[PATCH] verdin-imx8m{m|p}: defconfig: update fastboot buffer size/address
Remove FASTBOOT_BUF_SIZE from verdin-imx8mm_defconfig and verdin-imx8mp_defconfig to use the default value of 0x7000000, aligning with other Toradex boards.
Update FASTBOOT_BUF_ADDR to 0x44200000, consistent with the value in previous downstream NXP U-Boot releases. This will make fastboot applications continue working with upstream U-Boot by using the same address.
Signed-off-by: Hiago De Franco hiago.franco@toradex.com --- configs/verdin-imx8mm_defconfig | 3 +-- configs/verdin-imx8mp_defconfig | 3 +-- 2 files changed, 2 insertions(+), 4 deletions(-)
diff --git a/configs/verdin-imx8mm_defconfig b/configs/verdin-imx8mm_defconfig index aa4a400c3c60..abb458df4a98 100644 --- a/configs/verdin-imx8mm_defconfig +++ b/configs/verdin-imx8mm_defconfig @@ -100,8 +100,7 @@ CONFIG_CLK_COMPOSITE_CCF=y CONFIG_SPL_CLK_IMX8MM=y CONFIG_CLK_IMX8MM=y CONFIG_USB_FUNCTION_FASTBOOT=y -CONFIG_FASTBOOT_BUF_ADDR=0x42800000 -CONFIG_FASTBOOT_BUF_SIZE=0x40000000 +CONFIG_FASTBOOT_BUF_ADDR=0x44200000 CONFIG_FASTBOOT_FLASH=y CONFIG_FASTBOOT_UUU_SUPPORT=y CONFIG_FASTBOOT_FLASH_MMC_DEV=0 diff --git a/configs/verdin-imx8mp_defconfig b/configs/verdin-imx8mp_defconfig index bf1a0b8badfa..661761f39774 100644 --- a/configs/verdin-imx8mp_defconfig +++ b/configs/verdin-imx8mp_defconfig @@ -112,8 +112,7 @@ CONFIG_CLK_COMPOSITE_CCF=y CONFIG_CLK_IMX8MP=y CONFIG_FSL_CAAM=y CONFIG_USB_FUNCTION_FASTBOOT=y -CONFIG_FASTBOOT_BUF_ADDR=0x42800000 -CONFIG_FASTBOOT_BUF_SIZE=0x40000000 +CONFIG_FASTBOOT_BUF_ADDR=0x44200000 CONFIG_FASTBOOT_FLASH=y CONFIG_FASTBOOT_UUU_SUPPORT=y CONFIG_FASTBOOT_FLASH_MMC_DEV=0
Reviewed-by: Francesco Dolcini francesco.dolcini@toradex.com
Applied, thanks.
Fabio Estevam
Francesco Dolcini
Hiago De Franco
