PAD_LCD1_CLK__LCDIF1_CLK | MUX_PAD_CTRL(LCD_PAD_CTRL), + MX6_PAD_LCD1_ENABLE__LCDIF1_ENABLE | MUX_PAD_CTRL(LCD_PAD_CTRL), + MX6_PAD_LCD1_HSYNC__LCDIF1_HSYNC | MUX_PAD_CTRL(LCD_PAD_CTRL), + MX6_PAD_LCD1_VSYNC__LCDIF1_VSYNC | MUX_PAD_CTRL(LCD_PAD_CTRL), + MX6_PAD_LCD1_DATA00__LCDIF1_DATA_0 | MUX_PAD_CTRL(LCD_PAD_CTRL), + MX6_PAD_LCD1_DATA01__LCDIF1_DATA_1 | MUX_PAD_CTRL(LCD_PAD_CTRL), + MX6_PAD_LCD1_DATA02__LCDIF1_DATA_2 | MUX_PAD_CTRL(LCD_PAD_CTRL), + MX6_PAD_LCD1_DATA03__LCDIF1_DATA_3 | MUX_PAD_CTRL(LCD_PAD_CTRL), + MX6_PAD_LCD1_DATA04__LCDIF1_DATA_4 | MUX_PAD_CTRL(LCD_PAD_CTRL), + MX6_PAD_LCD1_DATA05__LCDIF1_DATA_5 | MUX_PAD_CTRL(LCD_PAD_CTRL), + MX6_PAD_LCD1_DATA06__LCDIF1_DATA_6 | MUX_PAD_CTRL(LCD_PAD_CTRL), + MX6_PAD_LCD1_DATA07__LCDIF1_DATA_7 | MUX_PAD_CTRL(LCD_PAD_CTRL), + MX6_PAD_LCD1_DATA08__LCDIF1_DATA_8 | MUX_PAD_CTRL(LCD_PAD_CTRL), + MX6_PAD_LCD1_DATA09__LCDIF1_DATA_9 | MUX_PAD_CTRL(LCD_PAD_CTRL), + MX6_PAD_LCD1_DATA10__LCDIF1_DATA_10 | MUX_PAD_CTRL(LCD_PAD_CTRL), + MX6_PAD_LCD1_DATA11__LCDIF1_DATA_11 | MUX_PAD_CTRL(LCD_PAD_CTRL), + MX6_PAD_LCD1_DATA12__LCDIF1_DATA_12 | MUX_PAD_CTRL(LCD_PAD_CTRL), + MX6_PAD_LCD1_DATA13__LCDIF1_DATA_13 | MUX_PAD_CTRL(LCD_PAD_CTRL), + MX6_PAD_LCD1_DATA14__LCDIF1_DATA_14 | MUX_PAD_CTRL(LCD_PAD_CTRL), + MX6_PAD_LCD1_DATA15__LCDIF1_DATA_15 | MUX_PAD_CTRL(LCD_PAD_CTRL), + MX6_PAD_LCD1_DATA16__LCDIF1_DATA_16 | MUX_PAD_CTRL(LCD_PAD_CTRL), + MX6_PAD_LCD1_DATA17__LCDIF1_DATA_17 | MUX_PAD_CTRL(LCD_PAD_CTRL), + MX6_PAD_LCD1_DATA18__LCDIF1_DATA_18 | MUX_PAD_CTRL(LCD_PAD_CTRL), + MX6_PAD_LCD1_DATA19__LCDIF1_DATA_19 | MUX_PAD_CTRL(LCD_PAD_CTRL), + MX6_PAD_LCD1_DATA20__LCDIF1_DATA_20 | MUX_PAD_CTRL(LCD_PAD_CTRL), + MX6_PAD_LCD1_DATA21__LCDIF1_DATA_21 | MUX_PAD_CTRL(LCD_PAD_CTRL), + MX6_PAD_LCD1_DATA22__LCDIF1_DATA_22 | MUX_PAD_CTRL(LCD_PAD_CTRL), + MX6_PAD_LCD1_DATA23__LCDIF1_DATA_23 | MUX_PAD_CTRL(LCD_PAD_CTRL), + MX6_PAD_LCD1_RESET__GPIO3_IO_27 | MUX_PAD_CTRL(NO_PAD_CTRL), + + /* Use GPIO for Brightness adjustment, duty cycle = period */ + MX6_PAD_SD1_DATA2__GPIO6_IO_4 | MUX_PAD_CTRL(NO_PAD_CTRL), +}; + +static int setup_lcd(void) +{ + enable_lcdif_clock(LCDIF1_BASE_ADDR); + + imx_iomux_v3_setup_multiple_pads(lcd_pads, ARRAY_SIZE(lcd_pads)); + + /* Reset the LCD */ + gpio_direction_output(IMX_GPIO_NR(3, 27) , 0); + udelay(500); + gpio_direction_output(IMX_GPIO_NR(3, 27) , 1); + + /* Set Brightness to high */ + gpio_direction_output(IMX_GPIO_NR(6, 4) , 1); + + return 0; +} +#endif + int board_init(void) { /* Address of boot parameters */ @@ -471,6 +528,10 @@ int board_init(void) board_qspi_init(); #endif
+#ifdef CONFIG_VIDEO_MXS + setup_lcd(); +#endif + return 0; }
diff --git a/include/configs/mx6sxsabresd.h b/include/configs/mx6sxsabresd.h index 0aec296..29e9c08 100644 --- a/include/configs/mx6sxsabresd.h +++ b/include/configs/mx6sxsabresd.h @@ -36,6 +36,7 @@ "fdt_addr=0x88000000\0" \ "boot_fdt=try\0" \ "ip_dyn=yes\0" \ + "videomode=video=ctfb:x:800,y:480,depth:24,pclk:29850,le:89,ri:164,up:23,lo:10,hs:10,vs:10,sync:0,vmode:0\0" \ "mmcdev=2\0" \ "mmcpart=1\0" \ "mmcroot=/dev/mmcblk0p2 rootwait rw\0" \ @@ -195,6 +196,25 @@ #define FSL_QSPI_FLASH_NUM 2 #endif
+#ifndef CONFIG_SPL_BUILD +#define CONFIG_VIDEO +#ifdef CONFIG_VIDEO +#define CONFIG_CFB_CONSOLE +#define CONFIG_VIDEO_MXS +#define CONFIG_VIDEO_LOGO +#define CONFIG_VIDEO_SW_CURSOR +#define CONFIG_VGA_AS_SINGLE_DEVICE +#define CONFIG_SYS_CONSOLE_IS_IN_ENV +#define CONFIG_SPLASH_SCREEN +#define CONFIG_SPLASH_SCREEN_ALIGN +#define CONFIG_CMD_BMP +#define CONFIG_BMP_16BPP +#define CONFIG_VIDEO_BMP_RLE8 +#define CONFIG_VIDEO_BMP_LOGO +#define MXS_LCDIF_BASE MX6SX_LCDIF1_BASE_ADDR +#endif +#endif + #define CONFIG_ENV_OFFSET (8 * SZ_64K) #define CONFIG_ENV_SIZE SZ_8K #define CONFIG_ENV_IS_IN_MMC
- PAD_CTL_PKE | PAD_CTL_SPEED_MED | PAD_CTL_DSE_40ohm)
- MX6_PAD_LCD1_CLK__LCDIF1_CLK | MUX_PAD_CTRL(LCD_PAD_CTRL),
- MX6_PAD_LCD1_ENABLE__LCDIF1_ENABLE | MUX_PAD_CTRL(LCD_PAD_CTRL),
- MX6_PAD_LCD1_HSYNC__LCDIF1_HSYNC | MUX_PAD_CTRL(LCD_PAD_CTRL),
- MX6_PAD_LCD1_VSYNC__LCDIF1_VSYNC | MUX_PAD_CTRL(LCD_PAD_CTRL),
- MX6_PAD_LCD1_DATA00__LCDIF1_DATA_0 | MUX_PAD_CTRL(LCD_PAD_CTRL),
- MX6_PAD_LCD1_DATA01__LCDIF1_DATA_1 | MUX_PAD_CTRL(LCD_PAD_CTRL),
- MX6_PAD_LCD1_DATA02__LCDIF1_DATA_2 | MUX_PAD_CTRL(LCD_PAD_CTRL),
- MX6_PAD_LCD1_DATA03__LCDIF1_DATA_3 | MUX_PAD_CTRL(LCD_PAD_CTRL),
- MX6_PAD_LCD1_DATA04__LCDIF1_DATA_4 | MUX_PAD_CTRL(LCD_PAD_CTRL),
- MX6_PAD_LCD1_DATA05__LCDIF1_DATA_5 | MUX_PAD_CTRL(LCD_PAD_CTRL),
- MX6_PAD_LCD1_DATA06__LCDIF1_DATA_6 | MUX_PAD_CTRL(LCD_PAD_CTRL),
- MX6_PAD_LCD1_DATA07__LCDIF1_DATA_7 | MUX_PAD_CTRL(LCD_PAD_CTRL),
- MX6_PAD_LCD1_DATA08__LCDIF1_DATA_8 | MUX_PAD_CTRL(LCD_PAD_CTRL),
- MX6_PAD_LCD1_DATA09__LCDIF1_DATA_9 | MUX_PAD_CTRL(LCD_PAD_CTRL),
- MX6_PAD_LCD1_DATA10__LCDIF1_DATA_10 | MUX_PAD_CTRL(LCD_PAD_CTRL),
- MX6_PAD_LCD1_DATA11__LCDIF1_DATA_11 | MUX_PAD_CTRL(LCD_PAD_CTRL),
- MX6_PAD_LCD1_DATA12__LCDIF1_DATA_12 | MUX_PAD_CTRL(LCD_PAD_CTRL),
- MX6_PAD_LCD1_DATA13__LCDIF1_DATA_13 | MUX_PAD_CTRL(LCD_PAD_CTRL),
- MX6_PAD_LCD1_DATA14__LCDIF1_DATA_14 | MUX_PAD_CTRL(LCD_PAD_CTRL),
- MX6_PAD_LCD1_DATA15__LCDIF1_DATA_15 | MUX_PAD_CTRL(LCD_PAD_CTRL),
- MX6_PAD_LCD1_DATA16__LCDIF1_DATA_16 | MUX_PAD_CTRL(LCD_PAD_CTRL),
- MX6_PAD_LCD1_DATA17__LCDIF1_DATA_17 | MUX_PAD_CTRL(LCD_PAD_CTRL),
- MX6_PAD_LCD1_DATA18__LCDIF1_DATA_18 | MUX_PAD_CTRL(LCD_PAD_CTRL),
- MX6_PAD_LCD1_DATA19__LCDIF1_DATA_19 | MUX_PAD_CTRL(LCD_PAD_CTRL),
- MX6_PAD_LCD1_DATA20__LCDIF1_DATA_20 | MUX_PAD_CTRL(LCD_PAD_CTRL),
- MX6_PAD_LCD1_DATA21__LCDIF1_DATA_21 | MUX_PAD_CTRL(LCD_PAD_CTRL),
- MX6_PAD_LCD1_DATA22__LCDIF1_DATA_22 | MUX_PAD_CTRL(LCD_PAD_CTRL),
- MX6_PAD_LCD1_DATA23__LCDIF1_DATA_23 | MUX_PAD_CTRL(LCD_PAD_CTRL),
- MX6_PAD_LCD1_RESET__GPIO3_IO_27 | MUX_PAD_CTRL(NO_PAD_CTRL),
- /* Use GPIO for Brightness adjustment, duty cycle = period */
- MX6_PAD_SD1_DATA2__GPIO6_IO_4 | MUX_PAD_CTRL(NO_PAD_CTRL),
- enable_lcdif_clock(LCDIF1_BASE_ADDR);
- imx_iomux_v3_setup_multiple_pads(lcd_pads, ARRAY_SIZE(lcd_pads));
- /* Reset the LCD */
- gpio_direction_output(IMX_GPIO_NR(3, 27) , 0);
- udelay(500);
- gpio_direction_output(IMX_GPIO_NR(3, 27) , 1);
- /* Set Brightness to high */
- gpio_direction_output(IMX_GPIO_NR(6, 4) , 1);
+} +#endif
- setup_lcd();
- "videomode=video=ctfb:x:800,y:480,depth:24,pclk:29850,le:89,ri:164,up:23,lo:10,hs:10,vs:10,sync:0,vmode:0\0" \ "mmcdev=2\0" \ "mmcpart=1\0" \ "mmcroot=/dev/mmcblk0p2 rootwait rw\0" \
Best regards, Stefano Babic
Stefano Babic
Ye Li
